Kernel failing to boot on startup
I recommend installing a second kernel (5.10) just to be safe in case one gets compromised…
You can then remove linux59: sudo mhwd-kernel -r linux59
5.10 and 5.9 have usually failed on me so i’d rather use 5.4
Your pc, your choice. So are you saying you’re back in business?
Now, manjaro is working but the option to boot into windows is gone, any ideas?
It’s a known issue, please read the release/issue notes here:
https://forum.manjaro.org/t/stable-update-2021-03-08-kernels-plasma-5-21-2-haskell-kodi-grub-kde-dev
Alright, it worked. Kernel 5.9 is failing on me again and Kernel 5.10 won’t even show up, but I can fix these issues.
Thank you @anon88624618 for helping me along the way, really appreciate it. And thank you @stephane
@philm Could somebody please have a look at manjaro-chroot and its weird behaviour?
EDIT: Nevermind, maybe OP used an iso that’s older than 6 months:
@freggel.doe
@Manjaro-Team A fix exists for quite some time now:
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
:innocent:
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
