Hi all,
Just reporting…it’s past 11 PM here, so I’ll turn in.
After the update, I experienced a load fail:
● systemd-modules-load.service - Load Kernel Modules
Loaded: loaded (/usr/lib/systemd/system/systemd-modules-load.service; static)
Active: failed (Result: exit-code) since Mon 2021-03-29 23:05:46 CEST; 3min 29s ago
Docs: man:systemd-modules-load.service(8)
man:modules-load.d(5)
Process: 246 ExecStart=/usr/lib/systemd/systemd-modules-load (code=exited, status=1/FAILURE)
Main PID: 246 (code=exited, status=1/FAILURE)
mrt 29 23:05:46 Avalon systemd-modules-load[246]: Failed to look up module alias 'crypto_user': Function not implemented
mrt 29 23:05:46 Avalon systemd-modules-load[246]: Failed to look up module alias 'sg': Function not implemented
mrt 29 23:05:46 Avalon systemd-modules-load[246]: Failed to look up module alias 'msr': Function not implemented
mrt 29 23:05:46 Avalon systemd-modules-load[246]: Failed to look up module alias 'uinput': Function not implemented
mrt 29 23:05:46 Avalon systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
mrt 29 23:05:46 Avalon systemd[1]: systemd-modules-load.service: Failed with result 'exit-code'.
mrt 29 23:05:46 Avalon systemd[1]: Failed to start Load Kernel Modules.
Notice: journal has been rotated since unit was started, output may be incomplete.
This while loading 5.9… 4.19 loads nicely
As said, not panicing yet (eh, I use Manjaro, why should I panic?) just reporting…
Tomorrow, I’ll dig into it…
Sweet dreams all
Melissa
