Kernel 5.8 working with window managers but not with desktop environments!
with manjaro 20.1.1 gnome i can use kernel 5.8.11…but sometimes it gets stuck during startup, with only motherboard logo…i can’t even install Manjaro 20.1.1 with kernel 5.8 iso (have to use kernel 5.4 iso)…but with the Openbox edition there is no such problem…i can even install directly from the iso(Manjaro openbox 20.1 unstable with kernel 5.8.13 and manjaro openbox 20.0 kernel 5.6)…
so the problem is something with DEs? I thought this was a Manjaro kernel issue ( as i can use arch with latest kernels just fine)…
I don’t know, but in my opinion most likely this is GPU or DE issue. Or something with your configuration. You should provide more info.
  Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
  root=UUID=f8abd287-5794-4ddc-8913-586d2acbd906 rw quiet udev.log_priority=3
  Desktop: Xfce info: polybar, tint2 wm: Openbox 3.6.1 dm: LXDM
  Distro: Manjaro Linux
  Type: Desktop Mobo: Intel model: DH61HO v: AAG62445-102 serial: <filter>
  UEFI: Intel v: HOH6110H.86A.0816.2018.1031.1524 date: 10/31/2018
  Topology: Quad Core model: Intel Core i7-3770S bits: 64 type: MT MCP
  arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
  L2 cache: 8192 KiB
  flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 49509
  Speed: 1700 MHz min/max: 1600/3900 MHz Core speeds (MHz): 1: 2801 2: 2460
  3: 2509 4: 3243 5: 3272 6: 2082 7: 2131 8: 2830
  Type: l1tf
  Type: srbds status: Vulnerable: No microcode
  Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: ZOTAC driver: nvidia
  v: 450.66 alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1c82
  Display: x11 server: X.Org 1.20.9 compositor: picom v: git-2c9e7
  driver: nvidia display ID: :0 screens: 1
  Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.7x9.4")
  s-diag: 485mm (19.1")
  Monitor-1: DVI-D-0 res: 1600x900 hz: 60 dpi: 92 size: 443x249mm (17.4x9.8")
  diag: 508mm (20")
  driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1c20
  Device-2: NVIDIA GP107GL High Definition Audio vendor: ZOTAC
  driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0fb9
  Sound Server: ALSA v: k5.8.11-1-MANJARO
  Message: No Device data found.
  Device-1: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: USB
  driver: r8188eu bus ID: 1-1.1:3 chip ID: 0bda:8179 serial: <filter>
  IF: wlp0s26u1u1 state: down mac: <filter>
  Device-2: TP-Link UE300 10/100/1000 LAN (ethernet mode) [Realtek RTL8153]
  type: USB driver: r8152 bus ID: 4-3:2 chip ID: 2357:0601 serial: <filter>
  IF: enp3s0u3 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 1.82 TiB used: 7.04 GiB (0.4%)
  ID-1: /dev/sda vendor: Seagate model: ST500DM002-1BD142 size: 465.76 GiB
  block size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
  rotation: 7200 rpm serial: <filter> rev: KC45 scheme: GPT
  ID-2: /dev/sdb vendor: Crucial model: CT500MX500SSD1 size: 465.76 GiB
  block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s serial: <filter>
  rev: 023 scheme: GPT
  ID-3: /dev/sdc type: USB vendor: Seagate model: BUP Slim BK size: 931.51 GiB
  block size: physical: 4096 B logical: 512 B serial: <filter> rev: 0304
  scheme: MBR
  ID-1: / raw size: 70.00 GiB size: 68.40 GiB (97.71%) used: 7.01 GiB (10.3%)
  fs: ext4 dev: /dev/sdb5
  System Temperatures: cpu: 49.0 C mobo: N/A gpu: nvidia temp: 36 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 49%
  Processes: 226 Uptime: 3m Memory: 15.60 GiB used: 813.6 MiB (5.1%)
  Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 774 lib: 165
  Shell: Zsh v: 5.8 running in: termite inxi: 3.1.05
Hi!
I think latte-dock is made for KDE plasma and you’re using Openbox, check if you have installed all dependencies, even that I don’t know if it would work without kwin as compositor
ah! my eyes :sweat_smile:
please edit your message, select your block of text and click the </> button to make your text readable.
LIKE
THIS
One critical info you forgot to mention is:
Are you booting in UEFI-SecureBoot mode or plain BIOS mode?
If you are booting in UEFI-SecureBoot mode it could be due to drivers not initializing properly because they get rejected…
To others:
Does Manjaro use SecureBoot at all yet?
No secure boot, IIRC Manjaro needs to have Microsoft sign something something.
edit: Is it possible to enable Secure Boot? - #4 by eugen-b
PS: maybe try the search function sometimes, it took two keywords to find the thread I link: “secure boot” :stuck_out_tongue_winking_eye:
Ahh yes ok…
BTW the info the last replier posted in that link is not actually correct:
Since everything is installed by a package manager from a trusted source (packages are signed and have checksums like secure boot does), malicious code is not a problem…
SB does prevent external drivers from being loaded by the Linux-kernel, those drivers could be injected on the users system outside of the package manager :wink:
Anyhow that’s off-topic in this case because Arch/Manjaro doesn’t use it yet…
[offtopic]
Even if, you have to run modprobe as root or at least with sudo. Then the module have to be recompiled for every new kernel. Also we have AppArmor and SELinux. That also remembers me btw on that silly document: https://media.defense.gov/2020/Aug/13/2002476465/-1/-1/0/CSA_DROVORUB_RUSSIAN_GRU_MALWARE_AUG_2020.PDF
Quote:
If the Drovorub-client is unable to communicate with the Drovorub-kernel module, it will stop execution.
System administrators should update to Linux Kernel 3.7 or later
SB is not useless, but not necessary, if you think before doing.
:joy: :rofl: :crazy_face:
[/offtopic]
Uefi mode…secure boot is disabled
I can recreate the problem just by installing gdm, gnome
Removed gdm and gnome… problem disappeared
If I remember right this is actually an issue involving the NVIDIA drivers, GNOME/gdm and kernel 5.8. You could try recreating the issue with the Noveau driver instead. If it doesn’t happen you’ll at least know exactly where the glitch is located. If it is the driver you may need to use Noveau until either NVIDIA updates the driver or a patch gets worked out by GNOME.
I also noticed the issue with kde plasma
I tried installing kernel 5.8 on my friend’s laptop with 6th Gen Intel core i5 and Amd GPU…same issue there
On a post earlier today someone reported gdm wasn’t starting but after switching to LTS kernel the problem is now solved(i7 7700hq)
I was blaming my old machine (i7 3770) for this kernel issue…but now it seems, it’s not only me having the issue but also many others…
Do you get any output or failures listed from grub in verbose mode or does it freeze immediately?
Also, you can look at the logs from previous boots with journalctl. If it’s been a few boots since the issue happened you can run `journalctl -b 2’ or replace 2 with however many boots ago the issue happened.
I’ll give it a try
-- Logs begin at Wed 2020-10-14 11:06:14 IST, end at Wed 2020-10-14 16:36:12 IST. --
Oct 14 15:44:30 King kernel: microcode: microcode updated early to revision 0x21, date = 2019-02-13
Oct 14 15:44:30 King kernel: Linux version 5.8.11-1-MANJARO (builder@4970a884831b) (gcc (GCC) 10.2.0, GNU >
Oct 14 15:44:30 King kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=62b61989-cf8d-4bd>
Oct 14 15:44:30 King kernel: KERNEL supported cpus:
Oct 14 15:44:30 King kernel:   Intel GenuineIntel
Oct 14 15:44:30 King kernel:   AMD AuthenticAMD
Oct 14 15:44:30 King kernel:   Hygon HygonGenuine
Oct 14 15:44:30 King kernel:   Centaur CentaurHauls
Oct 14 15:44:30 King kernel:   zhaoxin   Shanghai
Oct 14 15:44:30 King kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Oct 14 15:44:30 King kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Oct 14 15:44:30 King kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Oct 14 15:44:30 King kernel: x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
Oct 14 15:44:30 King kernel: x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'stand>
Oct 14 15:44:30 King kernel: BIOS-provided physical RAM map:
Oct 14 15:44:30 King kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009dfff] usable
Oct 14 15:44:30 King kernel: BIOS-e820: [mem 0x000000000009e000-0x000000000009ffff] reserved
Oct 14 15:44:30 King kernel: BIOS-e820: [mem 0x0000000000100000-0x00000000de2adfff] usable
Oct 14 15:44:30 King kernel: BIOS-e820: [mem 0x00000000de2ae000-0x00000000de755fff] reserved
Oct 14 15:44:30 King kernel: BIOS-e820: [mem 0x00000000de756000-0x00000000de765fff] ACPI data
Oct 14 15:44:30 King kernel: BIOS-e820: [mem 0x00000000de766000-0x00000000de874fff] ACPI NVS
Oct 14 15:44:30 King kernel: BIOS-e820: [mem 0x00000000de875000-0x00000000dee48fff] reserved
Oct 14 15:44:30 King kernel: BIOS-e820: [mem 0x00000000dee49000-0x00000000deee9fff] type 20
Oct 14 15:44:30 King kernel: BIOS-e820: [mem 0x00000000deeea000-0x00000000deeeafff] usable
Oct 14 15:44:30 King kernel: BIOS-e820: [mem 0x00000000deeeb000-0x00000000def2dfff] ACPI NVS
Oct 14 15:44:30 King kernel: BIOS-e820: [mem 0x00000000def2e000-0x00000000df7fffff] usable
Oct 14 15:44:30 King kernel: BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
Oct 14 15:44:30 King kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
Oct 14 15:44:30 King kernel: BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
[    0.000000] efi: ACPI=0xde75a000 ACPI 2.0=0xde75a000 SMBIOS=0xdee47518
[    0.000000] SMBIOS 2.7 present.
[    0.000000] DMI:  /DH61HO, BIOS HOH6110H.86A.0816.2018.1031.1524 10/31/2018
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] tsc: Detected 3092.889 MHz processor
[    0.000590] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000591] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000597] last_pfn = 0x41f000 max_arch_pfn = 0x400000000
[    0.000601] MTRR default type: uncachable
[    0.000601] MTRR fixed ranges enabled:
[    0.000602]   00000-9FFFF write-back
[    0.000603]   A0000-EFFFF uncachable
[    0.000604]   F0000-FFFFF write-protect
[    0.000604] MTRR variable ranges enabled:
[    0.000606]   0 base 000000000 mask C00000000 write-back
[    0.000606]   1 base 400000000 mask FF0000000 write-back
[    0.000607]   2 base 410000000 mask FF8000000 write-back
[    0.000608]   3 base 418000000 mask FFC000000 write-back
[    0.000608]   4 base 41C000000 mask FFE000000 write-back
[    0.000609]   5 base 41E000000 mask FFF000000 write-back
[    0.000610]   6 base 0E0000000 mask FE0000000 uncachable
[    0.000610]   7 disabled
[    0.000611]   8 disabled
[    0.000611]   9 disabled
[    0.000994] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.001189] total RAM covered: 16368M
[    0.001787] Found optimal setting for mtrr clean up
[    0.001788]  gran_size: 64K  chunk_size: 32M         num_reg: 7      lose cover RAM: 0G
[    0.002123] e820: update [mem 0xe0000000-0xffffffff] usable ==> reserved
[    0.002126] last_pfn = 0xdf800 max_arch_pfn = 0x400000000
[    0.011444] check: Scanning 1 areas for low memory corruption
[    0.012025] Secure boot could not be determined
[    0.012026] RAMDISK: [mem 0x36759000-0x373a3fff]
[    0.012032] ACPI: Early table checksum verification disabled
[    0.012035] ACPI: RSDP 0x00000000DE75A000 000024 (v02 INTEL )
[    0.012038] ACPI: XSDT 0x00000000DE75A078 000074 (v01 INTEL  DH61HO   00000330 AMI  00010013)
[    0.012043] ACPI: FACP 0x00000000DE763AF0 00010C (v05 INTEL  DH61HO   00000330 AMI  00010013)
[    0.012048] ACPI: DSDT 0x00000000DE75A180 009970 (v02 INTEL  DH61HO   00000330 INTL 20051117)
[    0.012051] ACPI: FACS 0x00000000DE873080 000040
[    0.012053] ACPI: APIC 0x00000000DE763C00 000092 (v03 INTEL  DH61HO   00000330 AMI  00010013)
[    0.012055] ACPI: FPDT 0x00000000DE763C98 000044 (v01 INTEL  DH61HO   00000330 AMI  00010013)
[    0.012058] ACPI: MCFG 0x00000000DE763CE0 00003C (v01 INTEL  DH61HO   00000330 MSFT 00000097)
[    0.012060] ACPI: HPET 0x00000000DE763D20 000038 (v01 INTEL  DH61HO   00000330 AMI. 00000005)
[    0.012062] ACPI: SSDT 0x00000000DE763D58 00036D (v01 INTEL  DH61HO   00000330 INTL 20091112)
[    0.012065] ACPI: SSDT 0x00000000DE7640C8 0009AA (v01 INTEL  DH61HO   00000330 INTL 20051117)
[    0.012067] ACPI: SSDT 0x00000000DE764A78 000A92 (v01 INTEL  DH61HO   00000330 INTL 20051117)
[    0.012069] ACPI: DMAR 0x00000000DE765510 000078 (v01 INTEL  DH61HO   00000330 INTL 00000001)
[    0.012072] ACPI: BGRT 0x00000000DE765588 000038 (v00 INTEL  DH61HO   00000330 AMI  00010013)
[    0.012078] ACPI: Local APIC address 0xfee00000
[    0.012117] No NUMA configuration found
[    0.012118] Faking a node at [mem 0x0000000000000000-0x000000041effffff]
[    0.012121] NODE_DATA(0) allocated [mem 0x41eff1000-0x41eff4fff]
[    0.012153] Zone ranges:
[    0.012154]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.012155]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.012156]   Normal   [mem 0x0000000100000000-0x000000041effffff]
[    0.012157]   Device   empty
[    0.012157] Movable zone start for each node
[    0.012158] Early memory node ranges
[    0.012158]   node   0: [mem 0x0000000000001000-0x000000000009dfff]
[    0.012159]   node   0: [mem 0x0000000000100000-0x00000000de2adfff]
[    0.012160]   node   0: [mem 0x00000000deeea000-0x00000000deeeafff]
[    0.012161]   node   0: [mem 0x00000000def2e000-0x00000000df7fffff]
[    0.012161]   node   0: [mem 0x0000000100000000-0x000000041effffff]
[    0.012245] Zeroed struct page in unavailable ranges: 9442 pages
[    0.012245] Initmem setup node 0 [mem 0x0000000000001000-0x000000041effffff]
[    0.012247] On node 0 totalpages: 4184862
[    0.012247]   DMA zone: 64 pages used for memmap
[    0.012248]   DMA zone: 24 pages reserved
[    0.012249]   DMA zone: 3997 pages, LIFO batch:0
[    0.012270]   DMA32 zone: 14191 pages used for memmap
[    0.012271]   DMA32 zone: 908161 pages, LIFO batch:63
[    0.018747]   Normal zone: 51136 pages used for memmap
[    0.018749]   Normal zone: 3272704 pages, LIFO batch:63
[    0.043173] ACPI: PM-Timer IO Port: 0x408
[    0.043177] ACPI: Local APIC address 0xfee00000
[    0.043183] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[    0.043194] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[    0.043196] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.043197] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.043199] ACPI: IRQ0 used by override.
[    0.043199] ACPI: IRQ9 used by override.
[    0.043201] Using ACPI (MADT) for SMP configuration information
[    0.043202] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[    0.043213] e820: update [mem 0xdbd3b000-0xdbd96fff] usable ==> reserved
[    0.043220] TSC deadline timer available
[    0.043221] smpboot: Allowing 8 CPUs, 0 hotplug CPUs
[    0.043239] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.043240] PM: hibernation: Registered nosave memory: [mem 0x0009e000-0x0009ffff]
[    0.043241] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[    0.043242] PM: hibernation: Registered nosave memory: [mem 0xdbd3b000-0xdbd96fff]
[    0.043243] PM: hibernation: Registered nosave memory: [mem 0xde2ae000-0xde755fff]
[    0.043244] PM: hibernation: Registered nosave memory: [mem 0xde756000-0xde765fff]
[    0.043244] PM: hibernation: Registered nosave memory: [mem 0xde766000-0xde874fff]
[    0.043245] PM: hibernation: Registered nosave memory: [mem 0xde875000-0xdee48fff]
[    0.043245] PM: hibernation: Registered nosave memory: [mem 0xdee49000-0xdeee9fff]
[    0.043247] PM: hibernation: Registered nosave memory: [mem 0xdeeeb000-0xdef2dfff]
[    0.043248] PM: hibernation: Registered nosave memory: [mem 0xdf800000-0xf7ffffff]
[    0.043248] PM: hibernation: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
[    0.043249] PM: hibernation: Registered nosave memory: [mem 0xfc000000-0xfebfffff]
[    0.043249] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[    0.043250] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[    0.043250] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
[    0.043251] PM: hibernation: Registered nosave memory: [mem 0xfed04000-0xfed1bfff]
[    0.043251] PM: hibernation: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
[    0.043252] PM: hibernation: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
[    0.043252] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.043253] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[    0.043253] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[    0.043255] [mem 0xdf800000-0xf7ffffff] available for PCI devices
[    0.043256] Booting paravirtualized kernel on bare hardware
[    0.043259] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 63704527
78343963 ns
[    0.047578] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:8 nr_node_ids:1
[    0.047775] percpu: Embedded 56 pages/cpu s192512 r8192 d28672 u262144
[    0.047781] pcpu-alloc: s192512 r8192 d28672 u262144 alloc=1*2097152
[    0.047782] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
[    0.047801] Built 1 zonelists, mobility grouping on.  Total pages: 4119447
[    0.047802] Policy zone: Normal
[    0.047803] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=62b61989-cf8d-4bde-bbd7-b
be48591abe4 rw quiet udev.log_priority=3
[    0.048658] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.049067] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.049151] mem auto-init: stack:byref_all, heap alloc:on, heap free:off
[    0.093993] Memory: 16293504K/16739448K available (14339K kernel code, 1504K rwdata, 4684K rodata, 1644K
init, 2976K bss, 445944K reserved, 0K cma-reserved)
[    0.093999] random: get_random_u64 called from __kmem_cache_create+0x3e/0x600 with crng_init=0
[    0.094111] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.094122] Kernel/User page tables isolation: enabled
[    0.094137] ftrace: allocating 40307 entries in 158 pages
[    0.107213] ftrace: allocated 158 pages with 5 groups
[    0.107308] rcu: Preemptible hierarchical RCU implementation.
[    0.107309] rcu:     RCU dyntick-idle grace-period acceleration is enabled.
[    0.107310] rcu:     RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=8.
[    0.107310] rcu:     RCU priority boosting: priority 1 delay 500 ms.
[    0.107311]  Trampoline variant of Tasks RCU enabled.
[    0.107312]  Rude variant of Tasks RCU enabled.
[    0.107312] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[    0.107313] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[    0.110245] NR_IRQS: 20736, nr_irqs: 488, preallocated irqs: 16
[    0.110483] Console: colour dummy device 80x25
[    0.110486] printk: console [tty0] enabled
[    0.110500] ACPI: Core revision 20200528
[    0.110580] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[    0.110592] APIC: Switch to symmetric I/O mode setup
[    0.110593] DMAR: Host address width 36
[    0.110594] DMAR: DRHD base: 0x000000fed90000 flags: 0x1
[    0.110598] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap c9008020660262 ecap f0105a
[    0.110599] DMAR: RMRR base: 0x000000de6c9000 end: 0x000000de6e8fff
[    0.110601] DMAR-IR: IOAPIC id 2 under DRHD base  0xfed90000 IOMMU 0
[    0.110602] DMAR-IR: HPET id 0 under DRHD base 0xfed90000
[    0.110602] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[    0.110834] DMAR-IR: Enabled IRQ remapping in x2apic mode
[    0.110835] x2apic enabled
[    0.110840] Switched APIC routing to cluster x2apic.
[    0.111275] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.127261] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2c950a35ecb, max_idle_ns: 440
795248189 ns
[    0.127264] Calibrating delay loop (skipped), value calculated using timer frequency.. 6188.51 BogoMIPS
(lpj=10309630)
[    0.127266] pid_max: default: 32768 minimum: 301
[    0.129481] LSM: Security Framework initializing
[    0.129485] Yama: becoming mindful.
[    0.129523] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.129736] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.129960] mce: CPU0: Thermal monitoring enabled (TM1)
[    0.129969] process: using mwait in idle threads
[    0.129971] Last level iTLB entries: 4KB 512, 2MB 8, 4MB 8
[    0.129972] Last level dTLB entries: 4KB 512, 2MB 32, 4MB 32, 1GB 0
[    0.129974] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.129975] Spectre V2 : Mitigation: Full generic retpoline
[    0.129976] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.129976] Spectre V2 : Enabling Restricted Speculation for firmware calls
[    0.129977] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.129978] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[    0.129979] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccom
p
[    0.129981] SRBDS: Vulnerable: No microcode
[    0.129982] MDS: Mitigation: Clear CPU buffers
[    0.130167] Freeing SMP alternatives memory: 32K
[    0.133739] smpboot: CPU0: Intel(R) Core(TM) i7-3770S CPU @ 3.10GHz (family: 0x6, model: 0x3a, stepping:
0x9)
[    0.133830] Performance Events: PEBS fmt1+, IvyBridge events, 16-deep LBR, full-width counters, Intel PM
U driver.
[    0.133835] ... version:                3
[    0.133836] ... bit width:              48
[    0.133836] ... generic registers:      4
[    0.133837] ... value mask:             0000ffffffffffff
[    0.133837] ... max period:             00007fffffffffff
[    0.133838] ... fixed-purpose events:   3
[    0.133838] ... event mask:             000000070000000f
[    0.133872] rcu: Hierarchical SRCU implementation.
[    0.133929] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.133929] smp: Bringing up secondary CPUs ...
[    0.133929] x86: Booting SMP configuration:
[    0.133929] .... node  #0, CPUs:      #1 #2 #3 #4
[    0.142897] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/late
st/admin-guide/hw-vuln/mds.html for more details.
[    0.142897]  #5 #6 #7
[    0.147320] smp: Brought up 1 node, 8 CPUs
[    0.147320] smpboot: Max logical packages: 1
[    0.147320] smpboot: Total of 8 processors activated (49506.15 BogoMIPS)
[    0.149616] devtmpfs: initialized
[    0.149616] x86/mm: Memory block size: 128MB
[    0.151316] PM: Registering ACPI NVS region [mem 0xde766000-0xde874fff] (1110016 bytes)
[    0.151316] PM: Registering ACPI NVS region [mem 0xdeeeb000-0xdef2dfff] (274432 bytes)
[    0.151316] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994
ns
[    0.151316] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.151316] pinctrl core: initialized pinctrl subsystem
[    0.151316] PM: RTC time: 06:12:40, date: 2020-10-14
[    0.151316] thermal_sys: Registered thermal governor 'fair_share'
[    0.151316] thermal_sys: Registered thermal governor 'bang_bang'
[    0.151316] thermal_sys: Registered thermal governor 'step_wise'
[    0.151316] thermal_sys: Registered thermal governor 'user_space'
[    0.151316] thermal_sys: Registered thermal governor 'power_allocator'
[    0.151316] NET: Registered protocol family 16
[    0.151316] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.151316] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.151316] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.151316] audit: initializing netlink subsys (disabled)
[    0.151316] audit: type=2000 audit(1602655960.039:1): state=initialized audit_enabled=0 res=1
[    0.151316] cpuidle: using governor ladder
[    0.151316] cpuidle: using governor menu
[    0.151316] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.151316] ACPI: bus type PCI registered
[    0.151316] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.151316] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[    0.151316] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[    0.151316] PCI: Using configuration type 1 for base access
[    0.151316] core: PMU erratum BJ122, BV98, HSD29 worked around, HT is on
[    0.151316] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.153958] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.154030] ACPI: Added _OSI(Module Device)
[    0.154031] ACPI: Added _OSI(Processor Device)
[    0.154031] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.154032] ACPI: Added _OSI(Processor Aggregator Device)
[    0.154033] ACPI: Added _OSI(Linux-Dell-Video)
[    0.154034] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.154035] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    0.160644] ACPI: 4 ACPI AML tables successfully acquired and loaded
[    0.161722] ACPI: Dynamic OEM Table Load:
[    0.161722] ACPI: SSDT 0xFFFF9500CCA2E000 00083B (v01 PmRef  Cpu0Cst  00003001 INTL 20051117)
[    0.161722] ACPI: SSDT 0xFFFF9500CC6B6C00 000303 (v01 PmRef  ApIst    00003000 INTL 20051117)
[    0.162054] ACPI: Dynamic OEM Table Load:
[    0.162056] ACPI: SSDT 0xFFFF9500CC271E00 000119 (v01 PmRef  ApCst    00003000 INTL 20051117)
[    0.164743] ACPI: Interpreter enabled
[    0.164762] ACPI: (supports S0 S3 S4 S5)
[    0.164763] ACPI: Using IOAPIC for interrupt routing
[    0.164788] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.165213] ACPI: Enabled 15 GPEs in block 00 to 3F
[    0.173808] ACPI: Power Resource [FN00] (off)
[    0.173892] ACPI: Power Resource [FN01] (off)
[    0.173981] ACPI: Power Resource [FN02] (off)
[    0.174062] ACPI: Power Resource [FN03] (off)
[    0.174143] ACPI: Power Resource [FN04] (off)
[    0.174849] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[    0.174854] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[    0.175159] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME]
[    0.175351] acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability LTR DPC]
[    0.175352] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    0.175850] PCI host bridge to bus 0000:00
[    0.175852] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.175853] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.175854] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.175855] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000c3fff window]
[    0.175856] pci_bus 0000:00: root bus resource [mem 0x000c4000-0x000c7fff window]
[    0.175856] pci_bus 0000:00: root bus resource [mem 0x000c8000-0x000cbfff window]
[    0.175857] pci_bus 0000:00: root bus resource [mem 0x000cc000-0x000cffff window]
[    0.175858] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
[    0.175859] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[    0.175860] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[    0.175861] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[    0.175861] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
[    0.175862] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
[    0.175863] pci_bus 0000:00: root bus resource [mem 0x000e8000-0x000ebfff window]
[    0.175864] pci_bus 0000:00: root bus resource [mem 0x000ec000-0x000effff window]
[    0.175865] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xfeafffff window]
[    0.175866] pci_bus 0000:00: root bus resource [bus 00-3e]
[    0.175874] pci 0000:00:00.0: [8086:0150] type 00 class 0x060000
[    0.175976] pci 0000:00:01.0: [8086:0151] type 01 class 0x060400
[    0.176012] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    0.176149] pci 0000:00:16.0: [8086:1c3a] type 00 class 0x078000
[    0.176174] pci 0000:00:16.0: reg 0x10: [mem 0xf720a000-0xf720a00f 64bit]
[    0.176247] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[    0.176345] pci 0000:00:1a.0: [8086:1c2d] type 00 class 0x0c0320
[    0.176367] pci 0000:00:1a.0: reg 0x10: [mem 0xf7208000-0xf72083ff]
[    0.176450] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[    0.176553] pci 0000:00:1b.0: [8086:1c20] type 00 class 0x040300
[    0.176575] pci 0000:00:1b.0: reg 0x10: [mem 0xf7200000-0xf7203fff 64bit]
[    0.176652] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    0.176757] pci 0000:00:1c.0: [8086:1c10] type 01 class 0x060400
[    0.176852] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.176972] pci 0000:00:1c.4: [8086:1c18] type 01 class 0x060400
[    0.177066] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[    0.177189] pci 0000:00:1d.0: [8086:1c26] type 00 class 0x0c0320
[    0.177211] pci 0000:00:1d.0: reg 0x10: [mem 0xf7207000-0xf72073ff]
[    0.177296] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.177401] pci 0000:00:1f.0: [8086:1c5c] type 00 class 0x060100
[    0.177598] pci 0000:00:1f.2: [8086:1c02] type 00 class 0x010601
[    0.177616] pci 0000:00:1f.2: reg 0x10: [io  0xf070-0xf077]
[    0.177623] pci 0000:00:1f.2: reg 0x14: [io  0xf060-0xf063]
[    0.177630] pci 0000:00:1f.2: reg 0x18: [io  0xf050-0xf057]
[    0.177638] pci 0000:00:1f.2: reg 0x1c: [io  0xf040-0xf043]
[    0.177645] pci 0000:00:1f.2: reg 0x20: [io  0xf020-0xf03f]
[    0.177653] pci 0000:00:1f.2: reg 0x24: [mem 0xf7206000-0xf72067ff]
[    0.177694] pci 0000:00:1f.2: PME# supported from D3hot
[    0.177791] pci 0000:00:1f.3: [8086:1c22] type 00 class 0x0c0500
[    0.177810] pci 0000:00:1f.3: reg 0x10: [mem 0xf7205000-0xf72050ff 64bit]
[    0.177830] pci 0000:00:1f.3: reg 0x20: [io  0xf000-0xf01f]
[    0.177973] pci 0000:01:00.0: [10de:1c82] type 00 class 0x030000
[    0.177990] pci 0000:01:00.0: reg 0x10: [mem 0xf6000000-0xf6ffffff]
[    0.177999] pci 0000:01:00.0: reg 0x14: [mem 0xe0000000-0xefffffff 64bit pref]
[    0.178008] pci 0000:01:00.0: reg 0x1c: [mem 0xf0000000-0xf1ffffff 64bit pref]
[    0.178014] pci 0000:01:00.0: reg 0x24: [io  0xe000-0xe07f]
[    0.178021] pci 0000:01:00.0: reg 0x30: [mem 0xf7000000-0xf707ffff pref]
[    0.178026] pci 0000:01:00.0: enabling Extended Tags
[    0.178038] pci 0000:01:00.0: BAR 1: assigned to efifb
[    0.178102] pci 0000:01:00.0: 32.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x16 link at
0000:00:01.0 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
[    0.178139] pci 0000:01:00.1: [10de:0fb9] type 00 class 0x040300
[    0.178152] pci 0000:01:00.1: reg 0x10: [mem 0xf7080000-0xf7083fff]
[    0.178177] pci 0000:01:00.1: enabling Extended Tags
[    0.178270] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.178272] pci 0000:00:01.0:   bridge window [io  0xe000-0xefff]
[    0.178274] pci 0000:00:01.0:   bridge window [mem 0xf6000000-0xf70fffff]
[    0.178276] pci 0000:00:01.0:   bridge window [mem 0xe0000000-0xf1ffffff 64bit pref]
[    0.178324] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    0.178397] pci 0000:03:00.0: [1106:3483] type 00 class 0x0c0330
[    0.178431] pci 0000:03:00.0: reg 0x10: [mem 0xf7100000-0xf7100fff 64bit]
[    0.178562] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.178670] pci 0000:00:1c.4: PCI bridge to [bus 03]
[    0.178676] pci 0000:00:1c.4:   bridge window [mem 0xf7100000-0xf71fffff]
[    0.179319] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.179386] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 11 12 14 15) *0, disabled.
[    0.179451] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.179515] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.179580] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.179645] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.179712] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.179777] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.180681] iommu: Default domain type: Translated
[    0.180693] pci 0000:01:00.0: vgaarb: setting as boot VGA device
[    0.180693] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.180693] pci 0000:01:00.0: vgaarb: bridge control possible
[    0.180693] vgaarb: loaded
[    0.180764] SCSI subsystem initialized
[    0.180777] libata version 3.00 loaded.
[    0.180777] ACPI: bus type USB registered
[    0.180777] usbcore: registered new interface driver usbfs
[    0.180777] usbcore: registered new interface driver hub
[    0.180777] usbcore: registered new device driver usb
[    0.180777] pps_core: LinuxPPS API ver. 1 registered
[    0.180777] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.180777] PTP clock support registered
[    0.180777] EDAC MC: Ver: 3.0.0
[    0.180777] Registered efivars operations
[    0.180777] NetLabel: Initializing
[    0.180777] NetLabel:  domain hash size = 128
[    0.180777] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.180777] NetLabel:  unlabeled traffic allowed by default
[    0.180777] PCI: Using ACPI for IRQ routing
[    0.182212] PCI: pci_cache_line_size set to 64 bytes
[    0.182251] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
[    0.182252] e820: reserve RAM buffer [mem 0xdbd3b000-0xdbffffff]
[    0.182253] e820: reserve RAM buffer [mem 0xde2ae000-0xdfffffff]
[    0.182254] e820: reserve RAM buffer [mem 0xdeeeb000-0xdfffffff]
[    0.182255] e820: reserve RAM buffer [mem 0xdf800000-0xdfffffff]
[    0.182256] e820: reserve RAM buffer [mem 0x41f000000-0x41fffffff]
[    0.184644] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    0.184647] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[    0.188308] clocksource: Switched to clocksource tsc-early
[    0.198260] VFS: Disk quotas dquot_6.6.0
[    0.198275] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.198339] pnp: PnP ACPI init
[    0.198464] system 00:00: [mem 0xfed40000-0xfed44fff] has been reserved
[    0.198469] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.198549] system 00:01: [io  0x0680-0x069f] has been reserved
[    0.198550] system 00:01: [io  0x1000-0x100f] has been reserved
[    0.198551] system 00:01: [io  0xffff] has been reserved
[    0.198552] system 00:01: [io  0xffff] has been reserved
[    0.198553] system 00:01: [io  0x0400-0x0453] has been reserved
[    0.198554] system 00:01: [io  0x0458-0x047f] has been reserved
[    0.198555] system 00:01: [io  0x0500-0x057f] has been reserved
[    0.198556] system 00:01: [io  0x164e-0x164f] has been reserved
[    0.198560] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.198582] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.198631] system 00:03: [io  0x0454-0x0457] has been reserved
[    0.198634] system 00:03: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[    0.198791] system 00:04: [io  0x0a10-0x0a2f] has been reserved
[    0.198792] system 00:04: [io  0x0a30-0x0a3f] has been reserved
[    0.198793] system 00:04: [io  0x0a20-0x0a2f] has been reserved
[    0.198796] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.198986] pnp 00:05: [dma 0 disabled]
[    0.199029] pnp 00:05: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.199225] system 00:06: [io  0x04d0-0x04d1] has been reserved
[    0.199228] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.199486] system 00:07: [mem 0xfed1c000-0xfed1ffff] has been reserved
[    0.199487] system 00:07: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.199488] system 00:07: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.199489] system 00:07: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.199490] system 00:07: [mem 0xf8000000-0xfbffffff] has been reserved
[    0.199491] system 00:07: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.199493] system 00:07: [mem 0xfed90000-0xfed93fff] could not be reserved
[    0.199494] system 00:07: [mem 0xfed45000-0xfed8ffff] has been reserved
[    0.199495] system 00:07: [mem 0xff000000-0xffffffff] has been reserved
[    0.199496] system 00:07: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.199497] system 00:07: [mem 0xf2000000-0xf2000fff] has been reserved
[    0.199500] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.199650] pnp: PnP ACPI: found 8 devices
[    0.205616] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.205665] NET: Registered protocol family 2
[    0.205789] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.205858] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.206043] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.206110] TCP: Hash tables configured (established 131072 bind 65536)
[    0.206180] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.206217] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.206296] NET: Registered protocol family 1
[    0.206300] NET: Registered protocol family 44
[    0.206309] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.206311] pci 0000:00:01.0:   bridge window [io  0xe000-0xefff]
[    0.206314] pci 0000:00:01.0:   bridge window [mem 0xf6000000-0xf70fffff]
[    0.206316] pci 0000:00:01.0:   bridge window [mem 0xe0000000-0xf1ffffff 64bit pref]
[    0.206318] pci 0000:00:1c.0: PCI bridge to [bus 02]
[    0.206329] pci 0000:00:1c.4: PCI bridge to [bus 03]
[    0.206334] pci 0000:00:1c.4:   bridge window [mem 0xf7100000-0xf71fffff]
[    0.206342] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.206343] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.206344] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.206345] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000c3fff window]
[    0.206346] pci_bus 0000:00: resource 8 [mem 0x000c4000-0x000c7fff window]
[    0.206347] pci_bus 0000:00: resource 9 [mem 0x000c8000-0x000cbfff window]
[    0.206348] pci_bus 0000:00: resource 10 [mem 0x000cc000-0x000cffff window]
[    0.206349] pci_bus 0000:00: resource 11 [mem 0x000d0000-0x000d3fff window]
[    0.206350] pci_bus 0000:00: resource 12 [mem 0x000d4000-0x000d7fff window]
[    0.206351] pci_bus 0000:00: resource 13 [mem 0x000d8000-0x000dbfff window]
[    0.206352] pci_bus 0000:00: resource 14 [mem 0x000dc000-0x000dffff window]
[    0.206352] pci_bus 0000:00: resource 15 [mem 0x000e0000-0x000e3fff window]
[    0.206353] pci_bus 0000:00: resource 16 [mem 0x000e4000-0x000e7fff window]
[    0.206354] pci_bus 0000:00: resource 17 [mem 0x000e8000-0x000ebfff window]
[    0.206355] pci_bus 0000:00: resource 18 [mem 0x000ec000-0x000effff window]
[    0.206356] pci_bus 0000:00: resource 19 [mem 0xe0000000-0xfeafffff window]
[    0.206357] pci_bus 0000:01: resource 0 [io  0xe000-0xefff]
[    0.206358] pci_bus 0000:01: resource 1 [mem 0xf6000000-0xf70fffff]
[    0.206359] pci_bus 0000:01: resource 2 [mem 0xe0000000-0xf1ffffff 64bit pref]
[    0.206360] pci_bus 0000:03: resource 1 [mem 0xf7100000-0xf71fffff]
[    0.230717] pci 0000:00:1a.0: quirk_usb_early_handoff+0x0/0x6d5 took 23701 usecs
[    0.254039] pci 0000:00:1d.0: quirk_usb_early_handoff+0x0/0x6d5 took 22760 usecs
[    0.254060] pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.254071] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[    0.254263] pci 0000:03:00.0: CLS mismatch (64 != 32), using 64 bytes
[    0.254300] Trying to unpack rootfs image as initramfs...
[    0.369474] Freeing initrd memory: 12588K
[    0.390625] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.390628] software IO TLB: mapped [mem 0xd7528000-0xdb528000] (64MB)
[    0.390801] check: Scanning for low memory corruption every 60 seconds
[    0.391100] Initialise system trusted keyrings
[    0.391108] Key type blacklist registered
[    0.391151] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[    0.392106] zbud: loaded
[    0.401696] Key type asymmetric registered
[    0.401697] Asymmetric key parser 'x509' registered
[    0.401705] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.401741] io scheduler mq-deadline registered
[    0.401742] io scheduler kyber registered
[    0.401759] io scheduler bfq registered
[    0.402318] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    0.402376] efifb: probing for efifb
[    0.402394] efifb: showing boot graphics
[    0.404309] efifb: framebuffer at 0xe0000000, using 7232k, total 7232k
[    0.404310] efifb: mode is 1600x900x32, linelength=8192, pages=1
[    0.404311] efifb: scrolling: redraw
[    0.404312] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    0.404346] fbcon: Deferring console take-over
[    0.404347] fb0: EFI VGA frame buffer device
[    0.404354] intel_idle: MWAIT substates: 0x1120
[    0.404355] intel_idle: v0.5.1 model 0x3A
[    0.404596] intel_idle: Local APIC timer is reliable in all C-states
[    0.404657] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[    0.407291] ACPI: Power Button [PWRB]
[    0.407327] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[    0.407456] ACPI: Power Button [PWRF]
[    0.408283] thermal LNXTHERM:00: registered as thermal_zone0
[    0.408284] ACPI: Thermal Zone [TZ00] (28 C)
[    0.408573] thermal LNXTHERM:01: registered as thermal_zone1
[    0.408573] ACPI: Thermal Zone [TZ01] (30 C)
[    0.408727] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.408868] 00:05: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[    0.409529] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[    0.409530] AMD-Vi: AMD IOMMUv2 functionality not available on this system
[    0.410423] ahci 0000:00:1f.2: version 3.0
[    0.410586] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 4 ports 3 Gbps 0x3 impl SATA mode
[    0.410589] ahci 0000:00:1f.2: flags: 64bit ncq pm led clo pio slum part ems apst
[    0.421195] scsi host0: ahci
[    0.421512] scsi host1: ahci
[    0.421795] scsi host2: ahci
[    0.421939] scsi host3: ahci
[    0.421972] ata1: SATA max UDMA/133 abar m2048@0xf7206000 port 0xf7206100 irq 28
[    0.421975] ata2: SATA max UDMA/133 abar m2048@0xf7206000 port 0xf7206180 irq 28
[    0.421975] ata3: DUMMY
[    0.421976] ata4: DUMMY
[    0.422009] usbcore: registered new interface driver usbserial_generic
[    0.422012] usbserial: USB Serial support registered for generic
[    0.422028] rtc_cmos 00:02: RTC can wake from S4
[    0.422211] rtc_cmos 00:02: registered as rtc0
[    0.422240] rtc_cmos 00:02: setting system clock to 2020-10-14T06:12:41 UTC (1602655961)
[    0.422254] rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[    0.422297] intel_pstate: Intel P-state driver initializing
[    0.422661] ledtrig-cpu: registered to indicate activity on CPUs
[    0.422773] ashmem: initialized
[    0.422898] drop_monitor: Initializing network drop monitor service
[    0.423153] NET: Registered protocol family 10
[    0.427924] Segment Routing with IPv6
[    0.427925] RPL Segment Routing with IPv6
[    0.427949] NET: Registered protocol family 17
[    0.428575] microcode: sig=0x306a9, pf=0x2, revision=0x21
[    0.428685] microcode: Microcode Update Driver: v2.2.
[    0.428689] IPI shorthand broadcast: enabled
[    0.428705] sched_clock: Marking stable (428516644, 154636)->(437575510, -8904230)
[    0.428836] registered taskstats version 1
[    0.428843] Loading compiled-in X.509 certificates
[    0.431486] Loaded X.509 cert 'Build time autogenerated kernel key: ff68ef670fabf1756b3d6cdb3b04b014942c
1fd2'
[    0.432519] zswap: loaded using pool zstd/z3fold
[    0.432709] Key type ._fscrypt registered
[    0.432710] Key type .fscrypt registered
[    0.432711] Key type fscrypt-provisioning registered
[    0.432986] PM:   Magic number: 8:877:215
[    0.433002] event_source software: hash matches
[    0.433123] RAS: Correctable Errors collector initialized.
[    0.737310] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    0.737335] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    0.738544] ata2.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[    0.738545] ata2.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[    0.738546] ata2.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[    0.738655] ata2.00: supports DRM functions and may not be fully accessible
[    0.738710] ata2.00: ATA-10: CT500MX500SSD1, M3CR023, max UDMA/133
[    0.738711] ata2.00: 976773168 sectors, multi 1: LBA48 NCQ (depth 32), AA
[    0.738826] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[    0.738830] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[    0.738832] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[    0.739654] ata2.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[    0.739656] ata2.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[    0.739657] ata2.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[    0.739784] ata2.00: supports DRM functions and may not be fully accessible
[    0.740070] ata1.00: ATA-8: ST500DM002-1BD142, KC45, max UDMA/133
[    0.740072] ata1.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 32)
[    0.740324] ata2.00: configured for UDMA/133
[    0.741834] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[    0.741838] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[    0.741840] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[    0.743127] ata1.00: configured for UDMA/133
[    0.743312] scsi 0:0:0:0: Direct-Access     ATA      ST500DM002-1BD14 KC45 PQ: 0 ANSI: 5
[    0.743566] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/466 GiB)
[    0.743569] sd 0:0:0:0: [sda] 4096-byte physical blocks
[    0.743580] sd 0:0:0:0: [sda] Write Protect is off
[    0.743583] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    0.743593] scsi 1:0:0:0: Direct-Access     ATA      CT500MX500SSD1   023  PQ: 0 ANSI: 5
[    0.743602] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    0.743794] sd 1:0:0:0: [sdb] 976773168 512-byte logical blocks: (500 GB/466 GiB)
[    0.743802] sd 1:0:0:0: [sdb] Write Protect is off
[    0.743803] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    0.743814] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    0.744904]  sdb: sdb1 sdb2 sdb3 sdb4 sdb5
[    0.745449] sd 1:0:0:0: [sdb] supports TCG Opal
[    0.745450] sd 1:0:0:0: [sdb] Attached SCSI disk
[    0.795022]  sda: sda1
[    0.795309] sd 0:0:0:0: [sda] Attached SCSI disk
[    0.796321] Freeing unused decrypted memory: 2040K
[    0.796609] Freeing unused kernel image (initmem) memory: 1644K
[    0.837360] Write protecting the kernel read-only data: 22528k
[    0.837950] Freeing unused kernel image (text/rodata gap) memory: 2044K
[    0.838309] Freeing unused kernel image (rodata/data gap) memory: 1460K
[    0.889987] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    0.889988] x86/mm: Checking user space page tables
[    0.931783] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    0.931787] Run /init as init process
[    0.931788]   with arguments:
[    0.931788]     /init
[    0.931789]   with environment:
[    0.931789]     HOME=/
[    0.931790]     TERM=linux
[    0.931790]     BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
[    1.016491] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.017628] ehci-pci: EHCI PCI platform driver
[    1.017828] ehci-pci 0000:00:1a.0: EHCI Host Controller
[    1.017835] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[    1.017850] ehci-pci 0000:00:1a.0: debug port 2
[    1.021766] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
[    1.021790] ehci-pci 0000:00:1a.0: irq 16, io mem 0xf7208000
[    1.037277] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[    1.037331] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
[    1.037332] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.037333] usb usb1: Product: EHCI Host Controller
[    1.037334] usb usb1: Manufacturer: Linux 5.8.11-1-MANJARO ehci_hcd
[    1.037334] usb usb1: SerialNumber: 0000:00:1a.0
[    1.037456] hub 1-0:1.0: USB hub found
[    1.037462] hub 1-0:1.0: 2 ports detected
[    1.037593] xhci_hcd 0000:03:00.0: xHCI Host Controller
[    1.037598] xhci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 2
[    1.037806] xhci_hcd 0000:03:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000000000000890
[    1.037960] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
[    1.037961] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.037962] usb usb2: Product: xHCI Host Controller
[    1.037963] usb usb2: Manufacturer: Linux 5.8.11-1-MANJARO xhci-hcd
[    1.037963] usb usb2: SerialNumber: 0000:03:00.0
[    1.038059] hub 2-0:1.0: USB hub found
[    1.038065] hub 2-0:1.0: 1 port detected
[    1.038139] ehci-pci 0000:00:1d.0: EHCI Host Controller
[    1.038143] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 3
[    1.038160] ehci-pci 0000:00:1d.0: debug port 2
[    1.038172] xhci_hcd 0000:03:00.0: xHCI Host Controller
[    1.038174] xhci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 4
[    1.038176] xhci_hcd 0000:03:00.0: Host supports USB 3.0 SuperSpeed
[    1.038217] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.08
[    1.038218] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.038219] usb usb4: Product: xHCI Host Controller
[    1.038220] usb usb4: Manufacturer: Linux 5.8.11-1-MANJARO xhci-hcd
[    1.038220] usb usb4: SerialNumber: 0000:03:00.0
[    1.038301] hub 4-0:1.0: USB hub found
[    1.038313] hub 4-0:1.0: 4 ports detected
[    1.042057] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
[    1.042069] ehci-pci 0000:00:1d.0: irq 23, io mem 0xf7207000
[    1.050780] random: fast init done
[    1.057347] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[    1.057419] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
[    1.057420] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.057421] usb usb3: Product: EHCI Host Controller
[    1.057421] usb usb3: Manufacturer: Linux 5.8.11-1-MANJARO ehci_hcd
[    1.057422] usb usb3: SerialNumber: 0000:00:1d.0
[    1.057608] hub 3-0:1.0: USB hub found
[    1.057614] hub 3-0:1.0: 2 ports detected
[    1.201535] EXT4-fs (sdb5): recovery complete
[    1.202077] EXT4-fs (sdb5): mounted filesystem with ordered data mode. Opts: (null)
[    1.348315] systemd[1]: systemd 246.6-1-manjaro running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPA
RMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +K
MOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    1.360651] usb 1-1: new high-speed USB device number 2 using ehci-pci
[    1.361202] usb 4-3: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[    1.364058] systemd[1]: Detected architecture x86-64.
[    1.379897] usb 4-3: New USB device found, idVendor=2357, idProduct=0601, bcdDevice=30.00
[    1.379900] usb 4-3: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[    1.379902] usb 4-3: Product: USB 10/100/1000 LAN
[    1.379904] usb 4-3: Manufacturer: TP-LINK
[    1.379906] usb 4-3: SerialNumber: 000001000000
[    1.387303] tsc: Refined TSC clocksource calibration: 3092.974 MHz
[    1.387307] usb 3-1: new high-speed USB device number 2 using ehci-pci
[    1.387317] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2c955ac38be, max_idle_ns: 440795348
546 ns
[    1.387350] clocksource: Switched to clocksource tsc
[    1.415620] systemd[1]: Set hostname to <King>.
[    1.500618] usb 2-1: new high-speed USB device number 2 using xhci_hcd
[    1.507626] usb 1-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
[    1.507627] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.507933] hub 1-1:1.0: USB hub found
[    1.508115] hub 1-1:1.0: 4 ports detected
[    1.534391] usb 3-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
[    1.534392] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.534671] hub 3-1:1.0: USB hub found
[    1.534791] hub 3-1:1.0: 6 ports detected
[    1.538958] systemd[1]: Queued start job for default target Graphical Interface.
[    1.539712] systemd[1]: Created slice system-getty.slice.
[    1.539875] systemd[1]: Created slice system-modprobe.slice.
[    1.540033] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    1.540216] systemd[1]: Created slice User and Session Slice.
[    1.540262] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    1.540297] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    1.540425] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    1.540447] systemd[1]: Reached target Local Encrypted Volumes.
[    1.540455] systemd[1]: Reached target Login Prompts.
[    1.540470] systemd[1]: Reached target Paths.
[    1.540481] systemd[1]: Reached target Remote File Systems.
[    1.540488] systemd[1]: Reached target Slices.
[    1.540499] systemd[1]: Reached target Swap.
[    1.540551] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    1.540787] systemd[1]: Listening on LVM2 metadata daemon socket.
[    1.540957] systemd[1]: Listening on LVM2 poll daemon socket.
[    1.541922] systemd[1]: Listening on Process Core Dump Socket.
[    1.542032] systemd[1]: Listening on Journal Audit Socket.
[    1.542098] systemd[1]: Listening on Journal Socket (/dev/log).
[    1.542170] systemd[1]: Listening on Journal Socket.
[    1.542247] systemd[1]: Listening on udev Control Socket.
[    1.542304] systemd[1]: Listening on udev Kernel Socket.
[    1.542918] systemd[1]: Mounting Huge Pages File System...
[    1.543590] systemd[1]: Mounting POSIX Message Queue File System...
[    1.544369] systemd[1]: Mounting Kernel Debug File System...
[    1.545103] systemd[1]: Mounting Kernel Trace File System...
[    1.545927] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    1.546682] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress p
olling...
[    1.547406] systemd[1]: Starting Load Kernel Module drm...
[    1.548770] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    1.548808] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    1.550709] systemd[1]: Starting Journal Service...
[    1.552114] systemd[1]: Starting Load Kernel Modules...
[    1.552740] systemd[1]: Starting Remount Root and Kernel File Systems...
[    1.552791] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[    1.553419] systemd[1]: Starting Coldplug All udev Devices...
[    1.554671] systemd[1]: Mounted Huge Pages File System.
[    1.554789] systemd[1]: Mounted POSIX Message Queue File System.
[    1.554883] systemd[1]: Mounted Kernel Debug File System.
[    1.554972] systemd[1]: Mounted Kernel Trace File System.
[    1.555352] systemd[1]: Finished Create list of static device nodes for the current kernel.
[    1.555586] systemd[1]: modprobe@drm.service: Succeeded.
[    1.555851] systemd[1]: Finished Load Kernel Module drm.
[    1.560519] EXT4-fs (sdb5): re-mounted. Opts: discard
[    1.561609] systemd[1]: Finished Remount Root and Kernel File Systems.
[    1.561761] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[    1.562976] random: lvm: uninitialized urandom read (4 bytes read)
[    1.564054] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    1.565104] systemd[1]: Starting Load/Save Random Seed...
[    1.565182] systemd[1]: Condition check resulted in Create System Users being skipped.
[    1.566189] systemd[1]: Starting Create Static Device Nodes in /dev...
[    1.568788] IPMI message handler: version 39.2
[    1.571178] ipmi device interface
[    1.585876] systemd[1]: Finished Create Static Device Nodes in /dev.
[    1.587118] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[    1.617114] systemd[1]: Finished Coldplug All udev Devices.
[    1.642267] usb 2-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.20
[    1.642270] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    1.642271] usb 2-1: Product: USB2.0 Hub
[    1.643187] hub 2-1:1.0: USB hub found
[    1.643519] hub 2-1:1.0: 4 ports detected
[    1.700488] nvidia: loading out-of-tree module taints kernel.
[    1.700496] nvidia: module license 'NVIDIA' taints kernel.
[    1.700496] Disabling lock debugging due to kernel taint
[    1.706608] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[    1.719440] nvidia-nvlink: Nvlink Core is being initialized, major device number 241
[    1.719845] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[    1.764490] usb 4-4: new SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[    1.781953] usb 4-4: New USB device found, idVendor=0bc2, idProduct=ab24, bcdDevice= 1.00
[    1.781955] usb 4-4: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[    1.781957] usb 4-4: Product: BUP Slim BK
[    1.781958] usb 4-4: Manufacturer: Seagate
[    1.781960] usb 4-4: SerialNumber: NA9E8CVM
[    1.787303] usb 1-1.2: new low-speed USB device number 3 using ehci-pci
[    1.791490] systemd[1]: Started Journal Service.
[    1.791568] audit: type=1130 audit(1602655962.865:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='un
it=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    1.820129] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  440.100  Fri May 29 08:45:51 UTC 2020
[    1.833743] audit: type=1130 audit(1602655962.905:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='un
it=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=suc
cess'
[    1.841073] Linux agpgart interface v0.103
[    1.853860] audit: type=1130 audit(1602655962.925:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='un
it=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    1.854979] audit: type=1130 audit(1602655962.928:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='un
it=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    1.889091] usb 1-1.2: New USB device found, idVendor=0079, idProduct=0006, bcdDevice= 1.07
[    1.889094] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.889096] usb 1-1.2: Product: Generic   USB  Joystick
[    1.889097] usb 1-1.2: Manufacturer: DragonRise Inc.
[    1.935431] input: PC Speaker as /devices/platform/pcspkr/input/input2
[    1.935441] EDAC ie31200: No ECC support
[    1.935464] EDAC ie31200: No ECC support
[    1.935673] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0
x0000000000000400-0x000000000000047F (\PMIO) (20200528/utaddress-204)
[    1.935678] ACPI: If an ACPI driver is available for this device, you should use it instead of the nativ
e driver
[    1.935681] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0
x0000000000000500-0x0000000000000563 (\GPIO) (20200528/utaddress-204)
[    1.935684] ACPI: If an ACPI driver is available for this device, you should use it instead of the nativ
e driver
[    1.935685] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0
[    1.935688] ACPI: If an ACPI driver is available for this device, you should use it instead of the nativ
e driver
[    1.935689] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0
[    1.935692] ACPI: If an ACPI driver is available for this device, you should use it instead of the nativ
e driver
[    1.935692] lpc_ich: Resource conflict(s) found affecting gpio_ich
[    1.939146] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  440.100  Fri M
ay 29 08:14:04 UTC 2020
[    1.941289] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[    1.941292] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
[    1.944048] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[    1.944603] i2c i2c-0: 2/2 memory slots populated (from DMI)
[    1.945121] i2c i2c-0: Successfully instantiated SPD at 0x51
[    1.946100] audit: type=1130 audit(1602655963.015:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='un
it=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=succ
ess'
[    1.959599] audit: type=1130 audit(1602655963.031:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='un
it=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    1.963948] usb 1-1.3: new low-speed USB device number 4 using ehci-pci
[    1.969113] RAPL PMU: API unit is 2^-32 Joules, 2 fixed counters, 163840 ms ovfl timer
[    1.969115] RAPL PMU: hw unit of domain pp0-core 2^-16 Joules
[    1.969115] RAPL PMU: hw unit of domain package 2^-16 Joules
[    1.971290] random: mktemp: uninitialized urandom read (6 bytes read)
[    1.971435] random: mktemp: uninitialized urandom read (6 bytes read)
[    1.980183] audit: type=1130 audit(1602655963.051:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='un
it=ufw comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    2.019199] iTCO_vendor_support: vendor-support=0
[    2.022182] cryptd: max_cpu_qlen set to 1000
[    2.034391] AVX version of gcm_enc/dec engaged.
[    2.034393] AES CTR mode by8 optimization enabled
[    2.035593] at24 0-0051: supply vcc not found, using dummy regulator
[    2.036603] at24 0-0051: 256 byte spd EEPROM, read-only
[    2.073093] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c31d, bcdDevice=66.01
[    2.073096] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.073098] usb 1-1.3: Product: USB Keyboard
[    2.073099] usb 1-1.3: Manufacturer: Logitech
[    2.122517] audit: type=1130 audit(1602655963.195:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='un
it=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    2.132014] snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
[    2.132272] snd_hda_intel 0000:01:00.1: Disabling MSI
[    2.132330] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[    2.132774] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[    2.132827] iTCO_wdt: Found a Cougar Point TCO device (Version=2, TCOBASE=0x0460)
[    2.132979] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[    2.147286] usb 1-1.4: new low-speed USB device number 5 using ehci-pci
[    2.178703] audit: type=1130 audit(1602655963.251:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='u
nit=systemd-fsck@dev-disk-by\x2duuid-D03D\x2dB38C comm="systemd" exe="/usr/lib/systemd/systemd" hostname=?
[    2.248113] usb 1-1.4: New USB device found, idVendor=046d, idProduct=c05a, bcdDevice=63.00
[    2.248115] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.248116] usb 1-1.4: Product: USB Optical Mouse
[    2.248117] usb 1-1.4: Manufacturer: Logitech
[    2.264388] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1
/input3
[    2.264425] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1
/input4
[    2.264456] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1
/input5
[    2.264486] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1
/input6
[    2.264519] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card
1/input7
[    2.264551] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card
1/input8
[    2.266573] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC662 rev1: line_outs=1 (0x14/0x0/0x0/0x0
/0x0) type:line
[    2.266576] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    2.266578] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[    2.266579] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    2.266581] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    2.266583] snd_hda_codec_realtek hdaudioC0D0:      Front Mic=0x19
[    2.266584] snd_hda_codec_realtek hdaudioC0D0:      Rear Mic=0x18
[    2.266586] snd_hda_codec_realtek hdaudioC0D0:      Line=0x1a
[    2.297873] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[    2.297944] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[    2.297998] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[    2.298047] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[    2.520546] intel_rapl_common: Found RAPL domain package
[    2.520548] intel_rapl_common: Found RAPL domain core
[    3.151021] usbcore: registered new interface driver usb-storage
[    3.159013] scsi host4: uas
[    3.159132] usbcore: registered new interface driver uas
[    3.159639] scsi 4:0:0:0: Direct-Access     Seagate  BUP Slim BK      0304 PQ: 0 ANSI: 6
[    3.160678] sd 4:0:0:0: [sdc] 1953525167 512-byte logical blocks: (1.00 TB/932 GiB)
[    3.160680] sd 4:0:0:0: [sdc] 4096-byte physical blocks
[    3.160810] sd 4:0:0:0: [sdc] Write Protect is off
[    3.160812] sd 4:0:0:0: [sdc] Mode Sense: 4f 00 00 00
[    3.160999] sd 4:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    3.161798] sd 4:0:0:0: [sdc] Optimal transfer size 33553920 bytes not a multiple of physical block size
(4096 bytes)
[    3.169173] usbcore: registered new interface driver r8152
[    3.176996] usbcore: registered new interface driver cdc_ether
[    3.193938] random: crng init done
[    3.193939] random: 7 urandom warning(s) missed due to ratelimiting
[    3.200640]  sdc: sdc1
[    3.201784] sd 4:0:0:0: [sdc] Attached SCSI disk
[    3.298183] usb 4-3: reset SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[    3.361025] r8152 4-3:1.0: load rtl8153a-3 v2 02/07/20 successfully
[    3.391345] r8152 4-3:1.0 eth0: v1.11.11
[    3.396340] r8152 4-3:1.0 enp3s0u3: renamed from eth0
[    3.697362] hid: raw HID events driver (C) Jiri Kosina
[    3.714254] usbcore: registered new interface driver usbhid
[    3.714255] usbhid: USB HID core driver
[    3.721120] input: Logitech USB Keyboard as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3/1-1.3:1.0/00
03:046D:C31D.0002/input/input13
[    3.777462] hid-generic 0003:046D:C31D.0002: input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Keyboar
d] on usb-0000:00:1a.0-1.3/input0
[    3.777591] input: Logitech USB Keyboard Consumer Control as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1
-1.3/1-1.3:1.1/0003:046D:C31D.0003/input/input14
[    3.834063] input: Logitech USB Keyboard System Control as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1
.3/1-1.3:1.1/0003:046D:C31D.0003/input/input15
[    3.834172] hid-generic 0003:046D:C31D.0003: input,hidraw1: USB HID v1.10 Device [Logitech USB Keyboard]
on usb-0000:00:1a.0-1.3/input1
[    3.834260] input: Logitech USB Optical Mouse as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4:1
.0/0003:046D:C05A.0004/input/input16
[    3.834343] hid-generic 0003:046D:C05A.0004: input,hidraw2: USB HID v1.11 Mouse [Logitech USB Optical Mo
use] on usb-0000:00:1a.0-1.4/input0
[    3.839829] input: DragonRise Inc.   Generic   USB  Joystick   as /devices/pci0000:00/0000:00:1a.0/usb1/
1-1/1-1.2/1-1.2:1.0/0003:0079:0006.0001/input/input17
[    3.839910] dragonrise 0003:0079:0006.0001: input,hidraw3: USB HID v1.10 Joystick [DragonRise Inc.   Gen
eric   USB  Joystick  ] on usb-0000:00:1a.0-1.2/input0
[    3.839921] dragonrise 0003:0079:0006.0001: Force Feedback for DragonRise Inc. game controllers by Richa
rd Walmsley <richwalm@gmail.com>
[    3.841616] mousedev: PS/2 mouse device common for all mice
[    4.970662] IPv6: ADDRCONF(NETDEV_CHANGE): enp3s0u3: link becomes ready
[    4.972018] r8152 4-3:1.0 enp3s0u3: carrier on
[    5.496598] kauditd_printk_skb: 19 callbacks suppressed
[    5.496599] audit: type=1100 audit(1602655966.568:30): pid=783 uid=0 auid=4294967295 ses=4294967295 msg=
'op=PAM:authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? te
[    5.496613] audit: type=1101 audit(1602655966.568:31): pid=783 uid=0 auid=4294967295 ses=4294967295 msg=
'op=PAM:accounting grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? termin
al=? res=success'
[    5.497543] audit: type=1103 audit(1602655966.571:32): pid=783 uid=0 auid=4294967295 ses=4294967295 msg=
'op=PAM:setcred grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=
? res=success'
[    5.515937] audit: type=1130 audit(1602655966.588:33): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='u
nit=user-runtime-dir@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=suc
cess'
[    5.529891] audit: type=1101 audit(1602655966.601:34): pid=786 uid=0 auid=4294967295 ses=4294967295 msg=
'op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="sddm" exe="/usr/lib/systemd/systemd" hostn
[    5.529912] audit: type=1103 audit(1602655966.601:35): pid=786 uid=0 auid=4294967295 ses=4294967295 msg=
'op=PAM:setcred grantors=? acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=fail
ed'
[    5.529988] audit: type=1006 audit(1602655966.601:36): pid=786 uid=0 old-auid=4294967295 auid=971 tty=(n
one) old-ses=4294967295 ses=1 res=1
[    5.531531] audit: type=1105 audit(1602655966.605:37): pid=786 uid=0 auid=971 ses=1 msg='op=PAM:session_
open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam
_env acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.537288] audit: type=1334 audit(1602655966.608:38): prog-id=11 op=LOAD
[    5.537291] audit: type=1334 audit(1602655966.611:39): prog-id=11 op=UNLOAD
[   11.785604] kauditd_printk_skb: 7 callbacks suppressed
[   11.785606] audit: type=1100 audit(1602655972.858:47): pid=858 uid=0 auid=4294967295 ses=4294967295 msg=
'op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="avra" exe="/usr/lib/s
ddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[   11.787160] audit: type=1101 audit(1602655972.858:48): pid=858 uid=0 auid=4294967295 ses=4294967295 msg=
'op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="avra" exe="/usr/lib/sddm/sddm-helper" host
[   11.787655] audit: type=1103 audit(1602655972.861:49): pid=858 uid=0 auid=4294967295 ses=4294967295 msg=
'op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="avra" exe="/usr/lib/sddm/sdd
[   11.787778] audit: type=1006 audit(1602655972.861:50): pid=858 uid=0 old-auid=4294967295 auid=1000 tty=(
none) old-ses=4294967295 ses=2 res=1
[   11.806553] audit: type=1130 audit(1602655972.878:51): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='u
nit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=su
ccess'
[   11.813369] audit: type=1101 audit(1602655972.885:52): pid=860 uid=0 auid=4294967295 ses=4294967295 msg=
'op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="avra" exe="/usr/lib/systemd/systemd" hostn
[   11.813399] audit: type=1103 audit(1602655972.885:53): pid=860 uid=0 auid=4294967295 ses=4294967295 msg=
'op=PAM:setcred grantors=? acct="avra" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=fail
ed'
[   11.813460] audit: type=1006 audit(1602655972.885:54): pid=860 uid=0 old-auid=4294967295 auid=1000 tty=(
none) old-ses=4294967295 ses=3 res=1
[   11.814712] audit: type=1105 audit(1602655972.888:55): pid=860 uid=0 auid=1000 ses=3 msg='op=PAM:session
_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pa
m_env acct="avra" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   11.821428] audit: type=1334 audit(1602655972.895:56): prog-id=14 op=LOAD
[   22.189226] kauditd_printk_skb: 7 callbacks suppressed
[   22.189227] audit: type=1131 audit(1602655983.261:64): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='u
nit=user@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   22.198828] audit: type=1131 audit(1602655983.271:65): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='u
cess'
[   32.870578] audit: type=1131 audit(1602655993.941:66): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='u
nit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=succes
s'
[   32.972605] audit: type=1334 audit(1602655994.048:67): prog-id=10 op=UNLOAD
[   32.972611] audit: type=1334 audit(1602655994.048:68): prog-id=9 op=UNLOAD
[  275.656434] audit: type=1100 audit(1602656236.279:69): pid=1207 uid=1000 auid=1000 ses=2 msg='op=PAM:aut
hentication grantors=pam_faillock,pam_permit,pam_faillock acct="avra" exe="/usr/bin/sudo" hostname=? addr=?
terminal=/dev/pts/1 res=success'
[  275.658386] audit: type=1101 audit(1602656236.282:70): pid=1207 uid=1000 auid=1000 ses=2 msg='op=PAM:acc
ounting grantors=pam_permit,pam_time acct="avra" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1
res=success'
[  275.658774] audit: type=1110 audit(1602656236.282:71): pid=1207 uid=0 auid=1000 ses=2 msg='op=PAM:setcre
d grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=
[  275.661500] audit: type=1105 audit(1602656236.285:72): pid=1207 uid=0 auid=1000 ses=2 msg='op=PAM:sessio
n_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/
[  277.783490] audit: type=1106 audit(1602656238.410:73): pid=1207 uid=0 auid=1000 ses=2 msg='op=PAM:sessio
n_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=
[  277.783602] audit: type=1104 audit(1602656238.410:74): pid=1207 uid=0 auid=1000 ses=2 msg='op=PAM:setcre
[  290.990379] audit: type=1101 audit(1602656251.623:75): pid=1216 uid=1000 auid=1000 ses=2 msg='op=PAM:acc
res=success'
[  290.990563] audit: type=1110 audit(1602656251.623:76): pid=1216 uid=0 auid=1000 ses=2 msg='op=PAM:setcre
d grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? t
[  290.993096] audit: type=1105 audit(1602656251.626:77): pid=1216 uid=0 auid=1000 ses=2 msg='op=PAM:sessio
[  292.487487] audit: type=1106 audit(1602656253.120:78): pid=1216 uid=0 auid=1000 ses=2 msg='op=PAM:sessio
[  292.487600] audit: type=1104 audit(1602656253.120:79): pid=1216 uid=0 auid=1000 ses=2 msg='op=PAM:setcre
[  308.148003] audit: type=1101 audit(1602656268.785:80): pid=1239 uid=1000 auid=1000 ses=2 msg='op=PAM:acc
res=success'
[  308.148290] audit: type=1110 audit(1602656268.785:81): pid=1239 uid=0 auid=1000 ses=2 msg='op=PAM:setcre
[  308.151197] audit: type=1105 audit(1602656268.789:82): pid=1239 uid=0 auid=1000 ses=2 msg='op=PAM:sessio
[  308.165899] audit: type=1106 audit(1602656268.802:83): pid=1239 uid=0 auid=1000 ses=2 msg='op=PAM:sessio
[  308.165973] audit: type=1104 audit(1602656268.802:84): pid=1239 uid=0 auid=1000 ses=2 msg='op=PAM:setcre
[  395.181191] audit: type=1101 audit(1602656355.831:85): pid=1260 uid=1000 auid=1000 ses=2 msg='op=PAM:acc
res=success'
[  395.181384] audit: type=1110 audit(1602656355.831:86): pid=1260 uid=0 auid=1000 ses=2 msg='op=PAM:setcre
[  395.183343] audit: type=1105 audit(1602656355.831:87): pid=1260 uid=0 auid=1000 ses=2 msg='op=PAM:sessio
[  395.185031] audit: type=1106 audit(1602656355.835:88): pid=1260 uid=0 auid=1000 ses=2 msg='op=PAM:sessio
[  395.185104] audit: type=1104 audit(1602656355.835:89): pid=1260 uid=0 auid=1000 ses=2 msg='op=PAM:setcre
[  405.012262] fuse: init (API version 7.31)
[  497.674158] audit: type=1101 audit(1602656458.325:90): pid=1774 uid=1000 auid=1000 ses=2 msg='op=PAM:acc
res=success'
[  497.674345] audit: type=1110 audit(1602656458.325:91): pid=1774 uid=0 auid=1000 ses=2 msg='op=PAM:setcre
[  497.676218] audit: type=1105 audit(1602656458.325:92): pid=1774 uid=0 auid=1000 ses=2 msg='op=PAM:sessio
This is ‘dmesg’
I’m still looking into this. I’m currently trying to recreate the issue here so I can dive in a bit more.
Out of curiosity have you tried using a different dm like lightdm just to see if that temporarily solves the issue? It might at least let you get into GNOME on 5.8. Just be aware you may have to do a little configuring to make lightdm load GNOME.
not lightdm…but tried sddm and lxdm…same issue
if i use windows manager(ussing manjaro awesome) there isn’t ant of these issues…i can use any kernel without any issue…currently on 5.8.11…working fine
this problem seems to be a random one…some machines are fine…some have weird stuff going on
