I recently installed Linux Mint Cinnamon 20 on top of Manjaro KDE 20 and i had to partition my drives and a gave Mint 56GB and Manjaro was left with about 423GB.
The system boots into Mint fine but however when i try to boot into Manjaro it fails. It gives the error:
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
CPU: 1 PID: 1 Comm: swapper/0 Not tainted 5.7.14-1-Manjaro #1
Hardware name: Hewlette-Packard HP 255 G3 Notebook PC/21F7, BIOS F.48 04/16/2018
Call Trace
dump_stack+0x64/0x88
panic+0x112/0x2e8
mount_block_root+0x317/0x326
prepare_namespace+0x136/0x165
? rest_init+0xbf/0xbf
kernel_init+0xa/0x101
ret_from_fork+0x22/0x40
Kernel Offset: 0xbe00000 from 0xffffffff81000000 (relocation range: 0xffffffff-0xfffffffbfffffff)
---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
Use a Manjaro live ISO, boot into it in the same mode as your install (BIOS or UEFI) and enter
sudo manjaro-chroot -a
Select the Manjaro install, if only one line is offered enter: 1
Enter
parted -l
lsblk -f
ls -la /boot
efibootmgr -v
Copy the output here to the forum. Then leave chroot and terminal by
exit
exit
This allows us to determine how to re-install the grub bootloader from Manjaro. manjaro can boot Mint but Mint cannot (easily) boot Manjaro. Therefore best procedure is to re-install grub from Manjaro and then to enter sudo update grub to have the option to boot both OS from Manjaro’s grub menu.
total 94492
drwxr-xr-x 5 root root 4096 Aug 20 19:58 .
drwxr-xr-x 17 root root 4096 Sep 1 12:05 ..
drwxr-xr-x 3 root root 4096 Jan 1 1970 efi
drwxr-xr-x 5 root root 4096 Aug 20 19:59 grub
-rw-r--r-- 1 root root 30835186 Aug 20 19:57 initramfs-5.6-x86_64-fallback.img
-rw-r--r-- 1 root root 9127403 Aug 20 19:56 initramfs-5.6-x86_64.img
-rw-r--r-- 1 root root 30982431 Aug 20 19:58 initramfs-5.7-x86_64-fallback.img
-rw-r--r-- 1 root root 9128007 Aug 20 19:58 initramfs-5.7-x86_64.img
-rw-r--r-- 1 root root 3161088 Jun 16 19:50 intel-ucode.img
-rw-r--r-- 1 root root 21 Jun 18 00:24 linux56-x86_64.kver
-rw-r--r-- 1 root root 21 Aug 7 12:11 linux57-x86_64.kver
drwxr-xr-x 2 root root 4096 Jun 6 10:03 memtest86+
-rw-r--r-- 1 root root 6795040 Jul 21 01:29 vmlinuz-5.6-x86_64
-rw-r--r-- 1 root root 6680800 Aug 20 19:56 vmlinuz-5.7-x86_64
output of efibootmgr -v
BootCurrent: 0002
Timeout: 0 seconds
BootOrder: 0003,0000,3000,0001,2001,2002,2003
Boot0000* ubuntu HD(4,GPT,24bcaf0e-df38-4b79-9fbe-43319de95511,0x33a6e800,0x100000)/File(\EFI\ubuntu\shimx64.efi)
Boot0001* EFI HDD Device (TOSHIBA MQ01ABD050V -63) PciRoot(0x0)/Pci(0x11,0x0)/Ata(0,0,0)/HD(1,GPT,6574a687-1ca8-ad48-accf-5d795d3f18c6,0x800,0x100000)RC
Boot0002* USB Hard Drive (UEFI) - Generic Flash Disk PciRoot(0x0)/Pci(0x12,0x2)/USB(0,0)/HD(1,MBR,0x0,0x5cf8f0,0x2000)RC
Boot0003* USB Entry for Windows To Go UsbClass(ffff,ffff,255,255)....&@.G...C..6.
Boot0009* Internal Hard Disk or Solid State Disk RC
Boot000A* Internal Hard Disk or Solid State Disk RC
Boot2001* USB Drive (UEFI) RC
Boot2002* Internal CD/DVD ROM Drive (UEFI) RC
Boot3000* Internal Hard Disk or Solid State Disk RC
Boot3001* Internal Hard Disk or Solid State Disk RC
Boot3002* Internal Hard Disk or Solid State Disk RC
Boot3004* Internal Hard Disk or Solid State Disk RC
Boot3005* Internal Hard Disk or Solid State Disk RC
You need to boot into your UEFI firmware. There is usual a config table you select the device to boot from. After successful re-install of grub from Manjaro you should see an entry with name “Manjaro” in it. make this your primary boot device and boot into it.
I used the Advanced Manjaro entry on the boot menu and from there i selected the fallback kernel and the system has successfully booted. Is there anything I can do now being in the system so that next time the default kernel should work
It could be that you have to change the boot flag. It’s currently set for sda4 but for Manjaro you use sda1. You could run a live ISO again, start GParted and change the boot flag to have it set on sda1 and removed on sda4. For the esp flag you can do the same.
Hi,
I have the same problem, but it started differently…
I was doing an update from the GUI when my battery went empty (now I know why they ask you on the phone to plug it in before updating)
Now my systems seems to be in a rather inconsistent state.
Trying reinstall a kernel from a live-system in a chroot with mhwd-kernel -i linux54
gives me the error that on trying to synchronize package databases that it cannot lock any of the databases:
error: failed to update core (unable to lock database)
error: failed to update extra (unable to lock database)
error: failed to update community (unable to lock database)
error: failed to update multilib (unable to lock database)
I have had kernel panic with both manjaro and slackware this week, and my search brought me here, where I really enjoyed reading TheWizard`s posts. Searching for solutions is painful work and it was refreshing to have some soft nice humor around.
I had faced this problem a couple years ago when I first tried Manjaro. and with the help of the venerable Goh Lip (hope I am not misspelling it) I solved it by chrooting in Manjaro from some Manjaro media and installing /updating grub, which gave me the bonus of a nicer-looking booting visual.
I have also “solved” it , or went around it, by editing a 40_custom file at /etc/grub.d, in the case of the distros I had booting in different cases.
I understand the custom.grub way is the more elegant one, but I wonder whether it can be used as a once for all with 2 distros.
Thanks for the good time I had reading the thread, which by the way I found way above the average in pedagogical terms - that is the subject I am best at.
Edit: Ooops! seems you had already answered my question here:
“Manjaro - Kernel Panics and Other Tips for Arch-based Distros”
