Krdc 24.02 + freedp 3.1 or 3.4 is not working
Manjaro Testing, current version. There was a problem after last updating.
  1. upgraded krdc (23.08.5-1 → 24.02.1-2)
  2. upgraded freerdp (2:2.11.4-1 → 2:3.4.0-5)
  3. It is impossible to select rdp protocol in the krdc settings (empty place)
  4. krdc rdp://user@host from console: QLibraryPrivate::loadPlugin failed on “/usr/lib/qt/plugins/krdc/libkrdc_rdpplugin.so”
  5. /usr/lib/qt/plugins/krdc/libkrdc_rdpplugin.so is present.
any ideas??
Just for the sake of verifying I tested krdc and wasn’t able to use either - it depends on the version of freerdp installed and I have the package freerdp2 synced.
I believe it is an upstream kde issue - but I cannot be sure - but I would start by checking the bugs.kde.org to see if already reported.
I ran into issues with krdc a while back - created a script template for it.
My script stalled when the update came in unstable branch.
After some troubleshooting I found that we have two packages freerdp2 and freerdp.
Syncing the former restored my script functions by providing the usual xfreerdp and wlfreerdp binaries
I have freerdp working by using a script.
When you use Plasma and Wayland the wlfreerdp3 is deprecated and it is recommend to replace with sdl based client (I haven’t got that part myself yet).
The freerdp package does not provide wlfreerdp which is binary used on Wayland - it only provides the deprecated wlfreerdp3.
The solution to my issue was to sync the freerdp2 package - in addition to removing krdc and freerdp - which provides wlfreerdp and xfreerdp which is the binaries my script relies on.
And I rely on rdp for development tasks - so I am crippled when it is not working.
I tried to delete freerdp 3.4 and and installed freerdp2 2.11.5. Krdc is the same version 24.0.2.
This combination opens a window of the remote system, but TAB key inside remote window is not worked :frowning: (bug id=483638 in KDE bugs list)
Now then.
  1. Combination of new krdc 24.02.1 and freerdp3 3.1 or 3.4 doesn’t work.
  2. Combination of new krdc 24.02.1 and old freerdp2 (2.11.5 from testing repositories) works, but TAB key does not perform the function.
  3. Downgraded krdc from 24.02.1 to 23.08.5 with old freerdp2 is fully working.
I continue to monitor situation :slight_smile:
I updated all programs using pamac.
KDE Plasma Version: 6.0.5
KDE Frameworks Version: 6.2.0
Qt Version: 6.7.1
Kernel Version: 6.2.16-2-MANJARO (64-bit)
Graphics Platform: X11
There was a problem with the application - KRDC 24.05.0 -
When trying to connect via RDP, a request began to appear
Unknown certificate for this system. Continue?
Error appears when entering password
Failed to sign in using the provided credentials. Please carefully check that your username and password are correct.
pamac install flatpak libpamac-flatpak-plugin
flatpak search org.kde.krdc
flatpak install org.kde.krdc
flatpak run org.kde.krdc
version KRDC 23.08.5 from flatpak works!
How to fix the problem with krds - KRDC 24.05.0 - ?
krdc 24.05.0-1 has the same behavior - the tab key in the remote system window also does not work
My system: Manjaro testing, kernel 6.9,3-3, KDE 6.0.5, Xorg.
another rollback to the old working version 23.08.5 :frowning:
