Noob using Logitech K580 wireless keyboard.
Keyboard basically works (I can type, use the number row, enter key, etc), but number pad doesn’t work and I don’t know what any of the other misc. keys actually do now.
Is there something I can download or a command or something that will make Manjaro recognize this specific keyboard and enable all of its functionality?
Thanks in advance for any help.
Check out solaar, it’s in the official repos. Solaar | Linux Device Manager for Logitech Unifying Receivers and Devices.
Hi and welcome to the forum
For the OP and those interested in his Keyboard, it is probably one of these:
- Logitech K580 Multi-Device Wireless Keyboard - Chrome OS™
- Logitech K580 for Chrome OS + M350 | Keyboard & Mouse Combo
- I would suggest to contact the maker of your Keyboard for support with Linux.
- For people on the forum that have knowledge to assist you, you should provide some system info:
That’s only for managing the Unifying Receiver connection and viewing the battery level of connected devices.
@motojojo As far as remapping keys, you might try piper
available in the AUR (Arch User Repository)
