KVM remote VM GUI: virt-viewer works - virt-manager don't work
Hi all,
I’m using virt-manager to access VM hosted on another machine; but the graphical console shows an empty window with the message
Connecting to graphical console for guest
The command to launch was
 LANG=C virt-manager --debug >virt-manager-log.txt 2>virt-manager-err.txt
From the error log I see
[sab, 28 mar 2026 11:49:24 virt-manager 8911] DEBUG (vmwindow:175) Showing VM details: <vmmDomain name=mserver01 id=0x7f267669a740>
[sab, 28 mar 2026 11:49:24 virt-manager 8911] DEBUG (engine:302) window counter incremented to 2
[sab, 28 mar 2026 11:49:24 virt-manager 8911] DEBUG (console:653) Starting connect process for proto=spice trans=ssh connhost=mostro connuser=mirto connport= gaddr=0.0.0.0 gport=5901 gtlsport=None gsocket=None
[sab, 28 mar 2026 11:49:24 virt-manager 8911] DEBUG (viewers:698) Spice connecting to host=mostro port=5901 tlsport=None
[sab, 28 mar 2026 11:49:31 virt-manager 8911] DEBUG (vmwindow:234) Closing VM details: <vmmDomain name=mserver01 id=0x7f267669a740>
[sab, 28 mar 2026 11:49:31 virt-manager 8911] DEBUG (console:556) Viewer object cleaned up
[sab, 28 mar 2026 11:49:31 virt-manager 8911] DEBUG (engine:309) window counter decremented to 1
[sab, 28 mar 2026 11:49:35 virt-manager 8911] DEBUG (manager:184) Closing manager
[sab, 28 mar 2026 11:49:35 virt-manager 8911] DEBUG (engine:309) window counter decremented to 0
[sab, 28 mar 2026 11:49:35 virt-manager 8911] DEBUG (engine:352) No windows found, requesting app exit
[sab, 28 mar 2026 11:49:35 virt-manager 8911] DEBUG (connection:858) conn.close() uri=qemu+ssh://mirto@mostro/system
[sab, 28 mar 2026 11:49:35 virt-manager 8911] DEBUG (connection:474) conn=qemu+ssh://mirto@mostro/system changed to state=Disconnected
[sab, 28 mar 2026 11:49:35 virt-manager 8911] DEBUG (connection:858) conn.close() uri=qemu:///system
[sab, 28 mar 2026 11:49:35 virt-manager 8911] DEBUG (connection:474) conn=qemu:///system changed to state=Disconnected
[sab, 28 mar 2026 11:49:35 virt-manager 8911] DEBUG (engine:378) Exiting app normally.
But If I use virt-viewer with the command
LANG=C virt-viewer -v -c qemu+ssh://mirto@mostro/system mserver01 >virt-viewer-log.txt 2>virt-viewer-err.txt
it works correctly and in the log I see
Opening connection to libvirt with URI qemu+ssh://mirto@mostro/system
Guest mserver01 is running, determining display
Guest mserver01 has a spice display
Opening indirect TCP connection to display at localhost:5901
Setting up SSH tunnel via mirto@mostro
Guest mserver01 display has disconnected, shutting down
The local machine, the server and the VM are all with Manjaro Plasma Wayland updated up to today.
What have I to do to use virt-manager for remote VM GUI?
X11. client-server systems via networking and wayland are still 2 universes that don’t match. wayland isn’t able to replace x11 in a 100% compatible.
Hi Mirto,
What does the complete output when starting virt-manager have to say:
This seems relevant:
@Olli Lets try to find a solution and not regurgitate all the know problems in the universe, this is a support thread.
Hi @Hanzel the suggested package python-tqdm is already installed.
The complete error log for
is:
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (cli:209) Version 5.1.0 launched with command line: /usr/bin/virt-manager --debug
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (virtmanager:198) virt-manager version: 5.1.0
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (virtmanager:199) virtManager import: /usr/share/virt-manager/virtManager
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (virtmanager:221) Using SSH_ASKPASS_REQUIRE=force
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (virtmanager:238) PyGObject version: 3.54.5
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (virtmanager:241) GTK version: 3.24.51
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (systray:477) Showing systray: True
(virt-manager:8911): Gtk-CRITICAL **: 11:49:14.759: gtk_widget_get_scale_factor: assertion 'GTK_IS_WIDGET (widget)' failed
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (inspection:210) python guestfs is not installed
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (engine:112) Loading stored URIs:
qemu:///system
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (engine:476) processing cli command uri= show_window=manager domain=
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (engine:486) No cli action requested, launching default window
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (manager:173) Showing manager
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (engine:302) window counter incremented to 1
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (engine:206) Initial gtkapplication activated
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (connection:474) conn=qemu:///system changed to state=Connecting
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (connection:922) Scheduling background open thread for qemu:///system
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (connection:129) libvirt URI versions library=12.1.0 driver=12.1.0 hypervisor=10.2.1
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (connection:110) Fetched capabilities for qemu:///system: <capabilities>
  <host>
    <uuid>8948eb88-eaec-cd1c-aa7d-d8bbc14d5eb1</uuid>
    <cpu>
      <arch>x86_64</arch>
      <model>EPYC-Rome-v5</model>
      <vendor>AMD</vendor>
      <microcode version='169873454'/>
      <signature family='25' model='33' stepping='0'/>
      <counter name='tsc' frequency='3800001000' scaling='yes'/>
      <topology sockets='1' dies='1' clusters='1' cores='8' threads='2'/>
      <maxphysaddr mode='emulate' bits='48'/>
      <feature name='monitor'/>
      <feature name='x2apic'/>
      <feature name='osxsave'/>
      <feature name='ht'/>
      <feature name='erms'/>
      <feature name='invpcid'/>
      <feature name='cmt'/>
      <feature name='pku'/>
      <feature name='ospke'/>
      <feature name='vaes'/>
      <feature name='vpclmulqdq'/>
      <feature name='fsrm'/>
      <feature name='xsaves'/>
      <feature name='mbm_total'/>
      <feature name='mbm_local'/>
      <feature name='cmp_legacy'/>
      <feature name='extapic'/>
      <feature name='ibs'/>
      <feature name='skinit'/>
      <feature name='wdt'/>
      <feature name='tce'/>
      <feature name='topoext'/>
      <feature name='perfctr_nb'/>
      <feature name='invtsc'/>
      <feature name='stibp-always-on'/>
      <feature name='amd-psfd'/>
      <feature name='svm-lock'/>
      <feature name='decodeassists'/>
      <feature name='avic'/>
      <feature name='svme-addr-chk'/>
      <feature name='no-nested-data-bp'/>
      <feature name='lfence-always-serializing'/>
      <feature name='null-sel-clr-base'/>
      <pages unit='KiB' size='4'/>
      <pages unit='KiB' size='2048'/>
      <pages unit='KiB' size='1048576'/>
    </cpu>
    <power_management>
      <suspend_mem/>
    </power_management>
    <iommu support='yes'/>
    <migration_features>
      <live/>
      <uri_transports>
        <uri_transport>tcp</uri_transport>
        <uri_transport>rdma</uri_transport>
      </uri_transports>
    </migration_features>
    <topology>
      <cells num='1'>
        <cell id='0'>
          <memory unit='KiB'>65762404</memory>
          <pages unit='KiB' size='4'>16440601</pages>
          <pages unit='KiB' size='2048'>0</pages>
          <pages unit='KiB' size='1048576'>0</pages>
          <distances>
            <sibling id='0' value='10'/>
          </distances>
          <cpus num='16'>
            <cpu id='0' socket_id='0' die_id='0' cluster_id='65535' core_id='0' siblings='0,8'/>
            <cpu id='1' socket_id='0' die_id='0' cluster_id='65535' core_id='1' siblings='1,9'/>
            <cpu id='2' socket_id='0' die_id='0' cluster_id='65535' core_id='2' siblings='2,10'/>
            <cpu id='3' socket_id='0' die_id='0' cluster_id='65535' core_id='3' siblings='3,11'/>
            <cpu id='4' socket_id='0' die_id='0' cluster_id='65535' core_id='4' siblings='4,12'/>
            <cpu id='5' socket_id='0' die_id='0' cluster_id='65535' core_id='5' siblings='5,13'/>
            <cpu id='6' socket_id='0' die_id='0' cluster_id='65535' core_id='6' siblings='6,14'/>
            <cpu id='7' socket_id='0' die_id='0' cluster_id='65535' core_id='7' siblings='7,15'/>
            <cpu id='8' socket_id='0' die_id='0' cluster_id='65535' core_id='0' siblings='0,8'/>
            <cpu id='9' socket_id='0' die_id='0' cluster_id='65535' core_id='1' siblings='1,9'/>
            <cpu id='10' socket_id='0' die_id='0' cluster_id='65535' core_id='2' siblings='2,10'/>
            <cpu id='11' socket_id='0' die_id='0' cluster_id='65535' core_id='3' siblings='3,11'/>
            <cpu id='12' socket_id='0' die_id='0' cluster_id='65535' core_id='4' siblings='4,12'/>
            <cpu id='13' socket_id='0' die_id='0' cluster_id='65535' core_id='5' siblings='5,13'/>
            <cpu id='14' socket_id='0' die_id='0' cluster_id='65535' core_id='6' siblings='6,14'/>
            <cpu id='15' socket_id='0' die_id='0' cluster_id='65535' core_id='7' siblings='7,15'/>
          </cpus>
        </cell>
      </cells>
    </topology>
    <cache>
      <bank id='0' level='2' type='both' size='512' unit='KiB' cpus='0,8'/>
      <bank id='1' level='2' type='both' size='512' unit='KiB' cpus='1,9'/>
      <bank id='2' level='2' type='both' size='512' unit='KiB' cpus='2,10'/>
      <bank id='3' level='2' type='both' size='512' unit='KiB' cpus='3,11'/>
      <bank id='4' level='2' type='both' size='512' unit='KiB' cpus='4,12'/>
      <bank id='5' level='2' type='both' size='512' unit='KiB' cpus='5,13'/>
      <bank id='6' level='2' type='both' size='512' unit='KiB' cpus='6,14'/>
      <bank id='7' level='2' type='both' size='512' unit='KiB' cpus='7,15'/>
      <bank id='0' level='3' type='both' size='32' unit='MiB' cpus='0-15'/>
    </cache>
    <secmodel>
      <model>none</model>
      <doi>0</doi>
    </secmodel>
    <secmodel>
      <model>dac</model>
      <doi>0</doi>
      <baselabel type='kvm'>+958:+958</baselabel>
      <baselabel type='qemu'>+958:+958</baselabel>
    </secmodel>
  </host>
  <guest>
    <os_type>hvm</os_type>
    <arch name='i686'>
      <wordsize>32</wordsize>
      <emulator>/usr/bin/qemu-system-i386</emulator>
      <machine maxCpus='255'>pc-i440fx-10.2</machine>
      <machine canonical='pc-i440fx-10.2' maxCpus='255'>pc</machine>
      <machine maxCpus='288' deprecated='yes'>pc-q35-5.2</machine>
      <machine maxCpus='255' deprecated='yes'>pc-i440fx-6.2</machine>
      <machine maxCpus='255' deprecated='yes'>pc-i440fx-5.2</machine>
      <machine maxCpus='4096'>pc-q35-9.1</machine>
      <machine maxCpus='288' deprecated='yes'>pc-q35-7.1</machine>
      <machine maxCpus='1024'>pc-q35-8.1</machine>
      <machine maxCpus='255'>pc-i440fx-8.1</machine>
      <machine maxCpus='288' deprecated='yes'>pc-q35-6.1</machine>
      <machine maxCpus='255'>pc-i440fx-9.1</machine>
      <machine maxCpus='4096'>pc-q35-10.0</machine>
      <machine maxCpus='255' deprecated='yes'>pc-i440fx-7.1</machine>
      <machine maxCpus='288' deprecated='yes'>pc-q35-5.1</machine>
      <machine maxCpus='255'>pc-i440fx-10.1</machine>
      <machine maxCpus='1'>x-remote</machine>
      <machine maxCpus='255' deprecated='yes'>pc-i440fx-6.1</machine>
      <machine maxCpus='255' deprecated='yes'>pc-i440fx-5.1</machine>
      <machine maxCpus='1'>isapc</machine>
      <machine maxCpus='4096'>pc-q35-9.0</machine>
      <machine maxCpus='4096'>pc-q35-10.2</machine>
      <machine canonical='pc-q35-10.2' maxCpus='4096'>q35</machine>
      <machine maxCpus='288' deprecated='yes'>pc-q35-7.0</machine>
      <machine maxCpus='288'>pc-q35-8.0</machine>
      <machine maxCpus='255'>pc-i440fx-8.0</machine>
      <machine maxCpus='288' deprecated='yes'>pc-q35-6.0</machine>
      <machine maxCpus='255'>pc-i440fx-9.0</machine>
      <machine maxCpus='288'>nitro-enclave</machine>
      <machine maxCpus='255' deprecated='yes'>pc-i440fx-7.0</machine>
      <machine maxCpus='288' deprecated='yes'>pc-q35-5.0</machine>
      <machine maxCpus='255'>pc-i440fx-10.0</machine>
      <machine maxCpus='4096'>pc-q35-9.2</machine>
      <machine maxCpus='255' deprecated='yes'>pc-i440fx-6.0</machine>
      <machine maxCpus='288' deprecated='yes'>pc-q35-7.2</machine>
      <machine maxCpus='288'>microvm</machine>
      <machine maxCpus='1024'>pc-q35-8.2</machine>
      <machine maxCpus='255'>pc-i440fx-8.2</machine>
      <machine maxCpus='255' deprecated='yes'>pc-i440fx-5.0</machine>
      <machine maxCpus='288' deprecated='yes'>pc-q35-6.2</machine>
      <machine maxCpus='255'>pc-i440fx-9.2</machine>
      <machine maxCpus='4096'>pc-q35-10.1</machine>
      <machine maxCpus='255' deprecated='yes'>pc-i440fx-7.2</machine>
      <domain type='qemu'/>
      <domain type='kvm'/>
    </arch>
    <features>
      <pae/>
      <nonpae/>
      <acpi default='on' toggle='yes'/>
      <apic default='on' toggle='no'/>
      <cpuselection/>
      <deviceboot/>
      <disksnapshot default='on' toggle='no'/>
      <externalSnapshot/>
    </features>
  </guest>
  <guest>
    <arch name='x86_64'>
      <wordsize>64</wordsize>
      <emulator>/usr/bin/qemu-system-x86_64</emulator>
    </arch>
    <features>
      <cpuselection/>
      <deviceboot/>
      <externalSnapshot/>
    </features>
  </guest>
</capabilities>
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (connection:755) Using domain events
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (connection:798) Using network events
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (connection:819) Using storage pool events
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (connection:843) Using node device events
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (connection:704) storage pool refresh event: pool=SATA1-VIRTIMAGES
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (connection:1101) network=dmz status=Active added
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (connection:1101) network=default status=Active added
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (connection:1101) network=int status=Active added
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (connection:1101) domain=debian12 status=Shutoff added
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (connection:1101) domain=h5a-serv status=Shutoff added
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (connection:704) storage pool refresh event: pool=ISO
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (connection:704) storage pool refresh event: pool=default
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (connection:704) storage pool refresh event: pool=SSD2-VIRTIMAGES
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (connection:1101) domain=manjaro-tor status=Shutoff added
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (connection:1101) domain=manjaro status=Shutoff added
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (connection:1101) domain=h5a-kw1 status=Shutoff added
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (connection:1101) pool=SATA1-VIRTIMAGES status=Active added
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (connection:1101) domain=manjaro-blender status=Shutoff added
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (connection:1101) domain=h5a-dev status=Shutoff added
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (connection:1101) domain=h5a-km status=Shutoff added
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (connection:1101) domain=h5a-kw2 status=Shutoff added
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (connection:1101) domain=h5a-kw3 status=Shutoff added
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (connection:1101) pool=ISO status=Active added
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (connection:1101) pool=default status=Active added
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (connection:1101) pool=SSD2-VIRTIMAGES status=Active added
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (storage:137) Found default pool name=default target=/var/lib/libvirt/images
[sab, 28 mar 2026 11:49:14 virt-manager 8911] DEBUG (connection:474) conn=qemu:///system changed to state=Active
[sab, 28 mar 2026 11:49:19 virt-manager 8911] DEBUG (connection:474) conn=qemu+ssh://mirto@mostro/system changed to state=Connecting
[sab, 28 mar 2026 11:49:19 virt-manager 8911] DEBUG (connection:922) Scheduling background open thread for qemu+ssh://mirto@mostro/system
[sab, 28 mar 2026 11:49:19 virt-manager 8911] DEBUG (connection:129) libvirt URI versions library=12.1.0 driver=12.1.0 hypervisor=10.2.1
[sab, 28 mar 2026 11:49:19 virt-manager 8911] DEBUG (connection:110) Fetched capabilities for qemu+ssh://mirto@mostro/system: <capabilities>
  <host>
    <uuid>9538cbfc-c848-a91b-af94-d8bbc10f8a33</uuid>
    <cpu>
      <arch>x86_64</arch>
      <microcode version='169873937'/>
      <signature family='25' model='33' stepping='2'/>
      <counter name='tsc' frequency='3400035000' scaling='yes'/>
      <topology sockets='1' dies='1' clusters='1' cores='16' threads='2'/>
    </cpu>
    <power_management>
      <suspend_mem/>
    </power_management>
      <live/>
      <uri_transports>
      </uri_transports>
    <topology>
      <cells num='1'>
        <cell id='0'>
          <memory unit='KiB'>131812312</memory>
          <pages unit='KiB' size='4'>32953078</pages>
          <distances>
          </distances>
          <cpus num='32'>
            <cpu id='0' socket_id='0' die_id='0' cluster_id='65535' core_id='0' siblings='0,16'/>
            <cpu id='1' socket_id='0' die_id='0' cluster_id='65535' core_id='1' siblings='1,17'/>
            <cpu id='2' socket_id='0' die_id='0' cluster_id='65535' core_id='2' siblings='2,18'/>
            <cpu id='3' socket_id='0' die_id='0' cluster_id='65535' core_id='3' siblings='3,19'/>
            <cpu id='4' socket_id='0' die_id='0' cluster_id='65535' core_id='4' siblings='4,20'/>
            <cpu id='5' socket_id='0' die_id='0' cluster_id='65535' core_id='5' siblings='5,21'/>
            <cpu id='6' socket_id='0' die_id='0' cluster_id='65535' core_id='6' siblings='6,22'/>
            <cpu id='7' socket_id='0' die_id='0' cluster_id='65535' core_id='7' siblings='7,23'/>
            <cpu id='8' socket_id='0' die_id='0' cluster_id='65535' core_id='8' siblings='8,24'/>
            <cpu id='9' socket_id='0' die_id='0' cluster_id='65535' core_id='9' siblings='9,25'/>
            <cpu id='10' socket_id='0' die_id='0' cluster_id='65535' core_id='10' siblings='10,26'/>
            <cpu id='11' socket_id='0' die_id='0' cluster_id='65535' core_id='11' siblings='11,27'/>
            <cpu id='12' socket_id='0' die_id='0' cluster_id='65535' core_id='12' siblings='12,28'/>
            <cpu id='13' socket_id='0' die_id='0' cluster_id='65535' core_id='13' siblings='13,29'/>
            <cpu id='14' socket_id='0' die_id='0' cluster_id='65535' core_id='14' siblings='14,30'/>
            <cpu id='15' socket_id='0' die_id='0' cluster_id='65535' core_id='15' siblings='15,31'/>
            <cpu id='16' socket_id='0' die_id='0' cluster_id='65535' core_id='0' siblings='0,16'/>
            <cpu id='17' socket_id='0' die_id='0' cluster_id='65535' core_id='1' siblings='1,17'/>
            <cpu id='18' socket_id='0' die_id='0' cluster_id='65535' core_id='2' siblings='2,18'/>
            <cpu id='19' socket_id='0' die_id='0' cluster_id='65535' core_id='3' siblings='3,19'/>
            <cpu id='20' socket_id='0' die_id='0' cluster_id='65535' core_id='4' siblings='4,20'/>
            <cpu id='21' socket_id='0' die_id='0' cluster_id='65535' core_id='5' siblings='5,21'/>
            <cpu id='22' socket_id='0' die_id='0' cluster_id='65535' core_id='6' siblings='6,22'/>
            <cpu id='23' socket_id='0' die_id='0' cluster_id='65535' core_id='7' siblings='7,23'/>
            <cpu id='24' socket_id='0' die_id='0' cluster_id='65535' core_id='8' siblings='8,24'/>
            <cpu id='25' socket_id='0' die_id='0' cluster_id='65535' core_id='9' siblings='9,25'/>
            <cpu id='26' socket_id='0' die_id='0' cluster_id='65535' core_id='10' siblings='10,26'/>
            <cpu id='27' socket_id='0' die_id='0' cluster_id='65535' core_id='11' siblings='11,27'/>
            <cpu id='28' socket_id='0' die_id='0' cluster_id='65535' core_id='12' siblings='12,28'/>
            <cpu id='29' socket_id='0' die_id='0' cluster_id='65535' core_id='13' siblings='13,29'/>
            <cpu id='30' socket_id='0' die_id='0' cluster_id='65535' core_id='14' siblings='14,30'/>
            <cpu id='31' socket_id='0' die_id='0' cluster_id='65535' core_id='15' siblings='15,31'/>
          </cpus>
        </cell>
      </cells>
    </topology>
    <cache>
      <bank id='0' level='2' type='both' size='512' unit='KiB' cpus='0,16'/>
      <bank id='1' level='2' type='both' size='512' unit='KiB' cpus='1,17'/>
      <bank id='2' level='2' type='both' size='512' unit='KiB' cpus='2,18'/>
      <bank id='3' level='2' type='both' size='512' unit='KiB' cpus='3,19'/>
      <bank id='4' level='2' type='both' size='512' unit='KiB' cpus='4,20'/>
      <bank id='5' level='2' type='both' size='512' unit='KiB' cpus='5,21'/>
      <bank id='6' level='2' type='both' size='512' unit='KiB' cpus='6,22'/>
      <bank id='7' level='2' type='both' size='512' unit='KiB' cpus='7,23'/>
      <bank id='8' level='2' type='both' size='512' unit='KiB' cpus='8,24'/>
      <bank id='9' level='2' type='both' size='512' unit='KiB' cpus='9,25'/>
      <bank id='10' level='2' type='both' size='512' unit='KiB' cpus='10,26'/>
      <bank id='11' level='2' type='both' size='512' unit='KiB' cpus='11,27'/>
      <bank id='12' level='2' type='both' size='512' unit='KiB' cpus='12,28'/>
      <bank id='13' level='2' type='both' size='512' unit='KiB' cpus='13,29'/>
      <bank id='14' level='2' type='both' size='512' unit='KiB' cpus='14,30'/>
      <bank id='15' level='2' type='both' size='512' unit='KiB' cpus='15,31'/>
      <bank id='0' level='3' type='both' size='32' unit='MiB' cpus='0-7,16-23'/>
      <bank id='1' level='3' type='both' size='32' unit='MiB' cpus='8-15,24-31'/>
    </cache>
    <secmodel>
      <model>none</model>
      <doi>0</doi>
    </secmodel>
    <secmodel>
      <model>dac</model>
      <doi>0</doi>
    </secmodel>
  </host>
  <guest>
    <arch name='i686'>
    </arch>
    <features>
      <pae/>
      <nonpae/>
      <cpuselection/>
      <deviceboot/>
      <externalSnapshot/>
    </features>
  </guest>
  <guest>
    </arch>
    <features>
      <cpuselection/>
      <deviceboot/>
      <externalSnapshot/>
    </features>
  </guest>
</capabilities>
[sab, 28 mar 2026 11:49:19 virt-manager 8911] DEBUG (connection:755) Using domain events
[sab, 28 mar 2026 11:49:19 virt-manager 8911] DEBUG (connection:798) Using network events
[sab, 28 mar 2026 11:49:19 virt-manager 8911] DEBUG (connection:819) Using storage pool events
[sab, 28 mar 2026 11:49:19 virt-manager 8911] DEBUG (connection:843) Using node device events
[sab, 28 mar 2026 11:49:19 virt-manager 8911] DEBUG (connection:704) storage pool refresh event: pool=ISO
[sab, 28 mar 2026 11:49:19 virt-manager 8911] DEBUG (connection:1101) network=default status=Inactive added
[sab, 28 mar 2026 11:49:19 virt-manager 8911] DEBUG (connection:1101) network=dmz status=Active added
[sab, 28 mar 2026 11:49:19 virt-manager 8911] DEBUG (connection:1101) network=int status=Active added
[sab, 28 mar 2026 11:49:19 virt-manager 8911] DEBUG (connection:1101) domain=mserver01 status=Running added
[sab, 28 mar 2026 11:49:19 virt-manager 8911] DEBUG (connection:1101) domain=nfs-vm status=Running added
[sab, 28 mar 2026 11:49:19 virt-manager 8911] DEBUG (connection:1101) domain=myserver status=Shutoff added
[sab, 28 mar 2026 11:49:19 virt-manager 8911] DEBUG (connection:1101) pool=ISO status=Active added
[sab, 28 mar 2026 11:49:19 virt-manager 8911] DEBUG (connection:704) storage pool refresh event: pool=VIRTIMAGES
[sab, 28 mar 2026 11:49:19 virt-manager 8911] DEBUG (connection:1101) domain=librespeed status=Shutoff added
[sab, 28 mar 2026 11:49:19 virt-manager 8911] DEBUG (connection:1101) domain=mclient status=Shutoff added
[sab, 28 mar 2026 11:49:19 virt-manager 8911] DEBUG (connection:1101) domain=plugnmeet status=Shutoff added
[sab, 28 mar 2026 11:49:19 virt-manager 8911] DEBUG (connection:1101) domain=mserver02 status=Shutoff added
[sab, 28 mar 2026 11:49:19 virt-manager 8911] DEBUG (connection:1101) pool=VIRTIMAGES status=Active added
[sab, 28 mar 2026 11:49:19 virt-manager 8911] DEBUG (connection:704) storage pool refresh event: pool=default
[sab, 28 mar 2026 11:49:19 virt-manager 8911] DEBUG (connection:1101) pool=default status=Active added
[sab, 28 mar 2026 11:49:20 virt-manager 8911] DEBUG (storage:137) Found default pool name=default target=/var/lib/libvirt/images
[sab, 28 mar 2026 11:49:20 virt-manager 8911] DEBUG (connection:474) conn=qemu+ssh://mirto@mostro/system changed to state=Active
[sab, 28 mar 2026 11:49:24 virt-manager 8911] DEBUG (serialcon:17) Using VTE API 2.91
[sab, 28 mar 2026 11:49:24 virt-manager 8911] DEBUG (xmleditor:15) Using GtkSource 4
[sab, 28 mar 2026 11:49:24 virt-manager 8911] DEBUG (domcapabilities:256) Fetched domain capabilities for (/usr/bin/qemu-system-x86_64,x86_64,pc-q35-10.2,kvm): <domainCapabilities>
  <path>/usr/bin/qemu-system-x86_64</path>
  <domain>kvm</domain>
  <machine>pc-q35-10.2</machine>
  <arch>x86_64</arch>
  <vcpu max='1024'/>
  <iothreads supported='yes'/>
  <os supported='yes'>
    <enum name='firmware'>
      <value>efi</value>
    </enum>
    <firmwareFeatures supported='yes'>
      <enum name='secureBoot'>
        <value>yes</value>
        <value>no</value>
      </enum>
      <enum name='enrolledKeys'>
        <value>no</value>
      </enum>
    </firmwareFeatures>
    <loader supported='yes'>
      <value>/usr/share/edk2/x64/OVMF_CODE.secboot.4m.fd</value>
      <value>/usr/share/edk2/x64/OVMF_CODE.4m.fd</value>
      <value>/usr/share/edk2/ia32/OVMF_CODE.secboot.4m.fd</value>
      <value>/usr/share/edk2/ia32/OVMF_CODE.4m.fd</value>
      <enum name='type'>
        <value>rom</value>
        <value>pflash</value>
      </enum>
      <enum name='readonly'>
        <value>yes</value>
        <value>no</value>
      </enum>
      <enum name='secure'>
        <value>yes</value>
        <value>no</value>
      </enum>
    </loader>
    <varstore supported='no'/>
  </os>
  <cpu>
    <mode name='host-passthrough' supported='yes'>
      <enum name='hostPassthroughMigratable'>
        <value>on</value>
        <value>off</value>
      </enum>
    </mode>
    <mode name='maximum' supported='yes'>
      <enum name='maximumMigratable'>
        <value>on</value>
        <value>off</value>
      </enum>
    </mode>
    <mode name='host-model' supported='yes'>
      <model fallback='forbid'>EPYC-Milan</model>
      <maxphysaddr mode='passthrough' limit='48'/>
      <feature policy='require' name='x2apic'/>
      <feature policy='require' name='tsc-deadline'/>
      <feature policy='require' name='hypervisor'/>
      <feature policy='require' name='tsc_adjust'/>
      <feature policy='require' name='vaes'/>
      <feature policy='require' name='vpclmulqdq'/>
      <feature policy='require' name='stibp'/>
      <feature policy='require' name='ssbd'/>
      <feature policy='require' name='cmp_legacy'/>
      <feature policy='require' name='overflow-recov'/>
      <feature policy='require' name='succor'/>
      <feature policy='require' name='invtsc'/>
      <feature policy='require' name='stibp-always-on'/>
      <feature policy='require' name='virt-ssbd'/>
      <feature policy='require' name='amd-psfd'/>
      <feature policy='require' name='lbrv'/>
      <feature policy='require' name='tsc-scale'/>
      <feature policy='require' name='vmcb-clean'/>
      <feature policy='require' name='flushbyasid'/>
      <feature policy='require' name='pause-filter'/>
      <feature policy='require' name='pfthreshold'/>
      <feature policy='require' name='v-vmsave-vmload'/>
      <feature policy='require' name='vgif'/>
      <feature policy='require' name='no-nested-data-bp'/>
      <feature policy='require' name='lfence-always-serializing'/>
      <feature policy='require' name='verw-clear'/>
      <feature policy='require' name='null-sel-clr-base'/>
      <feature policy='require' name='sbpb'/>
      <feature policy='require' name='ibpb-brtype'/>
      <feature policy='require' name='tsa-sq-no'/>
      <feature policy='require' name='tsa-l1-no'/>
      <feature policy='disable' name='pcid'/>
    </mode>
    <mode name='custom' supported='yes'>
      <model usable='yes' vendor='unknown' canonical='486-v1'>486</model>
      <model usable='yes' vendor='unknown'>486-v1</model>
      <model usable='no' vendor='Intel' canonical='Broadwell-v1'>Broadwell</model>
      <blockers model='Broadwell'>
        <feature name='hle'/>
        <feature name='pcid'/>
        <feature name='rtm'/>
      </blockers>
      <model usable='no' vendor='Intel' canonical='Broadwell-v3'>Broadwell-IBRS</model>
      <blockers model='Broadwell-IBRS'>
        <feature name='spec-ctrl'/>
      </blockers>
      <model usable='no' vendor='Intel' canonical='Broadwell-v2'>Broadwell-noTSX</model>
      <blockers model='Broadwell-noTSX'>
      </blockers>
      <model usable='no' vendor='Intel' canonical='Broadwell-v4'>Broadwell-noTSX-IBRS</model>
      <blockers model='Broadwell-noTSX-IBRS'>
      </blockers>
      <model usable='no' vendor='Intel'>Broadwell-v1</model>
      <blockers model='Broadwell-v1'>
      </blockers>
      <model usable='no' vendor='Intel'>Broadwell-v2</model>
      <blockers model='Broadwell-v2'>
      </blockers>
      <model usable='no' vendor='Intel'>Broadwell-v3</model>
      <blockers model='Broadwell-v3'>
      </blockers>
      <model usable='no' vendor='Intel'>Broadwell-v4</model>
      <blockers model='Broadwell-v4'>
      </blockers>
      <model usable='no' vendor='Intel' canonical='Cascadelake-Server-v1'>Cascadelake-Server</model>
      <blockers model='Cascadelake-Server'>
        <feature name='avx512bw'/>
        <feature name='avx512cd'/>
        <feature name='avx512dq'/>
        <feature name='avx512f'/>
        <feature name='avx512vl'/>
        <feature name='avx512vnni'/>
      </blockers>
      <model usable='no' vendor='Intel' canonical='Cascadelake-Server-v3'>Cascadelake-Server-noTSX</model>
      <blockers model='Cascadelake-Server-noTSX'>
        <feature name='ibrs-all'/>
      </blockers>
      <model usable='no' vendor='Intel'>Cascadelake-Server-v1</model>
      <blockers model='Cascadelake-Server-v1'>
      </blockers>
      <model usable='no' vendor='Intel'>Cascadelake-Server-v2</model>
      <blockers model='Cascadelake-Server-v2'>
      </blockers>
      <model usable='no' vendor='Intel'>Cascadelake-Server-v3</model>
      <blockers model='Cascadelake-Server-v3'>
      </blockers>
      <model usable='no' vendor='Intel'>Cascadelake-Server-v4</model>
      <blockers model='Cascadelake-Server-v4'>
      </blockers>
      <model usable='no' vendor='Intel'>Cascadelake-Server-v5</model>
      <blockers model='Cascadelake-Server-v5'>
      </blockers>
      <model usable='no' vendor='Intel' canonical='ClearwaterForest-v1'>ClearwaterForest</model>
      <blockers model='ClearwaterForest'>
        <feature name='avx-ifma'/>
        <feature name='avx-ne-convert'/>
        <feature name='avx-vnni'/>
        <feature name='avx-vnni-int16'/>
        <feature name='avx-vnni-int8'/>
        <feature name='bhi-ctrl'/>
        <feature name='bhi-no'/>
        <feature name='bus-lock-detect'/>
        <feature name='cldemote'/>
        <feature name='cmpccxadd'/>
        <feature name='ddpd-u'/>
        <feature name='fbsdp-no'/>
        <feature name='fsrs'/>
        <feature name='gfni'/>
        <feature name='intel-psfd'/>
        <feature name='ipred-ctrl'/>
        <feature name='lam'/>
        <feature name='mcdt-no'/>
        <feature name='movdir64b'/>
        <feature name='movdiri'/>
        <feature name='pbrsb-no'/>
        <feature name='prefetchiti'/>
        <feature name='psdp-no'/>
        <feature name='rrsba-ctrl'/>
        <feature name='sbdr-ssdp-no'/>
        <feature name='serialize'/>
        <feature name='sha512'/>
        <feature name='sm3'/>
        <feature name='sm4'/>
        <feature name='ss'/>
      </blockers>
      <model usable='no' vendor='Intel'>ClearwaterForest-v1</model>
      <blockers model='ClearwaterForest-v1'>
      </blockers>
      <model usable='yes' vendor='Intel' canonical='Conroe-v1'>Conroe</model>
      <model usable='yes' vendor='Intel'>Conroe-v1</model>
      <model usable='no' vendor='Intel' canonical='Cooperlake-v1'>Cooperlake</model>
      <blockers model='Cooperlake'>
        <feature name='avx512-bf16'/>
        <feature name='taa-no'/>
      </blockers>
      <model usable='no' vendor='Intel'>Cooperlake-v1</model>
      <blockers model='Cooperlake-v1'>
      </blockers>
      <model usable='no' vendor='Intel'>Cooperlake-v2</model>
      <blockers model='Cooperlake-v2'>
      </blockers>
      <model usable='no' vendor='Intel' canonical='Denverton-v1'>Denverton</model>
      <blockers model='Denverton'>
        <feature name='mpx'/>
      </blockers>
      <model usable='no' vendor='Intel'>Denverton-v1</model>
      <blockers model='Denverton-v1'>
      </blockers>
      <model usable='no' vendor='Intel'>Denverton-v2</model>
      <blockers model='Denverton-v2'>
      </blockers>
      <model usable='no' vendor='Intel'>Denverton-v3</model>
      <blockers model='Denverton-v3'>
      </blockers>
      <model usable='yes' vendor='Hygon' canonical='Dhyana-v1'>Dhyana</model>
      <model usable='yes' vendor='Hygon'>Dhyana-v1</model>
      <model usable='yes' vendor='Hygon'>Dhyana-v2</model>
      <model usable='yes' vendor='AMD' canonical='EPYC-v1'>EPYC</model>
      <model usable='no' vendor='AMD' canonical='EPYC-Genoa-v1'>EPYC-Genoa</model>
      <blockers model='EPYC-Genoa'>
        <feature name='auto-ibrs'/>
        <feature name='avx512-vpopcntdq'/>
        <feature name='avx512bitalg'/>
        <feature name='avx512ifma'/>
        <feature name='avx512vbmi'/>
        <feature name='avx512vbmi2'/>
        <feature name='la57'/>
      </blockers>
      <model usable='no' vendor='AMD'>EPYC-Genoa-v1</model>
      <blockers model='EPYC-Genoa-v1'>
      </blockers>
      <model usable='no' vendor='AMD'>EPYC-Genoa-v2</model>
      <blockers model='EPYC-Genoa-v2'>
        <feature name='fs-gs-base-ns'/>
        <feature name='perfmon-v2'/>
      </blockers>
      <model usable='yes' vendor='AMD' canonical='EPYC-v2'>EPYC-IBPB</model>
      <model usable='no' vendor='AMD' canonical='EPYC-Milan-v1'>EPYC-Milan</model>
      <blockers model='EPYC-Milan'>
      </blockers>
      <model usable='no' vendor='AMD'>EPYC-Milan-v1</model>
      <blockers model='EPYC-Milan-v1'>
      </blockers>
      <model usable='no' vendor='AMD'>EPYC-Milan-v2</model>
      <blockers model='EPYC-Milan-v2'>
      </blockers>
      <model usable='no' vendor='AMD'>EPYC-Milan-v3</model>
      <blockers model='EPYC-Milan-v3'>
      </blockers>
      <model usable='yes' vendor='AMD' canonical='EPYC-Rome-v1'>EPYC-Rome</model>
      <model usable='yes' vendor='AMD'>EPYC-Rome-v1</model>
      <model usable='yes' vendor='AMD'>EPYC-Rome-v2</model>
      <model usable='yes' vendor='AMD'>EPYC-Rome-v3</model>
      <model usable='yes' vendor='AMD'>EPYC-Rome-v4</model>
      <model usable='yes' vendor='AMD'>EPYC-Rome-v5</model>
      <model usable='no' vendor='AMD' canonical='EPYC-Turin-v1'>EPYC-Turin</model>
      <blockers model='EPYC-Turin'>
        <feature name='avx512-vp2intersect'/>
        <feature name='prefetchi'/>
        <feature name='srso-user-kernel-no'/>
      </blockers>
      <model usable='no' vendor='AMD'>EPYC-Turin-v1</model>
      <blockers model='EPYC-Turin-v1'>
      </blockers>
      <model usable='yes' vendor='AMD'>EPYC-v1</model>
      <model usable='yes' vendor='AMD'>EPYC-v2</model>
      <model usable='yes' vendor='AMD'>EPYC-v3</model>
      <model usable='yes' vendor='AMD'>EPYC-v4</model>
      <model usable='yes' vendor='AMD'>EPYC-v5</model>
      <model usable='no' vendor='Intel' canonical='GraniteRapids-v1'>GraniteRapids</model>
      <blockers model='GraniteRapids'>
        <feature name='amx-bf16'/>
        <feature name='amx-fp16'/>
        <feature name='amx-int8'/>
        <feature name='amx-tile'/>
        <feature name='avx512-fp16'/>
        <feature name='fsrc'/>
        <feature name='fzrm'/>
        <feature name='tsx-ldtrk'/>
        <feature name='xfd'/>
      </blockers>
      <model usable='no' vendor='Intel'>GraniteRapids-v1</model>
      <blockers model='GraniteRapids-v1'>
      </blockers>
      <model usable='no' vendor='Intel'>GraniteRapids-v2</model>
      <blockers model='GraniteRapids-v2'>
        <feature name='avx10'/>
        <feature name='avx10-128'/>
        <feature name='avx10-256'/>
        <feature name='avx10-512'/>
      </blockers>
      <model usable='no' vendor='Intel'>GraniteRapids-v3</model>
      <blockers model='GraniteRapids-v3'>
      </blockers>
      <model usable='no' vendor='Intel' canonical='Haswell-v1'>Haswell</model>
      <blockers model='Haswell'>
      </blockers>
      <model usable='no' vendor='Intel' canonical='Haswell-v3'>Haswell-IBRS</model>
      <blockers model='Haswell-IBRS'>
      </blockers>
      <model usable='no' vendor='Intel' canonical='Haswell-v2'>Haswell-noTSX</model>
      <blockers model='Haswell-noTSX'>
      </blockers>
      <model usable='no' vendor='Intel' canonical='Haswell-v4'>Haswell-noTSX-IBRS</model>
      <blockers model='Haswell-noTSX-IBRS'>
      </blockers>
      <model usable='no' vendor='Intel'>Haswell-v1</model>
      <blockers model='Haswell-v1'>
      </blockers>
      <model usable='no' vendor='Intel'>Haswell-v2</model>
      <blockers model='Haswell-v2'>
      </blockers>
      <model usable='no' vendor='Intel'>Haswell-v3</model>
      <blockers model='Haswell-v3'>
      </blockers>
      <model usable='no' vendor='Intel'>Haswell-v4</model>
      <blockers model='Haswell-v4'>
      </blockers>
      <model usable='no' vendor='Intel' canonical='Icelake-Server-v1'>Icelake-Server</model>
      <blockers model='Icelake-Server'>
      </blockers>
      <model usable='no' vendor='Intel' canonical='Icelake-Server-v2'>Icelake-Server-noTSX</model>
      <blockers model='Icelake-Server-noTSX'>
      </blockers>
      <model usable='no' vendor='Intel'>Icelake-Server-v1</model>
      <blockers model='Icelake-Server-v1'>
      </blockers>
      <model usable='no' vendor='Intel'>Icelake-Server-v2</model>
      <blockers model='Icelake-Server-v2'>
      </blockers>
      <model usable='no' vendor='Intel'>Icelake-Server-v3</model>
      <blockers model='Icelake-Server-v3'>
      </blockers>
      <model usable='no' vendor='Intel'>Icelake-Server-v4</model>
      <blockers model='Icelake-Server-v4'>
      </blockers>
      <model usable='no' vendor='Intel'>Icelake-Server-v5</model>
      <blockers model='Icelake-Server-v5'>
      </blockers>
      <model usable='no' vendor='Intel'>Icelake-Server-v6</model>
      <blockers model='Icelake-Server-v6'>
      </blockers>
      <model usable='no' vendor='Intel'>Icelake-Server-v7</model>
      <blockers model='Icelake-Server-v7'>
      </blockers>
      <model usable='yes' vendor='Intel' canonical='IvyBridge-v1'>IvyBridge</model>
      <model usable='no' vendor='Intel' canonical='IvyBridge-v2'>IvyBridge-IBRS</model>
      <blockers model='IvyBridge-IBRS'>
      </blockers>
      <model usable='yes' vendor='Intel'>IvyBridge-v1</model>
      <model usable='no' vendor='Intel'>IvyBridge-v2</model>
      <blockers model='IvyBridge-v2'>
      </blockers>
      <model usable='no' vendor='Intel' canonical='KnightsMill-v1'>KnightsMill</model>
      <blockers model='KnightsMill'>
        <feature name='avx512-4fmaps'/>
        <feature name='avx512-4vnniw'/>
        <feature name='avx512er'/>
        <feature name='avx512pf'/>
      </blockers>
      <model usable='no' vendor='Intel'>KnightsMill-v1</model>
      <blockers model='KnightsMill-v1'>
      </blockers>
      <model usable='yes' vendor='Intel' canonical='Nehalem-v1'>Nehalem</model>
      <model usable='no' vendor='Intel' canonical='Nehalem-v2'>Nehalem-IBRS</model>
      <blockers model='Nehalem-IBRS'>
      </blockers>
      <model usable='yes' vendor='Intel'>Nehalem-v1</model>
      <model usable='no' vendor='Intel'>Nehalem-v2</model>
      <blockers model='Nehalem-v2'>
      </blockers>
      <model usable='yes' vendor='AMD' canonical='Opteron_G1-v1'>Opteron_G1</model>
      <model usable='yes' vendor='AMD'>Opteron_G1-v1</model>
      <model usable='yes' vendor='AMD' canonical='Opteron_G2-v1'>Opteron_G2</model>
      <model usable='yes' vendor='AMD'>Opteron_G2-v1</model>
      <model usable='yes' vendor='AMD' canonical='Opteron_G3-v1'>Opteron_G3</model>
      <model usable='yes' vendor='AMD'>Opteron_G3-v1</model>
      <model usable='no' vendor='AMD' canonical='Opteron_G4-v1'>Opteron_G4</model>
      <blockers model='Opteron_G4'>
        <feature name='fma4'/>
        <feature name='xop'/>
      </blockers>
      <model usable='no' vendor='AMD'>Opteron_G4-v1</model>
      <blockers model='Opteron_G4-v1'>
      </blockers>
      <model usable='no' vendor='AMD' canonical='Opteron_G5-v1'>Opteron_G5</model>
      <blockers model='Opteron_G5'>
        <feature name='tbm'/>
      </blockers>
      <model usable='no' vendor='AMD'>Opteron_G5-v1</model>
      <blockers model='Opteron_G5-v1'>
      </blockers>
      <model usable='yes' vendor='Intel' canonical='Penryn-v1'>Penryn</model>
      <model usable='yes' vendor='Intel'>Penryn-v1</model>
      <model usable='yes' vendor='Intel' canonical='SandyBridge-v1'>SandyBridge</model>
      <model usable='no' vendor='Intel' canonical='SandyBridge-v2'>SandyBridge-IBRS</model>
      <blockers model='SandyBridge-IBRS'>
      </blockers>
      <model usable='yes' vendor='Intel'>SandyBridge-v1</model>
      <model usable='no' vendor='Intel'>SandyBridge-v2</model>
      <blockers model='SandyBridge-v2'>
      </blockers>
      <model usable='no' vendor='Intel' canonical='SapphireRapids-v1'>SapphireRapids</model>
      <blockers model='SapphireRapids'>
      </blockers>
      <model usable='no' vendor='Intel'>SapphireRapids-v1</model>
      <blockers model='SapphireRapids-v1'>
      </blockers>
      <model usable='no' vendor='Intel'>SapphireRapids-v2</model>
      <blockers model='SapphireRapids-v2'>
      </blockers>
      <model usable='no' vendor='Intel'>SapphireRapids-v3</model>
      <blockers model='SapphireRapids-v3'>
      </blockers>
      <model usable='no' vendor='Intel'>SapphireRapids-v4</model>
      <blockers model='SapphireRapids-v4'>
      </blockers>
      <model usable='no' vendor='Intel' canonical='SierraForest-v1'>SierraForest</model>
      <blockers model='SierraForest'>
      </blockers>
      <model usable='no' vendor='Intel'>SierraForest-v1</model>
      <blockers model='SierraForest-v1'>
      </blockers>
      <model usable='no' vendor='Intel'>SierraForest-v2</model>
      <blockers model='SierraForest-v2'>
      </blockers>
      <model usable='no' vendor='Intel'>SierraForest-v3</model>
      <blockers model='SierraForest-v3'>
      </blockers>
      <model usable='no' vendor='Intel' canonical='Skylake-Client-v1'>Skylake-Client</model>
      <blockers model='Skylake-Client'>
      </blockers>
      <model usable='no' vendor='Intel' canonical='Skylake-Client-v2'>Skylake-Client-IBRS</model>
      <blockers model='Skylake-Client-IBRS'>
      </blockers>
      <model usable='no' vendor='Intel' canonical='Skylake-Client-v3'>Skylake-Client-noTSX-IBRS</model>
      <blockers model='Skylake-Client-noTSX-IBRS'>
      </blockers>
      <model usable='no' vendor='Intel'>Skylake-Client-v1</model>
      <blockers model='Skylake-Client-v1'>
      </blockers>
      <model usable='no' vendor='Intel'>Skylake-Client-v2</model>
      <blockers model='Skylake-Client-v2'>
      </blockers>
      <model usable='no' vendor='Intel'>Skylake-Client-v3</model>
      <blockers model='Skylake-Client-v3'>
      </blockers>
      <model usable='no' vendor='Intel'>Skylake-Client-v4</model>
      <blockers model='Skylake-Client-v4'>
      </blockers>
      <model usable='no' vendor='Intel' canonical='Skylake-Server-v1'>Skylake-Server</model>
      <blockers model='Skylake-Server'>
      </blockers>
      <model usable='no' vendor='Intel' canonical='Skylake-Server-v2'>Skylake-Server-IBRS</model>
      <blockers model='Skylake-Server-IBRS'>
      </blockers>
      <model usable='no' vendor='Intel' canonical='Skylake-Server-v3'>Skylake-Server-noTSX-IBRS</model>
      <blockers model='Skylake-Server-noTSX-IBRS'>
      </blockers>
      <model usable='no' vendor='Intel'>Skylake-Server-v1</model>
      <blockers model='Skylake-Server-v1'>
      </blockers>
      <model usable='no' vendor='Intel'>Skylake-Server-v2</model>
      <blockers model='Skylake-Server-v2'>
      </blockers>
      <model usable='no' vendor='Intel'>Skylake-Server-v3</model>
      <blockers model='Skylake-Server-v3'>
      </blockers>
      <model usable='no' vendor='Intel'>Skylake-Server-v4</model>
      <blockers model='Skylake-Server-v4'>
      </blockers>
      <model usable='no' vendor='Intel'>Skylake-Server-v5</model>
      <blockers model='Skylake-Server-v5'>
      </blockers>
      <model usable='no' vendor='Intel' canonical='Snowridge-v1'>Snowridge</model>
      <blockers model='Snowridge'>
        <feature name='core-capability'/>
        <feature name='split-lock-detect'/>
      </blockers>
      <model usable='no' vendor='Intel'>Snowridge-v1</model>
      <blockers model='Snowridge-v1'>
      </blockers>
      <model usable='no' vendor='Intel'>Snowridge-v2</model>
      <blockers model='Snowridge-v2'>
      </blockers>
      <model usable='no' vendor='Intel'>Snowridge-v3</model>
      <blockers model='Snowridge-v3'>
      </blockers>
      <model usable='no' vendor='Intel'>Snowridge-v4</model>
      <blockers model='Snowridge-v4'>
      </blockers>
      <model usable='yes' vendor='Intel' canonical='Westmere-v1'>Westmere</model>
      <model usable='no' vendor='Intel' canonical='Westmere-v2'>Westmere-IBRS</model>
      <blockers model='Westmere-IBRS'>
      </blockers>
      <model usable='yes' vendor='Intel'>Westmere-v1</model>
      <model usable='no' vendor='Intel'>Westmere-v2</model>
      <blockers model='Westmere-v2'>
      </blockers>
      <model usable='no' vendor='Zhaoxin CentaurHauls' canonical='YongFeng-v1'>YongFeng</model>
      <blockers model='YongFeng'>
        <feature name='ace2'/>
        <feature name='phe'/>
        <feature name='phe-en'/>
        <feature name='pmm'/>
        <feature name='pmm-en'/>
        <feature name='ssb-no'/>
        <feature name='xcrypt'/>
        <feature name='xcrypt-en'/>
        <feature name='xstore'/>
        <feature name='xstore-en'/>
      </blockers>
      <model usable='no' vendor='Zhaoxin CentaurHauls'>YongFeng-v1</model>
      <blockers model='YongFeng-v1'>
      </blockers>
      <model usable='no' vendor='Zhaoxin CentaurHauls'>YongFeng-v2</model>
      <blockers model='YongFeng-v2'>
      </blockers>
      <model usable='no' vendor='Zhaoxin CentaurHauls'>YongFeng-v3</model>
      <blockers model='YongFeng-v3'>
      </blockers>
      <model usable='no' vendor='AMD' canonical='athlon-v1'>athlon</model>
      <blockers model='athlon'>
        <feature name='3dnow'/>
        <feature name='3dnowext'/>
      </blockers>
      <model usable='no' vendor='AMD'>athlon-v1</model>
      <blockers model='athlon-v1'>
      </blockers>
      <model usable='no' vendor='Intel' canonical='core2duo-v1'>core2duo</model>
      <blockers model='core2duo'>
      </blockers>
      <model usable='no' vendor='Intel'>core2duo-v1</model>
      <blockers model='core2duo-v1'>
      </blockers>
      <model usable='no' vendor='Intel' canonical='coreduo-v1'>coreduo</model>
      <blockers model='coreduo'>
      </blockers>
      <model usable='no' vendor='Intel'>coreduo-v1</model>
      <blockers model='coreduo-v1'>
      </blockers>
      <model usable='yes' vendor='unknown' canonical='kvm32-v1'>kvm32</model>
      <model usable='yes' vendor='unknown'>kvm32-v1</model>
      <model usable='yes' vendor='unknown' canonical='kvm64-v1'>kvm64</model>
      <model usable='yes' vendor='unknown'>kvm64-v1</model>
      <model usable='no' vendor='Intel' canonical='n270-v1'>n270</model>
      <blockers model='n270'>
      </blockers>
      <model usable='no' vendor='Intel'>n270-v1</model>
      <blockers model='n270-v1'>
      </blockers>
      <model usable='yes' vendor='unknown' canonical='pentium-v1'>pentium</model>
      <model usable='yes' vendor='unknown'>pentium-v1</model>
      <model usable='yes' vendor='unknown' canonical='pentium2-v1'>pentium2</model>
      <model usable='yes' vendor='unknown'>pentium2-v1</model>
      <model usable='yes' vendor='unknown' canonical='pentium3-v1'>pentium3</model>
      <model usable='yes' vendor='unknown'>pentium3-v1</model>
      <model usable='no' vendor='AMD' canonical='phenom-v1'>phenom</model>
      <blockers model='phenom'>
      </blockers>
      <model usable='no' vendor='AMD'>phenom-v1</model>
      <blockers model='phenom-v1'>
      </blockers>
      <model usable='yes' vendor='unknown' canonical='qemu32-v1'>qemu32</model>
      <model usable='yes' vendor='unknown'>qemu32-v1</model>
      <model usable='yes' vendor='unknown' canonical='qemu64-v1'>qemu64</model>
      <model usable='yes' vendor='unknown'>qemu64-v1</model>
    </mode>
  </cpu>
  <memoryBacking supported='yes'>
    <enum name='sourceType'>
      <value>file</value>
      <value>anonymous</value>
      <value>memfd</value>
    </enum>
  </memoryBacking>
  <devices>
    <disk supported='yes'>
      <enum name='diskDevice'>
        <value>disk</value>
        <value>cdrom</value>
        <value>floppy</value>
        <value>lun</value>
      </enum>
      <enum name='bus'>
        <value>fdc</value>
        <value>scsi</value>
        <value>virtio</value>
        <value>usb</value>
        <value>sata</value>
        <value>nvme</value>
      </enum>
      <enum name='model'>
        <value>virtio-transitional</value>
        <value>virtio-non-transitional</value>
      </enum>
    </disk>
    <graphics supported='yes'>
      <enum name='type'>
        <value>sdl</value>
        <value>vnc</value>
        <value>spice</value>
        <value>egl-headless</value>
        <value>dbus</value>
      </enum>
    </graphics>
    <video supported='yes'>
      <enum name='modelType'>
        <value>vga</value>
        <value>cirrus</value>
        <value>vmvga</value>
        <value>qxl</value>
        <value>none</value>
        <value>bochs</value>
        <value>ramfb</value>
      </enum>
    </video>
    <hostdev supported='yes'>
      <enum name='mode'>
        <value>subsystem</value>
      </enum>
      <enum name='startupPolicy'>
        <value>default</value>
        <value>mandatory</value>
        <value>requisite</value>
        <value>optional</value>
      </enum>
      <enum name='subsysType'>
        <value>usb</value>
        <value>pci</value>
        <value>scsi</value>
      </enum>
      <enum name='capsType'/>
      <enum name='pciBackend'>
        <value>vfio</value>
      </enum>
      <enum name='iommufd'>
        <value>no</value>
      </enum>
    </hostdev>
    <rng supported='yes'>
      <enum name='model'>
      </enum>
      <enum name='backendModel'>
        <value>random</value>
        <value>egd</value>
        <value>builtin</value>
      </enum>
    </rng>
    <filesystem supported='yes'>
      <enum name='driverType'>
        <value>path</value>
        <value>handle</value>
        <value>virtiofs</value>
      </enum>
    </filesystem>
    <tpm supported='yes'>
      <enum name='model'>
        <value>tpm-tis</value>
        <value>tpm-crb</value>
      </enum>
        <value>passthrough</value>
      </enum>
    </tpm>
    <redirdev supported='yes'>
      <enum name='bus'>
        <value>usb</value>
      </enum>
    </redirdev>
    <channel supported='yes'>
      <enum name='type'>
        <value>pty</value>
        <value>unix</value>
        <value>spicevmc</value>
      </enum>
    </channel>
    <crypto supported='yes'>
      <enum name='model'>
      </enum>
      <enum name='type'>
        <value>qemu</value>
      </enum>
        <value>lkcf</value>
      </enum>
    </crypto>
    <interface supported='yes'>
      <enum name='backendType'>
        <value>passt</value>
      </enum>
    </interface>
    <panic supported='yes'>
      <enum name='model'>
        <value>isa</value>
        <value>hyperv</value>
        <value>pvpanic</value>
      </enum>
    </panic>
    <console supported='yes'>
      <enum name='type'>
        <value>null</value>
        <value>vc</value>
        <value>pty</value>
        <value>dev</value>
        <value>file</value>
        <value>pipe</value>
        <value>stdio</value>
        <value>udp</value>
        <value>tcp</value>
        <value>unix</value>
        <value>spiceport</value>
        <value>qemu-vdagent</value>
        <value>dbus</value>
      </enum>
    </console>
  </devices>
  <features>
    <gic supported='no'/>
    <vmcoreinfo supported='yes'/>
    <genid supported='yes'/>
    <backingStoreInput supported='yes'/>
    <backup supported='yes'/>
    <async-teardown supported='yes'/>
    <s390-pv supported='no'/>
    <ps2 supported='yes'/>
    <tdx supported='no'/>
    <sev supported='no'/>
    <sgx supported='no'/>
    <hyperv supported='yes'>
      <enum name='features'>
        <value>relaxed</value>
        <value>vapic</value>
        <value>spinlocks</value>
        <value>vpindex</value>
        <value>runtime</value>
        <value>synic</value>
        <value>stimer</value>
        <value>reset</value>
        <value>vendor_id</value>
        <value>frequencies</value>
        <value>reenlightenment</value>
        <value>tlbflush</value>
        <value>ipi</value>
        <value>avic</value>
        <value>emsr_bitmap</value>
        <value>xmm_input</value>
      </enum>
      <defaults>
        <spinlocks>4095</spinlocks>
        <stimer_direct>on</stimer_direct>
        <tlbflush_direct>on</tlbflush_direct>
        <tlbflush_extended>on</tlbflush_extended>
        <vendor_id>Linux KVM Hv</vendor_id>
      </defaults>
    </hyperv>
    <launchSecurity supported='no'/>
  </features>
</domainCapabilities>
(I don’t know how to upload a .txt file)
The operations reported in the log are generated by these actions:
  1. launch virt-manager
  2. start remote connection to “mostro” machine using qemu+ssh
  3. start the console of the “mserver01” VM machine
  4. close the console of the “mserver01” VM machine
  5. close the remote connection to “mostro” machine
This might be missing depenency.
libguestfs is a package in the extra repo.
Tried to install libguestfs and nothing changed; but the error was different.
Now it complais that guestfs is not installed
(virt-manager:65383): Gtk-CRITICAL **: 20:18:20.638: gtk_widget_get_scale_factor: assertion 'GTK_IS_WIDGET (widget)' failed
[sab, 28 mar 2026 20:18:20 virt-manager 65383] DEBUG (inspection:210) python guestfs is not installed
My problem is that seems this package doesn’t exist.
Searching for “python guestfs” I only find these packages:
Unless I have to swithc to the git version of libguestfs
The error seems the same to me. I use virt-manager, but not in the way you are so I’ not sure how to provide any more support. It could be an option to open a issue with GitHub - virt-manager/virt-manager: Desktop tool for managing virtual machines via libvirt · GitHub or check out their IRC channel for a chat about this issue.
Hi @Hanzel I’ve tried to install libguestfs-git; but it ends with a compile error.
  OCAMLOPT daemon.cmx
ocamlfind opt -output-obj -o camldaemon.o \
    -g -annot  -warn-error +C+D+E+F+L+M+P+S+U+V+Y+Z+X+52-3-6 -w -6 -ccopt '-march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions         -Wp,-D_FORTIFY_SOURCE=3 -Wformat -Werror=format-security         -fstack-clash-protection -fcf-protection         -fno-omit-frame-pointer -mno-omit-leaf-frame-pointer -fno-strict-overflow -Wno-strict-overflow' -package str,unix,augeas,hivex -I ../common/mlstdutils -I ../common/mlutils -I ../common/utils/.libs -I ../common/mlpcre -I ../common/mlpcre/.libs -I ../gnulib/lib/.libs \
    -linkpkg \
    mlpcre.cmxa \
    mlstdutils.cmxa \
    mlcutils.cmxa \
    daemon_config.cmx utils.cmx structs.cmx optgroups.cmx sysroot.cmx mountable.cmx chroot.cmx blkid.cmx btrfs.cmx cryptsetup.cmx devsparts.cmx file_helper.cmx file.cmx filearch.cmx isoinfo.cmx is.cmx ldm.cmx link.cmx lvm.cmx lvm_full.cmx lvm_utils.cmx lvm_dm.cmx findfs.cmx md.cmx mount.cmx mount_utils.cmx sfdisk.cmx parted.cmx listfs.cmx realpath.cmx statvfs.cmx selinux.cmx xfs.cmx inspect_types.cmx inspect_utils.cmx inspect_fs_unix_fstab.cmx inspect_fs_unix.cmx inspect_fs_windows.cmx inspect_fs.cmx inspect.cmx rpm.cmx callbacks.cmx daemon.cmx
File "_none_", line 1:
Error: Files /usr/lib/ocaml/augeas/mlaugeas.cmxa
       and /usr/lib/ocaml/stdlib.cmxa
       make inconsistent assumptions over implementation Stdlib__Callback
make[3]: *** [Makefile:4109: camldaemon.o] Error 2
make[3]: uscita dalla directory «/home/mirto/TMP/libguestfs-git/src/libguestfs/daemon»
make[2]: *** [Makefile:1405: all] Error 2
make[2]: uscita dalla directory «/home/mirto/TMP/libguestfs-git/src/libguestfs/daemon»
make[1]: *** [Makefile:1054: all-recursive] Error 1
make[1]: uscita dalla directory «/home/mirto/TMP/libguestfs-git/src/libguestfs»
make: *** [Makefile:960: all] Error 2
==> ERRORE: Si è verificato un errore in build().
    L'operazione sta per essere interrotta...
For now I’ll survive using virt-manager for the local VM and virt-viewer for the remote VM.
Thanks for your time.
I believe you need ssh port forwarding enabled on the host to make this work.
Check this file..
/etc/ssh/sshd_config
#AllowTcpForwarding yes
Just uncomment.
And restart sshd
sudo systemctl restart sshd
Hi @Molski no luck
enabled AllowTcpForwarding on bot the local machine and the remote machine hosting the VM
restarted sshd on both machines.
Nothing changed
BTW here is the virt-manager error log
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (cli:209) Version 5.1.0 launched with command line: /usr/bin/virt-manager --debug
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (virtmanager:198) virt-manager version: 5.1.0
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (virtmanager:199) virtManager import: /usr/share/virt-manager/virtManager
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (virtmanager:221) Using SSH_ASKPASS_REQUIRE=force
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (virtmanager:238) PyGObject version: 3.54.5
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (virtmanager:241) GTK version: 3.24.51
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (systray:477) Showing systray: True
(virt-manager:90595): Gtk-CRITICAL **: 20:15:03.170: gtk_widget_get_scale_factor: assertion 'GTK_IS_WIDGET (widget)' failed
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (inspection:207) python guestfs is installed
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (inspection:228) libguestfs gsetting enabled=False
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (engine:112) Loading stored URIs:
qemu:///system
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (engine:476) processing cli command uri= show_window=manager domain=
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (engine:486) No cli action requested, launching default window
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (manager:173) Showing manager
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (engine:302) window counter incremented to 1
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (engine:206) Initial gtkapplication activated
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (connection:474) conn=qemu:///system changed to state=Connecting
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (connection:922) Scheduling background open thread for qemu:///system
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (connection:129) libvirt URI versions library=12.1.0 driver=12.1.0 hypervisor=10.2.1
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (connection:110) Fetched capabilities for qemu:///system: <capabilities>
  <host>
    <cpu>
      <arch>x86_64</arch>
      <counter name='tsc' frequency='3800026000' scaling='yes'/>
    </cpu>
    <power_management>
      <suspend_mem/>
    </power_management>
      <live/>
      <uri_transports>
      </uri_transports>
    <topology>
      <cells num='1'>
        <cell id='0'>
          <memory unit='KiB'>65762400</memory>
          <pages unit='KiB' size='4'>16440600</pages>
          <distances>
          </distances>
          <cpus num='16'>
          </cpus>
        </cell>
      </cells>
    </topology>
    <cache>
    </cache>
    <secmodel>
      <model>none</model>
      <doi>0</doi>
    </secmodel>
    <secmodel>
      <model>dac</model>
      <doi>0</doi>
    </secmodel>
  </host>
  <guest>
    <arch name='i686'>
    </arch>
    <features>
      <pae/>
      <nonpae/>
      <cpuselection/>
      <deviceboot/>
      <externalSnapshot/>
    </features>
  </guest>
  <guest>
    </arch>
    <features>
      <cpuselection/>
      <deviceboot/>
      <externalSnapshot/>
    </features>
  </guest>
</capabilities>
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (connection:755) Using domain events
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (connection:798) Using network events
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (connection:819) Using storage pool events
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (connection:843) Using node device events
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (connection:704) storage pool refresh event: pool=SSD2-VIRTIMAGES
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (connection:1101) network=dmz status=Active added
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (connection:1101) network=default status=Active added
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (connection:1101) domain=manjaro-blender status=Shutoff added
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (connection:1101) network=int status=Active added
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (connection:1101) domain=h5a-km status=Shutoff added
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (connection:704) storage pool refresh event: pool=SATA1-VIRTIMAGES
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (connection:704) storage pool refresh event: pool=ISO
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (connection:704) storage pool refresh event: pool=default
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (connection:1101) domain=h5a-kw2 status=Shutoff added
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (connection:1101) domain=h5a-dev status=Shutoff added
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (connection:1101) domain=h5a-kw1 status=Shutoff added
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (connection:1101) pool=SSD2-VIRTIMAGES status=Active added
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (connection:1101) domain=h5a-kw3 status=Shutoff added
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (connection:1101) domain=manjaro-tor status=Shutoff added
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (connection:1101) domain=manjaro status=Shutoff added
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (connection:1101) domain=h5a-serv status=Shutoff added
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (connection:1101) domain=debian12 status=Shutoff added
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (connection:1101) pool=SATA1-VIRTIMAGES status=Active added
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (connection:1101) pool=ISO status=Active added
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (connection:1101) pool=default status=Active added
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (storage:137) Found default pool name=default target=/var/lib/libvirt/images
[dom, 29 mar 2026 20:15:03 virt-manager 90595] DEBUG (connection:474) conn=qemu:///system changed to state=Active
[dom, 29 mar 2026 20:15:06 virt-manager 90595] DEBUG (connection:474) conn=qemu+ssh://mirto@mostro/system changed to state=Connecting
[dom, 29 mar 2026 20:15:06 virt-manager 90595] DEBUG (connection:922) Scheduling background open thread for qemu+ssh://mirto@mostro/system
[dom, 29 mar 2026 20:15:06 virt-manager 90595] DEBUG (connection:129) libvirt URI versions library=12.1.0 driver=12.1.0 hypervisor=10.2.1
[dom, 29 mar 2026 20:15:06 virt-manager 90595] DEBUG (connection:110) Fetched capabilities for qemu+ssh://mirto@mostro/system: <capabilities>
  <host>
    <cpu>
      <arch>x86_64</arch>
    </cpu>
    <power_management>
      <suspend_mem/>
    </power_management>
      <live/>
      <uri_transports>
      </uri_transports>
    <topology>
      <cells num='1'>
        <cell id='0'>
          <distances>
          </distances>
          <cpus num='32'>
          </cpus>
        </cell>
      </cells>
    </topology>
    <cache>
    </cache>
    <secmodel>
      <model>none</model>
      <doi>0</doi>
    </secmodel>
    <secmodel>
      <model>dac</model>
      <doi>0</doi>
    </secmodel>
  </host>
  <guest>
    <arch name='i686'>
    </arch>
    <features>
      <pae/>
      <nonpae/>
      <cpuselection/>
      <deviceboot/>
      <externalSnapshot/>
    </features>
  </guest>
  <guest>
    </arch>
    <features>
      <cpuselection/>
      <deviceboot/>
      <externalSnapshot/>
    </features>
  </guest>
</capabilities>
[dom, 29 mar 2026 20:15:06 virt-manager 90595] DEBUG (connection:755) Using domain events
[dom, 29 mar 2026 20:15:06 virt-manager 90595] DEBUG (connection:798) Using network events
[dom, 29 mar 2026 20:15:06 virt-manager 90595] DEBUG (connection:819) Using storage pool events
[dom, 29 mar 2026 20:15:06 virt-manager 90595] DEBUG (connection:843) Using node device events
[dom, 29 mar 2026 20:15:06 virt-manager 90595] DEBUG (connection:1101) network=default status=Inactive added
[dom, 29 mar 2026 20:15:06 virt-manager 90595] DEBUG (connection:1101) network=dmz status=Active added
[dom, 29 mar 2026 20:15:06 virt-manager 90595] DEBUG (connection:1101) network=int status=Active added
[dom, 29 mar 2026 20:15:06 virt-manager 90595] DEBUG (connection:1101) domain=mserver01 status=Running added
[dom, 29 mar 2026 20:15:06 virt-manager 90595] DEBUG (connection:704) storage pool refresh event: pool=ISO
[dom, 29 mar 2026 20:15:06 virt-manager 90595] DEBUG (connection:1101) domain=nfs-vm status=Running added
[dom, 29 mar 2026 20:15:06 virt-manager 90595] DEBUG (connection:1101) domain=myserver status=Shutoff added
[dom, 29 mar 2026 20:15:06 virt-manager 90595] DEBUG (connection:1101) domain=librespeed status=Shutoff added
[dom, 29 mar 2026 20:15:06 virt-manager 90595] DEBUG (connection:704) storage pool refresh event: pool=VIRTIMAGES
[dom, 29 mar 2026 20:15:06 virt-manager 90595] DEBUG (connection:1101) domain=mclient status=Shutoff added
[dom, 29 mar 2026 20:15:06 virt-manager 90595] DEBUG (connection:1101) pool=ISO status=Active added
[dom, 29 mar 2026 20:15:06 virt-manager 90595] DEBUG (connection:1101) domain=plugnmeet status=Shutoff added
[dom, 29 mar 2026 20:15:06 virt-manager 90595] DEBUG (connection:1101) domain=mserver02 status=Shutoff added
[dom, 29 mar 2026 20:15:06 virt-manager 90595] DEBUG (connection:1101) pool=VIRTIMAGES status=Active added
[dom, 29 mar 2026 20:15:06 virt-manager 90595] DEBUG (connection:704) storage pool refresh event: pool=default
[dom, 29 mar 2026 20:15:06 virt-manager 90595] DEBUG (connection:1101) pool=default status=Active added
[dom, 29 mar 2026 20:15:07 virt-manager 90595] DEBUG (storage:137) Found default pool name=default target=/var/lib/libvirt/images
[dom, 29 mar 2026 20:15:07 virt-manager 90595] DEBUG (connection:474) conn=qemu+ssh://mirto@mostro/system changed to state=Active
[dom, 29 mar 2026 20:15:08 virt-manager 90595] DEBUG (serialcon:17) Using VTE API 2.91
[dom, 29 mar 2026 20:15:08 virt-manager 90595] DEBUG (xmleditor:15) Using GtkSource 4
[dom, 29 mar 2026 20:15:08 virt-manager 90595] DEBUG (domcapabilities:256) Fetched domain capabilities for (/usr/bin/qemu-system-x86_64,x86_64,pc-q35-10.2,kvm): <domainCapabilities>
  <arch>x86_64</arch>
  <vcpu max='1024'/>
      <value>efi</value>
    </enum>
        <value>yes</value>
        <value>no</value>
      </enum>
        <value>no</value>
      </enum>
    </firmwareFeatures>
      <enum name='type'>
        <value>rom</value>
      </enum>
        <value>yes</value>
        <value>no</value>
      </enum>
        <value>yes</value>
        <value>no</value>
      </enum>
    </loader>
  </os>
  <cpu>
        <value>on</value>
        <value>off</value>
      </enum>
    </mode>
        <value>on</value>
        <value>off</value>
      </enum>
    </mode>
    </mode>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
      </blockers>
    </mode>
  </cpu>
      <value>file</value>
    </enum>
  </memoryBacking>
  <devices>
        <value>disk</value>
        <value>lun</value>
      </enum>
      <enum name='bus'>
        <value>fdc</value>
        <value>scsi</value>
        <value>usb</value>
        <value>sata</value>
        <value>nvme</value>
      </enum>
      <enum name='model'>
      </enum>
    </disk>
      <enum name='type'>
        <value>sdl</value>
        <value>vnc</value>
        <value>dbus</value>
      </enum>
    </graphics>
        <value>vga</value>
        <value>qxl</value>
        <value>none</value>
      </enum>
    </video>
      <enum name='mode'>
      </enum>
      </enum>
        <value>usb</value>
        <value>pci</value>
        <value>scsi</value>
      </enum>
        <value>vfio</value>
      </enum>
        <value>no</value>
      </enum>
    </hostdev>
      <enum name='model'>
      </enum>
        <value>egd</value>
      </enum>
    </rng>
        <value>path</value>
      </enum>
    </filesystem>
      <enum name='model'>
      </enum>
      </enum>
    </tpm>
      <enum name='bus'>
        <value>usb</value>
      </enum>
    </redirdev>
      <enum name='type'>
        <value>pty</value>
        <value>unix</value>
      </enum>
    </channel>
      <enum name='model'>
      </enum>
      <enum name='type'>
        <value>qemu</value>
      </enum>
        <value>lkcf</value>
      </enum>
    </crypto>
      </enum>
    </interface>
      <enum name='model'>
        <value>isa</value>
      </enum>
    </panic>
      <enum name='type'>
        <value>null</value>
        <value>vc</value>
        <value>pty</value>
        <value>dev</value>
        <value>file</value>
        <value>pipe</value>
        <value>udp</value>
        <value>tcp</value>
        <value>unix</value>
        <value>dbus</value>
      </enum>
    </console>
  </devices>
  <features>
        <value>ipi</value>
        <value>avic</value>
      </enum>
      <defaults>
      </defaults>
    </hyperv>
  </features>
[dom, 29 mar 2026 20:15:08 virt-manager 90595] DEBUG (vmwindow:175) Showing VM details: <vmmDomain name=mserver01 id=0x7f1910221300>
[dom, 29 mar 2026 20:15:08 virt-manager 90595] DEBUG (engine:302) window counter incremented to 2
[dom, 29 mar 2026 20:15:08 virt-manager 90595] DEBUG (console:653) Starting connect process for proto=spice trans=ssh connhost=mostro connuser=mirto connport= gaddr=0.0.0.0 gport=5901 gtlsport=None gsocket=None
[dom, 29 mar 2026 20:15:08 virt-manager 90595] DEBUG (viewers:698) Spice connecting to host=mostro port=5901 tlsport=None
[dom, 29 mar 2026 20:15:15 virt-manager 90595] DEBUG (vmwindow:234) Closing VM details: <vmmDomain name=mserver01 id=0x7f1910221300>
[dom, 29 mar 2026 20:15:15 virt-manager 90595] DEBUG (console:556) Viewer object cleaned up
[dom, 29 mar 2026 20:15:15 virt-manager 90595] DEBUG (engine:309) window counter decremented to 1
[dom, 29 mar 2026 20:15:20 virt-manager 90595] DEBUG (manager:184) Closing manager
[dom, 29 mar 2026 20:15:20 virt-manager 90595] DEBUG (engine:309) window counter decremented to 0
[dom, 29 mar 2026 20:15:20 virt-manager 90595] DEBUG (engine:352) No windows found, requesting app exit
[dom, 29 mar 2026 20:15:20 virt-manager 90595] DEBUG (connection:858) conn.close() uri=qemu+ssh://mirto@mostro/system
[dom, 29 mar 2026 20:15:20 virt-manager 90595] DEBUG (connection:474) conn=qemu+ssh://mirto@mostro/system changed to state=Disconnected
[dom, 29 mar 2026 20:15:20 virt-manager 90595] DEBUG (connection:858) conn.close() uri=qemu:///system
[dom, 29 mar 2026 20:15:20 virt-manager 90595] DEBUG (connection:474) conn=qemu:///system changed to state=Disconnected
[dom, 29 mar 2026 20:15:20 virt-manager 90595] DEBUG (engine:378) Exiting app normally.
Hi @Molski @Hanzel @Olli I feel a little stupid
Solution:
  • open port 5901 TCP in the firewall on both machines.
  • Then reboot both machines
Sorry
That would do it. :grinning_face:
Well at least you fixed that problem before even running into it. :grinning_face:
I actually was considering setting it up right before your post, to figure out why it wasn’t working. I have everything already installed I needed to. Just a matter of configuring.
That said, I’d expect performance to be horrible, depending on what you’re doing. Remote consoles are sluggish to begin with, and tunnelling it over ssh doesn’t exactly help.
If you haven’t already, I’d probably reach for waypipe instead. It’s not a full VM console, but it’s fantastic for running individual apps remotely. (And there are ways to connect to a full Plasma or Gnome desktop too.)
So it’s great to have both! As obviously, you need the actual console for many things. (And when UI performance isn’t exactly at the top of the priority list.)
Hi @Molski
I confirm: the performance over ssh is terrible.
I should like to use waypipe but didn’t find the documentation about to connect a full plasma desktop. Can you point me in the right direction?
Maybe someone, smarter than me, can post in the tutorial section a guide to interacting with remote VM gui.
A checklist of things to setup should be useful:
  • verify your brain is connected (my case :slightly_smiling_face: )
  • enable AllowTcpForwarding
  • use waypipe to connect the remote desktop [add configuration]
… and thanks for your time
This part is just connecting to other hosts (that happen to be virtualised.)
I often import my keys to make this easier. (i.e. ssh-copy-id user@guest) So I can simply:
waypipe ssh host /usr/bin/firefox &
Here are a couple links:
Hi @Molski it worked
I normally use ssh-copy-id to ssh into machines without giving a password
so the command
waypipe ssh mostro /usr/bin/startplasma-wayland
works perfectly
Now I’ll study the tutorials you cited
Thanks a lot
