Hi everyone, since I switch to Manjaro I can’t make my scanner working. It worked very easy and without problems on EndeavourOS before. Printing via Cups is fine.
My Notebook can find the scanner.
scanimage -L
device `kyocera_wc3:192.168.1.90' is a Kyocera ECOSYS M5521cdn A4
device `airscan:w0:Kyocera ECOSYS M5521cdn' is a WSD Kyocera ECOSYS M5521cdn ip=192.168.1.90, 2003:f3:9701:d400:217:c8ff:feb8:bc31
If I try to scan via sane-airscan I get the error.
scanimage --device 'airscan:w0:Kyocera ECOSYS M5521cdn' --format=tiff --output-file test.tiff --progress
scanimage: sane_start: Device busy
Today I also try the kyocera-sane package from AUR but it’s not working too. In this case my scanner starts scanning, but then abort.
scanimage --verbose --device 'kyocera_wc3:192.168.1.90' --format=tiff --output-file test.tiff --progress
scanimage: sane_start: Document feeder out of documents
I hope someone can help. I spent some hours already with this problem, and I don’t have an idea what else I can do.
