Keyboard Backlight Not Working Samsung Galaxy Chromebook, possible fix?
I am curious if it is possible to fix my laptop backlit keyboard as it looks like its detected internally in Manjaro.
I was reading around and saw this command:
ls -l /sys/class/leds/
lsmod | grep -i system76
output:
lrwxrwxrwx 1 root root 0 Sep 23 22:23 chromeos::kbd_backlight -> ../../devices/platform/GOOG0002:00/leds/chromeos::kbd_backlight
Anything helps! Thanks in advance!
Not sure if this helps at all. Saw a driver online “leds: Add Chrome OS keyboard backlight LEDs driver” since I cant post links. Sorry, I am a newbie here.
Following command:
cat /sys/class/leds/chromeos::kbd_backlight/brightness
0
cat /sys/class/leds/chromeos::kbd_backlight/max_brightness
100
Ok I did your command:
Outcome:
  Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=0b3d851a-ce35-4ff2-a57a-8d1db8419e20 rw quiet
  cryptdevice=UUID=583f7780-2c8d-4b06-a62c-3ca33984fb3f:luks-583f7780-2c8d-4b06-a62c-3ca33984fb3f
  root=/dev/mapper/luks-583f7780-2c8d-4b06-a62c-3ca33984fb3f splash apparmor=1
  Console: tty pts/0 wm: gnome-shell DM: GDM 40.1 Distro: Manjaro Linux
  base: Arch Linux
  Type: Laptop System: Google product: Kohaku v: rev6 serial: <filter>
  Chassis: type: 9 serial: N/A
  Mobo: Google model: Kohaku v: rev6 serial: <filter> UEFI: coreboot
  v: MrChromebox-4.14 date: 07/25/2021
  ID-1: BAT0 charge: 47.0 Wh (97.1%) condition: 48.4/48.0 Wh (100.9%)
  volts: 8.4 min: 7.7 model: SDI 4404D62 type: Li-ion serial: <filter>
  status: Discharging
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S
  status: Discharging
  RAM: total: 7.64 GiB used: 3.35 GiB (43.8%)
  Array-1: capacity: 64 GiB note: check slots: 2 EC: None
  Device-1: Channel-0-DIMM-0 size: 4 GiB speed: 2133 MT/s type: LPDDR3
  detail: unknown synchronous bus-width: 64 bits total: 64 bits
  manufacturer: N/A part-no: None serial: N/A
  Device-2: Channel-1-DIMM-0 size: 4 GiB speed: 2133 MT/s type: LPDDR3
  Info: Quad Core model: Intel Core i5-10210U bits: 64 type: MT MCP
  arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: C (12)
  microcode: EA cache: L1: 256 KiB L2: 6 MiB L3: 6 MiB bogomips: 33615
  Speed: 900 MHz min/max: 400/4200 MHz ext-clock: 100 MHz Core speeds (MHz):
  1: 900 2: 900 3: 900 4: 900 5: 900 6: 900 7: 900 8: 900
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
  arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
  cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est
  hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
  invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
  nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
  popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss
  ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
  tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
  xsaveopt xsaves xtopology xtpr
  Type: srbds mitigation: TSX disabled
  Device-1: Intel CometLake-U GT2 [UHD Graphics] driver: i915 v: kernel
  bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
  Device-2: Chicony 720p HD Camera type: USB driver: uvcvideo bus-ID: 1-7:3
  chip-ID: 04f2:b6b4 class-ID: 0e02 serial: <filter>
  Device-3: Chicony 8M Camera type: USB driver: uvcvideo bus-ID: 2-3:2
  chip-ID: 04f2:b6b5 class-ID: 0e02 serial: <filter>
  Display: server: X.org 1.20.13 compositor: gnome-shell driver: loaded: i915
  note: n/a (using device driver) resolution: <missing: xdpyinfo>
  OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.2.2
  direct render: Yes
  Device-1: Intel Comet Lake PCH-LP cAVS driver: sof-audio-pci-intel-cnl
  alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
  chip-ID: 8086:02c8 class-ID: 0401
  Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.37 running: yes
  Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
  port: 1000 bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
  bus-ID: 1-10:4 chip-ID: 8087:0026 class-ID: e001
  Device-1: luks-583f7780-2c8d-4b06-a62c-3ca33984fb3f maj-min: 254:0
  type: LUKS dm: dm-0 size: 238.17 GiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 238.17 GiB
  Local Storage: total: 238.47 GiB used: 28.85 GiB (12.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 model: SSSTC CL1-3D256 size: 238.47 GiB
  block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
  type: SSD serial: <filter> rev: CR22002 temp: 20.9 C scheme: GPT
  ID-1: / raw-size: 238.17 GiB size: 233.37 GiB (97.99%)
  used: 28.85 GiB (12.4%) fs: ext4 block-size: 4096 B dev: /dev/dm-0
  maj-min: 254:0 mapped: luks-583f7780-2c8d-4b06-a62c-3ca33984fb3f label: N/A
  uuid: 0b3d851a-ce35-4ff2-a57a-8d1db8419e20
  used: 440 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
  maj-min: 259:1 label: NO_LABEL uuid: A53C-E0DE
  ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
  file: /swapfile
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
  Device-1: 1-2:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
  power: 98mA chip-ID: 046d:c52b class-ID: 0300
  Device-2: 1-7:3 info: Chicony 720p HD Camera type: Video driver: uvcvideo
  interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b6b4
  Device-3: 1-10:4 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
  interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
  class-ID: e001
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s
  Device-1: 2-3:2 info: Chicony 8M Camera type: Video driver: uvcvideo
  interfaces: 2 rev: 3.2 speed: 5 Gb/s power: 800mA chip-ID: 04f2:b6b5
  System Temperatures: cpu: 29.0 C mobo: N/A
  Processes: 286 Uptime: 43m wakeups: 729 Init: systemd v: 249 tool: systemctl
  Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1268 lib: 332
  flatpak: 0 Shell: Zsh (sudo) v: 5.8 default: Bash v: 5.1.8
  running-in: gnome-terminal inxi: 3.3.06
:+1: Welcome to Manjaro! :+1:
  1. Please read this:
    How to provide good information
    and press the three dots below your post and press the :pencil2: to give us more information so we can see what’s really going on.
    Now we know the symptom of the disease, but we need some more probing to know where the origin lies… :grin:
  2. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
  3. What’s the output of:
  4. In the future, when providing code/output, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text so that the output looks like this:
    Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua.
    Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat.
    Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur.
    Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
    instead of like this:
    Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.`
    (as that makes both our lives much easier)
  5. No need to do anything right now as I’m a moderator here on this site and have fixed it for you already. However, in the future I might not see your post so review my RAW edits by pushing the orange pencil in the upper right corner of the post I just fixed. :wink:
:+1:
P.S. If you want to notify me that you did provide this information, please :heart: this message and I’ll come back and have another look.
P.P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which exact CPU/GPU or Kernel, … you have without typing it every time
Kernel 5.13 is EOL so please install both 5.4 and 5.10 LTS (Long Term Support) and see which one of the two troubles you least.
Fantastic! So what does:
echo 100 | sudo tee --append /sys/class/leds/chromeos::kbd_backlight/brightness
do?
Keyboard lights on now?
:grin:
Unrelated to your problem, but you have both PulseAudio and PipeWire running and they could conflict. If you want a stable experience, do a:
systemctl --user disable --now pipewire.socket
systemctl --user disable --now pipewire.service
systemctl --user mask pipewire.socket
:+1:
and if you like bleeding edge (unstable) do the opposite and disable&mask PulseAudio. :scream:
Yes the keyboard works now haha thanks, Is there a way for it to sensor when typing? What does “EOL” mean? And ill look into how I can install 5.4 and 5.10
Thanks
I don’t know what you mean…
You didn’t read the FAQ, did you?
https://www.kernel.org/category/faq.html
:stuck_out_tongue_winking_eye:
Please read this:
Especially the Linux has multiple kernels section, then try an LTS kernel and hopefully the problem will go away “automagically”. :grin:
:crossed_fingers:
Therefore, I’ve marked this answer as the solution to your question as it is by far the best answer you’ll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
:innocent:
P.S. In the future, please don’t forget to come back to your question after your issue has been solved and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
So I did what you said regarding
I am not sure what bleeding edge is, is it better than using pulseAudio?
Is there a way for the keyboard to light up when typing and then turn off when not in use?
Very new, very shiny, very broken unstable.
$ pulseaudio --version
pulseaudio 15.0
$ pipewire --version
pipewire
Compiled with libpipewire 0.3.37
Linked with libpipewire 0.3.37
but PulseAudio is on version 15, so rock stable and you just disabled PipeWire version 0.3.37.
:+1:
Thanks for answering my questions, Ill try a different kernel! Do you have a link for me to look into bleeding edge more? Thanks.
https://lmddgtfy.net/?q=linux%20bleeding%20edge
:stuck_out_tongue_winking_eye: :upside_down_face:
… your irony detector is broken?
I know the feeling.
Mine only works sparingly - and never at times when it’s needed the most :wink:
