Oh boy, Iām back after a long hiatus, but hopefully this will be the conclusion to this thrilling story, because this machine needs to come back to life soon. Canāt postpone solving this issue much longer. Thanks for not closing the topic in the meantime.
Picking up from where we left off last time -
./pacman-static -Syyu glibc lib32-glibc
gave the following result:
Total (1261/1261) 3.2 GiB 1052 KiB/s 53:09 [######################] 100%
error: failed retrieving file āfirefox-103.0-1-x86_64.pkg.tar.zstā from mirrors.fossho.st : OpenSSL SSL_read: error:1408F119:SSL routines:ssl3_get_record:decryption failed or bad record mac, errno 0
(1263/1263) checking keys in keyring [######################] 100%
warning: Public keyring not found; have you run āpacman-key --initā?
downloading required keysā¦
error: keyring is not writable
error: required key missing from keyring
error: failed to commit transaction (unexpected error)
[manjaro /]# pacman-key --init
pacman-conf: /usr/lib/libc.so.6: version GLIBC_2.34' not found (required by pacman-conf) mkdir: cannot create directory '': No such file or directory gpg: marginals needed: 3 completes needed: 1 trust model: pgp gpg: depth: 0 valid: 1 signed: 0 trust: 0-, 0q, 0n, 0m, 0f, 1u chmod: cannot access '/trustdb.gpg': No such file or directory vercmp: /usr/lib/libc.so.6: version GLIBC_2.34ā not found (required by vercmp)
/usr/bin/pacman-key: line 243: ((: >= 0 : syntax error: operand expected (error token is ">= 0 ")
Didnāt include the first thousand or so lines of packages downloading for readability, I hope thatās fine.
I did the
pacman-key --init
right after to see if that would change anything, and after that, I realized I selected pipedrive instead of wireplumber first time, tried running the original command with the other option, not much different either:
warning: config file /etc/pacman.conf, line 20: directive āSyncFirstā in section āoptionsā not recognized.
:: Synchronizing package databasesā¦
core 166.3 KiB 554 KiB/s 00:00 [######################] 100%
^[xtra 1861.3 KiB 1171 KiB/s 00:02 [######################] 100%
community 7.1 MiB 1184 KiB/s 00:06 [######################] 100%
multilib 174.3 KiB 1194 KiB/s 00:00 [######################] 100%
:: Starting full system upgradeā¦
:: Replace breath2-icon-themes with community/plasma5-themes-breath? [Y/n] y
:: Replace crda with core/wireless-regdb? [Y/n] y
:: Replace hwids with core/hwdata? [Y/n] y
:: Replace plasma5-themes-breath2 with community/plasma5-themes-breath? [Y/n] y
:: Replace sdl with community/sdl12-compat? [Y/n] y
:: Replace wxgtk-common with extra/wxwidgets-common? [Y/n] y
:: Replace wxgtk3 with extra/wxwidgets-gtk3? [Y/n] y
resolving dependenciesā¦
:: There are 2 providers available for pipewire-session-manager:
:: Repository extra
- pipewire-media-session 2) wireplumber
Enter a number (default=1): 2
looking for conflicting packagesā¦
warning: dependency cycle detected:
warning: bashrc-manjaro will be installed before its bash dependency
warning: harfbuzz will be installed before its freetype2 dependency
warning: libglvnd will be installed before its mesa dependency
warning: nvidia-utils will be installed before its gtk3 dependency
warning: nvidia-utils will be installed before its libglvnd dependency
warning: xorg-server will be installed before its libglvnd dependency
warning: eglexternalplatform will be installed before its libglvnd dependency
warning: smbclient will be installed before its cifs-utils dependency
warning: python-incremental will be installed before its python-twisted dependency
warning: phonon-qt5-gstreamer will be installed before its phonon-qt5 dependency
warning: lib32-harfbuzz will be installed before its lib32-freetype2 dependency
warning: lib32-mesa will be installed before its lib32-libglvnd dependency
warning: lib32-nvidia-utils will be installed before its lib32-libglvnd dependency
warning: rubygems will be installed before its ruby dependency
warning: ruby-bundler will be installed before its ruby dependency
warning: ruby-irb will be installed before its ruby dependency
warning: ruby-reline will be installed before its ruby dependency
warning: ruby-json will be installed before its ruby dependency
warning: ruby-psych will be installed before its ruby dependency
warning: ruby-stringio will be installed before its ruby dependency
warning: ruby-rdoc will be installed before its ruby dependency
warning: ruby-minitest will be installed before its ruby dependency
warning: ruby-power_assert will be installed before its ruby dependency
warning: ruby-rake will be installed before its ruby dependency
warning: ruby-rexml will be installed before its ruby dependency
warning: ruby-test-unit will be installed before its ruby dependency
Packages (1270) abseil-cpp-20220623.0-1 accountsservice-22.08.8-2 acl-2.3.1-2
acpid-2.0.33-1 adwaita-icon-theme-42.0+r1+gc144c3d75-1
alembic-1.8.3-3 alsa-card-profiles-1:0.3.56-1
alsa-lib-1.2.7.2-1 alsa-oss-1.1.8-4 alsa-plugins-1:1.2.7.1-1
alsa-ucm-conf-1.2.7.2-1 alsa-utils-1.2.7-1
amd-ucode-20220708.be7798e-1 android-tools-31.0.3-6
android-udev-20220611-1 aom-3.4.0-1 apparmor-3.0.4-2
appstream-0.15.4-1 appstream-glib-0.8.0-1
appstream-qt-0.15.4-1 apr-util-1.6.1-9
archlinux-appstream-data-20220727-1
archlinux-keyring-20220713-2 argon2-20190702-4 ark-22.04.3-1
asciidoc-10.2.0-1 at-spi2-core-2.44.1-1 atk-2.38.0-1
atkmm-2.28.3-1 attica-5.96.0-1 attr-2.5.1-2
audacity-1:3.1.3-1 audit-3.0.8-1 avahi-0.8+22+gfd482a7-3
babl-0.1.92-1 baloo-5.96.0-1 baloo-widgets-22.04.3-1
base-3-2 bash-5.1.016-2 bashrc-manjaro-5.1.016-2
binutils-2.38-6 blas-3.10.1-1 blender-17:3.2.1-1
blosc-1.21.1-2 bluedevil-1:5.24.6-1 bluez-5.64-2
bluez-libs-5.64-2 bluez-qt-5.96.0-1 boost-1.79.0-1
boost-libs-1.79.0-1 botan-2.19.2-1 box2d-2.4.1-1
breath2-icon-themes-1.0.18-5 [removal] breeze-5.24.6-1
breeze-icons-5.96.0-1 brotli-1.0.9-8 btrfs-progs-5.18.1-1
bubblewrap-0.6.2-1 c-ares-1.18.1-1
ca-certificates-mozilla-3.81-1 cairo-1.17.6-2
cantarell-fonts-1:0.303.1-1 cblas-3.10.1-1 ccid-1.5.0-1
ceph-libs-15.2.14-6 cfitsio-1:4.1.0-1 chromaprint-1.5.1-3
cifs-utils-6.15-1 ckbcomp-1.208-1 clang-14.0.6-1
clucene-2.3.3.4-12 cmake-3.23.2-2 colord-1.4.6-1
compiler-rt-14.0.6-1 containerd-1.6.6-1 coreutils-9.1-1
cpupower-5.18-1 crda-4.14-4 [removal] cronie-1.6.1-1
cryptsetup-2.4.3-2 cups-1:2.4.2-3 cups-filters-1.28.15-1
cups-pk-helper-0.2.6-5 curl-7.84.0-2 cython-0.29.31-1
dav1d-1.0.0-1 dbus-1.14.0-1 dbus-python-1.2.18-3
ddcutil-1.3.0-1 deluge-1:2.1.1-1 deluge-gtk-1:2.1.1-1
desktop-file-utils-0.26-2 device-mapper-2.03.16-1
dhclient-4.4.3-1 dhcpcd-9.4.1-1 ding-libs-0.6.2-1
discord-0.0.18-1 discount-2.2.7.b-1 dkms-3.0.5-2
dmidecode-3.4-1 dnsmasq-2.86-2 docker-1:20.10.17-1
dolphin-22.04.3-1 dolphin-plugins-22.04.3-1 dosfstools-4.2-2
double-conversion-3.2.0-1 downgrade-11.2.1-1 draco-1.5.1-2
duktape-2.7.0-4 e2fsprogs-1.46.5-4 ecryptfs-utils-111-5
efibootmgr-18-1 efivar-38-2 egl-wayland-2:1.1.10-1
eglexternalplatform-1.1-2 elfutils-0.187-1 embree-3.13.4-1
enchant-2.3.3-1 exiv2-0.27.5-3 expat-2.4.8-1
extra-cmake-modules-5.96.0-1 f2fs-tools-1.15.0-1 faac-1.30-3
faudio-22.07-1 ffmpeg-2:5.0.1-3 ffmpeg4.4-4.4.2-3
ffmpegthumbs-22.04.3-1 fftw-3.3.10-3 filelight-22.04.3-1
filesystem-2022.06.08-3 filezilla-3.60.2-1 firefox-103.0-1
flac-1.3.4-3 flashrom-1.2-4 flatpak-1:1.12.7-1
fluidsynth-2.2.8-1 fmt-8.1.1-2 fontconfig-2:2.14.0-1
foomatic-db-engine-4:20220521-1 frameworkintegration-5.96.0-1
freeglut-3.2.2-2 freetype2-2.12.1-1 fribidi-1.0.12-1
fuse-common-3.11.0-1 fuse3-3.11.0-1 fwupd-1.8.3-1
fwupd-efi-1.3-1 fzf-0.31.0-1 game-devices-udev-0.16-1
gamemode-1.6.1-2 gc-8.2.0-3 gcab-1.4-2 gcc-12.1.0-3
gcc-libs-12.1.0-3 gcr-3.41.1-1 gd-2.3.3-4 gdbm-1.23-1
gdk-pixbuf2-2.42.8-1 gegl-0.4.38-1 geoclue-2.6.0-2
geocode-glib-3.26.3-1 geoip-database-20220621-1
ghostscript-9.56.1-1 gimp-2.10.32-1 git-2.37.1-1
glew-2.2.0-3 glfw-x11-3.3.8-1 glib-networking-1:2.72.1-1
glib2-2.72.3-1 glib2-docs-2.72.3-1 glibmm-2.66.4-1
glslang-11.10.0-1 glu-9.0.2-3 gmp-6.2.1-2
gnome-desktop-1:42.3-1 gnome-desktop-common-1:42.3-1
gnome-themes-extra-3.28+r6+g45b1d457-1 gnupg-2.2.36-1
gnustep-base-1.28.0-4 gnutls-3.7.6-1
gobject-introspection-runtime-1.72.0-1 gparted-1.4.0-1
gpgme-1.17.1-1 gpm-1.20.7.r38.ge82d1a6-4 gptfdisk-1.0.9-1
graphene-1.10.8-1 graphite-1:1.3.14-2 graphviz-5.0.0-1
grub-2.06.r261.g2f4430cc0-1 gsettings-desktop-schemas-42.0-1
gsm-1.0.20-1 gsmartcontrol-1.1.4-1 gssdp-1.4.0.1-1
gssproxy-0.9.1-2 gst-libav-1.20.3-1 gst-plugins-bad-1.20.3-1
gst-plugins-bad-libs-1.20.3-1 gst-plugins-base-1.20.3-1
gst-plugins-base-libs-1.20.3-1 gst-plugins-good-1.20.3-1
gst-plugins-ugly-1.20.3-1 gstreamer-1.20.3-1
gtk-update-icon-cache-1:4.6.6-1 gtk3-1:3.24.34-1
gtkmm3-3.24.6-1 guile-2.2.7-2 gupnp-1:1.4.3-1
gupnp-igd-1.2.0-2 gvfs-1.50.2-1 gvfs-afc-1.50.2-1
gvfs-gphoto2-1.50.2-1 gvfs-mtp-1.50.2-1 gvfs-nfs-1.50.2-1
gvfs-smb-1.50.2-1 gwenview-22.04.3-1 harfbuzz-5.0.1-1
harfbuzz-icu-5.0.1-1 haveged-1.9.18-1 hdf5-1.12.2-1
hdparm-9.64-1 hidapi-0.12.0-1 hplip-1:3.22.6-1 hspell-1.4-4
htop-3.2.1-1 hunspell-1.7.0-4 hwdata-0.361-1
hwids-20210613-1 [removal] hwinfo-21.82-1 hwloc-2.8.0-1
hyphen-2.8.8-4 i2c-tools-4.3-3 iana-etc-20220603-1
icu-71.1-1 ijs-0.35-4 imagemagick-7.1.0.44-1
imagewriter-1.10.1432200249.1d253d9.2.13-1 imath-3.1.5-2
imlib2-1.9.1-1 inetutils-2.2-1 iniparser-4.1-4
inxi-3.3.20.1-1 iproute2-5.18.0-1 iptables-1:1.8.8-1
iputils-20211215-1 iso-codes-4.11.0-1 iw-5.19-1
jack2-1.9.21-1 jansson-2.14-2 jasper-3.0.6-1
jdk-openjdk-18.0.2.u9-1 jemalloc-1:5.3.0-1 jfsutils-1.1.15-8
jre-openjdk-18.0.2.u9-1 jre-openjdk-headless-18.0.2.u9-1
jre8-openjdk-8.342.u07-1 jre8-openjdk-headless-8.342.u07-1
js78-78.15.0-4 json-c-0.16-1 json-glib-1.6.6-2
jsoncpp-1.9.5-2 kaccounts-integration-22.04.3-1
kaccounts-providers-22.04.3-1 kactivities-5.96.0-1
kactivities-stats-5.96.0-1 kactivitymanagerd-5.24.6-1
kamera-22.04.3-1 karchive-5.96.0-1 kate-22.04.3-1
kauth-5.96.0-1 kbd-2.5.1-1 kbookmarks-5.96.0-1
kcalc-22.04.3-1 kcm-wacomtablet-1:3.2.0-5 kcmutils-5.96.0-1
kcodecs-5.96.0-1 kcolorpicker-0.2.0-1 kcompletion-5.96.0-1
kconfig-5.96.0-1 kconfigwidgets-5.96.0-1 kcontacts-1:5.96.0-1
kcoreaddons-5.96.0-1 kcrash-5.96.0-1 kdbusaddons-5.96.0-1
kde-cli-tools-5.24.6-1 kde-gtk-config-5.24.6-1
kdeclarative-5.96.0-1 kdeconnect-22.04.3-1
kdecoration-5.24.6-1 kded-5.96.0-1
kdegraphics-mobipocket-22.04.3-1
kdegraphics-thumbnailers-22.04.3-1 kdelibs4support-5.96.0-1
kdenetwork-filesharing-22.04.3-1 kdeplasma-addons-5.24.6-1
kdesu-5.96.0-1 kdialog-22.04.3-1 kdnssd-5.96.0-1
kdoctools-5.96.0-1 keditbookmarks-22.04.3-1
kemoticons-5.96.0-1 kfilemetadata-5.96.0-1 kfind-22.04.3-1
kgamma5-5.24.6-1 kget-22.04.3-1 kglobalaccel-5.96.0-1
kguiaddons-5.96.0-1 khelpcenter-22.04.3-1
kholidays-1:5.96.0-1 khotkeys-5.24.6-1 khtml-5.96.0-1
ki18n-5.96.0-1 kiconthemes-5.96.0-1 kidletime-5.96.0-1
kimageannotator-0.6.0-1 kimageformats-5.96.0-1
kinfocenter-5.24.6-1 kinit-5.96.0-1 kio-5.96.0-1
kio-extras-22.04.3-1 kirigami2-5.96.0-1 kitemmodels-5.96.0-1
kitemviews-5.96.0-1 kjobwidgets-5.96.0-1 kjs-5.96.0-1
kjsembed-5.96.0-1 kmenuedit-5.24.6-1 kmod-30-1
knewstuff-5.96.0-1 knotifications-5.96.0-1
knotifyconfig-5.96.0-1 konsole-22.04.3-1
konversation-22.04.3-1 kpackage-5.96.0-1 kparts-5.96.0-1
kpeople-5.96.0-1 kpty-5.96.0-1 kquickcharts-5.96.0-1
krb5-1.19.3-3 krunner-5.96.0-1 kscreen-5.24.6-1
kscreenlocker-5.24.6-1 kservice-5.96.0-1 ksshaskpass-5.24.6-1
ksystemlog-22.04.3-1 ksystemstats-5.24.6-1
ktexteditor-5.96.0-1 ktextwidgets-5.96.0-1
kunitconversion-5.96.0-1 kuserfeedback-1.2.0-1
kwallet-5.96.0-1 kwallet-pam-5.24.6-1
kwalletmanager-22.04.3-1 kwayland-5.96.0-1
kwayland-integration-5.24.6-1 kwayland-server-5.24.6-1
kwidgetsaddons-5.96.0-1 kwin-5.24.6-1 kwindowsystem-5.96.0-1
kwrited-5.24.6-1 kxmlgui-5.96.0-1 ladspa-1.17-1 lame-3.100-4
lapack-3.10.1-1 layer-shell-qt-5.24.6-1 lcms2-2.13.1-1
ldb-2:2.5.2-1 ldns-1.8.1-1 lensfun-1:0.3.3-1
lib32-alsa-lib-1.2.7.2-1 lib32-alsa-oss-1.1.8-3
lib32-alsa-plugins-1.2.7.1-1 lib32-at-spi2-atk-2.38.0-2
lib32-at-spi2-core-2.44.1-1 lib32-atk-2.38.0-1
lib32-brotli-1.0.9-4 lib32-cairo-1.17.6-2
lib32-colord-1.4.6-1 lib32-curl-7.84.0-1 lib32-db-5.3.28-5
lib32-dbus-1.14.0-1 lib32-e2fsprogs-1.46.5-1
lib32-expat-2.4.8-1 lib32-faudio-22.07-1 lib32-flac-1.3.4-3
lib32-flex-2.6.4-3 lib32-fluidsynth-2.2.8-1
lib32-fontconfig-2:2.14.0-1 lib32-freeglut-3.2.2-2
lib32-freetype2-2.12.1-1 lib32-fribidi-1.0.12-1
lib32-gcc-libs-12.1.0-3 lib32-gdk-pixbuf2-2.42.8-1
lib32-glew-2.2.0-3 lib32-glib-networking-2.72.1-1
lib32-glib2-2.72.3-1 lib32-glu-9.0.2-3 lib32-gnutls-3.7.6-1
lib32-gstreamer-1.20.3-1 lib32-gtk3-3.24.34-1
lib32-harfbuzz-5.0.1-1 lib32-icu-71.1-1 lib32-jack2-1.9.21-1
lib32-json-glib-1.6.6-2 lib32-krb5-1.19.3-2
lib32-lcms2-2.13.1-1 lib32-libasyncns-1:0.8+r3+g68cd5af-1
lib32-libcanberra-1:0.30+r2+gc0620e4-1 lib32-libcap-2.65-1
lib32-libcups-2.4.2-1 lib32-libdbusmenu-glib-16.04.0-5
lib32-libdbusmenu-gtk2-16.04.0-5 lib32-libdrm-2.4.112-1
lib32-libelf-0.187-1 lib32-libepoxy-1.5.10-1
lib32-libffi-3.4.2-4 lib32-libgcrypt-1.10.1-1
lib32-libglvnd-1.4.0-2 lib32-libgpg-error-1.45-1
lib32-libidn-1.41-1 lib32-libidn2-2.3.3-1
lib32-libindicator-gtk2-12.10.1-9 lib32-libjpeg-turbo-2.1.3-1
lib32-libldap-2.6.3-1 lib32-libltdl-2.4.7-2
lib32-libnl-3.7.0-1 lib32-libnsl-2.0.0-1
lib32-libproxy-0.4.18-1 lib32-libpsl-0.21.1-2
lib32-libpulse-16.1-1 lib32-librsvg-2:2.54.4-1
lib32-libsamplerate-0.2.2-1 lib32-libsndfile-1.1.0-1
lib32-libsoup-2.74.2-1 lib32-libssh2-1.10.0-1
lib32-libtasn1-4.18.0-1 lib32-libthai-0.1.29-1
lib32-libtiff-4.4.0-1 lib32-libtirpc-1.3.2-2
lib32-libunistring-1.0-1 lib32-libunwind-1.6.2-1
lib32-libusb-1.0.26-1 lib32-libva-2.14.0-1
lib32-libva-mesa-driver-22.1.4-1 lib32-libx11-1.8.1-1
lib32-libxau-1.0.9-2 lib32-libxcb-1.15-1
lib32-libxcomposite-0.4.5-2 lib32-libxcrypt-4.4.28-1
lib32-libxcursor-1.2.1-1 lib32-libxdamage-1.1.5-2
lib32-libxext-1.3.4-2 lib32-libxft-2.3.4-1 lib32-libxi-1.8-1
lib32-libxinerama-1.1.4-2 lib32-libxkbcommon-1.4.1-1
lib32-libxml2-2.9.14-1 lib32-libxmu-1.1.3-2
lib32-libxrandr-1.5.2-2 lib32-libxrender-0.9.10-3
lib32-libxss-1.2.3-2 lib32-libxtst-1.2.3-3
lib32-libxxf86vm-1.1.4-3 lib32-llvm-libs-14.0.6-2
lib32-mesa-22.1.4-1 lib32-mesa-demos-8.5.0-1
lib32-ncurses-6.3-1 lib32-nettle-3.8-1 lib32-nspr-4.34-1
lib32-nss-3.81-1 lib32-nvidia-utils-515.57-1
lib32-openal-1.22.2-1 lib32-openssl-1:1.1.1.q-1
lib32-opus-1.3.1-2 lib32-p11-kit-0.24.1-1 lib32-pam-1.5.2-1
lib32-pango-1:1.50.8-1 lib32-pcre-8.45-1
lib32-readline-8.1.002-1 lib32-rest-0.8.1-4
lib32-sdl2-2.0.22-1 lib32-sqlite-3.39.0-1
lib32-systemd-251.3-1 lib32-tdb-1.4.7-1
lib32-util-linux-2.38-1 lib32-vkd3d-1.4-1
lib32-vulkan-icd-loader-1.3.221-1 lib32-wayland-1.20.0-2
lib32-zlib-1.2.12-1 lib32-zstd-1.5.2-1 libabw-0.1.3-3
libaccounts-glib-1.25-7 libaec-1.0.6-1 libaio-0.3.113-1
libappindicator-gtk3-12.10.0.r296-2 libarchive-3.6.1-1
libass-0.16.0-1 libasyncns-1:0.8+r3+g68cd5af-1
libatomic_ops-7.6.12-1 libavif-0.10.1-2 libavtp-0.2.0-1
libb2-0.98.1-2 libblockdev-2.27-1 libbluray-1.3.1-1
libbpf-0.8.1-1 libbs2b-3.1.0-8 libbsd-0.11.6-2
libbytesize-2.7-1 libcaca-0.99.beta20-1
libcanberra-1:0.30+r2+gc0620e4-1 libcap-2.65-1
libcap-ng-0.8.3-1 libcbor-0.9.0-1 libcdr-0.1.7-4
libcmis-0.5.2-10 libcolord-1.4.6-1 libcups-1:2.4.2-3
libdbusmenu-glib-16.04.0-5 libdbusmenu-gtk2-16.04.0-5
libdbusmenu-gtk3-16.04.0-5
libdbusmenu-qt5-0.9.3+16.04.20160218-6 libde265-1.0.8-2
libdispatch-5.5.0-1 libdmtx-0.7.7-1 libdrm-2.4.112-1
libdvdread-6.1.3-1 libe-book-0.1.3-11 libebml-1.4.2-2
libedit-20210910_3.1-1 libelf-0.187-1 libepoxy-1.5.10-1
libepubgen-0.1.1-3 libevdev-1.12.1-1 libexif-0.6.24-1
libexttextcat-3.4.6-1 libffi-3.4.2-5 libfilezilla-1:0.38.1-1
libfreehand-0.1.2-4 libftdi-1.5-4 libgcrypt-1.10.1-1
libgexiv2-0.14.0-3 libgit2-1:1.4.4-1 libglvnd-1.4.0-2
libgpg-error-1.45-2 libgphoto2-2.5.30-1 libgudev-237-2
libgusb-0.3.10-2 libhandy-1.6.3-1 libharu-2.3.0-5
libheif-1.12.0-3 libibus-1.5.26-2 libical-3.0.14-3
libice-1.0.10-4 libidn-1.41-1 libidn2-2.3.3-1
libieee1284-0.2.11-13 libimagequant-4.0.0-1
libimobiledevice-1.3.0-5 libindicator-gtk2-12.10.1-10
libindicator-gtk3-12.10.1-10 libinih-55-2 libinput-1.21.0-1
libisl-0.25-1 libixion-0.17.0-2 libjcat-0.1.11-1
libjpeg-turbo-2.1.3-2 libkate-0.4.1-8 libkdcraw-22.04.3-1
libkexiv2-22.04.3-1 libksane-22.04.3-1 libkscreen-5.24.6-1
libksysguard-5.24.6-1 libktorrent-22.04.3-1
liblangtag-0.6.4-1 libldap-2.6.3-1 liblouis-3.22.0-1
libltc-1.3.1-3 libmanette-0.2.6-3 libmatroska-1.6.3-2
libmbim-1.26.4-1 libmd-1.0.4-1 libmfx-22.4.4-1
libmicrohttpd-0.9.75-1 libmm-glib-1.18.10-2 libmnl-1.0.5-1
libmp4v2-1:2.1.1-1 libmpc-1.2.1-2 libmspack-1:0.10.1alpha-3
libmspub-0.1.4-12 libmtp-1.1.20-1 libmwaw-0.3.21-2
libnetfilter_conntrack-1.0.9-1 libnewt-0.52.21-8
libnfnetlink-1.0.2-1 libnfs-5.0.1-2 libnftnl-1.2.2-1
libnghttp2-1.48.0-1 libnice-0.1.19-1 libnl-3.7.0-1
libnm-1.38.2-2 libnotify-0.8.1-1 libnsl-2.0.0-2
libnumbertext-1.0.10-1 libopenmpt-0.6.4-1 liborcus-0.17.2-2
libp11-kit-0.24.1-1 libpagemaker-0.0.4-3 libpamac-11.3.1-1
libpaper-1.1.28-2 libpcap-1.10.1-2 libpciaccess-0.16-3
libpgm-5.3.128-2 libpipeline-1.5.6-1 libplacebo-4.208.0-1
libplist-2.2.0-5 libproxy-0.4.18-1 libpulse-16.1-1
libpwquality-1.4.4-5 libqalculate-4.2.0-1 libqmi-1.30.8-1
libqrtr-glib-1.2.2-2 libqxp-0.0.2-8 libraqm-0.9.0-1
libraw-0.20.2-2 libreoffice-still-7.2.7-3 librevenge-0.0.4-4
librsvg-2:2.54.4-1 libsamplerate-0.2.2-1 libsasl-2.1.28-1
libsbsms-2.3.0-3 libseccomp-2.5.4-1 libsecret-0.20.5-2
libshout-1:2.4.6-1 libsigc+±2.10.8-1 libsm-1.2.3-3
libsmbios-2.4.3-5 libsndfile-1.1.0-2 libsoup-2.74.2-2
libsoup3-3.0.7-1 libspectre-0.2.10-1 libspiro-1:20220722-1
libspnav-1.0-1 libsrtp-1:2.4.2-1 libssh-0.9.6-1
libssh2-1.10.0-1 libstaroffice-0.0.7-2 libstemmer-2.2.0-2
libsysprof-capture-3.44.0-1 libtar-1.2.20-6 libtasn1-4.18.0-1
libteam-1.31-5 libtg_owt-0.git14.10d5f4b-2 libthai-0.1.29-1
libtiff-4.4.0-1 libtorrent-rasterbar-1:2.0.7-1
libunistring-1.0-1 libunwind-1.6.2-1 libupnp-1.14.12-3
liburcu-0.13.1-1 liburing-2.2-1 libusb-1.0.26-1
libutempter-1.2.1-3 libutf8proc-2.7.0-2 libuv-1.44.2-1
libva-2.15.0-1 libva-intel-driver-2.4.1-2 libvdpau-1.5-1
libverto-0.3.2-4 libvisio-0.1.7-7 libvoikko-4.3.1-2
libvorbis-1.3.7-3 libvpx-1.12.0-1 libwacom-2.3.0-1
libwebp-1.2.3-1 libwpe-1.12.0-2 libwpg-0.3.3-3
libx11-1.8.1-3 libx86emu-3.5-2 libxau-1.0.9-4 libxcb-1.15-1
libxcomposite-0.4.5-4 libxcrypt-4.4.28-2 libxcursor-1.2.1-1
libxcvt-0.1.1-1 libxdamage-1.1.5-4 libxdmcp-1.1.3-4
libxext-1.3.4-4 libxi-1.8-1 libxinerama-1.1.4-4
libxkbcommon-1.4.1-1 libxkbcommon-x11-1.4.1-1
libxkbfile-1.1.0-3 libxml2-2.9.14-1 libxmlb-0.3.9-1
libxmu-1.1.3-3 libxnvctrl-515.57-1 libxpm-3.5.13-3
libxrandr-1.5.2-4 libxrender-0.9.10-5 libxshmfence-1.3-3
libxslt-1.1.35-1 libxss-1.2.3-4 libxtst-1.2.3-5
libxv-1.0.11-5 libxxf86vm-1.1.4-5 libyuv-r2322+3aebf69d-1
libzip-1.9.2-1 libzmf-0.0.2-12 licenses-20220125-1
lilv-0.24.14-2 linux-api-headers-5.17.5-2
linux-firmware-20220708.be7798e-1
linux-firmware-whence-20220708.be7798e-1 linux510-5.10.133-1
linux510-nvidia-515.57-8 linux54-5.4.207-1
linux54-nvidia-515.57-7 lirc-1:0.10.1-12 llvm-14.0.6-2
llvm-libs-14.0.6-2 logrotate-3.20.1-1 lrzip-0.651-2
lsb-release-2.0.r48.3cf5103-1 lsof-4.95.0-1 lua-5.4.4-1
luajit-2.1.0.beta3.r431.g5677985d-1 lutris-0.5.10.1-2
lv2-1.18.6-1 lvm2-2.03.16-1 lzip-1.23-2 man-db-2.10.2-1
man-pages-5.13-1 manjaro-alsa-20210928-1
manjaro-application-utility-1.3.3-7
manjaro-browser-settings-20220522-1 manjaro-hello-0.7.0-1
manjaro-kde-settings-20220130-1 manjaro-keyring-20220514-2
manjaro-pulse-20220217-2 manjaro-release-21.3.6-1
manjaro-settings-manager-0.5.7-5
manjaro-settings-manager-kcm-0.5.7-5
manjaro-settings-manager-knotifier-0.5.7-5
manjaro-system-20220727-1 mbedtls-2.28.0-1 mdadm-4.2-2
mesa-22.1.4-1 mesa-demos-8.5.0-2 mesa-utils-8.5.0-2
meson-0.63.0-1 mhwd-db-0.6.5-21 mhwd-nvidia-515.57-1
mhwd-nvidia-390xx-390.151-2 mhwd-nvidia-470xx-470.129.06-1
milou-5.24.6-1 minizip-1:1.2.12-2 mjpegtools-2.2.1-1
mkinitcpio-31-2.0 mkinitcpio-busybox-1.35.0-1
mobile-broadband-provider-info-20220725-1
modemmanager-1.18.10-2 modemmanager-qt-5.96.0-1
mono-6.12.0.177-1 mpfr-4.1.0.p13-2 mpg123-1.30.1-1
mtdev-1.1.6-2 nano-6.3-1 ncurses-6.3-3 ndctl-73-1
neon-0.32.2-1 net-snmp-5.9.1-4 netpbm-10.73.37-1
nettle-3.8-1 networkmanager-1.38.2-2
networkmanager-openconnect-1.2.8-2
networkmanager-openvpn-1.8.18-2 networkmanager-pptp-1.2.10-2
networkmanager-qt-5.96.0-1 networkmanager-vpnc-1.2.8-2
nfs-utils-2.6.1-1 nfsidmap-2.6.1-1 ninja-1.11.0-1
nodejs-18.7.0-1 noto-fonts-20220607-1
noto-fonts-cjk-20220126-1 noto-fonts-emoji-20211101-1
nspr-4.34-1 nss-3.81-1 ntfs-3g-2022.5.17-1
nvidia-utils-515.57-1 obs-studio-27.2.4-2 okular-22.04.3-1
openal-1.22.2-1 opencolorio-2.1.2-1 openconnect-1:9.01-2
openexr-3.1.5-1 openimagedenoise-1.4.3-1
openimageio-2.3.16.0-2 openjpeg2-2.5.0-1 openmpi-4.1.4-1
openpmix-4.1.2-1 openshadinglanguage-1.11.17.0-4
openssh-9.0p1-1 openssl-1.1.1.q-1 opensubdiv-3.4.4-11
openvdb-9.1.0-1 openvpn-2.5.7-1 openvr-1.16.8-2
openxr-1.0.24-1 opera-ffmpeg-codecs-103.0.5060.114-1
opus-1.3.1-3 os-prober-1.81-1 ostree-2022.5-1
p11-kit-0.24.1-1 p7zip-1:17.04-3 pacman-6.0.1-12
pacman-mirrors-4.23.2-2 pam-1.5.2-1 pamac-cli-10.4.1-1
pamac-gtk-10.4.1-1 pambase-20211210-1 pango-1:1.50.8-1
pangomm-2.46.2-1 parted-3.5-1 pciutils-3.8.0-2 pcre2-10.40-1
pcsclite-1.9.8-1 perl-5.36.0-1 perl-alien-build-2.50-1
perl-alien-libxml2-0.17-3 perl-capture-tiny-0.48-6
perl-clone-0.45-4 perl-dbi-1.643-4 perl-encode-locale-1.05-9
perl-error-0.17029-4 perl-ffi-checklib-0.28-3
perl-file-basedir-0.09-2 perl-file-desktopentry-0.22-9
perl-file-listing-6.15-2 perl-file-mimeinfo-0.33-1
perl-file-which-1.27-2 perl-html-parser-3.78-2
perl-html-tagset-3.20-12 perl-http-cookies-6.10-3
perl-http-daemon-6.14-2 perl-http-date-6.05-5
perl-http-message-6.37-1 perl-http-negotiate-6.01-10
perl-io-html-1.004-3 perl-ipc-system-simple-1.30-4
perl-libwww-6.60-2 perl-lwp-mediatypes-6.04-2
perl-mailtools-2.21-6 perl-net-http-6.22-2
perl-parse-yapp-1.21-5 perl-path-tiny-0.122-2
perl-timedate-2.33-4 perl-try-tiny-0.31-2 perl-uri-5.12-1
perl-www-robotrules-6.02-10 perl-xml-libxml-2.0207-3
perl-xml-parser-2.46-4 perl-xml-writer-0.900-1
phonon-qt5-4.11.1-3 phonon-qt5-gstreamer-4.10.0-3
pinentry-1.2.0-1 pipewire-1:0.3.56-1 pixman-0.40.0-2
pkcs11-helper-1.29.0-1 plasma-desktop-5.24.6-1
plasma-framework-5.96.0-1 plasma-integration-5.24.6-1
plasma-nm-5.24.6-1 plasma-pa-5.24.6-1
plasma-workspace-5.24.6-1 plasma-workspace-wallpapers-5.24.6-1
plasma5-themes-breath-21.3.0-4
plasma5-themes-breath-migration-21.3.0-4
plasma5-themes-breath2-1.0.18-5 [removal] polkit-121-1
polkit-kde-agent-5.24.6-1 poppler-22.07.0-1
poppler-data-0.4.11-1 poppler-glib-22.07.0-1
poppler-qt5-22.07.0-1 popt-1.18-3 portmidi-236-1
powerdevil-5.24.6-1 print-manager-22.04.3-1 prison-5.96.0-2
protobuf-21.4-1 protobuf-c-1.4.1-1 psmisc-23.5-1
ptex-2.4.1-3 pugixml-1.12.1-1 pulseaudio-16.1-1
pulseaudio-alsa-1:1.2.7.1-1 pulseaudio-bluetooth-16.1-1
pulseaudio-equalizer-16.1-1 pulseaudio-jack-16.1-1
pulseaudio-lirc-16.1-1 pulseaudio-rtp-16.1-1
pulseaudio-zeroconf-16.1-1 purpose-5.96.0-1 pybind11-2.10.0-1
pyside6-6.3.1-3 python-3.10.5-1 python-anytree-2.8.0-5
python-apipkg-2.1.1-1 python-appdirs-1.4.4-6
python-argcomplete-2.0.0-1 python-asn1crypto-1.5.1-1
python-atomicwrites-1.4.1-1 python-attrs-21.4.0-1
python-automat-20.2.0-9 python-beaker-1.11.0-8
python-cachecontrol-1:0.12.6-4 python-cairo-1.21.0-1
python-certifi-2022.06.15-1 python-cffi-1.15.1-1
python-chardet-4.0.0-5 python-click-8.1.3-1
python-cloudpickle-2.1.0-1 python-colorama-0.4.5-1
python-colorlog-6.5.0-3 python-commonmark-0.9.1-5
python-constantly-15.1.0-11 python-contextlib2-21.6.0-1
python-coverage-6.1.1-3 python-cryptography-37.0.4-1
python-cycler-0.11.0-1 python-daemonize-2.5.0-5
python-dateutil-2.8.2-4 python-decorator-5.1.1-1
python-distlib-0.3.5-1 python-distro-1.7.0-1
python-dnspython-1:2.2.1-1 python-docopt-0.6.2-11
python-docutils-1:0.19-1 python-evdev-1.6.0-1
python-fonttools-4.34.4-1 python-frozendict-1:2.3.3-1
python-future-0.18.2-7 python-geoip-1.3.2-12
python-gobject-3.42.2-1 python-hidapi-0.12.0.2-1
python-hsluv-5.0.3-1 python-html5lib-1.1-11
python-hyperlink-21.0.0-4 python-idna-3.3-4
python-ifaddr-0.2.0-1 python-importlib-metadata-4.8.1-3
python-incremental-21.3.0-5 python-iniconfig-1.1.1-5
python-jaraco.context-4.1.1-2 python-jaraco.functools-3.5.1-1
python-jaraco.text-3.8.1-1 python-keyutils-0.6-8
python-kiwisolver-1.4.3-1 python-lockfile-0.12.2-11
python-lxml-4.9.1-1 python-magic-1:0.4.27-1
python-mako-1.1.6-3 python-manjaro-sdk-0.8-2
python-markdown-3.4.1-1 python-markupsafe-2.1.1-1
python-matplotlib-3.5.2-1 python-mock-3.0.5-9
python-more-itertools-8.13.0-2 python-msgpack-1.0.3-1
python-networkx-2.8.4-1 python-nose-1.3.7-14
python-notify2-0.3.1-7 python-npyscreen-4.10.5-7
python-nspektr-0.4.0-1 python-numpy-1.23.1-1
python-ordered-set-4.0.2-6 python-packaging-21.3-1
python-pandas-1.4.3-1 python-pbr-5.9.0-1
python-pep517-0.12.0-4 python-pillow-9.2.0-1
python-pip-22.2-1 python-platformdirs-2.5.1-1
python-pluggy-1.0.0-1 python-ply-3.11-10
python-progress-1.6-5 python-py-1.11.0-1
python-pyaml-21.10.1-1 python-pyasn1-0.4.8-7
python-pyasn1-modules-0.2.8-6 python-pycparser-2.21-3
python-pycups-2.0.1-5 python-pycurl-7.45.1-1
python-pydbus-0.6.0-9 python-pyftpdlib-1.5.6-5
python-pygments-2.12.0-1 python-pyhamcrest-1.10.1-3
python-pyopenssl-22.0.0-1 python-pyparsing-3.0.9-1
python-pyqt5-5.15.7-1 python-pyqt5-sip-12.11.0-1
python-pysmbc-1.0.23-3 python-pytest-7.1.2-1
python-pytest-runner-5.3.2-1 python-pytoml-0.1.21-7
python-pytz-2022.1-1 python-pyudev-0.22-7 python-pyxdg-0.28-1
python-rencode-1.0.6-7 python-reportlab-3.6.10-1
python-requests-2.27.1-1 python-resolvelib-0.8.1-1
python-retrying-1.3.3-13 python-rich-12.5.1-1
python-ruamel-yaml-0.17.21-1 python-ruamel.yaml.clib-0.2.6-3
python-scipy-1.8.1-1 python-service-identity-21.1.0-4
python-setproctitle-1.2.3-1 python-setuptools-1:61.3.1-1
python-setuptools-scm-7.0.4-1 python-sip4-4.19.25-3
python-six-1.16.0-5 python-systemd-234-11
python-tenacity-8.0.1-3 python-toml-0.10.2-7
python-tomli-2.0.1-1 python-traitlets-5.3.0-1
python-trove-classifiers-2022.7.22-1 python-twisted-21.7.0-4
python-typing_extensions-4.2.0-1 python-urllib3-1.26.9-1
python-validate-pyproject-0.9-1 python-wcwidth-0.2.5-6
python-webencodings-0.5.1-9 python-wrapt-1.14.1-1
python-yaml-6.0-1 python-zipp-3.8.1-1
python-zope-interface-5.4.0-4 python2-2.7.18-5
python2-appdirs-1.4.4-6 python2-ordered-set-3.1.1-4
python2-packaging-20.9-7 python2-pyparsing-2.4.7-6
python2-six-1.16.0-5 qca-qt5-2.3.4-3 qgpgme-1.17.1-1
qpdf-10.6.3-1 qqc2-desktop-style-5.96.0-1
qt5-base-5.15.5+kde+r173-1 qt5-declarative-5.15.5+kde+r19-1
qt5-graphicaleffects-5.15.5+kde+r0-1
qt5-imageformats-5.15.5+kde+r4-1 qt5-location-5.15.5+kde+r3-1
qt5-multimedia-5.15.5+kde+r1-1
qt5-quickcontrols-5.15.5+kde+r0-1
qt5-quickcontrols2-5.15.5+kde+r5-1 qt5-script-5.15.10-2
qt5-sensors-5.15.5+kde+r0-1 qt5-speech-5.15.5+kde+r1-1
qt5-svg-5.15.5+kde+r11-1 qt5-tools-5.15.5+kde+r1-3
qt5-translations-5.15.5+kde+r2-1
qt5-virtualkeyboard-5.15.5+kde+r3-1
qt5-wayland-5.15.5+kde+r38-3 qt5-webchannel-5.15.5+kde+r3-1
qt5-webengine-5.15.10-2 qt5-webkit-5.212.0alpha4-15
qt5-x11extras-5.15.5+kde+r0-1 qt6-5compat-6.3.1-1
qt6-base-6.3.1-1 qt6-declarative-6.3.1-1
qt6-imageformats-6.3.1-1 qt6-svg-6.3.1-1
qt6-translations-6.3.1-1 qt6-wayland-6.3.1-1 raptor-2.0.15-19
rasqal-1:0.9.33-5 rav1e-0.4.1-2 re2-1:20220601-1
readline-8.1.002-1 rest-0.8.1+r4+ge5ee6ef-1 rpcbind-1.2.6-2
rsync-3.2.4-1 rtkit-0.13-2 rtmpdump-1:2.4.r99.f1b83c1-2
ruby-3.0.4-2 ruby-bundledgems-3.0.4-2 ruby-bundler-2.3.18-1
ruby-irb-1.4.1-1 ruby-json-2.6.2-1 ruby-minitest-5.15.0-1
ruby-power_assert-2.0.1-1 ruby-psych-4.0.4-2
ruby-rake-13.0.6-1 ruby-rdoc-6.4.0-2 ruby-reline-0.3.1-1
ruby-rexml-3.2.5-1 ruby-stdlib-3.0.4-2 ruby-stringio-3.0.2-1
ruby-test-unit-3.5.3-1 rubygems-3.3.15-1 run-parts-5.5-1
runc-1.1.3-1 s-nail-14.9.24-1 samba-4.16.4-1 sane-1.1.1-1
sbc-2.0-1 scons-4.3.0-3 sddm-0.19.0-8
sddm-breath-theme-21.3.0-4 sddm-kcm-5.24.6-1
sdl-1.2.15-14 [removal] sdl12-compat-1.2.52-2 sdl2-2.0.22-2
serd-0.30.14-1 shaderc-2022.1-4 shadow-4.11.1-1
shared-mime-info-2.0+144+g13695c7-1 shiboken6-6.3.1-3
signon-kwallet-extension-22.04.3-1 signon-ui-0.17+20171022-3
signond-8.61-1 skanlite-22.04.3-1 smartmontools-7.3-1
smbclient-4.16.4-1 snapd-2.56.3-1 snappy-1.1.9-2
socat-1.7.4.3-1 sof-firmware-2.2-1 solid-5.96.0-1
sonnet-5.96.0-1 sord-0.16.12-3 sound-theme-freedesktop-0.8-5
soundtouch-2.3.1-2 spectacle-22.04.3-1
spectre-meltdown-checker-0.45-1 speex-1.2.1-1
speexdsp-1.2.1-1 spirv-tools-2022.1-1 splix-2.0.0-16
sqlite-3.39.1-1 squashfs-tools-4.5.1-1 sratom-0.6.12-1
srt-1.5.0-1 sshfs-3.7.3-1 steam-manjaro-1.0.0.74-1
subversion-1.14.1-6 suil-0.10.12-2 suitesparse-5.12.0-1
svt-av1-1.1.0-1 svt-hevc-1.5.1-2 syndication-5.96.0-1
syntax-highlighting-5.96.0-1 system-config-printer-1.5.16-1.2
systemd-251.3-1 systemd-libs-251.3-1
systemd-sysvcompat-251.3-1 systemsettings-5.24.6-3
talloc-2.3.4-1 tbb-2021.5.0-2 tcl-8.6.12-3 tdb-1.4.7-1
telegram-desktop-4.0.2-4 tevent-1:0.12.1-1
threadweaver-5.96.0-1 thunderbird-91.11.0-1 tinyxml-2.6.2-9
tlp-1.5.0-4 tpm2-tss-3.2.0-1 tracker3-3.3.2-1
ttf-liberation-2.1.5-1 tzdata-2022a-1 udiskie-2.4.2-1
udisks2-2.9.4-1 unarchiver-1.10.7-6 unrar-1:6.1.7-1
unzip-6.0-18 upower-0.99.20-1 usb_modeswitch-2.6.1-3
usbutils-014-2 util-linux-2.38-1 util-linux-libs-2.38-1
v4l-utils-1.22.1-1 v86d-0.1.10-6 vkd3d-1.4-1 vlc-3.0.17.4-7
vmaf-2.3.1-1 volume_key-0.3.12-7 vpnc-1:0.5.3.r506.r204-1
vte-common-0.68.0-2 vte3-0.68.0-2 vulkan-headers-1:1.3.221-1
vulkan-icd-loader-1.3.221-1 vulkan-tools-1.3.217-1
wayland-1.21.0-1 wayland-protocols-1.25-1
wayland-utils-1.0.0-2 web-installer-url-handler-2.3-1
webkit2gtk-2.36.4-2 webkit2gtk-4.1-2.36.4-2 wget-1.21.3-1
wine-7.13-1 wireless-regdb-2022.06.06-1 wireplumber-0.4.11-2
woff2-1.0.2-4 wpa_supplicant-2:2.10-4 wpebackend-fdo-1.12.0-2
wxgtk-common-3.0.5.1-2 [removal] wxgtk3-3.0.5.1-2 [removal]
wxwidgets-common-3.2.0-4 wxwidgets-gtk3-3.2.0-4
x264-3:0.164.r3081.19856cc-2 x265-3.5-3 xalan-c-1:1.12-5
xapian-core-1:1.4.19-2 xarchiver-0.5.4.18-1
xcb-proto-1.15.2-1 xcb-util-0.4.0-4 xcb-util-cursor-0.1.3-4
xcb-util-image-0.4.0-4 xcb-util-keysyms-0.4.0-4
xcb-util-renderutil-0.3.9-4 xcb-util-wm-0.4.1-4
xdg-dbus-proxy-0.1.4-1 xdg-desktop-portal-1.14.5-1
xdg-desktop-portal-kde-5.24.6-1 xdg-utils-1.1.3+21+g1a58bc2-1
xerces-c-3.2.3-6 xf86-input-elographics-1.4.2-3
xf86-input-evdev-2.10.6-3 xf86-input-libinput-1.2.1-1
xf86-input-void-1.4.1-6 xf86-input-wacom-1.1.0-1
xfsprogs-5.18.0-1 xkeyboard-config-2.36-2.1 xmlsec-1.2.34-1
xorg-bdftopcf-1.1-3 xorg-font-util-1.3.3-1
xorg-fonts-encodings-1.0.6-1 xorg-mkfontscale-1.2.2-1
xorg-server-21.1.4-1 xorg-server-common-21.1.4-1
xorg-setxkbmap-1.3.3-1 xorg-twm-1.0.12-1 xorg-xauth-1.1.2-1
xorg-xdpyinfo-1.3.3-4 xorg-xkill-1.0.5-3
xorg-xmessage-1.0.6-1 xorg-xmodmap-1.0.11-1 xorg-xrdb-1.2.1-1
xorg-xset-1.2.4-3 xorg-xsetroot-1.1.2-3 xorgproto-2022.1-1
xxhash-0.8.1-2 xz-5.2.5-3 yakuake-22.04.3-1 yaml-cpp-0.7.0-2
zbar-0.23.1-9 zenity-3.43.0-1 zeromq-4.3.4-2 zimg-3.0.4-1
zip-3.0-10 zita-alsa-pcmi-0.5.1-1 zlib-1:1.2.12-2 zsh-5.9-1
zstd-1.5.2-7 zxing-cpp-1.4.0-1 glibc-2.35-6
lib32-glibc-2.35-6
Total Download Size: 0.40 MiB
Total Installed Size: 11663.37 MiB
Net Upgrade Size: 689.20 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packagesā¦
wireplumber-0.4⦠408.8 KiB 395 KiB/s 00:01 [######################] 100%
Iām assuming it skipped a bunch of downloads because they got downloaded on the first time?
Honestly, at this stage, Iām assuming the easiest way is to just completely reinstall the OS? Backup the files on another drive and format this one, start from scratch?
