[manjaro@manjaro ~]$ sudo manjaro-chroot -a
==> Mounting (ManjaroLinux) [/dev/sda2]
--> mount: [/mnt]
--> mount: [/mnt/boot/efi]
please let me know what should be done after this
ok, now run update again:
pacman -Syyu
pacman -Syyu
error: failed to synchronize all databases (unable to lock database)
A bit late now, but so you know for next time.
rm /var/lib/pacman/db.lck
pacman -Syyu
warning: could not get file information for usr/share/icu/70.1/config/mh-linux
warning: could not get file information for usr/share/icu/70.1/install-sh
warning: could not get file information for usr/share/icu/70.1/mkinstalldirs
warning: could not get file information for usr/share/licenses/icu/LICENSE
warning: could not get file information for usr/share/man/man1/derb.1.gz
warning: could not get file information for usr/share/man/man1/genbrk.1.gz
warning: could not get file information for usr/share/man/man1/gencfu.1.gz
warning: could not get file information for usr/share/man/man1/gencnval.1.gz
warning: could not get file information for usr/share/man/man1/gendict.1.gz
warning: could not get file information for usr/share/man/man1/genrb.1.gz
warning: could not get file information for usr/share/man/man1/icu-config.1.gz
warning: could not get file information for usr/share/man/man1/icuexportdata.1.gz
warning: could not get file information for usr/share/man/man1/makeconv.1.gz
warning: could not get file information for usr/share/man/man1/pkgdata.1.gz
warning: could not get file information for usr/share/man/man1/uconv.1.gz
warning: could not get file information for usr/share/man/man8/genccode.8.gz
warning: could not get file information for usr/share/man/man8/gencmn.8.gz
warning: could not get file information for usr/share/man/man8/gensprep.8.gz
warning: could not get file information for usr/share/man/man8/icupkg.8.gz
warning: could not get file information for usr/lib/thunderbird/distribution/distribution.ini
is this something to be worried about??
well its probably not good… and did it already updated ?
it’s still updating
and you still getting the warning: could not get file information for messages?
only these packages got this
not others
( 1/35) Creating system user accounts...
( 2/35) Registering binary formats...
Skipped: Running in chroot.
( 3/35) Updating journal message catalog...
( 4/35) Reloading system manager configuration...
( 5/35) Updating udev hardware database...
( 6/35) Applying kernel sysctl settings...
( 7/35) Creating temporary files...
Failed to open file "/sys/devices/system/cpu/microcode/reload": Read-only file system
error: command failed to execute correctly
( 8/35) Reloading device manager configuration...
( 9/35) Arming ConditionNeedsUpdate...
(10/35) Updating the MIME type database...
(11/35) Rebuilding certificate stores...
(12/35) Updating module dependencies...
(13/35) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux513.preset: 'default'
-> -k /boot/vmlinuz-5.13-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.13-x86_64.img
==> ERROR: '/lib/modules/5.13.19-2-MANJARO' is not a valid kernel module directory
==> Building image from preset: /etc/mkinitcpio.d/linux513.preset: 'fallback'
-> -k /boot/vmlinuz-5.13-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.13-x86_64-fallback.img -S autodetect
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'default'
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64.img
==> Starting build: 5.15.41-1-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
-> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'fallback'
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: qla2xxx
==> WARNING: Possibly missing firmware for module: qed
==> WARNING: Possibly missing firmware for module: qla1280
==> WARNING: Possibly missing firmware for module: bfa
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64-fallback.img
(14/35) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.13-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.13-x86_64.img
Found initrd fallback image: /boot/initramfs-5.13-x86_64-fallback.img
done
(15/35) Reloading system bus configuration...
(16/35) Warn about old perl modules
(17/35) Copy Firefox Distribution Settings
(18/35) Updating fontconfig cache...
(19/35) Updating 32-bit fontconfig cache...
(20/35) Probing GDK-Pixbuf loader modules...
(21/35) Probing 32-bit GDK-Pixbuf loader modules...
(22/35) Updating GIO module cache...
(23/35) Compiling GSettings XML schema files...
(24/35) Probing GTK3 input method modules...
(25/35) Probing 32-bit GTK3 input method modules...
(26/35) Updating icon theme caches...
(27/35) Updating GTK4 module cache...
(28/35) Reloading GVFS config...
killall: /proc lacks process entries (not mounted ?)
(29/35) Restore Linux kernel modules
==> Warning:
-> Kernel has been updated. Modules of the current kernel
-> have been backed up so you can continue to use your
-> computer. However, the new kernel will only work
-> at next boot.
(30/35) Changing NetworkManager Connectivity-Ping to manjaro.org
(31/35) Updating the info directory file...
(32/35) Copy Thunderbird Distribution Settings
(33/35) Updating the desktop file MIME type cache...
(34/35) Updating the vlc plugin cache...
(35/35) Updating X fontdir indices...
please let me know what to do after this
ok so it finnished updating?
yes i have finished updating
so post output from:
mhwd-kernel -li
mhwd-kernel -li
Currently running: 5.15.32-1-MANJARO (linux515)
* linux515
you dont have any kernels installed, so install the 5.10 lts and the 517:
mhwd-kernel -i linux510
mhwd-kernel -i linux517
linux515 is installed
aha, it was shown that there is no kernel… anyway install the 5.10, it is better to have one backup kernel:
done installing
what do i do next?
