Kernel5.14 rc6 - ath11k on QCA6390 regression - mhi probe failure
Hi all,
On using the 5.14 RC6 kernel there seems to have been a regression that prevents the wifi from working on boot. It works on 5.13.x [mostly] fine.
I believe this probably needs to be reported upstream but I’m not running an upstream kernel.
The failure message is:
Aug 22 14:03:40 chuchel kernel: qcom_mhi_qrtr: probe of mhi0_IPCR failed with error -22
System:    Kernel: 5.13.11-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.13-x86_64 root=UUID=0968f16f-24ed-4711-98b1-f7e16423f32d rw apparmor=1
           security=apparmor udev.log_priority=3 memmap=12M$20M bootsplash.bootfile=/bootsplash-themes/manjaro/bootsplash
           Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Machine:   Type: Laptop System: Dell product: XPS 13 9310 v: N/A serial: <filter> Chassis: type: 10 serial: <filter>
           Mobo: Dell model: 0DMPXV v: A00 serial: <filter> UEFI: Dell v: 3.0.3 date: 06/19/2021
Battery:   ID-1: BAT0 charge: 51.0 Wh (100.0%) condition: 51.0/51.0 Wh (100.0%) volts: 8.7 min: 7.6
           model: LGC-LGC6.5 DELL 2XXFW11 type: Li-poly serial: <filter> status: Full
Memory:    RAM: total: 31.06 GiB used: 2.9 GiB (9.3%)
CPU:       Info: Quad Core model: 11th Gen Intel Core i7-1185G7 bits: 64 type: MT MCP arch: Tiger Lake family: 6
           model-id: 8C (140) stepping: 1 microcode: 88 cache: L2: 12 MiB bogomips: 47936
           Speed: 1023 MHz min/max: 400/4800 MHz Core speeds (MHz): 1: 1023 2: 1021 3: 959 4: 517 5: 787 6: 1056 7: 804 8: 806
           Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities arch_perfmon art avx avx2
           avx512_bitalg avx512_vbmi2 avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
           avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2 cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid
           cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
           fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt
           invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr nonstop_tsc nopl nx
           ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a
           rdtscp rep_good sdbg sep sha_ni smap smep smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
           tm tm2 tme tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid
           x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Graphics:  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell driver: i915 v: kernel bus-ID: 0000:00:02.0
           chip-ID: 8086:9a49 class-ID: 0300
           Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo bus-ID: 3-6:3 chip-ID: 0c45:672a class-ID: 0e02
           Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: modesetting alternate: fbdev,intel,vesa
           display-ID: :0 screens: 1
           Screen-1: 0 s-res: 3456x2160 s-dpi: 96 s-size: 914x571mm (36.0x22.5") s-diag: 1078mm (42.4")
           Monitor-1: eDP-1 res: 3456x2160 hz: 60 dpi: 305 size: 288x180mm (11.3x7.1") diag: 340mm (13.4")
           OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 21.1.6 direct render: Yes
Audio:     Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell driver: sof-audio-pci-intel-tgl
           alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8 class-ID: 0401
           Sound Server-1: ALSA v: k5.13.11-1-MANJARO running: yes
           Sound Server-4: PipeWire v: 0.3.33 running: no
Network:   Device-1: Qualcomm QCA6390 Wireless Network Adapter [AX500-DBS ] vendor: Rivet Networks driver: ath11k_pci
           v: kernel port: efa0 bus-ID: 0000:71:00.0 chip-ID: 17cb:1101 class-ID: 0280
           IF: wlp113s0 state: up mac: <filter>
           IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
           IF-ID-1: docker0 state: down mac: <filter>
Bluetooth: Message: No bluetooth data found.
Logical:   Message: No logical block device data found.
RAID:      Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd v: 0.6 port: 3000 bus-ID: 0000:00:0e.0
           chip-ID: 8086.9a0b rev: class-ID: 0104
Drives:    Local Storage: total: 953.87 GiB used: 63.95 GiB (6.7%)
           ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: KXG60ZNV1T02 NVMe 1024GB size: 953.87 GiB block-size:
           physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 10604107 temp: 42.9 C
           scheme: GPT
Partition: ID-1: / raw-size: 439.45 GiB size: 431.48 GiB (98.19%) used: 63.84 GiB (14.8%) fs: ext4 dev: /dev/nvme0n1p7
           maj-min: 259:7 label: N/A uuid: 0968f16f-24ed-4711-98b1-f7e16423f32d
           ID-2: /boot/efi raw-size: 190 MiB size: 186 MiB (97.89%) used: 103.8 MiB (55.8%) fs: vfat dev: /dev/nvme0n1p1
           maj-min: 259:1 label: ESP uuid: FCD8-9EE8
Swap:      Alert: No swap data was found.
Unmounted: ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: <superuser required> label: N/A uuid: N/A
           ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 496.45 GiB fs: bitlocker label: N/A uuid: N/A
           ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 990 MiB fs: ntfs label: WINRETOOLS uuid: 7A807A398079FBC7
           ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 15.32 GiB fs: ntfs label: Image uuid: C8387A43387A3094
           ID-5: /dev/nvme0n1p6 maj-min: 259:6 size: 1.37 GiB fs: ntfs label: DELLSUPPORT uuid: A804E6B804E68920
USB:       Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
           Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
           Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
           Device-1: 3-3:2 info: Shenzhen Goodix FingerPrint type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
           speed: 12 Mb/s power: 100mA chip-ID: 27c6:533c class-ID: ff00
           Device-2: 3-6:3 info: Microdia Integrated_Webcam_HD type: Video driver: uvcvideo interfaces: 4 rev: 2.0
           speed: 480 Mb/s power: 500mA chip-ID: 0c45:672a class-ID: 0e02
           Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Sensors:   System Temperatures: cpu: N/A mobo: N/A
           Fan Speeds (RPM): cpu: 0 fan-2: 0
Info:      Processes: 216 Uptime: 55m wakeups: 564 Init: systemd v: 248 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1
           Packages: pacman: 1492 lib: 401 flatpak: 0 Shell: Zsh v: 5.8 running-in: kitty inxi: 3.3.06
Full kernel log:
-- Journal begins at Sat 2021-06-12 02:03:11 AEST, ends at Sun 2021-08-22 14:49:12 AEST. --
Aug 22 14:03:39 chuchel kernel: microcode: microcode updated early to revision 0x88, date = 2021-03-31
Aug 22 14:03:39 chuchel kernel: Linux version 5.14.0-1-MANJARO (builduser@fv-az83-229) (gcc (GCC) 11.1.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT Mon Aug 16 11:10:19 UTC 2021
Aug 22 14:03:39 chuchel kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64 root=UUID=0968f16f-24ed-4711-98b1-f7e16423f32d rw apparmor=1 security=apparmor udev.log_priority=3 memmap=12M$20M bootsplash.bootfile=/bootsplash-themes/manjaro/bootsplash
Aug 22 14:03:39 chuchel kernel: x86/split lock detection: #AC: crashing the kernel on kernel split_locks and warning on user-space split_locks
Aug 22 14:03:39 chuchel kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Aug 22 14:03:39 chuchel kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Aug 22 14:03:39 chuchel kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Aug 22 14:03:39 chuchel kernel: x86/fpu: Supporting XSAVE feature 0x020: 'AVX-512 opmask'
Aug 22 14:03:39 chuchel kernel: x86/fpu: Supporting XSAVE feature 0x040: 'AVX-512 Hi256'
Aug 22 14:03:39 chuchel kernel: x86/fpu: Supporting XSAVE feature 0x080: 'AVX-512 ZMM_Hi256'
Aug 22 14:03:39 chuchel kernel: x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
Aug 22 14:03:39 chuchel kernel: x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
Aug 22 14:03:39 chuchel kernel: x86/fpu: xstate_offset[5]:  832, xstate_sizes[5]:   64
Aug 22 14:03:39 chuchel kernel: x86/fpu: xstate_offset[6]:  896, xstate_sizes[6]:  512
Aug 22 14:03:39 chuchel kernel: x86/fpu: xstate_offset[7]: 1408, xstate_sizes[7]: 1024
Aug 22 14:03:39 chuchel kernel: x86/fpu: xstate_offset[9]: 2432, xstate_sizes[9]:    8
Aug 22 14:03:39 chuchel kernel: x86/fpu: Enabled xstate features 0x2e7, context size is 2440 bytes, using 'compacted' format.
Aug 22 14:03:39 chuchel kernel: signal: max sigframe size: 3632
Aug 22 14:03:39 chuchel kernel: BIOS-provided physical RAM map:
Aug 22 14:03:39 chuchel kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
Aug 22 14:03:39 chuchel kernel: BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
Aug 22 14:03:39 chuchel kernel: BIOS-e820: [mem 0x0000000000100000-0x000000005e72afff] usable
Aug 22 14:03:39 chuchel kernel: BIOS-e820: [mem 0x000000005e72b000-0x000000005e84dfff] type 20
Aug 22 14:03:39 chuchel kernel: BIOS-e820: [mem 0x000000005e84e000-0x0000000062510fff] reserved
Aug 22 14:03:39 chuchel kernel: BIOS-e820: [mem 0x0000000062511000-0x0000000062d71fff] ACPI NVS
Aug 22 14:03:39 chuchel kernel: BIOS-e820: [mem 0x0000000062d72000-0x0000000062ffefff] ACPI data
Aug 22 14:03:39 chuchel kernel: BIOS-e820: [mem 0x0000000062fff000-0x0000000062ffffff] usable
Aug 22 14:03:39 chuchel kernel: BIOS-e820: [mem 0x0000000063000000-0x0000000066ffffff] reserved
Aug 22 14:03:39 chuchel kernel: BIOS-e820: [mem 0x0000000067600000-0x00000000677fffff] reserved
Aug 22 14:03:39 chuchel kernel: BIOS-e820: [mem 0x0000000068000000-0x00000000707fffff] reserved
Aug 22 14:03:39 chuchel kernel: BIOS-e820: [mem 0x00000000c0000000-0x00000000cfffffff] reserved
Aug 22 14:03:39 chuchel kernel: BIOS-e820: [mem 0x00000000fed20000-0x00000000fed7ffff] reserved
Aug 22 14:03:39 chuchel kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
Aug 22 14:03:39 chuchel kernel: BIOS-e820: [mem 0x0000000100000000-0x000000088f7fffff] usable
Aug 22 14:03:39 chuchel kernel: NX (Execute Disable) protection: active
Aug 22 14:03:39 chuchel kernel: user-defined physical RAM map:
Aug 22 14:03:39 chuchel kernel: user: [mem 0x0000000000000000-0x000000000009efff] usable
Aug 22 14:03:39 chuchel kernel: user: [mem 0x000000000009f000-0x00000000000fffff] reserved
Aug 22 14:03:39 chuchel kernel: user: [mem 0x0000000000100000-0x00000000013fffff] usable
Aug 22 14:03:39 chuchel kernel: user: [mem 0x0000000001400000-0x0000000001ffffff] reserved
Aug 22 14:03:39 chuchel kernel: user: [mem 0x0000000002000000-0x000000005e72afff] usable
Aug 22 14:03:39 chuchel kernel: user: [mem 0x000000005e72b000-0x000000005e84dfff] type 20
Aug 22 14:03:39 chuchel kernel: user: [mem 0x000000005e84e000-0x0000000062510fff] reserved
Aug 22 14:03:39 chuchel kernel: user: [mem 0x0000000062511000-0x0000000062d71fff] ACPI NVS
Aug 22 14:03:39 chuchel kernel: user: [mem 0x0000000062d72000-0x0000000062ffefff] ACPI data
Aug 22 14:03:39 chuchel kernel: user: [mem 0x0000000062fff000-0x0000000062ffffff] usable
Aug 22 14:03:39 chuchel kernel: user: [mem 0x0000000063000000-0x0000000066ffffff] reserved
Aug 22 14:03:39 chuchel kernel: user: [mem 0x0000000067600000-0x00000000677fffff] reserved
Aug 22 14:03:39 chuchel kernel: user: [mem 0x0000000068000000-0x00000000707fffff] reserved
Aug 22 14:03:39 chuchel kernel: user: [mem 0x00000000c0000000-0x00000000cfffffff] reserved
Aug 22 14:03:39 chuchel kernel: user: [mem 0x00000000fed20000-0x00000000fed7ffff] reserved
Aug 22 14:03:39 chuchel kernel: user: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
Aug 22 14:03:39 chuchel kernel: user: [mem 0x0000000100000000-0x000000088f7fffff] usable
Aug 22 14:03:39 chuchel kernel: efi: EFI v2.70 by Dell
Aug 22 14:03:39 chuchel kernel: efi: ACPI=0x62ffe000 ACPI 2.0=0x62ffe014 SMBIOS=0x5edd7000 TPMFinalLog=0x62cd8000 ESRT=0x5ecceb98 MEMATTR=0x59e95298
Aug 22 14:03:39 chuchel kernel: SMBIOS 3.2 present.
Aug 22 14:03:39 chuchel kernel: DMI: Dell Inc. XPS 13 9310/0DMPXV, BIOS 3.0.3 06/19/2021
Aug 22 14:03:39 chuchel kernel: tsc: Detected 3000.000 MHz processor
Aug 22 14:03:39 chuchel kernel: tsc: Detected 2995.200 MHz TSC
Aug 22 14:03:39 chuchel kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Aug 22 14:03:39 chuchel kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
Aug 22 14:03:39 chuchel kernel: last_pfn = 0x88f800 max_arch_pfn = 0x400000000
Aug 22 14:03:39 chuchel kernel: x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
Aug 22 14:03:39 chuchel kernel: last_pfn = 0x63000 max_arch_pfn = 0x400000000
Aug 22 14:03:39 chuchel kernel: esrt: Reserving ESRT space from 0x000000005ecceb98 to 0x000000005eccec20.
Aug 22 14:03:39 chuchel kernel: Using GB pages for direct mapping
Aug 22 14:03:39 chuchel kernel: Secure boot disabled
Aug 22 14:03:39 chuchel kernel: RAMDISK: [mem 0x366d3000-0x37360fff]
Aug 22 14:03:39 chuchel kernel: ACPI: Early table checksum verification disabled
Aug 22 14:03:39 chuchel kernel: ACPI: RSDP 0x0000000062FFE014 000024 (v02 DELL  )
Aug 22 14:03:39 chuchel kernel: ACPI: XSDT 0x0000000062F76188 00011C (v01 DELL   Dell Inc 00000002      01000013)
Aug 22 14:03:39 chuchel kernel: ACPI: FACP 0x0000000062FF5000 000114 (v06 DELL   Dell Inc 00000002      01000013)
Aug 22 14:03:39 chuchel kernel: ACPI: DSDT 0x0000000062F95000 05C466 (v02 DELL   Dell Inc 00000002      01000013)
Aug 22 14:03:39 chuchel kernel: ACPI: FACS 0x0000000062D1B000 000040
Aug 22 14:03:39 chuchel kernel: ACPI: SSDT 0x0000000062FFA000 0024D0 (v02 CpuRef CpuSsdt  00003000 INTL 20191018)
Aug 22 14:03:39 chuchel kernel: ACPI: SSDT 0x0000000062FF6000 0038FA (v02 DptfTb DptfTabl 00001000 INTL 20191018)
Aug 22 14:03:39 chuchel kernel: ACPI: HPET 0x0000000062FF4000 000038 (v01 DELL   Dell Inc 00000002      01000013)
Aug 22 14:03:39 chuchel kernel: ACPI: APIC 0x0000000062FF3000 00012C (v04 DELL   Dell Inc 00000002      01000013)
Aug 22 14:03:39 chuchel kernel: ACPI: MCFG 0x0000000062FF2000 00003C (v01 DELL   Dell Inc 00000002      01000013)
Aug 22 14:03:39 chuchel kernel: ACPI: SSDT 0x0000000062F94000 000CF9 (v02 DELL   DellRtd3 00001000 INTL 20191018)
Aug 22 14:03:39 chuchel kernel: ACPI: NHLT 0x0000000062F92000 001B54 (v00 DELL   Dell Inc 00000002      01000013)
Aug 22 14:03:39 chuchel kernel: ACPI: SSDT 0x0000000062F8F000 002CD7 (v02 SaSsdt SaSsdt   00003000 INTL 20191018)
Aug 22 14:03:39 chuchel kernel: ACPI: SSDT 0x0000000062F8D000 0012D2 (v02 INTEL  IgfxSsdt 00003000 INTL 20191018)
Aug 22 14:03:39 chuchel kernel: ACPI: SSDT 0x0000000062F81000 00B27A (v02 INTEL  TcssSsdt 00001000 INTL 20191018)
Aug 22 14:03:39 chuchel kernel: ACPI: SSDT 0x0000000062F80000 000CD2 (v02 DELL   UsbCTabl 00001000 INTL 20191018)
Aug 22 14:03:39 chuchel kernel: ACPI: LPIT 0x0000000062F7F000 0000CC (v01 DELL   Dell Inc 00000002      01000013)
Aug 22 14:03:39 chuchel kernel: ACPI: WSMT 0x0000000062F7E000 000028 (v01 DELL   Dell Inc 00000002      01000013)
Aug 22 14:03:39 chuchel kernel: ACPI: SSDT 0x0000000062F7D000 000B75 (v02 DELL   PtidDevc 00001000 INTL 20191018)
Aug 22 14:03:39 chuchel kernel: ACPI: SSDT 0x0000000062F7C000 00012A (v02 DELL   TbtTypeC 00000000 INTL 20191018)
Aug 22 14:03:39 chuchel kernel: ACPI: DBGP 0x0000000062F7B000 000034 (v01 DELL   Dell Inc 00000002      01000013)
Aug 22 14:03:39 chuchel kernel: ACPI: DBG2 0x0000000062F7A000 000054 (v00 DELL   Dell Inc 00000002      01000013)
Aug 22 14:03:39 chuchel kernel: ACPI: SLIC 0x0000000062F79000 000176 (v03 DELL   CBX3     06222004 MSFT 00010013)
Aug 22 14:03:39 chuchel kernel: ACPI: BOOT 0x0000000062F78000 000028 (v01 DELL   CBX3     00000002      01000013)
Aug 22 14:03:39 chuchel kernel: ACPI: SSDT 0x0000000062F77000 00060E (v02 DELL   Tpm2Tabl 00001000 INTL 20191018)
Aug 22 14:03:39 chuchel kernel: ACPI: TPM2 0x0000000062FFD000 00004C (v04 DELL   Dell Inc 00000002      01000013)
Aug 22 14:03:39 chuchel kernel: ACPI: MSDM 0x0000000062F75000 000055 (v03 DELL   CBX3     06222004 AMI  00010013)
Aug 22 14:03:39 chuchel kernel: ACPI: DMAR 0x0000000062F74000 0000B8 (v02 INTEL  Dell Inc 00000002      01000013)
Aug 22 14:03:39 chuchel kernel: ACPI: SSDT 0x0000000062F73000 000841 (v02 DELL   xh_Dell_ 00000000 INTL 20191018)
Aug 22 14:03:39 chuchel kernel: ACPI: SSDT 0x0000000062F72000 000144 (v02 Intel  ADebTabl 00001000 INTL 20191018)
Aug 22 14:03:39 chuchel kernel: ACPI: UEFI 0x0000000062CD3000 00063A (v01 INTEL  RstVmdE  00000000 ??   00000000)
Aug 22 14:03:39 chuchel kernel: ACPI: UEFI 0x0000000062CD2000 00005C (v01 INTEL  RstVmdV  00000000 ??   00000000)
Aug 22 14:03:39 chuchel kernel: ACPI: PTDT 0x0000000062F71000 000D44 (v00 DELL   Dell Inc 00000005 MSFT 0100000D)
Aug 22 14:03:39 chuchel kernel: ACPI: BGRT 0x0000000062F70000 000038 (v01 DELL   Dell Inc 00000002      01000013)
Aug 22 14:03:39 chuchel kernel: ACPI: FPDT 0x0000000062F6F000 000034 (v01 DELL   Dell Inc 00000002      01000013)
Aug 22 14:03:39 chuchel kernel: ACPI: Reserving FACP table memory at [mem 0x62ff5000-0x62ff5113]
Aug 22 14:03:39 chuchel kernel: ACPI: Reserving DSDT table memory at [mem 0x62f95000-0x62ff1465]
Aug 22 14:03:39 chuchel kernel: ACPI: Reserving FACS table memory at [mem 0x62d1b000-0x62d1b03f]
Aug 22 14:03:39 chuchel kernel: ACPI: Reserving SSDT table memory at [mem 0x62ffa000-0x62ffc4cf]
Aug 22 14:03:39 chuchel kernel: ACPI: Reserving SSDT table memory at [mem 0x62ff6000-0x62ff98f9]
Aug 22 14:03:39 chuchel kernel: ACPI: Reserving HPET table memory at [mem 0x62ff4000-0x62ff4037]
Aug 22 14:03:39 chuchel kernel: ACPI: Reserving APIC table memory at [mem 0x62ff3000-0x62ff312b]
Aug 22 14:03:39 chuchel kernel: ACPI: Reserving MCFG table memory at [mem 0x62ff2000-0x62ff203b]
Aug 22 14:03:39 chuchel kernel: ACPI: Reserving SSDT table memory at [mem 0x62f94000-0x62f94cf8]
Aug 22 14:03:39 chuchel kernel: ACPI: Reserving NHLT table memory at [mem 0x62f92000-0x62f93b53]
Aug 22 14:03:39 chuchel kernel: ACPI: Reserving SSDT table memory at [mem 0x62f8f000-0x62f91cd6]
Aug 22 14:03:39 chuchel kernel: ACPI: Reserving SSDT table memory at [mem 0x62f8d000-0x62f8e2d1]
Aug 22 14:03:39 chuchel kernel: ACPI: Reserving SSDT table memory at [mem 0x62f81000-0x62f8c279]
Aug 22 14:03:39 chuchel kernel: ACPI: Reserving SSDT table memory at [mem 0x62f80000-0x62f80cd1]
Aug 22 14:03:39 chuchel kernel: ACPI: Reserving LPIT table memory at [mem 0x62f7f000-0x62f7f0cb]
Aug 22 14:03:39 chuchel kernel: ACPI: Reserving WSMT table memory at [mem 0x62f7e000-0x62f7e027]
Aug 22 14:03:39 chuchel kernel: ACPI: Reserving SSDT table memory at [mem 0x62f7d000-0x62f7db74]
Aug 22 14:03:39 chuchel kernel: ACPI: Reserving SSDT table memory at [mem 0x62f7c000-0x62f7c129]
Aug 22 14:03:39 chuchel kernel: ACPI: Reserving DBGP table memory at [mem 0x62f7b000-0x62f7b033]
Aug 22 14:03:39 chuchel kernel: ACPI: Reserving DBG2 table memory at [mem 0x62f7a000-0x62f7a053]
Aug 22 14:03:39 chuchel kernel: ACPI: Reserving SLIC table memory at [mem 0x62f79000-0x62f79175]
Aug 22 14:03:39 chuchel kernel: ACPI: Reserving BOOT table memory at [mem 0x62f78000-0x62f78027]
Aug 22 14:03:39 chuchel kernel: ACPI: Reserving SSDT table memory at [mem 0x62f77000-0x62f7760d]
Aug 22 14:03:39 chuchel kernel: ACPI: Reserving TPM2 table memory at [mem 0x62ffd000-0x62ffd04b]
Aug 22 14:03:39 chuchel kernel: ACPI: Reserving MSDM table memory at [mem 0x62f75000-0x62f75054]
Aug 22 14:03:39 chuchel kernel: ACPI: Reserving DMAR table memory at [mem 0x62f74000-0x62f740b7]
Aug 22 14:03:39 chuchel kernel: ACPI: Reserving SSDT table memory at [mem 0x62f73000-0x62f73840]
Aug 22 14:03:39 chuchel kernel: ACPI: Reserving SSDT table memory at [mem 0x62f72000-0x62f72143]
Aug 22 14:03:39 chuchel kernel: ACPI: Reserving UEFI table memory at [mem 0x62cd3000-0x62cd3639]
Aug 22 14:03:39 chuchel kernel: ACPI: Reserving UEFI table memory at [mem 0x62cd2000-0x62cd205b]
Aug 22 14:03:39 chuchel kernel: ACPI: Reserving PTDT table memory at [mem 0x62f71000-0x62f71d43]
Aug 22 14:03:39 chuchel kernel: ACPI: Reserving BGRT table memory at [mem 0x62f70000-0x62f70037]
Aug 22 14:03:39 chuchel kernel: ACPI: Reserving FPDT table memory at [mem 0x62f6f000-0x62f6f033]
Aug 22 14:03:39 chuchel kernel: No NUMA configuration found
Aug 22 14:03:39 chuchel kernel: Faking a node at [mem 0x0000000000000000-0x000000088f7fffff]
Aug 22 14:03:39 chuchel kernel: NODE_DATA(0) allocated [mem 0x88f7fc000-0x88f7fffff]
Aug 22 14:03:39 chuchel kernel: Zone ranges:
Aug 22 14:03:39 chuchel kernel:   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
Aug 22 14:03:39 chuchel kernel:   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
Aug 22 14:03:39 chuchel kernel:   Normal   [mem 0x0000000100000000-0x000000088f7fffff]
Aug 22 14:03:39 chuchel kernel:   Device   empty
Aug 22 14:03:39 chuchel kernel: Movable zone start for each node
Aug 22 14:03:39 chuchel kernel: Early memory node ranges
Aug 22 14:03:39 chuchel kernel:   node   0: [mem 0x0000000000001000-0x000000000009efff]
Aug 22 14:03:39 chuchel kernel:   node   0: [mem 0x0000000000100000-0x00000000013fffff]
Aug 22 14:03:39 chuchel kernel:   node   0: [mem 0x0000000002000000-0x000000005e72afff]
Aug 22 14:03:39 chuchel kernel:   node   0: [mem 0x0000000062fff000-0x0000000062ffffff]
Aug 22 14:03:39 chuchel kernel:   node   0: [mem 0x0000000100000000-0x000000088f7fffff]
Aug 22 14:03:39 chuchel kernel: Initmem setup node 0 [mem 0x0000000000001000-0x000000088f7fffff]
Aug 22 14:03:39 chuchel kernel: On node 0, zone DMA: 1 pages in unavailable ranges
Aug 22 14:03:39 chuchel kernel: On node 0, zone DMA: 97 pages in unavailable ranges
Aug 22 14:03:39 chuchel kernel: On node 0, zone DMA32: 3072 pages in unavailable ranges
Aug 22 14:03:39 chuchel kernel: On node 0, zone DMA32: 18644 pages in unavailable ranges
Aug 22 14:03:39 chuchel kernel: On node 0, zone Normal: 20480 pages in unavailable ranges
Aug 22 14:03:39 chuchel kernel: On node 0, zone Normal: 2048 pages in unavailable ranges
Aug 22 14:03:39 chuchel kernel: Reserving Intel graphics memory at [mem 0x6c800000-0x707fffff]
Aug 22 14:03:39 chuchel kernel: ACPI: PM-Timer IO Port: 0x1808
Aug 22 14:03:39 chuchel kernel: ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
Aug 22 14:03:39 chuchel kernel: ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
Aug 22 14:03:39 chuchel kernel: ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
Aug 22 14:03:39 chuchel kernel: ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
Aug 22 14:03:39 chuchel kernel: ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
Aug 22 14:03:39 chuchel kernel: ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
Aug 22 14:03:39 chuchel kernel: ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
Aug 22 14:03:39 chuchel kernel: ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
Aug 22 14:03:39 chuchel kernel: ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
Aug 22 14:03:39 chuchel kernel: ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
Aug 22 14:03:39 chuchel kernel: ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
Aug 22 14:03:39 chuchel kernel: ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
Aug 22 14:03:39 chuchel kernel: ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
Aug 22 14:03:39 chuchel kernel: ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
Aug 22 14:03:39 chuchel kernel: ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
Aug 22 14:03:39 chuchel kernel: ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
Aug 22 14:03:39 chuchel kernel: IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
Aug 22 14:03:39 chuchel kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Aug 22 14:03:39 chuchel kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Aug 22 14:03:39 chuchel kernel: ACPI: Using ACPI (MADT) for SMP configuration information
Aug 22 14:03:39 chuchel kernel: ACPI: HPET id: 0x8086a201 base: 0xfed00000
Aug 22 14:03:39 chuchel kernel: e820: update [mem 0x59bf5000-0x59c54fff] usable ==> reserved
Aug 22 14:03:39 chuchel kernel: TSC deadline timer available
Aug 22 14:03:39 chuchel kernel: smpboot: Allowing 8 CPUs, 0 hotplug CPUs
Aug 22 14:03:39 chuchel kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
Aug 22 14:03:39 chuchel kernel: PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x000fffff]
Aug 22 14:03:39 chuchel kernel: PM: hibernation: Registered nosave memory: [mem 0x01400000-0x01ffffff]
Aug 22 14:03:39 chuchel kernel: PM: hibernation: Registered nosave memory: [mem 0x59bf5000-0x59c54fff]
Aug 22 14:03:39 chuchel kernel: PM: hibernation: Registered nosave memory: [mem 0x5e72b000-0x5e84dfff]
Aug 22 14:03:39 chuchel kernel: PM: hibernation: Registered nosave memory: [mem 0x5e84e000-0x62510fff]
Aug 22 14:03:39 chuchel kernel: PM: hibernation: Registered nosave memory: [mem 0x62511000-0x62d71fff]
Aug 22 14:03:39 chuchel kernel: PM: hibernation: Registered nosave memory: [mem 0x62d72000-0x62ffefff]
Aug 22 14:03:39 chuchel kernel: PM: hibernation: Registered nosave memory: [mem 0x63000000-0x66ffffff]
Aug 22 14:03:39 chuchel kernel: PM: hibernation: Registered nosave memory: [mem 0x67000000-0x675fffff]
Aug 22 14:03:39 chuchel kernel: PM: hibernation: Registered nosave memory: [mem 0x67600000-0x677fffff]
Aug 22 14:03:39 chuchel kernel: PM: hibernation: Registered nosave memory: [mem 0x67800000-0x67ffffff]
Aug 22 14:03:39 chuchel kernel: PM: hibernation: Registered nosave memory: [mem 0x68000000-0x707fffff]
Aug 22 14:03:39 chuchel kernel: PM: hibernation: Registered nosave memory: [mem 0x70800000-0xbfffffff]
Aug 22 14:03:39 chuchel kernel: PM: hibernation: Registered nosave memory: [mem 0xc0000000-0xcfffffff]
Aug 22 14:03:39 chuchel kernel: PM: hibernation: Registered nosave memory: [mem 0xd0000000-0xfed1ffff]
Aug 22 14:03:39 chuchel kernel: PM: hibernation: Registered nosave memory: [mem 0xfed20000-0xfed7ffff]
Aug 22 14:03:39 chuchel kernel: PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xfeffffff]
Aug 22 14:03:39 chuchel kernel: PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
Aug 22 14:03:39 chuchel kernel: [mem 0x70800000-0xbfffffff] available for PCI devices
Aug 22 14:03:39 chuchel kernel: Booting paravirtualized kernel on bare hardware
Aug 22 14:03:39 chuchel kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
Aug 22 14:03:39 chuchel kernel: setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:8 nr_node_ids:1
Aug 22 14:03:39 chuchel kernel: percpu: Embedded 57 pages/cpu s196608 r8192 d28672 u262144
Aug 22 14:03:39 chuchel kernel: pcpu-alloc: s196608 r8192 d28672 u262144 alloc=1*2097152
Aug 22 14:03:39 chuchel kernel: pcpu-alloc: [0] 0 1 2 3 4 5 6 7
Aug 22 14:03:39 chuchel kernel: Built 1 zonelists, mobility grouping on.  Total pages: 8181471
Aug 22 14:03:39 chuchel kernel: Policy zone: Normal
Aug 22 14:03:39 chuchel kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64 root=UUID=0968f16f-24ed-4711-98b1-f7e16423f32d rw apparmor=1 security=apparmor udev.log_priority=3 memmap=12M$20M bootsplash.bootfile=/bootsplash-themes/manjaro/bootsplash
Aug 22 14:03:39 chuchel kernel: Unknown command line parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
Aug 22 14:03:39 chuchel kernel: Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
Aug 22 14:03:39 chuchel kernel: Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
Aug 22 14:03:39 chuchel kernel: mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
Aug 22 14:03:39 chuchel kernel: Memory: 32456908K/33245992K available (14344K kernel code, 2080K rwdata, 9116K rodata, 1808K init, 4040K bss, 788824K reserved, 0K cma-reserved)
Aug 22 14:03:39 chuchel kernel: random: get_random_u64 called from __kmem_cache_create+0x2a/0x5a0 with crng_init=0
Aug 22 14:03:39 chuchel kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
Aug 22 14:03:39 chuchel kernel: ftrace: allocating 42685 entries in 167 pages
Aug 22 14:03:39 chuchel kernel: ftrace: allocated 167 pages with 5 groups
Aug 22 14:03:39 chuchel kernel: rcu: Preemptible hierarchical RCU implementation.
Aug 22 14:03:39 chuchel kernel: rcu:         RCU dyntick-idle grace-period acceleration is enabled.
Aug 22 14:03:39 chuchel kernel: rcu:         RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=8.
Aug 22 14:03:39 chuchel kernel: rcu:         RCU priority boosting: priority 1 delay 500 ms.
Aug 22 14:03:39 chuchel kernel:         Trampoline variant of Tasks RCU enabled.
Aug 22 14:03:39 chuchel kernel:         Rude variant of Tasks RCU enabled.
Aug 22 14:03:39 chuchel kernel:         Tracing variant of Tasks RCU enabled.
Aug 22 14:03:39 chuchel kernel: rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
Aug 22 14:03:39 chuchel kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
Aug 22 14:03:39 chuchel kernel: NR_IRQS: 20736, nr_irqs: 2048, preallocated irqs: 16
Aug 22 14:03:39 chuchel kernel: Console: colour dummy device 80x25
Aug 22 14:03:39 chuchel kernel: printk: console [tty0] enabled
Aug 22 14:03:39 chuchel kernel: ACPI: Core revision 20210604
Aug 22 14:03:39 chuchel kernel: clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 99544814920 ns
Aug 22 14:03:39 chuchel kernel: APIC: Switch to symmetric I/O mode setup
Aug 22 14:03:39 chuchel kernel: DMAR: Host address width 39
Aug 22 14:03:39 chuchel kernel: DMAR: DRHD base: 0x000000fed90000 flags: 0x0
Aug 22 14:03:39 chuchel kernel: DMAR: dmar0: reg_base_addr fed90000 ver 4:0 cap 1c0000c40660462 ecap 29a00f0505e
Aug 22 14:03:39 chuchel kernel: DMAR: DRHD base: 0x000000fed84000 flags: 0x0
Aug 22 14:03:39 chuchel kernel: DMAR: dmar1: reg_base_addr fed84000 ver 1:0 cap d2008c40660462 ecap f050da
Aug 22 14:03:39 chuchel kernel: DMAR: DRHD base: 0x000000fed86000 flags: 0x0
Aug 22 14:03:39 chuchel kernel: DMAR: dmar2: reg_base_addr fed86000 ver 1:0 cap d2008c40660462 ecap f050da
Aug 22 14:03:39 chuchel kernel: DMAR: DRHD base: 0x000000fed91000 flags: 0x1
Aug 22 14:03:39 chuchel kernel: DMAR: dmar3: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
Aug 22 14:03:39 chuchel kernel: DMAR: RMRR base: 0x0000006c000000 end: 0x000000707fffff
Aug 22 14:03:39 chuchel kernel: DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 3
Aug 22 14:03:39 chuchel kernel: DMAR-IR: HPET id 0 under DRHD base 0xfed91000
Aug 22 14:03:39 chuchel kernel: DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
Aug 22 14:03:39 chuchel kernel: DMAR-IR: Enabled IRQ remapping in x2apic mode
Aug 22 14:03:39 chuchel kernel: x2apic enabled
Aug 22 14:03:39 chuchel kernel: Switched APIC routing to cluster x2apic.
Aug 22 14:03:39 chuchel kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
Aug 22 14:03:39 chuchel kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2b2c8ec87c7, max_idle_ns: 440795278598 ns
Aug 22 14:03:39 chuchel kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 5992.00 BogoMIPS (lpj=9984000)
Aug 22 14:03:39 chuchel kernel: pid_max: default: 32768 minimum: 301
Aug 22 14:03:39 chuchel kernel: LSM: Security Framework initializing
Aug 22 14:03:39 chuchel kernel: landlock: Up and running.
Aug 22 14:03:39 chuchel kernel: Yama: becoming mindful.
Aug 22 14:03:39 chuchel kernel: AppArmor: AppArmor initialized
Aug 22 14:03:39 chuchel kernel: Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
Aug 22 14:03:39 chuchel kernel: Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
Aug 22 14:03:39 chuchel kernel: x86/tme: enabled by BIOS
Aug 22 14:03:39 chuchel kernel: x86/mktme: No known encryption algorithm is supported: 0x0
Aug 22 14:03:39 chuchel kernel: x86/mktme: disabled by BIOS
Aug 22 14:03:39 chuchel kernel: CPU0: Thermal monitoring enabled (TM1)
Aug 22 14:03:39 chuchel kernel: x86/cpu: User Mode Instruction Prevention (UMIP) activated
Aug 22 14:03:39 chuchel kernel: process: using mwait in idle threads
Aug 22 14:03:39 chuchel kernel: Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
Aug 22 14:03:39 chuchel kernel: Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
Aug 22 14:03:39 chuchel kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
Aug 22 14:03:39 chuchel kernel: Spectre V2 : Mitigation: Enhanced IBRS
Aug 22 14:03:39 chuchel kernel: Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
Aug 22 14:03:39 chuchel kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
Aug 22 14:03:39 chuchel kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
Aug 22 14:03:39 chuchel kernel: Freeing SMP alternatives memory: 36K
Aug 22 14:03:39 chuchel kernel: smpboot: Estimated ratio of average max frequency by base frequency (times 1024): 1467
Aug 22 14:03:39 chuchel kernel: smpboot: CPU0: 11th Gen Intel(R) Core(TM) i7-1185G7 @ 3.00GHz (family: 0x6, model: 0x8c, stepping: 0x1)
Aug 22 14:03:39 chuchel kernel: Performance Events: PEBS fmt4+-baseline,  AnyThread deprecated, Icelake events, 32-deep LBR, full-width counters, Intel PMU driver.
Aug 22 14:03:39 chuchel kernel: ... version:                5
Aug 22 14:03:39 chuchel kernel: ... bit width:              48
Aug 22 14:03:39 chuchel kernel: ... generic registers:      8
Aug 22 14:03:39 chuchel kernel: ... value mask:             0000ffffffffffff
Aug 22 14:03:39 chuchel kernel: ... max period:             00007fffffffffff
Aug 22 14:03:39 chuchel kernel: ... fixed-purpose events:   4
Aug 22 14:03:39 chuchel kernel: ... event mask:             0001000f000000ff
Aug 22 14:03:39 chuchel kernel: rcu: Hierarchical SRCU implementation.
Aug 22 14:03:39 chuchel kernel: NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
Aug 22 14:03:39 chuchel kernel: smp: Bringing up secondary CPUs ...
Aug 22 14:03:39 chuchel kernel: x86: Booting SMP configuration:
Aug 22 14:03:39 chuchel kernel: .... node  #0, CPUs:      #1 #2 #3 #4 #5 #6 #7
Aug 22 14:03:39 chuchel kernel: smp: Brought up 1 node, 8 CPUs
Aug 22 14:03:39 chuchel kernel: smpboot: Max logical packages: 1
Aug 22 14:03:39 chuchel kernel: smpboot: Total of 8 processors activated (47942.00 BogoMIPS)
Aug 22 14:03:39 chuchel kernel: devtmpfs: initialized
Aug 22 14:03:39 chuchel kernel: x86/mm: Memory block size: 128MB
Aug 22 14:03:39 chuchel kernel: ACPI: PM: Registering ACPI NVS region [mem 0x62511000-0x62d71fff] (8785920 bytes)
Aug 22 14:03:39 chuchel kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
Aug 22 14:03:39 chuchel kernel: futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
Aug 22 14:03:39 chuchel kernel: pinctrl core: initialized pinctrl subsystem
Aug 22 14:03:39 chuchel kernel: PM: RTC time: 04:03:37, date: 2021-08-22
Aug 22 14:03:39 chuchel kernel: NET: Registered PF_NETLINK/PF_ROUTE protocol family
Aug 22 14:03:39 chuchel kernel: DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
Aug 22 14:03:39 chuchel kernel: DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
Aug 22 14:03:39 chuchel kernel: DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
Aug 22 14:03:39 chuchel kernel: audit: initializing netlink subsys (disabled)
Aug 22 14:03:39 chuchel kernel: audit: type=2000 audit(1629605017.039:1): state=initialized audit_enabled=0 res=1
Aug 22 14:03:39 chuchel kernel: thermal_sys: Registered thermal governor 'fair_share'
Aug 22 14:03:39 chuchel kernel: thermal_sys: Registered thermal governor 'bang_bang'
Aug 22 14:03:39 chuchel kernel: thermal_sys: Registered thermal governor 'step_wise'
Aug 22 14:03:39 chuchel kernel: thermal_sys: Registered thermal governor 'user_space'
Aug 22 14:03:39 chuchel kernel: thermal_sys: Registered thermal governor 'power_allocator'
Aug 22 14:03:39 chuchel kernel: cpuidle: using governor ladder
Aug 22 14:03:39 chuchel kernel: cpuidle: using governor menu
Aug 22 14:03:39 chuchel kernel: Simple Boot Flag at 0x47 set to 0x80
Aug 22 14:03:39 chuchel kernel: ACPI: bus type PCI registered
Aug 22 14:03:39 chuchel kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
Aug 22 14:03:39 chuchel kernel: PCI: MMCONFIG for domain 0000 [bus 00-e0] at [mem 0xc0000000-0xce0fffff] (base 0xc0000000)
Aug 22 14:03:39 chuchel kernel: PCI: MMCONFIG at [mem 0xc0000000-0xce0fffff] reserved in E820
Aug 22 14:03:39 chuchel kernel: PCI: Using configuration type 1 for base access
Aug 22 14:03:39 chuchel kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Aug 22 14:03:39 chuchel kernel: Kprobes globally optimized
Aug 22 14:03:39 chuchel kernel: HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
Aug 22 14:03:39 chuchel kernel: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
Aug 22 14:03:39 chuchel kernel: fbcon: Taking over console
Aug 22 14:03:39 chuchel kernel: ACPI: PRMT not present
Aug 22 14:03:39 chuchel kernel: PRM: found 4294967277 modules
Aug 22 14:03:39 chuchel kernel: ACPI: Added _OSI(Module Device)
Aug 22 14:03:39 chuchel kernel: ACPI: Added _OSI(Processor Device)
Aug 22 14:03:39 chuchel kernel: ACPI: Added _OSI(3.0 _SCP Extensions)
Aug 22 14:03:39 chuchel kernel: ACPI: Added _OSI(Processor Aggregator Device)
Aug 22 14:03:39 chuchel kernel: ACPI: Added _OSI(Linux-Dell-Video)
Aug 22 14:03:39 chuchel kernel: ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
Aug 22 14:03:39 chuchel kernel: ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
Aug 22 14:03:39 chuchel kernel: ACPI: 13 ACPI AML tables successfully acquired and loaded
Aug 22 14:03:39 chuchel kernel: ACPI: Dynamic OEM Table Load:
Aug 22 14:03:39 chuchel kernel: ACPI: SSDT 0xFFFF8E6500295600 0001CB (v02 PmRef  Cpu0Psd  00003000 INTL 20191018)
Aug 22 14:03:39 chuchel kernel: ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
Aug 22 14:03:39 chuchel kernel: ACPI: SSDT 0xFFFF8E650181A000 000394 (v02 PmRef  Cpu0Cst  00003001 INTL 20191018)
Aug 22 14:03:39 chuchel kernel: ACPI: SSDT 0xFFFF8E65019D3000 000689 (v02 PmRef  Cpu0Ist  00003000 INTL 20191018)
Aug 22 14:03:39 chuchel kernel: ACPI: SSDT 0xFFFF8E650181E400 00028B (v02 PmRef  Cpu0Hwp  00003000 INTL 20191018)
Aug 22 14:03:39 chuchel kernel: ACPI: SSDT 0xFFFF8E65019E2000 0008E7 (v02 PmRef  ApIst    00003000 INTL 20191018)
Aug 22 14:03:39 chuchel kernel: ACPI: SSDT 0xFFFF8E65019D7000 00048A (v02 PmRef  ApHwp    00003000 INTL 20191018)
Aug 22 14:03:39 chuchel kernel: ACPI: SSDT 0xFFFF8E65019D1800 0004D4 (v02 PmRef  ApPsd    00003000 INTL 20191018)
Aug 22 14:03:39 chuchel kernel: ACPI: SSDT 0xFFFF8E65019D0800 00048A (v02 PmRef  ApCst    00003000 INTL 20191018)
Aug 22 14:03:39 chuchel kernel: ACPI: EC: EC started
Aug 22 14:03:39 chuchel kernel: ACPI: EC: interrupt blocked
Aug 22 14:03:39 chuchel kernel: ACPI: EC: EC_CMD/EC_SC=0x934, EC_DATA=0x930
Aug 22 14:03:39 chuchel kernel: ACPI: \_SB_.PC00.LPCB.ECDV: Boot DSDT EC used to handle transactions
Aug 22 14:03:39 chuchel kernel: ACPI: Interpreter enabled
Aug 22 14:03:39 chuchel kernel: ACPI: PM: (supports S0 S4 S5)
Aug 22 14:03:39 chuchel kernel: ACPI: Using IOAPIC for interrupt routing
Aug 22 14:03:39 chuchel kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
Aug 22 14:03:39 chuchel kernel: ACPI: Enabled 8 GPEs in block 00 to 7F
Aug 22 14:03:39 chuchel kernel: ACPI: PM: Power Resource [WRST]
Aug 22 14:03:39 chuchel kernel: ACPI: PM: Power Resource [DRST]
Aug 22 14:03:39 chuchel kernel: ACPI: PM: Power Resource [V0PR]
Aug 22 14:03:39 chuchel kernel: ACPI: PM: Power Resource [V1PR]
Aug 22 14:03:39 chuchel kernel: ACPI: PM: Power Resource [V2PR]
Aug 22 14:03:39 chuchel kernel: ACPI: PM: Power Resource [V3PR]
Aug 22 14:03:39 chuchel kernel: ACPI: PM: Power Resource [TBT0]
Aug 22 14:03:39 chuchel kernel: ACPI: PM: Power Resource [TBT1]
Aug 22 14:03:39 chuchel kernel: ACPI: PM: Power Resource [D3C]
Aug 22 14:03:39 chuchel kernel: ACPI: PM: Power Resource [PIN]
Aug 22 14:03:39 chuchel kernel: ACPI: PCI Root Bridge [PC00] (domain 0000 [bus 00-e0])
Aug 22 14:03:39 chuchel kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
Aug 22 14:03:39 chuchel kernel: acpi PNP0A08:00: _OSC: platform does not support [AER]
Aug 22 14:03:39 chuchel kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME PCIeCapability LTR DPC]
Aug 22 14:03:39 chuchel kernel: PCI host bridge to bus 0000:00
Aug 22 14:03:39 chuchel kernel: pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
Aug 22 14:03:39 chuchel kernel: pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
Aug 22 14:03:39 chuchel kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
Aug 22 14:03:39 chuchel kernel: pci_bus 0000:00: root bus resource [mem 0x70800000-0xbfffffff window]
Aug 22 14:03:39 chuchel kernel: pci_bus 0000:00: root bus resource [mem 0x4000000000-0x7fffffffff window]
Aug 22 14:03:39 chuchel kernel: pci_bus 0000:00: root bus resource [bus 00-e0]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:00.0: [8086:9a14] type 00 class 0x060000
Aug 22 14:03:39 chuchel kernel: pci 0000:00:02.0: [8086:9a49] type 00 class 0x030000
Aug 22 14:03:39 chuchel kernel: pci 0000:00:02.0: reg 0x10: [mem 0x6054000000-0x6054ffffff 64bit]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:02.0: reg 0x18: [mem 0x4000000000-0x400fffffff 64bit pref]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:02.0: reg 0x20: [io  0x3000-0x303f]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:02.0: BAR 2: assigned to efifb
Aug 22 14:03:39 chuchel kernel: pci 0000:00:02.0: DMAR: Skip IOMMU disabling for graphics
Aug 22 14:03:39 chuchel kernel: pci 0000:00:02.0: reg 0x344: [mem 0x00000000-0x00ffffff 64bit]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:02.0: VF(n) BAR0 space: [mem 0x00000000-0x06ffffff 64bit] (contains BAR0 for 7 VFs)
Aug 22 14:03:39 chuchel kernel: pci 0000:00:02.0: reg 0x34c: [mem 0x00000000-0x1fffffff 64bit pref]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:02.0: VF(n) BAR2 space: [mem 0x00000000-0xdfffffff 64bit pref] (contains BAR2 for 7 VFs)
Aug 22 14:03:39 chuchel kernel: pci 0000:00:04.0: [8086:9a03] type 00 class 0x118000
Aug 22 14:03:39 chuchel kernel: pci 0000:00:04.0: reg 0x10: [mem 0x6055280000-0x605529ffff 64bit]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:06.0: [8086:09ab] type 00 class 0x088000
Aug 22 14:03:39 chuchel kernel: pci 0000:00:07.0: [8086:9a23] type 01 class 0x060400
Aug 22 14:03:39 chuchel kernel: pci 0000:00:07.0: PME# supported from D0 D3hot D3cold
Aug 22 14:03:39 chuchel kernel: pci 0000:00:07.0: DPC: RP PIO log size 0 is invalid
Aug 22 14:03:39 chuchel kernel: pci 0000:00:07.2: [8086:9a27] type 01 class 0x060400
Aug 22 14:03:39 chuchel kernel: pci 0000:00:07.2: PME# supported from D0 D3hot D3cold
Aug 22 14:03:39 chuchel kernel: pci 0000:00:07.2: DPC: RP PIO log size 0 is invalid
Aug 22 14:03:39 chuchel kernel: pci 0000:00:0a.0: [8086:9a0d] type 00 class 0x118000
Aug 22 14:03:39 chuchel kernel: pci 0000:00:0a.0: reg 0x10: [mem 0x60552d0000-0x60552d7fff 64bit]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:0a.0: enabling Extended Tags
Aug 22 14:03:39 chuchel kernel: pci 0000:00:0d.0: [8086:9a13] type 00 class 0x0c0330
Aug 22 14:03:39 chuchel kernel: pci 0000:00:0d.0: reg 0x10: [mem 0x60552c0000-0x60552cffff 64bit]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:0d.0: PME# supported from D3hot D3cold
Aug 22 14:03:39 chuchel kernel: pci 0000:00:0d.2: [8086:9a1b] type 00 class 0x0c0340
Aug 22 14:03:39 chuchel kernel: pci 0000:00:0d.2: reg 0x10: [mem 0x6055240000-0x605527ffff 64bit]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:0d.2: reg 0x18: [mem 0x60552e9000-0x60552e9fff 64bit]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:0d.2: supports D1 D2
Aug 22 14:03:39 chuchel kernel: pci 0000:00:0d.2: PME# supported from D0 D1 D2 D3hot D3cold
Aug 22 14:03:39 chuchel kernel: pci 0000:00:0d.3: [8086:9a1d] type 00 class 0x0c0340
Aug 22 14:03:39 chuchel kernel: pci 0000:00:0d.3: reg 0x10: [mem 0x6055200000-0x605523ffff 64bit]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:0d.3: reg 0x18: [mem 0x60552e8000-0x60552e8fff 64bit]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:0d.3: supports D1 D2
Aug 22 14:03:39 chuchel kernel: pci 0000:00:0d.3: PME# supported from D0 D1 D2 D3hot D3cold
Aug 22 14:03:39 chuchel kernel: pci 0000:00:0e.0: [8086:9a0b] type 00 class 0x010400
Aug 22 14:03:39 chuchel kernel: pci 0000:00:0e.0: reg 0x10: [mem 0x6052000000-0x6053ffffff 64bit]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:0e.0: reg 0x18: [mem 0xa4000000-0xa5ffffff]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:0e.0: reg 0x20: [mem 0x6055100000-0x60551fffff 64bit]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:12.0: [8086:a0fc] type 00 class 0x070000
Aug 22 14:03:39 chuchel kernel: pci 0000:00:12.0: reg 0x10: [mem 0x60552b0000-0x60552bffff 64bit]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:12.0: PME# supported from D0 D3hot
Aug 22 14:03:39 chuchel kernel: pci 0000:00:14.0: [8086:a0ed] type 00 class 0x0c0330
Aug 22 14:03:39 chuchel kernel: pci 0000:00:14.0: reg 0x10: [mem 0x60552a0000-0x60552affff 64bit]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:14.0: PME# supported from D3hot D3cold
Aug 22 14:03:39 chuchel kernel: pci 0000:00:14.2: [8086:a0ef] type 00 class 0x050000
Aug 22 14:03:39 chuchel kernel: pci 0000:00:14.2: reg 0x10: [mem 0x60552dc000-0x60552dffff 64bit]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:14.2: reg 0x18: [mem 0x60552e7000-0x60552e7fff 64bit]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:15.0: [8086:a0e8] type 00 class 0x0c8000
Aug 22 14:03:39 chuchel kernel: pci 0000:00:15.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:15.1: [8086:a0e9] type 00 class 0x0c8000
Aug 22 14:03:39 chuchel kernel: pci 0000:00:15.1: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:16.0: [8086:a0e0] type 00 class 0x078000
Aug 22 14:03:39 chuchel kernel: pci 0000:00:16.0: reg 0x10: [mem 0x60552e4000-0x60552e4fff 64bit]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:16.0: PME# supported from D3hot
Aug 22 14:03:39 chuchel kernel: pci 0000:00:19.0: [8086:a0c5] type 00 class 0x0c8000
Aug 22 14:03:39 chuchel kernel: pci 0000:00:19.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:19.1: [8086:a0c6] type 00 class 0x0c8000
Aug 22 14:03:39 chuchel kernel: pci 0000:00:19.1: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:1c.0: [8086:a0b8] type 01 class 0x060400
Aug 22 14:03:39 chuchel kernel: pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
Aug 22 14:03:39 chuchel kernel: pci 0000:00:1c.0: PTM enabled (root), 4ns granularity
Aug 22 14:03:39 chuchel kernel: pci 0000:00:1d.0: [8086:a0b3] type 01 class 0x060400
Aug 22 14:03:39 chuchel kernel: pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
Aug 22 14:03:39 chuchel kernel: pci 0000:00:1d.0: PTM enabled (root), 4ns granularity
Aug 22 14:03:39 chuchel kernel: pci 0000:00:1e.0: [8086:a0a8] type 00 class 0x078000
Aug 22 14:03:39 chuchel kernel: pci 0000:00:1e.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:1f.0: [8086:a082] type 00 class 0x060100
Aug 22 14:03:39 chuchel kernel: pci 0000:00:1f.3: [8086:a0c8] type 00 class 0x040100
Aug 22 14:03:39 chuchel kernel: pci 0000:00:1f.3: reg 0x10: [mem 0x60552d8000-0x60552dbfff 64bit]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:1f.3: reg 0x20: [mem 0x6055000000-0x60550fffff 64bit]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:1f.3: PME# supported from D3hot D3cold
Aug 22 14:03:39 chuchel kernel: pci 0000:00:1f.4: [8086:a0a3] type 00 class 0x0c0500
Aug 22 14:03:39 chuchel kernel: pci 0000:00:1f.4: reg 0x10: [mem 0x60552e0000-0x60552e00ff 64bit]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:1f.4: reg 0x20: [io  0xefa0-0xefbf]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:1f.5: [8086:a0a4] type 00 class 0x0c8000
Aug 22 14:03:39 chuchel kernel: pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:07.0: PCI bridge to [bus 01-38]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:07.0:   bridge window [mem 0x8c000000-0xa23fffff]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:07.0:   bridge window [mem 0x6000000000-0x6021ffffff 64bit pref]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:07.2: PCI bridge to [bus 39-70]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:07.2:   bridge window [mem 0x74000000-0x8a3fffff]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:07.2:   bridge window [mem 0x6030000000-0x6051ffffff 64bit pref]
Aug 22 14:03:39 chuchel kernel: pci 0000:71:00.0: [17cb:1101] type 00 class 0x028000
Aug 22 14:03:39 chuchel kernel: pci 0000:71:00.0: reg 0x10: [mem 0xa6100000-0xa61fffff 64bit]
Aug 22 14:03:39 chuchel kernel: pci 0000:71:00.0: PME# supported from D0 D3hot D3cold
Aug 22 14:03:39 chuchel kernel: pci 0000:71:00.0: 4.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x1 link at 0000:00:1c.0 (capable of 7.876 Gb/s with 8.0 GT/s PCIe x1 link)
Aug 22 14:03:39 chuchel kernel: pci 0000:00:1c.0: PCI bridge to [bus 71]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:1c.0:   bridge window [mem 0xa6100000-0xa61fffff]
Aug 22 14:03:39 chuchel kernel: pci 0000:72:00.0: [10ec:5260] type 00 class 0xff0000
Aug 22 14:03:39 chuchel kernel: pci 0000:72:00.0: reg 0x10: [mem 0xa6000000-0xa6000fff]
Aug 22 14:03:39 chuchel kernel: pci 0000:72:00.0: supports D1 D2
Aug 22 14:03:39 chuchel kernel: pci 0000:72:00.0: PME# supported from D1 D2 D3hot D3cold
Aug 22 14:03:39 chuchel kernel: pci 0000:00:1d.0: ASPM: current common clock configuration is inconsistent, reconfiguring
Aug 22 14:03:39 chuchel kernel: pci 0000:00:1d.0: PCI bridge to [bus 72]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:1d.0:   bridge window [mem 0xa6000000-0xa60fffff]
Aug 22 14:03:39 chuchel kernel: ACPI: EC: interrupt unblocked
Aug 22 14:03:39 chuchel kernel: ACPI: EC: event unblocked
Aug 22 14:03:39 chuchel kernel: ACPI: EC: GPE=0x6e
Aug 22 14:03:39 chuchel kernel: ACPI: \_SB_.PC00.LPCB.ECDV: Boot DSDT EC initialization complete
Aug 22 14:03:39 chuchel kernel: ACPI: \_SB_.PC00.LPCB.ECDV: EC: Used to handle transactions and events
Aug 22 14:03:39 chuchel kernel: iommu: Default domain type: Translated
Aug 22 14:03:39 chuchel kernel: pci 0000:00:02.0: vgaarb: setting as boot VGA device
Aug 22 14:03:39 chuchel kernel: pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
Aug 22 14:03:39 chuchel kernel: pci 0000:00:02.0: vgaarb: bridge control possible
Aug 22 14:03:39 chuchel kernel: vgaarb: loaded
Aug 22 14:03:39 chuchel kernel: SCSI subsystem initialized
Aug 22 14:03:39 chuchel kernel: libata version 3.00 loaded.
Aug 22 14:03:39 chuchel kernel: ACPI: bus type USB registered
Aug 22 14:03:39 chuchel kernel: usbcore: registered new interface driver usbfs
Aug 22 14:03:39 chuchel kernel: usbcore: registered new interface driver hub
Aug 22 14:03:39 chuchel kernel: usbcore: registered new device driver usb
Aug 22 14:03:39 chuchel kernel: pps_core: LinuxPPS API ver. 1 registered
Aug 22 14:03:39 chuchel kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
Aug 22 14:03:39 chuchel kernel: PTP clock support registered
Aug 22 14:03:39 chuchel kernel: EDAC MC: Ver: 3.0.0
Aug 22 14:03:39 chuchel kernel: Registered efivars operations
Aug 22 14:03:39 chuchel kernel: NetLabel: Initializing
Aug 22 14:03:39 chuchel kernel: NetLabel:  domain hash size = 128
Aug 22 14:03:39 chuchel kernel: NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
Aug 22 14:03:39 chuchel kernel: NetLabel:  unlabeled traffic allowed by default
Aug 22 14:03:39 chuchel kernel: PCI: Using ACPI for IRQ routing
Aug 22 14:03:39 chuchel kernel: PCI: pci_cache_line_size set to 64 bytes
Aug 22 14:03:39 chuchel kernel: pci 0000:00:1f.5: can't claim BAR 0 [mem 0xfe010000-0xfe010fff]: no compatible bridge window
Aug 22 14:03:39 chuchel kernel: e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
Aug 22 14:03:39 chuchel kernel: e820: reserve RAM buffer [mem 0x01400000-0x03ffffff]
Aug 22 14:03:39 chuchel kernel: e820: reserve RAM buffer [mem 0x59bf5000-0x5bffffff]
Aug 22 14:03:39 chuchel kernel: e820: reserve RAM buffer [mem 0x5e72b000-0x5fffffff]
Aug 22 14:03:39 chuchel kernel: e820: reserve RAM buffer [mem 0x63000000-0x63ffffff]
Aug 22 14:03:39 chuchel kernel: e820: reserve RAM buffer [mem 0x88f800000-0x88fffffff]
Aug 22 14:03:39 chuchel kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
Aug 22 14:03:39 chuchel kernel: hpet0: 8 comparators, 64-bit 19.200000 MHz counter
Aug 22 14:03:39 chuchel kernel: clocksource: Switched to clocksource tsc-early
Aug 22 14:03:39 chuchel kernel: VFS: Disk quotas dquot_6.6.0
Aug 22 14:03:39 chuchel kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Aug 22 14:03:39 chuchel kernel: AppArmor: AppArmor Filesystem Enabled
Aug 22 14:03:39 chuchel kernel: pnp: PnP ACPI init
Aug 22 14:03:39 chuchel kernel: system 00:00: [io  0x0680-0x069f] has been reserved
Aug 22 14:03:39 chuchel kernel: system 00:00: [io  0x164e-0x164f] has been reserved
Aug 22 14:03:39 chuchel kernel: system 00:02: [io  0x1854-0x1857] has been reserved
Aug 22 14:03:39 chuchel kernel: pnp 00:05: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
Aug 22 14:03:39 chuchel kernel: system 00:05: [mem 0xfedc0000-0xfedc7fff] has been reserved
Aug 22 14:03:39 chuchel kernel: system 00:05: [mem 0xfeda0000-0xfeda0fff] has been reserved
Aug 22 14:03:39 chuchel kernel: system 00:05: [mem 0xfeda1000-0xfeda1fff] has been reserved
Aug 22 14:03:39 chuchel kernel: system 00:05: [mem 0xfed20000-0xfed7ffff] could not be reserved
Aug 22 14:03:39 chuchel kernel: system 00:05: [mem 0xfed90000-0xfed93fff] could not be reserved
Aug 22 14:03:39 chuchel kernel: system 00:05: [mem 0xfed45000-0xfed8ffff] could not be reserved
Aug 22 14:03:39 chuchel kernel: system 00:05: [mem 0xfee00000-0xfeefffff] has been reserved
Aug 22 14:03:39 chuchel kernel: system 00:06: [io  0x1800-0x18fe] could not be reserved
Aug 22 14:03:39 chuchel kernel: system 00:06: [mem 0xfe000000-0xfe01ffff] has been reserved
Aug 22 14:03:39 chuchel kernel: system 00:06: [mem 0xfe04c000-0xfe04ffff] has been reserved
Aug 22 14:03:39 chuchel kernel: system 00:06: [mem 0xfe050000-0xfe0affff] has been reserved
Aug 22 14:03:39 chuchel kernel: system 00:06: [mem 0xfe0d0000-0xfe0fffff] has been reserved
Aug 22 14:03:39 chuchel kernel: system 00:06: [mem 0xfe200000-0xfe7fffff] has been reserved
Aug 22 14:03:39 chuchel kernel: system 00:06: [mem 0xff000000-0xffffffff] has been reserved
Aug 22 14:03:39 chuchel kernel: system 00:06: [mem 0xfd000000-0xfd68ffff] has been reserved
Aug 22 14:03:39 chuchel kernel: system 00:06: [mem 0xfd6b0000-0xfd6cffff] has been reserved
Aug 22 14:03:39 chuchel kernel: system 00:06: [mem 0xfd6f0000-0xfdffffff] has been reserved
Aug 22 14:03:39 chuchel kernel: system 00:07: [io  0x2000-0x20fe] has been reserved
Aug 22 14:03:39 chuchel kernel: pnp: PnP ACPI: found 9 devices
Aug 22 14:03:39 chuchel kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
Aug 22 14:03:39 chuchel kernel: NET: Registered PF_INET protocol family
Aug 22 14:03:39 chuchel kernel: IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
Aug 22 14:03:39 chuchel kernel: tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
Aug 22 14:03:39 chuchel kernel: TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
Aug 22 14:03:39 chuchel kernel: TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
Aug 22 14:03:39 chuchel kernel: TCP: Hash tables configured (established 262144 bind 65536)
Aug 22 14:03:39 chuchel kernel: MPTCP token hash table entries: 32768 (order: 7, 786432 bytes, linear)
Aug 22 14:03:39 chuchel kernel: UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
Aug 22 14:03:39 chuchel kernel: UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
Aug 22 14:03:39 chuchel kernel: NET: Registered PF_UNIX/PF_LOCAL protocol family
Aug 22 14:03:39 chuchel kernel: NET: Registered PF_XDP protocol family
Aug 22 14:03:39 chuchel kernel: pci 0000:00:07.0: bridge window [io  0x1000-0x0fff] to [bus 01-38] add_size 1000
Aug 22 14:03:39 chuchel kernel: pci 0000:00:07.2: bridge window [io  0x1000-0x0fff] to [bus 39-70] add_size 1000
Aug 22 14:03:39 chuchel kernel: pci 0000:00:02.0: BAR 9: assigned [mem 0x4020000000-0x40ffffffff 64bit pref]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:02.0: BAR 7: assigned [mem 0x4010000000-0x4016ffffff 64bit]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:07.0: BAR 13: assigned [io  0x4000-0x4fff]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:07.2: BAR 13: assigned [io  0x5000-0x5fff]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:15.0: BAR 0: assigned [mem 0x4017000000-0x4017000fff 64bit]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:15.1: BAR 0: assigned [mem 0x4017001000-0x4017001fff 64bit]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:19.0: BAR 0: assigned [mem 0x4017002000-0x4017002fff 64bit]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:19.1: BAR 0: assigned [mem 0x4017003000-0x4017003fff 64bit]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:1e.0: BAR 0: assigned [mem 0x4017004000-0x4017004fff 64bit]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:1f.5: BAR 0: assigned [mem 0x70800000-0x70800fff]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:07.0:   bridge window [io  0x4000-0x4fff]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:07.2:   bridge window [io  0x5000-0x5fff]
Aug 22 14:03:39 chuchel kernel: pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
Aug 22 14:03:39 chuchel kernel: pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
Aug 22 14:03:39 chuchel kernel: pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
Aug 22 14:03:39 chuchel kernel: pci_bus 0000:00: resource 7 [mem 0x70800000-0xbfffffff window]
Aug 22 14:03:39 chuchel kernel: pci_bus 0000:00: resource 8 [mem 0x4000000000-0x7fffffffff window]
Aug 22 14:03:39 chuchel kernel: pci_bus 0000:01: resource 0 [io  0x4000-0x4fff]
Aug 22 14:03:39 chuchel kernel: pci_bus 0000:01: resource 1 [mem 0x8c000000-0xa23fffff]
Aug 22 14:03:39 chuchel kernel: pci_bus 0000:01: resource 2 [mem 0x6000000000-0x6021ffffff 64bit pref]
Aug 22 14:03:39 chuchel kernel: pci_bus 0000:39: resource 0 [io  0x5000-0x5fff]
Aug 22 14:03:39 chuchel kernel: pci_bus 0000:39: resource 1 [mem 0x74000000-0x8a3fffff]
Aug 22 14:03:39 chuchel kernel: pci_bus 0000:39: resource 2 [mem 0x6030000000-0x6051ffffff 64bit pref]
Aug 22 14:03:39 chuchel kernel: pci_bus 0000:71: resource 1 [mem 0xa6100000-0xa61fffff]
Aug 22 14:03:39 chuchel kernel: pci_bus 0000:72: resource 1 [mem 0xa6000000-0xa60fffff]
Aug 22 14:03:39 chuchel kernel: pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
Aug 22 14:03:39 chuchel kernel: PCI: CLS 0 bytes, default 64
Aug 22 14:03:39 chuchel kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
Aug 22 14:03:39 chuchel kernel: software IO TLB: mapped [mem 0x0000000055bf5000-0x0000000059bf5000] (64MB)
Aug 22 14:03:39 chuchel kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2b2c8ec87c7, max_idle_ns: 440795278598 ns
Aug 22 14:03:39 chuchel kernel: Trying to unpack rootfs image as initramfs...
Aug 22 14:03:39 chuchel kernel: Initialise system trusted keyrings
Aug 22 14:03:39 chuchel kernel: Key type blacklist registered
Aug 22 14:03:39 chuchel kernel: workingset: timestamp_bits=41 max_order=23 bucket_order=0
Aug 22 14:03:39 chuchel kernel: zbud: loaded
Aug 22 14:03:39 chuchel kernel: Key type asymmetric registered
Aug 22 14:03:39 chuchel kernel: Asymmetric key parser 'x509' registered
Aug 22 14:03:39 chuchel kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
Aug 22 14:03:39 chuchel kernel: io scheduler mq-deadline registered
Aug 22 14:03:39 chuchel kernel: io scheduler kyber registered
Aug 22 14:03:39 chuchel kernel: io scheduler bfq registered
Aug 22 14:03:39 chuchel kernel: pcieport 0000:00:07.0: PME: Signaling with IRQ 124
Aug 22 14:03:39 chuchel kernel: pcieport 0000:00:07.0: pciehp: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
Aug 22 14:03:39 chuchel kernel: pcieport 0000:00:07.2: PME: Signaling with IRQ 125
Aug 22 14:03:39 chuchel kernel: pcieport 0000:00:07.2: pciehp: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
Aug 22 14:03:39 chuchel kernel: pcieport 0000:00:1c.0: PME: Signaling with IRQ 126
Aug 22 14:03:39 chuchel kernel: pcieport 0000:00:1d.0: PME: Signaling with IRQ 127
Aug 22 14:03:39 chuchel kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Aug 22 14:03:39 chuchel kernel: efifb: probing for efifb
Aug 22 14:03:39 chuchel kernel: efifb: framebuffer at 0x4000000000, using 29184k, total 29184k
Aug 22 14:03:39 chuchel kernel: efifb: mode is 3456x2160x32, linelength=13824, pages=1
Aug 22 14:03:39 chuchel kernel: efifb: scrolling: redraw
Aug 22 14:03:39 chuchel kernel: efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
Aug 22 14:03:39 chuchel kernel: Freeing initrd memory: 12856K
Aug 22 14:03:39 chuchel kernel: bootsplash: Loading splash file (606512 bytes)
Aug 22 14:03:39 chuchel kernel: bootsplash: Loaded (606512 bytes, 2 pics, 76 blobs).
Aug 22 14:03:39 chuchel kernel: Console: switching to colour frame buffer device 216x67
Aug 22 14:03:39 chuchel kernel: fb0: EFI VGA frame buffer device
Aug 22 14:03:39 chuchel kernel: Monitor-Mwait will be used to enter C-1 state
Aug 22 14:03:39 chuchel kernel: Monitor-Mwait will be used to enter C-2 state
Aug 22 14:03:39 chuchel kernel: Monitor-Mwait will be used to enter C-3 state
Aug 22 14:03:39 chuchel kernel: ACPI: \_SB_.PR00: Found 3 idle states
Aug 22 14:03:39 chuchel kernel: ACPI: AC: AC Adapter [AC] (on-line)
Aug 22 14:03:39 chuchel kernel: input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
Aug 22 14:03:39 chuchel kernel: ACPI: button: Lid Switch [LID0]
Aug 22 14:03:39 chuchel kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
Aug 22 14:03:39 chuchel kernel: ACPI: button: Power Button [PBTN]
Aug 22 14:03:39 chuchel kernel: Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
Aug 22 14:03:39 chuchel kernel: serial 0000:00:12.0: enabling device (0000 -> 0002)
Aug 22 14:03:39 chuchel kernel: Non-volatile memory driver v1.3
Aug 22 14:03:39 chuchel kernel: AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
Aug 22 14:03:39 chuchel kernel: AMD-Vi: AMD IOMMUv2 functionality not available on this system
Aug 22 14:03:39 chuchel kernel: ahci 0000:00:0e.0: version 3.0
Aug 22 14:03:39 chuchel kernel: ahci: probe of 0000:00:0e.0 failed with error -22
Aug 22 14:03:39 chuchel kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Aug 22 14:03:39 chuchel kernel: ehci-pci: EHCI PCI platform driver
Aug 22 14:03:39 chuchel kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Aug 22 14:03:39 chuchel kernel: ohci-pci: OHCI PCI platform driver
Aug 22 14:03:39 chuchel kernel: uhci_hcd: USB Universal Host Controller Interface driver
Aug 22 14:03:39 chuchel kernel: usbcore: registered new interface driver usbserial_generic
Aug 22 14:03:39 chuchel kernel: usbserial: USB Serial support registered for generic
Aug 22 14:03:39 chuchel kernel: rtc_cmos 00:01: RTC can wake from S4
Aug 22 14:03:39 chuchel kernel: rtc_cmos 00:01: registered as rtc0
Aug 22 14:03:39 chuchel kernel: rtc_cmos 00:01: setting system clock to 2021-08-22T04:03:38 UTC (1629605018)
Aug 22 14:03:39 chuchel kernel: rtc_cmos 00:01: alarms up to one month, y3k, 242 bytes nvram
Aug 22 14:03:39 chuchel kernel: intel_pstate: Intel P-state driver initializing
Aug 22 14:03:39 chuchel kernel: intel_pstate: HWP enabled
Aug 22 14:03:39 chuchel kernel: ledtrig-cpu: registered to indicate activity on CPUs
Aug 22 14:03:39 chuchel kernel: hid: raw HID events driver (C) Jiri Kosina
Aug 22 14:03:39 chuchel kernel: ashmem: initialized
Aug 22 14:03:39 chuchel kernel: intel_pmc_core INT33A1:00:  initialized
Aug 22 14:03:39 chuchel kernel: drop_monitor: Initializing network drop monitor service
Aug 22 14:03:39 chuchel kernel: Initializing XFRM netlink socket
Aug 22 14:03:39 chuchel kernel: NET: Registered PF_INET6 protocol family
Aug 22 14:03:39 chuchel kernel: Segment Routing with IPv6
Aug 22 14:03:39 chuchel kernel: RPL Segment Routing with IPv6
Aug 22 14:03:39 chuchel kernel: NET: Registered PF_PACKET protocol family
Aug 22 14:03:39 chuchel kernel: microcode: sig=0x806c1, pf=0x80, revision=0x88
Aug 22 14:03:39 chuchel kernel: microcode: Microcode Update Driver: v2.2.
Aug 22 14:03:39 chuchel kernel: resctrl: L2 allocation detected
Aug 22 14:03:39 chuchel kernel: resctrl: L2DATA allocation detected
Aug 22 14:03:39 chuchel kernel: resctrl: L2CODE allocation detected
Aug 22 14:03:39 chuchel kernel: IPI shorthand broadcast: enabled
Aug 22 14:03:39 chuchel kernel: sched_clock: Marking stable (1316907610, 3797522)->(1327367723, -6662591)
Aug 22 14:03:39 chuchel kernel: registered taskstats version 1
Aug 22 14:03:39 chuchel kernel: Loading compiled-in X.509 certificates
Aug 22 14:03:39 chuchel kernel: Loaded X.509 cert 'Build time autogenerated kernel key: f9d8b407c5629bfac1d38b5447028f60f0dde0d1'
Aug 22 14:03:39 chuchel kernel: zswap: loaded using pool zstd/z3fold
Aug 22 14:03:39 chuchel kernel: Key type ._fscrypt registered
Aug 22 14:03:39 chuchel kernel: Key type .fscrypt registered
Aug 22 14:03:39 chuchel kernel: Key type fscrypt-provisioning registered
Aug 22 14:03:39 chuchel kernel: AppArmor: AppArmor sha1 policy hashing enabled
Aug 22 14:03:39 chuchel kernel: PM:   Magic number: 1:600:60
Aug 22 14:03:39 chuchel kernel: memory memory221: hash matches
Aug 22 14:03:39 chuchel kernel: RAS: Correctable Errors collector initialized.
Aug 22 14:03:39 chuchel kernel: ACPI: battery: Slot [BAT0] (battery present)
Aug 22 14:03:39 chuchel kernel: Freeing unused decrypted memory: 2036K
Aug 22 14:03:39 chuchel kernel: Freeing unused kernel image (initmem) memory: 1808K
Aug 22 14:03:39 chuchel kernel: Write protecting the kernel read-only data: 26624k
Aug 22 14:03:39 chuchel kernel: Freeing unused kernel image (text/rodata gap) memory: 2036K
Aug 22 14:03:39 chuchel kernel: Freeing unused kernel image (rodata/data gap) memory: 1124K
Aug 22 14:03:39 chuchel kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
Aug 22 14:03:39 chuchel kernel: rodata_test: all tests were successful
Aug 22 14:03:39 chuchel kernel: Run /init as init process
Aug 22 14:03:39 chuchel kernel:   with arguments:
Aug 22 14:03:39 chuchel kernel:     /init
Aug 22 14:03:39 chuchel kernel:   with environment:
Aug 22 14:03:39 chuchel kernel:     HOME=/
Aug 22 14:03:39 chuchel kernel:     TERM=linux
Aug 22 14:03:39 chuchel kernel:     BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
Aug 22 14:03:39 chuchel kernel: vmd 0000:00:0e.0: PCI host bridge to bus 10000:e0
Aug 22 14:03:39 chuchel kernel: pci_bus 10000:e0: root bus resource [bus e0-ff]
Aug 22 14:03:39 chuchel kernel: pci_bus 10000:e0: root bus resource [mem 0xa4000000-0xa5ffffff]
Aug 22 14:03:39 chuchel kernel: pci_bus 10000:e0: root bus resource [mem 0x6055102000-0x60551fffff 64bit]
Aug 22 14:03:39 chuchel kernel: pci 10000:e0:06.0: [8086:9a09] type 01 class 0x060400
Aug 22 14:03:39 chuchel kernel: pci 10000:e0:06.0: PME# supported from D0 D3hot D3cold
Aug 22 14:03:39 chuchel kernel: pci 10000:e0:06.0: PTM enabled (root), 4ns granularity
Aug 22 14:03:39 chuchel kernel: pci 10000:e0:06.0: Primary bus is hard wired to 0
Aug 22 14:03:39 chuchel kernel: pci 10000:e1:00.0: [1179:011a] type 00 class 0x010802
Aug 22 14:03:39 chuchel kernel: pci 10000:e1:00.0: reg 0x10: [mem 0xa4000000-0xa4003fff 64bit]
Aug 22 14:03:39 chuchel kernel: pci 10000:e0:06.0: PCI bridge to [bus e1]
Aug 22 14:03:39 chuchel kernel: pci 10000:e0:06.0:   bridge window [io  0x0000-0x0fff]
Aug 22 14:03:39 chuchel kernel: pci 10000:e0:06.0:   bridge window [mem 0xa4000000-0xa40fffff]
Aug 22 14:03:39 chuchel kernel: pci 10000:e0:06.0: BAR 14: assigned [mem 0xa4000000-0xa40fffff]
Aug 22 14:03:39 chuchel kernel: pci 10000:e0:06.0: BAR 13: no space for [io  size 0x1000]
Aug 22 14:03:39 chuchel kernel: pci 10000:e0:06.0: BAR 13: failed to assign [io  size 0x1000]
Aug 22 14:03:39 chuchel kernel: pci 10000:e1:00.0: BAR 0: assigned [mem 0xa4000000-0xa4003fff 64bit]
Aug 22 14:03:39 chuchel kernel: pcieport 10000:e0:06.0: can't derive routing for PCI INT D
Aug 22 14:03:39 chuchel kernel: pcieport 10000:e0:06.0: PCI INT D: no GSI
Aug 22 14:03:39 chuchel kernel: pcieport 10000:e0:06.0: PME: Signaling with IRQ 147
Aug 22 14:03:39 chuchel kernel: pcieport 10000:e0:06.0: AER: enabled with IRQ 147
Aug 22 14:03:39 chuchel kernel: pcieport 10000:e0:06.0: DPC: enabled with IRQ 147
Aug 22 14:03:39 chuchel kernel: pcieport 10000:e0:06.0: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
Aug 22 14:03:39 chuchel kernel: nvme nvme0: pci function 10000:e1:00.0
Aug 22 14:03:39 chuchel kernel: vmd 0000:00:0e.0: Bound to PCI domain 10000
Aug 22 14:03:39 chuchel kernel: pcieport 10000:e0:06.0: can't derive routing for PCI INT A
Aug 22 14:03:39 chuchel kernel: nvme 10000:e1:00.0: PCI INT A: no GSI
Aug 22 14:03:39 chuchel kernel: nvme nvme0: 8/0/0 default/read/poll queues
Aug 22 14:03:39 chuchel kernel:  nvme0n1: p1 p2 p3 p4 p5 p6 p7
Aug 22 14:03:39 chuchel kernel: i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
Aug 22 14:03:39 chuchel kernel: i8042: Warning: Keylock active
Aug 22 14:03:39 chuchel kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
Aug 22 14:03:39 chuchel kernel: serio: i8042 AUX port at 0x60,0x64 irq 12
Aug 22 14:03:39 chuchel kernel: xhci_hcd 0000:00:0d.0: xHCI Host Controller
Aug 22 14:03:39 chuchel kernel: xhci_hcd 0000:00:0d.0: new USB bus registered, assigned bus number 1
Aug 22 14:03:39 chuchel kernel: xhci_hcd 0000:00:0d.0: hcc params 0x20007fc1 hci version 0x120 quirks 0x0000000200009810
Aug 22 14:03:39 chuchel kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.14
Aug 22 14:03:39 chuchel kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 22 14:03:39 chuchel kernel: usb usb1: Product: xHCI Host Controller
Aug 22 14:03:39 chuchel kernel: usb usb1: Manufacturer: Linux 5.14.0-1-MANJARO xhci-hcd
Aug 22 14:03:39 chuchel kernel: usb usb1: SerialNumber: 0000:00:0d.0
Aug 22 14:03:39 chuchel kernel: hub 1-0:1.0: USB hub found
Aug 22 14:03:39 chuchel kernel: hub 1-0:1.0: 1 port detected
Aug 22 14:03:39 chuchel kernel: xhci_hcd 0000:00:0d.0: new USB bus registered, assigned bus number 2
Aug 22 14:03:39 chuchel kernel: xhci_hcd 0000:00:0d.0: Host supports USB 3.1 Enhanced SuperSpeed
Aug 22 14:03:39 chuchel kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.14
Aug 22 14:03:39 chuchel kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 22 14:03:39 chuchel kernel: usb usb2: Product: xHCI Host Controller
Aug 22 14:03:39 chuchel kernel: usb usb2: Manufacturer: Linux 5.14.0-1-MANJARO xhci-hcd
Aug 22 14:03:39 chuchel kernel: usb usb2: SerialNumber: 0000:00:0d.0
Aug 22 14:03:39 chuchel kernel: hub 2-0:1.0: USB hub found
Aug 22 14:03:39 chuchel kernel: hub 2-0:1.0: 4 ports detected
Aug 22 14:03:39 chuchel kernel: xhci_hcd 0000:00:14.0: xHCI Host Controller
Aug 22 14:03:39 chuchel kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
Aug 22 14:03:39 chuchel kernel: xhci_hcd 0000:00:14.0: hcc params 0x20007fc1 hci version 0x120 quirks 0x0000000000009810
Aug 22 14:03:39 chuchel kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.14
Aug 22 14:03:39 chuchel kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 22 14:03:39 chuchel kernel: usb usb3: Product: xHCI Host Controller
Aug 22 14:03:39 chuchel kernel: usb usb3: Manufacturer: Linux 5.14.0-1-MANJARO xhci-hcd
Aug 22 14:03:39 chuchel kernel: usb usb3: SerialNumber: 0000:00:14.0
Aug 22 14:03:39 chuchel kernel: hub 3-0:1.0: USB hub found
Aug 22 14:03:39 chuchel kernel: hub 3-0:1.0: 12 ports detected
Aug 22 14:03:39 chuchel kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
Aug 22 14:03:39 chuchel kernel: xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
Aug 22 14:03:39 chuchel kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.14
Aug 22 14:03:39 chuchel kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 22 14:03:39 chuchel kernel: usb usb4: Product: xHCI Host Controller
Aug 22 14:03:39 chuchel kernel: usb usb4: Manufacturer: Linux 5.14.0-1-MANJARO xhci-hcd
Aug 22 14:03:39 chuchel kernel: usb usb4: SerialNumber: 0000:00:14.0
Aug 22 14:03:39 chuchel kernel: hub 4-0:1.0: USB hub found
Aug 22 14:03:39 chuchel kernel: hub 4-0:1.0: 4 ports detected
Aug 22 14:03:39 chuchel kernel: usb: port power management may be unreliable
Aug 22 14:03:39 chuchel kernel: random: fast init done
Aug 22 14:03:39 chuchel kernel: input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
Aug 22 14:03:39 chuchel kernel: EXT4-fs (nvme0n1p7): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
Aug 22 14:03:39 chuchel systemd[1]: systemd 248.7-1-manjaro running in system mode. (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
Aug 22 14:03:39 chuchel systemd[1]: Detected architecture x86-64.
Aug 22 14:03:39 chuchel systemd[1]: Hostname set to <chuchel>.
Aug 22 14:03:39 chuchel kernel: random: lvmconfig: uninitialized urandom read (4 bytes read)
Aug 22 14:03:39 chuchel kernel: usb 3-3: new full-speed USB device number 2 using xhci_hcd
Aug 22 14:03:39 chuchel systemd[1]: Queued start job for default target Graphical Interface.
Aug 22 14:03:39 chuchel systemd[1]: Created slice Slice /system/getty.
Aug 22 14:03:39 chuchel systemd[1]: Created slice Slice /system/modprobe.
Aug 22 14:03:39 chuchel systemd[1]: Created slice Slice /system/systemd-fsck.
Aug 22 14:03:39 chuchel systemd[1]: Created slice User and Session Slice.
Aug 22 14:03:39 chuchel systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
Aug 22 14:03:39 chuchel systemd[1]: Started Forward Password Requests to Wall Directory Watch.
Aug 22 14:03:39 chuchel systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
Aug 22 14:03:39 chuchel systemd[1]: Reached target Local Encrypted Volumes.
Aug 22 14:03:39 chuchel systemd[1]: Reached target Login Prompts.
Aug 22 14:03:39 chuchel systemd[1]: Reached target Remote File Systems.
Aug 22 14:03:39 chuchel systemd[1]: Reached target Slice Units.
Aug 22 14:03:39 chuchel systemd[1]: Reached target Swaps.
Aug 22 14:03:39 chuchel systemd[1]: Reached target Local Verity Integrity Protected Volumes.
Aug 22 14:03:39 chuchel systemd[1]: Listening on Device-mapper event daemon FIFOs.
Aug 22 14:03:39 chuchel systemd[1]: Listening on LVM2 poll daemon socket.
Aug 22 14:03:39 chuchel systemd[1]: Listening on Process Core Dump Socket.
Aug 22 14:03:39 chuchel systemd[1]: Listening on Journal Audit Socket.
Aug 22 14:03:39 chuchel systemd[1]: Listening on Journal Socket (/dev/log).
Aug 22 14:03:39 chuchel systemd[1]: Listening on Journal Socket.
Aug 22 14:03:39 chuchel systemd[1]: Listening on udev Control Socket.
Aug 22 14:03:39 chuchel systemd[1]: Listening on udev Kernel Socket.
Aug 22 14:03:39 chuchel systemd[1]: Mounting Huge Pages File System...
Aug 22 14:03:39 chuchel systemd[1]: Mounting POSIX Message Queue File System...
Aug 22 14:03:39 chuchel systemd[1]: Mounting Kernel Debug File System...
Aug 22 14:03:39 chuchel systemd[1]: Mounting Kernel Trace File System...
Aug 22 14:03:39 chuchel systemd[1]: Mounting Temporary Directory /tmp...
Aug 22 14:03:39 chuchel systemd[1]: Starting Load AppArmor profiles...
Aug 22 14:03:39 chuchel systemd[1]: Starting Create List of Static Device Nodes...
Aug 22 14:03:39 chuchel systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Aug 22 14:03:39 chuchel systemd[1]: Starting Load Kernel Module configfs...
Aug 22 14:03:39 chuchel systemd[1]: Starting Load Kernel Module drm...
Aug 22 14:03:39 chuchel systemd[1]: Starting Load Kernel Module fuse...
Aug 22 14:03:39 chuchel kernel: random: lvm: uninitialized urandom read (4 bytes read)
Aug 22 14:03:39 chuchel systemd[1]: Starting Set Up Additional Binary Formats...
Aug 22 14:03:39 chuchel systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
Aug 22 14:03:39 chuchel systemd[1]: Starting Load Kernel Modules...
Aug 22 14:03:39 chuchel systemd[1]: Starting Remount Root and Kernel File Systems...
Aug 22 14:03:39 chuchel systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
Aug 22 14:03:39 chuchel systemd[1]: Starting Coldplug All udev Devices...
Aug 22 14:03:39 chuchel systemd[1]: Mounted Huge Pages File System.
Aug 22 14:03:39 chuchel systemd[1]: Mounted POSIX Message Queue File System.
Aug 22 14:03:39 chuchel systemd[1]: Mounted Kernel Debug File System.
Aug 22 14:03:39 chuchel systemd[1]: Mounted Kernel Trace File System.
Aug 22 14:03:39 chuchel systemd[1]: Mounted Temporary Directory /tmp.
Aug 22 14:03:39 chuchel systemd[1]: Finished Create List of Static Device Nodes.
Aug 22 14:03:39 chuchel systemd[1]: modprobe@configfs.service: Deactivated successfully.
Aug 22 14:03:39 chuchel systemd[1]: Finished Load Kernel Module configfs.
Aug 22 14:03:39 chuchel systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 239 (systemd-binfmt)
Aug 22 14:03:39 chuchel kernel: EXT4-fs (nvme0n1p7): re-mounted. Opts: (null). Quota mode: none.
Aug 22 14:03:39 chuchel systemd[1]: Mounting Arbitrary Executable File Formats File System...
Aug 22 14:03:39 chuchel systemd[1]: Mounting Kernel Configuration File System...
Aug 22 14:03:39 chuchel systemd[1]: Finished Remount Root and Kernel File Systems.
Aug 22 14:03:39 chuchel systemd[1]: Mounted Arbitrary Executable File Formats File System.
Aug 22 14:03:39 chuchel systemd[1]: Mounted Kernel Configuration File System.
Aug 22 14:03:39 chuchel systemd[1]: Condition check resulted in First Boot Wizard being skipped.
Aug 22 14:03:39 chuchel systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
Aug 22 14:03:39 chuchel systemd[1]: Starting Load/Save Random Seed...
Aug 22 14:03:39 chuchel systemd[1]: Starting Create System Users...
Aug 22 14:03:39 chuchel systemd[1]: Finished Set Up Additional Binary Formats.
Aug 22 14:03:39 chuchel kernel: fuse: init (API version 7.34)
Aug 22 14:03:39 chuchel systemd[1]: modprobe@fuse.service: Deactivated successfully.
Aug 22 14:03:39 chuchel systemd[1]: Finished Load Kernel Module fuse.
Aug 22 14:03:39 chuchel systemd[1]: Mounting FUSE Control File System...
Aug 22 14:03:39 chuchel systemd[1]: Mounted FUSE Control File System.
Aug 22 14:03:39 chuchel kernel: vboxdrv: loading out-of-tree module taints kernel.
Aug 22 14:03:39 chuchel kernel: vboxdrv: module verification failed: signature and/or required key missing - tainting kernel
Aug 22 14:03:39 chuchel kernel: vboxdrv: Found 8 processor cores
Aug 22 14:03:39 chuchel systemd[1]: modprobe@drm.service: Deactivated successfully.
Aug 22 14:03:39 chuchel systemd[1]: Finished Load Kernel Module drm.
Aug 22 14:03:39 chuchel systemd[1]: Finished Create System Users.
Aug 22 14:03:39 chuchel systemd[1]: Starting Create Static Device Nodes in /dev...
Aug 22 14:03:39 chuchel systemd[1]: Finished Create Static Device Nodes in /dev.
Aug 22 14:03:39 chuchel systemd[1]: Started Entropy Daemon based on the HAVEGE algorithm.
Aug 22 14:03:39 chuchel systemd[1]: Starting Journal Service...
Aug 22 14:03:39 chuchel kernel: audit: type=1400 audit(1629605019.009:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=256 comm="apparmor_parser"
Aug 22 14:03:39 chuchel systemd[1]: Starting Rule-based Manager for Device Events and Files...
Aug 22 14:03:39 chuchel kernel: vboxdrv: TSC mode is Invariant, tentative frequency 2995199389 Hz
Aug 22 14:03:39 chuchel kernel: vboxdrv: Successfully loaded version 6.1.26 r145957 (interface 0x00300000)
Aug 22 14:03:39 chuchel kernel: VBoxNetAdp: Successfully started.
Aug 22 14:03:39 chuchel kernel: VBoxNetFlt: Successfully started.
Aug 22 14:03:39 chuchel systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Aug 22 14:03:39 chuchel kernel: audit: type=1130 audit(1629605019.023:3): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 22 14:03:39 chuchel systemd[1]: Reached target Preparation for Local File Systems.
Aug 22 14:03:39 chuchel systemd[1]: Condition check resulted in Virtual Machine and Container Storage (Compatibility) being skipped.
Aug 22 14:03:39 chuchel systemd[1]: Finished Load Kernel Modules.
Aug 22 14:03:39 chuchel kernel: audit: type=1130 audit(1629605019.026:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 22 14:03:39 chuchel kernel: audit: type=1400 audit(1629605019.026:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=253 comm="apparmor_parser"
Aug 22 14:03:39 chuchel systemd[1]: Starting Apply Kernel Variables...
Aug 22 14:03:39 chuchel kernel: audit: type=1400 audit(1629605019.029:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=253 comm="apparmor_parser"
Aug 22 14:03:39 chuchel systemd[1]: Finished Coldplug All udev Devices.
Aug 22 14:03:39 chuchel kernel: audit: type=1130 audit(1629605019.029:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 22 14:03:39 chuchel systemd[1]: Finished Apply Kernel Variables.
Aug 22 14:03:39 chuchel kernel: audit: type=1130 audit(1629605019.033:8): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 22 14:03:39 chuchel systemd[1]: Started Journal Service.
Aug 22 14:03:39 chuchel kernel: audit: type=1130 audit(1629605019.033:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 22 14:03:39 chuchel kernel: audit: type=1130 audit(1629605019.046:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 22 14:03:39 chuchel kernel: usb 3-3: New USB device found, idVendor=27c6, idProduct=533c, bcdDevice= 1.00
Aug 22 14:03:39 chuchel kernel: usb 3-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Aug 22 14:03:39 chuchel kernel: usb 3-3: Product: FingerPrint
Aug 22 14:03:39 chuchel kernel: usb 3-3: Manufacturer: Goodix
Aug 22 14:03:39 chuchel kernel: input: Intel HID events as /devices/platform/INTC1051:00/input/input4
Aug 22 14:03:39 chuchel kernel: intel-hid INTC1051:00: platform supports 5 button array
Aug 22 14:03:39 chuchel kernel: input: Intel HID 5 button array as /devices/platform/INTC1051:00/input/input5
Aug 22 14:03:39 chuchel kernel: random: crng init done
Aug 22 14:03:39 chuchel kernel: usb 3-6: new high-speed USB device number 3 using xhci_hcd
Aug 22 14:03:39 chuchel kernel: usb 3-6: New USB device found, idVendor=0c45, idProduct=672a, bcdDevice= 5.29
Aug 22 14:03:39 chuchel kernel: usb 3-6: New USB device strings: Mfr=2, Product=1, SerialNumber=0
Aug 22 14:03:39 chuchel kernel: usb 3-6: Product: Integrated_Webcam_HD
Aug 22 14:03:39 chuchel kernel: usb 3-6: Manufacturer: CN03GGY48LG000BEB0C3A00
Aug 22 14:03:39 chuchel kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 22 14:03:39 chuchel kernel: wmi_bus wmi_bus-PNP0C14:02: WQBC data block query control method not found
Aug 22 14:03:39 chuchel kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 22 14:03:39 chuchel kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 22 14:03:39 chuchel kernel: acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 22 14:03:39 chuchel kernel: acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 22 14:03:39 chuchel kernel: acpi PNP0C14:06: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 22 14:03:39 chuchel kernel: acpi PNP0C14:07: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Aug 22 14:03:39 chuchel kernel: intel-pmt 0000:00:0a.0: Watcher not supported
Aug 22 14:03:39 chuchel kernel: intel-pmt 0000:00:0a.0: Crashlog not supported
Aug 22 14:03:39 chuchel kernel: tpm_tis STM0125:00: 2.0 TPM (device-id 0x0, rev-id 78)
Aug 22 14:03:39 chuchel kernel: Bluetooth: Core ver 2.22
Aug 22 14:03:39 chuchel kernel: NET: Registered PF_BLUETOOTH protocol family
Aug 22 14:03:39 chuchel kernel: Bluetooth: HCI device and connection manager initialized
Aug 22 14:03:39 chuchel kernel: Bluetooth: HCI socket layer initialized
Aug 22 14:03:39 chuchel kernel: Bluetooth: L2CAP socket layer initialized
Aug 22 14:03:39 chuchel kernel: Bluetooth: SCO socket layer initialized
Aug 22 14:03:39 chuchel kernel: Linux agpgart interface v0.103
Aug 22 14:03:39 chuchel kernel: proc_thermal 0000:00:04.0: enabling device (0000 -> 0002)
Aug 22 14:03:39 chuchel kernel: intel_rapl_common: Found RAPL domain package
Aug 22 14:03:39 chuchel kernel: ACPI: bus type thunderbolt registered
Aug 22 14:03:39 chuchel kernel: Bluetooth: HCI UART driver ver 2.3
Aug 22 14:03:39 chuchel kernel: Bluetooth: HCI UART protocol H4 registered
Aug 22 14:03:39 chuchel kernel: Bluetooth: HCI UART protocol BCSP registered
Aug 22 14:03:39 chuchel kernel: Bluetooth: HCI UART protocol LL registered
Aug 22 14:03:39 chuchel kernel: Bluetooth: HCI UART protocol ATH3K registered
Aug 22 14:03:39 chuchel kernel: Bluetooth: HCI UART protocol Three-wire (H5) registered
Aug 22 14:03:39 chuchel kernel: Bluetooth: HCI UART protocol Intel registered
Aug 22 14:03:39 chuchel kernel: Bluetooth: HCI UART protocol Broadcom registered
Aug 22 14:03:39 chuchel kernel: Bluetooth: HCI UART protocol QCA registered
Aug 22 14:03:39 chuchel kernel: Bluetooth: HCI UART protocol AG6XX registered
Aug 22 14:03:39 chuchel kernel: Bluetooth: HCI UART protocol Marvell registered
Aug 22 14:03:39 chuchel kernel: intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
Aug 22 14:03:39 chuchel kernel: idma64 idma64.0: Found Intel integrated DMA 64-bit
Aug 22 14:03:39 chuchel kernel: intel-lpss 0000:00:15.1: enabling device (0000 -> 0002)
Aug 22 14:03:39 chuchel kernel: idma64 idma64.1: Found Intel integrated DMA 64-bit
Aug 22 14:03:39 chuchel kernel: mei_me 0000:00:16.0: enabling device (0000 -> 0002)
Aug 22 14:03:39 chuchel kernel: intel-lpss 0000:00:19.0: enabling device (0000 -> 0002)
Aug 22 14:03:39 chuchel kernel: idma64 idma64.2: Found Intel integrated DMA 64-bit
Aug 22 14:03:39 chuchel kernel: input: WCOM49B2:00 056A:49B2 Touchscreen as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-0/i2c-WCOM49B2:00/0018:056A:49B2.0001/input/input6
Aug 22 14:03:39 chuchel kernel: input: WCOM49B2:00 056A:49B2 as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-0/i2c-WCOM49B2:00/0018:056A:49B2.0001/input/input7
Aug 22 14:03:39 chuchel kernel: hid-generic 0018:056A:49B2.0001: input,hidraw0: I2C HID v1.00 Device [WCOM49B2:00 056A:49B2] on i2c-WCOM49B2:00
Aug 22 14:03:39 chuchel kernel: intel-lpss 0000:00:19.1: enabling device (0000 -> 0002)
Aug 22 14:03:39 chuchel kernel: idma64 idma64.3: Found Intel integrated DMA 64-bit
Aug 22 14:03:39 chuchel kernel: checking generic (4000000000 1c80000) vs hw (6054000000 1000000)
Aug 22 14:03:39 chuchel kernel: checking generic (4000000000 1c80000) vs hw (4000000000 10000000)
Aug 22 14:03:39 chuchel kernel: fb0: switching to inteldrmfb from EFI VGA
Aug 22 14:03:39 chuchel kernel: Console: switching to colour dummy device 80x25
Aug 22 14:03:39 chuchel kernel: i915 0000:00:02.0: vgaarb: deactivate vga console
Aug 22 14:03:39 chuchel kernel: input: DLL0945:00 06CB:CDE6 Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-DLL0945:00/0018:06CB:CDE6.0002/input/input8
Aug 22 14:03:39 chuchel kernel: i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
Aug 22 14:03:39 chuchel kernel: input: DLL0945:00 06CB:CDE6 Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-DLL0945:00/0018:06CB:CDE6.0002/input/input9
Aug 22 14:03:39 chuchel kernel: hid-generic 0018:06CB:CDE6.0002: input,hidraw1: I2C HID v1.00 Mouse [DLL0945:00 06CB:CDE6] on i2c-DLL0945:00
Aug 22 14:03:39 chuchel kernel: i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/tgl_dmc_ver2_08.bin (v2.8)
Aug 22 14:03:40 chuchel kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
Aug 22 14:03:40 chuchel kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Aug 22 14:03:40 chuchel kernel: i801_smbus 0000:00:1f.4: enabling device (0000 -> 0003)
Aug 22 14:03:40 chuchel kernel: i801_smbus 0000:00:1f.4: SPD Write Disable is set
Aug 22 14:03:40 chuchel kernel: i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
Aug 22 14:03:40 chuchel kernel: intel-lpss 0000:00:1e.0: enabling device (0000 -> 0002)
Aug 22 14:03:40 chuchel kernel: idma64 idma64.4: Found Intel integrated DMA 64-bit
Aug 22 14:03:40 chuchel kernel: intel-spi 0000:00:1f.5: unrecognized JEDEC id bytes: 20 60 19 20 60 19
Aug 22 14:03:40 chuchel kernel: intel-spi 0000:00:1f.5: failed to locate the chip
Aug 22 14:03:40 chuchel kernel: intel-spi: probe of 0000:00:1f.5 failed with error -2
Aug 22 14:03:40 chuchel kernel: loop: module loaded
Aug 22 14:03:40 chuchel kernel: loop0: detected capacity change from 0 to 8
Aug 22 14:03:40 chuchel kernel: input: PC Speaker as /devices/platform/pcspkr/input/input11
Aug 22 14:03:40 chuchel kernel: i2c i2c-13: 8/8 memory slots populated (from DMI)
Aug 22 14:03:40 chuchel kernel: i2c i2c-13: Systems with more than 4 memory slots not supported yet, not instantiating SPD
Aug 22 14:03:40 chuchel kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher
Aug 22 14:03:40 chuchel kernel: ath11k_pci 0000:71:00.0: BAR 0: assigned [mem 0xa6100000-0xa61fffff 64bit]
Aug 22 14:03:40 chuchel kernel: ath11k_pci 0000:71:00.0: enabling device (0000 -> 0002)
Aug 22 14:03:40 chuchel kernel: ath11k_pci 0000:71:00.0: qca6390 hw2.0
Aug 22 14:03:40 chuchel kernel: NET: Registered PF_QIPCRTR protocol family
Aug 22 14:03:40 chuchel kernel: resource sanity check: requesting [mem 0xfedc0000-0xfedcdfff], which spans more than pnp 00:05 [mem 0xfedc0000-0xfedc7fff]
Aug 22 14:03:40 chuchel kernel: caller tgl_uncore_imc_freerunning_init_box+0xbf/0x100 [intel_uncore] mapping multiple BARs
Aug 22 14:03:40 chuchel kernel: cryptd: max_cpu_qlen set to 1000
Aug 22 14:03:40 chuchel kernel: mhi mhi0: Requested to power ON
Aug 22 14:03:40 chuchel kernel: mhi mhi0: Power on setup success
Aug 22 14:03:40 chuchel kernel: AVX2 version of gcm_enc/dec engaged.
Aug 22 14:03:40 chuchel kernel: snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
Aug 22 14:03:40 chuchel kernel: snd_hda_intel 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
Aug 22 14:03:40 chuchel kernel: AES CTR mode by8 optimization enabled
Aug 22 14:03:40 chuchel kernel: mhi mhi0: Wait for device to enter SBL or Mission mode
Aug 22 14:03:40 chuchel kernel: intel_tcc_cooling: Programmable TCC Offset detected
Aug 22 14:03:40 chuchel kernel: input: Dell WMI hotkeys as /devices/platform/PNP0C14:02/wmi_bus/wmi_bus-PNP0C14:02/PNP0C14:02-9DBB5994-A997-11DA-B012-B622A1EF5492/input/input13
Aug 22 14:03:40 chuchel kernel: intel_rapl_msr: PL4 support detected.
Aug 22 14:03:40 chuchel kernel: intel_rapl_common: Found RAPL domain package
Aug 22 14:03:40 chuchel kernel: intel_rapl_common: Found RAPL domain core
Aug 22 14:03:40 chuchel kernel: intel_rapl_common: Found RAPL domain uncore
Aug 22 14:03:40 chuchel kernel: intel_rapl_common: Found RAPL domain psys
Aug 22 14:03:40 chuchel kernel: usbcore: registered new interface driver usbhid
Aug 22 14:03:40 chuchel kernel: usbhid: USB HID core driver
Aug 22 14:03:40 chuchel kernel: iTCO_vendor_support: vendor-support=0
Aug 22 14:03:40 chuchel kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
Aug 22 14:03:40 chuchel kernel: input: DLL0945:00 06CB:CDE6 Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-DLL0945:00/0018:06CB:CDE6.0002/input/input14
Aug 22 14:03:40 chuchel kernel: input: DLL0945:00 06CB:CDE6 Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-DLL0945:00/0018:06CB:CDE6.0002/input/input15
Aug 22 14:03:40 chuchel kernel: hid-multitouch 0018:06CB:CDE6.0002: input,hidraw1: I2C HID v1.00 Mouse [DLL0945:00 06CB:CDE6] on i2c-DLL0945:00
Aug 22 14:03:40 chuchel kernel: ish-hid {33AECD58-B679-4E54-9BD9-A04D34F0C226}: [hid-ish]: enum_devices_done OK, num_hid_devices=1
Aug 22 14:03:40 chuchel kernel: iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
Aug 22 14:03:40 chuchel kernel: iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
Aug 22 14:03:40 chuchel kernel: hid-generic 001F:8087:0AC2.0003: hidraw2: <UNKNOWN> HID v2.00 Device [hid-ishtp 8087:0AC2] on
Aug 22 14:03:40 chuchel kernel: qcom_mhi_qrtr: probe of mhi0_IPCR failed with error -22
Aug 22 14:03:40 chuchel kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
Aug 22 14:03:40 chuchel kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
Aug 22 14:03:40 chuchel kernel: mousedev: PS/2 mouse device common for all mice
Aug 22 14:03:40 chuchel kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: enabling device (0000 -> 0002)
Aug 22 14:03:40 chuchel kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if 0x040100
Aug 22 14:03:40 chuchel kernel: dw-apb-uart.4: ttyS4 at MMIO 0x4017004000 (irq = 16, base_baud = 6250000) is a 16550A
Aug 22 14:03:40 chuchel kernel: input: Wacom HID 49B2 Finger as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-0/i2c-WCOM49B2:00/0018:056A:49B2.0001/input/input18
Aug 22 14:03:40 chuchel kernel: wacom 0018:056A:49B2.0001: hidraw0: I2C HID v1.00 Device [WCOM49B2:00 056A:49B2] on i2c-WCOM49B2:00
Aug 22 14:03:40 chuchel kernel: hci_uart_qca serial0-0: failed to acquire enable gpio
Aug 22 14:03:40 chuchel kernel: serial serial0: tty port ttyS4 registered
Aug 22 14:03:40 chuchel kernel: Bluetooth: hci0: setting up ROME/QCA6390
Aug 22 14:03:40 chuchel kernel: Bluetooth: hci0: Frame reassembly failed (-84)
Aug 22 14:03:40 chuchel kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Aug 22 14:03:40 chuchel kernel: Bluetooth: BNEP filters: protocol multicast
Aug 22 14:03:40 chuchel kernel: Bluetooth: BNEP socket layer initialized
Aug 22 14:03:40 chuchel kernel: bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Aug 22 14:03:40 chuchel kernel: Bridge firewalling registered
Aug 22 14:03:41 chuchel kernel: mc: Linux media interface: v0.10
Aug 22 14:03:41 chuchel kernel: videodev: Linux video capture interface: v2.00
Aug 22 14:03:41 chuchel kernel: usb 3-6: Found UVC 1.00 device Integrated_Webcam_HD (0c45:672a)
Aug 22 14:03:41 chuchel kernel: input: Integrated_Webcam_HD: Integrate as /devices/pci0000:00/0000:00:14.0/usb3/3-6/3-6:1.0/input/input20
Aug 22 14:03:41 chuchel kernel: input: Integrated_Webcam_HD: Integrate as /devices/pci0000:00/0000:00:14.0/usb3/3-6/3-6:1.2/input/input21
Aug 22 14:03:41 chuchel kernel: usbcore: registered new interface driver uvcvideo
Aug 22 14:03:41 chuchel kernel: [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 0
Aug 22 14:03:41 chuchel kernel: ACPI: video: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
Aug 22 14:03:41 chuchel kernel: Bluetooth: hci0: QCA Product ID   :0x00000010
Aug 22 14:03:41 chuchel kernel: Bluetooth: hci0: QCA SOC Version  :0x400a0200
Aug 22 14:03:41 chuchel kernel: Bluetooth: hci0: QCA ROM Version  :0x00000200
Aug 22 14:03:41 chuchel kernel: Bluetooth: hci0: QCA Patch Version:0x00000d2b
Aug 22 14:03:41 chuchel kernel: Bluetooth: hci0: QCA controller version 0x02000200
Aug 22 14:03:41 chuchel kernel: Bluetooth: hci0: QCA Downloading qca/htbtfw20.tlv
Aug 22 14:03:41 chuchel kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input22
Aug 22 14:03:41 chuchel kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
Aug 22 14:03:41 chuchel kernel: fbcon: i915 (fb0) is primary device
Aug 22 14:03:41 chuchel kernel: Console: switching to colour frame buffer device 216x67
Aug 22 14:03:41 chuchel kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: use msi interrupt mode
Aug 22 14:03:41 chuchel kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: hda codecs found, mask 5
Aug 22 14:03:41 chuchel kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: using HDA machine driver skl_hda_dsp_generic now
Aug 22 14:03:41 chuchel kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: DMICs detected in NHLT tables: 2
Aug 22 14:03:41 chuchel kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware info: version 1:8:0-9e7a8
Aug 22 14:03:41 chuchel kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: Firmware: ABI 3:18:1 Kernel ABI 3:18:0
Aug 22 14:03:41 chuchel kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: unknown sof_ext_man header type 3 size 0x30
Aug 22 14:03:41 chuchel kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: Topology: ABI 3:18:1 Kernel ABI 3:18:0
Aug 22 14:03:41 chuchel kernel: sof-audio-pci-intel-tgl 0000:00:1f.3: ASoC: Parent card not yet available, widget card binding deferred
Aug 22 14:03:41 chuchel kernel: snd_hda_codec_realtek ehdaudio0D0: autoconfig for ALC289: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
Aug 22 14:03:41 chuchel kernel: snd_hda_codec_realtek ehdaudio0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
Aug 22 14:03:41 chuchel kernel: snd_hda_codec_realtek ehdaudio0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
Aug 22 14:03:41 chuchel kernel: snd_hda_codec_realtek ehdaudio0D0:    mono: mono_out=0x0
Aug 22 14:03:41 chuchel kernel: snd_hda_codec_realtek ehdaudio0D0:    inputs:
Aug 22 14:03:41 chuchel kernel: snd_hda_codec_realtek ehdaudio0D0:      Headset Mic=0x19
Aug 22 14:03:41 chuchel kernel: snd_hda_codec_realtek ehdaudio0D0:      Headphone Mic=0x1b
Aug 22 14:03:41 chuchel kernel: i915 0000:00:02.0: [drm] fb0: i915 frame buffer device
Aug 22 14:03:42 chuchel kernel: Bluetooth: hci0: QCA Downloading qca/htnv20.bin
Aug 22 14:03:42 chuchel kernel: snd_hda_codec_realtek ehdaudio0D0: ASoC: sink widget AIF1TX overwritten
Aug 22 14:03:42 chuchel kernel: snd_hda_codec_realtek ehdaudio0D0: ASoC: source widget AIF1RX overwritten
Aug 22 14:03:42 chuchel kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi3 overwritten
Aug 22 14:03:42 chuchel kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi2 overwritten
Aug 22 14:03:42 chuchel kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi1 overwritten
Aug 22 14:03:42 chuchel kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Codec Output Pin1 overwritten
Aug 22 14:03:42 chuchel kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Codec Input Pin1 overwritten
Aug 22 14:03:42 chuchel kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Analog Codec Playback overwritten
Aug 22 14:03:42 chuchel kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Digital Codec Playback overwritten
Aug 22 14:03:42 chuchel kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Alt Analog Codec Playback overwritten
Aug 22 14:03:42 chuchel kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Analog Codec Capture overwritten
Aug 22 14:03:42 chuchel kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Digital Codec Capture overwritten
Aug 22 14:03:42 chuchel kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Alt Analog Codec Capture overwritten
Aug 22 14:03:42 chuchel kernel: skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 3
Aug 22 14:03:42 chuchel kernel: skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 4
Aug 22 14:03:42 chuchel kernel: skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 5
Aug 22 14:03:42 chuchel kernel: skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 6
Aug 22 14:03:42 chuchel kernel: skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 7
Aug 22 14:03:42 chuchel kernel: skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 8
Aug 22 14:03:42 chuchel kernel: input: sof-hda-dsp Headphone Mic as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input23
Aug 22 14:03:42 chuchel kernel: input: sof-hda-dsp HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input24
Aug 22 14:03:42 chuchel kernel: input: sof-hda-dsp HDMI/DP,pcm=4 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input25
Aug 22 14:03:42 chuchel kernel: input: sof-hda-dsp HDMI/DP,pcm=5 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input26
Aug 22 14:03:42 chuchel kernel: Bluetooth: hci0: QCA setup on UART is completed
Aug 22 14:03:42 chuchel kernel: NET: Registered PF_ALG protocol family
Aug 22 14:03:42 chuchel kernel: kauditd_printk_skb: 173 callbacks suppressed
Aug 22 14:03:42 chuchel kernel: audit: type=1100 audit(1629605022.793:100): pid=1252 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Aug 22 14:03:42 chuchel kernel: audit: type=1101 audit(1629605022.793:101): pid=1252 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Aug 22 14:03:42 chuchel kernel: audit: type=1103 audit(1629605022.793:102): pid=1252 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Aug 22 14:03:42 chuchel kernel: audit: type=1130 audit(1629605022.843:103): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@965 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 22 14:03:42 chuchel kernel: audit: type=1101 audit(1629605022.846:104): pid=1254 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 22 14:03:42 chuchel kernel: audit: type=1103 audit(1629605022.846:105): pid=1254 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Aug 22 14:03:42 chuchel kernel: audit: type=1006 audit(1629605022.846:106): pid=1254 uid=0 subj==unconfined old-auid=4294967295 auid=965 tty=(none) old-ses=4294967295 ses=1 res=1
Aug 22 14:03:42 chuchel kernel: audit: type=1300 audit(1629605022.846:106): arch=c000003e syscall=1 success=yes exit=3 a0=9 a1=7ffd7766fcd0 a2=3 a3=3c5 items=0 ppid=1 pid=1254 auid=965 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd" subj==unconfined key=(null)
Aug 22 14:03:42 chuchel kernel: audit: type=1327 audit(1629605022.846:106): proctitle="(systemd)"
Aug 22 14:03:42 chuchel kernel: audit: type=1105 audit(1629605022.849:107): pid=1254 uid=0 auid=965 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 22 14:03:44 chuchel kernel: Bluetooth: Received HCI_IBS_WAKE_ACK in tx state 0
Aug 22 14:03:48 chuchel kernel: kauditd_printk_skb: 33 callbacks suppressed
Aug 22 14:03:48 chuchel kernel: audit: type=1130 audit(1629605028.446:133): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 22 14:03:48 chuchel kernel: Bluetooth: RFCOMM TTY layer initialized
Aug 22 14:03:48 chuchel kernel: Bluetooth: RFCOMM socket layer initialized
Aug 22 14:03:48 chuchel kernel: Bluetooth: RFCOMM ver 1.11
Aug 22 14:03:50 chuchel kernel: audit: type=1131 audit(1629605030.193:134): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 22 14:03:57 chuchel kernel: audit: type=1131 audit(1629605037.796:135): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@965 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 22 14:03:57 chuchel kernel: audit: type=1131 audit(1629605037.816:136): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@965 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 22 14:04:02 chuchel kernel: audit: type=1100 audit(1629605042.286:137): pid=1723 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="pondreed" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Aug 22 14:04:02 chuchel kernel: audit: type=1101 audit(1629605042.286:138): pid=1723 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="pondreed" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Aug 22 14:04:02 chuchel kernel: audit: type=1110 audit(1629605042.286:139): pid=1723 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Aug 22 14:04:02 chuchel kernel: audit: type=1105 audit(1629605042.289:140): pid=1723 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Aug 22 14:04:02 chuchel kernel: audit: type=1106 audit(1629605042.303:141): pid=1723 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Aug 22 14:04:02 chuchel kernel: audit: type=1104 audit(1629605042.303:142): pid=1723 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Aug 22 14:04:09 chuchel kernel: Bluetooth: hci0: QCA collecting dump of size:458752
Aug 22 14:04:17 chuchel kernel: Bluetooth: hci0: Injecting HCI hardware error event
Aug 22 14:04:36 chuchel kernel: watchdog: BUG: soft lockup - CPU#6 stuck for 26s! [swapper/6:0]
Aug 22 14:04:36 chuchel kernel: Modules linked in: rfcomm cmac algif_hash algif_skcipher af_alg snd_ctl_led snd_soc_skl_hda_dsp snd_soc_intel_hda_dsp_common snd_soc_hdac_hdmi snd_hda_codec_hdmi snd_hda_codec_realtek snd_hda_codec_generic xt_conntrack uvcvideo xt_MASQUERADE videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 nf_conntrack_netlink videobuf2_common nfnetlink videodev xt_addrtype iptable_filter iptable_nat mc nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c br_netfilter bridge stp llc bnep overlay hid_sensor_als hid_sensor_trigger industrialio_triggered_buffer kfifo_buf hid_sensor_iio_common industrialio snd_soc_dmic joydev hid_sensor_hub snd_sof_pci_intel_tgl snd_sof_intel_hda_common qrtr_mhi cros_ec_ishtp cros_ec intel_ishtp_loader soundwire_intel mousedev iTCO_wdt intel_ishtp_hid 8250_dw wacom soundwire_generic_allocation intel_pmc_bxt soundwire_cadence iTCO_vendor_support hid_multitouch usbhid mei_hdcp snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp intel_pmt_telemetry
Aug 22 14:04:36 chuchel kernel:  intel_rapl_msr intel_pmt_class snd_sof dell_wmi snd_soc_hdac_hda intel_tcc_cooling x86_pkg_temp_thermal dell_laptop snd_hda_ext_core intel_powerclamp dell_smbios coretemp snd_soc_acpi_intel_match dcdbas dell_wmi_sysman snd_soc_acpi firmware_attributes_class dell_wmi_descriptor wmi_bmof dell_smm_hwmon kvm_intel soundwire_bus ledtrig_audio snd_soc_core kvm snd_compress ac97_bus snd_pcm_dmaengine irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi crypto_simd cryptd intel_cstate intel_uncore snd_hda_codec qrtr ns ath11k_pci psmouse ath11k snd_hda_core squashfs snd_hwdep pcspkr snd_pcm intel_spi_pci snd_timer qmi_helpers intel_spi spi_nor snd i2c_i801 mac80211 mtd i2c_smbus soundcore cfg80211 loop mhi libarc4 i915 mei_me vfat mei fat intel_lpss_pci intel_lpss idma64 i2c_algo_bit ttm intel_ish_ipc intel_ishtp drm_kms_helper thunderbolt hci_uart tpm_crb btqca cec btrtl btbcm intel_gtt
Aug 22 14:04:36 chuchel kernel:  processor_thermal_device_pci_legacy agpgart btintel processor_thermal_device processor_thermal_rfim syscopyarea processor_thermal_mbox processor_thermal_rapl sysfillrect intel_rapl_common sysimgblt intel_pmt bluetooth fb_sys_fops intel_soc_dts_iosf tpm_tis ucsi_acpi tpm_tis_core typec_ucsi tpm typec roles rng_core wmi mac_hid ecdh_generic rfkill ecc i2c_hid_acpi i2c_hid int3403_thermal int340x_thermal_zone intel_hid sparse_keymap video acpi_tad int3400_thermal acpi_pad acpi_thermal_rel uinput vboxnetflt(OE) vboxnetadp(OE) vboxdrv(OE) drm fuse sg crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 rtsx_pci_sdmmc mmc_core serio_raw atkbd libps2 crc32c_intel rtsx_pci xhci_pci i8042 serio vmd
Aug 22 14:04:36 chuchel kernel: CPU: 6 PID: 0 Comm: swapper/6 Tainted: G           OE     5.14.0-1-MANJARO #1
Aug 22 14:04:36 chuchel kernel: Hardware name: Dell Inc. XPS 13 9310/0DMPXV, BIOS 3.0.3 06/19/2021
Aug 22 14:04:36 chuchel kernel: RIP: 0010:__do_softirq+0x79/0x2b4
Aug 22 14:04:36 chuchel kernel: Code: 81 67 2c ff f7 ff ff be 00 01 00 00 e8 a0 0e 2d ff c7 44 24 10 0a 00 00 00 65 66 c7 05 4e c5 02 60 00 00 fb 66 0f 1f 44 00 00 <b8> ff ff ff ff 49 c7 c3 c0 60 c0 a0 41 0f bc c7 89 c5 83 c5 01 74
Aug 22 14:04:36 chuchel kernel: RSP: 0018:ffffb4b080300fa0 EFLAGS: 00000246
Aug 22 14:04:36 chuchel kernel: RAX: 0000000000000000 RBX: 0000000000000000 RCX: 000000000000001f
Aug 22 14:04:36 chuchel kernel: RDX: 0000000000000025 RSI: 000000002abc2bc2 RDI: fffffffd6ad700c4
Aug 22 14:04:36 chuchel kernel: RBP: ffffb4b08018bdf8 R08: 00000007c52cb161 R09: ffff8e6519881900
Aug 22 14:04:36 chuchel kernel: R10: 0000000000000040 R11: 0000000000000000 R12: 0000000000000025
Aug 22 14:04:36 chuchel kernel: R13: 0000000000000001 R14: 0000000000000000 R15: 0000000000000040
Aug 22 14:04:36 chuchel kernel: FS:  0000000000000000(0000) GS:ffff8e6c6f780000(0000) knlGS:0000000000000000
Aug 22 14:04:36 chuchel kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Aug 22 14:04:36 chuchel kernel: CR2: 00007f90a08c9ec0 CR3: 00000007afc10002 CR4: 0000000000770ee0
Aug 22 14:04:36 chuchel kernel: PKRU: 55555554
Aug 22 14:04:36 chuchel kernel: Call Trace:
Aug 22 14:04:36 chuchel kernel:  <IRQ>
Aug 22 14:04:36 chuchel kernel:  irq_exit_rcu+0xa9/0xc0
Aug 22 14:04:36 chuchel kernel:  common_interrupt+0x83/0xa0
Aug 22 14:04:36 chuchel kernel:  </IRQ>
Aug 22 14:04:36 chuchel kernel:  asm_common_interrupt+0x1e/0x40
Aug 22 14:04:36 chuchel kernel: RIP: 0010:cpuidle_enter_state+0xc7/0x380
Aug 22 14:04:36 chuchel kernel: Code: 8b 3d e5 b3 5e 60 e8 a8 a9 8a ff 49 89 c5 0f 1f 44 00 00 31 ff e8 c9 b6 8a ff 45 84 ff 0f 85 da 01 00 00 fb 66 0f 1f 44 00 00 <45> 85 f6 0f 88 11 01 00 00 49 63 d6 4c 2b 2c 24 48 8d 04 52 48 8d
Aug 22 14:04:36 chuchel kernel: RSP: 0018:ffffb4b08018bea8 EFLAGS: 00000246
Aug 22 14:04:36 chuchel kernel: RAX: ffff8e6c6f7ace00 RBX: 0000000000000001 RCX: 000000000000001f
Aug 22 14:04:36 chuchel kernel: RDX: 0000000000000000 RSI: 000000002abc2bc2 RDI: 0000000000000000
Aug 22 14:04:36 chuchel kernel: RBP: ffff8e6c6f7b7f00 R08: 00000007c509400d R09: 0000000000000018
Aug 22 14:04:36 chuchel kernel: R10: 00000000000001af R11: 0000000000000279 R12: ffffffffa0d47d00
Aug 22 14:04:36 chuchel kernel: R13: 00000007c509400d R14: 0000000000000001 R15: 0000000000000000
Aug 22 14:04:36 chuchel kernel:  ? cpuidle_enter_state+0xb7/0x380
Aug 22 14:04:36 chuchel kernel:  cpuidle_enter+0x29/0x40
Aug 22 14:04:36 chuchel kernel:  do_idle+0x1e1/0x270
Aug 22 14:04:36 chuchel kernel:  cpu_startup_entry+0x19/0x20
Aug 22 14:04:36 chuchel kernel:  secondary_startup_64_no_verify+0xc2/0xcb
Aug 22 14:04:36 chuchel kernel: audit: type=1131 audit(1629605076.739:143): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 22 14:04:36 chuchel kernel: audit: type=1334 audit(1629605076.906:144): prog-id=16 op=UNLOAD
Aug 22 14:04:36 chuchel kernel: audit: type=1334 audit(1629605076.906:145): prog-id=15 op=UNLOAD
Aug 22 14:04:36 chuchel kernel: audit: type=1334 audit(1629605076.906:146): prog-id=14 op=UNLOAD
Aug 22 14:04:40 chuchel kernel: Bluetooth: hci0: Frame reassembly failed (-84)
Aug 22 14:04:43 chuchel kernel: ucsi_acpi USBC000:00: ucsi_handle_connector_change: GET_CONNECTOR_STATUS failed (-110)
Aug 22 14:04:57 chuchel kernel: Bluetooth: hci0: Frame reassembly failed (-84)
Aug 22 14:04:58 chuchel kernel: Bluetooth: hci0: Frame reassembly failed (-84)
Please read this:
especially the section “What’s this upstream and downstream business” and then file a bug upstream…
:+1:
I’ve heard that it is unwise to use RC kernels. They tend to break things that worked fine in an older kernel. I recommend using the latest Manjaro kernel which is now 5.13 or use the last LTS kernel which is 5.10 if I remember correctly.
Everything I have read elsewhere, including the linux bugzilla itself, says report bugs to the distro unless you are using an upstream kernel. I am not, I am using a manjaro kernel that has some [unrelated] patches applied to it.
Given that this hasn’t attracted any attention here, I think I will just contact the driver developers directly as this hasn’t been fixed in rc7 either.
as the thread links here, but not in reverse - this was discussed at lore kernel org in “[regression] Re: 5.14 rc6 broken for QCA6390 on Dell XPS 13 9310” and fixed before the final 5.14 release
Can’t find that, so please read this:
:+1:
