blp92
February 15, 2023, 5:32am
1
When I boot into my Majaro, no matter which of the 2 kernels I use I’m getting a kernel panic. I’m using my TV as a monitor currently but the overscan makes it so I can’t quite make out the first character or two per line. I think the lines begin with [2
but I could be wrong. Here’s a transcription of the error message I did from another computer so there’s likely a typo or two:
nvme0n1p6: clean, 499807/2621440 files. 7613422/10485760 blocks
"init: error while loading shared libraries: libcrypto.so.1.1: cannot open shared object file: no such file or directory
[2.290172] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00
[2.301519] CPU: 4 PID: 1 comm: init Not tainted 5.10.129-MANJARO #1
[2.301574] Hardware name: Micro-Star International Co., Ltd. MS-7885/8450 GAMING PRO CARBON AC(MS-7885). BIOS 1.F4 04/22/2021
[2.301671] Call Trace:
[2.301696] dump_stack+0x6b/0x83
[2.301726] panic_0x108/0x2fc
[2.301753] do_exit.cold+0x6f/-xb3
[2.301784] do_group_exit+0x33/0xa0
[2.301815] __x64_sys_exit_group+0x14/0x20
[2.301851] do_syscall_64+0x33/0x40
[2.301884] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[2.301927] RIP: 0033:0x7f1fb7d99651
[2.301958] Code: 1f 84 00 00 00 00 00 66 96 f3 0f1e fa be e7 00 00 00 ba 3c 00 00 00 eb 0d 89 d0 0f 05 48 3d 00 f0 ff ff 77 1f f4 89 f0 0f 05 <48> 3d 00 f0 ff ff 76 e7 f7 d8 89 06 ff 3b 01 00 eb dd 0f 1f 44 00
[2.302112] RSP: 002b:00004ffcb8d88e18 EFLAGS: 00000246 ORIG_RAX: 00000000000000e7
[2.302176] RAX: ffffffffffffffda RBX: 00007f1fb7da3588 RCX: 00007f1fb7d99651
[2.302236] RDX: 000000000000003c RSI: 00000000000000e7 RDI: 000000000000007f
[2.302296] RBP: 00007f1fb74e03ff R08: 00004ffcb8d88e28 R09: 00000000b7da0000
[2.302355] R10: 0000000000000020 R11: 0000000000000246 R12: 0000000000000002
[2.302415] R13: 00004f1fb74e0410 R14: 0000000000000011 R15: 0000000000000000
[2.303042] Kernel Offset: 0x9200000 from 0xfffffffff8000000 (relocation range: 0xffffffff80000000-0xffffffffbffffff)
[2.303140] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00 ]---
This happens whether I boot into any of the following kernels:
Manjaro Linux (Kernel: 5.13.19-2-MANJARO x64)
Manjaro Linux (Kernel: 5.13.19-2-MANJARO x64 - fallback initramfs)
Manjaro Linux (Kernel: 5.18.129-1-MANJARO x64)
Manjaro Linux (Kernel: 5.18.129-1-MANJARO x64 - fallback initramfs)
All your kernels are [EOL] !
chroot, then install a LTS-kernel !
chroot
How to boot from USB into live Manjaro (for repair):
Hi newbi question my desktop is XFCE my pc is 64bit 60gig hardrive. I did a recent up date and now manjaro won’t boot up. I get a message saying I need to have a kernel installed first. I’ve tried advanced option but even the fallback won’t boot. I did some research that it’s possible to recover my installed system by chroot using usb but not really sure what to do after I get the message below. In the terminal I typed “manjaro-chroot -a” below is the message I got.
“Mounting (ManjaroLinux) …
Please install 2 kernels (one of them LTS)
reboot,
then remove your EOL-kernels !
When using manjaro you have to stay up to date. You can’t stay with kernels that are [EOL].
No that is wrong. You can stay with EOL-kernels. Trouble ahead !
blp92
February 15, 2023, 7:41pm
3
So I’ve booted to a live USB and done manjaro-chroot -a
which gave me:
[manjaro@manjaro ~]$ manjaro-chroot -a
grub-probe: error: cannot find a GRUB drive for /dev/sda1. Check your device.map.
==> Mounting (ManjaroLinux) [/dev/nvme0n1p6]
--> mount: [/mnt]
--> mount: [/mnt/boot/efi]
--> mount: [/mnt/home]
Then to see what I currently have I did mhwd-kernel -li
which output:
6.1.11-1-MANJARO (linux61)
pacman: error while loading shared libraries: libcrypto.so.1.1: cannot open shared object file: No such file or directory
to install the newest kernel it looks like LTS is 5.15.94 and stable is 6.1.12 so would I just do:
mhwd-kernel -i linux61
and
mhwd-kernel -i linux515
blp92
February 16, 2023, 1:04am
4
Okay sure enough there is no libcrypto.so.1.1
in /usr/lib/
so I tried downloading openssl-3.0.8-1-x86_64.pkg.tar.zst
from the Belnet mirrors but now I’m a little stuck. Since I’m in chroot
I have full access to my home distro but I can’t figure out how to navigate to the live media downloads so I can unpackage and then copy the libcrypto.so.1.1
to my desktop’s /usr/bin/
. How to I access both from the chroot
environment?
blp92
February 16, 2023, 7:14pm
5
I think I have the general approach figured out but want to confirm before I do anything that might further damage my install.
download the package that contains libcrypto.so.1.1
(not sure exactly which one that would be but my next best guess is openssl-1.1-1.1.1.t-1-x86_64.pkg.tar.zst
) to some directory in my live media
Use tar
to unpackage that
move or copy /usr/bin/libcrypto.so.1.1
(if I understand it right this is the live media’s /usr/bin/
) to my desktop’s file system. I’m not 100% sure how to do that, but I think I need to go from outside the chroot environment and copy to the desktop’s filesystem, then chroot into the desktop’s file system and move it to that /usr/bin/
update kernel using mhwd-kernel -i linux61
and mhwd-kernel -i linux515
exit chroot
reboot
Can someone let me know if that’s correct and how I can do the copy from the live media to the filesystem directory outside of the chroot environment?
brahma
February 16, 2023, 7:20pm
6
can you install it from chroot:
pacman -S openssl lib32-openssl
if there are errors post them here
blp92
February 16, 2023, 7:39pm
7
it doesn’t seem like I can do anything from chroot
directly because pacman depends on libcrypto.so.1.1
but I will confirm shortly
blp92
February 16, 2023, 7:44pm
8
Yeah can’t do that because of the missing libcrypto.so.1.1
[manjaro /]# pacman -S openssl lib32-openssl
brahma
February 16, 2023, 7:48pm
9
ok, so use external pacman, so first exit chroot:
exit
then run this:
sudo sed -i 's/ trap/#trap/' /usr/lib/manjaro-tools/util-mount.sh
exit | manjaro-chroot -a
sudo pacman --sysroot /mnt -S openssl lib32-openssl --overwrite '*'
then remove the old kernels if you didnt already done it:
sudo pacman --sysroot /mnt -R linux513 linux518
then install the newer kernel:
sudo pacman --sysroot /mnt -S linux515
then rerun update:
sudo pacman --sysroot /mnt -Syu
since you didnt updated your system for some time…
when done, and there were no errors, reboot and see if you can boot normally
blp92
February 16, 2023, 8:09pm
10
Got to the part where I install the new kernels and got extensive error messages:
[manjaro@manjaro ~]$ sudo pacman --sysroot /mnt -S linux515
resolving dependencies...
Packages (1) linux515-5.15.93-1
Total Download Size: 100.18 MiB
Total Installed Size: 104.67 MiB
:: Proceed with installation? [Y/n] Y
:: Retrieving packages...
linux515-5.15.93-1-x86_64 100.2 MiB 20.3 MiB/s 00:05 [#####################################################] 100%
(1/1) checking keys in keyring [#####################################################] 100%
(1/1) checking package integrity [#####################################################] 100%
(1/1) loading package files [#####################################################] 100%
(1/1) checking for file conflicts [#####################################################] 100%
(1/1) checking available disk space [#####################################################] 100%
(1/1) installing linux515 [#####################################################] 100%
Optional dependencies for linux515
wireless-regdb: to set the correct wireless channels of your country [installed]
(1/4) Arming ConditionNeedsUpdate...
(2/4) Updating module dependencies...
depmod: error while loading shared libraries: libcrypto.so.1.1: cannot open shared object file: No such file or directory
(3/4) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'default'
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64.img
==> Starting build: 5.15.93-1-MANJARO
-> Running build hook: [base]
==> ERROR: binary dependency `libcrypto.so.1.1' not found for `kmod'
-> Running build hook: [udev]
==> ERROR: binary dependency `libcrypto.so.1.1' not found for `/usr/lib/systemd/systemd-udevd'
==> ERROR: binary dependency `libcrypto.so.1.1' not found for `/usr/bin/udevadm'
==> ERROR: binary dependency `libcrypto.so.1.1' not found for `/usr/bin/systemd-tmpfiles'
==> ERROR: binary dependency `libcrypto.so.1.1' not found for `/usr/lib/udev/ata_id'
==> ERROR: binary dependency `libcrypto.so.1.1' not found for `/usr/lib/udev/scsi_id'
sort: error while loading shared libraries: libcrypto.so.1.1: cannot open shared object file: No such file or directory
modprobe: error while loading shared libraries: libcrypto.so.1.1: cannot open shared object file: No such file or directory
==> ERROR: module not found: `floppy'
==> ERROR: module not found: `null_blk'
==> ERROR: module not found: `rbd'
==> ERROR: module not found: `pktcdvd'
==> ERROR: module not found: `aoe'
==> ERROR: module not found: `loop'
==> ERROR: module not found: `rsxx'
==> ERROR: module not found: `drbd'
==> ERROR: module not found: `xen_blkback'
==> ERROR: module not found: `virtio_blk'
==> ERROR: module not found: `cryptoloop'
==> ERROR: module not found: `sx8'
==> ERROR: module not found: `brd'
==> ERROR: module not found: `nbd'
==> ERROR: module not found: `rnbd_server'
==> ERROR: module not found: `rnbd_client'
==> ERROR: module not found: `mtip32xx'
==> ERROR: module not found: `zram'
==> ERROR: module not found: `xen_blkfront'
==> ERROR: module not found: `esp_scsi'
==> ERROR: module not found: `mpt3sas'
==> ERROR: module not found: `qedi'
==> ERROR: module not found: `cdns_pltfrm'
==> ERROR: module not found: `ufshcd_pci'
==> ERROR: module not found: `ufshcd_core'
==> ERROR: module not found: `ufshcd_pltfrm'
==> ERROR: module not found: `bnx2fc'
==> ERROR: module not found: `hpsa'
==> ERROR: module not found: `hv_storvsc'
==> ERROR: module not found: `fdomain_pci'
==> ERROR: module not found: `snic'
==> ERROR: module not found: `imm'
==> ERROR: module not found: `dc395x'
==> ERROR: module not found: `isci'
==> ERROR: module not found: `myrb'
==> ERROR: module not found: `scsi_dh_rdac'
==> ERROR: module not found: `scsi_dh_hp_sw'
==> ERROR: module not found: `scsi_dh_emc'
==> ERROR: module not found: `scsi_dh_alua'
==> ERROR: module not found: `scsi_transport_spi'
==> ERROR: module not found: `aic7xxx'
==> ERROR: module not found: `aic79xx'
==> ERROR: module not found: `qla4xxx'
==> ERROR: module not found: `hptiop'
==> ERROR: module not found: `atp870u'
==> ERROR: module not found: `efct'
==> ERROR: module not found: `raid_class'
==> ERROR: module not found: `tcm_qla2xxx'
==> ERROR: module not found: `qla2xxx'
==> ERROR: module not found: `sg'
==> ERROR: module not found: `bnx2i'
==> ERROR: module not found: `3w_xxxx'
==> ERROR: module not found: `aic94xx'
==> ERROR: module not found: `libfc'
==> ERROR: module not found: `libiscsi_tcp'
==> ERROR: module not found: `ppa'
==> ERROR: module not found: `scsi_transport_iscsi'
==> ERROR: module not found: `3w_9xxx'
==> ERROR: module not found: `csiostor'
==> ERROR: module not found: `megaraid_mbox'
==> ERROR: module not found: `megaraid_sas'
==> ERROR: module not found: `megaraid_mm'
==> ERROR: module not found: `smartpqi'
==> ERROR: module not found: `BusLogic'
==> ERROR: module not found: `scsi_debug'
==> ERROR: module not found: `qedf'
==> ERROR: module not found: `wd719x'
==> ERROR: module not found: `sym53c8xx'
==> ERROR: module not found: `pm80xx'
==> ERROR: module not found: `fnic'
==> ERROR: module not found: `scsi_transport_sas'
==> ERROR: module not found: `cxgb3i'
==> ERROR: module not found: `cxgb4i'
==> ERROR: module not found: `libcxgbi'
==> ERROR: module not found: `iscsi_tcp'
==> ERROR: module not found: `a100u2w'
==> ERROR: module not found: `mvumi'
==> ERROR: module not found: `ch'
==> ERROR: module not found: `qlogicfas408'
==> ERROR: module not found: `stex'
==> ERROR: module not found: `megaraid'
==> ERROR: module not found: `advansys'
==> ERROR: module not found: `dpt_i2o'
==> ERROR: module not found: `dmx3191d'
==> ERROR: module not found: `xen_scsifront'
==> ERROR: module not found: `vmw_pvscsi'
==> ERROR: module not found: `libfcoe'
==> ERROR: module not found: `fcoe'
==> ERROR: module not found: `bfa'
==> ERROR: module not found: `ipr'
==> ERROR: module not found: `ses'
==> ERROR: module not found: `iscsi_boot_sysfs'
==> ERROR: module not found: `st'
==> ERROR: module not found: `qla1280'
==> ERROR: module not found: `sr_mod'
==> ERROR: module not found: `arcmsr'
==> ERROR: module not found: `pmcraid'
==> ERROR: module not found: `mvsas'
==> ERROR: module not found: `be2iscsi'
==> ERROR: module not found: `ips'
==> ERROR: module not found: `esas2r'
==> ERROR: module not found: `scsi_transport_fc'
==> ERROR: module not found: `initio'
==> ERROR: module not found: `virtio_scsi'
==> ERROR: module not found: `fdomain'
==> ERROR: module not found: `libiscsi'
==> ERROR: module not found: `libsas'
==> ERROR: module not found: `fdomain_cs'
==> ERROR: module not found: `sym53c500_cs'
==> ERROR: module not found: `qlogic_cs'
==> ERROR: module not found: `aha152x_cs'
==> ERROR: module not found: `myrs'
==> ERROR: module not found: `lpfc'
==> ERROR: module not found: `scsi_transport_srp'
==> ERROR: module not found: `mpi3mr'
==> ERROR: module not found: `3w_sas'
==> ERROR: module not found: `am53c974'
==> ERROR: module not found: `aacraid'
==> ERROR: module not found: `nvme_tcp'
==> ERROR: module not found: `nvme_fabrics'
==> ERROR: module not found: `nvme_fc'
==> ERROR: module not found: `nvme_rdma'
==> ERROR: module not found: `nvmet_tcp'
==> ERROR: module not found: `nvme_fcloop'
==> ERROR: module not found: `nvmet_fc'
==> ERROR: module not found: `nvme_loop'
==> ERROR: module not found: `nvmet'
==> ERROR: module not found: `nvmet_rdma'
==> ERROR: module not found: `mptsas'
==> ERROR: module not found: `mptscsih'
==> ERROR: module not found: `mptbase'
==> ERROR: module not found: `mptfc'
==> ERROR: module not found: `mptctl'
==> ERROR: module not found: `mptspi'
==> ERROR: module not found: `mptlan'
==> ERROR: module not found: `pata_optidma'
==> ERROR: module not found: `pata_jmicron'
==> ERROR: module not found: `pata_ns87415'
==> ERROR: module not found: `pata_via'
==> ERROR: module not found: `pata_artop'
==> ERROR: module not found: `sata_dwc_460ex'
==> ERROR: module not found: `pata_pdc2027x'
==> ERROR: module not found: `pata_hpt3x3'
==> ERROR: module not found: `sata_svw'
==> ERROR: module not found: `pata_opti'
==> ERROR: module not found: `sata_qstor'
==> ERROR: module not found: `sata_sil24'
==> ERROR: module not found: `sata_via'
==> ERROR: module not found: `pata_mpiix'
==> ERROR: module not found: `pata_cypress'
==> ERROR: module not found: `pata_ninja32'
==> ERROR: module not found: `sata_vsc'
==> ERROR: module not found: `pata_hpt3x2n'
==> ERROR: module not found: `pata_pcmcia'
==> ERROR: module not found: `pata_marvell'
==> ERROR: module not found: `pata_legacy'
==> ERROR: module not found: `pata_amd'
==> ERROR: module not found: `pata_sl82c105'
==> ERROR: module not found: `pata_cmd640'
==> ERROR: module not found: `pata_pdc202xx_old'
==> ERROR: module not found: `pata_radisys'
==> ERROR: module not found: `sata_sil'
==> ERROR: module not found: `pata_piccolo'
==> ERROR: module not found: `pata_ns87410'
==> ERROR: module not found: `pata_sil680'
==> ERROR: module not found: `pata_acpi'
==> ERROR: module not found: `sata_uli'
==> ERROR: module not found: `pata_efar'
==> ERROR: module not found: `pata_hpt37x'
==> ERROR: module not found: `sata_promise'
==> ERROR: module not found: `pata_netcell'
==> ERROR: module not found: `sata_mv'
==> ERROR: module not found: `pata_oldpiix'
==> ERROR: module not found: `pata_hpt366'
==> ERROR: module not found: `pata_atp867x'
==> ERROR: module not found: `pata_atiixp'
==> ERROR: module not found: `pata_sch'
==> ERROR: module not found: `pata_cmd64x'
==> ERROR: module not found: `pata_triflex'
==> ERROR: module not found: `pata_ali'
==> ERROR: module not found: `sata_nv'
==> ERROR: module not found: `pata_it821x'
==> ERROR: module not found: `sata_sx4'
==> ERROR: module not found: `sata_sis'
==> ERROR: module not found: `pata_it8213'
==> ERROR: module not found: `pata_rz1000'
==> ERROR: module not found: `pata_sis'
==> ERROR: module not found: `sata_inic162x'
==> ERROR: module not found: `pata_serverworks'
==> ERROR: module not found: `pata_rdc'
==> ERROR: module not found: `ata_generic'
==> ERROR: module not found: `ata_piix'
==> ERROR: module not found: `ahci_platform'
==> ERROR: module not found: `pdc_adma'
==> ERROR: module not found: `ohci_platform'
==> ERROR: module not found: `xhci_plat_hcd'
==> ERROR: module not found: `ehci_platform'
==> ERROR: module not found: `bcma_hcd'
==> ERROR: module not found: `xhci_pci'
==> ERROR: module not found: `r8a66597_hcd'
==> ERROR: module not found: `isp116x_hcd'
==> ERROR: module not found: `u132_hcd'
==> ERROR: module not found: `ehci_fsl'
==> ERROR: module not found: `oxu210hp_hcd'
==> ERROR: module not found: `sl811_hcd'
==> ERROR: module not found: `max3421_hcd'
==> ERROR: module not found: `fotg210_hcd'
==> ERROR: module not found: `xhci_pci_renesas'
==> ERROR: module not found: `fsl_mph_dr_of'
==> ERROR: module not found: `ssb_hcd'
==> ERROR: module not found: `ums_usbat'
==> ERROR: module not found: `ums_freecom'
==> ERROR: module not found: `ums_alauda'
==> ERROR: module not found: `ums_cypress'
==> ERROR: module not found: `ums_onetouch'
==> ERROR: module not found: `ums_sddr55'
==> ERROR: module not found: `ums_jumpshot'
==> ERROR: module not found: `uas'
==> ERROR: module not found: `ums_sddr09'
==> ERROR: module not found: `ums_realtek'
==> ERROR: module not found: `ums_isd200'
==> ERROR: module not found: `usb_storage'
==> ERROR: module not found: `ums_eneub6250'
==> ERROR: module not found: `ums_karma'
==> ERROR: module not found: `ums_datafab'
==> ERROR: module not found: `firewire_sbp2'
==> ERROR: module not found: `nosy'
==> ERROR: module not found: `firewire_net'
==> ERROR: module not found: `firewire_core'
==> ERROR: module not found: `firewire_ohci'
==> ERROR: module not found: `mmc_spi'
==> ERROR: module not found: `mtk_sd'
==> ERROR: module not found: `rtsx_pci_sdmmc'
==> ERROR: module not found: `sdhci_pltfm'
==> ERROR: module not found: `cqhci'
==> ERROR: module not found: `alcor'
==> ERROR: module not found: `rtsx_usb_sdmmc'
==> ERROR: module not found: `via_sdmmc'
==> ERROR: module not found: `sdhci_f_sdh30'
==> ERROR: module not found: `sdhci_acpi'
==> ERROR: module not found: `tifm_sd'
==> ERROR: module not found: `ushc'
==> ERROR: module not found: `mmc_hsq'
==> ERROR: module not found: `sdhci_xenon_driver'
==> ERROR: module not found: `of_mmc_spi'
==> ERROR: module not found: `sdhci'
==> ERROR: module not found: `sdricoh_cs'
==> ERROR: module not found: `vub300'
==> ERROR: module not found: `toshsd'
==> ERROR: module not found: `sdhci_pci'
==> ERROR: module not found: `usdhi6rol0'
==> ERROR: module not found: `cb710_mmc'
==> ERROR: module not found: `wbsd'
==> ERROR: module not found: `mmc_test'
==> ERROR: module not found: `mmc_block'
==> ERROR: module not found: `sdio_uart'
==> ERROR: module not found: `mmc_core'
==> ERROR: module not found: `tifm_core'
==> ERROR: module not found: `tifm_7xx1'
==> ERROR: module not found: `tifm_ms'
==> ERROR: module not found: `vmw_vsock_virtio_transport'
==> ERROR: module not found: `vmw_vsock_virtio_transport_common'
==> ERROR: module not found: `9pnet_virtio'
==> ERROR: module not found: `virtiofs'
==> ERROR: module not found: `virtio_snd'
==> ERROR: module not found: `virtio_iommu'
==> ERROR: module not found: `virtio_crypto'
==> ERROR: module not found: `virtio_net'
==> ERROR: module not found: `virtio_pmem'
==> ERROR: module not found: `nd_virtio'
==> ERROR: module not found: `virtio_gpu'
==> ERROR: module not found: `virtio_bt'
==> ERROR: module not found: `virtio_pci_modern_dev'
==> ERROR: module not found: `virtio_balloon'
==> ERROR: module not found: `virtio_mmio'
==> ERROR: module not found: `virtio_input'
==> ERROR: module not found: `virtio_mem'
==> ERROR: module not found: `virtio_pci'
==> ERROR: module not found: `virtio_dma_buf'
==> ERROR: module not found: `virtio_vdpa'
==> ERROR: module not found: `virtio_rpmsg_bus'
==> ERROR: module not found: `vp_vdpa'
==> ERROR: module not found: `i2c_virtio'
==> ERROR: module not found: `gpio_virtio'
==> ERROR: module not found: `virtio_rng'
==> ERROR: module not found: `virtio_console'
==> ERROR: module not found: `nd_e820'
==> ERROR: module not found: `nd_blk'
==> ERROR: module not found: `nd_pmem'
==> ERROR: module not found: `nd_btt'
==> ERROR: module not found: `mvmdio'
==> ERROR: module not found: `vmd'
==> ERROR: module not found: `hid_viewsonic'
==> ERROR: module not found: `hid_roccat_isku'
==> ERROR: module not found: `hid_sensor_hub'
==> ERROR: module not found: `hid_ezkey'
==> ERROR: module not found: `hid_uclogic'
==> ERROR: module not found: `hid_roccat_common'
==> ERROR: module not found: `hid_nti'
==> ERROR: module not found: `hid_logitech_hidpp'
==> ERROR: module not found: `hid_roccat'
==> ERROR: module not found: `hid_roccat_kovaplus'
==> ERROR: module not found: `hid_a4tech'
==> ERROR: module not found: `hid_keytouch'
==> ERROR: module not found: `hid_dr'
==> ERROR: module not found: `hid_speedlink'
==> ERROR: module not found: `hid_elecom'
==> ERROR: module not found: `hid_roccat_koneplus'
==> ERROR: module not found: `hid_alps'
==> ERROR: module not found: `hid_steam'
==> ERROR: module not found: `hid_axff'
==> ERROR: module not found: `hid_lg_g15'
==> ERROR: module not found: `hid_prodikeys'
==> ERROR: module not found: `hid_holtek_mouse'
==> ERROR: module not found: `hid_cp2112'
==> ERROR: module not found: `hid_gfrm'
==> ERROR: module not found: `hid_macally'
==> ERROR: module not found: `hid_multitouch'
==> ERROR: module not found: `hid_roccat_savu'
==> ERROR: module not found: `hid_udraw_ps3'
==> ERROR: module not found: `hid_glorious'
==> ERROR: module not found: `hid_logitech_dj'
==> ERROR: module not found: `hid_wiimote'
==> ERROR: module not found: `hid_twinhan'
==> ERROR: module not found: `hid_roccat_kone'
==> ERROR: module not found: `hid_zpff'
==> ERROR: module not found: `hid_rmi'
==> ERROR: module not found: `hid_waltop'
==> ERROR: module not found: `hid_samsung'
==> ERROR: module not found: `hid_gaff'
==> ERROR: module not found: `hid_sensor_custom'
==> ERROR: module not found: `hid_mcp2221'
==> ERROR: module not found: `hid_saitek'
==> ERROR: module not found: `hid_gyration'
==> ERROR: module not found: `hid_topseed'
==> ERROR: module not found: `hid_elo'
==> ERROR: module not found: `hid_cherry'
==> ERROR: module not found: `hid_semitek'
==> ERROR: module not found: `hid_playstation'
==> ERROR: module not found: `hid_pl'
==> ERROR: module not found: `hid_lcpower'
==> ERROR: module not found: `hid_vivaldi'
==> ERROR: module not found: `hid_ortek'
==> ERROR: module not found: `hid_u2fzero'
==> ERROR: module not found: `hid_led'
==> ERROR: module not found: `hid_thrustmaster'
==> ERROR: module not found: `hid_cougar'
==> ERROR: module not found: `hid_corsair'
==> ERROR: module not found: `hid_gembird'
==> ERROR: module not found: `hid_cypress'
==> ERROR: module not found: `hid_tivo'
==> ERROR: module not found: `hid_roccat_konepure'
==> ERROR: module not found: `hid_microsoft'
==> ERROR: module not found: `hid_redragon'
==> ERROR: module not found: `hid_emsff'
==> ERROR: module not found: `hid_roccat_lua'
==> ERROR: module not found: `hid_accutouch'
==> ERROR: module not found: `hid_magicmouse'
==> ERROR: module not found: `hid_apple'
==> ERROR: module not found: `hid_picolcd'
==> ERROR: module not found: `hid_sunplus'
==> ERROR: module not found: `hid_tmff'
==> ERROR: module not found: `hid_chicony'
==> ERROR: module not found: `hid_roccat_ryos'
==> ERROR: module not found: `hid_aureal'
==> ERROR: module not found: `hid_kye'
==> ERROR: module not found: `hid_appleir'
==> ERROR: module not found: `hid_xinmo'
==> ERROR: module not found: `hid_penmount'
==> ERROR: module not found: `hid_betopff'
==> ERROR: module not found: `hid_elan'
==> ERROR: module not found: `hid_icade'
==> ERROR: module not found: `hid_mf'
==> ERROR: module not found: `hid_primax'
==> ERROR: module not found: `hid_monterey'
==> ERROR: module not found: `hid_creative_sb0540'
==> ERROR: module not found: `hid_kensington'
==> ERROR: module not found: `hid_cmedia'
==> ERROR: module not found: `hid_hyperv'
==> ERROR: module not found: `hid_holtekff'
==> ERROR: module not found: `hid_retrode'
==> ERROR: module not found: `hid_zydacron'
==> ERROR: module not found: `hid_sjoy'
==> ERROR: module not found: `hid_roccat_arvo'
==> ERROR: module not found: `hid_ite'
==> ERROR: module not found: `hid_plantronics'
==> ERROR: module not found: `hid_sony'
==> ERROR: module not found: `hid_jabra'
==> ERROR: module not found: `hid_holtek_kbd'
==> ERROR: module not found: `hid_bigbenff'
==> ERROR: module not found: `hid_petalynx'
==> ERROR: module not found: `hid_ntrig'
==> ERROR: module not found: `hid_asus'
==> ERROR: module not found: `hid_lenovo'
==> ERROR: module not found: `hid_roccat_pyra'
==> ERROR: module not found: `hid_maltron'
==> ERROR: module not found: `hid_google_hammer'
==> ERROR: module not found: `hid_ft260'
==> ERROR: module not found: `hid_logitech'
==> ERROR: module not found: `hid_belkin'
==> ERROR: module not found: `hid_steelseries'
==> ERROR: module not found: `hid_gt683r'
==> ERROR: module not found: `usbhid'
==> ERROR: module not found: `newtonkbd'
==> ERROR: module not found: `applespi'
==> ERROR: module not found: `matrix_keypad'
==> ERROR: module not found: `stowaway'
==> ERROR: module not found: `max7359_keypad'
==> ERROR: module not found: `adc_keys'
==> ERROR: module not found: `iqs62x_keys'
==> ERROR: module not found: `adp5589_keys'
==> ERROR: module not found: `atkbd'
==> ERROR: module not found: `mcs_touchkey'
==> ERROR: module not found: `qt1070'
==> ERROR: module not found: `qt1050'
==> ERROR: module not found: `lm8323'
==> ERROR: module not found: `opencores_kbd'
==> ERROR: module not found: `gpio_keys_polled'
==> ERROR: module not found: `lm8333'
==> ERROR: module not found: `gpio_keys'
==> ERROR: module not found: `sunkbd'
==> ERROR: module not found: `tca8418_keypad'
==> ERROR: module not found: `dlink_dir685_touchkeys'
==> ERROR: module not found: `adp5588_keys'
==> ERROR: module not found: `xtkbd'
==> ERROR: module not found: `cros_ec_keyb'
==> ERROR: module not found: `qt2160'
==> ERROR: module not found: `samsung_keypad'
==> ERROR: module not found: `twl4030_keypad'
==> ERROR: module not found: `tm2_touchkey'
==> ERROR: module not found: `mtk_pmic_keys'
==> ERROR: module not found: `lkkbd'
==> ERROR: module not found: `mpr121_touchkey'
==> ERROR: module not found: `adp5520_keys'
==> ERROR: module not found: `tca6416_keypad'
==> ERROR: module not found: `parkbd'
==> ERROR: module not found: `libps2'
==> ERROR: module not found: `ps2_gpio'
==> ERROR: module not found: `ps2mult'
==> ERROR: module not found: `serio'
==> ERROR: module not found: `serport'
==> ERROR: module not found: `serio_raw'
==> ERROR: module not found: `pcips2'
==> ERROR: module not found: `altera_ps2'
==> ERROR: module not found: `ct82c710'
==> ERROR: module not found: `arc_ps2'
==> ERROR: module not found: `userio'
==> ERROR: module not found: `i8042'
==> ERROR: module not found: `hyperv_keyboard'
-> Running build hook: [resume]
==> ERROR: module not found: `jbd2'
==> ERROR: module not found: `nfsv3'
==> ERROR: module not found: `blocklayoutdriver'
==> ERROR: module not found: `nfs'
==> ERROR: module not found: `nfs_layout_nfsv41_files'
==> ERROR: module not found: `nfs_layout_flexfiles'
==> ERROR: module not found: `nfsv4'
==> ERROR: module not found: `nfsv2'
==> ERROR: module not found: `quota_tree'
==> ERROR: module not found: `quota_v2'
==> ERROR: module not found: `quota_v1'
==> ERROR: module not found: `cramfs'
==> ERROR: module not found: `affs'
==> ERROR: module not found: `orangefs'
==> ERROR: module not found: `jffs2'
==> ERROR: module not found: `vboxsf'
==> ERROR: module not found: `fscache'
==> ERROR: module not found: `ufs'
==> ERROR: module not found: `ubifs'
==> ERROR: module not found: `cuse'
==> ERROR: module not found: `fuse'
==> ERROR: module not found: `btrfs'
==> ERROR: module not found: `exfat'
==> ERROR: module not found: `ecryptfs'
==> ERROR: module not found: `cifs'
==> ERROR: module not found: `befs'
==> ERROR: module not found: `ksmbd'
==> ERROR: module not found: `mbcache'
==> ERROR: module not found: `f2fs'
==> ERROR: module not found: `udf'
==> ERROR: module not found: `ntfs3'
==> ERROR: module not found: `overlay'
==> ERROR: module not found: `cachefiles'
==> ERROR: module not found: `ext4'
==> ERROR: module not found: `kafs'
==> ERROR: module not found: `nilfs2'
==> ERROR: module not found: `ramoops'
==> ERROR: module not found: `fat'
==> ERROR: module not found: `vfat'
==> ERROR: module not found: `msdos'
==> ERROR: module not found: `omfs'
==> ERROR: module not found: `isofs'
==> ERROR: module not found: `coda'
==> ERROR: module not found: `netfs'
==> ERROR: module not found: `hfs'
==> ERROR: module not found: `romfs'
==> ERROR: module not found: `lockd'
==> ERROR: module not found: `squashfs'
==> ERROR: module not found: `reiserfs'
==> ERROR: module not found: `dlm'
==> ERROR: module not found: `cifs_arc4'
==> ERROR: module not found: `cifs_md4'
==> ERROR: module not found: `hfsplus'
==> ERROR: module not found: `grace'
==> ERROR: module not found: `nfs_acl'
==> ERROR: module not found: `zonefs'
==> ERROR: module not found: `ceph'
==> ERROR: module not found: `nfsd'
==> ERROR: module not found: `ocfs2_stack_o2cb'
==> ERROR: module not found: `ocfs2_dlmfs'
==> ERROR: module not found: `ocfs2_dlm'
==> ERROR: module not found: `ocfs2_stack_user'
==> ERROR: module not found: `ocfs2_nodemanager'
==> ERROR: module not found: `ocfs2_stackglue'
==> ERROR: module not found: `ocfs2'
==> ERROR: module not found: `gfs2'
==> ERROR: module not found: `minix'
==> ERROR: module not found: `xfs'
==> ERROR: module not found: `jfs'
==> ERROR: module not found: `erofs'
==> ERROR: module not found: `9p'
-> Running build hook: [fsck]
==> WARNING: No modules were added to the image. This is probably not what you want.
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64.img
bsdtar: error while loading shared libraries: libcrypto.so.1.1: cannot open shared object file: No such file or directory
==> WARNING: errors were encountered during the build. The image may not be complete.
==> ERROR: Image generation FAILED: find reported an error
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'fallback'
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64-fallback.img
error: command failed to execute correctly
(4/4) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-5.10-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.10-x86_64.img
Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.13-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.13-x86_64.img
Found initrd fallback image: /boot/initramfs-5.13-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
udevadm: error while loading shared libraries: libcrypto.so.1.1: cannot open shared object file: No such file or directory
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
brahma
February 16, 2023, 8:12pm
11
hmm… and all related to the libcrypto.so … did you installed it with?:
blp92
February 16, 2023, 8:15pm
12
I did, and it seemed to go smoothly. Here is the terminal output:
[manjaro@manjaro ~]$ sudo pacman --sysroot /mnt -S openssl lib32-openssl --overwrite '*'
warning: openssl-3.0.8-1 is up to date -- reinstalling
warning: lib32-openssl-1:3.0.8-0.1 is up to date -- reinstalling
Packages (2) lib32-openssl-1:3.0.8-0.1 openssl-3.0.8-1
Total Installed Size: 15.84 MiB
Net Upgrade Size: 0.00 MiB
(2/2) checking keys in keyring [#####################################################] 100%
(2/2) checking package integrity [#####################################################] 100%
(2/2) loading package files [#####################################################] 100%
(2/2) checking for file conflicts [#####################################################] 100%
(2/2) checking available disk space [#####################################################] 100%
(1/1) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(1/2) reinstalling openssl [#####################################################] 100%
(2/2) reinstalling lib32-openssl [#####################################################] 100%
(1/1) Arming ConditionNeedsUpdate...
brahma
February 16, 2023, 8:17pm
13
so rerun the update first:
and if it didnt gave you any libcrypto errors, rerun again the linux515 install command
blp92
February 16, 2023, 8:24pm
14
I rebooted to see what happened first and I no longer have the option to boot to my windows partition in the GRUB bootloader, and the manjaro one was still showing the kernel panic.
Doing the update threw an error:
[manjaro@manjaro ~]$ sudo pacman --sysroot /mnt -Syu
core is up to date
extra 1855.0 KiB 5.44 MiB/s 00:00 [######################] 100%
community 7.6 MiB 16.9 MiB/s 00:00 [######################] 100%
multilib is up to date
:: Replace at-spi2-atk with extra/at-spi2-core? [Y/n] Y
:: Replace atk with extra/at-spi2-core? [Y/n] Y
:: Replace steam-manjaro with multilib/steam? [Y/n] Y
warning: dependency cycle detected:
warning: mesa will be installed before its libglvnd dependency
warning: lib32-mesa will be installed before its lib32-libglvnd dependency
warning: rubygems will be installed before its ruby dependency
warning: ruby-abbrev will be installed before its ruby dependency
warning: ruby-base64 will be installed before its ruby dependency
warning: ruby-benchmark will be installed before its ruby dependency
warning: ruby-bigdecimal will be installed before its ruby dependency
warning: ruby-bundler will be installed before its ruby dependency
warning: ruby-cgi will be installed before its ruby dependency
warning: ruby-csv will be installed before its ruby dependency
warning: ruby-date will be installed before its ruby dependency
warning: ruby-delegate will be installed before its ruby dependency
warning: ruby-did_you_mean will be installed before its ruby dependency
warning: ruby-digest will be installed before its ruby dependency
warning: ruby-drb will be installed before its ruby dependency
warning: ruby-ruby2_keywords will be installed before its ruby dependency
warning: ruby-english will be installed before its ruby dependency
warning: ruby-erb will be installed before its ruby dependency
warning: ruby-etc will be installed before its ruby dependency
warning: ruby-fcntl will be installed before its ruby dependency
warning: ruby-fiddle will be installed before its ruby dependency
warning: ruby-fileutils will be installed before its ruby dependency
warning: ruby-find will be installed before its ruby dependency
warning: ruby-forwardable will be installed before its ruby dependency
warning: ruby-getoptlong will be installed before its ruby dependency
warning: ruby-io-console will be installed before its ruby dependency
warning: ruby-io-nonblock will be installed before its ruby dependency
warning: ruby-io-wait will be installed before its ruby dependency
warning: ruby-ipaddr will be installed before its ruby dependency
warning: ruby-irb will be installed before its ruby dependency
warning: ruby-reline will be installed before its ruby dependency
warning: ruby-json will be installed before its ruby dependency
warning: ruby-logger will be installed before its ruby dependency
warning: ruby-mutex_m will be installed before its ruby dependency
warning: ruby-net-http will be installed before its ruby dependency
warning: ruby-uri will be installed before its ruby dependency
warning: ruby-open-uri will be installed before its ruby dependency
warning: ruby-stringio will be installed before its ruby dependency
warning: ruby-time will be installed before its ruby dependency
warning: ruby-psych will be installed before its ruby dependency
warning: ruby-racc will be installed before its ruby dependency
warning: ruby-rdoc will be installed before its ruby dependency
warning: ruby-tmpdir will be installed before its ruby dependency
warning: ruby-minitest will be installed before its ruby dependency
warning: ruby-power_assert will be installed before its ruby dependency
warning: ruby-rake will be installed before its ruby dependency
warning: ruby-test-unit will be installed before its ruby dependency
warning: ruby-bundledgems will be installed before its ruby dependency
Packages (935) a52dec-0.7.4-12 aalib-1.4rc5-15 abseil-cpp-20220623.1-1
acpid-2.0.34-1 adwaita-cursors-43-2 adwaita-icon-theme-43-2
alsa-card-profiles-1:0.3.65-6 alsa-lib-1.2.8-1
alsa-ucm-conf-1.2.8-1 alsa-utils-1.2.8-1
amd-ucode-20230117.7e4f0ed-1 android-tools-33.0.3-3
android-udev-20230104-1 aom-3.6.0-1 apparmor-3.1.2-1
appstream-0.16.0-1 appstream-glib-0.8.2-1
archlinux-appstream-data-20230115-1
arm-none-eabi-binutils-2.39-2 arm-none-eabi-gcc-12.2.0-1
aspell-0.60.8-3 at-spi2-atk-2.38.0-1 [removal]
at-spi2-core-2.46.0-2 atk-2.38.0-1 [removal] atkmm-2.28.3-1
audacious-4.2-3 audacious-plugins-4.2-3 audit-3.0.9-2
avr-binutils-2.39-2 avr-gcc-12.2.0-1 avrdude-1:7.0-3
b43-fwcutter-019-4 babl-0.1.98-1 bamf-0.5.6-1
bash-completion-2.11-3 binutils-2.40-4 blueman-2.3.5-1
bluez-5.66-1 bluez-libs-5.66-1 boost-libs-1.81.0-2
botan-2.19.3-1 brotli-1.0.9-9 btrfs-progs-6.1.3-1
bubblewrap-0.7.0-1 bzip2-1.0.8-5 ca-certificates-20220905-1
ca-certificates-mozilla-3.87-1 ca-certificates-utils-20220905-1
cairo-1.17.8-2 cairomm-1.14.4-1 catfish-4.16.4-1
chromaprint-1.5.1-6 cifs-utils-7.0-2 ckbcomp-1.212-1
clang-15.0.7-1 clucene-2.3.3.4-14 cmake-3.25.2-1
compiler-rt-15.0.7-1 coreutils-9.1-3 cpupower-6.1-1
cryptsetup-2.6.0-1 cups-1:2.4.2-5 cups-filters-1.28.17-1
cups-pdf-3.0.1-7 cups-pk-helper-0.2.7-1 curl-7.87.0-3
cython-0.29.33-1 db-6.2.32-1 db5.3-5.3.28-2 dconf-0.40.0-2
default-cursors-2-1 device-mapper-2.03.18-4
dhclient-4.4.3.P1-1 discord-0.0.25-1 djvulibre-3.5.28-4
dmraid-1.0.0.rc16.3-14 dnsmasq-2.89-1 dosfstools-4.2-3
double-conversion-3.2.1-1 duktape-2.7.0-5 e2fsprogs-1.46.6-1
ecryptfs-utils-111-7 efibootmgr-18-1
elementary-icon-theme-7.2.0-1 elfutils-0.188-3 enchant-2.3.3-2
evince-43.1-2 exiv2-0.27.6-1 exo-4.18.0-1 expat-2.5.0-1
f2fs-tools-1.15.0-2 faad2-2.10.1-1 fakeroot-1.31-1
ffmpeg-2:5.1.2-1 file-5.44-1 filesystem-2023.01.30-1
findutils-4.9.0-2 firefox-110.0-0.1 flac-1.4.2-1
flatpak-1:1.15.2-1 flex-2.6.4-4 fluidsynth-2.3.1-1
fmt-9.1.0-4 fontconfig-2:2.14.2-1 foomatic-db-3:20230115-1
foomatic-db-gutenprint-ppds-5.3.4-2
foomatic-db-nonfree-3:20230115-1
foomatic-db-nonfree-ppds-3:20230115-1
foomatic-db-ppds-3:20230115-1 freeglut-3.4.0-1
fuse-common-3.13.0-1 fuse3-3.13.0-1 game-devices-udev-0.18-1
garcon-4.18.0-1 gawk-5.2.1-1 gc-8.2.2-1 gcab-1.5-1
gcc-12.2.1-2 gcc-libs-12.2.1-2 gcr-3.41.1-3 gcr-4-4.0.0-1
gd-2.3.3-6 gdk-pixbuf2-2.42.10-2 gegl-0.4.40-4
geoclue-2.7.0-1 geocode-glib-3.26.4-2
geocode-glib-common-3.26.4-2 gettext-0.21.1-2
ghostscript-10.0.0-4 gimp-2.10.32-3 git-2.39.1-1 glew-2.2.0-6
glib-networking-1:2.74.0-1 glib2-2.74.5-1 glibc-2.37-2
glibmm-2.66.5-1 glibmm-2.68-2.74.0-1 glslang-11.13.0-2
gnome-desktop-1:43.1-1 gnome-desktop-4-1:43.1-1
gnome-desktop-common-1:43.1-1 gnome-keyring-1:42.1-2
gnome-menus-3.36.0-2 gnupg-2.2.40-1 gnutls-3.7.8-5
gobject-introspection-runtime-1.74.0-1 gpgme-1.18.0-2
gptfdisk-1.0.9-2 graphviz-7.1.0-1 grep-3.8-2
grub-2.06.r261.g2f4430cc0-3 grub-btrfs-4.12-2
grub-theme-manjaro-20.2-13 gsettings-desktop-schemas-43.0-1
gsm-1.0.22-1 gspell-1.12.0-2 gssdp-1.6.2-1 gst-libav-1.22.0-3
gst-plugins-bad-1.22.0-3 gst-plugins-bad-libs-1.22.0-3
gst-plugins-base-1.22.0-3 gst-plugins-base-libs-1.22.0-3
gst-plugins-good-1.22.0-3 gst-plugins-ugly-1.22.0-3
gstreamer-1.22.0-3 gtk-update-icon-cache-1:4.8.3-3
gtk3-1:3.24.36-1 gtk4-1:4.8.3-3 gtkhash-1.5-2
gtkhash-thunar-1.5-2 gtkmm3-3.24.7-1
gtksourceview3-1:3.24.11+r28+g73e57b57-1 gtksourceview4-4.8.4-1
guile-3.0.9-1 gupnp-1:1.6.3-1 gupnp-igd-1.2.0-3
gutenprint-5.3.4-2 gvfs-1.50.3-1 gvfs-afc-1.50.3-1
gvfs-gphoto2-1.50.3-1 gvfs-mtp-1.50.3-1 gvfs-nfs-1.50.3-1
gvfs-smb-1.50.3-1 harfbuzz-6.0.0-1 harfbuzz-icu-6.0.0-1
hdparm-9.65-1 hexchat-2.16.1-3 hidapi-0.13.1-1
hplip-1:3.22.10-3 htop-3.2.2-1 hunspell-1.7.2-1
hwdata-0.366-1 hwinfo-22.2-2 hwloc-2.8.0-1 hyphen-2.8.8-5
iana-etc-20221215-1 ibus-1.5.27-1 icu-72.1-2 ijs-0.35-5
imagemagick-7.1.0.61-1 imath-3.1.6-2 imlib2-1.10.0-3
inetutils-2.3-1 inxi-3.3.25.1-1 iproute2-6.1.0-4
iptables-1:1.8.9-1 iputils-20221126-1 iso-codes-4.12.0-1
jack2-1.9.21-3 jasper-4.0.0-1 java-environment-common-3-5
java-runtime-common-3-5 jdk8-openjdk-8.362.u09-1
jre8-openjdk-8.362.u09-1 jre8-openjdk-headless-8.362.u09-1
kauth-5.102.0-1 kcoreaddons-5.102.0-1 kguiaddons-5.102.0-1
kitemmodels-5.102.0-1 kmod-30-3 krb5-1.20.1-1 kvantum-1.0.9-0
kwayland-5.102.0-1 kwindowsystem-5.102.0-1 lame-3.100-4
languagetool-6.0-1 lcms2-2.14-2 ldb-2:2.6.1-2 ldns-1.8.3-2
less-1:608-2 lib32-alsa-lib-1.2.8-1 lib32-brotli-1.0.9-5
lib32-bzip2-1.0.8-3 lib32-curl-7.87.0-1
lib32-e2fsprogs-1.46.6-1 lib32-expat-2.5.0-2
lib32-freeglut-3.4.0-1 lib32-gcc-libs-12.2.1-2
lib32-glew-2.2.0-4 lib32-glibc-2.37-2 lib32-icu-72.1-2
lib32-krb5-1.20.1-1 lib32-libcap-2.66-1 lib32-libdrm-2.4.114-1
lib32-libelf-0.188-1 lib32-libffi-3.4.4-1
lib32-libgcrypt-1.10.1-2 lib32-libglvnd-1.6.0-1
lib32-libgpg-error-1.46-1 lib32-libice-1.1.1-1
lib32-libidn2-2.3.4-2 lib32-libldap-2.6.3-3
lib32-libpciaccess-0.17-1 lib32-libpsl-0.21.1-3
lib32-libsm-1.2.4-1 lib32-libssh2-1.10.0-2
lib32-libtasn1-4.19.0-1 lib32-libtirpc-1.3.3-2
lib32-libunistring-1.1-1 lib32-libunwind-1.6.2-2
lib32-libva-2.17.0-1 lib32-libva-mesa-driver-22.3.5-1
lib32-libva-vdpau-driver-0.7.4-7 lib32-libx11-1.8.3-1.1
lib32-libxau-1.0.11-1 lib32-libxcb-1.15-2
lib32-libxcrypt-4.4.33-1 lib32-libxcrypt-compat-4.4.33-1
lib32-libxdamage-1.1.6-1 lib32-libxdmcp-1.1.4-1
lib32-libxext-1.3.5-1 lib32-libxfixes-6.0.0-2
lib32-libxi-1.8-2 lib32-libxml2-2.10.3-2 lib32-libxmu-1.1.4-1
lib32-libxrandr-1.5.3-1 lib32-libxrender-0.9.11-1
lib32-libxshmfence-1.3.2-1 lib32-libxxf86vm-1.1.5-1
lib32-llvm-libs-15.0.7-1
lib32-lm_sensors-1:3.6.0.r41.g31d1f125-2 lib32-mesa-22.3.5-1
lib32-mesa-vdpau-22.3.5-1 lib32-ncurses-6.4-1
lib32-nspr-4.35-1 lib32-nss-3.87-1 lib32-readline-8.2.001-2
lib32-sqlite-3.40.1-1 lib32-systemd-252.5-1
lib32-util-linux-2.38.1-1 lib32-vulkan-icd-loader-1.3.240-1
lib32-vulkan-intel-22.3.5-1 lib32-vulkan-radeon-22.3.5-1
lib32-wayland-1.21.0-1 lib32-xz-5.4.1-1 lib32-zlib-1.2.13-2
libadwaita-1:1.2.1-1 libappindicator-gtk3-12.10.0.r298-1
libarchive-3.6.2-2 libass-0.17.0-1
libasyncns-1:0.8+r3+g68cd5af-2 libatomic_ops-7.6.14-1
libavif-0.11.1-1 libayatana-appindicator-0.5.92-1
libayatana-indicator-0.9.3-1 libblockdev-2.28-1
libbluray-1.3.4-1 libbpf-1.0.1-1 libbs2b-3.1.0-8
libbsd-0.11.7-1 libcamera-0.0.4-1
libcanberra-1:0.30+r2+gc0620e4-3 libcap-2.66-1 libcddb-1.3.2-7
libcdio-2.1.0-3 libcdr-0.1.7-5
libcloudproviders-0.3.1+r8+g3a229ee-1 libcups-1:2.4.2-5
libdatrie-0.2.13-2 libde265-1.0.11-1 libdiscid-0.6.2-4
libdrm-2.4.114-1 libe-book-0.1.3-13 libebml-1.4.4-1
libedit-20210910_3.1-2 libelf-0.188-3 libepubgen-0.1.1-4
libetonyek-0.1.10-3 libevdev-1.13.0-1 libevent-2.1.12-4
libffi-3.4.4-1 libfontenc-1.1.7-1 libgcrypt-1.10.1-2
libgee-0.20.6-1 libgit2-1:1.5.1-2 libglvnd-1.6.0-1
libgnomekbd-1:3.28.1-1 libgpg-error-1.46-2 libgphoto2-2.5.30-2
libgpod-0.8.3-14 libgsf-1.14.50-1 libgusb-0.4.5-1
libgxps-0.3.2-3 libhandy-1.8.1-1 libheif-1.14.2-1
libibus-1.5.27-1 libical-3.0.16-4 libice-1.1.1-1
libidn2-2.3.4-3 libiec61883-1.2.0-7 libieee1284-0.2.11-14
libimagequant-4.0.4-1 libimobiledevice-1.3.0-6 libinih-56-1
libinput-1.22.1-1 libixion-0.17.0-4 libjpeg-turbo-2.1.4-2
libkeybinder3-0.3.2-4 libksba-1.6.3-1 libldap-2.6.3-2
liblouis-3.24.0-1 libltc-1.3.2-1 libmalcontent-0.11.0-1
libmatroska-1.7.1-1 libmbim-1.28.2-1 libmfx-23.1.0-1
libmm-glib-1.20.4-1 libmodplug-0.8.9.0-5 libmpc-1.3.1-1
libmspub-0.1.4-13 libmusicbrainz5-5.1.0-5 libmwaw-0.3.21-3
libmythes-1:1.2.5-1 libnewt-0.52.23-1 libnfs-5.0.2-1
libnftnl-1.2.4-1 libnghttp2-1.51.0-1 libnice-0.1.21-1
libnl-3.7.0-3 libnm-1.40.12-1 libnma-1.10.6-1
libnma-common-1.10.6-1 libnotify-0.8.1-1
libnumbertext-1.0.11-1 libodfgen-0.1.8-2
libomxil-bellagio-0.9.3-4 libopenmpt-0.6.8-1
libopenraw-0.3.3-1 liborcus-0.17.2-4 libpamac-11.4.1-3
libpamac-flatpak-plugin-11.4.1-2 libpamac-snap-plugin-11.4.1-2
libpcap-1.10.3-1 libpciaccess-0.17-1 libpipeline-1.5.7-1
libplacebo-5.229.1-2 libplist-2.2.0-6 libpng-1.6.39-1
libproxy-0.4.18-2 libpsl-0.21.2-1 libpulse-16.1-3
libpurple-2.14.12-1 libqmi-1.32.2-1 libqxp-0.0.2-9
libraqm-0.10.0-1 libraw-0.21.1-1 libreoffice-fresh-7.5.0-1
librevenge-0.0.5-2 librsvg-2:2.55.1-1 libsasl-2.1.28-4
libshout-1:2.4.6-2 libsidplayfp-2.4.2-1 libsigc++-2.12.0-1
libsigc++-3.0-3.4.0-1 libsm-1.2.4-1 libsndfile-1.2.0-1
libsoup-2.74.3-1 libsoup3-3.2.2-1 libsoxr-0.1.3-3
libspectre-0.2.12-1 libspiro-1:20221101-1 libsrtp-1:2.5.0-1
libssh-0.10.4-3 libssh2-1.10.0-3 libsynctex-2022.62885-3
libsysprof-capture-3.46.0-4 libtasn1-4.19.0-1 libteam-1.31-7
libtg_owt-0.git20.5098730-1 libthai-0.1.29-2 libtiff-4.5.0-1
libtirpc-1.3.3-2 libtool-2.4.7+4+g1ec8fa28-2
libunistring-1.1-2 libunwind-1.6.2-2 libupnp-1.14.15-1
liburcu-0.13.2-1 liburing-2.3-1 libusb-compat-0.1.8-1
libuv-1.44.2-1 libva-2.17.0-1 libva-mesa-driver-22.3.5-1
libvisio-0.1.7-8 libvpx-1.12.0-2 libwacom-2.6.0-1
libwbclient-4.17.5-1 libwebp-1.3.0-2 libwmf-0.2.12-3
libwnck3-43.0-3 libwpd-0.10.3-4 libwpe-1.14.1-1
libwpg-0.3.3-4 libwps-0.4.13-1 libx11-1.8.3-6 libxau-1.0.11-1
libxcb-1.15-2 libxcomposite-0.4.6-1 libxcrypt-4.4.33-1
libxcrypt-compat-4.4.33-1 libxcursor-1.2.1-3 libxcvt-0.1.2-1
libxdamage-1.1.6-1 libxdmcp-1.1.4-1 libxext-1.3.5-1
libxfce4ui-4.18.2-1 libxfce4util-4.18.1-1 libxfixes-6.0.0-2
libxfont2-2.0.6-1 libxft-2.3.7-1 libxi-1.8-2
libxinerama-1.1.5-1 libxkbcommon-1.5.0-1
libxkbcommon-x11-1.5.0-1 libxkbfile-1.1.2-1 libxml2-2.10.3-2
libxmlb-0.3.10-1 libxmu-1.1.4-1 libxpm-3.5.15-1
libxpresent-1.0.1-1 libxrandr-1.5.3-1 libxrender-0.9.11-1
libxres-1.2.2-1 libxshmfence-1.3.2-1 libxslt-1.1.37-2
libxtst-1.2.4-1 libxv-1.0.12-1 libxxf86vm-1.1.5-1
libyaml-0.2.5-2 libzmf-0.0.2-13 lightdm-1:1.32.0-4
lightdm-gtk-greeter-1:2.0.8-3 lilv-0.24.20-1
linux-api-headers-6.1.9-1 linux-firmware-20230117.7e4f0ed-1
linux-firmware-whence-20230117.7e4f0ed-1 linux510-5.10.167-1
lirc-1:0.10.2-2 llvm-15.0.7-1 llvm-libs-15.0.7-1
lm_sensors-1:3.6.0.r41.g31d1f125-2 lmdb-0.9.30-1
logrotate-3.21.0-2 lpsolve-5.5.2.11-2 lsof-4.98.0-1
luajit-2.1.0.beta3.r467.gd0e88930-1 lv2-1.18.10-1
lvm2-2.03.18-4 lz4-1:1.9.4-1 lzo-2.10-5 m4-1.4.19-2
make-4.4-1 man-db-2.11.2-1 man-pages-6.02-1
manjaro-alsa-20221002-1 manjaro-hello-0.7.0-2
manjaro-printer-20220924-1 manjaro-pulse-20221015-2
manjaro-release-22.0.3-1 manjaro-settings-manager-0.5.7-13
manjaro-settings-manager-notifier-0.5.7-13
matcha-gtk-theme-20221115-1 mbedtls-2.28.2-1 memtest86+-6.10-1
mesa-22.3.5-1 mesa-vdpau-22.3.5-1 mhwd-0.6.5-23
mhwd-db-0.6.5-23 mhwd-nvidia-525.89.02-1
mhwd-nvidia-390xx-390.157-1 mhwd-nvidia-470xx-470.161.03-2
miniupnpc-2.2.4-1 minizip-1:1.2.13-2 mkinitcpio-34-1.1
mktorrent-1.1-6 mobile-broadband-provider-info-20221107-2
modemmanager-1.20.4-1 mousepad-0.6.0-1 mpfr-4.2.0-3
mpg123-1.31.2-2 mythes-en-20221102-2 nano-7.2-1 ncurses-6.4-1
ndctl-75-1 neon-0.32.5-1 net-snmp-5.9.1-5 netpbm-10.73.42-2
nettle-3.8.1-1 network-manager-applet-1.30.0-1
networkmanager-1.40.12-1 networkmanager-openvpn-1.10.2-1
nfs-utils-2.6.2-1 nfsidmap-2.6.2-1 nftables-1:1.0.6-1
nm-connection-editor-1.30.0-1 noto-fonts-20230201-1
nspr-4.35-1 nss-3.87-1 ntfs-3g-2022.10.3-1 ntp-4.2.8.p15-3
nuspell-5.1.2-2 obs-studio-29.0.2-1
onlyoffice-desktopeditors-7.3.0-1 openal-1.23.0-1
opencore-amr-0.1.6-1 openjpeg2-2.5.0-2 openmpi-4.1.4-4
openpmix-4.2.3-1 openssh-9.2p1-1 openssl-1.1-1.1.1.t-1
openvpn-2.6.0-1 orc-0.4.33-1 os-prober-1.81-1 ostree-2022.7-1
p7zip-1:17.04-4 pacman-6.0.2-7
pacman-mirrors-4.23.2+2+g2f58b3c-3 pamac-cli-10.4.3-3
pamac-gtk-10.4.3-3 pambase-20221020-1 pango-1:1.50.12-1
pangomm-2.46.3-1 papirus-icon-theme-20230104-1
pavucontrol-1:5.0+r61+gee77d86-2 pciutils-3.9.0-2 pcre-8.45-3
pcre2-10.42-2 pcsclite-1.9.9-2 perl-5.36.0-3
perl-alien-build-2.77-1 perl-alien-libxml2-0.19-1
perl-clone-0.46-1 perl-encode-locale-1.05-10
perl-ffi-checklib-0.31-2 perl-file-desktopentry-0.22-10
perl-file-mimeinfo-0.33-1 perl-html-parser-3.81-1
perl-html-tagset-3.20-13 perl-http-date-6.05-6
perl-http-message-6.44-1 perl-http-negotiate-6.01-11
perl-libwww-6.67-1 perl-lwp-mediatypes-6.04-3
perl-path-tiny-0.144-1 perl-uri-5.17-1
perl-www-robotrules-6.02-11 perl-xml-libxml-2.0208-1
perl-xml-namespacesupport-1.12-5 perl-xml-sax-base-1.09-5
pidgin-2.14.12-1 pinentry-1.2.1-1 pipewire-1:0.3.65-6
pixman-0.42.2-1 pkcs11-helper-1.29.0-2 polkit-122-1
poppler-23.02.0-1 poppler-data-0.4.12-1 poppler-glib-23.02.0-1
poppler-qt5-23.02.0-1 popt-1.19-1 postgresql-libs-15.1-3
powertop-2.15-1 ppp-2.4.9-3 pptpclient-1.10.0-3
protobuf-21.12-1 protobuf-c-1.4.1-1 psmisc-23.6-1
pulseaudio-16.1-3 pulseaudio-bluetooth-16.1-3
pulseaudio-equalizer-16.1-3 pulseaudio-jack-16.1-3
pulseaudio-lirc-16.1-3 pulseaudio-rtp-16.1-3
pulseaudio-zeroconf-16.1-3 pyside6-6.4.2-5 python-3.10.9-1
python-appdirs-1.4.4-7 python-attrs-22.2.0-1
python-autocommand-2.2.2-1 python-cachecontrol-1:0.12.11-1
python-cairo-1.23.0-3 python-certifi-2022.12.07-1
python-chardet-5.1.0-1 python-colorama-0.4.6-1
python-commonmark-0.9.1-6 python-cryptography-39.0.1-1
python-distlib-0.3.6-1 python-distro-1.8.0-2
python-dnspython-1:2.2.1-2 python-docutils-1:0.19-2
python-dotty-dict-1.3.1-2 python-fastjsonschema-2.16.2-1
python-gobject-3.42.2-1 python-idna-3.4-1
python-importlib-metadata-5.0.0-3 python-inflect-6.0.2-1
python-jaraco.context-4.3.0-1 python-jaraco.functools-3.5.2-1
python-jaraco.text-3.11.1-1 python-jsonschema-4.17.3-1
python-manjaro-sdk-0.9-1 python-markdown-3.4.1-2
python-markdown-it-py-2.1.0-1 python-mdurl-0.1.2-2
python-more-itertools-9.0.0-1 python-msgpack-1.0.4-1
python-nspektr-0.4.0-2 python-ordered-set-4.1.0-1
python-packaging-23.0-1 python-pillow-9.4.0-2
python-pip-22.3.1-1 python-platformdirs-2.6.2-1
python-psutil-5.9.4-1 python-pydantic-1.10.4-1
python-pygments-2.14.0-2 python-pyopenssl-23.0.0-1
python-pyqt5-5.15.9-1 python-pyqt5-sip-12.11.1-1
python-pyrsistent-0.19.3-1 python-reportlab-3.6.12-2
python-requests-2.28.1-1 python-resolvelib-0.9.0-1
python-retrying-1.3.3-15 python-rich-13.3.1-1
python-setuptools-1:67.2.0-1 python-six-1.16.0-6
python-systemd-235-1 python-tenacity-8.2.1-1
python-termcolor-2.2.0-1 python-toml-0.10.2-8
python-trove-classifiers-2023.2.8-1
python-typing_extensions-4.4.0-1 python-uc-micro-py-1.0.1-3
python-urllib3-1.26.12-1 python-validate-pyproject-0.12.1-1
python-wheel-0.38.4-1 python-zipp-3.13.0-1 qmk-1.1.1-1
qpdf-11.2.0-1 qrencode-4.1.1-2 qt5-base-5.15.8+kde+r181-1
qt5-declarative-5.15.8+kde+r24-2
qt5-imageformats-5.15.8+kde+r9-1 qt5-svg-5.15.8+kde+r8-1
qt5-translations-5.15.8-1 qt5-wayland-5.15.8+kde+r58-1
qt5-x11extras-5.15.8-1 qt6-5compat-6.4.2-1 qt6-base-6.4.2-1
qt6-declarative-6.4.2-1 qt6-imageformats-6.4.2-1
qt6-svg-6.4.2-1 qt6-translations-6.4.2-1 qt6-wayland-6.4.2-1
r-4.2.2-2 raptor-2.0.15-21 rav1e-0.6.3-1 readline-8.2.001-2
redshift-1.12-6 reiserfsprogs-3.6.27-4 rhash-1.4.3-1
rpcbind-1.2.6-3 rsync-3.2.7-3 rtkit-0.13-2 ruby-3.0.5-1
ruby-abbrev-0.1.0-4 ruby-addressable-2.8.1-1
ruby-base64-0.1.1-4 ruby-benchmark-0.2.0-4
ruby-bigdecimal-3.1.2-4 ruby-bundledgems-3.0.5-1
ruby-bundler-2.4.1-1 ruby-cgi-0.3.6-1 ruby-csv-3.2.5-4
ruby-date-3.2.2-4 ruby-delegate-0.2.0-4
ruby-did_you_mean-1.6.1-4 ruby-digest-3.1.1-1 ruby-drb-2.1.0-5
ruby-english-0.7.1-5 ruby-erb-4.0.2-2 ruby-etc-1.3.0-6
ruby-eventmachine-1.2.7-6 ruby-fcntl-1.0.1-4
ruby-fiddle-1.1.0-4 ruby-fileutils-1.6.0-4 ruby-find-0.1.1-4
ruby-forwardable-1.3.2-6 ruby-getoptlong-0.1.1-3
ruby-i18n-1.12.0-1 ruby-io-console-0.5.11-3
ruby-io-nonblock-0.1.0-3 ruby-io-wait-0.2.3-4
ruby-ipaddr-1.2.4-3 ruby-irb-1.4.2-1
ruby-jekyll-sass-converter-2.2.0-1 ruby-json-2.6.3-1
ruby-kramdown-parser-gfm-1.1.0-2 ruby-listen-3.8.0-2
ruby-logger-1.5.1-3 ruby-minitest-5.16.3-1 ruby-mocha-1.16.1-1
ruby-mutex_m-0.1.1-3 ruby-net-http-0.2.2-2
ruby-open-uri-0.2.0-3 ruby-power_assert-2.0.2-1
ruby-psych-4.0.6-1 ruby-public_suffix-5.0.0-1
ruby-racc-1.6.0-3 ruby-rake-13.0.6-1 ruby-rb-fsevent-0.11.2-1
ruby-rdoc-6.4.0-4 ruby-reline-0.3.1-2
ruby-ruby2_keywords-0.0.5-1 ruby-stdlib-3.0.5-1
ruby-stringio-3.0.2-4 ruby-test-unit-3.5.7-1 ruby-time-0.2.0-4
ruby-tmpdir-0.1.2-3 ruby-tzinfo-2.0.5-1
ruby-unicode-display_width-2.4.2-1 ruby-uri-0.11.0-5
ruby-zeitwerk-2.6.1-1 rubygems-3.3.25-1 s-nail-14.9.24-2
samba-4.17.5-1 sane-1.1.1-2 sbc-2.0-1 sdl2-2.26.3-1
sed-4.9-1 serd-0.30.16-1 shaderc-2022.4-1 shadow-4.13-2
shared-mime-info-2.2+13+ga2ffb28-1 shiboken6-6.4.2-5
slang-2.3.3-2 smbclient-4.17.5-1 snapd-2.58.2-1
snapd-glib-1.63-3 sof-firmware-2.2.4-1 sord-0.16.14-1
soundtouch-2.3.2-1 spandsp-0.0.6-4
spectre-meltdown-checker-0.45+1+gb68ebe6-2 spirv-tools-2022.4-1
splix-2.0.0-19 sqlite-3.40.1-1 squashfs-tools-4.5.1-2
sratom-0.6.14-1 srt-1.5.1-3 steam-1.0.0.75-2
steam-manjaro-1.0.0.74-1 [removal] strawberry-1.0.14-2
sudo-1.9.12.p2-1 suitesparse-7.0.1-2 svt-av1-1.4.1-1
systemd-252.5-1 systemd-libs-252.5-1
systemd-sysvcompat-252.5-1 taglib-1.13-1 talloc-2.4.0-2
tcl-8.6.13-1 tdb-1.4.8-1 telegram-desktop-4.6.1-1
terminus-font-4.49.1-5 tevent-1:0.14.0-1 texinfo-7.0.2-2
thin-provisioning-tools-1.0.0-1 thunar-4.18.3-1
thunar-media-tags-plugin-0.4.0-1 thunar-volman-4.18.0-1
thunarx-python-0.5.2-3 thunderbird-102.7.2-1
timeshift-22.11.2-1 tlp-1.5.0-5 tpm2-tss-3.2.0-3
tracker3-3.4.2-2 tumbler-4.18.0-1 tzdata-2022g-2
unrar-1:6.2.5-1 unzip-6.0-19 upower-1.90.0-3 usbmuxd-1.1.1-2
usbutils-015-2 util-linux-2.38.1-1 util-linux-libs-2.38.1-1
vi-1:070224-6 vlc-3.0.18-6 vpnc-1:0.5.3.r506.r204-2
vte-common-0.70.2-1 vte3-0.70.2-1 vulkan-headers-1:1.3.240-1
vulkan-icd-loader-1.3.240-1 vulkan-intel-22.3.5-1
vulkan-radeon-22.3.5-1 wavpack-5.6.0-1 wayland-1.21.0-2
wayland-protocols-1.31-1 webkit2gtk-2.38.4-1
webkit2gtk-4.1-2.38.4-1 wildmidi-0.4.5-1
wireless-regdb-2022.08.12-1 woff2-1.0.2-4
wpa_supplicant-2:2.10-8 wpebackend-fdo-1.14.0-1
x264-3:0.164.r3095.baee400-4 xapp-2.4.2-1 xcb-proto-1.15.2-2
xcb-util-0.4.1-1 xcb-util-cursor-0.1.4-1
xcb-util-image-0.4.1-2 xcb-util-keysyms-0.4.1-4
xcb-util-renderutil-0.3.10-1 xcb-util-wm-0.4.2-1
xcursor-breeze-5.24.6-1 xdg-desktop-portal-1.16.0-1
xdg-desktop-portal-gnome-43.1-1 xdg-desktop-portal-gtk-1.14.1-1
xdg-user-dirs-0.18-1 xdg-utils-1.1.3+25+g8ae0263-1
xf86-input-elographics-1.4.3-1 xf86-input-void-1.4.2-1
xf86-input-wacom-1.1.0-1
xf86-video-ati-1:19.1.0.r15.g7a6a34af-1
xf86-video-intel-1:2.99.917+923+gb74b67f0-1
xfce4-appfinder-4.18.0-1 xfce4-cpufreq-plugin-1.2.8-1
xfce4-cpugraph-plugin-1.2.7-1 xfce4-notifyd-0.7.3-1
xfce4-panel-4.18.2-1 xfce4-power-manager-4.18.0-1
xfce4-pulseaudio-plugin-0.4.5-1 xfce4-screenshooter-1.10.3-1
xfce4-sensors-plugin-1.4.4-1 xfce4-session-4.18.0-1
xfce4-settings-4.18.1-1 xfce4-systemload-plugin-1.3.2-1
xfce4-taskmanager-1.5.5-1 xfce4-whiskermenu-plugin-2.7.2-1
xfce4-xkb-plugin-0.8.3-1 xfconf-4.18.0-1 xfdesktop-4.18.1-1
xfsprogs-6.1.1-2 xfwm4-4.18.0-1 xkeyboard-config-2.37-1
xmlsec-1.2.37-1 xorg-bdftopcf-1.1.1-1 xorg-font-util-1.3.3-1
xorg-fonts-encodings-1.0.6-1 xorg-server-21.1.7-1
xorg-server-common-21.1.7-1 xorg-xhost-1.0.9-1
xorg-xinit-1.4.2-1 xorg-xkbcomp-1.4.6-1 xorg-xkill-1.0.6-1
xorg-xmessage-1.0.6-1 xorg-xmodmap-1.0.11-1 xorg-xprop-1.2.6-1
xorg-xrandr-1.5.2-1 xorg-xset-1.2.5-1 xorgproto-2022.2-1
xxhash-0.8.1-3 xz-5.4.1-1 yasm-1.3.0-6 yay-11.3.2-1
yelp-42.2-1 yelp-xsl-42.1-1 zbar-0.23.90-1 zenity-3.44.0-1
zensu-0.3-7 zita-alsa-pcmi-0.6.1-1 zlib-1:1.2.13-2 zsh-5.9-3
zstd-1.5.2-8 zvbi-0.2.40-1 zxing-cpp-2.0.0-1
Total Download Size: 82.92 MiB
Total Installed Size: 10363.65 MiB
Net Upgrade Size: 483.15 MiB
firefox-110.0-0.... 82.9 MiB 25.4 MiB/s 00:03 [######################] 100%
(932/932) checking keys in keyring [######################] 100%
(932/932) checking package integrity [######################] 100%
(932/932) loading package files [######################] 100%
(932/932) checking for file conflicts [######################] 100%
error: failed to commit transaction (conflicting files)
ruby-bundler: /usr/bin/bundle exists in filesystem
ruby-bundler: /usr/bin/bundler exists in filesystem
ruby-ruby2_keywords: /usr/lib/ruby/gems/3.0.0/gems/ruby2_keywords-0.0.5/LICENSE exists in filesystem
ruby-ruby2_keywords: /usr/lib/ruby/gems/3.0.0/gems/ruby2_keywords-0.0.5/README.md exists in filesystem
ruby-ruby2_keywords: /usr/lib/ruby/gems/3.0.0/gems/ruby2_keywords-0.0.5/lib/ruby2_keywords.rb exists in filesystem
ruby-ruby2_keywords: /usr/lib/ruby/gems/3.0.0/specifications/ruby2_keywords-0.0.5.gemspec exists in filesystem
ruby-racc: /usr/bin/racc exists in filesystem
Errors occurred, no packages were upgraded
brahma
February 16, 2023, 8:28pm
15
so you have also exist in filesystem errors, so use overwrite:
sudo pacman --sysroot /mnt -S ruby-bundler ruby-ruby2_keywords ruby-racc --overwrite '*'
then run again the update:
if there were no errors, then install the kernel 5.15
blp92
February 16, 2023, 8:43pm
16
it looks like the update went without any errors, just warnings:
core is up to date
extra is up to date
community is up to date
warning: ruby-stdlib will be installed before its ruby dependency
Packages (932) a52dec-0.7.4-12 aalib-1.4rc5-15 abseil-cpp-20220623.1-1
ruby-cgi-0.3.6-1 ruby-csv-3.2.5-4 ruby-date-3.2.2-4
ruby-delegate-0.2.0-4 ruby-did_you_mean-1.6.1-4
ruby-digest-3.1.1-1 ruby-drb-2.1.0-5 ruby-english-0.7.1-5
ruby-erb-4.0.2-2 ruby-etc-1.3.0-6 ruby-eventmachine-1.2.7-6
ruby-fcntl-1.0.1-4 ruby-fiddle-1.1.0-4 ruby-fileutils-1.6.0-4
ruby-find-0.1.1-4 ruby-forwardable-1.3.2-6
ruby-getoptlong-0.1.1-3 ruby-i18n-1.12.0-1
ruby-io-console-0.5.11-3 ruby-io-nonblock-0.1.0-3
ruby-io-wait-0.2.3-4 ruby-ipaddr-1.2.4-3 ruby-irb-1.4.2-1
ruby-rake-13.0.6-1 ruby-rb-fsevent-0.11.2-1 ruby-rdoc-6.4.0-4
ruby-reline-0.3.1-2 ruby-stdlib-3.0.5-1 ruby-stringio-3.0.2-4
ruby-test-unit-3.5.7-1 ruby-time-0.2.0-4 ruby-tmpdir-0.1.2-3
ruby-tzinfo-2.0.5-1 ruby-unicode-display_width-2.4.2-1
ruby-uri-0.11.0-5 ruby-zeitwerk-2.6.1-1 rubygems-3.3.25-1
s-nail-14.9.24-2 samba-4.17.5-1 sane-1.1.1-2 sbc-2.0-1
sdl2-2.26.3-1 sed-4.9-1 serd-0.30.16-1 shaderc-2022.4-1
shadow-4.13-2 shared-mime-info-2.2+13+ga2ffb28-1
shiboken6-6.4.2-5 slang-2.3.3-2 smbclient-4.17.5-1
snapd-2.58.2-1 snapd-glib-1.63-3 sof-firmware-2.2.4-1
sord-0.16.14-1 soundtouch-2.3.2-1 spandsp-0.0.6-4
Total Installed Size: 10361.80 MiB
Net Upgrade Size: 481.30 MiB
(929/929) checking keys in keyring [######################] 100%
(929/929) checking package integrity [######################] 100%
(929/929) loading package files [######################] 100%
(929/929) checking for file conflicts [######################] 100%
(932/932) checking available disk space [######################] 100%
(1/5) Creating Timeshift snapshot before upgrade...
(2/5) Removing linux initcpios...
(3/5) Remove Firefox Distribution Settings
(4/5) Save Linux kernel modules
(5/5) Remove Thunderbird Distribution Settings
(1/3) removing steam-manjaro [######################] 100%
(2/3) removing at-spi2-atk [######################] 100%
(3/3) removing atk [######################] 100%
( 1/929) upgrading linux-api-headers [######################] 100%
( 2/929) upgrading tzdata [######################] 100%
New optional dependencies for tzdata
bash: for tzselect [installed]
glibc: for zdump, zic [installed]
( 3/929) upgrading iana-etc [######################] 100%
( 4/929) upgrading filesystem [######################] 100%
( 5/929) upgrading glibc [######################] 100%
warning: /etc/locale.gen installed as /etc/locale.gen.pacnew
Generating locales...
en_US.UTF-8... done
Generation complete.
( 6/929) upgrading a52dec [######################] 100%
( 7/929) upgrading xcb-proto [######################] 100%
( 8/929) upgrading libxdmcp [######################] 100%
( 9/929) upgrading libxau [######################] 100%
( 10/929) upgrading libxcb [######################] 100%
( 11/929) upgrading xorgproto [######################] 100%
( 12/929) upgrading libx11 [######################] 100%
( 13/929) upgrading gcc-libs [######################] 100%
( 14/929) upgrading ncurses [######################] 100%
( 15/929) upgrading readline [######################] 100%
( 16/929) upgrading xz [######################] 100%
( 17/929) upgrading zlib [######################] 100%
( 18/929) upgrading lz4 [######################] 100%
( 19/929) upgrading zstd [######################] 100%
( 20/929) upgrading libxcrypt [######################] 100%
( 21/929) upgrading util-linux-libs [######################] 100%
( 22/929) upgrading e2fsprogs [######################] 100%
( 23/929) upgrading libsasl [######################] 100%
( 24/929) upgrading libldap [######################] 100%
( 25/929) upgrading libevent [######################] 100%
New optional dependencies for libevent
python: event_rpcgen.py [installed]
( 26/929) upgrading krb5 [######################] 100%
( 27/929) upgrading audit [######################] 100%
( 28/929) upgrading libtirpc [######################] 100%
( 29/929) upgrading pambase [######################] 100%
( 30/929) upgrading libcap [######################] 100%
( 31/929) upgrading libgpg-error [######################] 100%
( 32/929) upgrading libgcrypt [######################] 100%
( 33/929) upgrading libffi [######################] 100%
( 34/929) upgrading libtasn1 [######################] 100%
( 35/929) upgrading systemd-libs [######################] 100%
( 36/929) upgrading aalib [######################] 100%
( 37/929) upgrading abseil-cpp [######################] 100%
( 38/929) upgrading acpid [######################] 100%
( 39/929) upgrading libsysprof-capture [######################] 100%
( 40/929) upgrading bzip2 [######################] 100%
( 41/929) upgrading pcre2 [######################] 100%
( 42/929) upgrading glib2 [######################] 100%
( 43/929) upgrading libpng [######################] 100%
( 44/929) upgrading libjpeg-turbo [######################] 100%
( 45/929) upgrading libtiff [######################] 100%
( 46/929) upgrading icu [######################] 100%
( 47/929) upgrading libxml2 [######################] 100%
( 48/929) upgrading shared-mime-info [######################] 100%
( 49/929) upgrading gdk-pixbuf2 [######################] 100%
( 50/929) upgrading expat [######################] 100%
( 51/929) upgrading harfbuzz [######################] 100%
( 52/929) upgrading brotli [######################] 100%
( 53/929) upgrading fontconfig [######################] 100%
Rebuilding fontconfig cache...
( 54/929) upgrading libxext [######################] 100%
( 55/929) upgrading libxrender [######################] 100%
( 56/929) upgrading lzo [######################] 100%
( 57/929) upgrading pixman [######################] 100%
( 58/929) upgrading cairo [######################] 100%
( 59/929) upgrading libdatrie [######################] 100%
( 60/929) upgrading libthai [######################] 100%
( 61/929) upgrading libxft [######################] 100%
( 62/929) upgrading pango [######################] 100%
( 63/929) upgrading librsvg [######################] 100%
( 64/929) upgrading gtk-update-icon-cache [######################] 100%
( 65/929) installing adwaita-cursors [######################] 100%
( 66/929) upgrading adwaita-icon-theme [######################] 100%
( 67/929) upgrading alsa-card-profiles [######################] 100%
( 68/929) upgrading alsa-ucm-conf [######################] 100%
( 69/929) upgrading alsa-lib [######################] 100%
( 70/929) upgrading hwdata [######################] 100%
( 71/929) upgrading kmod [######################] 100%
( 72/929) upgrading pciutils [######################] 100%
New optional dependencies for pciutils
curl: for update-pciids [installed]
grep: for update-pciids [installed]
which: for update-pciids [installed]
( 73/929) upgrading psmisc [######################] 100%
( 74/929) upgrading alsa-utils [######################] 100%
( 75/929) upgrading amd-ucode [######################] 100%
( 76/929) upgrading protobuf [######################] 100%
( 77/929) upgrading device-mapper [######################] 100%
( 78/929) upgrading popt [######################] 100%
( 79/929) upgrading cryptsetup [######################] 100%
( 80/929) upgrading libnftnl [######################] 100%
( 81/929) upgrading libnl [######################] 100%
( 82/929) upgrading libpcap [######################] 100%
( 83/929) upgrading iptables [######################] 100%
( 84/929) upgrading libunistring [######################] 100%
( 85/929) upgrading libidn2 [######################] 100%
( 86/929) upgrading coreutils [######################] 100%
( 87/929) upgrading findutils [######################] 100%
( 88/929) upgrading ca-certificates-utils [######################] 100%
( 89/929) upgrading ca-certificates-mozilla [######################] 100%
( 90/929) upgrading ca-certificates [######################] 100%
( 91/929) upgrading libnghttp2 [######################] 100%
( 92/929) upgrading libpsl [######################] 100%
( 93/929) upgrading libssh2 [######################] 100%
( 94/929) upgrading curl [######################] 100%
( 95/929) upgrading libelf [######################] 100%
( 96/929) upgrading shadow [######################] 100%
( 97/929) upgrading file [######################] 100%
( 98/929) upgrading util-linux [######################] 100%
( 99/929) upgrading systemd [######################] 100%
New optional dependencies for systemd
curl: systemd-journal-upload, machinectl pull-tar and pull-raw [installed]
gnutls: systemd-journal-gatewayd and systemd-journal-remote [installed]
libbpf: support BPF programs [installed]
(100/929) upgrading android-udev [######################] 100%
(101/929) upgrading android-tools [######################] 100%
(102/929) upgrading aom [######################] 100%
(103/929) upgrading python [######################] 100%
(104/929) upgrading apparmor [######################] 100%
(105/929) upgrading libxi [######################] 100%
(106/929) upgrading libxfixes [######################] 100%
(107/929) upgrading libxtst [######################] 100%
(108/929) upgrading at-spi2-core [######################] 100%
(109/929) upgrading dconf [######################] 100%
(110/929) upgrading iso-codes [######################] 100%
(111/929) upgrading libcloudproviders [######################] 100%
(112/929) upgrading nettle [######################] 100%
(113/929) upgrading gnutls [######################] 100%
(114/929) upgrading libcups [######################] 100%
(115/929) upgrading libpciaccess [######################] 100%
(116/929) upgrading libdrm [######################] 100%
(117/929) installing default-cursors [######################] 100%
warning: /usr/share/icons/default/index.theme installed as /usr/share/icons/default/index.theme.pacnew
Optional dependencies for default-cursors
adwaita-cursors: default cursor theme [installed]
(118/929) upgrading wayland [######################] 100%
(119/929) upgrading libxxf86vm [######################] 100%
(120/929) upgrading libxdamage [######################] 100%
(121/929) upgrading libxshmfence [######################] 100%
(122/929) upgrading libomxil-bellagio [######################] 100%
(123/929) upgrading libunwind [######################] 100%
(124/929) upgrading libedit [######################] 100%
(125/929) upgrading llvm-libs [######################] 100%
(126/929) upgrading lm_sensors [######################] 100%
(127/929) upgrading vulkan-icd-loader [######################] 100%
(128/929) upgrading lib32-glibc [######################] 100%
(129/929) upgrading lib32-vulkan-icd-loader [######################] 100%
(130/929) upgrading mesa [######################] 100%
(131/929) upgrading libglvnd [######################] 100%
(132/929) upgrading libxcomposite [######################] 100%
(133/929) upgrading libxcursor [######################] 100%
(134/929) upgrading libxinerama [######################] 100%
(135/929) upgrading xkeyboard-config [######################] 100%
(136/929) upgrading libxkbcommon [######################] 100%
(137/929) upgrading libxrandr [######################] 100%
(138/929) upgrading duktape [######################] 100%
(139/929) upgrading libproxy [######################] 100%
New optional dependencies for libproxy
pacrunner: PAC proxy support (via pacrunner)
(140/929) upgrading gsettings-desktop-schemas [######################] 100%
(141/929) upgrading glib-networking [######################] 100%
(142/929) upgrading sqlite [######################] 100%
(143/929) upgrading libsoup3 [######################] 100%
(144/929) upgrading tracker3 [######################] 100%
(145/929) upgrading lcms2 [######################] 100%
(146/929) upgrading gtk3 [######################] 100%
(147/929) upgrading libyaml [######################] 100%
(148/929) upgrading libarchive [######################] 100%
(149/929) upgrading libksba [######################] 100%
(150/929) upgrading lib32-gcc-libs [######################] 100%
(151/929) upgrading lib32-libxcrypt [######################] 100%
(152/929) upgrading lib32-e2fsprogs [######################] 100%
(153/929) upgrading lib32-libldap [######################] 100%
(154/929) upgrading lib32-krb5 [######################] 100%
(155/929) upgrading lib32-libtirpc [######################] 100%
(156/929) upgrading lib32-libcap [######################] 100%
(157/929) upgrading tpm2-tss [######################] 100%
(158/929) upgrading pinentry [######################] 100%
(159/929) upgrading gnupg [######################] 100%
NOTE: GnuPG's systemd sockets are now enabled in the vendor location /usr/lib/systemd/user/!
(160/929) upgrading gpgme [######################] 100%
(161/929) upgrading gettext [######################] 100%
(162/929) upgrading mpfr [######################] 100%
(163/929) upgrading gawk [######################] 100%
(164/929) upgrading grep [######################] 100%
(165/929) upgrading sed [######################] 100%
(166/929) upgrading fakeroot [######################] 100%
(167/929) installing db5.3 [######################] 100%
(168/929) upgrading perl [######################] 100%
(169/929) upgrading python-urllib3 [######################] 100%
(170/929) upgrading python-chardet [######################] 100%
(171/929) upgrading python-idna [######################] 100%
(172/929) upgrading python-requests [######################] 100%
(173/929) upgrading python-certifi [######################] 100%
(174/929) upgrading pacman-mirrors [######################] 100%
(175/929) upgrading pacman [######################] 100%
(176/929) upgrading gcab [######################] 100%
(177/929) upgrading appstream-glib [######################] 100%
(178/929) upgrading archlinux-appstream-data [######################] 100%
(179/929) upgrading arm-none-eabi-binutils [######################] 100%
(180/929) upgrading libmpc [######################] 100%
(181/929) upgrading arm-none-eabi-gcc [######################] 100%
(182/929) upgrading aspell [######################] 100%
(183/929) upgrading libsigc++ [######################] 100%
(184/929) upgrading glibmm [######################] 100%
(185/929) upgrading atkmm [######################] 100%
(186/929) upgrading xcb-util-keysyms [######################] 100%
(187/929) upgrading xcb-util-renderutil [######################] 100%
(188/929) upgrading libice [######################] 100%
(189/929) upgrading libsm [######################] 100%
(190/929) upgrading libxmu [######################] 100%
(191/929) upgrading xorg-xset [######################] 100%
(192/929) upgrading xorg-xprop [######################] 100%
(193/929) upgrading xdg-utils [######################] 100%
(194/929) upgrading xcb-util-wm [######################] 100%
(195/929) upgrading xcb-util [######################] 100%
(196/929) upgrading xcb-util-image [######################] 100%
(197/929) upgrading libevdev [######################] 100%
(198/929) upgrading libwacom [######################] 100%
(199/929) upgrading libinput [######################] 100%
(200/929) upgrading libxkbcommon-x11 [######################] 100%
(201/929) upgrading double-conversion [######################] 100%
(202/929) upgrading qt5-translations [######################] 100%
(203/929) upgrading qt5-base [######################] 100%
(204/929) upgrading qt5-svg [######################] 100%
(205/929) upgrading freeglut [######################] 100%
(206/929) upgrading jasper [######################] 100%
(207/929) upgrading libwebp [######################] 100%
(208/929) upgrading qt5-imageformats [######################] 100%
(209/929) upgrading faad2 [######################] 100%
(210/929) upgrading gsm [######################] 100%
(211/929) upgrading jack2 [######################] 100%
(212/929) upgrading lame [######################] 100%
(213/929) upgrading libass [######################] 100%
(214/929) upgrading libbluray [######################] 100%
(215/929) upgrading flac [######################] 100%
(216/929) upgrading mpg123 [######################] 100%
(217/929) upgrading libsndfile [######################] 100%
(218/929) upgrading libbs2b [######################] 100%
(219/929) upgrading libiec61883 [######################] 100%
(220/929) upgrading libmfx [######################] 100%
(221/929) upgrading libmodplug [######################] 100%
(222/929) upgrading libasyncns [######################] 100%
(223/929) upgrading libpulse [######################] 100%
(224/929) upgrading libgit2 [######################] 100%
(225/929) upgrading rav1e [######################] 100%
(226/929) upgrading libsoxr [######################] 100%
(227/929) upgrading libssh [######################] 100%
(228/929) upgrading libva [######################] 100%
New optional dependencies for libva
libva-mesa-driver: backend for AMD and Nvidia GPUs [installed]
(229/929) upgrading libvpx [######################] 100%
(230/929) upgrading x264 [######################] 100%
(231/929) upgrading libxv [######################] 100%
(232/929) upgrading opencore-amr [######################] 100%
(233/929) upgrading openjpeg2 [######################] 100%
(234/929) upgrading hidapi [######################] 100%
(235/929) upgrading sdl2 [######################] 100%
(236/929) upgrading srt [######################] 100%
(237/929) upgrading svt-av1 [######################] 100%
(238/929) upgrading ffmpeg [######################] 100%
(239/929) installing libcamera [######################] 100%
Optional dependencies for libcamera
gst-plugin-libcamera: GStreamer plugin
libcamera-docs: for documentation
libcamera-tools: for applications
(240/929) upgrading pipewire [######################] 100%
New optional dependencies for pipewire
pipewire-audio: Audio support
pipewire-roc: ROC streaming
(241/929) upgrading fluidsynth [######################] 100%
(242/929) upgrading libnotify [######################] 100%
(243/929) upgrading libsidplayfp [######################] 100%
(244/929) upgrading libusb-compat [######################] 100%
(245/929) upgrading lirc [######################] 100%
(246/929) upgrading neon [######################] 100%
(247/929) upgrading wavpack [######################] 100%
(248/929) upgrading libopenmpt [######################] 100%
(249/929) upgrading libcddb [######################] 100%
(250/929) upgrading qt5-x11extras [######################] 100%
(251/929) upgrading libcdio [######################] 100%
(252/929) upgrading audacious-plugins [######################] 100%
(253/929) upgrading audacious [######################] 100%
(254/929) upgrading avr-binutils [######################] 100%
(255/929) upgrading avr-gcc [######################] 100%
(256/929) upgrading elfutils [######################] 100%
(257/929) upgrading avrdude [######################] 100%
(258/929) upgrading b43-fwcutter [######################] 100%
(259/929) upgrading babl [######################] 100%
(260/929) upgrading libxres [######################] 100%
(261/929) upgrading libwnck3 [######################] 100%
(262/929) upgrading bamf [######################] 100%
(263/929) upgrading bash-completion [######################] 100%
(264/929) upgrading binutils [######################] 100%
(265/929) upgrading libical [######################] 100%
(266/929) upgrading bluez [######################] 100%
warning: directory permissions differ on /etc/bluetooth/
filesystem: 755 package: 555
(267/929) upgrading bluez-libs [######################] 100%
(268/929) upgrading nspr [######################] 100%
(269/929) upgrading nss [######################] 100%
(270/929) upgrading libnm [######################] 100%
(271/929) upgrading python-cairo [######################] 100%
(272/929) upgrading gobject-introspection-runtime [######################] 100%
(273/929) upgrading python-gobject [######################] 100%
(274/929) upgrading blueman [######################] 100%
(275/929) upgrading boost-libs [######################] 100%
(276/929) upgrading botan [######################] 100%
(277/929) upgrading btrfs-progs [######################] 100%
(278/929) upgrading bubblewrap [######################] 100%
(279/929) upgrading cairomm [######################] 100%
(280/929) upgrading libxfce4util [######################] 100%
(281/929) upgrading xfconf [######################] 100%
(282/929) upgrading catfish [######################] 100%
(283/929) upgrading chromaprint [######################] 100%
(284/929) upgrading talloc [######################] 100%
(285/929) upgrading libbsd [######################] 100%
(286/929) installing libwbclient [######################] 100%
Optional dependencies for libwbclient
python-dnspython: samba_dnsupdate and samba_upgradedns in AD setup
[installed]
python-markdown: for samba-tool domain schemeupgrade [installed]
glusterfs: for vfs_glusterfs support
(287/929) upgrading cifs-utils [######################] 100%
New optional dependencies for cifs-utils
python: for smb2-quota and smbinfo script [installed]
(288/929) upgrading ckbcomp [######################] 100%
(289/929) upgrading gcc [######################] 100%
(290/929) upgrading compiler-rt [######################] 100%
(291/929) upgrading clang [######################] 100%
(292/929) upgrading clucene [######################] 100%
(293/929) upgrading libuv [######################] 100%
(294/929) upgrading rhash [######################] 100%
(295/929) upgrading cmake [######################] 100%
(296/929) upgrading cpupower [######################] 100%
(297/929) upgrading poppler [######################] 100%
(298/929) upgrading qpdf [######################] 100%
(299/929) upgrading ijs [######################] 100%
(300/929) upgrading cups-filters [######################] 100%
New optional dependencies for cups-filters
antiword: to convert MS Word documents for Braille embosser support
docx2txt: to convert Microsoft OOXML text from DOCX files for Braille
embosser support
imagemagick: for Braille embosser support [installed]
liblouis: for Braille embosser support [installed]
(301/929) upgrading cups [######################] 100%
libusb: for usb printer backend [installed]
(302/929) upgrading poppler-data [######################] 100%
(303/929) upgrading ghostscript [######################] 100%
(304/929) upgrading cups-pdf [######################] 100%
(305/929) upgrading polkit [######################] 100%
(306/929) upgrading cups-pk-helper [######################] 100%
(307/929) upgrading db [######################] 100%
(308/929) upgrading libbpf [######################] 100%
(309/929) upgrading iproute2 [######################] 100%
New optional dependencies for iproute2
db5.3: userspace arp daemon [installed]
python: for routel [installed]
(310/929) upgrading dhclient [######################] 100%
(311/929) upgrading discord [######################] 100%
New optional dependencies for discord
libappindicator-gtk3: Systray indicator support [installed]
(312/929) upgrading djvulibre [######################] 100%
(313/929) upgrading dmraid [######################] 100%
(314/929) installing nftables [######################] 100%
Optional dependencies for nftables
python: Python bindings [installed]
(315/929) upgrading dnsmasq [######################] 100%
(316/929) upgrading dosfstools [######################] 100%
(317/929) upgrading ecryptfs-utils [######################] 100%
(318/929) upgrading efibootmgr [######################] 100%
(319/929) upgrading enchant [######################] 100%
(320/929) upgrading libgxps [######################] 100%
(321/929) upgrading libspectre [######################] 100%
(322/929) upgrading poppler-glib [######################] 100%
(323/929) upgrading libsynctex [######################] 100%
(324/929) upgrading gnome-desktop-common [######################] 100%
(325/929) upgrading gnome-desktop [######################] 100%
(326/929) upgrading gstreamer [######################] 100%
(327/929) upgrading orc [######################] 100%
(328/929) upgrading gst-plugins-base-libs [######################] 100%
(329/929) upgrading gspell [######################] 100%
(330/929) upgrading libhandy [######################] 100%
(331/929) upgrading fuse-common [######################] 100%
(332/929) upgrading fuse3 [######################] 100%
(333/929) upgrading ldns [######################] 100%
(334/929) upgrading openssh [######################] 100%
Removed "/etc/systemd/user/sockets.target.wants/gcr-ssh-agent.socket".
(335/929) upgrading gcr [######################] 100%
(336/929) upgrading gptfdisk [######################] 100%
(337/929) upgrading thin-provisioning-tools [######################] 100%
(338/929) upgrading lvm2 [######################] 100%
(339/929) upgrading ndctl [######################] 100%
(340/929) upgrading libinih [######################] 100%
(341/929) upgrading liburcu [######################] 100%
(342/929) upgrading xfsprogs [######################] 100%
New optional dependencies for xfsprogs
icu: for xfs_scrub [installed]
(343/929) upgrading libblockdev [######################] 100%
(344/929) upgrading gvfs [######################] 100%
(345/929) upgrading evince [######################] 100%
(346/929) upgrading exiv2 [######################] 100%
(347/929) upgrading libxfce4ui [######################] 100%
(348/929) upgrading exo [######################] 100%
(349/929) upgrading f2fs-tools [######################] 100%
(350/929) upgrading noto-fonts [######################] 100%
(351/929) upgrading firefox [######################] 100%
(352/929) installing libxmlb [######################] 100%
(353/929) installing appstream [######################] 100%
(354/929) installing libmalcontent [######################] 100%
(355/929) upgrading libsoup [######################] 100%
(356/929) upgrading ostree [######################] 100%
(357/929) upgrading libmm-glib [######################] 100%
(358/929) upgrading geoclue [######################] 100%
(359/929) upgrading rtkit [######################] 100%
(360/929) upgrading xdg-desktop-portal-gtk [######################] 100%
(361/929) upgrading gssdp [######################] 100%
(362/929) upgrading gupnp [######################] 100%
(363/929) upgrading gupnp-igd [######################] 100%
(364/929) upgrading libnice [######################] 100%
(365/929) upgrading gst-plugins-bad-libs [######################] 100%
(366/929) upgrading gtk4 [######################] 100%
(367/929) upgrading libadwaita [######################] 100%
(368/929) installing gcr-4 [######################] 100%
Created symlink /etc/systemd/user/sockets.target.wants/gcr-ssh-agent.socket → /usr/lib/systemd/user/gcr-ssh-agent.socket.
Optional dependencies for gcr-4
gtk4: gcr-viewer-gtk4 [installed]
(369/929) upgrading gnome-keyring [######################] 100%
(370/929) upgrading gnome-desktop-4 [######################] 100%
(371/929) upgrading xdg-desktop-portal-gnome [######################] 100%
(372/929) upgrading xdg-desktop-portal [######################] 100%
(373/929) upgrading flatpak [######################] 100%
(374/929) upgrading m4 [######################] 100%
(375/929) upgrading flex [######################] 100%
(376/929) upgrading fmt [######################] 100%
(377/929) upgrading foomatic-db [######################] 100%
(378/929) upgrading foomatic-db-gutenprint-ppds [######################] 100%
(379/929) upgrading game-devices-udev [######################] 100%
Running in chroot, ignoring request.
(380/929) upgrading garcon [######################] 100%
(381/929) upgrading gc [######################] 100%
(382/929) upgrading libxpm [######################] 100%
(383/929) upgrading libavif [######################] 100%
(384/929) upgrading libde265 [######################] 100%
(385/929) upgrading libheif [######################] 100%
(386/929) upgrading gd [######################] 100%
(387/929) upgrading libraw [######################] 100%
(388/929) upgrading libspiro [######################] 100%
(389/929) upgrading luajit [######################] 100%
(390/929) upgrading suitesparse [######################] 100%
(391/929) upgrading imath [######################] 100%
(392/929) upgrading gegl [######################] 100%
(393/929) installing geocode-glib-common [######################] 100%
(394/929) upgrading geocode-glib [######################] 100%
(395/929) upgrading libwmf [######################] 100%
(396/929) upgrading libtool [######################] 100%
(397/929) upgrading netpbm [######################] 100%
(398/929) upgrading graphviz [######################] 100%
(399/929) upgrading gimp [######################] 100%
(400/929) upgrading git [######################] 100%
(401/929) upgrading glew [######################] 100%
New optional dependencies for glew
libx11: for glxewinfo and visualinfo [installed]
(402/929) upgrading glslang [######################] 100%
(403/929) upgrading gnome-menus [######################] 100%
(404/929) upgrading grub [######################] 100%
:: GRUB no longer supports side-loading modules when secure boot is
enabled. Thus booting will fail unless you have a 'grubx64.efi'
executable with bundled modules.
(405/929) upgrading grub-btrfs [######################] 100%
New optional dependencies for grub-btrfs
inotify-tools: For grub-btrfsd daemon
snapper: For snapper support
(406/929) upgrading grub-theme-manjaro [######################] 100%
(407/929) upgrading gst-libav [######################] 100%
(408/929) upgrading serd [######################] 100%
New optional dependencies for serd
serd-docs: for developer documentation
(409/929) upgrading pcre [######################] 100%
(410/929) upgrading sord [######################] 100%
New optional dependencies for sord
sord-docs: for developer documentation
(411/929) upgrading lv2 [######################] 100%
New optional dependencies for lv2
lv2-docs: for developer documentation
lv2-example-plugins: for example plugins
python-lxml: for lv2specgen.py
python-markdown: for lv2specgen.py [installed]
(412/929) upgrading sratom [######################] 100%
New optional dependencies for sratom
sratom-docs: for developer documentation
(413/929) upgrading lilv [######################] 100%
New optional dependencies for lilv
lilv-docs: for documentation
python-numpy: for Python bindings
(414/929) upgrading openal [######################] 100%
(415/929) upgrading sbc [######################] 100%
(416/929) upgrading libltc [######################] 100%
(417/929) upgrading soundtouch [######################] 100%
(418/929) upgrading spandsp [######################] 100%
(419/929) upgrading libsrtp [######################] 100%
(420/929) upgrading zvbi [######################] 100%
(421/929) upgrading wildmidi [######################] 100%
(422/929) upgrading libraqm [######################] 100%
(423/929) upgrading imagemagick [######################] 100%
(424/929) upgrading zbar [######################] 100%
(425/929) upgrading qrencode [######################] 100%
(426/929) upgrading zxing-cpp [######################] 100%
(427/929) upgrading libxslt [######################] 100%
(428/929) upgrading raptor [######################] 100%
(429/929) upgrading gst-plugins-bad [######################] 100%
(430/929) upgrading gst-plugins-base [######################] 100%
(431/929) upgrading taglib [######################] 100%
(432/929) upgrading libshout [######################] 100%
(433/929) upgrading imlib2 [######################] 100%
(434/929) upgrading gst-plugins-good [######################] 100%
(435/929) upgrading gst-plugins-ugly [######################] 100%
(436/929) upgrading mbedtls [######################] 100%
(437/929) upgrading gtkhash [######################] 100%
(438/929) upgrading thunar [######################] 100%
(439/929) installing thunarx-python [######################] 100%
(440/929) upgrading gtkhash-thunar [######################] 100%
(441/929) upgrading pangomm [######################] 100%
(442/929) upgrading gtkmm3 [######################] 100%
(443/929) upgrading gtksourceview3 [######################] 100%
(444/929) upgrading gtksourceview4 [######################] 100%
(445/929) upgrading guile [######################] 100%
(446/929) upgrading gutenprint [######################] 100%
>>please run /usr/bin/cups-genppdupdate
>>and restart cups daemon
(447/929) upgrading libplist [######################] 100%
New optional dependencies for libplist
python: for the Python bindings [installed]
(448/929) upgrading libimobiledevice [######################] 100%
(449/929) upgrading usbmuxd [######################] 100%
(450/929) upgrading gvfs-afc [######################] 100%
(451/929) upgrading libgphoto2 [######################] 100%
(452/929) upgrading gvfs-gphoto2 [######################] 100%
(453/929) upgrading gvfs-mtp [######################] 100%
(454/929) upgrading libnfs [######################] 100%
(455/929) upgrading gvfs-nfs [######################] 100%
(456/929) upgrading tdb [######################] 100%
(457/929) upgrading tevent [######################] 100%
(458/929) upgrading lmdb [######################] 100%
(459/929) upgrading ldb [######################] 100%
(460/929) upgrading smbclient [######################] 100%
(461/929) upgrading gvfs-smb [######################] 100%
(462/929) upgrading harfbuzz-icu [######################] 100%
(463/929) upgrading hdparm [######################] 100%
(464/929) upgrading libcanberra [######################] 100%
New optional dependencies for libcanberra
gtk3: canberra-gtk-play [installed]
(465/929) upgrading hexchat [######################] 100%
(466/929) upgrading python-distro [######################] 100%
(467/929) upgrading net-snmp [######################] 100%
(468/929) upgrading perl-clone [######################] 100%
(469/929) upgrading perl-ffi-checklib [######################] 100%
(470/929) upgrading perl-path-tiny [######################] 100%
(471/929) upgrading perl-alien-build [######################] 100%
(472/929) upgrading perl-alien-libxml2 [######################] 100%
(473/929) upgrading perl-xml-namespacesupport [######################] 100%
(474/929) upgrading perl-xml-sax-base [######################] 100%
(475/929) upgrading perl-xml-libxml [######################] 100%
(476/929) upgrading hplip [######################] 100%
(477/929) upgrading htop [######################] 100%
(478/929) upgrading hunspell [######################] 100%
(479/929) upgrading perl-encode-locale [######################] 100%
(480/929) upgrading perl-uri [######################] 100%
(481/929) upgrading perl-html-tagset [######################] 100%
(482/929) upgrading perl-http-date [######################] 100%
(483/929) upgrading perl-lwp-mediatypes [######################] 100%
(484/929) upgrading perl-http-message [######################] 100%
(485/929) upgrading perl-html-parser [######################] 100%
(486/929) upgrading perl-http-negotiate [######################] 100%
(487/929) upgrading perl-www-robotrules [######################] 100%
(488/929) upgrading perl-libwww [######################] 100%
(489/929) upgrading hwinfo [######################] 100%
(490/929) upgrading hwloc [######################] 100%
(491/929) upgrading hyphen [######################] 100%
(492/929) upgrading libibus [######################] 100%
(493/929) upgrading ibus [######################] 100%
(494/929) upgrading inetutils [######################] 100%
(495/929) upgrading inxi [######################] 100%
New optional dependencies for inxi
systemd-sysvcompat: -I runlevel [installed]
xorg-xdriinfo: xdriinfo: -G (X) DRI driver (if missing, fallback to Xorg
log)
(496/929) upgrading iputils [######################] 100%
(497/929) upgrading java-environment-common [######################] 100%
(498/929) upgrading java-runtime-common [######################] 100%
(499/929) upgrading jre8-openjdk-headless [######################] 100%
(500/929) upgrading jre8-openjdk [######################] 100%
(501/929) upgrading jdk8-openjdk [######################] 100%
(502/929) upgrading kcoreaddons [######################] 100%
(503/929) upgrading kauth [######################] 100%
(504/929) upgrading qt5-declarative [######################] 100%
(505/929) upgrading qt5-wayland [######################] 100%
(506/929) upgrading kguiaddons [######################] 100%
(507/929) upgrading kitemmodels [######################] 100%
(508/929) upgrading kwindowsystem [######################] 100%
(509/929) upgrading kvantum [######################] 100%
(510/929) upgrading kwayland [######################] 100%
(511/929) upgrading languagetool [######################] 100%
warning: directory permissions differ on /usr/share/languagetool/third-party-licenses/
filesystem: 755 package: 775
(512/929) upgrading less [######################] 100%
(513/929) upgrading lib32-alsa-lib [######################] 100%
(514/929) upgrading lib32-brotli [######################] 100%
(515/929) upgrading lib32-bzip2 [######################] 100%
(516/929) upgrading lib32-libunistring [######################] 100%
(517/929) upgrading lib32-libidn2 [######################] 100%
(518/929) upgrading lib32-zlib [######################] 100%
(519/929) upgrading lib32-libssh2 [######################] 100%
(520/929) upgrading lib32-libpsl [######################] 100%
(521/929) upgrading lib32-curl [######################] 100%
(522/929) upgrading lib32-expat [######################] 100%
(523/929) upgrading lib32-libxdmcp [######################] 100%
(524/929) upgrading lib32-libxau [######################] 100%
(525/929) upgrading lib32-libxcb [######################] 100%
(526/929) upgrading lib32-libx11 [######################] 100%
(527/929) upgrading lib32-libxext [######################] 100%
(528/929) upgrading lib32-libxfixes [######################] 100%
(529/929) upgrading lib32-libxi [######################] 100%
(530/929) upgrading lib32-libxrender [######################] 100%
(531/929) upgrading lib32-libxrandr [######################] 100%
(532/929) upgrading lib32-libpciaccess [######################] 100%
(533/929) upgrading lib32-libdrm [######################] 100%
(534/929) upgrading lib32-libffi [######################] 100%
(535/929) upgrading lib32-icu [######################] 100%
(536/929) upgrading lib32-xz [######################] 100%
(537/929) upgrading lib32-libxml2 [######################] 100%
(538/929) upgrading lib32-wayland [######################] 100%
(539/929) upgrading lib32-libxxf86vm [######################] 100%
(540/929) upgrading lib32-libxdamage [######################] 100%
(541/929) upgrading lib32-libxshmfence [######################] 100%
(542/929) upgrading lib32-libelf [######################] 100%
(543/929) upgrading lib32-libunwind [######################] 100%
(544/929) upgrading lib32-ncurses [######################] 100%
(545/929) upgrading lib32-llvm-libs [######################] 100%
(546/929) upgrading lib32-lm_sensors [######################] 100%
(547/929) upgrading lib32-mesa [######################] 100%
(548/929) upgrading lib32-libglvnd [######################] 100%
(549/929) upgrading lib32-freeglut [######################] 100%
(550/929) upgrading lib32-libice [######################] 100%
(551/929) upgrading lib32-util-linux [######################] 100%
(552/929) upgrading lib32-libsm [######################] 100%
(553/929) upgrading lib32-libxmu [######################] 100%
(554/929) upgrading lib32-glew [######################] 100%
(555/929) upgrading lib32-libgpg-error [######################] 100%
(556/929) upgrading lib32-libgcrypt [######################] 100%
(557/929) upgrading lib32-libtasn1 [######################] 100%
(558/929) upgrading lib32-libva [######################] 100%
New optional dependencies for lib32-libva
lib32-libva-intel-driver: backend for Intel GPUs (<= Haswell) [installed]
lib32-libva-mesa-driver: backend for AMD and Nvidia GPUs [installed]
(559/929) upgrading lib32-libva-mesa-driver [######################] 100%
(560/929) upgrading lib32-libva-vdpau-driver [######################] 100%
(561/929) upgrading lib32-mesa-vdpau [######################] 100%
(562/929) upgrading lib32-nspr [######################] 100%
(563/929) upgrading lib32-sqlite [######################] 100%
(564/929) upgrading lib32-nss [######################] 100%
(565/929) upgrading lib32-readline [######################] 100%
(566/929) upgrading lib32-systemd [######################] 100%
(567/929) upgrading lib32-vulkan-intel [######################] 100%
(568/929) upgrading vulkan-radeon [######################] 100%
(569/929) upgrading lib32-vulkan-radeon [######################] 100%
(570/929) upgrading libappindicator-gtk3 [######################] 100%
(571/929) upgrading libatomic_ops [######################] 100%
(572/929) upgrading libayatana-indicator [######################] 100%
(573/929) upgrading libayatana-appindicator [######################] 100%
(574/929) upgrading librevenge [######################] 100%
(575/929) upgrading libwpd [######################] 100%
(576/929) upgrading libcdr [######################] 100%
(577/929) upgrading libdiscid [######################] 100%
(578/929) upgrading libe-book [######################] 100%
(579/929) upgrading libebml [######################] 100%
(580/929) upgrading libepubgen [######################] 100%
(581/929) upgrading libetonyek [######################] 100%
(582/929) upgrading xorg-fonts-encodings [######################] 100%
(583/929) upgrading libfontenc [######################] 100%
(584/929) upgrading libgee [######################] 100%
(585/929) upgrading libxkbfile [######################] 100%
(586/929) upgrading libgnomekbd [######################] 100%
(587/929) upgrading libgpod [######################] 100%
(588/929) upgrading libgsf [######################] 100%
(589/929) upgrading libgusb [######################] 100%
(590/929) upgrading libieee1284 [######################] 100%
(591/929) upgrading libimagequant [######################] 100%
(592/929) upgrading libixion [######################] 100%
(593/929) upgrading libkeybinder3 [######################] 100%
(594/929) upgrading liblouis [######################] 100%
(595/929) upgrading libmatroska [######################] 100%
(596/929) upgrading libmbim [######################] 100%
(597/929) upgrading libmspub [######################] 100%
(598/929) upgrading libmusicbrainz5 [######################] 100%
(599/929) upgrading libmwaw [######################] 100%
(600/929) upgrading libmythes [######################] 100%
(601/929) upgrading slang [######################] 100%
(602/929) upgrading libnewt [######################] 100%
(603/929) upgrading mobile-broadband-provider-info [######################] 100%
(604/929) upgrading libnma-common [######################] 100%
(605/929) upgrading libnma [######################] 100%
(606/929) upgrading libnumbertext [######################] 100%
(607/929) upgrading libodfgen [######################] 100%
(608/929) upgrading libopenraw [######################] 100%
(609/929) upgrading liborcus [######################] 100%
(610/929) upgrading libpamac [######################] 100%
(611/929) upgrading libpamac-flatpak-plugin [######################] 100%
(612/929) upgrading squashfs-tools [######################] 100%
(613/929) upgrading snapd [######################] 100%
(614/929) upgrading snapd-glib [######################] 100%
(615/929) upgrading libpamac-snap-plugin [######################] 100%
(616/929) upgrading libpipeline [######################] 100%
(617/929) upgrading spirv-tools [######################] 100%
(618/929) upgrading shaderc [######################] 100%
(619/929) upgrading libplacebo [######################] 100%
(620/929) upgrading protobuf-c [######################] 100%
(621/929) upgrading libpurple [######################] 100%
(622/929) upgrading libqmi [######################] 100%
(623/929) upgrading libqxp [######################] 100%
(624/929) upgrading libwps [######################] 100%
(625/929) upgrading lpsolve [######################] 100%
(626/929) upgrading libwpg [######################] 100%
(627/929) upgrading libvisio [######################] 100%
(628/929) upgrading libzmf [######################] 100%
(629/929) upgrading xmlsec [######################] 100%
(630/929) upgrading libreoffice-fresh [######################] 100%
New optional dependencies for libreoffice-fresh
gtk4: for GTK4 integration (experimental) [installed]
qt6-base: for QT6 desktop integration [installed]
(631/929) upgrading libteam [######################] 100%
(632/929) upgrading libtg_owt [######################] 100%
(633/929) upgrading libupnp [######################] 100%
(634/929) upgrading liburing [######################] 100%
(635/929) upgrading libva-mesa-driver [######################] 100%
(636/929) upgrading libwpe [######################] 100%
(637/929) upgrading libxcvt [######################] 100%
(638/929) upgrading libxfont2 [######################] 100%
(639/929) upgrading libxpresent [######################] 100%
(640/929) upgrading xorg-xkbcomp [######################] 100%
(641/929) upgrading xorg-xrandr [######################] 100%
(642/929) upgrading xorg-server-common [######################] 100%
(643/929) upgrading xorg-server [######################] 100%
(644/929) upgrading xorg-xmodmap [######################] 100%
(645/929) upgrading lightdm [######################] 100%
warning: /etc/lightdm/lightdm.conf installed as /etc/lightdm/lightdm.conf.pacnew
(646/929) upgrading lightdm-gtk-greeter [######################] 100%
(647/929) upgrading linux-firmware-whence [######################] 100%
(648/929) upgrading linux-firmware [######################] 100%
(649/929) upgrading mkinitcpio [######################] 100%
warning: /etc/mkinitcpio.conf installed as /etc/mkinitcpio.conf.pacnew
(650/929) upgrading linux510 [######################] 100%
(651/929) upgrading llvm [######################] 100%
(652/929) upgrading logrotate [######################] 100%
(653/929) upgrading lsof [######################] 100%
(654/929) upgrading make [######################] 100%
(655/929) upgrading man-db [######################] 100%
(656/929) upgrading man-pages [######################] 100%
(657/929) upgrading manjaro-alsa [######################] 100%
New optional dependencies for manjaro-alsa
alsa-tools: Advanced tools for certain sound cards
pipewire-alsa: PipeWire support
pulseaudio-alsa: PulseAudio support [installed]
(658/929) upgrading pamac-cli [######################] 100%
(659/929) upgrading pamac-gtk [######################] 100%
(660/929) upgrading xcb-util-cursor [######################] 100%
(661/929) upgrading vulkan-headers [######################] 100%
(662/929) upgrading qt6-translations [######################] 100%
(663/929) upgrading qt6-base [######################] 100%
(664/929) upgrading qt6-declarative [######################] 100%
(665/929) upgrading shiboken6 [######################] 100%
(666/929) upgrading pyside6 [######################] 100%
New optional dependencies for pyside6
qt6-httpserver: QtHttpServer bindings
qt6-speech: QtTextToSpeech bindings
(667/929) upgrading mhwd-nvidia [######################] 100%
(668/929) upgrading mhwd-nvidia-390xx [######################] 100%
(669/929) upgrading mhwd-nvidia-470xx [######################] 100%
(670/929) upgrading mhwd-db [######################] 100%
(671/929) upgrading mhwd [######################] 100%
(672/929) upgrading python-systemd [######################] 100%
(673/929) upgrading python-manjaro-sdk [######################] 100%
(674/929) upgrading manjaro-hello [######################] 100%
(675/929) installing foomatic-db-ppds [######################] 100%
(676/929) installing foomatic-db-nonfree [######################] 100%
Optional dependencies for foomatic-db-nonfree
foomatic-db-nonfree-ppds: nonfree PPD files [pending]
(677/929) installing foomatic-db-nonfree-ppds [######################] 100%
(678/929) upgrading manjaro-printer [######################] 100%
New optional dependencies for manjaro-printer
hplip: HP printer and scaner support and tools [installed]
print-manager: A KDE tool for managing print jobs and printers
simple-scan: Gtk3 scanning utility
splix: CUPS drivers for SPL (Samsung Printer Language) printers [installed]
system-config-printer: A Gtk cups printer configuration tool and status
applet
xsane: Gtk2 sane scanner frontend
(679/929) upgrading openpmix [######################] 100%
New optional dependencies for openpmix
openpmix-docs: for documentation
(680/929) upgrading openmpi [######################] 100%
(681/929) upgrading pulseaudio [######################] 100%
(682/929) upgrading pulseaudio-bluetooth [######################] 100%
(683/929) upgrading manjaro-pulse [######################] 100%
New optional dependencies for manjaro-pulse
pulseaudio-zeroconf: Zeroconf support [installed]
(684/929) upgrading manjaro-release [######################] 100%
(685/929) upgrading manjaro-settings-manager [######################] 100%
(686/929) upgrading manjaro-settings-manager-n... [######################] 100%
(687/929) upgrading matcha-gtk-theme [######################] 100%
Firefox theme
See /usr/share/doc/matcha-gtk-theme/firefox/README.md
Gedit theme
See /usr/share/doc/matcha-gtk-theme/gedit/README.md
(688/929) upgrading memtest86+ [######################] 100%
(689/929) upgrading mesa-vdpau [######################] 100%
(690/929) upgrading miniupnpc [######################] 100%
(691/929) upgrading minizip [######################] 100%
(692/929) upgrading mktorrent [######################] 100%
(693/929) upgrading ppp [######################] 100%
(694/929) upgrading modemmanager [######################] 100%
(695/929) upgrading mousepad [######################] 100%
(696/929) upgrading mythes-en [######################] 100%
(697/929) upgrading nano [######################] 100%
(698/929) upgrading pcsclite [######################] 100%
New optional dependencies for pcsclite
ccid: USB Chip/Smart Card Interface Devices driver
python: API call trace logging with the pcsc-spy [installed]
(699/929) upgrading wpa_supplicant [######################] 100%
(700/929) upgrading networkmanager [######################] 100%
New optional dependencies for networkmanager
(701/929) upgrading nm-connection-editor [######################] 100%
(702/929) upgrading network-manager-applet [######################] 100%
(703/929) upgrading pkcs11-helper [######################] 100%
(704/929) upgrading openvpn [######################] 100%
(705/929) upgrading networkmanager-openvpn [######################] 100%
(706/929) upgrading rpcbind [######################] 100%
(707/929) upgrading nfsidmap [######################] 100%
(708/929) upgrading nfs-utils [######################] 100%
New optional dependencies for nfs-utils
python: for rpcctl, nfsiostat, nfsdclnts and mountstats usage [installed]
(709/929) upgrading ntfs-3g [######################] 100%
(710/929) upgrading ntp [######################] 100%
(711/929) upgrading nuspell [######################] 100%
(712/929) upgrading qt6-svg [######################] 100%
(713/929) upgrading obs-studio [######################] 100%
(714/929) upgrading onlyoffice-desktopeditors [######################] 100%
warning: directory permissions differ on /opt/onlyoffice/
(715/929) upgrading os-prober [######################] 100%
(716/929) upgrading p7zip [######################] 100%
(717/929) upgrading papirus-icon-theme [######################] 100%
(718/929) upgrading pavucontrol [######################] 100%
(719/929) upgrading perl-file-desktopentry [######################] 100%
(720/929) upgrading perl-file-mimeinfo [######################] 100%
(721/929) upgrading pidgin [######################] 100%
(722/929) upgrading poppler-qt5 [######################] 100%
(723/929) upgrading postgresql-libs [######################] 100%
(724/929) upgrading powertop [######################] 100%
(725/929) upgrading pptpclient [######################] 100%
(726/929) upgrading python-pyqt5-sip [######################] 100%
(727/929) upgrading python-pyqt5 [######################] 100%
New optional dependencies for python-pyqt5
qt5-location: QtLocation, QtPositioning
qt5-sensors: QtSensors
qt5-webchannel: QtWebChannel
(728/929) upgrading pulseaudio-equalizer [######################] 100%
(729/929) upgrading pulseaudio-jack [######################] 100%
(730/929) upgrading pulseaudio-lirc [######################] 100%
(731/929) upgrading pulseaudio-rtp [######################] 100%
(732/929) upgrading pulseaudio-zeroconf [######################] 100%
(733/929) upgrading python-appdirs [######################] 100%
(734/929) upgrading python-attrs [######################] 100%
(735/929) upgrading python-msgpack [######################] 100%
(736/929) upgrading python-cachecontrol [######################] 100%
New optional dependencies for python-cachecontrol
python-lockfile: for filecache
python-redis: for redis cache
(737/929) upgrading python-colorama [######################] 100%
(738/929) upgrading python-docutils [######################] 100%
(739/929) upgrading python-commonmark [######################] 100%
(740/929) upgrading python-cryptography [######################] 100%
(741/929) upgrading python-distlib [######################] 100%
(742/929) upgrading python-dnspython [######################] 100%
(743/929) upgrading python-dotty-dict [######################] 100%
(744/929) upgrading python-zipp [######################] 100%
(745/929) upgrading python-importlib-metadata [######################] 100%
(746/929) upgrading python-jaraco.context [######################] 100%
(747/929) upgrading python-more-itertools [######################] 100%
(748/929) upgrading python-jaraco.functools [######################] 100%
(749/929) installing python-autocommand [######################] 100%
(750/929) installing cython [######################] 100%
(751/929) upgrading python-typing_extensions [######################] 100%
(752/929) installing python-pydantic [######################] 100%
Optional dependencies for python-pydantic
python-dotenv: for .env file support
python-email-validator: for email validation
(753/929) installing python-inflect [######################] 100%
(754/929) upgrading python-jaraco.text [######################] 100%
(755/929) upgrading python-pyrsistent [######################] 100%
(756/929) upgrading python-jsonschema [######################] 100%
New optional dependencies for python-jsonschema
python-fqdn: for hostname format
python-idna: for idn-hostname format [installed]
python-isoduration: for duration format
python-jsonpointer: for json-pointer & relative-json-pointer format
python-rfc3339-validator: for date-time format
python-rfc3987: for iri, iri-reference, uri & uri-reference format
python-uri-template: for uri-template format
python-webcolors: for color format
(757/929) upgrading python-markdown [######################] 100%
(758/929) upgrading python-packaging [######################] 100%
(759/929) upgrading python-nspektr [######################] 100%
(760/929) upgrading python-ordered-set [######################] 100%
(761/929) upgrading python-pillow [######################] 100%
(762/929) installing python-wheel [######################] 100%
Optional dependencies for python-wheel
python-keyring: for wheel.signatures
python-xdg: for wheel.signatures [installed]
(763/929) upgrading python-pip [######################] 100%
(764/929) upgrading python-platformdirs [######################] 100%
(765/929) upgrading python-psutil [######################] 100%
(766/929) upgrading python-pygments [######################] 100%
(767/929) upgrading python-pyopenssl [######################] 100%
(768/929) upgrading python-reportlab [######################] 100%
(769/929) upgrading python-resolvelib [######################] 100%
(770/929) upgrading python-six [######################] 100%
(771/929) upgrading python-retrying [######################] 100%
(772/929) installing python-uc-micro-py [######################] 100%
(773/929) installing python-mdurl [######################] 100%
(774/929) installing python-markdown-it-py [######################] 100%
Optional dependencies for python-markdown-it-py
python-mdit_py_plugins: core plugins
(775/929) upgrading python-rich [######################] 100%
(776/929) installing python-fastjsonschema [######################] 100%
(777/929) upgrading python-trove-classifiers [######################] 100%
(778/929) upgrading python-validate-pyproject [######################] 100%
(779/929) upgrading python-setuptools [######################] 100%
(780/929) upgrading python-tenacity [######################] 100%
(781/929) upgrading python-termcolor [######################] 100%
(782/929) upgrading python-toml [######################] 100%
(783/929) upgrading qmk [######################] 100%
(784/929) upgrading qt6-5compat [######################] 100%
New optional dependencies for qt6-5compat
qt6-shadertools: for QtGraphicalEffects
(785/929) upgrading qt6-imageformats [######################] 100%
(786/929) upgrading qt6-wayland [######################] 100%
(787/929) upgrading unzip [######################] 100%
(788/929) upgrading r [######################] 100%
(789/929) upgrading redshift [######################] 100%
(790/929) upgrading reiserfsprogs [######################] 100%
(791/929) upgrading xxhash [######################] 100%
(792/929) upgrading rsync [######################] 100%
New optional dependencies for rsync
python: for rrsync [installed]
(793/929) upgrading rubygems [######################] 100%
(794/929) installing ruby-abbrev [######################] 100%
(795/929) installing ruby-base64 [######################] 100%
(796/929) installing ruby-benchmark [######################] 100%
(797/929) installing ruby-bigdecimal [######################] 100%
(798/929) installing ruby-cgi [######################] 100%
(799/929) installing ruby-csv [######################] 100%
(800/929) installing ruby-date [######################] 100%
(801/929) installing ruby-delegate [######################] 100%
(802/929) installing ruby-did_you_mean [######################] 100%
(803/929) installing ruby-digest [######################] 100%
(804/929) installing ruby-drb [######################] 100%
(805/929) installing ruby-english [######################] 100%
(806/929) installing ruby-erb [######################] 100%
(807/929) installing ruby-etc [######################] 100%
(808/929) installing ruby-fcntl [######################] 100%
(809/929) installing ruby-fiddle [######################] 100%
(810/929) installing ruby-fileutils [######################] 100%
(811/929) installing ruby-find [######################] 100%
(812/929) installing ruby-forwardable [######################] 100%
(813/929) installing ruby-getoptlong [######################] 100%
(814/929) installing ruby-io-console [######################] 100%
(815/929) installing ruby-io-nonblock [######################] 100%
(816/929) installing ruby-io-wait [######################] 100%
(817/929) installing ruby-ipaddr [######################] 100%
(818/929) upgrading ruby-reline [######################] 100%
(819/929) upgrading ruby-irb [######################] 100%
(820/929) upgrading ruby-json [######################] 100%
(821/929) installing ruby-logger [######################] 100%
(822/929) installing ruby-mutex_m [######################] 100%
(823/929) installing ruby-uri [######################] 100%
(824/929) installing ruby-net-http [######################] 100%
(825/929) upgrading ruby-stringio [######################] 100%
(826/929) installing ruby-time [######################] 100%
(827/929) installing ruby-open-uri [######################] 100%
(828/929) upgrading ruby-psych [######################] 100%
(829/929) upgrading ruby-rdoc [######################] 100%
(830/929) installing ruby-tmpdir [######################] 100%
(831/929) installing ruby-stdlib [######################] 100%
(832/929) upgrading ruby-minitest [######################] 100%
(833/929) installing ruby-power_assert [######################] 100%
(834/929) installing ruby-rake [######################] 100%
(835/929) installing ruby-test-unit [######################] 100%
(836/929) installing ruby-bundledgems [######################] 100%
(837/929) upgrading ruby [######################] 100%
(838/929) upgrading ruby-public_suffix [######################] 100%
(839/929) upgrading ruby-addressable [######################] 100%
(840/929) upgrading ruby-eventmachine [######################] 100%
(841/929) upgrading ruby-i18n [######################] 100%
(842/929) upgrading ruby-jekyll-sass-converter [######################] 100%
(843/929) upgrading ruby-kramdown-parser-gfm [######################] 100%
(844/929) upgrading ruby-rb-fsevent [######################] 100%
(845/929) upgrading ruby-listen [######################] 100%
(846/929) upgrading ruby-mocha [######################] 100%
(847/929) upgrading ruby-tzinfo [######################] 100%
(848/929) upgrading ruby-unicode-display_width [######################] 100%
(849/929) upgrading ruby-zeitwerk [######################] 100%
(850/929) upgrading s-nail [######################] 100%
(851/929) upgrading samba [######################] 100%
New optional dependencies for samba
python-cryptography: lockout_tests.py gp_cert_auto_enroll_ext.py gpo.py and
kcrypto.py [installed]
python-dnspython: netads_dns.py, dnsresolver.py and traffic_packets.py
[installed]
python-markdown: ms_schema_markdown.py and ms_forest_updates_markdown.py
[installed]
(852/929) upgrading sane [######################] 100%
(853/929) upgrading sof-firmware [######################] 100%
(854/929) upgrading spectre-meltdown-checker [######################] 100%
(855/929) upgrading splix [######################] 100%
(856/929) upgrading woff2 [######################] 100%
(857/929) upgrading wpebackend-fdo [######################] 100%
(858/929) upgrading webkit2gtk-4.1 [######################] 100%
(859/929) upgrading zenity [######################] 100%
(860/929) upgrading usbutils [######################] 100%
(861/929) installing libxcrypt-compat [######################] 100%
(862/929) installing lib32-libxcrypt-compat [######################] 100%
(863/929) installing steam [######################] 100%
Optional dependencies for steam
steam-native-runtime: steam native runtime support
vulkan-driver: packaged vulkan driver [installed]
lib32-vulkan-driver: packaged vulkan driver (32 bit) [installed]
lib32-libappindicator-gtk2: added tray icon functionality
xdg-desktop-portal: required for steam-runtime-urlopen to open some URLs
[installed]
(864/929) upgrading strawberry [######################] 100%
(865/929) upgrading sudo [######################] 100%
(866/929) upgrading systemd-sysvcompat [######################] 100%
(867/929) upgrading tcl [######################] 100%
(868/929) installing libsigc++-3.0 [######################] 100%
(869/929) installing glibmm-2.68 [######################] 100%
(870/929) installing openssl-1.1 [######################] 100%
(871/929) upgrading telegram-desktop [######################] 100%
(872/929) upgrading terminus-font [######################] 100%
(873/929) upgrading texinfo [######################] 100%
(874/929) upgrading thunar-media-tags-plugin [######################] 100%
(875/929) upgrading thunar-volman [######################] 100%
(876/929) upgrading thunderbird [######################] 100%
(877/929) upgrading vte-common [######################] 100%
(878/929) upgrading vte3 [######################] 100%
(879/929) upgrading xapp [######################] 100%
(880/929) upgrading xorg-xhost [######################] 100%
(881/929) upgrading timeshift [######################] 100%
(882/929) upgrading tlp [######################] 100%
New optional dependencies for tlp
acpi_call: ThinkPad battery functions, SandyBridge and newer (2011 onwards)
for kernels <5.17
(883/929) upgrading tumbler [######################] 100%
(884/929) upgrading unrar [######################] 100%
(885/929) upgrading upower [######################] 100%
(886/929) upgrading vi [######################] 100%
(887/929) upgrading vlc [######################] 100%
New optional dependencies for vlc
live-media: streaming over RTSP
(888/929) upgrading vpnc [######################] 100%
(889/929) upgrading vulkan-intel [######################] 100%
(890/929) upgrading wayland-protocols [######################] 100%
(891/929) upgrading webkit2gtk [######################] 100%
(892/929) upgrading wireless-regdb [######################] 100%
(893/929) upgrading xcursor-breeze [######################] 100%
(894/929) upgrading xdg-user-dirs [######################] 100%
(895/929) upgrading xf86-input-elographics [######################] 100%
(896/929) upgrading xf86-input-void [######################] 100%
(897/929) upgrading xf86-input-wacom [######################] 100%
(898/929) upgrading xf86-video-ati [######################] 100%
(899/929) upgrading xf86-video-intel [######################] 100%
(900/929) upgrading xfce4-appfinder [######################] 100%
(901/929) upgrading xfce4-panel [######################] 100%
(902/929) upgrading xfce4-cpufreq-plugin [######################] 100%
(903/929) upgrading xfce4-cpugraph-plugin [######################] 100%
(904/929) upgrading xfce4-notifyd [######################] 100%
(905/929) upgrading xfce4-power-manager [######################] 100%
(906/929) upgrading xfce4-pulseaudio-plugin [######################] 100%
(907/929) upgrading xfce4-screenshooter [######################] 100%
(908/929) upgrading xfce4-sensors-plugin [######################] 100%
(909/929) upgrading xorg-xinit [######################] 100%
(910/929) upgrading xfce4-session [######################] 100%
New optional dependencies for xfce4-session
light-locker: for locking screen with xflock4 [installed]
(911/929) installing elementary-icon-theme [######################] 100%
(912/929) upgrading xfce4-settings [######################] 100%
(913/929) upgrading xfce4-systemload-plugin [######################] 100%
(914/929) upgrading xfce4-taskmanager [######################] 100%
(915/929) upgrading xfce4-whiskermenu-plugin [######################] 100%
(916/929) upgrading xfce4-xkb-plugin [######################] 100%
New optional dependencies for xfce4-xkb-plugin
xfce4-notifyd: show notifications on layout change [installed]
(917/929) upgrading xfdesktop [######################] 100%
(918/929) upgrading xfwm4 [######################] 100%
(919/929) upgrading xorg-bdftopcf [######################] 100%
(920/929) upgrading xorg-font-util [######################] 100%
(921/929) upgrading xorg-xkill [######################] 100%
(922/929) upgrading xorg-xmessage [######################] 100%
(923/929) upgrading yasm [######################] 100%
(924/929) upgrading yay [######################] 100%
(925/929) upgrading yelp-xsl [######################] 100%
(926/929) upgrading yelp [######################] 100%
(927/929) upgrading zensu [######################] 100%
(928/929) upgrading zita-alsa-pcmi [######################] 100%
(929/929) upgrading zsh [######################] 100%
( 1/40) Creating system user accounts...
Creating group 'rpcuser' with GID 34.
Creating user 'rpcuser' (RPC Service User) with UID 34 and GID 34.
( 2/40) Updating journal message catalog...
( 3/40) Reloading system manager configuration...
Skipped: Running in chroot.
( 4/40) Updating udev hardware database...
( 5/40) Applying kernel sysctl settings...
( 6/40) Creating temporary files...
( 7/40) Reloading device manager configuration...
( 8/40) Arming ConditionNeedsUpdate...
( 9/40) Updating the MIME type database...
(10/40) Updating fontconfig configuration...
(11/40) Rebuilding certificate stores...
(12/40) Updating module dependencies...
(13/40) Restarting cronie for libc upgrade...
Running in chroot, ignoring command 'try-restart'
(14/40) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'default'
-> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img
==> Starting build: 5.10.167-1-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [resume]
-> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'fallback'
-> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: qed
==> WARNING: Possibly missing firmware for module: qla2xxx
==> WARNING: Possibly missing firmware for module: bfa
==> WARNING: Possibly missing firmware for module: qla1280
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux513.preset: 'default'
-> -k /boot/vmlinuz-5.13-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.13-x86_64.img
==> Starting build: 5.13.19-2-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.13-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux513.preset: 'fallback'
-> -k /boot/vmlinuz-5.13-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.13-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.13-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'default'
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64.img
==> Starting build: 5.15.93-1-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'fallback'
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64-fallback.img
(15/40) Qt5 Upgrade Warning
[WARNING] qt5-base was updated, qt5 applications will break until qt5-styleplugins is rebuilt.
(16/40) Updating the appstream cache...
✔ Metadata cache was updated successfully.
(17/40) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.13-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.13-x86_64.img
Found initrd fallback image: /boot/initramfs-5.13-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.10-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.10-x86_64.img
Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
grub-probe: error: cannot find a GRUB drive for /dev/sda1. Check your device.map.
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
(18/40) Reloading system bus configuration...
(19/40) Updating system dconf databases...
(20/40) Warn about old perl modules
(21/40) Copy Firefox Distribution Settings
(22/40) Updating fontconfig cache...
(23/40) Probing GDK-Pixbuf loader modules...
(24/40) Updating GIO module cache...
(25/40) Compiling GSettings XML schema files...
(26/40) Probing GTK2 input method modules...
(27/40) Probing GTK3 input method modules...
(28/40) Updating icon theme caches...
(29/40) Updating GTK4 module cache...
(30/40) Reloading GVFS config...
(31/40) Restore Linux kernel modules
==> Warning:
-> Kernel has been updated. Modules of the current kernel
-> have been backed up so you can continue to use your
-> computer. However, the new kernel will only work
-> at next boot.
(32/40) Hiding redundant menu entries
(33/40) Creating background picture sym-links for XFCE...
'/usr/share/backgrounds/xfce/illyria-default.jpg' -> '/usr/share/backgrounds/illyria-default.jpg'
'/usr/share/backgrounds/xfce/illyria-default-lockscreen.jpg' -> '/usr/share/backgrounds/illyria-default-lockscreen.jpg'
(34/40) Changing NetworkManager Connectivity-Ping to manjaro.org
(35/40) Configuring pacman-mirrors ...
::INFO => Mirror status: https://repo.manjaro.org/status.json
hint: use `pacman-mirrors` to generate and update your pacman mirrorlist.
(36/40) Updating the info directory file...
(37/40) Copy Thunderbird Distribution Settings
(38/40) Updating the desktop file MIME type cache...
(39/40) Updating the vlc plugin cache...
(40/40) Updating X fontdir indices...
[manjaro@manjaro ~]$
So I reran the kernal install as instructed:
[manjaro@manjaro ~]$ sudo pacman --sysroot /mnt -S linux515
warning: linux515-5.15.93-1 is up to date -- reinstalling
resolving dependencies...
Packages (1) linux515-5.15.93-1
Total Installed Size: 104.67 MiB
Net Upgrade Size: 0.00 MiB
:: Proceed with installation? [Y/n] Y
(1/1) checking keys in keyring [###########################################################] 100%
(1/1) checking package integrity [###########################################################] 100%
(1/1) loading package files [###########################################################] 100%
(1/1) checking for file conflicts [###########################################################] 100%
(1/1) checking available disk space [###########################################################] 100%
(1/2) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(2/2) Save Linux kernel modules
(1/1) reinstalling linux515 [###########################################################] 100%
(1/5) Arming ConditionNeedsUpdate...
(2/5) Updating module dependencies...
(3/5) Updating linux initcpios...
(4/5) Updating Grub-Bootmenu
done
(5/5) Restore Linux kernel modules
==> Warning:
-> at next boot.
So now I should be good to restart? Should I expect to see just the manjaro option in GRUB or both manjaro and my Windows booot?
brahma
February 16, 2023, 8:47pm
17
yes reboot, and you have still some leftovers from old kernels, looking at the update-grub output… we can fix it when you are back in your system… the windows will probably not be shown in the grub menu, you have to run:
sudo update-grub
from your installation
blp92
February 16, 2023, 9:46pm
18
That worked! I’m in my installation. Just ran the update and it looks like it worked?
update-grub
[sudo] password for sage:
Found Windows Boot Manager on /dev/nvme0n1p1@/EFI/Microsoft/Boot/bootmgfw.efi
done
brahma
February 16, 2023, 9:56pm
19
yes windows is detected:
but you still have some kernel leftovers, so post output from:
ls /etc/mkinitcpio.d/*.preset
sudo ls /boot/initramfs-*
sudo ls /boot/vmlinuz-*
sudo ls /usr/lib/modules/*
blp92
February 16, 2023, 10:16pm
20
/etc/mkinitcpio.d/linux510.preset /etc/mkinitcpio.d/linux515.preset
[~]$ sudo ls /boot/vmlinuz-*
/boot/vmlinuz-5.10-x86_64 /boot/vmlinuz-5.13-x86_64 /boot/vmlinuz-5.15-x86_64
[~]$ sudo ls /usr/lib/modules/*
/usr/lib/modules/5.10.167-1-MANJARO:
extramodules modules.builtin modules.dep.bin modules.symbols.bin
kernel modules.builtin.alias.bin modules.devname pkgbase
kernelbase modules.builtin.bin modules.order vmlinuz
modules.alias modules.builtin.modinfo modules.softdep
modules.alias.bin modules.dep modules.symbols
/usr/lib/modules/5.13.19-2-MANJARO:
/usr/lib/modules/5.15.93-1-MANJARO:
/usr/lib/modules/extramodules-5.10-MANJARO:
version
/usr/lib/modules/extramodules-5.13-MANJARO:
version
/usr/lib/modules/extramodules-5.15-MANJARO:
version
