[ 4184.012222] i915 0000:00:02.0: [drm] GPU HANG: ecode 8:0:00000000
[ 4184.013231] i915 0000:00:02.0: [drm] Resetting rcs0 for stopped heartbeat on rcs0
System hangs for up to 10 seconds and this message is displayed in dmesg. Happens quite a lot as well.
I’ve tried the suggestions here Intel graphics - ArchWiki
Google search reveals that I am not the only one with this problem, but no one has a fix.
Awesome
Well … you do have the option of (installing and) using another kernel. Like 6.6 LTS.
The i915 is an umbrella. You will have to supply more information. The output from
inxi -F
Host: pluto Kernel: 6.9.0-1-MANJARO arch: x86_64 bits: 64
Desktop: KDE Plasma v: 6.0.4 Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 20BXCTO1WW v: ThinkPad T450s
serial: <superuser required>
Mobo: LENOVO model: 20BXCTO1WW v: SDK0J40709 WIN
serial: <superuser required> UEFI: LENOVO v: JBET73WW (1.37 )
date: 08/14/2019
ID-1: BAT0 charge: 9.4 Wh (76.4%) condition: 12.3/23.5 Wh (52.3%)
volts: 11.6 min: 11.4
ID-2: BAT1 charge: 43.4 Wh (77.4%) condition: 56.1/71.3 Wh (78.7%)
Info: dual core model: Intel Core i5-5200U bits: 64 type: MT MCP cache:
L2: 512 KiB
Speed (MHz): avg: 2195 min/max: 500/2700 cores: 1: 2196 2: 2195 3: 2195
4: 2196
Device-1: Intel HD Graphics 5500 driver: i915 v: kernel
Device-2: Chicony Integrated Camera driver: uvcvideo type: USB
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 23.2.6
compositor: kwin_wayland driver: X: loaded: modesetting dri: iris gpu: i915
resolution: 1920x1080
API: EGL v: 1.5 drivers: iris,swrast
platforms: wayland,x11,surfaceless,device
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.6-manjaro1.1
renderer: Mesa Intel HD Graphics 5500 (BDW GT2)
API: Vulkan v: 1.3.279 drivers: intel surfaces: xcb,xlib,wayland
Device-1: Intel Broadwell-U Audio driver: snd_hda_intel
Device-2: Intel Wildcat Point-LP High Definition Audio
API: ALSA v: k6.9.0-1-MANJARO status: kernel-api
Server-1: PipeWire v: 1.0.5 status: active
Device-1: Intel Ethernet I218-V driver: e1000e
IF: enp0s25 state: down mac:
Device-2: Intel Wireless 7265 driver: iwlwifi
IF: wlp3s0 state: up mac:
Local Storage: total: 1.36 TiB used: 690.95 GiB (49.4%)
ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB
ID-2: /dev/sdb vendor: Dogfish Technology model: SSD 1TB size: 931.51 GiB
ID-1: / size: 435.97 GiB used: 295.07 GiB (67.7%) fs: ext4 dev: /dev/dm-0
ID-2: /boot/efi size: 299.4 MiB used: 117.6 MiB (39.3%) fs: vfat
dev: /dev/sda1
ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) file: /swapfile
ID-2: swap-2 type: zram size: 9.72 GiB used: 252 KiB (0.0%)
dev: /dev/zram0
System Temperatures: cpu: 53.0 C pch: 53.5 C mobo: N/A
Fan Speeds (rpm): fan-1: 3236
Memory: total: 20 GiB available: 19.44 GiB used: 9.63 GiB (49.6%)
Processes: 280 Uptime: 21h 9m Shell: Bash inxi: 3.3.34
Aragorn
Split this topic
5
A post was split to a new topic: Freezes with i915
