Hi, I check the error with
sudo journalctl -b -p err
and I found those errors
-- Journal begins at Fri 2021-06-25 23:20:58 +0630, ends at Tue 2021-06-29 21:38:18 +0630. --
Jun 29 21:29:34 msaixitu kernel: ata3.00: failed to set xfermode (err_mask=0x100)
Jun 29 21:29:34 msaixitu kernel: ata3.00: revalidation failed (errno=-5)
Jun 29 21:29:36 msaixitu kernel: Bluetooth: hci0: unexpected event for opcode 0xfc2f
Jun 29 21:29:47 msaixitu gdm-password][1210]: gkr-pam: unable to locate daemon control file
Jun 29 21:29:50 msaixitu pulseaudio[1325]: Doing resync
Jun 29 21:29:50 msaixitu pulseaudio[1325]: Playback too far ahead (74550), drop source 19080
Jun 29 21:29:51 msaixitu systemd[1220]: Failed to start Application launched by gnome-session-binary.
Jun 29 21:37:08 msaixitu sudo[2767]: msai : a password is required ; TTY=pts/0 ; PWD=/home/msai ; USER=root ; COMMAND=/sbin/file -s /dev/sda1
How can i solve those errors?
hear is output of inxi output
Kernel: 5.13.0-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=04b98feb-830b-4c6f-b774-58e5ba4f228d rw quiet splash apparmor=1
Desktop: GNOME 3.38.4 tk: GTK 3.24.29 wm: gnome-shell dm: GDM 40.0
Type: Laptop System: Micro-Star product: GL62 6QE v: REV:1.0
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Micro-Star model: MS-16J5 v: REV:0.A serial: <filter>
UEFI: American Megatrends v: E16J5IMS.11D date: 01/19/2018
ID-1: BAT1 charge: 4.1 Wh (12.3%) condition: 33.3/43.2 Wh (77.1%)
volts: 10.1 min: 10.8 model: MSI BIF0_9 type: Li-ion serial: N/A
status: Discharging
RAM: total: 7.66 GiB used: 4.4 GiB (57.5%)
Info: Quad Core model: Intel Core i7-6700HQ bits: 64 type: MT MCP
arch: Skylake-S family: 6 model-id: 5E (94) stepping: 3 microcode: E2 cache:
L2: 6 MiB bogomips: 41621
Speed: 1801 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 1801 2: 1801
3: 1800 4: 1800 5: 1800 6: 1800 7: 1800 8: 1801
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good rtm sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: Intel HD Graphics 530 vendor: Micro-Star MSI driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:191b class-ID: 0300
Device-2: NVIDIA GM107M [GeForce GTX 950M] vendor: Micro-Star MSI
driver: nvidia v: 465.31 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:139a class-ID: 0302
Device-3: Chicony USB 2.0 Webcam Device type: USB driver: uvcvideo
bus-ID: 1-11:3 chip-ID: 04f2:b521 class-ID: 0e02 serial: <filter>
Display: x11 server: X.org 1.20.11 compositor: gnome-shell driver:
loaded: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
OpenGL: renderer: Mesa Intel HD Graphics 530 (SKL GT2) v: 4.6 Mesa 21.1.2
direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
chip-ID: 8086:a170 class-ID: 0403
Sound Server-1: ALSA v: k5.13.0-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel port: e000
bus-ID: 02:00.0 chip-ID: 8086:3165 class-ID: 0280
Device-2: Qualcomm Atheros QCA8171 Gigabit Ethernet vendor: Micro-Star MSI
driver: alx v: kernel port: d000 bus-ID: 03:00.0 chip-ID: 1969:10a1
class-ID: 0200
bus-ID: 1-10:2 chip-ID: 8087:0a2a class-ID: e001
Permissions: Unable to run lvs. Root privileges required.
Local Storage: total: 1.14 TiB used: 22.71 GiB (1.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: SSD 256GB size: 238.47 GiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
rotation: SSD serial: <filter> rev: S0318A0G scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10JPVX-22JC3T0
rotation: 5400 rpm serial: <filter> rev: 1A01 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUD0N rev: 1.00
dev-links: cdrom
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
used: 22.71 GiB (9.7%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 04b98feb-830b-4c6f-b774-58e5ba4f228d
label: NO_LABEL uuid: 82EC-5D39
ID-1: /dev/sda1 maj-min: 8:1 size: 931.51 GiB fs: <superuser required>
label: WinDisk uuid: 54D2DCCED2DCB608
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-10:2 info: Intel Bluetooth wireless interface type: Bluetooth
Device-2: 1-11:3 info: Chicony USB 2.0 Webcam Device type: Video
Device-3: 1-12:4 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 55.0 C mobo: 27.8 C
Processes: 303 Uptime: 1h 30m wakeups: 1 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.0 Packages: pacman: 1296
lib: 330 flatpak: 0 Shell: Zsh v: 5.8 running-in: gnome-terminal
inxi: 3.3.04
