Here you go. This version of kernel / Nvidia driver runs just fine.
Kernel: 6.18.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=86ad2543-5b6f-4f9f-b63f-7518886db958 rw apparmor=1 delayacct
Desktop: Cinnamon v: 6.4.13 tk: GTK v: 3.24.51 wm: Muffin v: 6.4.1 tools:
avail: cinnamon-screensaver dm: LightDM v: 1.32.0 Distro: Manjaro
base: Arch Linux
Type: Desktop Mobo: Micro-Star model: MAG B550 TOMAHAWK (MS-7C91) v: 2.0
serial: <filter> uuid: a89f7277-b343-1512-ab8b-d8bbc136bbd5 Firmware: UEFI
vendor: American Megatrends LLC. v: A.C0 date: 03/06/2023
System RAM: total: 64 GiB available: 62.72 GiB used: 8.24 GiB (13.1%)
(unregistered) size: 16 GiB speed: 2667 MT/s volts: curr: 1.2 min: 1.2
max: 1.2 width (bits): data: 64 total: 64 manufacturer: Crucial
part-no: BL16G32C16U4B.M16FE1 serial: <filter>
part-no: BL16G32C16U4B.16FE serial: <filter>
Device-3: Channel-B DIMM 0 type: DDR4 detail: synchronous unbuffered
Slot: 0 type: PCIe status: in use info: J6B2 length: long volts: 3.3
bus-ID: 00:01.0
Slot: 1 type: PCIe status: in use info: J6B1 length: short volts: 3.3
bus-ID: 00:1c.3
Slot: 2 type: PCIe status: in use info: J6D1 length: short volts: 3.3
bus-ID: 00:1c.4
Slot: 3 type: PCIe status: in use info: J7B1 length: short volts: 3.3
bus-ID: 00:1c.5
Slot: 4 type: PCIe status: in use info: J8B4 length: short volts: 3.3
bus-ID: 00:1c.6
Slot: 5 type: PCIe status: in use info: J8D1 length: short volts: 3.3
bus-ID: 00:1c.7
Slot: 6 type: PCI status: in use info: J8B3 length: short volts: 3.3
bus-ID: 00:1e.0
Slot: 12 type: PCIe status: in use info: J10 length: short volts: 3.3
bus-ID: 00:03.1 children: 1: 2b:00.0 class-ID: 0300 type: display 2: 2b:00.1
class-ID: 0403 type: audio
Slot: 14 type: PCIe status: in use info: J3700, M.2 length: short
volts: 3.3 bus-ID: 00:01.1 children: 1: 01:00.0 class-ID: 0108
type: mass-storage
Slot: 128 type: PCIe status: in use info: J3708 length: short volts: 3.3
bus-ID: 03:00.0
Slot: 134 type: PCIe status: available info: J3703 length: short
volts: 3.3 bus-ID: 00:1f.7
Slot: 135 type: PCIe status: in use info: J3702 length: short volts: 3.3
bus-ID: 03:07.0
Slot: 132 type: PCIe status: available info: J3707 length: short
Slot: 137 type: PCIe status: in use info: J3701, M.2 length: short
volts: 3.3 bus-ID: 03:09.0
Info: model: AMD Ryzen 7 5800X socket: AM4 bits: 64 type: MT MCP
arch: Zen 3+ gen: 3 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA20102E
desc: 8x512 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 1754 min/max: 556/4854 boost: enabled
base/boost: 3800/4850 scaling: driver: amd-pstate-epp governor: powersave
volts: 1.1 V ext-clock: 100 MHz cores: 1: 1754 2: 1754 3: 1754 4: 1754
5: 1754 6: 1754 7: 1754 8: 1754 9: 1754 10: 1754 11: 1754 12: 1754
13: 1754 14: 1754 15: 1754 16: 1754 bogomips: 121607
xsaves xtopology
affected
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Gigabyte
driver: nvidia v: 580.105.08 alternate: nouveau,nova_core,nvidia_drm
non-free: 550-580.xx+ status: current (as of 2025-11; EOL~2026-12-xx)
arch: Pascal code: GP10x process: TSMC 16nm built: 2016-2021 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: none off: DP-1,HDMI-A-1
empty: DVI-D-1,DVI-D-2 bus-ID: 2b:00.0 chip-ID: 10de:1c03 class-ID: 0300
Device-2: Microsoft LifeCam VX-2000 driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:3
chip-ID: 045e:0761 class-ID: 0102
Display: x11 server: X.Org v: 21.1.21 with: Xwayland v: 24.1.9 driver: X:
loaded: nvidia gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 3640x1920 s-dpi: 96 s-size: 963x508mm (37.91x20.00")
s-diag: 1089mm (42.87")
Monitor-1: DP-1 mapped: DP-0 note: disabled pos: primary,bottom-r
model: BenQ GL2706PQ serial: <filter> built: 2016 res: mode: 2560x1440
hz: 60 scale: 100% (1) dpi: 109 gamma: 1.2 chroma: red: x: 0.651 y: 0.337
green: x: 0.314 y: 0.627 blue: x: 0.149 y: 0.051 white: x: 0.314 y: 0.329
size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
modes: 2560x1440, 2048x1280, 1920x1200, 1920x1080, 1600x1200, 1680x1050,
1600x1000, 1600x900, 1280x1024, 1440x900, 1280x720, 1024x768, 800x600,
720x576, 720x480, 640x480
Monitor-2: HDMI-A-1 mapped: HDMI-0 note: disabled pos: top-left
model: BenQ GL2460 serial: <filter> built: 2017 res: mode: 1920x1080 hz: 60
scale: 177% (0.5625) to: 1080x1920 dpi: 92 gamma: 1.2 chroma: red:
x: 0.643 y: 0.333 green: x: 0.333 y: 0.624 blue: x: 0.153 y: 0.047 white:
x: 0.314 y: 0.329 size: 531x299mm (20.91x11.77") diag: 609mm (24")
ratio: 16:9 modes: 1920x1080, 1680x1050, 1600x900, 1280x1024, 1280x800,
1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.105.08
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1060
6GB/PCIe/SSE2 memory: 5.86 GiB
API: Vulkan v: 1.4.328 layers: 2 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1060 6GB driver: nvidia v: 580.105.08 device-ID: 10de:1c03
surfaces: N/A
gpu: nvidia-settings,nvidia-smi x11: xdpyinfo, xprop, xrandr
Device-1: NVIDIA GP106 High Definition Audio vendor: Gigabyte
bus-ID: 2b:00.1 chip-ID: 10de:10f1 class-ID: 0403
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Kingston HyperX Cloud Stinger Wireless
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 0951:16da class-ID: 0300
Device-4: Microsoft LifeCam VX-2000 driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.18.0-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.9 status: n/a (root, process) tools: pw-cli
Server-3: PulseAudio v: 17.0-93-gbe2efb status: active (root, process)
with: 1: pulseaudio-alsa type: plugin 2: pulseaudio-jack type: module
tools: pacat,pactl,pavucontrol
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 2a:00.0
IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-0945b599233a state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IP v6: <filter> virtual: proto kernel_ll scope: link
IF-ID-2: br-47425c0bd684 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-3: br-50020bc7608e state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-4: br-6cc693103434 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-5: br-8d39dd95d400 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-6: br-9538c0462cee state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-7: br-ab4446e5f79c state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-8: br-d14efb21fbcb state: down mac: <filter>
IF-ID-9: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-10: veth057c62e state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-11: veth0bd6b28 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-12: veth0d63602 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-13: veth1ab9841 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-14: veth256ba88 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-15: veth37f8b85 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-16: veth4886b42 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-17: veth544bdb8 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-18: veth8a14135 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-19: veth8b387c7 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-20: vethaeb15b7 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-21: vethb5e58b1 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-22: vethb82c151 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-23: vethb873cdd state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-24: vethba8270c state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-25: vethe01214c state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-26: vethed571fb state: up speed: 10000 Mbps duplex: full
mac: <filter>
Info: services: NetworkManager, sshd, systemd-timesyncd
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:3
chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 6.46 TiB used: 4.35 TiB (67.4%)
ID-1: /dev/nvme0n1 maj-min: 259:6 vendor: Lexar model: SSD NM790 4TB
size: 3.73 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 16949 temp: 34.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 25.9 C
scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
ID-1: / raw-size: 150 GiB size: 147.09 GiB (98.06%) used: 98.23 GiB (66.8%)
fs: ext4 block-size: 4096 B dev: /dev/nvme1n1p5 maj-min: 259:5 label: N/A
uuid: 86ad2543-5b6f-4f9f-b63f-7518886db958
used: 31.3 MiB (32.6%) fs: vfat block-size: 512 B dev: /dev/nvme1n1p1
maj-min: 259:1 label: N/A uuid: 30CF-D74C
ID-3: /home raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 1.47 TiB (82.0%) fs: ext4 block-size: 4096 B dev: /dev/sda1
maj-min: 8:1 label: N/A uuid: e298188c-af0e-4a61-b3ac-6d84d9f0345a
ID-4: /home/<filter>/android raw-size: 3.73 TiB size: 3.67 TiB (98.40%)
used: 2.78 TiB (75.9%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p1
maj-min: 259:7 label: N/A uuid: 59876845-08b6-4d82-960f-56256bbb8141
ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) priority: -2
file: /swap
ID-1: /dev/nvme1n1p2 maj-min: 259:2 size: 16 MiB fs: N/A label: N/A
uuid: N/A
ID-2: /dev/nvme1n1p3 maj-min: 259:3 size: 780.6 GiB fs: ntfs label: BOOT
uuid: 5270D23670D22111
ID-3: /dev/nvme1n1p4 maj-min: 259:4 size: 822 MiB fs: ntfs
label: Windows RE tools uuid: 28E0578CE0575F5E
Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-4:3 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 0a12:0001
class-ID: e001
Hub-3: 1-5:4 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-5.2:6 info: Metadot Das Keyboard 4 type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 24f0:204a class-ID: 0300
Device-2: 1-6:5 info: Logitech Lightspeed Receiver
type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
chip-ID: 046d:c539 class-ID: 0300
Device-3: 1-8:7 info: Micro Star MYSTIC LIGHT type: HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7c91 class-ID: 0300
serial: <filter>
Hub-4: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-1:2 info: Kingston HyperX Cloud Stinger Wireless
type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
Device-2: 3-3:3 info: Microsoft LifeCam VX-2000 type: video,audio
Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 34.0 C mobo: 29.5 C gpu: nvidia temp: 24 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Packages: pm: pacman pkgs: 1920 libs: 457 tools: yay
1: https://manjaro.kurdy.org/stable/$repo/$arch
2: https://mirror.23m.com/manjaro/stable/$repo/$arch
3: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
4: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
5: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
6: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
7: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 519
1: cpu: 105% command: python3 pid: 14805 mem: 33.3 MiB (0.0%)
2: cpu: 100% command: ps pid: 14818 mem: 4.55 MiB (0.0%)
3: cpu: 15.7% command: chrome pid: 13015 mem: 474.3 MiB (0.7%)
4: cpu: 8.6% command: chrome pid: 13305 mem: 342.5 MiB (0.5%)
5: cpu: 6.2% command: python3 pid: 2911 mem: 736.1 MiB (1.1%)
Memory top: 5 of 519
1: mem: 1379.5 MiB (2.1%) command: python pid: 3755 cpu: 5.0%
2: mem: 736.1 MiB (1.1%) command: python3 pid: 2911 cpu: 6.2%
3: mem: 474.3 MiB (0.7%) command: chrome pid: 13015 cpu: 15.7%
4: mem: 342.5 MiB (0.5%) command: chrome pid: 13305 cpu: 8.6%
5: mem: 339.4 MiB (0.5%) command: cinnamon pid: 8521 cpu: 5.1%
Processes: 519 Power: uptime: 2m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25.03 GiB services: csd-power,upowerd
Init: systemd v: 258 default: graphical tool: systemctl
Compilers: gcc: 15.2.1 Shell: Sudo (sudo) v: 1.9.17p2 default: Bash
v: 5.3.8 running-in: gnome-terminal inxi: 3.3.40
