Hey there. I dual boot Manjaro Linux (LTS) and Windows 10. And I have problems with the internet via ethernet cable. In windows both Wi-Fi and Ethernet work fine. But when I boot Manjaro only wifi works. Ethernet connection doesnβt appear at all.
Specifications:
Kernel: 5.4.58-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
root=UUID=c1d616f4-e56d-428b-8c19-5c772696df93 rw quiet apparmor=1
Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop Mobo: Micro-Star model: MPG B550 GAMING EDGE WIFI (MS-7C91)
v: 1.0 serial: <filter> UEFI: American Megatrends v: 1.00 date: 05/29/2020
Topology: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: N/A microcode: 8701021
L2 cache: 3072 KiB
bogomips: 86433
Speed: 3595 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 3600 2: 2053 3: 3589 4: 2056 5: 2056 6: 2057 7: 3595 8: 2057 9: 3597
10: 2046 11: 2056 12: 2060
conditional, RSB filling
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: Sapphire Limited driver: amdgpu v: kernel bus ID: 2d:00.0
chip ID: 1002:731f
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: amdgpu
FAILED: ati unloaded: modesetting,radeon alternate: fbdev,vesa
display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 92
size: 532x304mm (20.9x12.0") diag: 613mm (24.1")
OpenGL: renderer: AMD Radeon RX 5700 XT (NAVI10 DRM 3.35.0 5.4.58-1-MANJARO
LLVM 10.0.1)
v: 4.6 Mesa 20.1.5 direct render: Yes
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
bus ID: 2d:00.1 chip ID: 1002:ab38
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 2f:00.4 chip ID: 1022:1487
Sound Server: ALSA v: k5.4.58-1-MANJARO
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus ID: 29:00.0
chip ID: 8086:2723
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: N/A
modules: r8169 port: f000 bus ID: 2a:00.0 chip ID: 10ec:8125
Local Storage: total: 894.25 GiB used: 10.68 GiB (1.2%)
ID-1: /dev/sda vendor: A-Data model: SU630 size: 894.25 GiB block size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 3B0
scheme: GPT
ID-1: / raw size: 244.14 GiB size: 239.31 GiB (98.02%)
used: 10.65 GiB (4.5%) fs: ext4 dev: /dev/sda5
System Temperatures: cpu: 49.2 C mobo: N/A gpu: amdgpu temp: 50 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 304 Uptime: N/A Memory: 15.65 GiB used: 790.2 MiB (4.9%)
Init: systemd v: 245 Compilers: gcc: 10.1.0 Packages: pacman: 1221 lib: 344
flatpak: 0 Shell: Bash v: 5.0.18 running in: yakuake inxi: 3.1.05
I did $ sudo dmesg -l emerg,alert,crit,err,warn just to see if some of this errors have relation.
[ 0.316977] do_IRQ: 1.55 No irq handler for vector
[ 0.734325] #2
[ 0.316977] do_IRQ: 2.55 No irq handler for vector
[ 0.774326] #3
[ 0.316977] do_IRQ: 3.55 No irq handler for vector
[ 0.814325] #4
[ 0.316977] do_IRQ: 4.55 No irq handler for vector
[ 0.854324] #5
[ 0.316977] do_IRQ: 5.55 No irq handler for vector
[ 0.894324] #6
[ 0.316977] do_IRQ: 6.55 No irq handler for vector
[ 0.934327] #7
[ 0.316977] do_IRQ: 7.55 No irq handler for vector
[ 0.974325] #8
[ 0.316977] do_IRQ: 8.55 No irq handler for vector
[ 1.014325] #9
[ 0.316977] do_IRQ: 9.55 No irq handler for vector
[ 1.054326] #10
[ 0.316977] do_IRQ: 10.55 No irq handler for vector
[ 1.094324] #11
[ 1.108831] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP8._DSM], AE_ALREADY_EXISTS (20190816/dswload2-326)
[ 1.108834] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20190816/psobject-220)
[ 1.235829] PPR X2APIC NX GT IA GA PC GA_vAPIC
[ 1.240564] efifb: Ignoring BGRT: unexpected or invalid BMP data
[ 4.286444] sp5100-tco sp5100-tco: Watchdog hardware is disabled
[ 4.302385] r8169 0000:2a:00.0: unknown chip XID 641
[ 4.824763] thermal thermal_zone0: failed to read out thermal zone (-61)
[ 5.373089] iwlwifi 0000:29:00.0: FW already configured (0) - re-configuring
[ 5.573051] iwlwifi 0000:29:00.0: FW already configured (0) - re-configuring
[ 5.757797] amdgpu: [powerplay] SMU driver if version not matched
[ 6.151844] kauditd_printk_skb: 29 callbacks suppressed
[ 14.607729] kauditd_printk_skb: 9 callbacks suppressed
[ 81.573012] iwlwifi 0000:29:00.0: FW already configured (0) - re-configuring
Hope you can help me. Thanks for your time and help.
