I have this computer, keyboard and touchpad both can’t work. 1. Only volume/screenshot hotkeys work from internal keyboard. 2. Normal keys produce no events in evtest on event2 (AT Translated Set 2 keyboard). 2. Touchpad is completely missing from /proc/bus/input/devices and dmesg.
Please provide more information – generally.
Start with your system details as described (below)
and provide a better description of the issue you have encountered.
Also, tell us what you have already tried to solve the problem yourself, to avoid others suggesting something you have already done. Have you tried using other USB ports?
inxi -zv8 |
(short-form) |
inxi --filter --verbosity=8 |
(long-form) |
- man inxi (The
inximanual)
Command output should be presented as pre-formatted text in accordance with forum guidelines. ![]()
- Add
--color=0to the long-form command, or… - Change the short-form command to
inxi -zv8c0
Your privacy is respected
Note: Grave accent (or, backtick) characters are used. ![]()
- please follow this simple example:
code here.
- place text beween two rows of three (```) backtick characters to form a scrollable text box, or …
- use the </> button in the Compose window to achieve the same result.
What is a Quark?
Here is the requested inxi output from the Manjaro system:
Kernel: 6.18.18-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
root=UUID=251fb48c-13fd-4db6-b2f5-3b96947b1977 rw rootflags=subvol=@
quiet splash apparmor=1 security=apparmor udev.log_priority=3
Desktop: GNOME v: 49.5 tk: GTK v: 3.24.51 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 49.2 Distro: Manjaro
base: Arch Linux
Type: Laptop System: HONOR product: XWC-P v: M1120
serial: <superuser required>
Mobo: HONOR model: XWC-P-PCB v: M1120 serial: <superuser required>
part-nu: C233 uuid: <superuser required> Firmware: UEFI vendor: HONOR
v: 1.09 date: 03/19/2026
ID-1: BAT0 charge: 70.1 Wh (76.2%) condition: 92/92 Wh (100%) volts: 16.64
min: 15.64 model: NVT HB7075R5EHW-41T1 type: Li-ion serial: <filter>
charging: status: discharging control: start: 40% end: 70% cycles: 3
System RAM: total: 32 GiB available: 30.89 GiB used: 2.55 GiB (8.3%)
Array-1: capacity: 32 GiB slots: 8 modules: 8 EC: None
max-module-size: 4 GiB note: est.
Device-1: Controller0-ChannelA type: LPDDR5 detail: synchronous
size: 4 GiB speed: spec: 9600 MT/s actual: 8533 MT/s volts: curr: 0.5
width (bits): data: 16 total: 16 manufacturer: Micron Technology
part-no: MT62F2G64D8ZA-020 WT serial: N/A
Device-2: Controller0-ChannelB type: LPDDR5 detail: synchronous
Device-3: Controller0-ChannelC type: LPDDR5 detail: synchronous
Device-4: Controller0-ChannelD type: LPDDR5 detail: synchronous
Device-5: Controller1-ChannelA type: LPDDR5 detail: synchronous
Device-6: Controller1-ChannelB type: LPDDR5 detail: synchronous
Device-7: Controller1-ChannelC type: LPDDR5 detail: synchronous
Device-8: Controller1-ChannelD type: LPDDR5 detail: synchronous
Info: model: Intel Core Ultra 5 338H bits: 64 type: MCP arch: Panther Lake
level: v3 note: check built: 2025+ process: Intel 18a (1.8nm) family: 6
model-id: 0xCC (204) stepping: 2 microcode: 0x119
Topology: cpus: 1x dies: 1 clusters: 6 cores: 12 smt: <unsupported> cache:
L1: 1.2 MiB desc: d-8x32 KiB, 4x48 KiB; i-12x64 KiB L2: 20 MiB
desc: 4x3 MiB, 2x4 MiB L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 400 min/max: 400/4700:3600:3300 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 bogomips: 88473
bts bus_lock_detect clflush clflushopt clwb cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
ida intel_pt invpcid lahf_lm lam lm mca mce md_clear mmx monitor movbe
movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pge pku pln pni popcnt pse pse36 pts rdpid rdrand
rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni smap smep smx
split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg wbnoinvd x2apic
conditional; PBRSB-eIBRS: Not affected; BHI: BHI_DIS_S
Type: vmscape status: Not affected
Device-1: Intel Panther Lake [Arc B370] driver: xe v: kernel arch: Xe3
process: TSMC 18A built: 2025+ ports: active: eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:b081
class-ID: 0300
Device-2: Luxvisions Innotech FHD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 30c9:012c
compositor: gnome-shell driver: gpu: xe display-ID: 0
Monitor-1: eDP-1 model: TL160MDMP01 built: 2023 res: 3072x1920 dpi: 226
gamma: 1.2 chroma: red: x: 0.678 y: 0.322 green: x: 0.267 y: 0.690 blue:
x: 0.145 y: 0.047 white: x: 0.306 y: 0.322 size: 345x215mm (13.58x8.46")
diag: 407mm (16") ratio: 16:10 modes: 3072x1920
EDID-Warnings: 1: parse_edid: unknown tag 112
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 26.0.2-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (PTL)
device-ID: 8086:b081 memory: 30.16 GiB unified: yes display-ID: :0.0
Info: Tools: api: eglinfo,glxinfo x11: xprop
Device-1: Intel driver: sof-audio-pci-intel-ptl
alternate: snd_sof_pci_intel_ptl,snd_hda_intel bus-ID: 00:1f.3
chip-ID: 8086:e428 class-ID: 0401
API: ALSA v: k6.18.18-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.6.2 status: active with: 1: pipewire-pulse
Device-1: Intel driver: iwlwifi v: kernel port: N/A bus-ID: 00:14.3
chip-ID: 8086:e440 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
Device-1: Intel driver: btintel_pcie v: 0.1 bus-ID: 00:14.7
chip-ID: 8086:e476 class-ID: 0d11
Local Storage: total: 1013.35 GiB used: 36.79 GiB (3.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: N/A
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: ASXA0102 temp: 29.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Generic model: SD MMC size: 59.48 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter> fw-rev: 1.00
scheme: MBR
ID-1: / raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
used: 4.96 GiB (0.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 251fb48c-13fd-4db6-b2f5-3b96947b1977
used: 8.6 MiB (2.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 1225-FD8E
ID-3: /home raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
ID-4: /run/media/shilai/Ventoy raw-size: 59.45 GiB
size: 59.44 GiB (100.00%) used: 31.82 GiB (53.5%) fs: exfat dev: /dev/sda1
maj-min: 8:1 label: Ventoy uuid: 4E21-0000
ID-5: /var/cache raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
ID-6: /var/log raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
ID-1: /dev/sda2 maj-min: 8:2 size: 32 MiB fs: vfat label: VTOYEFI
uuid: E039-AD96
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 3 rev: 3.1
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 10 rev: 2.0
Hub-4: 3-1:2 info: Huasheng USB2.0 HUB ports: 4 rev: 2.0
chip-ID: 214b:7250 class-ID: 0900
Device-1: 3-1.1:4 info: YICHIP 2.4G Receiver type: keyboard,mouse
lanes: 1 mode: 1.1 power: 100mA chip-ID: 3151:3120 class-ID: 0301
serial: <filter>
Device-2: 3-1.2:6 info: SHARKOON GmbH 2.4GHz Wireless rechargeable
vertical mouse [More&Better] type: mouse driver: hid-generic,usbhid
interfaces: 1 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 100mA chip-ID: 1ea7:0064 class-ID: 0301
Device-3: 3-4:3 info: Luxvisions Innotech FHD Camera type: video
driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 30c9:012c class-ID: fe01
serial: <filter>
Device-4: 3-7:5 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 27c6:6f94 class-ID: ef00 serial: <filter>
Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
Device-1: 4-1:2 info: Realtek Card Reader type: mass storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 800mA chip-ID: 0bda:0316 class-ID: 0806
serial: <filter>
System Temperatures: cpu: 35.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1190 libs: 336 tools: gnome-software,pamac
pm: flatpak pkgs: 0
1: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
2: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
3: https://mirror.zetup.net/manjaro/stable/$repo/$arch
4: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
6: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
7: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
8: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
9: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
10: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
11: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
12: https://mirror.init7.net/manjaro/stable/$repo/$arch
13: https://mirror.dc.uz/manjaro/stable/$repo/$arch
14: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
15: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
16: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
17: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
18: https://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
19: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
20: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
21: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
22: https://mirror.easyname.at/manjaro/stable/$repo/$arch
23: https://mirror.komelt.dev/manjaro/stable/$repo/$arch
24: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
25: https://mirror.dimensiondata.com/mirrors/manjaro.org/stable/$repo/$arch
26: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
27: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
28: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
29: https://manjaro.kurdy.org/stable/$repo/$arch
30: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
31: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
32: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
33: https://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
34: https://mirror.23m.com/manjaro/stable/$repo/$arch
35: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
36: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
37: https://muug.ca/mirror/manjaro/stable/$repo/$arch
38: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
39: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
40: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
41: https://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
42: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
43: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
44: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
45: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
46: https://mirrors.manjaro.org/repo/stable/$repo/$arch
47: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
48: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
49: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
50: https://mirror.fcix.net/manjaro/stable/$repo/$arch
51: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
52: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
53: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
54: https://manjaro.nic.cz/stable/$repo/$arch
55: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
56: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
57: https://manjaro.syxpi.fr/manjaro/stable/$repo/$arch
58: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
59: https://manjaro.grena.ge/stable/$repo/$arch
60: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
61: https://mirror.meowsmp.net/manjaro/stable/$repo/$arch
62: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
63: https://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
64: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
65: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
66: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
67: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
68: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
69: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
70: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
71: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
72: https://manjaro.ynh.ovh/stable/$repo/$arch
73: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
74: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
75: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
76: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
77: https://mirror.xeonbd.com/manjaro/stable/$repo/$arch
78: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
79: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
80: https://manjaro.mirror-services.net/pub/stable/$repo/$arch
81: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
82: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
83: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
84: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
85: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
86: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
87: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
88: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
89: https://mirror.koddos.net/manjaro/stable/$repo/$arch
90: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
91: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
92: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
93: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
94: https://mirror.mobinhost.com/manjaro/stable/$repo/$arch
95: https://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
96: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
97: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
98: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
99: https://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
100: https://manjaro.mirror.ac.za/stable/$repo/$arch
101: https://mirror.bakertelekom.fr/manjaro/stable/$repo/$arch
102: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
103: https://mirrors2.manjaro.org/stable/$repo/$arch
104: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
105: https://ftp.yz.yamagata-u.ac.jp/pub/linux/manjaro/stable/$repo/$arch
106: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
107: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
108: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
109: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
110: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
111: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
112: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
113: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
114: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
115: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
116: https://linorg.usp.br/manjaro/stable/$repo/$arch
117: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
118: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
119: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
120: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
121: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
122: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
123: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
124: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
125: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 409
1: cpu: 12.1% command: gnome-shell pid: 2572 mem: 430.4 MiB (1.3%)
2: cpu: 3.8% command: kgx pid: 8846 mem: 115.2 MiB (0.3%)
3: cpu: 2.1% command: nautilus pid: 7735 mem: 162.7 MiB (0.5%)
4: cpu: 0.9% command: zsh pid: 8926 mem: 12.7 MiB (0.0%)
5: cpu: 0.7% command: init pid: 1 mem: 14.5 MiB (0.0%)
Memory top: 5 of 409
1: mem: 430.4 MiB (1.3%) command: gnome-shell pid: 2572 cpu: 12.1%
2: mem: 162.7 MiB (0.5%) command: nautilus pid: 7735 cpu: 2.1%
3: mem: 115.2 MiB (0.3%) command: kgx pid: 8846 cpu: 3.8%
4: mem: 75.2 MiB (0.2%) command: mutter-x11-frames pid: 3470 cpu: 0.1%
5: mem: 71.9 MiB (0.2%) command: gnome-calendar pid: 7732 cpu: 0.3%
Processes: 409 Power: uptime: 5m states: freeze,mem,disk suspend: s2idle
image: 12.3 GiB services: gsd-power, power-profiles-daemon, upowerd
Init: systemd v: 259 default: graphical tool: systemctl
Compilers: N/A Shell: Zsh v: 5.9 running-in: kgx inxi: 3.3.40
Note: this is not only from the live ISO. I have already installed Manjaro on the internal SSD, and the internal keyboard and touchpad also do not work in the installed system. I can only use an external USB keyboard and mouse.
Update: with i8042.dumbkbd=1 initcall_blacklist=sysfb_init added to the kernel cmdline, the internal keyboard now works. However, two issues remain:
- The touchpad is still not detected in
/proc/bus/input/devices. - The power button does not respond. It appears as a device (
PNP0C0Cin/proc/bus/input/devicesatevent1), but pressing it generates no events inevtestand no ACPI events in the kernel log.
External USB keyboard and mouse continue to work normally.
Compatibility of these devices might be the first thing to consider; the Linux Hardware Database might be helpful; as I type, the site seems to be undergoing some difficulty, but do try later:
After i deactivated my VPN the website loads.
I’m guessing temporary DNS issues were the culprit when I tried, myself.
hello, any updates on the touchpad?
Do you see any mentioned?
no updates
Hardware input issues can be pretty alarming when both the keyboard and touchpad stop working at the same time, so it’s great to see a confirmed fix. Hopefully this helps others get back up and running much faster.
Any chance you have set this up with dual boot with Windows? You could get the hardware identifier from windows device manager so we know exactly what hardware you’re dealing with. But I suspect there probably isn’t any kernel support for it at all.
Also this post may be relevant: Honor MagicBook Pro 16 (Chinese version) – Touchpad not detected (I2C/ACPI issue)
The touchpad is a HID-compliant touch pad in windows device manager.
more information:
Device HID\TOPS010&Col03\5&8aeb8b7&0&0002 was configured.
Driver Name: input.inf
Driver Package ID: input.inf_amd64_5c2a9423ac7f6e1b
Class GUID: {745a17a0-74d3-11d0-b6fe-00a0c90f57da}
Driver Date: 06/21/2006
Driver Version: 10.0.26100.7920
Driver Provider: Microsoft
Driver Section: HID_Raw_Inst.NT
Driver Rank: 0xFF1003
Matching Device ID: HID_DEVICE_UP:000D_U:0005
Outranked Drivers: input.inf:HID_DEVICE:00FF1004
Device Updated: false
Parent Device: ACPI\TOPS010\4&1d7c2499&0
This is concerning - as it indicates a proprietary component that often requires proprietary drivers to work even in Windows.
Also the following suggests a virtual device. Was Windows booted natively when you obtained this information or was it run in a virtual machine?
Something else you could try which may have quicker results, is trying the new linux 7.1 kernel which may include drivers for this hardware. You can install it within Manjaro from the Manjaro Settings Manager/Kernel options. Once installed, power off the system completely, then power on and it should boot the new kernel. If it fails and doesn’t work, reboot again and hold shift at boot time to display the grub menu and you can then select the option to use the kernel you currently have installed.
If you successfully boot with the new kernel, run inxi -zv8 again and see if it has detected the touchpad.
Yes, for such uncommon and new hardware newer kernels often have better drivers…
New Kernel/s can be installed from manjaro settings manager, please avoid kernels that are tagged experimental.
But I still don’t have much hope for “Honor” laptop, don’t seem like a company that’d pay attention to open source drivers.
OP’s details suggest it’s a 2026 model, I wonder what made them choose honor hardware, if they are on linux.
Hello! Thanks to the user phreer, a solution to the issue has finally been found (I’m only seeing it about a month later, but still lol). This should do the work: GitHub - phreer/xwc-p-touchpad-ssdt-fix: ACPI workaround for touchpad on Honor Magicbook Pro 16 2026 (xwc-p) · GitHub
Thank you all so much for the help!!
In that case, it’s appropriate that this Topic be closed. ![]()
You could of course edit your post to elaborate a bit on the actual solution which worked for you, and maybe mark that post a the Solution. (If you wish to but are unable to do the edit, let us know).
