Kernel panic with 6.10.3 except when a VM running
Strange indeed.
That particular model is appearing a little too often.
That is even more strange.
So keeping the CPU active and busy prevents kernel panic?
I would seem it is somehow coupled with the specific iteration of the AMD Ryzen 7 PRO 6850U series. I have ThinkPad with 7840U - I don’t see these issues?
Has anyone of you tested Linux 6.11.0-rc4 - unstable?
 $ mbn info linux611 -q
Branch         : unstable
Version        : 6.11.0rc4-3
Repository     : core
Build Date     : Tue 20 Aug 2024 00:20:01
Packager       : Manjaro Build Server <build@manjaro.org>
Branch         : testing
Version        : 6.11.0rc3-2
Repository     : core
Build Date     : Tue 13 Aug 2024 10:33:18
Branch         : stable
Repository     : core
Also see → Lenovo ThinkPad P16s (AMD) Gen 2 - ArchWiki
In your log - I see a reference to ibm-acpi.sf.net.
A search for ThinkPad ACPI Extras v0.26 leads to the conclusion it is not supported for your device.
The package tp_smapi is - for what I recall - for older Thinkpads - could this cause the kernel panic?
Does not work on:
Yes - I know the module is in the repos - for all kernels and DKMS - but that does not imply it can be used for any Thinkpad.
I tested 6.11.0-rc-unstable, same behaviour
tp_smapi Module is not installed
It also happens, when the CPU is active and busy
Well one has to speculate why the above line appears in your log - ecpcially considering that the list of supported ThinkPads → Thinkpad-acpi - ThinkWiki does not include P16s
Have you installed any ThinkPad specific packages from the repos?
Have you build any custom ThinkPad related sources?
Have you tried disabling the virtual extensions in the firmware?
If you do require the virtual extensions - at least try disabling as a test - and try to reproduce the issue.
Nope , only acpi
also no
Also System freeze and Kernelpanic
Have you considered uninstalling VirtualBox, including the kernel modules (specifically vboxdrv)?
My reasoning is that the problem seems to be linked to VMs, so perhaps there’s some issue with VirtualBox, and in particular the kernel module, that’s causing a kernel panic when no VMs are loaded. I have no idea why that would be the case, but it seems worth checking.
Yep. And i saw similar reports from people like me.
That is vague
That is still too vague…
There is no indication that your AMD cpu or system for that matter is the same as OP.
The kernel is the software that interacts with the system.
Kernel panic describes a situation where the kernel meets unexpected values or conditions - and don’t know how to handle them. This can be caused by a bug in the kernel or a driver or a failure in a hardware component.
Basically most hardware has their own CPU’s which is preconfigured with yet another type of kernel - that goes for disk devices, usb devices, cpus, gpus - and the list goes on.
Since kernel panic can have a broad range of causes and since it is stated that running a virtual machine stablilized the system
One could
  • boot a live ISO and test the system ram using memtest+
  • test with virtualization enabled and disabled
  • enable - disable virtual extension in the firmware
  • test the system with extensions enabled and disabled
I have two systems running AMD - I have never had random kernel panic - ever…
