Freezes with i915
I tried different kernels from 5.15-6.12 to no avail, freezes periodically occur. I tried various healing methods, but all without success)
  Host: angelMG Kernel: 6.12.13-2-MANJARO arch: x86_64 bits: 64
  Desktop: KDE Plasma v: 6.3.0 Distro: Manjaro Linux
  Type: Laptop System: ASUSTeK product: TP300LDB v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: TP300LDB v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: TP300LDB.211 date: 04/16/2019
  ID-1: BAT0 charge: 39.8 Wh (98.0%) condition: 40.6/50.1 Wh (81.1%)
    volts: 11.3 min: 11.3
  Info: dual core model: Intel Core i5-5200U bits: 64 type: MT MCP cache:
    L2: 512 KiB
  Speed (MHz): avg: 2494 min/max: 500/2700 cores: 1: 2494 2: 2494 3: 2494
    4: 2494
  Device-1: Intel HD Graphics 5500 driver: i915 v: kernel
  Device-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT
    620M/625M/630M/720M] driver: nouveau v: kernel
  Device-3: Suyin Asus Integrated Webcam driver: uvcvideo type: USB
  Display: wayland server: X.org v: 1.21.1.15 with: Xwayland v: 24.1.5
    compositor: kwin_wayland driver: X: loaded: modesetting dri: iris,nouveau
    gpu: i915 resolution: 1920x1080~60Hz
  API: EGL v: 1.5 drivers: iris,nouveau,swrast
  API: OpenGL v: 4.6 compat-v: 4.3 vendor: intel mesa v: 24.3.4-arch1.1
    renderer: Mesa Intel HD Graphics 5500 (BDW GT2)
  API: Vulkan v: 1.4.303 drivers: N/A surfaces: xcb,xlib,wayland
    de: kscreen-console,kscreen-doctor gpu: gputop, intel_gpu_top, lsgpu
  Device-1: Intel Broadwell-U Audio driver: snd_hda_intel
  Device-2: Intel Wildcat Point-LP High Definition Audio
  API: ALSA v: k6.12.13-2-MANJARO status: kernel-api
  Server-1: PipeWire v: 1.2.7 status: active
  Device-1: Intel Wireless 7260 driver: iwlwifi
  IF: wlp2s0 state: up mac: 48:51:b7:c3:f4:ce
  IF-ID-1: amn0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
  Device-1: Intel Bluetooth wireless interface driver: btusb type: USB
  Local Storage: total: 447.13 GiB used: 107.92 GiB (24.1%)
  ID-1: /dev/sda vendor: Toshiba model: TR200 size: 447.13 GiB
  ID-1: / size: 143.13 GiB used: 29.99 GiB (21.0%) fs: ext4 dev: /dev/sda2
  ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat
    dev: /dev/sda4
  ID-3: /home size: 279.2 GiB used: 77.93 GiB (27.9%) fs: ext4
    dev: /dev/sda3
  ID-1: swap-1 type: partition size: 15.62 GiB used: 0 KiB (0.0%)
    dev: /dev/sda1
  System Temperatures: cpu: 57.0 C pch: 44.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 2900
  Memory: total: 12 GiB note: est. available: 11.12 GiB used: 6.45 GiB (58.0%)
  Processes: 237 Uptime: 3h 40m Shell: Zsh inxi: 3.3.37
I915 intel causes erratic Wayland hangs. And no matter how much I’ve searched I haven’t found a reliable solution yet
The provided inxi is odd/incomplete.
Please show
inxi -zv8
inxi -zv8         ✔
  Kernel: 6.12.13-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=b326b8d9-9b77-469c-9ab8-526f002cbfba rw quiet splash
    resume=UUID=0fce9c48-9f96-4bc5-9c34-5ffc0f3c6c62 udev.log_priority=3
    mitigations=off
  Desktop: KDE Plasma v: 6.3.0 tk: Qt v: N/A info: frameworks v: 6.10.0
    part-nu: ASUS-NotebookSKU uuid: <superuser required>
  ID-1: BAT0 charge: 39.8 Wh (98.0%) condition: 40.6/50.1 Wh (81.0%)
    volts: 11.3 min: 11.3 model: ASUSTeK UX3-44 type: Li-ion serial: N/A
    status: not charging cycles: 1095
  System RAM: total: 12 GiB available: 11.12 GiB used: 3.72 GiB (33.5%)
  Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
  Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 4 GiB
    speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: Samsung part-no: N/A serial: N/A
  Device-2: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 8 GiB
    manufacturer: 1201 part-no: R538G1601S2SL serial: N/A
  Info: model: Intel Core i5-5200U bits: 64 type: MT MCP arch: Broadwell
    gen: core 5 level: v3 note: check built: 2015-18 process: Intel 14nm
    family: 6 model-id: 0x3D (61) stepping: 4 microcode: 0x2F
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
    smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
    desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 2196 min/max: 500/2700 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 2196 2: 2196 3: 2196 4: 2196 bogomips: 17566
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
    avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs ida intel_pt invpcid lahf_lm
    lm mca mce md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae
    pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts
    rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
    tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
  Type: l1tf mitigation: PTE Inversion; VMX: vulnerable
  Type: mds status: Vulnerable; SMT vulnerable
  Type: meltdown status: Vulnerable
  Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
    usercopy barriers only; no swapgs barriers
  Type: spectre_v2 status: Vulnerable; IBPB: disabled; STIBP: disabled;
  Type: srbds status: Vulnerable
  Device-1: Intel HD Graphics 5500 vendor: ASUSTeK driver: i915 v: kernel
    arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
    empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1616 class-ID: 0300
    620M/625M/630M/720M] vendor: ASUSTeK driver: nouveau v: kernel non-free:
    series: 390.xx+ status: legacy (EOL~2022-11-22) last: release: 390.157
    kernel: 6.0 xorg: 1.21 arch: Fermi code: GF1xx process: 40/28nm
    built: 2010-2016 pcie: gen: 1 speed: 2.5 GT/s lanes: 4 link-max: lanes: 8
    bus-ID: 03:00.0 chip-ID: 10de:1140 class-ID: 0302
  Device-3: Suyin Asus Integrated Webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:4 chip-ID: 064e:9700
    alternate: fbdev,vesa dri: iris,nouveau gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x1361 built: 2014 res:
    mode: 1920x1080 hz: 60 scale: 125% (1.25) to: 1536x864 dpi: 166 gamma: 1.2
    chroma: red: x: 0.639 y: 0.341 green: x: 0.306 y: 0.616 blue: x: 0.149
    y: 0.071 white: x: 0.314 y: 0.329 size: 293x165mm (11.54x6.5")
    diag: 336mm (13.2") ratio: 16:9 modes: 1920x1080
  API: EGL v: 1.5 hw: drv: intel iris drv: nvidia nouveau platforms:
    device: 0 drv: nouveau device: 1 drv: iris device: 2 drv: swrast gbm:
    drv: nouveau surfaceless: drv: nouveau wayland: drv: iris x11: drv: iris
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 5500 (BDW
    GT2) device-ID: 8086:1616 memory: 5.43 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.4.303 layers: N/A device: 0 type: integrated-gpu
    name: Intel HD Graphics 5500 (BDW GT2) driver: N/A device-ID: 8086:1616
  Device-1: Intel Broadwell-U Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c class-ID: 0403
  Device-2: Intel Wildcat Point-LP High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0
    class-ID: 0403
  API: ALSA v: k6.12.13-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Intel Wireless 7260 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:08b1 class-ID: 0280
  IP v6: <filter> scope: global
  IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
  Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:3 chip-ID: 8087:07dc
    class-ID: e001
  Local Storage: total: 447.13 GiB used: 108.5 GiB (24.3%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: TR200 size: 447.13 GiB
    block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD
    serial: <filter> fw-rev: 13.6 scheme: GPT
  ID-1: / raw-size: 146.48 GiB size: 143.13 GiB (97.71%)
    used: 30.7 GiB (21.4%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: b326b8d9-9b77-469c-9ab8-526f002cbfba
    used: 288 KiB (0.1%) fs: vfat dev: /dev/sda4 maj-min: 8:4 label: N/A
    uuid: B8A9-BAA4
  ID-3: /home raw-size: 284.73 GiB size: 279.2 GiB (98.06%)
    used: 77.8 GiB (27.9%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
    uuid: b69511a1-4ed8-4c95-be54-807f86927a04
  Kernel: swappiness: 10 (default 60) cache-pressure: 50 (default 100)
    zswap: no
    priority: -2 dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 0fce9c48-9f96-4bc5-9c34-5ffc0f3c6c62
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 11 rev: 2.0
  Device-1: 1-3:2 info: YICHIP Wireless Device type: keyboard,mouse
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 3151:3020 class-ID: 0301
  Device-2: 1-4:3 info: Intel Bluetooth wireless interface type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:07dc class-ID: e001
  Device-3: 1-5:4 info: Suyin Asus Integrated Webcam type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 064e:9700 class-ID: 0e02
    serial: <filter>
  Device-4: 1-7:5 info: Atmel type: HID
    driver: hid-generic,hid-multitouch,usbhid interfaces: 2 rev: 2.0
    chip-ID: 03eb:8b04 class-ID: 0300
  Hub-2: 2-0:1 info: super-speed hub ports: 4 rev: 3.0
  Hub-3: 3-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-4: 3-1:2 info: Intel Integrated Hub ports: 8 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8001
  System Temperatures: cpu: 49.0 C pch: 40.5 C mobo: N/A
  Fan Speeds (rpm): cpu: 2800
  Packages: 1434 pm: pacman pkgs: 1384 libs: 369 tools: pamac pm: flatpak
    pkgs: 50
    1: https://mirrors2.manjaro.org/unstable/$repo/$arch
    2: https://mirror.init7.net/manjaro/unstable/$repo/$arch
    3: https://manjaro.kurdy.org/unstable/$repo/$arch
    4: https://ftp.gwdg.de/pub/linux/manjaro/unstable/$repo/$arch
    5: http://manjaro.mirrors.uk2.net/unstable/$repo/$arch
    6: https://edgeuno-bog2.mm.fcix.net/manjaro/unstable/$repo/$arch
    7: https://irltoolkit.mm.fcix.net/manjaro/unstable/$repo/$arch
    8: https://mirror.freedif.org/Manjaro/unstable/$repo/$arch
Processes:
  CPU top: 5 of 234
  1: cpu: 54.6% command: firefox pid: 2193 mem: 509.0 MiB (4.4%)
  2: cpu: 22.8% command: firefox pid: 2406 mem: 289.4 MiB (2.5%)
  3: cpu: 22.6% command: firefox pid: 2756 mem: 291.4 MiB (2.5%)
  4: cpu: 22.0% command: firefox pid: 2320 mem: 433.8 MiB (3.8%)
  5: cpu: 21.0% command: firefox pid: 2622 mem: 260.7 MiB (2.2%)
  Memory top: 5 of 234
  1: mem: 509.0 MiB (4.4%) command: firefox pid: 2193 cpu: 54.6%
  2: mem: 433.8 MiB (3.8%) command: firefox pid: 2320 cpu: 22.0%
  3: mem: 389.6 MiB (3.4%) command: plasmashell pid: 1043 cpu: 10.3%
  4: mem: 291.4 MiB (2.5%) command: firefox pid: 2756 cpu: 22.6%
  5: mem: 289.4 MiB (2.5%) command: firefox pid: 2406 cpu: 22.8%
  Processes: 234 Power: uptime: 1m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 4.42 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.37
please
I also have frequent GPU freezes (1-6 times a day) with kernel 6.12.12-2. With 6.6.75-2 everything seems to be fine, if the freezes return, I will write here.
The logs ended with an error (then I rebooted the laptop):
Feb 22 23:28:32 boris-hp kernel: i915 0000:00:02.0: [drm] Resetting rcs0 for preemption time out
Feb 22 23:28:32 boris-hp kernel: i915 0000:00:02.0: [drm] *ERROR* GT0: rcs0 reset request timed out: {request: 00000001, RESET_CTL: 00000001}
Feb 22 23:28:32 boris-hp kernel: i915 0000:00:02.0: [drm] GPU HANG: ecode 9:1:85dffffa, in Xorg [790]
Edit:
Yes, there are hangs with kernel 6.6.
Feb 24 17:52:39 boris-hp kernel: i915 0000:00:02.0: [drm] Resetting rcs0 for preemption time out
Feb 24 17:52:39 boris-hp kernel: i915 0000:00:02.0: [drm] *ERROR* rcs0 reset request timed out: {request: 00000001, RESET_CTL: 00000001}
Feb 24 17:52:39 boris-hp kernel: i915 0000:00:02.0: [drm] GPU HANG: ecode 9:1:85dffffa, in kwin_x11 [14530]
Feb 24 17:52:49 boris-hp kernel: Asynchronous wait on fence 0000:00:02.0:kwin_x11[14530]:275f26 timed out (hint:intel_atomic_commit_ready [i915])
LC_ALL=C inxi -zv8
  Kernel: 6.6.75-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=7fb0dd4d-7227-42fb-9866-a3d3ad15b246 rw quiet splash
    udev.log_priority=3 fsck.mode=force fsck.repair=yes
  Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A info: frameworks v: 6.10.0
  Type: Laptop System: HP product: HP Pavilion Gaming Laptop 16-a0xxx v: N/A
  Mobo: HP model: 87AE v: 32.32 serial: <superuser required>
    part-nu: 316G9EA#ACB uuid: <superuser required> UEFI: AMI v: F.30
    date: 07/22/2024
  ID-1: BAT0 charge: 41.5 Wh (100.0%) condition: 41.5/41.5 Wh (100.0%)
    volts: 11.6 min: 11.6 model: HP Primary type: Li-ion serial: <filter>
    status: discharging cycles: 83
  System RAM: total: 16 GiB available: 15.27 GiB used: 5.87 GiB (38.4%)
  Device-1: Bottom - Slot 1 (Up) type: DDR4 detail: synchronous size: 8 GiB
    speed: spec: 3200 MT/s actual: 2933 MT/s volts: note: check curr: 1 min: 1
    max: 1 width (bits): data: 64 total: 64 manufacturer: A-Data
    part-no: AO1P32NC8T1-BBVS serial: <filter>
  Device-2: Bottom - Slot 2 (down) type: DDR4 detail: synchronous
    size: 8 GiB speed: spec: 3200 MT/s actual: 2933 MT/s volts: note: check
    curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: A-Data part-no: AO1P32NC8T1-BBVS serial: <filter>
  Info: model: Intel Core i5-10300H bits: 64 type: MT MCP arch: Comet Lake
    gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
    model-id: 0xA5 (165) stepping: 2 microcode: 0xFC
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
    desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 800 min/max: 800/4500 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 bogomips: 40009
    fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
    ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx
    monitor movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
    pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdrand
    rdseed rdtscp rep_good sdbg sep sgx sgx_lc smap smep ss ssbd sse sse2
    xsaves xtopology xtpr
  Type: retbleed mitigation: Enhanced IBRS
    conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW
    loop
  Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Hewlett-Packard
    ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
    class-ID: 0300
  Device-2: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile]
    vendor: Hewlett-Packard driver: nvidia v: 550.144.03
    alternate: nouveau,nvidia_drm non-free: 550/565.xx+ status: current (as
    of 2025-01; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
    built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16
    bus-ID: 01:00.0 chip-ID: 10de:1f95 class-ID: 0300
  Device-3: Quanta HP TrueVision HD Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2 chip-ID: 0408:5365
    class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.15 with: Xwayland v: 24.1.5
    compositor: kwin_x11 driver: X: loaded: modesetting,nvidia unloaded: nouveau
    alternate: fbdev,nv,vesa dri: iris gpu: i915 display-ID: :0 screens: 1
    s-diag: 582mm (22.93") monitors: <missing: xrandr>
  Monitor-1: eDP-1 model: BOE Display 0x08f6 built: 2019 res: 1920x1080
    dpi: 137 gamma: 1.2 chroma: red: x: 0.584 y: 0.345 green: x: 0.333 y: 0.553
    blue: x: 0.161 y: 0.129 white: x: 0.314 y: 0.329
    size: 355x200mm (13.98x7.87") diag: 407mm (16") ratio: 16:9
    modes: 1920x1080
  EDID-Warnings: 1: parse_edid: unknown flag 2
    drv: nvidia gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.3.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
    device-ID: 8086:9bc4 memory: 7.46 GiB unified: yes
  API: Vulkan v: 1.4.303 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
    GeForce GTX 1650 Ti driver: N/A device-ID: 10de:1f95 surfaces: xcb,xlib
    device: 1 type: integrated-gpu name: Intel UHD Graphics (CML GT2)
    driver: N/A device-ID: 8086:9bc4 surfaces: xcb,xlib
    wl: wayland-info x11: xdpyinfo,xprop
  Device-1: Intel Comet Lake PCH cAVS vendor: Hewlett-Packard
    driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel, snd_soc_skl,
    snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0401
  Device-2: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
    pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
    chip-ID: 10de:10fa class-ID: 0403
  API: ALSA v: k6.6.75-2-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
    vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 4000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
    vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 04:00.0
    chip-ID: 10ec:c822 class-ID: 0280
  IF-ID-1: outline-tun0 state: down mac: N/A
  IP v4: <filter> scope: global
  Info: services: NetworkManager, systemd-networkd, systemd-timesyncd,
    wpa_supplicant
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:3 chip-ID: 0bda:b00c
  Report: btmgmt ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
    rfk-block: hardware: no software: yes address: <filter> bt-v: 5.1 lmp-v: 10
    status: discoverable: no pairing: no
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
    v: 3.0 port: 6060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: class-ID: 0104
  Local Storage: total: 1.38 TiB used: 307.21 GiB (21.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Ardor Gaming
    model: m.2 NVME 512Gb AL1284 size: 476.94 GiB block-size: physical: 512 B
    fw-rev: H231106a temp: 27.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM048-2E7172
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: GPT
  ID-1: / raw-size: 58.59 GiB size: 57.12 GiB (97.49%) used: 40.88 GiB (71.6%)
    fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4 label: root_newSSD
    uuid: 7fb0dd4d-7227-42fb-9866-a3d3ad15b246
  ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%)
    used: 27.3 MiB (2.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 0522-8ED9
  ID-3: /home raw-size: 361.69 GiB size: 354.94 GiB (98.13%)
    used: 266.3 GiB (75.0%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
    label: home_newSSD uuid: 22dc86a4-1861-4c94-beaf-1fef9f1c134d
  ID-1: swap-1 type: partition size: 16.6 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p5 maj-min: 259:5 label: swap_newSSD
    uuid: d27f4d1a-f0c0-4a72-a9a9-43eb696a66d4
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 39.06 GiB fs: ntfs label: N/A
    uuid: 8C36C77636C75FB6
  ID-3: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
  ID-4: /dev/sda2 maj-min: 8:2 size: 831.5 GiB fs: ntfs label: N/A
    uuid: 1E52533052530BC1
  ID-5: /dev/sda3 maj-min: 8:3 size: 100 GiB fs: ext4 label: N/A
    uuid: 13e91fac-2d52-4c27-9969-a3c2b9bd322c
  Device-1: 1-6:2 info: Quanta HP TrueVision HD Camera type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 0408:5365 class-ID: 0e02
  Device-2: 1-7:3 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
  System Temperatures: cpu: 35.0 C pch: 36.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 0 fan-2: 0
  Packages: pm: pacman pkgs: 1768 libs: 398 tools: pamac,yay pm: flatpak
    pkgs: 0
    1: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    2: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    3: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    4: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    5: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    6: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    7: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    8: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 300
  1: cpu: 40.2% command: firefox pid: 2704 mem: 554.6 MiB (3.5%)
  2: cpu: 31.8% command: firefox pid: 2948 mem: 931.3 MiB (5.9%)
  3: cpu: 29.2% command: thunderbird pid: 1411 mem: 658.6 MiB (4.2%)
  4: cpu: 12.0% command: firefox pid: 3159 mem: 276.6 MiB (1.7%)
  5: cpu: 7.5% command: firefox pid: 3084 mem: 297.9 MiB (1.9%)
  Memory top: 5 of 300
  1: mem: 931.3 MiB (5.9%) command: firefox pid: 2948 cpu: 31.8%
  2: mem: 658.6 MiB (4.2%) command: thunderbird pid: 1411 cpu: 29.2%
  3: mem: 554.6 MiB (3.5%) command: firefox pid: 2704 cpu: 40.2%
  4: mem: 358.9 MiB (2.2%) command: plasmashell pid: 987 cpu: 4.1%
  5: mem: 297.9 MiB (1.9%) command: firefox pid: 3084 cpu: 7.5%
  Processes: 300 Power: uptime: 3m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.09 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.37 running-in: yakuake inxi: 3.3.37
Hi, tried item 6.16? I installed all 3 parameters, and there were no freezes for a long time, but then there was still one frost, I will continue to look.
sudo nano /etc/default/grub && sudo update-grub && reboot
It would appear that you have BIOS updates available.
Including some marked for ‘performance’.
Ah. Broadwell.
I had one of those.
And freezes were an issue. C-states being the only reliable fix.
But a few options are shown at the archwiki:
https://wiki.archlinux.org/title/Intel_graphics#Crash/freeze_on_low_power_Intel_CPUs
Thank you, the bios is the latest, for some reason the dates do not match, but also 2019(there is no other one there). I updated it when I was on Windows, but I never tried to update it on Linux.
I already use all three directives)), but sometimes it still hangs, although much less
intel_idle.max_cstate = 1 i915.enable_dc = 0 ahci.mobile_lpm_policy = 1
In general, the topic can be closed, and the only solution here is to buy a notbook on Amd).
P.S. I updated the Bios with [this] (fwupd - ArchWiki), I never thought that on Linux it’s so easy :grinning:
