Hello
Couple of days ago
whenever i start my system am being shown Failed to Load Kernel Modules
and also systemd-modules-load.service is failing
please let me know what details i need to providing support
inxi -Fazy
journalctl --boot=0 --priority=3 --no-pager
click this icon in the editor: </>
and put the output there
just click the icon, dont write anything and remove the type or paste code here
and put there the outputs
you put inside the output from:
inxi -Fazy
i’m sorry i’m not able understand you
i’m in emergency mode so i wont able to take screenshot
i see, so you cant boot and copy the text…
yeah that is problem
you need to chroot using a manjaro live usb
ok so boot into it, connect to internet and run this command:
sudo manjaro-chroot -a
is this picture from trying to boot into manjaro iso?
yes it is being pushed into rescue mode
it may be a corrupted iso, or the way it was flashed onto usb … can you download ventoy and use it to flash the manjaro iso
okay will do give me 5min
booted into it just now
so open terminal and run this:
