Kernel panic with 6.10.3 except when a VM running
Hello,
I have a strange behaviour with Kernel 6.10.3 (also every Kernel 6). I have radomly Kernel panic when system running except a VM is running with Virtualbox. Then the system runs without errors.
There is no entry in journalctl.
How can I get further on this issue?
Greetings
Eric
what does cat /proc/sys/kernel/tainted return?
Hi,
it returned 12288
inxi:
CPU: 8-core AMD Ryzen 7 PRO 6850U with Radeon Graphics (-MT MCP-)
speed/min/max: 586/400/4768 MHz Kernel: 6.10.3-1-MANJARO x86_64 Up: 3m
Mem: 2.06/27.18 GiB (7.6%) Storage: 1.82 TiB (54.9% used) Procs: 384
Shell: Zsh inxi: 3.3.35
Do you use a nvidia GPU?
It is most certainly some driver module. As Pheiduck suggested, some debugging info can be obtained from the tainted status of the kernel, also in the oops messages
https://docs.kernel.org/admin-guide/tainted-kernels.html
isn’t documented there Tainted kernels — The Linux Kernel documentation :thinking:
@erimar030279 how do you perform system upgrades?
sudo pacman-mirrors -f && sudo pacman -Syyu ?
I perform upgrades with Software-Center or with
sudo pacman -Syu
Nothing Special
Hi again,
Today i have more time.
Well, i run the scripts “kernel-chktaint”
Kernel is "tainted" for the following reasons:
 * externally-built ('out-of-tree') module was loaded  (#12)
 * unsigned module was loaded (#13)
but
find /lib/modules -name '*.ko' -exec grep -FL '~Module signature appended~' {} \+
give nothing
Okay, then maybe your mirrors mostly not up to date…
Try the command I mentioned above and check if there some missing updates.
Everything up-to-date
I guess it’s something with a Kernel-module
Are you running AMD?
If so you are in the same situation like me and few other lads.
And if it is happening when system is idle, yes, i read one of the solution is running VM at background.
Never tried it, but i will install VM just for this.
I have tried almost every option in bios (C states, power load) and nothing works.
6.6 and 6.10 give me same results
random reboots
once a day
Yes it’s an AMD Ryzen 7
Glad, that i am not alone and its not an issue from me.
So I think it will be fix :wink:
Thank you
I don’t think there will be a fix
because there is no way (at least for me) to find why it is happening
no logs in my case
just random restarts
but for you, try next steps:
  1. Change Power Supply Idle Control in BIOS to typical current idle
  2. Disable C states in BIOS
Some lads reported that it is solved their problems.
Sometimes weird unexplainable errors happen because of faulty RAM. You might want to check your RAM with memtest.
tested for few days
no problems with Windows, btw
RAM is ok.
It‘s Dualboot with win10. There are no Problems with Win.
I guess it‘s a Kernel-bug with AMD
Did you test it, or just guessing? Just because you don’t see symptoms in with one OS doesn’t mean there is no problem.
Of course, I have tested. Knowledge, skill and experience with Linux and IT are already a bit advanced :stuck_out_tongue_winking_eye:
inxi -Fazy
sudo dmesg
inxi -Fazy:
  Kernel: 6.10.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64
    root=UUID=5338bde3-ac29-4c5e-9fb3-efebf439e246 rw quiet
    cryptdevice=UUID=e85818be-44b8-43b9-b852-56ece99bf27d:luks-e85818be-44b8-43b9-b852-56ece99bf27d
    root=/dev/mapper/luks-e85818be-44b8-43b9-b852-56ece99bf27d apparmor=1
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
    with: plank,xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
  Type: Laptop System: LENOVO product: 21CK0034GE v: ThinkPad P16s Gen 1
  Mobo: LENOVO model: 21CK0034GE v: SDK0T76538 WIN
    serial: <superuser required> part-nu: LENOVO_MT_21CK_BU_Think_FM_ThinkPad
    P16s Gen 1 uuid: <superuser required> UEFI: LENOVO v: R23ET70W (1.40 )
    date: 08/08/2023
  ID-1: BAT0 charge: 45.9 Wh (96.2%) condition: 47.7/52.5 Wh (90.9%)
    power: 17.2 W volts: 16.4 min: 15.5 model: Sunwoda LNV-5B10W51870@�
    type: Li-poly serial: <filter> status: discharging cycles: 106
  Info: model: AMD Ryzen 7 PRO 6850U with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3+ gen: 4 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
    family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404102
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
    desc: 1x16 MiB
  Speed (MHz): avg: 1260 high: 2379 min/max: 400/4768 scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 400 3: 2349
    4: 400 5: 2378 6: 400 7: 400 8: 400 9: 2375 10: 2341 11: 2362 12: 2378
    13: 2379 14: 400 15: 400 16: 400 bogomips: 86278
  Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
    affected
  Device-1: AMD Rembrandt [Radeon 680M] vendor: Lenovo driver: amdgpu v: kernel
    arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1, DP-2, DP-3,
    DP-4, DP-5, DP-6, HDMI-A-1, Writeback-1 bus-ID: 04:00.0 chip-ID: 1002:1681
    class-ID: 0300 temp: 42.0 C
  Device-2: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 174f:1812
  Display: x11 server: X.org v: 1.21.1.13 compositor: xfwm4 v: 4.18.0 driver:
    X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
    gpu: amdgpu display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1200 s-size: <missing: xdpyinfo>
  Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0a30 built: 2021
    res: 1920x1200 hz: 60 dpi: 141 gamma: 1.2 size: 345x215mm (13.58x8.46")
    diag: 407mm (16") ratio: 16:10 modes: max: 1920x1200 min: 640x480
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.5-manjaro1.1
    rembrandt LLVM 18.1.8 DRM 3.57 6.10.3-1-MANJARO) device-ID: 1002:1681
    memory: 3.91 GiB unified: no
  Device-1: AMD Rembrandt Radeon High Definition Audio vendor: Lenovo
    bus-ID: 04:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
    driver: snd_pci_acp6x v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
    snd_pci_acp5x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
    snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.5
    chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.10.3-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp1s0f0 state: down mac: <filter>
  Device-2: Qualcomm QCNFA765 Wireless Network Adapter vendor: Lenovo
    driver: ath11k_pci v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 link-max:
    gen: 3 speed: 8 GT/s bus-ID: 02:00.0 chip-ID: 17cb:1103 class-ID: 0280
  Device-1: USI driver: btusb v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s lanes: 1
    mode: 1.1 bus-ID: 1-3.1:3 chip-ID: 10ab:9309 class-ID: e001
  Local Storage: total: 1.82 TiB used: 1 TiB (55.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S2000G
    lanes: 4 tech: SSD serial: <filter> fw-rev: SBK00104 temp: 33.9 C
    scheme: GPT
  ID-1: / raw-size: 1.57 TiB size: 1.55 TiB (98.36%) used: 1 TiB (64.7%)
    fs: ext4 dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-e85818be-44b8-43b9-b852-56ece99bf27d
    used: 28.4 MiB (29.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-1: swap-1 type: file size: 64 GiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  System Temperatures: cpu: 50.0 C mobo: N/A gpu: amdgpu temp: 44.0 C
  Fan Speeds (rpm): fan-1: 0
  Memory: total: 28 GiB available: 27.18 GiB used: 4.64 GiB (17.1%)
  Processes: 405 Power: uptime: 2m states: freeze,mem,disk suspend: s2idle
    image: 10.85 GiB services: upowerd,xfce4-power-manager Init: systemd v: 256
  Packages: 1484 pm: pacman pkgs: 1470 libs: 487 tools: pamac pm: flatpak
    pkgs: 7 pm: snap pkgs: 7 Compilers: gcc: 14.1.1 Shell: Zsh v: 5.9
    running-in: terminator inxi: 3.3.35
dmesg:
[    0.000000] Linux version 6.10.3-1-MANJARO (builduser@fv-az1430-375) (gcc (GCC) 14.1.1 20240720, GNU ld (GNU Binutils) 2.42.0) #1 SMP PREEMPT_DYNAMIC Sat Aug  3 10:24:35 UTC 2024
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64 root=UUID=5338bde3-ac29-4c5e-9fb3-efebf439e246 rw quiet cryptdevice=UUID=e85818be-44b8-43b9-b852-56ece99bf27d:luks-e85818be-44b8-43b9-b852-56ece99bf27d root=/dev/mapper/luks-e85818be-44b8-43b9-b852-56ece99bf27d apparmor=1 security=apparmor udev.log_priority=3
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000009bfffff] usable
[    0.000000] BIOS-e820: [mem 0x0000000009c00000-0x0000000009da0fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000009da1000-0x0000000009efffff] usable
[    0.000000] BIOS-e820: [mem 0x0000000009f00000-0x0000000009f27fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x0000000009f28000-0x0000000070b7dfff] usable
[    0.000000] BIOS-e820: [mem 0x0000000070b7e000-0x000000007677dfff] reserved
[    0.000000] BIOS-e820: [mem 0x000000007677e000-0x000000007777dfff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000007777e000-0x00000000777fdfff] ACPI data
[    0.000000] BIOS-e820: [mem 0x00000000777fe000-0x0000000079ffcfff] usable
[    0.000000] BIOS-e820: [mem 0x0000000079ffd000-0x000000007bffffff] reserved
[    0.000000] BIOS-e820: [mem 0x000000007ce00000-0x000000007fffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fde00000-0x00000000fdefffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed80000-0x00000000fed80fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000077e2fffff] usable
[    0.000000] BIOS-e820: [mem 0x000000077f340000-0x00000008a01fffff] reserved
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] APIC: Static calls initialized
[    0.000000] e820: update [mem 0x3d62c018-0x3d636e57] usable ==> usable
[    0.000000] extended physical RAM map:
[    0.000000] reserve setup_data: [mem 0x0000000000000000-0x000000000009ffff] usable
[    0.000000] reserve setup_data: [mem 0x0000000000100000-0x0000000009bfffff] usable
[    0.000000] reserve setup_data: [mem 0x0000000009c00000-0x0000000009da0fff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000009da1000-0x0000000009efffff] usable
[    0.000000] reserve setup_data: [mem 0x0000000009f00000-0x0000000009f27fff] ACPI NVS
[    0.000000] reserve setup_data: [mem 0x0000000009f28000-0x000000003d62c017] usable
[    0.000000] reserve setup_data: [mem 0x000000003d62c018-0x000000003d636e57] usable
[    0.000000] reserve setup_data: [mem 0x000000003d636e58-0x0000000070b7dfff] usable
[    0.000000] reserve setup_data: [mem 0x0000000070b7e000-0x000000007677dfff] reserved
[    0.000000] reserve setup_data: [mem 0x000000007677e000-0x000000007777dfff] ACPI NVS
[    0.000000] reserve setup_data: [mem 0x000000007777e000-0x00000000777fdfff] ACPI data
[    0.000000] reserve setup_data: [mem 0x00000000777fe000-0x0000000079ffcfff] usable
[    0.000000] reserve setup_data: [mem 0x0000000079ffd000-0x000000007bffffff] reserved
[    0.000000] reserve setup_data: [mem 0x000000007ce00000-0x000000007fffffff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000fde00000-0x00000000fdefffff] reserved
[    0.000000] reserve setup_data: [mem 0x00000000fed80000-0x00000000fed80fff] reserved
[    0.000000] reserve setup_data: [mem 0x0000000100000000-0x000000077e2fffff] usable
[    0.000000] reserve setup_data: [mem 0x000000077f340000-0x00000008a01fffff] reserved
[    0.000000] efi: EFI v2.7 by Lenovo
[    0.000000] efi: ACPI=0x777fd000 ACPI 2.0=0x777fd014 SMBIOS=0x73694000 SMBIOS 3.0=0x73687000 MEMATTR=0x6be40018 ESRT=0x6be9bd18 INITRD=0x3f041698 RNG=0x777fc018
[    0.000000] random: crng init done
[    0.000000] efi: Remove mem60: MMIO range=[0xfde00000-0xfdefffff] (1MB) from e820 map
[    0.000000] e820: remove [mem 0xfde00000-0xfdefffff] reserved
[    0.000000] efi: Not removing mem61: MMIO range=[0xfed80000-0xfed80fff] (4KB) from e820 map
[    0.000000] efi: Remove mem63: MMIO range=[0x880000000-0x8a01fffff] (514MB) from e820 map
[    0.000000] e820: remove [mem 0x880000000-0x8a01fffff] reserved
[    0.000000] SMBIOS 3.3.0 present.
[    0.000000] DMI: LENOVO 21CK0034GE/21CK0034GE, BIOS R23ET70W (1.40 ) 08/08/2023
[    0.000000] DMI: Memory slots populated: 4/4
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] tsc: Detected 2694.924 MHz processor
[    0.000198] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000199] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000204] last_pfn = 0x77e300 max_arch_pfn = 0x400000000
[    0.000210] MTRR map: 9 entries (3 fixed + 6 variable; max 20), built from 9 variable MTRRs
[    0.000212] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.000484] last_pfn = 0x79ffd max_arch_pfn = 0x400000000
[    0.003333] esrt: Reserving ESRT space from 0x000000006be9bd18 to 0x000000006be9be68.
[    0.003340] e820: update [mem 0x6be9b000-0x6be9bfff] usable ==> reserved
[    0.003354] Using GB pages for direct mapping
[    0.003544] Secure boot disabled
[    0.003545] RAMDISK: [mem 0x3751e000-0x396e7fff]
[    0.003624] ACPI: Early table checksum verification disabled
[    0.003627] ACPI: RSDP 0x00000000777FD014 000024 (v02 LENOVO)
[    0.003630] ACPI: XSDT 0x00000000777FB188 000134 (v01 LENOVO TP-R23   000012E0 PTEC 00000002)
[    0.003635] ACPI: FACP 0x0000000071383000 000114 (v06 LENOVO TP-R23   000012E0 PTEC 00000002)
[    0.003639] ACPI: DSDT 0x0000000071369000 014C24 (v01 LENOVO TP-R23   000012E0 INTL 20180313)
[    0.003641] ACPI: FACS 0x0000000077757000 000040
[    0.003643] ACPI: SSDT 0x000000007369B000 0000A2 (v01 LENOVO PID0Ssdt 00000001 INTL 20180313)
[    0.003645] ACPI: SSDT 0x000000007369A000 000A93 (v01 LENOVO UsbCTabl 00000001 INTL 20180313)
[    0.003646] ACPI: SSDT 0x000000007362F000 007F5B (v02 LENOVO TP-R23   00000002 MSFT 02000002)
[    0.003648] ACPI: SSDT 0x000000007362E000 000586 (v01 LENOVO ACDC     00000001 INTL 20180313)
[    0.003650] ACPI: SSDT 0x000000007362D000 0001D8 (v01 LENOVO STD3     00000001 INTL 20180313)
[    0.003652] ACPI: MSDM 0x000000007359B000 000055 (v03 LENOVO TP-R23   000012E0 PTEC 00000002)
[    0.003653] ACPI: BATB 0x0000000073585000 00004A (v02 LENOVO TP-R23   000012E0 PTEC 00000002)
[    0.003655] ACPI: HPET 0x0000000071382000 000038 (v01 LENOVO TP-R23   000012E0 PTEC 00000002)
[    0.003657] ACPI: APIC 0x0000000071381000 00014C (v02 LENOVO TP-R23   000012E0 PTEC 00000002)
[    0.003658] ACPI: MCFG 0x0000000071380000 00003C (v01 LENOVO TP-R23   000012E0 PTEC 00000002)
[    0.003660] ACPI: SBST 0x000000007137F000 000030 (v01 LENOVO TP-R23   000012E0 PTEC 00000002)
[    0.003662] ACPI: WSMT 0x000000007137E000 000028 (v01 LENOVO TP-R23   000012E0 PTEC 00000002)
[    0.003663] ACPI: SSDT 0x0000000071363000 005354 (v02 LENOVO TP-R23   00000001 AMD  00000001)
[    0.003665] ACPI: CRAT 0x0000000071362000 000EC0 (v01 LENOVO TP-R23   000012E0 PTEC 00000002)
[    0.003667] ACPI: CDIT 0x0000000071361000 000029 (v01 LENOVO TP-R23   000012E0 PTEC 00000002)
[    0.003668] ACPI: VFCT 0x0000000071356000 00AE84 (v01 LENOVO TP-R23   000012E0 PTEC 00000002)
[    0.003670] ACPI: FPDT 0x0000000071355000 000034 (v01 LENOVO TP-R23   000012E0 PTEC 00000002)
[    0.003672] ACPI: SSDT 0x0000000073587000 000BC3 (v01 LENOVO TP-R23   00000001 INTL 20180313)
[    0.003673] ACPI: SSDT 0x000000007132D000 0015F7 (v01 LENOVO TP-R23   00000001 INTL 20180313)
[    0.003675] ACPI: SSDT 0x0000000071324000 0085B1 (v01 LENOVO TP-R23   00000001 INTL 20180313)
[    0.003676] ACPI: BGRT 0x0000000071323000 000038 (v01 LENOVO TP-R23   000012E0 PTEC 00000002)
[    0.003678] ACPI: SSDT 0x0000000071322000 0007CF (v01 LENOVO TP-R23   00000001 INTL 20180313)
[    0.003680] ACPI: SSDT 0x0000000071321000 000410 (v01 LENOVO TP-R23   00000001 INTL 20180313)
[    0.003681] ACPI: SSDT 0x0000000071320000 000024 (v01 LENOVO TP-R23   00000001 INTL 20180313)
[    0.003683] ACPI: SSDT 0x000000007131E000 001880 (v01 LENOVO TP-R23   00000001 INTL 20180313)
[    0.003685] ACPI: SSDT 0x0000000071314000 009B23 (v01 LENOVO TP-R23   00000001 INTL 20180313)
[    0.003686] ACPI: SSDT 0x000000007130E000 0051C4 (v01 LENOVO TP-R23   00000001 INTL 20180313)
[    0.003688] ACPI: SSDT 0x000000007130D000 000DB2 (v01 LENOVO TP-R23   00000001 INTL 20180313)
[    0.003690] ACPI: SSDT 0x000000007130C000 000762 (v01 LENOVO TP-R23   00000001 INTL 20180313)
[    0.003691] ACPI: UEFI 0x0000000077756000 00009E (v01 LENOVO TP-R23   000012E0 PTEC 00000002)
[    0.003693] ACPI: IVRS 0x000000007130B000 0001E4 (v02 LENOVO TP-R23   000012E0 PTEC 00000002)
[    0.003695] ACPI: SSDT 0x0000000073699000 000090 (v01 LENOVO TP-R23   00000001 INTL 20180313)
[    0.003696] ACPI: SSDT 0x0000000073697000 001203 (v01 LENOVO TP-R23   00000001 INTL 20180313)
[    0.003698] ACPI: Reserving FACP table memory at [mem 0x71383000-0x71383113]
[    0.003699] ACPI: Reserving DSDT table memory at [mem 0x71369000-0x7137dc23]
[    0.003699] ACPI: Reserving FACS table memory at [mem 0x77757000-0x7775703f]
[    0.003700] ACPI: Reserving SSDT table memory at [mem 0x7369b000-0x7369b0a1]
[    0.003700] ACPI: Reserving SSDT table memory at [mem 0x7369a000-0x7369aa92]
[    0.003701] ACPI: Reserving SSDT table memory at [mem 0x7362f000-0x73636f5a]
[    0.003701] ACPI: Reserving SSDT table memory at [mem 0x7362e000-0x7362e585]
[    0.003702] ACPI: Reserving SSDT table memory at [mem 0x7362d000-0x7362d1d7]
[    0.003702] ACPI: Reserving MSDM table memory at [mem 0x7359b000-0x7359b054]
[    0.003703] ACPI: Reserving BATB table memory at [mem 0x73585000-0x73585049]
[    0.003703] ACPI: Reserving HPET table memory at [mem 0x71382000-0x71382037]
[    0.003704] ACPI: Reserving APIC table memory at [mem 0x71381000-0x7138114b]
[    0.003704] ACPI: Reserving MCFG table memory at [mem 0x71380000-0x7138003b]
[    0.003705] ACPI: Reserving SBST table memory at [mem 0x7137f000-0x7137f02f]
[    0.003705] ACPI: Reserving WSMT table memory at [mem 0x7137e000-0x7137e027]
[    0.003706] ACPI: Reserving SSDT table memory at [mem 0x71363000-0x71368353]
[    0.003706] ACPI: Reserving CRAT table memory at [mem 0x71362000-0x71362ebf]
[    0.003707] ACPI: Reserving CDIT table memory at [mem 0x71361000-0x71361028]
[    0.003707] ACPI: Reserving VFCT table memory at [mem 0x71356000-0x71360e83]
[    0.003708] ACPI: Reserving FPDT table memory at [mem 0x71355000-0x71355033]
[    0.003708] ACPI: Reserving SSDT table memory at [mem 0x73587000-0x73587bc2]
[    0.003709] ACPI: Reserving SSDT table memory at [mem 0x7132d000-0x7132e5f6]
[    0.003709] ACPI: Reserving SSDT table memory at [mem 0x71324000-0x7132c5b0]
[    0.003710] ACPI: Reserving BGRT table memory at [mem 0x71323000-0x71323037]
[    0.003710] ACPI: Reserving SSDT table memory at [mem 0x71322000-0x713227ce]
[    0.003711] ACPI: Reserving SSDT table memory at [mem 0x71321000-0x7132140f]
[    0.003711] ACPI: Reserving SSDT table memory at [mem 0x71320000-0x71320023]
[    0.003712] ACPI: Reserving SSDT table memory at [mem 0x7131e000-0x7131f87f]
[    0.003712] ACPI: Reserving SSDT table memory at [mem 0x71314000-0x7131db22]
[    0.003713] ACPI: Reserving SSDT table memory at [mem 0x7130e000-0x713131c3]
[    0.003713] ACPI: Reserving SSDT table memory at [mem 0x7130d000-0x7130ddb1]
[    0.003714] ACPI: Reserving SSDT table memory at [mem 0x7130c000-0x7130c761]
[    0.003715] ACPI: Reserving UEFI table memory at [mem 0x77756000-0x7775609d]
[    0.003715] ACPI: Reserving IVRS table memory at [mem 0x7130b000-0x7130b1e3]
[    0.003716] ACPI: Reserving SSDT table memory at [mem 0x73699000-0x7369908f]
[    0.003716] ACPI: Reserving SSDT table memory at [mem 0x73697000-0x73698202]
[    0.003777] No NUMA configuration found
[    0.003777] Faking a node at [mem 0x0000000000000000-0x000000077e2fffff]
[    0.003780] NODE_DATA(0) allocated [mem 0x77e2fb000-0x77e2fffff]
[    0.003812] Zone ranges:
[    0.003813]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.003814]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.003815]   Normal   [mem 0x0000000100000000-0x000000077e2fffff]
[    0.003816]   Device   empty
[    0.003816] Movable zone start for each node
[    0.003817] Early memory node ranges
[    0.003817]   node   0: [mem 0x0000000000001000-0x000000000009ffff]
[    0.003818]   node   0: [mem 0x0000000000100000-0x0000000009bfffff]
[    0.003819]   node   0: [mem 0x0000000009da1000-0x0000000009efffff]
[    0.003820]   node   0: [mem 0x0000000009f28000-0x0000000070b7dfff]
[    0.003820]   node   0: [mem 0x00000000777fe000-0x0000000079ffcfff]
[    0.003821]   node   0: [mem 0x0000000100000000-0x000000077e2fffff]
[    0.003823] Initmem setup node 0 [mem 0x0000000000001000-0x000000077e2fffff]
[    0.003828] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.003848] On node 0, zone DMA: 96 pages in unavailable ranges
[    0.004018] On node 0, zone DMA32: 417 pages in unavailable ranges
[    0.006164] On node 0, zone DMA32: 40 pages in unavailable ranges
[    0.006446] On node 0, zone DMA32: 27776 pages in unavailable ranges
[    0.044687] On node 0, zone Normal: 24579 pages in unavailable ranges
[    0.044754] On node 0, zone Normal: 7424 pages in unavailable ranges
[    0.044976] ACPI: PM-Timer IO Port: 0x408
[    0.044986] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[    0.044988] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.044988] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.044989] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.044989] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[    0.044990] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[    0.044990] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[    0.044991] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[    0.044991] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[    0.044992] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[    0.044992] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[    0.044992] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[    0.044993] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[    0.044993] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[    0.044994] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[    0.044994] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[    0.045007] IOAPIC[0]: apic_id 32, version 33, address 0xfec00000, GSI 0-23
[    0.045012] IOAPIC[1]: apic_id 33, version 33, address 0xfec01000, GSI 24-55
[    0.045013] ACPI: INT_SRC_OVR (bus 0 bus_irq 1 global_irq 1 low edge)
[    0.045015] ACPI: INT_SRC_OVR (bus 0 bus_irq 12 global_irq 12 low edge)
[    0.045016] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.045017] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[    0.045019] ACPI: Using ACPI (MADT) for SMP configuration information
[    0.045020] ACPI: HPET id: 0x43538210 base: 0xfed00000
[    0.045030] e820: update [mem 0x6b74e000-0x6b7defff] usable ==> reserved
[    0.045044] CPU topo: Max. logical packages:   1
[    0.045044] CPU topo: Max. logical dies:       1
[    0.045045] CPU topo: Max. dies per package:   1
[    0.045048] CPU topo: Max. threads per core:   2
[    0.045049] CPU topo: Num. cores per package:     8
[    0.045050] CPU topo: Num. threads per package:  16
[    0.045050] CPU topo: Allowing 16 present CPUs plus 0 hotplug CPUs
[    0.045065] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.045067] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[    0.045068] PM: hibernation: Registered nosave memory: [mem 0x09c00000-0x09da0fff]
[    0.045069] PM: hibernation: Registered nosave memory: [mem 0x09f00000-0x09f27fff]
[    0.045070] PM: hibernation: Registered nosave memory: [mem 0x3d62c000-0x3d62cfff]
[    0.045071] PM: hibernation: Registered nosave memory: [mem 0x3d636000-0x3d636fff]
[    0.045072] PM: hibernation: Registered nosave memory: [mem 0x6b74e000-0x6b7defff]
[    0.045073] PM: hibernation: Registered nosave memory: [mem 0x6be9b000-0x6be9bfff]
[    0.045074] PM: hibernation: Registered nosave memory: [mem 0x70b7e000-0x7677dfff]
[    0.045075] PM: hibernation: Registered nosave memory: [mem 0x7677e000-0x7777dfff]
[    0.045075] PM: hibernation: Registered nosave memory: [mem 0x7777e000-0x777fdfff]
[    0.045076] PM: hibernation: Registered nosave memory: [mem 0x79ffd000-0x7bffffff]
[    0.045077] PM: hibernation: Registered nosave memory: [mem 0x7c000000-0x7cdfffff]
[    0.045077] PM: hibernation: Registered nosave memory: [mem 0x7ce00000-0x7fffffff]
[    0.045078] PM: hibernation: Registered nosave memory: [mem 0x80000000-0xdfffffff]
[    0.045078] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[    0.045078] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xfed7ffff]
[    0.045079] PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xfed80fff]
[    0.045079] PM: hibernation: Registered nosave memory: [mem 0xfed81000-0xffffffff]
[    0.045081] [mem 0x80000000-0xdfffffff] available for PCI devices
[    0.045082] Booting paravirtualized kernel on bare hardware
[    0.045084] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[    0.048919] setup_percpu: NR_CPUS:320 nr_cpumask_bits:16 nr_cpu_ids:16 nr_node_ids:1
[    0.049702] percpu: Embedded 66 pages/cpu s233472 r8192 d28672 u524288
[    0.049707] pcpu-alloc: s233472 r8192 d28672 u524288 alloc=1*2097152
[    0.049709] pcpu-alloc: [0] 00 01 02 03 [0] 04 05 06 07
[    0.049712] pcpu-alloc: [0] 08 09 10 11 [0] 12 13 14 15
[    0.049728] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64 root=UUID=5338bde3-ac29-4c5e-9fb3-efebf439e246 rw quiet cryptdevice=UUID=e85818be-44b8-43b9-b852-56ece99bf27d:luks-e85818be-44b8-43b9-b852-56ece99bf27d root=/dev/mapper/luks-e85818be-44b8-43b9-b852-56ece99bf27d apparmor=1 security=apparmor udev.log_priority=3
[    0.049799] Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64 cryptdevice=UUID=e85818be-44b8-43b9-b852-56ece99bf27d:luks-e85818be-44b8-43b9-b852-56ece99bf27d", will be passed to user space.
[    0.052478] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[    0.053743] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.053830] Fallback order for Node 0: 0
[    0.053836] Built 1 zonelists, mobility grouping on.  Total pages: 7279699
[    0.053837] Policy zone: Normal
[    0.054038] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[    0.054083] software IO TLB: area num 16.
[    0.111133] Memory: 28322264K/29118796K available (18432K kernel code, 2195K rwdata, 13512K rodata, 3444K init, 3436K bss, 796272K reserved, 0K cma-reserved)
[    0.111296] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=16, Nodes=1
[    0.111336] ftrace: allocating 50463 entries in 198 pages
[    0.121782] ftrace: allocated 198 pages with 4 groups
[    0.121848] Dynamic Preempt: full
[    0.121904] rcu: Preemptible hierarchical RCU implementation.
[    0.121905] rcu: 	RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=16.
[    0.121906] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
[    0.121907] 	Trampoline variant of Tasks RCU enabled.
[    0.121907] 	Rude variant of Tasks RCU enabled.
[    0.121907] 	Tracing variant of Tasks RCU enabled.
[    0.121908] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[    0.121909] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=16
[    0.121917] RCU Tasks: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1.
[    0.121919] RCU Tasks Rude: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1.
[    0.121921] RCU Tasks Trace: Setting shift to 4 and lim to 1 rcu_task_cb_adjust=1.
[    0.124844] NR_IRQS: 20736, nr_irqs: 1096, preallocated irqs: 16
[    0.125046] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.125218] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[    0.125247] Console: colour dummy device 80x25
[    0.125249] printk: legacy console [tty0] enabled
[    0.125286] ACPI: Core revision 20240322
[    0.125456] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[    0.125472] APIC: Switch to symmetric I/O mode setup
[    0.126306] AMD-Vi: ivrs, add hid:AMDI0020, uid:\_SB.FUR0, rdevid:160
[    0.126307] AMD-Vi: ivrs, add hid:AMDI0020, uid:\_SB.FUR1, rdevid:160
[    0.126308] AMD-Vi: ivrs, add hid:AMDI0020, uid:\_SB.FUR2, rdevid:160
[    0.126309] AMD-Vi: ivrs, add hid:AMDI0020, uid:\_SB.FUR3, rdevid:160
[    0.126309] AMD-Vi: Using global IVHD EFR:0x246577efa2254afa, EFR2:0x0
[    0.126655] x2apic: IRQ remapping doesn't support X2APIC mode
[    0.126662] APIC: Switched APIC routing to: physical flat
[    0.127412] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.142146] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x26d88341801, max_idle_ns: 440795299600 ns
[    0.142150] Calibrating delay loop (skipped), value calculated using timer frequency.. 5392.42 BogoMIPS (lpj=8983080)
[    0.142172] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[    0.142208] LVT offset 1 assigned for vector 0xf9
[    0.142348] LVT offset 2 assigned for vector 0xf4
[    0.142372] Last level iTLB entries: 4KB 512, 2MB 512, 4MB 256
[    0.142373] Last level dTLB entries: 4KB 2048, 2MB 2048, 4MB 1024, 1GB 0
[    0.142375] process: using mwait in idle threads
[    0.142377] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.142380] Spectre V2 : Mitigation: Retpolines
[    0.142380] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.142381] Spectre V2 : Spectre v2 / SpectreRSB : Filling RSB on VMEXIT
[    0.142382] Spectre V2 : Enabling Restricted Speculation for firmware calls
[    0.142383] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.142384] Spectre V2 : User space: Mitigation: STIBP always-on protection
[    0.142385] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[    0.142387] Speculative Return Stack Overflow: IBPB-extending microcode not applied!
[    0.142387] Speculative Return Stack Overflow: WARNING: See https://kernel.org/doc/html/latest/admin-guide/hw-vuln/srso.html for mitigation options.
[    0.142388] Speculative Return Stack Overflow: Vulnerable: Safe RET, no microcode
[    0.142394] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.142395] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.142396] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.142397] x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
[    0.142397] x86/fpu: Supporting XSAVE feature 0x800: 'Control-flow User registers'
[    0.142398] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.142399] x86/fpu: xstate_offset[9]:  832, xstate_sizes[9]:    8
[    0.142400] x86/fpu: xstate_offset[11]:  840, xstate_sizes[11]:   16
[    0.142401] x86/fpu: Enabled xstate features 0xa07, context size is 856 bytes, using 'compacted' format.
[    0.164925] Freeing SMP alternatives memory: 40K
[    0.164927] pid_max: default: 32768 minimum: 301
[    0.168088] LSM: initializing lsm=capability,landlock,lockdown,yama,bpf,apparmor
[    0.168096] landlock: Up and running.
[    0.168098] Yama: becoming mindful.
[    0.168103] LSM support for eBPF active
[    0.168118] AppArmor: AppArmor initialized
[    0.168173] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.168214] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.278839] smpboot: CPU0: AMD Ryzen 7 PRO 6850U with Radeon Graphics (family: 0x19, model: 0x44, stepping: 0x1)
[    0.279066] Performance Events: Fam17h+ core perfctr, AMD PMU driver.
[    0.279071] ... version:                0
[    0.279073] ... bit width:              48
[    0.279073] ... generic registers:      6
[    0.279074] ... value mask:             0000ffffffffffff
[    0.279076] ... max period:             00007fffffffffff
[    0.279076] ... fixed-purpose events:   0
[    0.279077] ... event mask:             000000000000003f
[    0.279161] signal: max sigframe size: 3376
[    0.279194] rcu: Hierarchical SRCU implementation.
[    0.279195] rcu: 	Max phase no-delay instances is 1000.
[    0.281472] MCE: In-kernel MCE decoding enabled.
[    0.281521] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.281655] smp: Bringing up secondary CPUs ...
[    0.281789] smpboot: x86: Booting SMP configuration:
[    0.281791] .... node  #0, CPUs:        #2  #4  #6  #8 #10 #12 #14  #1  #3  #5  #7  #9 #11 #13 #15
[    0.300816] Spectre V2 : Update user space SMT mitigation: STIBP always-on
[    0.315518] smp: Brought up 1 node, 16 CPUs
[    0.315518] smpboot: Total of 16 processors activated (86272.80 BogoMIPS)
[    0.319096] devtmpfs: initialized
[    0.319096] x86/mm: Memory block size: 128MB
[    0.321359] ACPI: PM: Registering ACPI NVS region [mem 0x09f00000-0x09f27fff] (163840 bytes)
[    0.321359] ACPI: PM: Registering ACPI NVS region [mem 0x7677e000-0x7777dfff] (16777216 bytes)
[    0.321359] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.321359] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[    0.321359] pinctrl core: initialized pinctrl subsystem
[    0.322151] PM: RTC time: 04:55:53, date: 2024-08-22
[    0.322151] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.322151] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[    0.322151] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.322151] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.322151] audit: initializing netlink subsys (disabled)
[    0.322189] audit: type=2000 audit(1724302553.196:1): state=initialized audit_enabled=0 res=1
[    0.322256] thermal_sys: Registered thermal governor 'fair_share'
[    0.322257] thermal_sys: Registered thermal governor 'bang_bang'
[    0.322258] thermal_sys: Registered thermal governor 'step_wise'
[    0.322260] thermal_sys: Registered thermal governor 'user_space'
[    0.322260] thermal_sys: Registered thermal governor 'power_allocator'
[    0.322267] cpuidle: using governor ladder
[    0.322267] cpuidle: using governor menu
[    0.322267] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.322267] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.322327] PCI: ECAM [mem 0xe0000000-0xefffffff] (base 0xe0000000) for domain 0000 [bus 00-ff]
[    0.322343] PCI: Using configuration type 1 for base access
[    0.322438] mtrr: your CPUs had inconsistent fixed MTRR settings
[    0.322439] mtrr: your CPUs had inconsistent variable MTRR settings
[    0.322440] mtrr: probably your BIOS does not setup all CPUs.
[    0.322441] mtrr: corrected configuration.
[    0.322471] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[    0.326664] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.326666] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[    0.326668] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.326669] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[    0.329653] Demotion targets for Node 0: null
[    0.329653] ACPI: Added _OSI(Module Device)
[    0.329653] ACPI: Added _OSI(Processor Device)
[    0.329653] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.329653] ACPI: Added _OSI(Processor Aggregator Device)
[    0.359642] ACPI: 20 ACPI AML tables successfully acquired and loaded
[    0.362787] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.379516] ACPI: USB4 _OSC: OS supports USB3+ DisplayPort+ PCIe+ XDomain+
[    0.379518] ACPI: USB4 _OSC: OS controls USB3+ DisplayPort+ PCIe+ XDomain+
[    0.379605] ACPI: _OSC evaluation for CPUs failed, trying _PDC
[    0.380148] ACPI: EC: EC started
[    0.380149] ACPI: EC: interrupt blocked
[    0.380419] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.380419] ACPI: \_SB_.PCI0.LPC0.EC0_: Boot DSDT EC used to handle transactions
[    0.380419] ACPI: Interpreter enabled
[    0.380419] ACPI: PM: (supports S0 S4 S5)
[    0.380419] ACPI: Using IOAPIC for interrupt routing
[    0.381620] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.381622] PCI: Ignoring E820 reservations for host bridge windows
[    0.382008] ACPI: Enabled 2 GPEs in block 00 to 1F
[    0.384100] ACPI: \_SB_.PCI0.GPP6.PXSX.WRST: New power resource
[    0.384298] ACPI: \_SB_.PCI0.GPP7.P0WW: New power resource
[    0.384736] ACPI: \_SB_.PCI0.GPP8.P0NV: New power resource
[    0.387949] ACPI: \_SB_.PCI0.GP11.PWRS: New power resource
[    0.388019] ACPI: \_SB_.PCI0.GP11: Overriding _PRW sleep state (S4) by S0 from power resources
[    0.388579] ACPI: \_SB_.PCI0.GP11.SWUS.PWRS: New power resource
[    0.389169] ACPI: \_SB_.PCI0.GP12.PWRS: New power resource
[    0.389238] ACPI: \_SB_.PCI0.GP12: Overriding _PRW sleep state (S4) by S0 from power resources
[    0.389789] ACPI: \_SB_.PCI0.GP12.SWUS.PWRS: New power resource
[    0.390114] ACPI: \_SB_.PCI0.GP17.PWRS: New power resource
[    0.390461] ACPI: \_SB_.PCI0.GP17.VGA_.PWRS: New power resource
[    0.390904] ACPI: \_SB_.PCI0.GP17.ACP_.PWRS: New power resource
[    0.391489] ACPI: \_SB_.PCI0.GP17.AZAL.PWRS: New power resource
[    0.392073] ACPI: \_SB_.PCI0.GP17.HDAU.PWRS: New power resource
[    0.392636] ACPI: \_SB_.PCI0.GP17.XHC0.PWRS: New power resource
[    0.393214] ACPI: \_SB_.PCI0.GP17.XHC0.RHUB.HS03.HS01.BTRT: New power resource
[    0.393654] ACPI: \_SB_.PCI0.GP17.XHC1.PWRS: New power resource
[    0.394390] ACPI: \_SB_.PCI0.GP18.SATA.P0S0: New power resource
[    0.394422] ACPI: \_SB_.PCI0.GP18.SATA.P3S0: New power resource
[    0.395044] ACPI: \_SB_.PCI0.GP19.NHI0.PWRS: New power resource
[    0.395114] ACPI: \_SB_.PCI0.GP19.NHI0: Overriding _PRW sleep state (S3) by S0 from power resources
[    0.395643] ACPI: \_SB_.PCI0.GP19.NHI1.PWRS: New power resource
[    0.395713] ACPI: \_SB_.PCI0.GP19.NHI1: Overriding _PRW sleep state (S3) by S0 from power resources
[    0.396038] ACPI: \_SB_.PCI0.GP19.XHC2.PWRS: New power resource
[    0.397020] ACPI: \_SB_.PCI0.GP19.XHC3.PWRS: New power resource
[    0.398003] ACPI: \_SB_.PCI0.GP19.XHC4.PWRS: New power resource
[    0.404811] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.404817] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[    0.405034] acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug AER]
[    0.405444] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME PCIeCapability LTR DPC]
[    0.405446] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    0.405942] PCI host bridge to bus 0000:00
[    0.405946] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000effff window]
[    0.405948] pci_bus 0000:00: root bus resource [mem 0x80000000-0xdfffffff window]
[    0.405950] pci_bus 0000:00: root bus resource [mem 0xf0000000-0xfdbfffff window]
[    0.405951] pci_bus 0000:00: root bus resource [mem 0x880000000-0xffffffffff window]
[    0.405953] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.405954] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.405956] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.405970] pci 0000:00:00.0: [1022:14b5] type 00 class 0x060000 conventional PCI endpoint
[    0.406056] pci 0000:00:00.2: [1022:14b6] type 00 class 0x080600 conventional PCI endpoint
[    0.406130] pci 0000:00:01.0: [1022:14b7] type 00 class 0x060000 conventional PCI endpoint
[    0.406194] pci 0000:00:02.0: [1022:14b7] type 00 class 0x060000 conventional PCI endpoint
[    0.406253] pci 0000:00:02.1: [1022:14ba] type 01 class 0x060400 PCIe Root Port
[    0.406276] pci 0000:00:02.1: PCI bridge to [bus 01]
[    0.406282] pci 0000:00:02.1:   bridge window [io  0x2000-0x2fff]
[    0.406285] pci 0000:00:02.1:   bridge window [mem 0x80a00000-0x80afffff]
[    0.406368] pci 0000:00:02.1: PME# supported from D0 D3hot D3cold
[    0.406542] pci 0000:00:02.2: [1022:14ba] type 01 class 0x060400 PCIe Root Port
[    0.406564] pci 0000:00:02.2: PCI bridge to [bus 02]
[    0.406572] pci 0000:00:02.2:   bridge window [mem 0x80000000-0x801fffff]
[    0.406652] pci 0000:00:02.2: PME# supported from D0 D3hot D3cold
[    0.406824] pci 0000:00:02.4: [1022:14ba] type 01 class 0x060400 PCIe Root Port
[    0.406846] pci 0000:00:02.4: PCI bridge to [bus 03]
[    0.406853] pci 0000:00:02.4:   bridge window [mem 0x80900000-0x809fffff]
[    0.406933] pci 0000:00:02.4: PME# supported from D0 D3hot D3cold
[    0.407093] pci 0000:00:03.0: [1022:14b7] type 00 class 0x060000 conventional PCI endpoint
[    0.407157] pci 0000:00:04.0: [1022:14b7] type 00 class 0x060000 conventional PCI endpoint
[    0.407225] pci 0000:00:08.0: [1022:14b7] type 00 class 0x060000 conventional PCI endpoint
[    0.407280] pci 0000:00:08.1: [1022:14b9] type 01 class 0x060400 PCIe Root Port
[    0.407296] pci 0000:00:08.1: PCI bridge to [bus 04]
[    0.407300] pci 0000:00:08.1:   bridge window [io  0x1000-0x1fff]
[    0.407302] pci 0000:00:08.1:   bridge window [mem 0x80500000-0x808fffff]
[    0.407308] pci 0000:00:08.1:   bridge window [mem 0x8b0000000-0x8c01fffff 64bit pref]
[    0.407315] pci 0000:00:08.1: enabling Extended Tags
[    0.407355] pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
[    0.407509] pci 0000:00:08.3: [1022:14b9] type 01 class 0x060400 PCIe Root Port
[    0.407525] pci 0000:00:08.3: PCI bridge to [bus 05]
[    0.407530] pci 0000:00:08.3:   bridge window [mem 0x80200000-0x804fffff]
[    0.407541] pci 0000:00:08.3: enabling Extended Tags
[    0.407583] pci 0000:00:08.3: PME# supported from D0 D3hot D3cold
[    0.407903] pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500 conventional PCI endpoint
[    0.408025] pci 0000:00:14.3: [1022:790e] type 00 class 0x060100 conventional PCI endpoint
[    0.408187] pci 0000:00:18.0: [1022:1679] type 00 class 0x060000 conventional PCI endpoint
[    0.408222] pci 0000:00:18.1: [1022:167a] type 00 class 0x060000 conventional PCI endpoint
[    0.408255] pci 0000:00:18.2: [1022:167b] type 00 class 0x060000 conventional PCI endpoint
[    0.408289] pci 0000:00:18.3: [1022:167c] type 00 class 0x060000 conventional PCI endpoint
[    0.408322] pci 0000:00:18.4: [1022:167d] type 00 class 0x060000 conventional PCI endpoint
[    0.408356] pci 0000:00:18.5: [1022:167e] type 00 class 0x060000 conventional PCI endpoint
[    0.408389] pci 0000:00:18.6: [1022:167f] type 00 class 0x060000 conventional PCI endpoint
[    0.408425] pci 0000:00:18.7: [1022:1680] type 00 class 0x060000 conventional PCI endpoint
[    0.408545] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000 PCIe Endpoint
[    0.408560] pci 0000:01:00.0: BAR 0 [io  0x2000-0x20ff]
[    0.408579] pci 0000:01:00.0: BAR 2 [mem 0x80a04000-0x80a04fff 64bit]
[    0.408591] pci 0000:01:00.0: BAR 4 [mem 0x80a00000-0x80a03fff 64bit]
[    0.408687] pci 0000:01:00.0: supports D1 D2
[    0.408688] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.408910] pci 0000:00:02.1: PCI bridge to [bus 01]
[    0.408999] pci 0000:02:00.0: [17cb:1103] type 00 class 0x028000 PCIe Endpoint
[    0.409016] pci 0000:02:00.0: BAR 0 [mem 0x80000000-0x801fffff 64bit]
[    0.409122] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[    0.409187] pci 0000:02:00.0: 4.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x1 link at 0000:00:02.2 (capable of 7.876 Gb/s with 8.0 GT/s PCIe x1 link)
[    0.409321] pci 0000:00:02.2: PCI bridge to [bus 02]
[    0.409389] pci 0000:03:00.0: [2646:5017] type 00 class 0x010802 PCIe Endpoint
[    0.409403] pci 0000:03:00.0: BAR 0 [mem 0x80900000-0x80903fff 64bit]
[    0.409629] pci 0000:00:02.4: PCI bridge to [bus 03]
[    0.409731] pci 0000:04:00.0: [1002:1681] type 00 class 0x030000 PCIe Legacy Endpoint
[    0.409744] pci 0000:04:00.0: BAR 0 [mem 0x8b0000000-0x8bfffffff 64bit pref]
[    0.409752] pci 0000:04:00.0: BAR 2 [mem 0x8c0000000-0x8c01fffff 64bit pref]
[    0.409758] pci 0000:04:00.0: BAR 4 [io  0x1000-0x10ff]
[    0.409764] pci 0000:04:00.0: BAR 5 [mem 0x80800000-0x8087ffff]
[    0.409773] pci 0000:04:00.0: enabling Extended Tags
[    0.409830] pci 0000:04:00.0: PME# supported from D1 D2 D3hot D3cold
[    0.409973] pci 0000:04:00.1: [1002:1640] type 00 class 0x040300 PCIe Legacy Endpoint
[    0.409982] pci 0000:04:00.1: BAR 0 [mem 0x808c8000-0x808cbfff]
[    0.410005] pci 0000:04:00.1: enabling Extended Tags
[    0.410040] pci 0000:04:00.1: PME# supported from D1 D2 D3hot D3cold
[    0.410131] pci 0000:04:00.2: [1022:1649] type 00 class 0x108000 PCIe Endpoint
[    0.410214] pci 0000:04:00.2: BAR 2 [mem 0x80700000-0x807fffff]
[    0.410224] pci 0000:04:00.2: BAR 5 [mem 0x808cc000-0x808cdfff]
[    0.410232] pci 0000:04:00.2: enabling Extended Tags
[    0.410356] pci 0000:04:00.3: [1022:161d] type 00 class 0x0c0330 PCIe Endpoint
[    0.410368] pci 0000:04:00.3: BAR 0 [mem 0x80500000-0x805fffff 64bit]
[    0.410394] pci 0000:04:00.3: enabling Extended Tags
[    0.410431] pci 0000:04:00.3: PME# supported from D0 D3hot D3cold
[    0.410541] pci 0000:04:00.4: [1022:161e] type 00 class 0x0c0330 PCIe Endpoint
[    0.410553] pci 0000:04:00.4: BAR 0 [mem 0x80600000-0x806fffff 64bit]
[    0.410579] pci 0000:04:00.4: enabling Extended Tags
[    0.410617] pci 0000:04:00.4: PME# supported from D0 D3hot D3cold
[    0.410713] pci 0000:04:00.5: [1022:15e2] type 00 class 0x048000 PCIe Endpoint
[    0.410721] pci 0000:04:00.5: BAR 0 [mem 0x80880000-0x808bffff]
[    0.410745] pci 0000:04:00.5: enabling Extended Tags
[    0.410780] pci 0000:04:00.5: PME# supported from D0 D3hot D3cold
[    0.410870] pci 0000:04:00.6: [1022:15e3] type 00 class 0x040300 PCIe Endpoint
[    0.410878] pci 0000:04:00.6: BAR 0 [mem 0x808c0000-0x808c7fff]
[    0.410901] pci 0000:04:00.6: enabling Extended Tags
[    0.410936] pci 0000:04:00.6: PME# supported from D0 D3hot D3cold
[    0.411051] pci 0000:00:08.1: PCI bridge to [bus 04]
[    0.411128] pci 0000:05:00.0: [1022:161f] type 00 class 0x0c0330 PCIe Endpoint
[    0.411144] pci 0000:05:00.0: BAR 0 [mem 0x80200000-0x802fffff 64bit]
[    0.411175] pci 0000:05:00.0: enabling Extended Tags
[    0.411221] pci 0000:05:00.0: PME# supported from D0 D3hot D3cold
[    0.411341] pci 0000:05:00.3: [1022:15d6] type 00 class 0x0c0330 PCIe Endpoint
[    0.411353] pci 0000:05:00.3: BAR 0 [mem 0x80300000-0x803fffff 64bit]
[    0.411379] pci 0000:05:00.3: enabling Extended Tags
[    0.411417] pci 0000:05:00.3: PME# supported from D0 D3hot D3cold
[    0.411509] pci 0000:05:00.4: [1022:15d7] type 00 class 0x0c0330 PCIe Endpoint
[    0.411521] pci 0000:05:00.4: BAR 0 [mem 0x80400000-0x804fffff 64bit]
[    0.411547] pci 0000:05:00.4: enabling Extended Tags
[    0.411584] pci 0000:05:00.4: PME# supported from D0 D3hot D3cold
[    0.411687] pci 0000:00:08.3: PCI bridge to [bus 05]
[    0.414685] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[    0.414764] ACPI: PCI: Interrupt link LNKB configured for IRQ 0
[    0.414822] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[    0.414898] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[    0.414969] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[    0.415022] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[    0.415075] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[    0.415128] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[    0.416928] Low-power S0 idle used by default for system suspend
[    0.417294] ACPI: EC: interrupt unblocked
[    0.417296] ACPI: EC: event unblocked
[    0.417299] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.417301] ACPI: EC: GPE=0xb
[    0.417302] ACPI: \_SB_.PCI0.LPC0.EC0_: Boot DSDT EC initialization complete
[    0.417304] ACPI: \_SB_.PCI0.LPC0.EC0_: EC: Used to handle transactions and events
[    0.418874] iommu: Default domain type: Translated
[    0.418874] iommu: DMA domain TLB invalidation policy: lazy mode
[    0.418961] SCSI subsystem initialized
[    0.418969] libata version 3.00 loaded.
[    0.418969] ACPI: bus type USB registered
[    0.418969] usbcore: registered new interface driver usbfs
[    0.418969] usbcore: registered new interface driver hub
[    0.418969] usbcore: registered new device driver usb
[    0.434026] EDAC MC: Ver: 3.0.0
[    0.434107] efivars: Registered efivars operations
[    0.434107] NetLabel: Initializing
[    0.434107] NetLabel:  domain hash size = 128
[    0.434107] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.434107] NetLabel:  unlabeled traffic allowed by default
[    0.434107] mctp: management component transport protocol core
[    0.434107] NET: Registered PF_MCTP protocol family
[    0.434107] PCI: Using ACPI for IRQ routing
[    0.441340] PCI: pci_cache_line_size set to 64 bytes
[    0.441391] e820: reserve RAM buffer [mem 0x09c00000-0x0bffffff]
[    0.441394] e820: reserve RAM buffer [mem 0x09f00000-0x0bffffff]
[    0.441395] e820: reserve RAM buffer [mem 0x3d62c018-0x3fffffff]
[    0.441396] e820: reserve RAM buffer [mem 0x6b74e000-0x6bffffff]
[    0.441397] e820: reserve RAM buffer [mem 0x6be9b000-0x6bffffff]
[    0.441398] e820: reserve RAM buffer [mem 0x70b7e000-0x73ffffff]
[    0.441399] e820: reserve RAM buffer [mem 0x79ffd000-0x7bffffff]
[    0.441400] e820: reserve RAM buffer [mem 0x77e300000-0x77fffffff]
[    0.442180] pci 0000:04:00.0: vgaarb: setting as boot VGA device
[    0.442180] pci 0000:04:00.0: vgaarb: bridge control possible
[    0.442180] pci 0000:04:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[    0.442180] vgaarb: loaded
[    0.442216] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[    0.442221] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[    0.446556] clocksource: Switched to clocksource tsc-early
[    0.446685] VFS: Disk quotas dquot_6.6.0
[    0.446692] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.446814] AppArmor: AppArmor Filesystem Enabled
[    0.446836] pnp: PnP ACPI init
[    0.447099] system 00:00: [mem 0xfec00000-0xfec01fff] could not be reserved
[    0.447102] system 00:00: [mem 0xfee00000-0xfee00fff] has been reserved
[    0.447104] system 00:00: [mem 0xe0000000-0xefffffff] has been reserved
[    0.448364] system 00:02: [io  0x0400-0x04cf] has been reserved
[    0.448364] system 00:02: [io  0x04d0-0x04d1] has been reserved
[    0.448364] system 00:02: [io  0x04d6] has been reserved
[    0.448364] system 00:02: [io  0x0c00-0x0c01] has been reserved
[    0.448364] system 00:02: [io  0x0c14] has been reserved
[    0.448364] system 00:02: [io  0x0c50-0x0c52] has been reserved
[    0.448364] system 00:02: [io  0x0c6c] has been reserved
[    0.448364] system 00:02: [io  0x0c6f] has been reserved
[    0.448364] system 00:02: [io  0x0cd0-0x0cdb] has been reserved
[    0.448364] system 00:03: [mem 0x000e0000-0x000fffff] could not be reserved
[    0.448364] system 00:03: [mem 0x00000000-0x01ffffff] could not be reserved
[    0.448364] system 00:03: [mem 0xffffffe0-0xffffffff] has been reserved
[    0.448364] system 00:03: [mem 0xfed00000-0xfed003ff] has been reserved
[    0.448364] system 00:03: [mem 0xfed61000-0xfed613ff] has been reserved
[    0.448364] system 00:03: [mem 0xfed80000-0xfed80fff] has been reserved
[    0.448577] pnp: PnP ACPI: found 6 devices
[    0.454642] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.454800] NET: Registered PF_INET protocol family
[    0.455067] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.466223] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    0.466253] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.466392] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.466665] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[    0.466750] TCP: Hash tables configured (established 262144 bind 65536)
[    0.466882] MPTCP token hash table entries: 32768 (order: 7, 786432 bytes, linear)
[    0.466939] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.467004] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.467074] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.467082] NET: Registered PF_XDP protocol family
[    0.467093] pci 0000:00:02.1: PCI bridge to [bus 01]
[    0.467102] pci 0000:00:02.1:   bridge window [io  0x2000-0x2fff]
[    0.467107] pci 0000:00:02.1:   bridge window [mem 0x80a00000-0x80afffff]
[    0.467114] pci 0000:00:02.2: PCI bridge to [bus 02]
[    0.467118] pci 0000:00:02.2:   bridge window [mem 0x80000000-0x801fffff]
[    0.467124] pci 0000:00:02.4: PCI bridge to [bus 03]
[    0.467128] pci 0000:00:02.4:   bridge window [mem 0x80900000-0x809fffff]
[    0.467135] pci 0000:00:08.1: PCI bridge to [bus 04]
[    0.467137] pci 0000:00:08.1:   bridge window [io  0x1000-0x1fff]
[    0.467143] pci 0000:00:08.1:   bridge window [mem 0x80500000-0x808fffff]
[    0.467145] pci 0000:00:08.1:   bridge window [mem 0x8b0000000-0x8c01fffff 64bit pref]
[    0.467149] pci 0000:00:08.3: PCI bridge to [bus 05]
[    0.467152] pci 0000:00:08.3:   bridge window [mem 0x80200000-0x804fffff]
[    0.467158] pci_bus 0000:00: resource 4 [mem 0x000a0000-0x000effff window]
[    0.467160] pci_bus 0000:00: resource 5 [mem 0x80000000-0xdfffffff window]
[    0.467161] pci_bus 0000:00: resource 6 [mem 0xf0000000-0xfdbfffff window]
[    0.467163] pci_bus 0000:00: resource 7 [mem 0x880000000-0xffffffffff window]
[    0.467164] pci_bus 0000:00: resource 8 [io  0x0000-0x0cf7 window]
[    0.467166] pci_bus 0000:00: resource 9 [io  0x0d00-0xffff window]
[    0.467168] pci_bus 0000:01: resource 0 [io  0x2000-0x2fff]
[    0.467169] pci_bus 0000:01: resource 1 [mem 0x80a00000-0x80afffff]
[    0.467171] pci_bus 0000:02: resource 1 [mem 0x80000000-0x801fffff]
[    0.467172] pci_bus 0000:03: resource 1 [mem 0x80900000-0x809fffff]
[    0.467174] pci_bus 0000:04: resource 0 [io  0x1000-0x1fff]
[    0.467175] pci_bus 0000:04: resource 1 [mem 0x80500000-0x808fffff]
[    0.467177] pci_bus 0000:04: resource 2 [mem 0x8b0000000-0x8c01fffff 64bit pref]
[    0.467178] pci_bus 0000:05: resource 1 [mem 0x80200000-0x804fffff]
[    0.467375] pci 0000:04:00.1: D0 power state depends on 0000:04:00.0
[    0.468317] PCI: CLS 32 bytes, default 64
[    0.468344] pci 0000:00:00.2: AMD-Vi: IOMMU performance counters supported
[    0.468403] Trying to unpack rootfs image as initramfs...
[    0.468406] pci 0000:00:01.0: Adding to iommu group 0
[    0.468434] pci 0000:00:02.0: Adding to iommu group 1
[    0.468448] pci 0000:00:02.1: Adding to iommu group 2
[    0.468461] pci 0000:00:02.2: Adding to iommu group 3
[    0.468474] pci 0000:00:02.4: Adding to iommu group 4
[    0.468492] pci 0000:00:03.0: Adding to iommu group 5
[    0.468511] pci 0000:00:04.0: Adding to iommu group 6
[    0.468535] pci 0000:00:08.0: Adding to iommu group 7
[    0.468547] pci 0000:00:08.1: Adding to iommu group 8
[    0.468560] pci 0000:00:08.3: Adding to iommu group 9
[    0.468583] pci 0000:00:14.0: Adding to iommu group 10
[    0.468595] pci 0000:00:14.3: Adding to iommu group 10
[    0.468648] pci 0000:00:18.0: Adding to iommu group 11
[    0.468661] pci 0000:00:18.1: Adding to iommu group 11
[    0.468673] pci 0000:00:18.2: Adding to iommu group 11
[    0.468686] pci 0000:00:18.3: Adding to iommu group 11
[    0.468698] pci 0000:00:18.4: Adding to iommu group 11
[    0.468710] pci 0000:00:18.5: Adding to iommu group 11
[    0.468722] pci 0000:00:18.6: Adding to iommu group 11
[    0.468734] pci 0000:00:18.7: Adding to iommu group 11
[    0.468758] pci 0000:01:00.0: Adding to iommu group 12
[    0.468771] pci 0000:02:00.0: Adding to iommu group 13
[    0.468786] pci 0000:03:00.0: Adding to iommu group 14
[    0.468811] pci 0000:04:00.0: Adding to iommu group 15
[    0.468826] pci 0000:04:00.1: Adding to iommu group 16
[    0.468840] pci 0000:04:00.2: Adding to iommu group 17
[    0.468854] pci 0000:04:00.3: Adding to iommu group 18
[    0.468869] pci 0000:04:00.4: Adding to iommu group 19
[    0.468884] pci 0000:04:00.5: Adding to iommu group 20
[    0.468898] pci 0000:04:00.6: Adding to iommu group 21
[    0.468912] pci 0000:05:00.0: Adding to iommu group 22
[    0.468927] pci 0000:05:00.3: Adding to iommu group 23
[    0.468940] pci 0000:05:00.4: Adding to iommu group 24
[    0.471289] AMD-Vi: Extended features (0x246577efa2254afa, 0x0): PPR NX GT [5] IA GA PC GA_vAPIC
[    0.471298] AMD-Vi: Interrupt remapping enabled
[    0.471393] AMD-Vi: Virtual APIC enabled
[    0.471409] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.471412] software IO TLB: mapped [mem 0x0000000066405000-0x000000006a405000] (64MB)
[    0.471483] LVT offset 0 assigned for vector 0x400
[    0.471594] perf: AMD IBS detected (0x000003fd)
[    0.471599] perf/amd_iommu: Detected AMD IOMMU #0 (2 banks, 4 counters/bank).
[    0.481836] Initialise system trusted keyrings
[    0.481851] Key type blacklist registered
[    0.481893] workingset: timestamp_bits=41 max_order=23 bucket_order=0
[    0.481906] zbud: loaded
[    0.482066] fuse: init (API version 7.40)
[    0.482265] integrity: Platform Keyring initialized
[    0.482269] integrity: Machine keyring initialized
[    0.490423] Key type asymmetric registered
[    0.490425] Asymmetric key parser 'x509' registered
[    0.490444] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    0.490491] io scheduler mq-deadline registered
[    0.490493] io scheduler kyber registered
[    0.490501] io scheduler bfq registered
[    0.492028] pcieport 0000:00:02.1: PME: Signaling with IRQ 34
[    0.492175] pcieport 0000:00:02.2: PME: Signaling with IRQ 35
[    0.492319] pcieport 0000:00:02.4: PME: Signaling with IRQ 36
[    0.492468] pcieport 0000:00:08.1: PME: Signaling with IRQ 37
[    0.492584] pcieport 0000:00:08.3: PME: Signaling with IRQ 38
[    0.492684] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    0.494910] ACPI: AC: AC Adapter [AC] (off-line)
[    0.494956] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[    0.494975] ACPI: button: Power Button [PWRB]
[    0.495009] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input1
[    0.495043] ACPI: button: Lid Switch [LID]
[    0.495067] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
[    0.495090] ACPI: button: Sleep Button [SLPB]
[    0.495120] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[    0.495158] ACPI: button: Power Button [PWRF]
[    0.495258] Estimated ratio of average max frequency by base frequency (times 1024): 1416
[    0.495272] Monitor-Mwait will be used to enter C-1 state
[    0.495277] ACPI: \_SB_.PLTF.C000: Found 3 idle states
[    0.495391] ACPI: \_SB_.PLTF.C001: Found 3 idle states
[    0.495505] ACPI: \_SB_.PLTF.C002: Found 3 idle states
[    0.495596] ACPI: \_SB_.PLTF.C003: Found 3 idle states
[    0.495693] ACPI: \_SB_.PLTF.C004: Found 3 idle states
[    0.495835] ACPI: \_SB_.PLTF.C005: Found 3 idle states
[    0.495965] ACPI: \_SB_.PLTF.C006: Found 3 idle states
[    0.496095] ACPI: \_SB_.PLTF.C007: Found 3 idle states
[    0.496230] ACPI: \_SB_.PLTF.C008: Found 3 idle states
[    0.496364] ACPI: \_SB_.PLTF.C009: Found 3 idle states
[    0.496493] ACPI: \_SB_.PLTF.C00A: Found 3 idle states
[    0.496618] ACPI: \_SB_.PLTF.C00B: Found 3 idle states
[    0.496752] ACPI: \_SB_.PLTF.C00C: Found 3 idle states
[    0.496876] ACPI: \_SB_.PLTF.C00D: Found 3 idle states
[    0.497012] ACPI: \_SB_.PLTF.C00E: Found 3 idle states
[    0.497139] ACPI: \_SB_.PLTF.C00F: Found 3 idle states
[    0.498350] thermal LNXTHERM:00: registered as thermal_zone0
[    0.498352] ACPI: thermal: Thermal Zone [THM0] (61 C)
[    0.498592] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    0.500163] ACPI: battery: Slot [BAT0] (battery present)
[    0.501368] Non-volatile memory driver v1.3
[    0.501370] Linux agpgart interface v0.103
[    0.501454] ACPI: bus type drm_connector registered
[    0.503400] usbcore: registered new interface driver usbserial_generic
[    0.503405] usbserial: USB Serial support registered for generic
[    0.503509] rtc_cmos 00:01: RTC can wake from S4
[    0.503735] rtc_cmos 00:01: registered as rtc0
[    0.503765] rtc_cmos 00:01: setting system clock to 2024-08-22T04:55:53 UTC (1724302553)
[    0.503790] rtc_cmos 00:01: alarms up to one month, y3k, 114 bytes nvram
[    0.505016] ledtrig-cpu: registered to indicate activity on CPUs
[    0.505387] [drm] Initialized simpledrm 1.0.0 20200625 for simple-framebuffer.0 on minor 0
[    0.506378] fbcon: Deferring console take-over
[    0.506381] simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
[    0.506440] hid: raw HID events driver (C) Jiri Kosina
[    0.506521] drop_monitor: Initializing network drop monitor service
[    0.506624] NET: Registered PF_INET6 protocol family
[    0.561001] Freeing initrd memory: 34600K
[    0.568586] Segment Routing with IPv6
[    0.568590] RPL Segment Routing with IPv6
[    0.568614] In-situ OAM (IOAM) with IPv6
[    0.568671] NET: Registered PF_PACKET protocol family
[    0.571002] microcode: Current revision: 0x0a404102
[    0.571718] resctrl: L3 allocation detected
[    0.571720] resctrl: MB allocation detected
[    0.571721] resctrl: L3 monitoring detected
[    0.571750] IPI shorthand broadcast: enabled
[    0.573669] sched_clock: Marking stable (572898137, 407503)->(771135474, -197829834)
[    0.573851] Timer migration: 2 hierarchy levels; 8 children per group; 2 crossnode level
[    0.574168] registered taskstats version 1
[    0.575304] Loading compiled-in X.509 certificates
[    0.577678] Loaded X.509 cert 'Build time autogenerated kernel key: 9681da52163db5a16aa46dd4f64344dc5bebefc2'
[    0.582642] zswap: loaded using pool zstd/zsmalloc
[    0.582719] Demotion targets for Node 0: null
[    0.583063] Key type .fscrypt registered
[    0.583064] Key type fscrypt-provisioning registered
[    0.583111] AppArmor: AppArmor sha256 policy hashing enabled
[    0.583769] integrity: Loading X.509 certificate: UEFI:db
[    0.583794] integrity: Loaded X.509 cert 'Lenovo Ltd.: ThinkPad Product CA 2012: 838b1f54c1550463f45f98700640f11069265949'
[    0.583796] integrity: Loading X.509 certificate: UEFI:db
[    0.583805] integrity: Loaded X.509 cert 'Lenovo UEFI CA 2014: 4b91a68732eaefdd2c8ffffc6b027ec3449e9c8f'
[    0.583806] integrity: Loading X.509 certificate: UEFI:db
[    0.583817] integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
[    0.583818] integrity: Loading X.509 certificate: UEFI:db
[    0.583830] integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
[    0.585149] blacklist: Duplicate blacklisted hash bin:80b4d96931bf0d02fd91a61e19d14f1da452e66db2408ca8604d411f92659f0a
[    0.585152] blacklist: Duplicate blacklisted hash bin:f52f83a3fa9cfbd6920f722824dbe4034534d25b8507246b3b957dac6e1bce7a
[    0.585153] blacklist: Duplicate blacklisted hash bin:c5d9d8a186e2c82d09afaa2a6f7f2e73870d3e64f72c4e08ef67796a840f0fbd
[    0.585155] blacklist: Duplicate blacklisted hash bin:1aec84b84b6c65a51220a9be7181965230210d62d6d33c48999c6b295a2b0a06
[    0.585156] blacklist: Duplicate blacklisted hash bin:c3a99a460da464a057c3586d83cef5f4ae08b7103979ed8932742df0ed530c66
[    0.585158] blacklist: Duplicate blacklisted hash bin:58fb941aef95a25943b3fb5f2510a0df3fe44c58c95e0ab80487297568ab9771
[    0.585159] blacklist: Duplicate blacklisted hash bin:5391c3a2fb112102a6aa1edc25ae77e19f5d6f09cd09eeb2509922bfcd5992ea
[    0.585161] blacklist: Duplicate blacklisted hash bin:d626157e1d6a718bc124ab8da27cbb65072ca03a7b6b257dbdcbbd60f65ef3d1
[    0.585162] blacklist: Duplicate blacklisted hash bin:d063ec28f67eba53f1642dbf7dff33c6a32add869f6013fe162e2c32f1cbe56d
[    0.585164] blacklist: Duplicate blacklisted hash bin:29c6eb52b43c3aa18b2cd8ed6ea8607cef3cfae1bafe1165755cf2e614844a44
[    0.585166] blacklist: Duplicate blacklisted hash bin:90fbe70e69d633408d3e170c6832dbb2d209e0272527dfb63d49d29572a6f44c
[    0.585167] blacklist: Duplicate blacklisted hash bin:106faceacfecfd4e303b74f480a08098e2d0802b936f8ec774ce21f31686689c
[    0.585169] blacklist: Duplicate blacklisted hash bin:174e3a0b5b43c6a607bbd3404f05341e3dcf396267ce94f8b50e2e23a9da920c
[    0.585170] blacklist: Duplicate blacklisted hash bin:2b99cf26422e92fe365fbf4bc30d27086c9ee14b7a6fff44fb2f6b9001699939
[    0.585172] blacklist: Duplicate blacklisted hash bin:2e70916786a6f773511fa7181fab0f1d70b557c6322ea923b2a8d3b92b51af7d
[    0.585174] blacklist: Duplicate blacklisted hash bin:3fce9b9fdf3ef09d5452b0f95ee481c2b7f06d743a737971558e70136ace3e73
[    0.585175] blacklist: Duplicate blacklisted hash bin:47cc086127e2069a86e03a6bef2cd410f8c55a6d6bdb362168c31b2ce32a5adf
[    0.585177] blacklist: Duplicate blacklisted hash bin:71f2906fd222497e54a34662ab2497fcc81020770ff51368e9e3d9bfcbfd6375
[    0.585179] blacklist: Duplicate blacklisted hash bin:82db3bceb4f60843ce9d97c3d187cd9b5941cd3de8100e586f2bda5637575f67
[    0.585180] blacklist: Duplicate blacklisted hash bin:8ad64859f195b5f58dafaa940b6a6167acd67a886e8f469364177221c55945b9
[    0.585182] blacklist: Duplicate blacklisted hash bin:8d8ea289cfe70a1c07ab7365cb28ee51edd33cf2506de888fbadd60ebf80481c
[    0.585184] blacklist: Duplicate blacklisted hash bin:aeebae3151271273ed95aa2e671139ed31a98567303a332298f83709a9d55aa1
[    0.585185] blacklist: Duplicate blacklisted hash bin:c409bdac4775add8db92aa22b5b718fb8c94a1462c1fe9a416b95d8a3388c2fc
[    0.585187] blacklist: Duplicate blacklisted hash bin:c617c1a8b1ee2a811c28b5a81b4c83d7c98b5b0c27281d610207ebe692c2967f
[    0.585188] blacklist: Duplicate blacklisted hash bin:c90f336617b8e7f983975413c997f10b73eb267fd8a10cb9e3bdbfc667abdb8b
[    0.585190] blacklist: Duplicate blacklisted hash bin:64575bd912789a2e14ad56f6341f52af6bf80cf94400785975e9f04e2d64d745
[    0.585192] blacklist: Duplicate blacklisted hash bin:45c7c8ae750acfbb48fc37527d6412dd644daed8913ccd8a24c94d856967df8e
[    0.585354] blacklist: Duplicate blacklisted hash bin:47ff1b63b140b6fc04ed79131331e651da5b2e2f170f5daef4153dc2fbc532b1
[    0.585356] blacklist: Duplicate blacklisted hash bin:5391c3a2fb112102a6aa1edc25ae77e19f5d6f09cd09eeb2509922bfcd5992ea
[    0.585391] blacklist: Duplicate blacklisted hash bin:80b4d96931bf0d02fd91a61e19d14f1da452e66db2408ca8604d411f92659f0a
[    0.585421] blacklist: Duplicate blacklisted hash bin:992d359aa7a5f789d268b94c11b9485a6b1ce64362b0edb4441ccc187c39647b
[    0.585462] blacklist: Duplicate blacklisted hash bin:c452ab846073df5ace25cca64d6b7a09d906308a1a65eb5240e3c4ebcaa9cc0c
[    0.585486] blacklist: Duplicate blacklisted hash bin:e051b788ecbaeda53046c70e6af6058f95222c046157b8c4c1b9c2cfc65f46e5
[    0.586380] PM:   Magic number: 4:977:919
[    0.586414] clockevents clockevent12: hash matches
[    0.586421] msr msr14: hash matches
[    0.590399] RAS: Correctable Errors collector initialized.
[    0.601624] clk: Disabling unused clocks
[    0.601628] PM: genpd: Disabling unused power domains
[    0.602739] Freeing unused decrypted memory: 2028K
[    0.603368] Freeing unused kernel image (initmem) memory: 3444K
[    0.603385] Write protecting the kernel read-only data: 32768k
[    0.603957] Freeing unused kernel image (rodata/data gap) memory: 824K
[    0.643126] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    0.643132] rodata_test: all tests were successful
[    0.643138] Run /init as init process
[    0.643140]   with arguments:
[    0.643141]     /init
[    0.643142]   with environment:
[    0.643143]     HOME=/
[    0.643144]     TERM=linux
[    0.643145]     BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64
[    0.643146]     cryptdevice=UUID=e85818be-44b8-43b9-b852-56ece99bf27d:luks-e85818be-44b8-43b9-b852-56ece99bf27d
[    0.817487] i8042: PNP: PS/2 Controller [PNP0303:KBD,PNP0f13:MOU] at 0x60,0x64 irq 1,12
[    0.818927] serio: i8042 KBD port at 0x60,0x64 irq 1
[    0.819008] serio: i8042 AUX port at 0x60,0x64 irq 12
[    0.819138] ACPI: video: Video Device [VGA] (multi-head: yes  rom: no  post: no)
[    0.819160] ccp 0000:04:00.2: enabling device (0000 -> 0002)
[    0.819427] xhci_hcd 0000:04:00.3: xHCI Host Controller
[    0.819434] xhci_hcd 0000:04:00.3: new USB bus registered, assigned bus number 1
[    0.819554] ccp 0000:04:00.2: psp: TSME enabled
[    0.819698] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0f/LNXVIDEO:00/input/input4
[    0.819828] xhci_hcd 0000:04:00.3: hcc params 0x0120ffc5 hci version 0x120 quirks 0x0000000200000010
[    0.820086] xhci_hcd 0000:04:00.3: xHCI Host Controller
[    0.820089] xhci_hcd 0000:04:00.3: new USB bus registered, assigned bus number 2
[    0.820092] xhci_hcd 0000:04:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[    0.820136] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.10
[    0.820139] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.820141] usb usb1: Product: xHCI Host Controller
[    0.820143] usb usb1: Manufacturer: Linux 6.10.3-1-MANJARO xhci-hcd
[    0.820144] usb usb1: SerialNumber: 0000:04:00.3
[    0.820276] hub 1-0:1.0: USB hub found
[    0.820292] hub 1-0:1.0: 4 ports detected
[    0.820612] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    0.820649] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.10
[    0.820652] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.820655] usb usb2: Product: xHCI Host Controller
[    0.820657] usb usb2: Manufacturer: Linux 6.10.3-1-MANJARO xhci-hcd
[    0.820659] usb usb2: SerialNumber: 0000:04:00.3
[    0.820785] hub 2-0:1.0: USB hub found
[    0.820803] hub 2-0:1.0: 2 ports detected
[    0.821065] cryptd: max_cpu_qlen set to 1000
[    0.821200] xhci_hcd 0000:04:00.4: xHCI Host Controller
[    0.821207] xhci_hcd 0000:04:00.4: new USB bus registered, assigned bus number 3
[    0.821583] xhci_hcd 0000:04:00.4: hcc params 0x0120ffc5 hci version 0x120 quirks 0x0000000200000010
[    0.821883] xhci_hcd 0000:04:00.4: xHCI Host Controller
[    0.821888] xhci_hcd 0000:04:00.4: new USB bus registered, assigned bus number 4
[    0.821892] xhci_hcd 0000:04:00.4: Host supports USB 3.1 Enhanced SuperSpeed
[    0.821944] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.10
[    0.821948] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.821950] usb usb3: Product: xHCI Host Controller
[    0.821952] usb usb3: Manufacturer: Linux 6.10.3-1-MANJARO xhci-hcd
[    0.821953] usb usb3: SerialNumber: 0000:04:00.4
[    0.822054] hub 3-0:1.0: USB hub found
[    0.822071] hub 3-0:1.0: 3 ports detected
[    0.822338] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    0.822383] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.10
[    0.822386] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.822388] usb usb4: Product: xHCI Host Controller
[    0.822390] usb usb4: Manufacturer: Linux 6.10.3-1-MANJARO xhci-hcd
[    0.822391] usb usb4: SerialNumber: 0000:04:00.4
[    0.822487] hub 4-0:1.0: USB hub found
[    0.822508] hub 4-0:1.0: 2 ports detected
[    0.822882] xhci_hcd 0000:05:00.0: xHCI Host Controller
[    0.822887] xhci_hcd 0000:05:00.0: new USB bus registered, assigned bus number 5
[    0.823383] ccp 0000:04:00.2: tee enabled
[    0.823636] ccp 0000:04:00.2: psp enabled
[    0.824180] xhci_hcd 0000:05:00.0: USB3 root hub has no ports
[    0.824184] xhci_hcd 0000:05:00.0: hcc params 0x0110ffc5 hci version 0x120 quirks 0x0000000200000010
[    0.824477] xhci_hcd 0000:05:00.0: xHCI Host Controller
[    0.824481] xhci_hcd 0000:05:00.0: new USB bus registered, assigned bus number 6
[    0.824486] xhci_hcd 0000:05:00.0: Host supports USB 3.0 SuperSpeed
[    0.824528] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.10
[    0.824531] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.824533] usb usb5: Product: xHCI Host Controller
[    0.824534] usb usb5: Manufacturer: Linux 6.10.3-1-MANJARO xhci-hcd
[    0.824536] usb usb5: SerialNumber: 0000:05:00.0
[    0.824635] hub 5-0:1.0: USB hub found
[    0.824656] hub 5-0:1.0: 1 port detected
[    0.824765] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    0.824788] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.10
[    0.824790] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.824792] usb usb6: Product: xHCI Host Controller
[    0.824794] usb usb6: Manufacturer: Linux 6.10.3-1-MANJARO xhci-hcd
[    0.824795] usb usb6: SerialNumber: 0000:05:00.0
[    0.824924] hub 6-0:1.0: USB hub found
[    0.824935] hub 6-0:1.0: config failed, hub doesn't have any ports! (err -19)
[    0.825165] xhci_hcd 0000:05:00.3: xHCI Host Controller
[    0.825171] xhci_hcd 0000:05:00.3: new USB bus registered, assigned bus number 7
[    0.825542] xhci_hcd 0000:05:00.3: hcc params 0x0110ffc5 hci version 0x120 quirks 0x0000000200000010
[    0.826068] xhci_hcd 0000:05:00.3: xHCI Host Controller
[    0.826072] xhci_hcd 0000:05:00.3: new USB bus registered, assigned bus number 8
[    0.826075] xhci_hcd 0000:05:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[    0.826113] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.10
[    0.826115] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.826117] usb usb7: Product: xHCI Host Controller
[    0.826119] usb usb7: Manufacturer: Linux 6.10.3-1-MANJARO xhci-hcd
[    0.826120] usb usb7: SerialNumber: 0000:05:00.3
[    0.826289] hub 7-0:1.0: USB hub found
[    0.826312] hub 7-0:1.0: 1 port detected
[    0.826503] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
[    0.826530] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.10
[    0.826533] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.826534] usb usb8: Product: xHCI Host Controller
[    0.826536] usb usb8: Manufacturer: Linux 6.10.3-1-MANJARO xhci-hcd
[    0.826537] usb usb8: SerialNumber: 0000:05:00.3
[    0.826636] hub 8-0:1.0: USB hub found
[    0.826652] hub 8-0:1.0: 1 port detected
[    0.827365] xhci_hcd 0000:05:00.4: xHCI Host Controller
[    0.827371] xhci_hcd 0000:05:00.4: new USB bus registered, assigned bus number 9
[    0.827744] xhci_hcd 0000:05:00.4: hcc params 0x0110ffc5 hci version 0x120 quirks 0x0000000200000010
[    0.828236] xhci_hcd 0000:05:00.4: xHCI Host Controller
[    0.828240] xhci_hcd 0000:05:00.4: new USB bus registered, assigned bus number 10
[    0.828243] xhci_hcd 0000:05:00.4: Host supports USB 3.1 Enhanced SuperSpeed
[    0.828280] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.10
[    0.828283] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.828284] usb usb9: Product: xHCI Host Controller
[    0.828286] usb usb9: Manufacturer: Linux 6.10.3-1-MANJARO xhci-hcd
[    0.828287] usb usb9: SerialNumber: 0000:05:00.4
[    0.828409] hub 9-0:1.0: USB hub found
[    0.828429] hub 9-0:1.0: 1 port detected
[    0.828632] nvme 0000:03:00.0: platform quirk: setting simple suspend
[    0.828661] usb usb10: We don't know the algorithms for LPM for this host, disabling LPM.
[    0.828691] usb usb10: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.10
[    0.828695] usb usb10: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.828697] usb usb10: Product: xHCI Host Controller
[    0.828700] usb usb10: Manufacturer: Linux 6.10.3-1-MANJARO xhci-hcd
[    0.828702] usb usb10: SerialNumber: 0000:05:00.4
[    0.828715] nvme nvme0: pci function 0000:03:00.0
[    0.828911] hub 10-0:1.0: USB hub found
[    0.828924] hub 10-0:1.0: 1 port detected
[    0.831720] AVX2 version of gcm_enc/dec engaged.
[    0.831773] AES CTR mode by8 optimization enabled
[    0.866294] nvme nvme0: allocated 64 MiB host memory buffer.
[    0.891180] nvme nvme0: 8/0/0 default/read/poll queues
[    1.069713] usb 1-3: new high-speed USB device number 2 using xhci_hcd
[    1.072977] usb 3-3: new full-speed USB device number 2 using xhci_hcd
[    1.076296] usb 5-1: new high-speed USB device number 2 using xhci_hcd
[    1.102462]  nvme0n1: p1 p2 p3 p4 p5 p6 p7
[    1.111641] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input5
[    1.119451] thinkpad_acpi: ThinkPad ACPI Extras v0.26
[    1.119453] thinkpad_acpi: http://ibm-acpi.sf.net/
[    1.119454] thinkpad_acpi: ThinkPad BIOS R23ET70W (1.40 ), EC R23HT64W
[    1.119455] thinkpad_acpi: Lenovo ThinkPad P16s Gen 1, model 21CK0034GE
[    1.120212] thinkpad_acpi: radio switch found; radios are enabled
[    1.120217] thinkpad_acpi: This ThinkPad has standard ACPI backlight brightness control, supported by the ACPI video driver
[    1.120218] thinkpad_acpi: Disabling thinkpad-acpi brightness events by default...
[    1.123341] thinkpad_acpi: rfkill switch tpacpi_bluetooth_sw: radio is unblocked
[    1.126898] thinkpad_acpi: Standard ACPI backlight interface available, not loading native one
[    1.142833] thinkpad_acpi: battery 1 registered (start 0, stop 100, behaviours: 0x7)
[    1.142848] ACPI: battery: new extension: ThinkPad Battery Extension
[    1.158245] input: ThinkPad Extra Buttons as /devices/platform/thinkpad_acpi/input/input7
[    1.213726] usb 1-3: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=61.60
[    1.213734] usb 1-3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    1.213736] usb 1-3: Product: USB2.0 Hub
[    1.220958] usb 5-1: New USB device found, idVendor=174f, idProduct=1812, bcdDevice=10.20
[    1.220961] usb 5-1: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[    1.220963] usb 5-1: Product: Integrated Camera
[    1.220965] usb 5-1: Manufacturer:
[    1.220967] usb 5-1: SerialNumber: 0001
[    1.234086] usb 3-3: New USB device found, idVendor=06cb, idProduct=00f9, bcdDevice= 0.00
[    1.234089] usb 3-3: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[    1.234091] usb 3-3: SerialNumber: 29640a8b3ca5
[    1.268478] hub 1-3:1.0: USB hub found
[    1.269052] hub 1-3:1.0: 3 ports detected
[    1.483778] tsc: Refined TSC clocksource calibration: 2694.961 MHz
[    1.483785] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x26d8a641443, max_idle_ns: 440795233662 ns
[    1.490428] clocksource: Switched to clocksource tsc
[    1.613776] usb 1-3.1: new full-speed USB device number 3 using xhci_hcd
[    1.718120] usb 1-3.1: New USB device found, idVendor=10ab, idProduct=9309, bcdDevice= 0.01
[    1.718127] usb 1-3.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.857373] usb 1-3.2: new full-speed USB device number 4 using xhci_hcd
[    1.977367] usb 1-3.2: New USB device found, idVendor=058f, idProduct=9540, bcdDevice= 1.20
[    1.977374] usb 1-3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.977378] usb 1-3.2: Product: EMV Smartcard Reader
[    1.977381] usb 1-3.2: Manufacturer: Generic
[    2.471012] [drm] amdgpu kernel modesetting enabled.
[    2.485714] amdgpu: Virtual CRAT table created for CPU
[    2.485731] amdgpu: Topology: Add CPU node
[    2.485882] amdgpu 0000:04:00.0: enabling device (0006 -> 0007)
[    2.485963] [drm] initializing kernel modesetting (YELLOW_CARP 0x1002:0x1681 0x17AA:0x50B7 0xD1).
[    2.487358] [drm] register mmio base: 0x80800000
[    2.487363] [drm] register mmio size: 524288
[    2.491866] [drm] add ip block number 0 <nv_common>
[    2.491869] [drm] add ip block number 1 <gmc_v10_0>
[    2.491872] [drm] add ip block number 2 <navi10_ih>
[    2.491873] [drm] add ip block number 3 <psp>
[    2.491874] [drm] add ip block number 4 <smu>
[    2.491876] [drm] add ip block number 5 <dm>
[    2.491878] [drm] add ip block number 6 <gfx_v10_0>
[    2.491880] [drm] add ip block number 7 <sdma_v5_2>
[    2.491882] [drm] add ip block number 8 <vcn_v3_0>
[    2.491884] [drm] add ip block number 9 <jpeg_v3_0>
[    2.491911] amdgpu 0000:04:00.0: amdgpu: Fetched VBIOS from VFCT
[    2.491914] amdgpu: ATOM BIOS: 113-REMBRANDT-X37
[    2.493452] [drm] VCN(0) decode is enabled in VM mode
[    2.493454] [drm] VCN(0) encode is enabled in VM mode
[    2.493863] [drm] JPEG decode is enabled in VM mode
[    2.531652] amdgpu 0000:04:00.0: vgaarb: deactivate vga console
[    2.531666] amdgpu 0000:04:00.0: amdgpu: Trusted Memory Zone (TMZ) feature disabled as experimental (default)
[    2.531735] [drm] vm size is 262144 GB, 4 levels, block size is 9-bit, fragment size is 9-bit
[    2.531744] amdgpu 0000:04:00.0: amdgpu: VRAM: 4096M 0x000000F400000000 - 0x000000F4FFFFFFFF (4096M used)
[    2.531747] amdgpu 0000:04:00.0: amdgpu: GART: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
[    2.531755] [drm] Detected VRAM RAM=4096M, BAR=4096M
[    2.531757] [drm] RAM width 128bits LPDDR5
[    2.532751] [drm] amdgpu: 4096M of VRAM memory ready
[    2.532754] [drm] amdgpu: 13913M of GTT memory ready.
[    2.532778] [drm] GART: num cpu pages 262144, num gpu pages 262144
[    2.533204] [drm] PCIE GART of 1024M enabled (table at 0x000000F4FFC00000).
[    2.533856] [drm] Loading DMUB firmware via PSP: version=0x04000044
[    2.534434] [drm] use_doorbell being set to: [true]
[    2.534462] [drm] Found VCN firmware Version ENC: 1.31 DEC: 3 VEP: 0 Revision: 2
[    2.534470] amdgpu 0000:04:00.0: amdgpu: Will use PSP to load VCN firmware
[    2.558296] amdgpu 0000:04:00.0: amdgpu: reserve 0xa00000 from 0xf4fe000000 for PSP TMR
[    2.735107] amdgpu 0000:04:00.0: amdgpu: RAS: optional ras ta ucode is not available
[    2.747606] amdgpu 0000:04:00.0: amdgpu: RAP: optional rap ta ucode is not available
[    2.747610] amdgpu 0000:04:00.0: amdgpu: SECUREDISPLAY: securedisplay ta ucode is not available
[    2.749937] amdgpu 0000:04:00.0: amdgpu: SMU is initialized successfully!
[    2.749941] [drm] Seamless boot condition check passed
[    2.750928] [drm] Display Core v3.2.281 initialized on DCN 3.1
[    2.750931] [drm] DP-HDMI FRL PCON supported
[    2.752992] [drm] DMUB hardware initialized: version=0x04000044
[    2.820792] [drm] PSR support 1, DC PSR ver 0, sink PSR ver 1 DPCD caps 0xb su_y_granularity 0
[    2.823094] [drm] kiq ring mec 2 pipe 1 q 0
[    2.827154] [drm] JPEG decode initialized successfully.
[    2.829255] kfd kfd: amdgpu: Allocated 3969056 bytes on gart
[    2.829272] kfd kfd: amdgpu: Total number of KFD nodes to be created: 1
[    2.830189] amdgpu: Virtual CRAT table created for GPU
[    2.830344] amdgpu: Topology: Add dGPU node [0x1681:0x1002]
[    2.830346] kfd kfd: amdgpu: added device 1002:1681
[    2.830364] amdgpu 0000:04:00.0: amdgpu: SE 1, SH per SE 2, CU per SH 6, active_cu_number 12
[    2.830370] amdgpu 0000:04:00.0: amdgpu: ring gfx_0.0.0 uses VM inv eng 0 on hub 0
[    2.830372] amdgpu 0000:04:00.0: amdgpu: ring gfx_0.1.0 uses VM inv eng 1 on hub 0
[    2.830374] amdgpu 0000:04:00.0: amdgpu: ring comp_1.0.0 uses VM inv eng 4 on hub 0
[    2.830375] amdgpu 0000:04:00.0: amdgpu: ring comp_1.1.0 uses VM inv eng 5 on hub 0
[    2.830376] amdgpu 0000:04:00.0: amdgpu: ring comp_1.2.0 uses VM inv eng 6 on hub 0
[    2.830378] amdgpu 0000:04:00.0: amdgpu: ring comp_1.3.0 uses VM inv eng 7 on hub 0
[    2.830379] amdgpu 0000:04:00.0: amdgpu: ring comp_1.0.1 uses VM inv eng 8 on hub 0
[    2.830380] amdgpu 0000:04:00.0: amdgpu: ring comp_1.1.1 uses VM inv eng 9 on hub 0
[    2.830381] amdgpu 0000:04:00.0: amdgpu: ring comp_1.2.1 uses VM inv eng 10 on hub 0
[    2.830383] amdgpu 0000:04:00.0: amdgpu: ring comp_1.3.1 uses VM inv eng 11 on hub 0
[    2.830384] amdgpu 0000:04:00.0: amdgpu: ring kiq_0.2.1.0 uses VM inv eng 12 on hub 0
[    2.830385] amdgpu 0000:04:00.0: amdgpu: ring sdma0 uses VM inv eng 13 on hub 0
[    2.830386] amdgpu 0000:04:00.0: amdgpu: ring vcn_dec_0 uses VM inv eng 0 on hub 8
[    2.830387] amdgpu 0000:04:00.0: amdgpu: ring vcn_enc_0.0 uses VM inv eng 1 on hub 8
[    2.830389] amdgpu 0000:04:00.0: amdgpu: ring vcn_enc_0.1 uses VM inv eng 4 on hub 8
[    2.830390] amdgpu 0000:04:00.0: amdgpu: ring jpeg_dec uses VM inv eng 5 on hub 8
[    2.832735] amdgpu 0000:04:00.0: amdgpu: Runtime PM not available
[    2.834083] [drm] Initialized amdgpu 3.57.0 20150101 for 0000:04:00.0 on minor 1
[    2.864723] fbcon: amdgpudrmfb (fb0) is primary device
[    2.864726] fbcon: Deferring console take-over
[    2.864728] amdgpu 0000:04:00.0: [drm] fb0: amdgpudrmfb frame buffer device
[    2.945138] device-mapper: uevent: version 1.0.3
[    2.945233] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@lists.linux.dev
[    3.166122] Key type encrypted registered
[   11.877862] fbcon: Taking over console
[   11.881799] [drm] DSC precompute is not needed.
[   11.964484] EXT4-fs (dm-0): mounted filesystem 5338bde3-ac29-4c5e-9fb3-efebf439e246 r/w with ordered data mode. Quota mode: none.
[   12.970508] Console: switching to colour frame buffer device 240x75
[   13.024406] systemd[1]: systemd 256.4-1-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT +LIBARCHIVE)
[   13.024413] systemd[1]: Detected architecture x86-64.
[   13.025846] systemd[1]: Hostname set to <WS37-martini>.
[   13.280643] systemd[1]: bpf-restrict-fs: LSM BPF program attached
[   13.487943] systemd[1]: /usr/lib/systemd/system/teamviewerd.service:9: PIDFile= references a path below legacy directory /var/run/, updating /var/run/teamviewerd.pid → /run/teamviewerd.pid; please update the unit file accordingly.
[   13.492664] systemd[1]: Queued start job for default target Graphical Interface.
[   13.556517] systemd[1]: Created slice Slice /system/dirmngr.
[   13.556890] systemd[1]: Created slice Slice /system/getty.
[   13.557182] systemd[1]: Created slice Slice /system/gpg-agent.
[   13.557446] systemd[1]: Created slice Slice /system/gpg-agent-browser.
[   13.557718] systemd[1]: Created slice Slice /system/gpg-agent-extra.
[   13.557970] systemd[1]: Created slice Slice /system/gpg-agent-ssh.
[   13.558237] systemd[1]: Created slice Slice /system/keyboxd.
[   13.558488] systemd[1]: Created slice Slice /system/modprobe.
[   13.558733] systemd[1]: Created slice Encrypted Volume Units Service Slice.
[   13.559020] systemd[1]: Created slice Slice /system/systemd-fsck.
[   13.559210] systemd[1]: Created slice User and Session Slice.
[   13.559276] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   13.559313] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   13.559508] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   13.559526] systemd[1]: Expecting device /dev/disk/by-uuid/3E9F-5CF2...
[   13.559532] systemd[1]: Expecting device /dev/disk/by-uuid/e85818be-44b8-43b9-b852-56ece99bf27d...
[   13.559549] systemd[1]: Reached target Login Prompts.
[   13.559562] systemd[1]: Reached target Local Integrity Protected Volumes.
[   13.559581] systemd[1]: Reached target Remote File Systems.
[   13.559590] systemd[1]: Reached target Slice Units.
[   13.559601] systemd[1]: Reached target Mounting snaps.
[   13.559625] systemd[1]: Reached target Local Verity Protected Volumes.
[   13.559689] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[   13.559771] systemd[1]: Listening on LVM2 poll daemon socket.
[   13.560921] systemd[1]: Listening on Process Core Dump Socket.
[   13.561431] systemd[1]: Listening on Credential Encryption/Decryption.
[   13.561511] systemd[1]: Listening on Journal Socket (/dev/log).
[   13.561578] systemd[1]: Listening on Journal Sockets.
[   13.561614] systemd[1]: TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   13.561625] systemd[1]: Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   13.561686] systemd[1]: Listening on udev Control Socket.
[   13.561731] systemd[1]: Listening on udev Kernel Socket.
[   13.561777] systemd[1]: Listening on User Database Manager Socket.
[   13.562772] systemd[1]: Mounting Huge Pages File System...
[   13.563475] systemd[1]: Mounting POSIX Message Queue File System...
[   13.564063] systemd[1]: Mounting Kernel Debug File System...
[   13.564667] systemd[1]: Mounting Kernel Trace File System...
[   13.565458] systemd[1]: Starting Load AppArmor profiles...
[   13.566278] systemd[1]: Starting Create List of Static Device Nodes...
[   13.566904] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[   13.567595] systemd[1]: Starting Load Kernel Module configfs...
[   13.568165] systemd[1]: Starting Load Kernel Module dm_mod...
[   13.568750] systemd[1]: Starting Load Kernel Module drm...
[   13.569403] systemd[1]: Starting Load Kernel Module fuse...
[   13.570037] systemd[1]: Starting Load Kernel Module loop...
[   13.570107] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[   13.570152] systemd[1]: Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
[   13.571852] systemd[1]: Starting Journal Service...
[   13.573393] systemd[1]: Starting Load Kernel Modules...
[   13.573415] systemd[1]: TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   13.574123] systemd[1]: Starting Remount Root and Kernel File Systems...
[   13.574170] systemd[1]: Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   13.574745] systemd[1]: Starting Load udev Rules from Credentials...
[   13.575469] systemd[1]: Starting Coldplug All udev Devices...
[   13.577846] systemd[1]: Mounted Huge Pages File System.
[   13.577949] systemd[1]: Mounted POSIX Message Queue File System.
[   13.578037] systemd[1]: Mounted Kernel Debug File System.
[   13.578382] systemd[1]: Mounted Kernel Trace File System.
[   13.578671] systemd[1]: Finished Create List of Static Device Nodes.
[   13.578975] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[   13.579142] systemd[1]: Finished Load Kernel Module configfs.
[   13.579373] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[   13.579539] systemd[1]: Finished Load Kernel Module dm_mod.
[   13.579788] systemd[1]: modprobe@drm.service: Deactivated successfully.
[   13.579857] loop: module loaded
[   13.579972] systemd[1]: Finished Load Kernel Module drm.
[   13.580182] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[   13.580338] systemd[1]: Finished Load Kernel Module fuse.
[   13.580565] systemd[1]: modprobe@loop.service: Deactivated successfully.
[   13.580732] systemd[1]: Finished Load Kernel Module loop.
[   13.581762] systemd[1]: Mounting FUSE Control File System...
[   13.582373] systemd[1]: Mounting Kernel Configuration File System...
[   13.582425] systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
[   13.583380] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
[   13.586719] systemd[1]: Finished Load udev Rules from Credentials.
[   13.586850] systemd[1]: Mounted FUSE Control File System.
[   13.587184] systemd-journald[448]: Collecting audit messages is disabled.
[   13.587199] systemd[1]: Mounted Kernel Configuration File System.
[   13.590372] vboxdrv: loading out-of-tree module taints kernel.
[   13.590380] vboxdrv: module verification failed: signature and/or required key missing - tainting kernel
[   13.607244] vboxdrv: Found 16 processor cores/threads
[   13.615356] audit: type=1400 audit(1724302566.607:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="klogd" pid=476 comm="apparmor_parser"
[   13.616449] audit: type=1400 audit(1724302566.607:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-anvil" pid=480 comm="apparmor_parser"
[   13.616930] systemd[1]: Starting User Database Manager...
[   13.633603] audit: type=1400 audit(1724302566.623:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=469 comm="apparmor_parser"
[   13.633615] audit: type=1400 audit(1724302566.623:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=469 comm="apparmor_parser"
[   13.633619] audit: type=1400 audit(1724302566.623:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=468 comm="apparmor_parser"
[   13.637109] EXT4-fs (dm-0): re-mounted 5338bde3-ac29-4c5e-9fb3-efebf439e246 r/w. Quota mode: none.
[   13.643768] audit: type=1400 audit(1724302566.633:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ping" pid=466 comm="apparmor_parser"
[   13.644577] vboxdrv: TSC mode is Invariant, tentative frequency 2694962019 Hz
[   13.644581] vboxdrv: Successfully loaded version 7.0.20 r163906 (interface 0x00330004)
[   13.647750] systemd[1]: Finished Remount Root and Kernel File Systems.
[   13.649142] audit: type=1400 audit(1724302566.640:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-rpcd" pid=473 comm="apparmor_parser"
[   13.649553] systemd[1]: Activating swap /swapfile...
[   13.649599] VBoxNetAdp: Successfully started.
[   13.650344] systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
[   13.651344] audit: type=1400 audit(1724302566.643:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-rpcd-spoolss" pid=475 comm="apparmor_parser"
[   13.653133] systemd[1]: Starting Load/Save OS Random Seed...
[   13.653178] systemd[1]: TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   13.653474] VBoxNetFlt: Successfully started.
[   13.655373] systemd[1]: Started Journal Service.
[   13.656113] audit: type=1400 audit(1724302566.647:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-dcerpcd" pid=472 comm="apparmor_parser"
[   13.659814] audit: type=1400 audit(1724302566.650:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-bgqd" pid=471 comm="apparmor_parser"
[   13.695883] systemd-journald[448]: Received client request to flush runtime journal.
[   13.714841] Adding 67108860k swap on /swapfile.  Priority:-2 extents:522 across:162938876k SS
[   13.961638] acpi-tad ACPI000E:00: Missing _PRW
[   13.981992] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[   13.982001] piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
[   13.984054] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
[   14.020580] RAPL PMU: API unit is 2^-32 Joules, 1 fixed counters, 163840 ms ovfl timer
[   14.020589] RAPL PMU: hw unit of domain package 2^-16 Joules
[   14.071607] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[   14.075348] sp5100-tco sp5100-tco: Using 0xfeb00000 for watchdog MMIO address
[   14.078678] sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
[   14.090770] Bluetooth: Core ver 2.22
[   14.090813] NET: Registered PF_BLUETOOTH protocol family
[   14.090816] Bluetooth: HCI device and connection manager initialized
[   14.090824] Bluetooth: HCI socket layer initialized
[   14.090829] Bluetooth: L2CAP socket layer initialized
[   14.090836] Bluetooth: SCO socket layer initialized
[   14.090982] mc: Linux media interface: v0.10
[   14.124287] kvm_amd: TSC scaling supported
[   14.124292] kvm_amd: Nested Virtualization enabled
[   14.124294] kvm_amd: Nested Paging enabled
[   14.124297] kvm_amd: LBR virtualization supported
[   14.124325] kvm_amd: Virtual VMLOAD VMSAVE supported
[   14.124326] kvm_amd: Virtual GIF supported
[   14.195925] input: ELAN0688:00 04F3:320B Mouse as /devices/platform/AMDI0010:01/i2c-1/i2c-ELAN0688:00/0018:04F3:320B.0001/input/input21
[   14.196001] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   14.196065] input: ELAN0688:00 04F3:320B Touchpad as /devices/platform/AMDI0010:01/i2c-1/i2c-ELAN0688:00/0018:04F3:320B.0001/input/input23
[   14.196203] hid-generic 0018:04F3:320B.0001: input,hidraw0: I2C HID v1.00 Mouse [ELAN0688:00 04F3:320B] on i2c-ELAN0688:00
[   14.197401] r8169 0000:01:00.0: enabling device (0000 -> 0003)
[   14.198306] r8169 0000:01:00.0: can't disable ASPM; OS doesn't have ASPM control
[   14.199466] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   14.199572] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[   14.209095] snd_pci_acp6x 0000:04:00.5: enabling device (0000 -> 0002)
[   14.209792] videodev: Linux video capture interface: v2.00
[   14.213680] r8169 0000:01:00.0 eth0: RTL8168ep/8111ep, 6c:24:08:c6:74:9a, XID 502, IRQ 65
[   14.213687] r8169 0000:01:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[   14.213690] r8169 0000:01:00.0 eth0: DASH disabled
[   14.214124] usbcore: registered new interface driver btusb
[   14.216703] r8169 0000:01:00.0 enp1s0f0: renamed from eth0
[   14.221929] Bluetooth: hci0: using rampatch file: qca/rampatch_usb_00130201.bin
[   14.221935] Bluetooth: hci0: QCA: patch rome 0x130201 build 0x65e2, firmware rome 0x130201 build 0x38e6
[   14.262664] snd_hda_intel 0000:04:00.1: enabling device (0000 -> 0002)
[   14.263934] snd_hda_intel 0000:04:00.1: Handle vga_switcheroo audio client
[   14.264583] snd_hda_intel 0000:04:00.6: enabling device (0000 -> 0002)
[   14.266611] usb 5-1: Found UVC 1.10 device Integrated Camera (174f:1812)
[   14.274850] usb 5-1: Found UVC 1.50 device Integrated Camera (174f:1812)
[   14.276847] usbcore: registered new interface driver uvcvideo
[   14.280495] snd_hda_intel 0000:04:00.1: bound 0000:04:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
[   14.285722] input: HD-Audio Generic HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.1/sound/card0/input24
[   14.287349] input: HD-Audio Generic HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:08.1/0000:04:00.1/sound/card0/input25
[   14.287399] input: HD-Audio Generic HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:08.1/0000:04:00.1/sound/card0/input26
[   14.291939] ath11k_pci 0000:02:00.0: BAR 0 [mem 0x80000000-0x801fffff 64bit]: assigned
[   14.291966] ath11k_pci 0000:02:00.0: enabling device (0000 -> 0002)
[   14.292714] ath11k_pci 0000:02:00.0: MSI vectors: 32
[   14.292722] ath11k_pci 0000:02:00.0: wcn6855 hw2.1
[   14.296834] input: ELAN0688:00 04F3:320B Mouse as /devices/platform/AMDI0010:01/i2c-1/i2c-ELAN0688:00/0018:04F3:320B.0001/input/input27
[   14.296912] input: ELAN0688:00 04F3:320B Touchpad as /devices/platform/AMDI0010:01/i2c-1/i2c-ELAN0688:00/0018:04F3:320B.0001/input/input29
[   14.296983] hid-multitouch 0018:04F3:320B.0001: input,hidraw0: I2C HID v1.00 Mouse [ELAN0688:00 04F3:320B] on i2c-ELAN0688:00
[   14.312838] NET: Registered PF_QIPCRTR protocol family
[   14.313392] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC257: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[   14.313398] snd_hda_codec_realtek hdaudioC1D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   14.313401] snd_hda_codec_realtek hdaudioC1D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[   14.313404] snd_hda_codec_realtek hdaudioC1D0:    mono: mono_out=0x0
[   14.313406] snd_hda_codec_realtek hdaudioC1D0:    inputs:
[   14.313408] snd_hda_codec_realtek hdaudioC1D0:      Mic=0x19
[   14.342327] mousedev: PS/2 mouse device common for all mice
[   14.346312] intel_rapl_common: Found RAPL domain package
[   14.346317] intel_rapl_common: Found RAPL domain core
[   14.346395] AMD Address Translation Library initialized
[   14.386363] input: HD-Audio Generic Mic as /devices/pci0000:00/0000:00:08.1/0000:04:00.6/sound/card1/input30
[   14.386457] input: HD-Audio Generic Headphone as /devices/pci0000:00/0000:00:08.1/0000:04:00.6/sound/card1/input31
[   14.410508] acp_yc_mach acp_yc_mach.0: Enabling ACP DMIC support via DMI
[   14.410621] acp_yc_mach acp_yc_mach.0: Enabling ACP DMIC support via DMI
[   14.469637] mhi mhi0: Requested to power ON
[   14.469657] mhi mhi0: Power on setup success
[   14.492401] psmouse serio1: trackpoint: Elan TrackPoint firmware: 0x00, buttons: 3/3
[   14.504431] input: TPPS/2 Elan TrackPoint as /devices/platform/i8042/serio1/input/input20
[   14.567569] mhi mhi0: Wait for device to enter SBL or Mission mode
[   14.640548] loop0: detected capacity change from 0 to 130960
[   14.640749] loop1: detected capacity change from 0 to 8
[   14.643399] loop2: detected capacity change from 0 to 716176
[   14.643921] loop3: detected capacity change from 0 to 187776
[   14.647401] loop4: detected capacity change from 0 to 672
[   14.648112] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[   14.648996] loop5: detected capacity change from 0 to 79520
[   14.780850] Bluetooth: hci0: using NVM file: qca/nvm_usb_00130201_gf.bin
[   14.923878] Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
[   15.203471] ath11k_pci 0000:02:00.0: chip_id 0x12 chip_family 0xb board_id 0xff soc_id 0x400c1211
[   15.203481] ath11k_pci 0000:02:00.0: fw_version 0x1106196e fw_build_timestamp 2024-01-12 11:30 fw_build_id WLAN.HSP.1.1-03125-QCAHSPSWPL_V1_V2_SILICONZ_LITE-3.6510.37
[   15.550838] ath11k_pci 0000:02:00.0 wlp2s0: renamed from wlan0
[   15.788451] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   15.788455] Bluetooth: BNEP filters: protocol multicast
[   15.788464] Bluetooth: BNEP socket layer initialized
[   15.789720] Bluetooth: MGMT ver 1.22
[   15.795545] NET: Registered PF_ALG protocol family
[   15.901188] loop6: detected capacity change from 0 to 8
[   15.957130] Generic FE-GE Realtek PHY r8169-0-100:00: attached PHY driver (mii_bus:phy_addr=r8169-0-100:00, irq=MAC)
[   16.077421] r8169 0000:01:00.0 enp1s0f0: Link is Down
[   25.196133] Bluetooth: RFCOMM TTY layer initialized
[   25.196151] Bluetooth: RFCOMM socket layer initialized
[   25.196155] Bluetooth: RFCOMM ver 1.11
[   26.299713] wlp2s0: authenticate with be:6a:0d:ee:4f:c9 (local address=04:7b:cb:2c:4f:28)
[   26.299726] wlp2s0: send auth to be:6a:0d:ee:4f:c9 (try 1/3)
[   26.367095] wlp2s0: authenticate with be:6a:0d:ee:4f:c9 (local address=04:7b:cb:2c:4f:28)
[   26.367103] wlp2s0: send auth to be:6a:0d:ee:4f:c9 (try 1/3)
[   26.372519] wlp2s0: authenticated
[   26.373776] wlp2s0: associate with be:6a:0d:ee:4f:c9 (try 1/3)
[   26.380273] wlp2s0: RX AssocResp from be:6a:0d:ee:4f:c9 (capab=0x431 status=0 aid=1)
[   26.394813] wlp2s0: associated
[   26.642952] wlp2s0: Limiting TX power to 20 (20 - 0) dBm as advertised by be:6a:0d:ee:4f:c9
[   31.170412] block nvme0n1: No UUID available providing old NGUID
[   31.413253] warning: `nextcloud' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
[   47.940816] SUPR0GipMap: fGetGipCpu=0x3b
[   57.672727] vboxdrv: 0000000035e3d020 VMMR0.r0
[   57.861748] vboxdrv: 00000000aaa8e1aa VBoxDDR0.r0
[   57.957456] VBoxNetFlt: attached to '4026531840/wlp2s0' / 04:7b:cb:2c:4f:28
