Kernel update issues
Kernel 5.10.126-1 runs perfectly on my system and is rock solid.
If I install any later kernel, I can log in but as soon as I open any applications the computer crashes.
AMD Ryzen 2600X CPU and AMD Radeon 570 GPU .
What I have tried:
  1. Changed boot options iommu=pt or soft, idle=nomwait and several others
  2. Disabled C6 states
  3. Set bios power supply idle control to Typical current idle
  4. Replace motherboard; now using ASUS TUF X570
  5. Replaced RAM
  6. Replaced SSD drive
  7. Replaced PSU
Nothing I do seems to make any difference.
The computer runs perfectly with Windows.
Any suggestions?
Please let me know if you need more information; I can not provide log files as the computer has to be power cycled to restart.
After many hours of searching I discovered that this is an AMD Radeon driver problem and not a kernel problem.
Don’t know why it works with kernel 5.10.
To solve change grub line GRUB_CMDLINE_LINUX_DEFAULT to the following: GRUB_CMDLINE_LINUX_DEFAULT=“quiet apparmor=1 security=apparmor udev.log_priority=3 radeon.modeset=0 amdgpu.aspm=0 amdgpu.dpm=0 pcie.aspm=off”
Running 5.15 LTS without any further problems.
Hope this can help somebody.
but with the crashing kernel, then boot with the stable 5.10 kernel and provide log from the crashed session:
journalctl -b-1 -p5 --no-pager
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information. [HowTo] Provide System Information
  2. Please press the three dots … below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
**inxi --admin --verbosity=7 --filter --no-host --width info**
  Kernel: 5.10.126-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
    root=UUID=8eb9bda3-0538-46d2-be29-ff603d3428a5 rw quiet apparmor=1
    security=apparmor udev.log_priority=3 idle=nomwait iommu=soft
  Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
    v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
  Mobo: ASUSTeK model: TUF GAMING X570-PRO WIFI II v: Rev X.0x
    serial: <superuser required> UEFI: American Megatrends v: 4403
    date: 04/27/2022
  RAM: total: 31.27 GiB used: 1.78 GiB (5.7%)
  RAM Report:
  Info: model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+ gen: 2
    built: 2018-21 process: GF 12nm family: 0x17 (23) model-id: 8 stepping: 2
    microcode: 0x800820D
    L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB desc: 6x512 KiB
    L3: 16 MiB desc: 2x8 MiB
  Speed (MHz): avg: 2460 high: 3805 min/max: 2200/3800 boost: disabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3805 2: 2182
    3: 2178 4: 2201 5: 2200 6: 2199 7: 3802 8: 2167 9: 2178 10: 2200 11: 2212
    12: 2197 bogomips: 91244
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
    fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm
    mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
    nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
    pse36 rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca
    sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock
    syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
    vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
  Type: spectre_v2
    mitigation: Retpolines, IBPB: conditional, STIBP: disabled, RSB filling
  Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
    vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN 4 process: GF 14nm
    built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
    active: DP-1,HDMI-A-1 empty: DP-2,DVI-D-1,HDMI-A-2 bus-ID: 09:00.0
    chip-ID: 1002:67df class-ID: 0300
  Display: x11 server: X.Org v: 21.1.3 compositor: xfwm v: 4.16.1 driver: X:
    loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
    display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
    s-diag: 1055mm (41.54")
  Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,left model: Dell P2214H
    serial: <filter> built: 2015 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
    size: 477x268mm (18.78x10.55") diag: 547mm (21.5") ratio: 16:9 modes:
    max: 1920x1080 min: 720x400
  Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: right model: Dell SE2717H/HX
    serial: <filter> built: 2018 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
    size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9 modes:
  Message: Unable to show GL data. Required tool glxinfo missing.
  Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 09:00.1
    chip-ID: 1002:aaf0 class-ID: 0403
  Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0b:00.3
    chip-ID: 1022:1457 class-ID: 0403
  Sound Server-1: ALSA v: k5.10.126-1-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.52 running: yes
  Device-1: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: N/A pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 14c3:0608 class-ID: 0280
  Device-2: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 05:00.0
    chip-ID: 8086:15f3 class-ID: 0200
  IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: MediaTek Wireless_Device type: USB driver: btusb v: 0.8
    bus-ID: 1-4:3 chip-ID: 0e8d:0608 class-ID: e001 serial: <filter>
  Local Storage: total: 3.43 TiB used: 26.4 GiB (0.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: HP model: SSD EX900 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 type: SSD serial: <filter> rev: R1115D0 temp: 33.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD20EZRX-00D8PB0 size: 1.82 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
    rev: 0A80 scheme: MBR
  ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD5000BUCT-63PUZY0 size: 465.76 GiB block-size: physical: 4096 B
    logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter>
    rev: 1A01 scheme: MBR
  ID-4: /dev/sdc maj-min: 8:32 vendor: Hikvision model: HS-SSD-E100 1024G
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: 8A0 scheme: MBR
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH24NSD5 rev: LV00
    dev-links: cdrom
  Features: speed: 12 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 292.97 GiB size: 292.83 GiB (99.95%)
    used: 14.45 GiB (4.9%) fs: xfs dev: /dev/sdc2 maj-min: 8:34 label: N/A
    uuid: 8eb9bda3-0538-46d2-be29-ff603d3428a5
  ID-2: /boot/efi raw-size: 33 MiB size: 32.5 MiB (98.34%)
    used: 285 KiB (0.9%) fs: vfat dev: /dev/sdc1 maj-min: 8:33 label: N/A
    uuid: 8308-4D5D
  ID-3: /home raw-size: 585.94 GiB size: 585.65 GiB (99.95%)
    used: 11.95 GiB (2.0%) fs: xfs dev: /dev/sdc3 maj-min: 8:35 label: N/A
    uuid: 7516a8c7-fada-45cb-a5ec-b609619308af
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 450 MiB fs: ntfs label: N/A
    uuid: 24CA5EAECA5E7C4C
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 100 MiB fs: vfat label: N/A
    uuid: 705F-1FE0
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 231.81 GiB fs: ntfs label: N/A
    uuid: A450699A506973C8
  ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 530 MiB fs: ntfs label: N/A
    uuid: 1C66447366445026
  ID-6: /dev/sda1 maj-min: 8:1 size: 931.51 GiB fs: ntfs
    label: Foto Werk Stoor uuid: 0343DB190A1A04C3
  ID-7: /dev/sda2 maj-min: 8:2 size: 390.62 GiB fs: ntfs
    label: WindowsDokumente uuid: 6B709F1F023B22DC
  ID-8: /dev/sda3 maj-min: 8:3 size: 507.81 GiB fs: xfs label: N/A
    uuid: 7f98c196-2e11-4252-87d3-c61a7b6ea33d
  ID-9: /dev/sda4 maj-min: 8:4 size: 33.07 GiB fs: swap label: N/A
    uuid: a51794b0-eee5-46ee-af32-171e43ed85c9
  ID-10: /dev/sdb1 maj-min: 8:17 size: 465.76 GiB fs: xfs label: Timeshift
    uuid: d4101907-7218-459d-8c8f-e5d217f23514
  ID-11: /dev/sdc4 maj-min: 8:36 size: 74.93 GiB fs: swap label: N/A
    uuid: e782e4a6-4413-475e-89f6-7c60fb6bb4de
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
  Hub-2: 1-2:2 info: Alcor Micro USB Hub ports: 4 rev: 2.0 speed: 480 Mb/s
    power: 100mA chip-ID: 058f:6254 class-ID: 0900
  Device-1: 1-2.1:4
    info: JMicron / USA JM20337 Hi-Speed USB to SATA & PATA Combo Bridge
    type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
    speed: 480 Mb/s power: 2mA chip-ID: 152d:2338 class-ID: 0806
    serial: <filter>
  Device-2: 1-2.2:5 info: Genesys Logic Multislot Card Reader/Writer
    speed: 480 Mb/s power: 500mA chip-ID: 05e3:0716 class-ID: 0806
    serial: <filter>
  Device-3: 1-4:3 info: MediaTek Wireless_Device type: Bluetooth
    driver: btusb interfaces: 3 rev: 2.1 speed: 480 Mb/s power: 100mA
  Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 3-4:2 info: ASUSTek AURA LED Controller type: HID
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
    chip-ID: 0b05:1939 class-ID: 0300 serial: <filter>
  Hub-5: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-6: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 5-1:2 info: Logitech Marble Mouse (4-button) type: Mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
    power: 50mA chip-ID: 046d:c408 class-ID: 0301
  Device-2: 5-2:3 info: Logitech DeLuxe 250 Keyboard type: Keyboard
    power: 70mA chip-ID: 046d:c312 class-ID: 0301
  Hub-7: 6-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 27.8 C mobo: N/A gpu: amdgpu temp: 38.0 C
  Processes: 352 Uptime: 8m wakeups: 0 Init: systemd v: 251 default: graphical
  tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1225
  lib: 358 flatpak: 0 Shell: Bash v: 5.1.16 running-in: xfce4-terminal
  inxi: 3.3.19
**journalctl -b-1 -p5 --no-pager**
Jul 07 17:27:55 danie-ms7b84 kernel: Linux version 5.10.126-1-MANJARO (builduser@fv-az135-369) (gcc (GCC) 12.1.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT Mon Jun 27 10:02:42 UTC 2022
Jul 07 17:27:55 danie-ms7b84 kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=8eb9bda3-0538-46d2-be29-ff603d3428a5 rw quiet apparmor=1 security=apparmor udev.log_priority=3 idle=nomwait iommu=soft
Jul 07 17:27:55 danie-ms7b84 kernel: audit: type=2000 audit(1657207673.159:1): state=initialized audit_enabled=0 res=1
Jul 07 17:27:55 danie-ms7b84 kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
Jul 07 17:27:55 danie-ms7b84 kernel: SCSI subsystem initialized
Jul 07 17:27:55 danie-ms7b84 kernel: VFS: Disk quotas dquot_6.6.0
Jul 07 17:27:55 danie-ms7b84 kernel: Initialise system trusted keyrings
Jul 07 17:27:55 danie-ms7b84 kernel: Key type blacklist registered
Jul 07 17:27:55 danie-ms7b84 kernel: Key type asymmetric registered
Jul 07 17:27:55 danie-ms7b84 kernel: Asymmetric key parser 'x509' registered
Jul 07 17:27:55 danie-ms7b84 kernel: Loading compiled-in X.509 certificates
Jul 07 17:27:55 danie-ms7b84 kernel: nvme nvme0: missing or invalid SUBNQN field.
Jul 07 17:27:55 danie-ms7b84 kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 5b51f9f1661e11748533e04cd5d0517fe4e83d2f'
Jul 07 17:27:55 danie-ms7b84 kernel: Key type ._fscrypt registered
Jul 07 17:27:55 danie-ms7b84 kernel: Key type .fscrypt registered
Jul 07 17:27:55 danie-ms7b84 kernel: Key type fscrypt-provisioning registered
Jul 07 17:27:55 danie-ms7b84 kernel: scsi 3:0:0:0: Direct-Access     ATA      WDC WD20EZRX-00D 0A80 PQ: 0 ANSI: 5
Jul 07 17:27:55 danie-ms7b84 kernel: sd 3:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
Jul 07 17:27:55 danie-ms7b84 kernel: sd 3:0:0:0: [sda] 4096-byte physical blocks
Jul 07 17:27:55 danie-ms7b84 kernel: sd 3:0:0:0: [sda] Write Protect is off
Jul 07 17:27:55 danie-ms7b84 kernel: sd 3:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jul 07 17:27:55 danie-ms7b84 kernel: scsi 4:0:0:0: CD-ROM            HL-DT-ST DVDRAM GH24NSD5  LV00 PQ: 0 ANSI: 5
Jul 07 17:27:55 danie-ms7b84 kernel: sd 3:0:0:0: [sda] Attached SCSI disk
Jul 07 17:27:55 danie-ms7b84 kernel: scsi 8:0:0:0: Direct-Access     ATA      WDC WD5000BUCT-6 1A01 PQ: 0 ANSI: 5
Jul 07 17:27:55 danie-ms7b84 kernel: sd 8:0:0:0: [sdb] 976773168 512-byte logical blocks: (500 GB/466 GiB)
Jul 07 17:27:55 danie-ms7b84 kernel: sd 8:0:0:0: [sdb] 4096-byte physical blocks
Jul 07 17:27:55 danie-ms7b84 kernel: sd 8:0:0:0: [sdb] Write Protect is off
Jul 07 17:27:55 danie-ms7b84 kernel: sd 8:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jul 07 17:27:55 danie-ms7b84 kernel: scsi 9:0:0:0: Direct-Access     ATA      HS-SSD-E100 1024 8A0  PQ: 0 ANSI: 5
Jul 07 17:27:55 danie-ms7b84 kernel: sd 9:0:0:0: [sdc] 2000409264 512-byte logical blocks: (1.02 TB/954 GiB)
Jul 07 17:27:55 danie-ms7b84 kernel: sd 9:0:0:0: [sdc] Write Protect is off
Jul 07 17:27:55 danie-ms7b84 kernel: sd 9:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jul 07 17:27:55 danie-ms7b84 kernel: sd 9:0:0:0: [sdc] Attached SCSI disk
Jul 07 17:27:55 danie-ms7b84 kernel: sd 8:0:0:0: [sdb] Attached SCSI disk
Jul 07 17:27:55 danie-ms7b84 kernel: usb: port power management may be unreliable
Jul 07 17:27:55 danie-ms7b84 kernel: usb 3-4: config 1 has an invalid interface number: 2 but max is 1
Jul 07 17:27:55 danie-ms7b84 kernel: usb 3-4: config 1 has no interface number 1
Jul 07 17:27:55 danie-ms7b84 kernel: XFS (sdc2): Mounting V5 Filesystem
Jul 07 17:27:55 danie-ms7b84 kernel: XFS (sdc2): Starting recovery (logdev: internal)
Jul 07 17:27:55 danie-ms7b84 kernel: XFS (sdc2): Ending recovery (logdev: internal)
Jul 07 17:27:55 danie-ms7b84 kernel: xfs filesystem being mounted at /new_root supports timestamps until 2038 (0x7fffffff)
Jul 07 17:27:55 danie-ms7b84 kernel: xfs filesystem being remounted at / supports timestamps until 2038 (0x7fffffff)
Jul 07 17:27:55 danie-ms7b84 kernel: random: lvm: uninitialized urandom read (4 bytes read)
Jul 07 17:27:55 danie-ms7b84 kernel: audit: type=1400 audit(1657207675.680:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=337 comm="apparmor_parser"
Jul 07 17:27:55 danie-ms7b84 systemd-modules-load[322]: Failed to find module 'add msr'
Jul 07 17:27:55 danie-ms7b84 systemd-random-seed[329]: Kernel entropy pool is not initialized yet, waiting until it is.
Jul 07 17:27:55 danie-ms7b84 systemd-udevd[348]: /etc/udev/rules.d/40-libsane.rules:26: GOTO="libsane_rules_end" has no matching label, ignoring
Jul 07 17:27:55 danie-ms7b84 kernel: audit: type=1130 audit(1657207675.690:3): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 07 17:27:55 danie-ms7b84 kernel: audit: type=1400 audit(1657207675.694:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=338 comm="apparmor_parser"
Jul 07 17:27:55 danie-ms7b84 kernel: audit: type=1400 audit(1657207675.694:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=338 comm="apparmor_parser"
Jul 07 17:27:55 danie-ms7b84 systemd-journald[347]: File /var/log/journal/dd51c824280b44dc88a54e0b5f4d3da9/system.journal corrupted or uncleanly shut down, renaming and replacing.
Jul 07 17:27:55 danie-ms7b84 kernel: audit: type=1130 audit(1657207675.704:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 07 17:27:55 danie-ms7b84 kernel: audit: type=1130 audit(1657207675.704:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 07 17:27:55 danie-ms7b84 kernel: audit: type=1400 audit(1657207675.737:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-script-login" pid=341 comm="apparmor_parser"
Jul 07 17:27:55 danie-ms7b84 kernel: audit: type=1400 audit(1657207675.747:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-bgqd" pid=340 comm="apparmor_parser"
Jul 07 17:27:55 danie-ms7b84 kernel: audit: type=1400 audit(1657207675.764:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="php-fpm" pid=339 comm="apparmor_parser"
Jul 07 17:27:55 danie-ms7b84 kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Jul 07 17:27:55 danie-ms7b84 kernel: acpi PNP0C14:02: duplicate WMI GUID 97845ED0-4E6D-11DE-8A39-0800200C9A66 (first instance was on PNP0C14:00)
Jul 07 17:27:55 danie-ms7b84 kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Jul 07 17:27:55 danie-ms7b84 kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Jul 07 17:27:55 danie-ms7b84 kernel: acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Jul 07 17:27:55 danie-ms7b84 kernel: acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Jul 07 17:27:55 danie-ms7b84 kernel: ccp 0000:0a:00.2: ccp enabled
Jul 07 17:27:55 danie-ms7b84 systemd-udevd[348]: /etc/udev/rules.d/S99-2000S1.rules:26: GOTO="libsane_rules_end" has no matching label, ignoring
Jul 07 17:27:55 danie-ms7b84 kernel: random: tlp-readconfs: uninitialized urandom read (4 bytes read)
Jul 07 17:27:55 danie-ms7b84 kernel: XFS (sdc3): Mounting V5 Filesystem
Jul 07 17:27:56 danie-ms7b84 kernel: XFS (sdc3): Starting recovery (logdev: internal)
Jul 07 17:27:56 danie-ms7b84 kernel: XFS (sdc3): Ending recovery (logdev: internal)
Jul 07 17:27:56 danie-ms7b84 kernel: xfs filesystem being mounted at /home supports timestamps until 2038 (0x7fffffff)
Jul 07 17:27:56 danie-ms7b84 kernel: random: crng init done
Jul 07 17:27:56 danie-ms7b84 kernel: random: 10 urandom warning(s) missed due to ratelimiting
Jul 07 17:27:56 danie-ms7b84 kernel: kvm: disabled by bios
Jul 07 17:27:56 danie-ms7b84 kernel: amdgpu 0000:09:00.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported
Jul 07 17:27:56 danie-ms7b84 kernel: msr: Write to unrecognized MSR 0xc0010292 by zenstates (pid: 703). Please report to x86@kernel.org.
Jul 07 17:27:56 danie-ms7b84 kernel: xfs filesystem being remounted at /run/systemd/unit-root/var/tmp supports timestamps until 2038 (0x7fffffff)
Jul 07 17:27:56 danie-ms7b84 kernel: xfs filesystem being remounted at /run/systemd/unit-root/etc supports timestamps until 2038 (0x7fffffff)
Jul 07 17:27:56 danie-ms7b84 kernel: xfs filesystem being remounted at /run/systemd/unit-root/var/lib/systemd/linger supports timestamps until 2038 (0x7fffffff)
Jul 07 17:27:56 danie-ms7b84 kernel: asus_wmi: Failed to get WMI notify code: AE_NOT_FOUND
Jul 07 17:27:56 danie-ms7b84 kernel: asus_wmi: Failed to get event during flush: -5
Jul 07 17:27:56 danie-ms7b84 kernel: eeprom 0-0052: eeprom driver is deprecated, please use at24 instead
Jul 07 17:27:56 danie-ms7b84 kernel: eeprom 0-0053: eeprom driver is deprecated, please use at24 instead
Jul 07 17:27:56 danie-ms7b84 polkitd[716]: Loading rules from directory /etc/polkit-1/rules.d
Jul 07 17:27:56 danie-ms7b84 polkitd[716]: Loading rules from directory /usr/share/polkit-1/rules.d
Jul 07 17:27:56 danie-ms7b84 polkitd[716]: Finished loading, compiling and executing 7 rules
Jul 07 17:27:56 danie-ms7b84 polkitd[716]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Jul 07 17:27:56 danie-ms7b84 systemd-udevd[388]: event18: Failed to call EVIOCSKEYCODE with scan code 0x7c, and key code 190: Invalid argument
Jul 07 17:27:57 danie-ms7b84 kernel: kvm: disabled by bios
Jul 07 17:27:57 danie-ms7b84 kernel: eeprom 5-0050: eeprom driver is deprecated, please use at24 instead
Jul 07 17:27:57 danie-ms7b84 kernel: eeprom 8-0050: eeprom driver is deprecated, please use at24 instead
Jul 07 17:27:57 danie-ms7b84 kernel: xfs filesystem being remounted at /run/systemd/unit-root/etc supports timestamps until 2038 (0x7fffffff)
Jul 07 17:27:57 danie-ms7b84 kernel: xfs filesystem being remounted at /run/systemd/unit-root/var/tmp supports timestamps until 2038 (0x7fffffff)
Jul 07 17:27:57 danie-ms7b84 kernel: Bluetooth: hci0: Unsupported support hardware variant (00000000)
Jul 07 17:27:57 danie-ms7b84 kernel: xfs filesystem being remounted at /run/systemd/unit-root/var/lib/bluetooth supports timestamps until 2038 (0x7fffffff)
Jul 07 17:27:57 danie-ms7b84 colord-sane[929]: io/hpmud/musb.c 2099: Invalid usb_open: Permission denied
Jul 07 17:27:57 danie-ms7b84 colord[818]: CdMain: failed to emit DeviceAdded: failed to register object: An object is already exported for the interface org.freedesktop.ColorManager.Device at /org/freedesktop/ColorManager/devices/sysfs_Hewlett_Packard_HP_LaserJet_Professional_M1212nf_MFP
Jul 07 17:27:57 danie-ms7b84 kernel: WARNING! power/level is deprecated; use power/control instead
Jul 07 17:27:57 danie-ms7b84 colord-sane[1190]: io/hpmud/musb.c 2099: Invalid usb_open: Permission denied
Jul 07 17:27:57 danie-ms7b84 colord-sane[1231]: io/hpmud/musb.c 2099: Invalid usb_open: Permission denied
Jul 07 17:27:58 danie-ms7b84 kernel: kauditd_printk_skb: 49 callbacks suppressed
Jul 07 17:27:58 danie-ms7b84 kernel: audit: type=1103 audit(1657207678.360:60): pid=1248 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jul 07 17:27:58 danie-ms7b84 kernel: audit: type=1130 audit(1657207678.374:61): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 07 17:27:58 danie-ms7b84 systemd[1252]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[lightdm] ruser=[<unknown>] rhost=[<unknown>]
Jul 07 17:27:58 danie-ms7b84 kernel: audit: type=1101 audit(1657207678.384:62): pid=1252 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 07 17:27:58 danie-ms7b84 kernel: audit: type=1103 audit(1657207678.384:63): pid=1252 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Jul 07 17:27:58 danie-ms7b84 kernel: audit: type=1006 audit(1657207678.384:64): pid=1252 uid=0 subj==unconfined old-auid=4294967295 auid=969 tty=(none) old-ses=4294967295 ses=1 res=1
Jul 07 17:27:58 danie-ms7b84 kernel: audit: type=1105 audit(1657207678.384:65): pid=1252 uid=0 auid=969 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 07 17:27:58 danie-ms7b84 kernel: audit: type=1334 audit(1657207678.387:66): prog-id=19 op=LOAD
Jul 07 17:27:58 danie-ms7b84 kernel: audit: type=1334 audit(1657207678.387:67): prog-id=19 op=UNLOAD
Jul 07 17:27:58 danie-ms7b84 kernel: scsi 11:0:0:0: Direct-Access                                    PQ: 0 ANSI: 2 CCS
Jul 07 17:27:58 danie-ms7b84 kernel: scsi 12:0:0:0: Direct-Access     Generic  STORAGE DEVICE   9744 PQ: 0 ANSI: 0
Jul 07 17:27:58 danie-ms7b84 kernel: sd 11:0:0:0: [sdd] 0 512-byte logical blocks: (0 B/0 B)
Jul 07 17:27:58 danie-ms7b84 kernel: sd 11:0:0:0: [sdd] 0-byte physical blocks
Jul 07 17:27:58 danie-ms7b84 kernel: sd 11:0:0:0: [sdd] Test WP failed, assume Write Enabled
Jul 07 17:27:58 danie-ms7b84 kernel: sd 11:0:0:0: [sdd] Asking for cache data failed
Jul 07 17:27:58 danie-ms7b84 kernel: sd 11:0:0:0: [sdd] Assuming drive cache: write through
Jul 07 17:27:58 danie-ms7b84 kernel: sd 11:0:0:0: [sdd] Attached SCSI disk
Jul 07 17:27:58 danie-ms7b84 kernel: audit: type=1130 audit(1657207678.590:68): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 07 17:27:58 danie-ms7b84 colord-sane[1259]: io/hpmud/musb.c 2099: Invalid usb_open: Permission denied
Jul 07 17:27:58 danie-ms7b84 kernel: audit: type=1105 audit(1657207678.597:69): pid=1248 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_open grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jul 07 17:27:59 danie-ms7b84 polkitd[716]: <no filename>:3: action=[Action id='org.freedesktop.DisplayManager.AccountsService.ReadAny']
Jul 07 17:27:59 danie-ms7b84 polkitd[716]: <no filename>:4: subject=[Subject pid=1272 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
Jul 07 17:28:01 danie-ms7b84 kernel: scsi 12:0:0:1: Direct-Access     Generic  STORAGE DEVICE   9744 PQ: 0 ANSI: 0
Jul 07 17:28:03 danie-ms7b84 kernel: scsi 12:0:0:2: Direct-Access     Generic  STORAGE DEVICE   9744 PQ: 0 ANSI: 0
Jul 07 17:28:06 danie-ms7b84 kernel: scsi 12:0:0:3: Direct-Access     Generic  STORAGE DEVICE   9744 PQ: 0 ANSI: 0
Jul 07 17:28:06 danie-ms7b84 kernel: sd 12:0:0:0: [sde] Attached SCSI removable disk
Jul 07 17:28:06 danie-ms7b84 kernel: sd 12:0:0:1: [sdf] Attached SCSI removable disk
Jul 07 17:28:06 danie-ms7b84 kernel: sd 12:0:0:3: [sdh] Attached SCSI removable disk
Jul 07 17:28:06 danie-ms7b84 kernel: sd 12:0:0:2: [sdg] Attached SCSI removable disk
Jul 07 17:28:06 danie-ms7b84 colord-sane[1401]: io/hpmud/musb.c 2099: Invalid usb_open: Permission denied
Jul 07 17:28:06 danie-ms7b84 kernel: kauditd_printk_skb: 2 callbacks suppressed
Jul 07 17:28:06 danie-ms7b84 kernel: audit: type=1131 audit(1657207686.930:72): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 07 17:28:08 danie-ms7b84 lightdm[1392]: gkr-pam: unable to locate daemon control file
Jul 07 17:28:08 danie-ms7b84 kernel: audit: type=1100 audit(1657207688.387:73): pid=1392 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="danie" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jul 07 17:28:08 danie-ms7b84 kernel: audit: type=1101 audit(1657207688.387:74): pid=1392 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="danie" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jul 07 17:28:08 danie-ms7b84 kernel: audit: type=1106 audit(1657207688.434:75): pid=1248 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jul 07 17:28:08 danie-ms7b84 kernel: audit: type=1104 audit(1657207688.434:76): pid=1248 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jul 07 17:28:08 danie-ms7b84 kernel: audit: type=1103 audit(1657207688.437:77): pid=1392 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="danie" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jul 07 17:28:08 danie-ms7b84 kernel: audit: type=1006 audit(1657207688.437:78): pid=1392 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
Jul 07 17:28:08 danie-ms7b84 kernel: audit: type=1130 audit(1657207688.457:79): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 07 17:28:08 danie-ms7b84 systemd[1722]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[danie] ruser=[<unknown>] rhost=[<unknown>]
Jul 07 17:28:08 danie-ms7b84 kernel: audit: type=1101 audit(1657207688.464:80): pid=1722 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="danie" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 07 17:28:08 danie-ms7b84 kernel: audit: type=1103 audit(1657207688.464:81): pid=1722 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="danie" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Jul 07 17:28:08 danie-ms7b84 systemd-xdg-autostart-generator[1728]: /home/danie/.config/autostart/xcape.desktop:9: Unknown key name 'RunHook' in section 'Desktop Entry', ignoring.
Jul 07 17:28:08 danie-ms7b84 systemd-journald[347]: File /var/log/journal/dd51c824280b44dc88a54e0b5f4d3da9/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
Jul 07 17:28:08 danie-ms7b84 systemd-xdg-autostart-generator[1728]: Configuration file /home/danie/.config/autostart/xfce-panel-workaround.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Jul 07 17:28:08 danie-ms7b84 systemd-xdg-autostart-generator[1728]: Configuration file /home/danie/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits. Proceeding anyway.
Jul 07 17:28:08 danie-ms7b84 systemd-xdg-autostart-generator[1728]: /home/danie/.config/autostart/xfce-pbw.sh:2: Assignment outside of section. Ignoring.
Jul 07 17:28:08 danie-ms7b84 systemd-xdg-autostart-generator[1728]: /home/danie/.config/autostart/xfce-pbw.sh:3: Assignment outside of section. Ignoring.
Jul 07 17:28:08 danie-ms7b84 systemd-xdg-autostart-generator[1728]: /home/danie/.config/autostart/xfce-pbw.sh:4: Assignment outside of section. Ignoring.
Jul 07 17:28:08 danie-ms7b84 systemd-xdg-autostart-generator[1728]: /home/danie/.config/autostart/xfce-pbw.sh:5: Assignment outside of section. Ignoring.
Jul 07 17:28:08 danie-ms7b84 systemd-xdg-autostart-generator[1728]: /home/danie/.config/autostart/xfce-pbw.sh:6: Assignment outside of section. Ignoring.
Jul 07 17:28:08 danie-ms7b84 systemd-xdg-autostart-generator[1728]: /home/danie/.config/autostart/xfce-pbw.sh:7: Assignment outside of section. Ignoring.
Jul 07 17:28:08 danie-ms7b84 systemd-xdg-autostart-generator[1728]: Configuration file /home/danie/.config/autostart/overgrive-autostart.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Jul 07 17:28:09 danie-ms7b84 polkitd[716]: Registered Authentication Agent for unix-session:2 (system bus name :1.49 [/usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1], object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_ZA.utf8)
Jul 07 17:28:09 danie-ms7b84 tumblerd[1866]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.6.so.0: cannot open shared object file: No such file or directory
Jul 07 17:28:09 danie-ms7b84 kernel: xfs filesystem being remounted at /run/systemd/unit-root/var/lib/upower supports timestamps until 2038 (0x7fffffff)
Jul 07 17:28:09 danie-ms7b84 kernel: xfs filesystem being remounted at /run/systemd/unit-root/var/tmp supports timestamps until 2038 (0x7fffffff)
Jul 07 17:28:09 danie-ms7b84 udisksd[1951]: udisks daemon version 2.9.4 starting
Jul 07 17:28:10 danie-ms7b84 pulseaudio[1820]: stat('/etc/pulse/default.pa.d'): No such file or directory
Jul 07 17:28:10 danie-ms7b84 udisksd[1951]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Jul 07 17:28:12 danie-ms7b84 kernel: kauditd_printk_skb: 13 callbacks suppressed
Jul 07 17:28:12 danie-ms7b84 kernel: audit: type=1131 audit(1657207692.050:95): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 07 17:28:13 danie-ms7b84 xdg-desktop-por[2178]: Theme parser error: gtk.css:6100:3-36: No property named "-GtkTreeView-horizontal-separator"
Jul 07 17:28:13 danie-ms7b84 xdg-desktop-por[2178]: Theme parser error: gtk.css:6101:3-34: No property named "-GtkTreeView-vertical-separator"
Jul 07 17:28:13 danie-ms7b84 xdg-desktop-por[2178]: Theme parser error: gtk.css:6159:3-29: No property named "-GtkTreeView-expander-size"
Jul 07 17:28:13 danie-ms7b84 xdg-desktop-por[2178]: Theme parser error: gtk.css:6192:3-37: No property named "-GraniteWidgetsPopOver-arrow-width"
Jul 07 17:28:13 danie-ms7b84 xdg-desktop-por[2178]: Theme parser error: gtk.css:6193:3-38: No property named "-GraniteWidgetsPopOver-arrow-height"
Jul 07 17:28:13 danie-ms7b84 xdg-desktop-por[2178]: Theme parser error: gtk.css:6194:3-39: No property named "-GraniteWidgetsPopOver-border-radius"
Jul 07 17:28:13 danie-ms7b84 xdg-desktop-por[2178]: Theme parser error: gtk.css:6195:3-38: No property named "-GraniteWidgetsPopOver-border-width"
Jul 07 17:28:13 danie-ms7b84 xdg-desktop-por[2178]: Theme parser error: gtk.css:6196:3-37: No property named "-GraniteWidgetsPopOver-shadow-size"
Jul 07 17:28:18 danie-ms7b84 systemd[1253]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[lightdm] ruser=[<unknown>] rhost=[<unknown>]
Jul 07 17:28:18 danie-ms7b84 kernel: audit: type=1131 audit(1657207698.504:96): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 07 17:28:18 danie-ms7b84 kernel: audit: type=1131 audit(1657207698.510:97): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 07 17:28:27 danie-ms7b84 kernel: audit: type=1131 audit(1657207707.127:98): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 07 17:28:27 danie-ms7b84 kernel: audit: type=1334 audit(1657207707.157:99): prog-id=18 op=UNLOAD
Jul 07 17:28:27 danie-ms7b84 kernel: audit: type=1334 audit(1657207707.157:100): prog-id=17 op=UNLOAD
Jul 07 17:28:27 danie-ms7b84 kernel: audit: type=1334 audit(1657207707.157:101): prog-id=16 op=UNLOAD
Jul 07 17:28:27 danie-ms7b84 kernel: audit: type=1131 audit(1657207707.310:102): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 07 17:28:27 danie-ms7b84 kernel: audit: type=1334 audit(1657207707.430:103): prog-id=14 op=UNLOAD
Jul 07 17:28:27 danie-ms7b84 kernel: audit: type=1334 audit(1657207707.430:104): prog-id=13 op=UNLOAD
Jul 07 17:28:27 danie-ms7b84 kernel: audit: type=1334 audit(1657207707.430:105): prog-id=12 op=UNLOAD
Jul 07 17:28:40 danie-ms7b84 kernel: audit: type=1131 audit(1657207720.304:106): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 07 17:28:43 danie-ms7b84 xdg-desktop-por[2161]: Failed to get application states: GDBus.Error:org.freedesktop.portal.Error.Failed: Could not get window list
Jul 07 17:35:32 danie-ms7b84 kernel: audit: type=1334 audit(1657208132.174:107): prog-id=24 op=LOAD
Jul 07 17:35:32 danie-ms7b84 kernel: audit: type=1334 audit(1657208132.174:108): prog-id=25 op=LOAD
Jul 07 17:35:32 danie-ms7b84 kernel: audit: type=1334 audit(1657208132.174:109): prog-id=26 op=LOAD
Jul 07 17:35:32 danie-ms7b84 kernel: xfs filesystem being remounted at /run/systemd/unit-root/etc supports timestamps until 2038 (0x7fffffff)
Jul 07 17:35:32 danie-ms7b84 kernel: xfs filesystem being remounted at /run/systemd/unit-root/var/tmp supports timestamps until 2038 (0x7fffffff)
Jul 07 17:35:32 danie-ms7b84 kernel: audit: type=1130 audit(1657208132.217:110): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 07 17:36:02 danie-ms7b84 kernel: audit: type=1131 audit(1657208162.250:111): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 07 17:36:02 danie-ms7b84 kernel: audit: type=1334 audit(1657208162.270:112): prog-id=26 op=UNLOAD
Jul 07 17:36:02 danie-ms7b84 kernel: audit: type=1334 audit(1657208162.270:113): prog-id=25 op=UNLOAD
Jul 07 17:36:02 danie-ms7b84 kernel: audit: type=1334 audit(1657208162.270:114): prog-id=24 op=UNLOAD
Jul 07 17:41:30 danie-ms7b84 kernel: bdi 8:80: the stable_pages_required attribute has been removed. Use the stable_writes queue attribute instead.
Jul 07 17:41:30 danie-ms7b84 kernel: audit: type=1130 audit(1657208490.947:115): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 07 17:41:30 danie-ms7b84 kernel: audit: type=1334 audit(1657208490.950:116): prog-id=27 op=LOAD
Jul 07 17:41:30 danie-ms7b84 kernel: audit: type=1334 audit(1657208490.950:117): prog-id=28 op=LOAD
Jul 07 17:41:30 danie-ms7b84 kernel: audit: type=1334 audit(1657208490.950:118): prog-id=29 op=LOAD
Jul 07 17:41:30 danie-ms7b84 kernel: xfs filesystem being remounted at /run/systemd/unit-root/var/tmp supports timestamps until 2038 (0x7fffffff)
Jul 07 17:41:30 danie-ms7b84 kernel: xfs filesystem being remounted at /run/systemd/unit-root/etc supports timestamps until 2038 (0x7fffffff)
Jul 07 17:41:31 danie-ms7b84 kernel: audit: type=1130 audit(1657208490.994:119): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 07 17:41:35 danie-ms7b84 kernel: audit: type=1131 audit(1657208495.954:120): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 07 17:42:01 danie-ms7b84 kernel: audit: type=1131 audit(1657208521.280:121): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 07 17:42:01 danie-ms7b84 kernel: audit: type=1334 audit(1657208521.327:122): prog-id=29 op=UNLOAD
Jul 07 17:42:01 danie-ms7b84 kernel: audit: type=1334 audit(1657208521.327:123): prog-id=28 op=UNLOAD
Jul 07 17:42:01 danie-ms7b84 kernel: audit: type=1334 audit(1657208521.327:124): prog-id=27 op=UNLOAD
Jul 07 17:42:59 danie-ms7b84 kernel: audit: type=1130 audit(1657208579.270:125): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 07 17:42:59 danie-ms7b84 kernel: audit: type=1131 audit(1657208579.270:126): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 07 17:47:29 danie-ms7b84 systemd-logind[718]: System is powering down.
Jul 07 17:47:29 danie-ms7b84 polkitd[716]: Unregistered Authentication Agent for unix-session:2 (system bus name :1.49, object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_ZA.utf8) (disconnected from bus)
Jul 07 17:47:29 danie-ms7b84 kernel: audit: type=1131 audit(1657208849.284:127): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cups comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 07 17:47:29 danie-ms7b84 kernel: audit: type=1131 audit(1657208849.284:128): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=accounts-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 07 17:47:29 danie-ms7b84 kernel: audit: type=1131 audit(1657208849.287:129): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 07 17:47:29 danie-ms7b84 kernel: audit: type=1113 audit(1657208849.287:130): pid=1392 uid=0 auid=1000 ses=2 subj==unconfined msg='op=logout id=1000 exe="/usr/bin/lightdm" hostname=danie-ms7b84 addr=? terminal=/dev/tty7 res=success'
Jul 07 17:47:29 danie-ms7b84 kernel: audit: type=1131 audit(1657208849.287:131): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 07 17:47:29 danie-ms7b84 kernel: audit: type=1131 audit(1657208849.287:132): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 07 17:47:29 danie-ms7b84 kernel: audit: type=1131 audit(1657208849.287:133): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 07 17:47:29 danie-ms7b84 kernel: audit: type=1131 audit(1657208849.287:134): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 07 17:47:29 danie-ms7b84 udisksd[1951]: udisks daemon version 2.9.4 exiting
Jul 07 17:47:29 danie-ms7b84 kernel: audit: type=1131 audit(1657208849.300:135): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=colord comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 07 17:47:29 danie-ms7b84 kernel: audit: type=1131 audit(1657208849.300:136): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 07 17:47:29 danie-ms7b84 systemd[1722]: gvfs-daemon.service: Killing process 2076 (gdbus) with signal SIGKILL.
Jul 07 17:47:29 danie-ms7b84 systemd[1722]: xdg-document-portal.service: Main process exited, code=exited, status=20/n/a
Jul 07 17:47:29 danie-ms7b84 systemd[1722]: xdg-document-portal.service: Failed with result 'exit-code'.
Jul 07 17:47:29 danie-ms7b84 systemd[1722]: xdg-desktop-portal-gnome.service: Main process exited, code=exited, status=1/FAILURE
Jul 07 17:47:29 danie-ms7b84 systemd[1722]: xdg-desktop-portal-gnome.service: Failed with result 'exit-code'.
Jul 07 17:47:29 danie-ms7b84 systemd[1723]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[danie] ruser=[<unknown>] rhost=[<unknown>]
Jul 07 17:47:29 danie-ms7b84 kernel: XFS (sdc3): Unmounting Filesystem
Jul 07 17:47:29 danie-ms7b84 systemd[1]: Shutting down.
Managed to get rid of KVM disabled by bios message; called SVM in ASUS bios. Switched on, still crashing.
AFAIK this should not be required since the 5.8 kernel came by … Does the system work without and with the 5.10 kernel?
How did you installed the new kernel? List the installed ones:
mhwd-kernel -li
The system works perfectly with the 5.10 kernel.
Installed kernels:
5.10.126-1-MANJARO (linux510)
   * linux510
   * linux515
   * linux518
Please label as solved
