In order to unlock switch to a virtual terminal(Ctrl+Alt+F2), login and execute the command loginctl unlock-session 2. Afterwards switch back to the running session (Ctrl+Alt+F1)
Tried: resetting lock screen params and image in settings GUI; solution from here; reinstalling kscreenlocker. Nothing helps so far.
мар 08 19:30:27 gigas-pc kscreenlocker_greet[38293]: Qt: Session management error: networkIdsList argument is NULL
мар 08 19:30:27 gigas-pc kscreenlocker_greet[38293]: Icon theme "ubuntu-mono-dark" not found.
мар 08 19:30:27 gigas-pc kscreenlocker_greet[38293]: Icon theme "Mint-X" not found.
мар 08 19:30:27 gigas-pc kscreenlocker_greet[38293]: Icon theme "elementary" not found.
мар 08 19:30:27 gigas-pc kscreenlocker_greet[38293]: file:///home/gigas/.local/share/plasma/look-and-feel/Sweet/contents/lockscreen/LockScreen.qml:52:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
мар 08 19:30:28 gigas-pc kscreenlocker_greet[38293]: file:///home/gigas/.local/share/plasma/look-and-feel/Sweet/contents/lockscreen/MainBlock.qml:101:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
мар 08 19:30:28 gigas-pc kscreenlocker_greet[38293]: file:///home/gigas/.local/share/plasma/look-and-feel/Sweet/contents/lockscreen/LockScreenUi.qml:66:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
мар 08 19:30:28 gigas-pc kscreenlocker_greet[38293]: file:///home/gigas/.local/share/plasma/look-and-feel/Sweet/contents/lockscreen/LockScreenUi.qml:43:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
мар 08 19:30:28 gigas-pc kscreenlocker_greet[38293]: Cannot mix incompatible Qt library (5.15.2) with this library (5.15.3)
мар 08 19:30:28 gigas-pc audit[38293]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=2 pid=38293 comm="kscreenlocker_g" exe="/usr/lib/kscreenlocker_greet" sig=6 res=1
мар 08 19:30:28 gigas-pc kernel: audit: type=1701 audit(1646757028.321:120): auid=1000 uid=1000 gid=1000 ses=2 pid=38293 comm="kscreenlocker_g" exe="/usr/lib/kscreenlocker_greet" sig=6 res=1
мар 08 19:30:28 gigas-pc kscreenlocker_greet[38323]: Qt: Session management error: networkIdsList argument is NULL
мар 08 19:30:28 gigas-pc kscreenlocker_greet[38323]: Icon theme "ubuntu-mono-dark" not found.
мар 08 19:30:28 gigas-pc kscreenlocker_greet[38323]: Icon theme "Mint-X" not found.
мар 08 19:30:28 gigas-pc kscreenlocker_greet[38323]: Icon theme "elementary" not found.
мар 08 19:30:28 gigas-pc kscreenlocker_greet[38323]: file:///home/gigas/.local/share/plasma/look-and-feel/Sweet/contents/lockscreen/LockScreen.qml:52:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
мар 08 19:30:28 gigas-pc kscreenlocker_greet[38323]: file:///home/gigas/.local/share/plasma/look-and-feel/Sweet/contents/lockscreen/MainBlock.qml:101:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
мар 08 19:30:28 gigas-pc kscreenlocker_greet[38323]: file:///home/gigas/.local/share/plasma/look-and-feel/Sweet/contents/lockscreen/LockScreenUi.qml:66:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
мар 08 19:30:28 gigas-pc kscreenlocker_greet[38323]: file:///home/gigas/.local/share/plasma/look-and-feel/Sweet/contents/lockscreen/LockScreenUi.qml:43:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
мар 08 19:30:28 gigas-pc kscreenlocker_greet[38323]: Cannot mix incompatible Qt library (5.15.2) with this library (5.15.3)
мар 08 19:30:28 gigas-pc audit[38323]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=2 pid=38323 comm="kscreenlocker_g" exe="/usr/lib/kscreenlocker_greet" sig=6 res=1
мар 08 19:30:28 gigas-pc kernel: audit: type=1701 audit(1646757028.644:121): auid=1000 uid=1000 gid=1000 ses=2 pid=38323 comm="kscreenlocker_g" exe="/usr/lib/kscreenlocker_greet" sig=6 res=1
мар 08 19:30:28 gigas-pc kscreenlocker_greet[38346]: Qt: Session management error: networkIdsList argument is NULL
мар 08 19:30:28 gigas-pc kscreenlocker_greet[38346]: Icon theme "ubuntu-mono-dark" not found.
мар 08 19:30:28 gigas-pc kscreenlocker_greet[38346]: Icon theme "Mint-X" not found.
мар 08 19:30:28 gigas-pc kscreenlocker_greet[38346]: Icon theme "elementary" not found.
мар 08 19:30:28 gigas-pc kscreenlocker_greet[38346]: file:///home/gigas/.local/share/plasma/look-and-feel/Sweet/contents/lockscreen/LockScreen.qml:52:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
мар 08 19:30:28 gigas-pc kscreenlocker_greet[38346]: file:///home/gigas/.local/share/plasma/look-and-feel/Sweet/contents/lockscreen/MainBlock.qml:101:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
мар 08 19:30:28 gigas-pc kscreenlocker_greet[38346]: file:///home/gigas/.local/share/plasma/look-and-feel/Sweet/contents/lockscreen/LockScreenUi.qml:66:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
мар 08 19:30:28 gigas-pc kscreenlocker_greet[38346]: file:///home/gigas/.local/share/plasma/look-and-feel/Sweet/contents/lockscreen/LockScreenUi.qml:43:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
мар 08 19:30:28 gigas-pc kscreenlocker_greet[38346]: Cannot mix incompatible Qt library (5.15.2) with this library (5.15.3)
мар 08 19:30:28 gigas-pc audit[38346]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=2 pid=38346 comm="kscreenlocker_g" exe="/usr/lib/kscreenlocker_greet" sig=6 res=1
мар 08 19:30:28 gigas-pc kernel: audit: type=1701 audit(1646757028.977:122): auid=1000 uid=1000 gid=1000 ses=2 pid=38346 comm="kscreenlocker_g" exe="/usr/lib/kscreenlocker_greet" sig=6 res=1
мар 08 19:30:29 gigas-pc kscreenlocker_greet[38369]: Qt: Session management error: networkIdsList argument is NULL
мар 08 19:30:29 gigas-pc kscreenlocker_greet[38369]: Icon theme "ubuntu-mono-dark" not found.
мар 08 19:30:29 gigas-pc kscreenlocker_greet[38369]: Icon theme "Mint-X" not found.
мар 08 19:30:29 gigas-pc kscreenlocker_greet[38369]: Icon theme "elementary" not found.
мар 08 19:30:29 gigas-pc kscreenlocker_greet[38369]: file:///home/gigas/.local/share/plasma/look-and-feel/Sweet/contents/lockscreen/LockScreen.qml:52:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
мар 08 19:30:29 gigas-pc kscreenlocker_greet[38369]: file:///home/gigas/.local/share/plasma/look-and-feel/Sweet/contents/lockscreen/MainBlock.qml:101:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
мар 08 19:30:29 gigas-pc kscreenlocker_greet[38369]: file:///home/gigas/.local/share/plasma/look-and-feel/Sweet/contents/lockscreen/LockScreenUi.qml:66:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
мар 08 19:30:29 gigas-pc kscreenlocker_greet[38369]: file:///home/gigas/.local/share/plasma/look-and-feel/Sweet/contents/lockscreen/LockScreenUi.qml:43:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
мар 08 19:30:29 gigas-pc kscreenlocker_greet[38369]: Cannot mix incompatible Qt library (5.15.2) with this library (5.15.3)
мар 08 19:30:29 gigas-pc audit[38369]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=2 pid=38369 comm="kscreenlocker_g" exe="/usr/lib/kscreenlocker_greet" sig=6 res=1
мар 08 19:30:29 gigas-pc kernel: audit: type=1701 audit(1646757029.294:123): auid=1000 uid=1000 gid=1000 ses=2 pid=38369 comm="kscreenlocker_g" exe="/usr/lib/kscreenlocker_greet" sig=6 res=1
Yep. You are right. What is the output of cat /var/log/pacman.log | grep qt5?
Is any of these stuff installed from the AUR? If yes then rebuild them. Also try resetting your themes and stuff to verify if it’s the themes causing the issue or not.
