Kernel 5.16 breaks 144hz option
All 5.16, 5.16rt and 5.17rc kernels combo with Mesa Amdgpu and Xorg(xfce), break the 144hz option and only the 60hz one is select-able. Just reverting to 5.15 alone fixes everything.
I have lost faith that we can keep a distro with state of the art updated software. Is LTS distros our only option after all?
Ye of little faith. A pebble in your path causes you to fall? :stuck_out_tongue:
Please post your system info as outlined here:
KERNEL 5.15
$ xrandr
Screen 0: minimum 320 x 200, current 2560 x 1440, maximum 16384 x 16384
DisplayPort-0 connected primary 2560x1440+0+0 (normal left inverted right x axis y axis) 597mm x 336mm
   `2560x1440     59.95 + 154.85*`
   1920x1200     59.88
   1920x1080     60.00    50.00    59.94
   1600x1200     60.00
   1680x1050     59.95
   1280x1024     75.02    60.02
   1440x900      59.95
   1280x800      59.81
   1152x864      75.00
   1280x720      60.00    50.00    59.94
   1024x768      75.03    60.00
   800x600       75.00    60.32
   720x576       50.00
   720x480       60.00    59.94
   640x480       75.00    60.00    59.94
   720x400       70.08
KERNEL 5.16
$ xrandr
   `2560x1440     59.95*+`
   1920x1200     59.88
   1600x1200     60.00
   1680x1050     59.95
   1440x900      59.95
   1280x800      59.81
   1152x864      75.00
   800x600       75.00    60.32
   720x576       50.00
   720x480       60.00    59.94
   720x400       70.08
Is that enough information?
Please post the output of the following as outlined in the tutorial above for providing system info:
inxi --admin --verbosity=7 --filter --width
KERNEL 5.15
$ inxi --admin --verbosity=7 --filter --width
  Kernel: 5.15.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    root=UUID=e7710bda-2918-4406-9f2b-914f8372bf23 ro quiet apparmor=1
    security=apparmor udev.log_priority=3 amdgpu.ppfeaturemask=0xffffffff
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
    vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
  Type: Desktop Mobo: ASRock model: B450 Gaming-ITX/ac
    serial: <superuser required> UEFI: American Megatrends v: P3.40
    date: 07/17/2019
  RAM: total: 7.75 GiB used: 1.77 GiB (22.9%)
  RAM Report:
  Info: model: AMD Ryzen 3 2200G with Radeon Vega Graphics bits: 64 type: MCP
    arch: Zen family: 0x17 (23) model-id: 0x11 (17) stepping: 0
    microcode: 0x8101016
  Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
    desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
    desc: 1x4 MiB
  Speed (MHz): avg: 3655 high: 3689 min/max: 1600/3700 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3564 2: 3685
    3: 3689 4: 3684 bogomips: 29557
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
    fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm
    mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
    nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
    pse36 rapl rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap
    smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock
    syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
    vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
    disabled, RSB filling
  Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
    vendor: Sapphire Limited driver: amdgpu v: kernel bus-ID: 01:00.0
    chip-ID: 1002:67df class-ID: 0300
  Display: x11 server: X.Org 1.21.1.3 compositor: picom v: git-dac85 driver:
    loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
    display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0")
    s-diag: 777mm (30.6")
  Monitor-1: DisplayPort-0 res: 2560x1440 dpi: 109
    size: 597x336mm (23.5x13.2") diag: 685mm (27")
  OpenGL: renderer: AMD Radeon RX 570 Series (POLARIS10 DRM 3.42.0
    5.15.16-1-MANJARO LLVM 13.0.0)
    v: 4.6 Mesa 21.3.4 direct render: Yes
  Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
    vendor: Sapphire Limited driver: snd_hda_intel v: kernel bus-ID: 01:00.1
    chip-ID: 1002:aaf0 class-ID: 0403
  Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
    v: kernel bus-ID: 0b:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Sound Server-1: ALSA v: k5.15.16-1-MANJARO running: yes
  Sound Server-3: JACK v: 1.9.20 running: no
  Sound Server-4: PulseAudio v: 15.0 running: no
  Sound Server-5: PipeWire v: 0.3.43 running: yes
  Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
    v: kernel bus-ID: 08:00.0 chip-ID: 8086:24fb class-ID: 0280
  IF: wlp8s0 state: down mac: <filter>
  Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
    port: e000 bus-ID: 09:00.0 chip-ID: 8086:1539 class-ID: 0200
  IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
    bus-ID: 1-6:2 chip-ID: 8087:0aa7 class-ID: e001
  Local Storage: total: 223.57 GiB used: 177.62 GiB (79.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate model: XPG GAMMIX S11
    size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 type: SSD serial: <filter> rev: SVN139B temp: 29.9 C scheme: GPT
  ID-1: / raw-size: 223.27 GiB size: 218.77 GiB (97.98%)
    used: 177.62 GiB (81.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: e7710bda-2918-4406-9f2b-914f8372bf23
    used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 4032-1C27
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
  Device-1: 1-6:2 info: Intel Wireless-AC 3168 Bluetooth type: Bluetooth
  Device-2: 1-7:3 info: A4Tech USB Device type: Keyboard,Mouse,HID
    driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s
    power: 100mA chip-ID: 09da:f6eb class-ID: 0300
  Device-3: 1-10:4 info: A4Tech USB Device type: Keyboard,Mouse,HID
    power: 500mA chip-ID: 09da:fa44 class-ID: 0300
  Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-6: 6-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 50.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 173
  Processes: 224 Uptime: 10m wakeups: 0 Init: systemd v: 250 tool: systemctl
  Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1441 pacman: 1426 lib: 439
  flatpak: 8 snap: 7 Shell: Bash v: 5.1.16 running-in: xfce4-terminal
  inxi: 3.3.12
KERNEL 5.16
  Kernel: 5.16.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
    date: 07/17/2019
  RAM: total: 7.75 GiB used: 1.15 GiB (14.8%)
  RAM Report:
    desc: 1x4 MiB
  Speed (MHz): avg: 3674 high: 3698 min/max: 1600/3700 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3612 2: 3698
    3: 3693 4: 3694 bogomips: 29559
  Monitor-1: DisplayPort-0 res: 2560x1440 hz: 60 dpi: 109
  OpenGL: renderer: AMD Radeon RX 570 Series (POLARIS10 DRM 3.44.0
    5.16.2-1-MANJARO LLVM 13.0.0)
  Sound Server-1: ALSA v: k5.16.2-1-MANJARO running: yes
  Local Storage: total: 223.57 GiB used: 177.81 GiB (79.5%)
    lanes: 4 type: SSD serial: <filter> rev: SVN139B temp: 33.9 C scheme: GPT
    used: 177.81 GiB (81.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    uuid: 4032-1C27
  System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 42.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 130
  Processes: 243 Uptime: 0m wakeups: 0 Init: systemd v: 250 tool: systemctl
  Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1442 pacman: 1427 lib: 439
  inxi: 3.3.12
I would stick with 5.15 for now and try 5.16 later as it matures.
Tip: When pasting terminal output on Discourse forums, one can either…
  • Use the Preformatted text </> toolbar button–NOT the Quote " button.
  • Add three backticks ` above and below the text (Markdown):
    type or paste code here
  • Use HTML:
    <pre><code>
    </pre></code>
I’ve done it for you this time. :wink:
It seems not only 120Hz/144Hz option is broken. The new kernels broke 4K with some configurations as well.
My Radeon Pro WX5100 can reach 4K (3840x2160) @ 120Hz with my ASUS XG27UQR when using 5.15 kernel, but with 5.16 kernel and onwards, the maximum resolution I could set is 2560x1440 @ 60Hz.
EDIT: To be precise, with 5.16/5.17rc kernels, higher resolutions and refresh rates are simply not available in the Display settings and the system automatically defaults to the maximum possible resolution. I’m using Cinnamon, though, as it is a bit more HiDPI-friendly than Xfce.
At first I thought there might be an issue with my DP connection but turned out it’s not the case. Returning to 5.15 kernel and I could use 4K @ 120Hz again with no issues.
I think the issue might be related to this bisected regression.
Could be related to
https://forum.manjaro.org/t/cant-change-resolution-on-linux-5-16
5.18 Fixed the issue. From what i can i understand flashes was appearing on some Amd gpus and someone (not related with Manjaro) kernel developer id…iot decided to blacklist the entire high Hz spectrum. I will say this again, if there is no cleansing to our fields then Linux will never become mainstream. Remember heart-bleed.
