- Laptop: Honor MagicBook Pro 16 (Chinese version)
- OS: Manjaro Linux
- Kernel: 6.18
- Desktop: XFCE
Problem:
The touchpad is not detected at all in the system. Everything else works normally (keyboard, USB mouse, hotkeys, etc.).
The touchpad works in BIOS/UEFI, so it is not a hardware issue.
What I checked:
“/proc/bus/input/devices” shows no touchpad device at all (only keyboard, mouse, and other inputs).
Relevant output:
(no touchpad listed)
Kernel / dmesg errors:
I am seeing ACPI-related errors that may be related to the issue:
ACPI Error: AE_AML_INTERNAL, (SSDT:I2C_DEVT) while loading table
Also earlier during ACPI table disassembly:
AE_ALREADY_EXISTS
Analysis:
From what I understand:
- The touchpad is likely an I2C HID device
- It may be defined in the “I2C_DEVT” ACPI table
- That table appears to fail during loading
- Because of that, the device is never exposed to the kernel
So this looks like a firmware/ACPI issue rather than a libinput or userspace problem.
What I tried:
- Installed and checked libinput (no devices found)
- Verified input devices via “/proc/bus/input/devices”
- Loaded modules manually:
- “i2c_hid”
- “i2c_hid_acpi”
- “hid_multitouch”
- Tested with kernel 6.18
- Confirmed touchpad works in BIOS
None of these made the touchpad appear.
Question:
- Is this a known issue with newer Honor/MagicBook devices?
- Are there any kernel quirks, patches, or workarounds available?
- Would testing a newer (mainline) kernel be useful in this case?
Additional info:
If needed, I can provide:
- Full “dmesg”
- ACPI dump (DSDT/SSDT)
- “libinput list-devices” output
Thanks in advance for any help.
I’m not using Manjaro on a laptop, so I don’t have a touch pad, but I do however have a touch pad on a Tuxedo laptop running Ubuntu. This touch pad has a setting to make it inactivated. For me, that’s the top left corner one has to hit twice to inactivate it or activate it.
Could this be something to look for in settings? Perhaps there is a setting to have it turned off at start-up? Or perhaps there is a settings file one has to set values correctly to make it work?
Just a few ideas.
Hello! I checked and the touchpad does not appear in libinput or xinput, so it seems it’s not being detected at all rather than being disabled, as though it works perfectly in BIOS.
@shozkpov
Please provide more useful information that might be useful to others wishing to help; see below.
inxi -zv8 |
(short-form) |
inxi --filter --verbosity=8 |
(long-form) |
Command output should be presented as pre-formatted text in accordance with forum guidelines.
- Add
--color=0 to the long-form command, or…
- Change the short-form command to
inxi -zv8c0
Your privacy is respected
Note: Grave accent (or, backtick) characters are used.
- please follow this simple example:
code here.
- place text beween two rows of three (```) backtick characters to form a scrollable text box, or …
- use the </> button in the Compose window to achieve the same result.
What is a Quark?
I’ll send the xinput-list followed by inxi so my specs can be throughly checked.
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ SIGMACHIP Usb Mouse id=6 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Video Bus id=7 [slave keyboard (3)]
↳ Power Button id=8 [slave keyboard (3)]
↳ Huawei WMI hotkeys id=9 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=10 [slave keyboard (3)]
As seen, no touchpad shows up, as if the system won’t even recognize it.
Here’s the inxi in long form:
Kernel: 7.0.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-7.0-x86_64
root=UUID=78513c3b-6b8a-46a6-92c8-56131636aa0e rw rootflags=subvol=@
i8042.dumbkbd=1 quiet splash apparmor=1 security=apparmor
udev.log_priority=3 i8042.dumbkbd=1 initcall_blacklist=sysfb_init
Desktop: Xfce v: 4.20.2 tk: Gtk v: 3.24.52 wm: xfwm4 v: 4.20.0
with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: HONOR product: XWC-P v: M1110
serial: <superuser required>
Mobo: HONOR model: XWC-P-PCB v: M1110 serial: <superuser required>
part-nu: C233 uuid: <superuser required> Firmware: UEFI vendor: HONOR
v: 1.07 date: 02/26/2026
ID-1: BAT0 charge: 37.4 Wh (40.7%) condition: 92/92 Wh (100%) volts: 15.27
min: 15.64 model: NVT HB7075R5EHW-41T1 type: Li-ion serial: <filter>
charging: status: discharging control: start: 0% end: 0% cycles: 1
System RAM: total: 32 GiB available: 30.89 GiB used: 4.92 GiB (15.9%)
Array-1: capacity: 32 GiB slots: 8 modules: 8 EC: None
max-module-size: 4 GiB note: est.
Device-1: Controller0-ChannelA type: LPDDR5 detail: synchronous
size: 4 GiB speed: spec: 9600 MT/s actual: 8533 MT/s volts: curr: 0.5
width (bits): data: 16 total: 16 manufacturer: Micron Technology
part-no: MT62F2G64D8ZA-020 WT serial: N/A
Device-2: Controller0-ChannelB type: LPDDR5 detail: synchronous
Device-3: Controller0-ChannelC type: LPDDR5 detail: synchronous
Device-4: Controller0-ChannelD type: LPDDR5 detail: synchronous
Device-5: Controller1-ChannelA type: LPDDR5 detail: synchronous
Device-6: Controller1-ChannelB type: LPDDR5 detail: synchronous
Device-7: Controller1-ChannelC type: LPDDR5 detail: synchronous
Device-8: Controller1-ChannelD type: LPDDR5 detail: synchronous
Info: model: Intel Core Ultra 5 338H bits: 64 type: MCP arch: Panther Lake
level: v3 note: check built: 2025+ process: Intel 18a (1.8nm) family: 6
model-id: 0xCC (204) stepping: 2 microcode: 0x114
Topology: cpus: 1x dies: 1 clusters: 6 cores: 12 smt: <unsupported> cache:
L1: 1.2 MiB desc: d-8x32 KiB, 4x48 KiB; i-12x64 KiB L2: 20 MiB
desc: 4x3 MiB, 2x4 MiB L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 400 min/max: 400/4700:3600:3300 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 bogomips: 88473
bts bus_lock_detect clflush clflushopt clwb cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
ida intel_pt invpcid lahf_lm lam lm mca mce md_clear mmx monitor movbe
movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pge pku pln pni popcnt pse pse36 pts rdpid rdrand
rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni smap smep smx
split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg wbnoinvd x2apic
conditional; PBRSB-eIBRS: Not affected; BHI: BHI_DIS_S
Type: vmscape status: Not affected
Device-1: Intel Panther Lake [Arc B370] driver: xe v: kernel arch: Xe3
process: TSMC 18A built: 2025+ ports: active: eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:b081
class-ID: 0300
Device-2: Shinetech FHD Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:2 chip-ID: 3277:00de
Display: x11 server: X.org v: 1.21.1.22 compositor: xfwm4 v: 4.20.0
driver: X: loaded: modesetting alternate: fbdev,vesa dri: iris gpu: xe
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3072x1920 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 model: TL160MDMP01 built: 2023 res: mode: 3072x1920
hz: 165 scale: 100% (1) dpi: 226 gamma: 1.2 chroma: red: x: 0.678 y: 0.322
green: x: 0.267 y: 0.690 blue: x: 0.145 y: 0.047 white: x: 0.306 y: 0.322
size: 345x215mm (13.58x8.46") diag: 407mm (16") ratio: 16:10
modes: 3072x1920
EDID-Warnings: 1: parse_edid: unknown tag 112
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 26.0.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (PTL)
device-ID: 8086:b081 memory: 30.16 GiB unified: yes
x11: xprop,xrandr
Device-1: Intel driver: sof-audio-pci-intel-ptl
alternate: snd_sof_pci_intel_ptl,snd_hda_intel bus-ID: 00:1f.3
chip-ID: 8086:e428 class-ID: 0401
API: ALSA v: k7.0.3-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.6.4 status: active with: 1: pipewire-pulse
Device-1: Intel Panther Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:e440 class-ID: 0280
Device-1: Intel Panther Lake Bluetooth PCI Enumerator driver: btintel_pcie
v: 0.1 bus-ID: 00:14.7 chip-ID: 8086:e476 class-ID: 0d11
Local Storage: total: 953.87 GiB used: 16.03 GiB (1.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Hynix model: YMTC PC411-1TB-B
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: YM3603E3 temp: 30.9 C
scheme: GPT
ID-1: / raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
used: 16.02 GiB (1.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 78513c3b-6b8a-46a6-92c8-56131636aa0e
used: 8.6 MiB (2.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 1121-B9FB
ID-3: /home raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
ID-4: /var/cache raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
ID-5: /var/log raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 3 rev: 3.1
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 3-4:2 info: Shinetech FHD Camera type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 3277:00de class-ID: 0e02 serial: <filter>
Device-2: 3-5:5 info: SiGma Micro Usb Mouse type: mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
chip-ID: 1c4f:0048 class-ID: 0301
Device-3: 3-7:4 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 27c6:6f94 class-ID: ef00 serial: <filter>
System Temperatures: cpu: 38.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1132 libs: 366 tools: pamac pm: flatpak pkgs: 0
1: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
2: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
4: https://mirror.dimensiondata.com/mirrors/manjaro.org/stable/$repo/$arch
5: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
6: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
7: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
8: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
9: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
10: https://ftp.yz.yamagata-u.ac.jp/pub/linux/manjaro/stable/$repo/$arch
11: https://mirrors2.manjaro.org/stable/$repo/$arch
12: https://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
13: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
14: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
15: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
16: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
17: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
18: https://mirror.xeonbd.com/manjaro/stable/$repo/$arch
19: https://manjaro.grena.ge/stable/$repo/$arch
20: https://manjaro.syxpi.fr/manjaro/stable/$repo/$arch
21: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
22: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
23: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
24: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
25: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
26: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
27: https://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
28: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
29: https://manjaro.mirror-services.net/pub/stable/$repo/$arch
30: https://mirror.koddos.net/manjaro/stable/$repo/$arch
31: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
32: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
33: https://mirror.bakertelekom.fr/manjaro/stable/$repo/$arch
34: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
35: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
36: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
37: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
38: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
39: https://linorg.usp.br/manjaro/stable/$repo/$arch
40: https://mirror.init7.net/manjaro/stable/$repo/$arch
41: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
42: https://mirror.meowsmp.net/manjaro/stable/$repo/$arch
43: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
44: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
45: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
46: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
47: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
48: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
49: https://mirror.dc.uz/manjaro/stable/$repo/$arch
50: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
51: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
52: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
53: https://mirror.easyname.at/manjaro/stable/$repo/$arch
54: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
55: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
56: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
57: https://manjaro.ynh.ovh/stable/$repo/$arch
58: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
59: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
60: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
61: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
62: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
63: https://mirror.fcix.net/manjaro/stable/$repo/$arch
64: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
65: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
66: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
67: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
68: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
69: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
70: https://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
71: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
72: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
73: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
74: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
75: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
76: https://mirror.komelt.dev/manjaro/stable/$repo/$arch
77: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
78: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
79: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
80: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
81: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
82: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
83: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
84: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
85: https://muug.ca/mirror/manjaro/stable/$repo/$arch
86: https://manjaro.mirror.ac.za/stable/$repo/$arch
87: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
88: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
89: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
90: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
91: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
92: https://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
93: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
94: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
95: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
96: https://mirror.23m.com/manjaro/stable/$repo/$arch
97: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
98: https://mirror.mobinhost.com/manjaro/stable/$repo/$arch
99: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
100: https://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
101: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
102: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
103: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
104: https://manjaro.kurdy.org/stable/$repo/$arch
105: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
106: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
107: https://mirrors.manjaro.org/repo/stable/$repo/$arch
108: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
109: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
110: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
111: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
112: https://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
113: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
114: https://mirror.zetup.net/manjaro/stable/$repo/$arch
115: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
116: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
117: https://manjaro.nic.cz/stable/$repo/$arch
118: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
119: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
120: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
121: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
122: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
123: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
124: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
125: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 420
1: cpu: 33.6% command: firefox pid: 2492 mem: 739.7 MiB (2.3%)
2: cpu: 22.4% command: Xorg pid: 956 mem: 115.4 MiB (0.3%)
3: cpu: 13.8% command: firefox pid: 3079 mem: 462.0 MiB (1.4%)
4: cpu: 4.7% command: firefox pid: 8848 mem: 411.9 MiB (1.3%)
5: cpu: 3.6% command: firefox pid: 6293 mem: 359.4 MiB (1.1%)
Memory top: 5 of 420
1: mem: 739.7 MiB (2.3%) command: firefox pid: 2492 cpu: 33.6%
2: mem: 462.0 MiB (1.4%) command: firefox pid: 3079 cpu: 13.8%
3: mem: 411.9 MiB (1.3%) command: firefox pid: 8848 cpu: 4.7%
4: mem: 404.1 MiB (1.2%) command: firefox pid: 5443 cpu: 0.5%
5: mem: 359.4 MiB (1.1%) command: firefox pid: 6293 cpu: 3.6%
Processes: 420 Power: uptime: 21m states: freeze,mem,disk suspend: s2idle
image: 12.29 GiB services: upowerd,xfce4-power-manager Init: systemd
v: 260 default: graphical tool: systemctl
Compilers: N/A Shell: Zsh v: 5.9 running-in: xfce4-terminal inxi: 3.3.40
