I am sorry. I must be very tired, I posted on wrong thread. Had to create new account in the process, the old one was not active anymore. Got mixed up. But it feels good to be back here.
Always use the latest version of grubā¦shouldāve installed Mint without grub installationā¦then in Manjaro just run update-grub
Hi there,
I recently had a similar problem. The solution I found was like @Wollie already wrote to reinstall the kernel. However, I was not able to reinstall it since the error message no target specified
showed up. The solution for this error message is to manually force pacman to reinstall the kernel via pacman -S --overwrite "*" linux510
. AFAIK the package might be broken after the update, so you have to reinstall it. After that a simple update-grub
should fix the problem.
