check again:
ls -l /usr/lib/libc.so.6
check again:
[manjaro /]# ls -l /usr/lib/libc.so.6
ls: error while loading shared libraries: libc.so.6: cannot open shared object file: No such file or directory
The file has seemed to disappear after doing the unlinking. I backed it up in the live dowload folder, but cannot paste it back there, is it because I’m chroot?
I was unable to go back to chroot after doing that, so I opened Thunar as root and pasted the backed-up files back in the folder. Back to the previous step, I guess.
your system is a mess…
there is pacman static, try with it:
wget https://pkgbuild.com/~eschwartz/repo/x86_64-extracted/pacman-static
chmod +x pacman-static
./pacman-static -Syyu glibc lib32-glibc
do I do this after chroot?
yes you need to be chrooted
--2022-07-16 20:43:41-- https://pkgbuild.com/~eschwartz/repo/x86_64-extracted/pacman-static
Loaded CA certificate '/etc/ssl/certs/ca-certificates.crt'
Resolving pkgbuild.com (pkgbuild.com)... 2a01:4f8:c2c:51e2::1, 78.46.178.133
Connecting to pkgbuild.com (pkgbuild.com)|2a01:4f8:c2c:51e2::1|:443... connected.
HTTP request sent, awaiting response... 404 Not Found
2022-07-16 20:43:41 ERROR 404: Not Found.
god damn haha … found it elsewhere:
wget https://pkgbuild.com/~morganamilo/pacman-static/x86_64/bin/pacman-static
[manjaro /]# wget https://pkgbuild.com/~morganamilo/pacman-static/x86_64/bin/pacman-static
--2022-07-16 20:48:19-- https://pkgbuild.com/~morganamilo/pacman-static/x86_64/bin/pacman-static
HTTP request sent, awaiting response... 200 OK
Length: 4606712 (4.4M) [application/octet-stream]
Saving to: 'pacman-static'
pacman-static 100%[====================================================>] 4.39M 1.17MB/s in 3.8s
2022-07-16 20:48:23 (1.15 MB/s) - 'pacman-static' saved [4606712/4606712]
[manjaro /]# chmod +x pacman-static
[manjaro /]# ./pacman-static -Syyu glibc lib32-glibc
warning: config file /etc/pacman.conf, line 20: directive 'SyncFirst' in section 'options' not recognized.
core 168.2 KiB 327 KiB/s 00:01 [##########################################] 100%
extra 1867.1 KiB 1201 KiB/s 00:02 [##########################################] 100%
community 7.1 MiB 1173 KiB/s 00:06 [##########################################] 100%
multilib 177.5 KiB 612 KiB/s 00:00 [##########################################] 100%
:: Replace breath2-icon-themes with community/plasma5-themes-breath? [Y/n]
This last part might be mundane, but do I answer Y?
click y
Should I answer all the followups Y as well?
:: Replace crda with core/wireless-regdb? [Y/n]
yes, since you didnt update your system for so long, there were some package replacement etc…
core 168.2 KiB 526 KiB/s 00:00 [##########################################] 100%
extra 1867.1 KiB 1174 KiB/s 00:02 [##########################################] 100%
community 7.1 MiB 1189 KiB/s 00:06 [##########################################] 100%
multilib 177.5 KiB 1517 KiB/s 00:00 [##########################################] 100%
:: Replace breath2-icon-themes with community/plasma5-themes-breath? [Y/n] y
:: Replace crda with core/wireless-regdb? [Y/n] y
:: Replace hwids with core/hwdata? [Y/n] y
:: Replace plasma5-themes-breath2 with community/plasma5-themes-breath? [Y/n] y
:: Replace sdl with community/sdl12-compat? [Y/n] y
resolving dependencies...
:: There are 2 providers available for pipewire-session-manager:
:: Repository extra
1) pipewire-media-session 2) wireplumber
Enter a number (default=1): 1
:: installing nvidia-utils (515.57-1) breaks dependency 'nvidia-utils=470.63.01' required by linux513-nvidia
Well, I knew Nvidia had to get involved at some point.
remove it first:
./pacman-static -R linux513-nvidia
then run update again:
and when you are prompted here:
select number 2
[manjaro /]# ./pacman-static -R linux513-nvidia
checking dependencies...
Packages (1) linux513-nvidia-470.63.01-3
Total Removed Size: 39.63 MiB
:: Do you want to remove these packages? [Y/n] y
(1/1) removing linux513-nvidia [##########################################] 100%
(1/3) Arming ConditionNeedsUpdate...
(2/3) Updating module dependencies...
(3/3) Updating Kernel initcpios for Nvidia-DRM...
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'default'
-> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img
==> Starting build: 5.10.59-1-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
findmnt: /usr/lib/libc.so.6: version `GLIBC_2.35' not found (required by /usr/lib/libgcc_s.so.1)
findmnt: /usr/lib/libc.so.6: version `GLIBC_2.34' not found (required by /usr/lib/libgcc_s.so.1)
==> ERROR: failed to detect root filesystem
gzip: /usr/lib/libc.so.6: version `GLIBC_2.34' not found (required by gzip)
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64.img
bsdtar: Write error
bsdtar: Write error
==> ERROR: Image generation FAILED: bsdtar (step 1) reported an error
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'fallback'
-> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64-fallback.img
bsdtar: Write error
: Write error==> ERROR: Image generation FAILED: bsdtar (step 1) reported an error
==> Building image from preset: /etc/mkinitcpio.d/linux513.preset: 'default'
-> -k /boot/vmlinuz-5.13-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.13-x86_64.img
==> Starting build: 5.13.11-1-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.13-x86_64.img
bsdtar: Write error
bsdtar: Write error
==> Building image from preset: /etc/mkinitcpio.d/linux513.preset: 'fallback'
-> -k /boot/vmlinuz-5.13-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.13-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.13-x86_64-fallback.img
bsdtar: Write error
bsdtar: Write error
==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'default'
-> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64.img
==> Starting build: 5.4.141-1-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64.img
bsdtar: Write error
==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'fallback'
-> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64-fallback.img
bsdtar: Write error
Not sure if it was successful.
regardless of all the errors the first command gave me, this now prompts me to proceed with installation:
it failed again because of this:
So even though there is no more nvidia conflict error, is it not safe to proceed with
it should be since it will reinstall the glibc anyway but just to be sure run this first:
./pacman-static -S glibc lib32-glibc
then:
