Hi, I have a rendering problem in KDE Konsole terminal when using tmux with multiple panes. I’ve attached the photo because artifacts disappear when a screenshot is taken. Stripes appear after quick pane change or modifying large blocks in vim. They disappear after s second or two or after the next screen cursor movement. Their amount and placement are random. In general, it appears after operations in the terminal produce a lot of line changes. I’ve observed this effect only in Tmux inside Konsole emulator (I’ve checked on xterm and terminator and I haven’t noticed this effect). It worked well a month or two ago (I think I’ve updated Manjaro twice since then). I’ve read that it may be caused by screen scaling but I use 100%. It’s not making work impossible but it’s getting more and more annoying over time. One option is to switch terminal emulator but I like Konsole… Has anyone experienced something similar?
OS: Manjaro Linux x86_64
Host: UX305UA 1.0
Kernel: 5.14.10-1-MANJARO
Uptime: 26 mins
Packages: 1659 (pacman)
Shell: zsh 5.8
Resolution: 1920x1080
DE: Plasma 5.22.5
WM: KWin
WM Theme: Freeze
Theme: Breath [Plasma], Breath [GTK2/3]
Icons: breath [Plasma], breath [GTK2/3]
Terminal: tmux
CPU: Intel i5-6200U (4) @ 2.800GHz
GPU: Intel Skylake GT2 [HD Graphics 520]
Memory: 3702MiB / 7853MiB
DISTRIB_RELEASE=21.1.6
DISTRIB_CODENAME=Pahvo
tmux 3.2a
konsole 21.08.2
Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=053e926f-8ed5-40f2-90ea-17fef085167c rw quiet
resume=UUID=6cdd92c4-cca4-4ee1-9a22-47d72226ec03
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: UX305UA v: 1.0 serial: <filter>
Mobo: ASUSTeK model: UX305UA v: 1.0 serial: <filter>
UEFI: American Megatrends v: UX305UA.302 date: 04/18/2019
ID-1: BAT0 charge: 32.1 Wh (98.5%) condition: 32.6/56.0 Wh (58.2%)
volts: 11.3 min: 11.3 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Not charging cycles: 315
RAM: total: 7.67 GiB used: 5.49 GiB (71.6%)
Info: Dual Core model: Intel Core i5-6200U bits: 64 type: MT MCP
arch: Skylake family: 6 model-id: 4E (78) stepping: 3 microcode: EA cache:
L2: 3 MiB bogomips: 19204
Speed: 700 MHz min/max: 400/2800 MHz Core speeds (MHz): 1: 700 2: 786 3: 732
4: 785
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: ASUSTeK driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: Realtek USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-5:2 chip-ID: 0bda:57cb class-ID: 0e02 serial: <filter>
loaded: modesetting unloaded: vesa alternate: fbdev display-ID: :0
screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 166 size: 293x165mm (11.5x6.5")
diag: 336mm (13.2")
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 21.2.3
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d70 class-ID: 0403
Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 15.0 running: no
Sound Server-5: PipeWire v: 0.3.38 running: yes
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel bus-ID: 02:00.0
chip-ID: 8086:095a class-ID: 0280
IP v4: <filter> scope: global
IP v6: <filter> virtual: stable-privacy scope: link
bus-ID: 1-8:3 chip-ID: 8087:0a2a class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 238.47 GiB used: 157.11 GiB (65.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Micron model: M600 MTFDDAV256MBF
size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: MA01 scheme: GPT
ID-1: / raw-size: 175.74 GiB size: 172.74 GiB (98.29%)
used: 157.08 GiB (90.9%) fs: ext4 dev: /dev/sda7 maj-min: 8:7 label: N/A
uuid: 053e926f-8ed5-40f2-90ea-17fef085167c
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 24.7 MiB (9.7%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 67AE-6FA8
ID-1: swap-1 type: partition size: 2.66 GiB used: 12.8 MiB (0.5%)
priority: -2 dev: /dev/sda6 maj-min: 8:6 label: N/A
uuid: 6cdd92c4-cca4-4ee1-9a22-47d72226ec03
ID-1: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda3 maj-min: 8:3 size: 58.98 GiB fs: ntfs label: OS
uuid: 987E6ACD7E6AA42A
ID-3: /dev/sda4 maj-min: 8:4 size: 842 MiB fs: ntfs label: N/A
uuid: EE906F46906F147D
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-5:2 info: Realtek USB2.0 HD UVC WebCam type: Video
Device-2: 1-8:3 info: Intel Bluetooth wireless interface type: Bluetooth
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 41.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2800
Processes: 319 Uptime: 2h 12m wakeups: 16118 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1659
lib: 460 flatpak: 0 Shell: Zsh v: 5.8 running-in: tmux: inxi: 3.3.07
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
eDP-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 293mm x 165mm
1920x1080 60.05*+ 60.01 59.97 59.96 59.93
1680x1050 59.95 59.88
1400x1050 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 60.02
1400x900 59.96 59.88
1280x960 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1280x800 59.99 59.97 59.81 59.91
1280x720 60.00 59.99 59.86 59.74
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
960x540 59.96 59.99 59.63 59.82
800x600 60.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
700x525 59.98
800x450 59.95 59.82
640x512 60.02
700x450 59.96 59.88
640x480 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
640x400 59.88 59.98
640x360 59.86 59.83 59.84 59.32
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
DP-1 disconnected (normal left inverted right x axis y axis)
HDMI-1 disconnected (normal left inverted right x axis y axis)
HDMI-2 disconnected (normal left inverted right x axis y axis)
Xorg and syslog do not produce anything interesting when the problem occurs.
