Hi,
I’ve just put my MSI Prestige 15 to Manjaro. I can’t find the perfect keyboard settings.
I mainly have problem with the >/< key. When I press it, it detect the same keycode as the */µ key.
This is my inxi output:
~ inxi --admin --verbosity=7 --filter --no-host --width ✔
Kernel: 5.10.52-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=ad8fae2b-2c07-435e-a4de-ed6699940bd8 rw quiet splash apparmor=1
security=apparmor resume=UUID=345cd9f3-df13-4db2-9b1f-6a75b78b0587
udev.log_priority=3
Desktop: GNOME 40.3 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.0
Type: Laptop System: Micro-Star product: Prestige 15 A10SC v: REV:1.0
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Micro-Star model: MS-16S3 v: REV:1.0 serial: <filter>
UEFI: American Megatrends v: E16S3IMS.106 date: 09/09/2019
ID-1: BAT1 charge: 55.4 Wh (94.5%) condition: 58.6/80.3 Wh (73.0%)
volts: 15.7 min: 15.2 model: MSI BIF0_9 type: Li-ion serial: N/A
status: Discharging
RAM: total: 15.47 GiB used: 2.61 GiB (16.9%)
Info: 6-Core model: Intel Core i7-10710U bits: 64 type: MT MCP arch: N/A
family: 6 model-id: A6 (166) stepping: 0 microcode: E8 cache: L2: 12 MiB
bogomips: 38415
Speed: 400 MHz min/max: 400/4700 MHz Core speeds (MHz): 1: 400 2: 400 3: 400
4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Device-1: Intel Comet Lake UHD Graphics vendor: Micro-Star MSI driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:9bca class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Micro-Star MSI driver: nouveau v: kernel bus-ID: 02:00.0
chip-ID: 10de:1f91 class-ID: 0302
Display: wayland server: X.org 1.20.11 compositor: gnome-shell driver:
loaded: nouveau note: n/a (using device driver) - try sudo/root
display-ID: 0 resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.1.5
direct render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0403
Sound Server-1: ALSA v: k5.10.52-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.32 running: no
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
port: 4000 bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 4-2.3:3 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp57s0u2u3 state: down mac: <filter>
bus-ID: 1-10:5 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Permissions: Unable to run lvs. Root privileges required.
Local Storage: total: 506.1 GiB used: 49.12 GiB (9.7%)
ID-1: /dev/mmcblk0 maj-min: 179:0 vendor: SanDisk model: SD16G
size: 29.16 GiB block-size: physical: 512 B logical: 512 B rotation: SSD
serial: <filter> scheme: MBR
ID-2: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital
model: PC SN730 SDBPNTY-512G-1032 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD
serial: <filter> rev: 11110000 temp: 31.9 C scheme: GPT
ID-1: / raw-size: 459.62 GiB size: 451.33 GiB (98.20%)
used: 33.85 GiB (7.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: ad8fae2b-2c07-435e-a4de-ed6699940bd8
label: NO_LABEL uuid: 4618-1068
ID-3: /run/media/chokearth/Chokearth raw-size: 29.16 GiB
size: 28.58 GiB (98.00%) used: 15.26 GiB (53.4%) fs: ext4
dev: /dev/mmcblk0p1 maj-min: 179:1 label: Chokearth
uuid: 0600cedf-db04-46b3-89b9-314e295395c4
ID-1: swap-1 type: partition size: 17.02 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 345cd9f3-df13-4db2-9b1f-6a75b78b0587
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Hub-2: 1-5:2 info: Terminus USB 2.0 Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0801 class-ID: 0900
Device-1: 1-5.1:4 info: VIA Labs USB 2.0 BILLBOARD type: Billboard
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s chip-ID: 2109:0102
class-ID: 1100 serial: <filter>
Hub-3: 1-5.2:6 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2817 class-ID: 0900
Hub-4: 1-5.3:7 info: Terminus USB 2.0 Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-5.3.3:8 info: Logitech G502 Proteus Spectrum Optical Mouse
type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 300mA chip-ID: 046d:c332 class-ID: 0300
serial: <filter>
Device-2: 1-5.3.4:9 info: Logitech G910 Orion Spectrum Mechanical Keyboard
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 046d:c335 class-ID: 0300
serial: <filter>
Device-3: 1-6:3 info: Synaptics type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 06cb:009b
class-ID: ff00 serial: <filter>
Device-4: 1-10:5 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-5: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s
Hub-6: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-7: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-8: 4-2:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 2109:0817 class-ID: 0900
Device-1: 4-2.3:3 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 288mA chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
System Temperatures: cpu: 48.0 C mobo: N/A gpu: nouveau temp: 28.0 C
Processes: 299 Uptime: 9m wakeups: 8 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1276 lib: 406 flatpak: 0 Shell: Zsh
v: 5.8 running-in: gnome-terminal inxi: 3.3.05
Does anybody know the correct settings ?
Thanks in advance!
