When I start a Plasma Wayland Session, I am able to type my password at SDDM and log in, but after login, keystrokes are no longer accepted.
More specifically:
- Super key does bring up the menu
- F12 makes Yakuake show and immediately hide again (.as if pressing it twice very fast)
- Arrow keys don’t respond
- text entry doesn’t work
- I’m able to switch between TTYs, for instance with Ctrl+Alt+F3
- Function keys do not work alone, E.g. F10 should create new folder in Dolphin, doesn’t work
- mouse clicks work normally
X11 works fine. I’d really like to switch to Wayland because of better support for touchpad gestures.
Here’s some info about my system:
~ inxi -v7azy
Kernel: 6.1.55-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: acpi_pm
root=UUID=02d09efd-0036-4efc-ace1-08d57809dd36 rw quiet apparmor=1
security=apparmor udev.log_priority=3 sysrq_always_enabled=1
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2 dm: SDDM
Type: Laptop System: TUXEDO product: TUXEDO v: N/A
serial: <superuser required> Chassis: Notebook type: 10
Mobo: TUXEDO model: N141CU serial: <superuser required> UEFI: INSYDE
v: 1.07.07RTR1 date: 11/08/2019
ID-1: BAT0 charge: 36.2 Wh (96.5%) condition: 37.5/35.3 Wh (106.2%)
volts: 12.0 min: 11.4 model: Notebook BAT type: Li-ion serial: <filter>
status: discharging
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M315/M235
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
System RAM: total: 16 GiB note: est. available: 15.32 GiB used: 5 GiB (32.6%)
Info: model: Intel Core i7-10510U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check gen: core 10 level: v3 note: check
built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xF8
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 802 high: 814 min/max: 400/4900 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 814 4: 800
5: 800 6: 809 7: 800 8: 800 bogomips: 36812
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand
rdseed rdtscp rep_good sdbg sep sgx smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: CLEVO/KAPOK
ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:9b41 class-ID: 0300
Device-2: Chicony USB2.0 Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:3 chip-ID: 04f2:b649
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.2.1
compositor: kwin_x11 driver: X: loaded: intel gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP1 model: AU Optronics 0x543d built: 2017
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85")
diag: 355mm (14") ratio: 16:9 modes: 1920x1080
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: swrast
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: llvmpipe (LLVM 16.0.6 256 bits)
device-ID: ffffffff:ffffffff memory: 14.96 GiB unified: yes
API: Vulkan v: 1.3.264 layers: 4 device: 0 type: integrated-gpu name: Intel
UHD Graphics (CML GT2) driver: mesa intel v: 23.1.9-manjaro1.1
device-ID: 8086:9b41 surfaces: N/A
Device-1: Intel Comet Lake PCH-LP cAVS vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0403
API: ALSA v: k6.1.55-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.81 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 5000 bus-ID: 3b:00.1 chip-ID: 10ec:8168 class-ID: 0200
IF: enp59s0f1 state: down mac: <filter>
Device-2: Intel Wireless-AC 9260 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 40:00.0 chip-ID: 8086:2526 class-ID: 0280
IF: wlp64s0 state: up mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4
chip-ID: 8087:0025 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 953.87 GiB used: 500.56 GiB (52.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW010T8
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 29.9 C scheme: GPT
ID-1: / raw-size: 206.87 GiB size: 202.56 GiB (97.92%)
used: 53.01 GiB (26.2%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
label: MNJ uuid: 02d09efd-0036-4efc-ace1-08d57809dd36
used: 5.4 MiB (1.8%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3 label: UEFI
uuid: 2F50-AF86
ID-3: /home raw-size: 553.57 GiB size: 543.81 GiB (98.24%)
used: 447.53 GiB (82.3%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
label: Home uuid: 3814dd46-f87d-457e-b4e7-34dae63757f8
ID-1: swap-1 type: partition size: 8 GiB used: 21.8 MiB (0.3%) priority: -2
dev: /dev/nvme0n1p2 maj-min: 259:2 label: Swap
uuid: 81357175-5808-423e-8f8d-82a2642b02a7
ID-1: /dev/nvme0n1p5 maj-min: 259:5 size: 93.13 GiB fs: ext4 label: N/A
uuid: 991aa536-b6d0-4afe-bf56-a2dc2d0d2572
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-4:2 info: Logitech Unifying Receiver type: mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c52f class-ID: 0300
Device-2: 1-7:3 info: Chicony USB2.0 Camera type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 04f2:b649 class-ID: 0e02
Device-3: 1-10:4 info: Intel Wireless-AC 9260 Bluetooth Adapter
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
System Temperatures: cpu: 43.0 C pch: 44.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 291 Uptime: 6m wakeups: 3 Init: systemd v: 254 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: 1936
pm: pacman pkgs: 1897 libs: 469 tools: pamac,yay pm: flatpak pkgs: 35
pm: snap pkgs: 4 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: yakuake inxi: 3.3.30
