I have an X380 Yoga with a built-in Wacom tablet. After a Kernel update my system freezes on 5.10 as soon as I put the pen on the screen. Even audio stops working.
I have no problems on 5.9 and am using that one now.
Is there any known issue? I don’t have time to search in journalctl at the moment sorry…
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=a2f3e649-9263-4ff5-a6cb-047f0b645cb7 rw quiet apparmor=1
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
dm: SDDM Distro: Manjaro Linux
Type: Convertible System: LENOVO product: 20LJS02W00 v: ThinkPad X380 Yoga
serial: <filter> Chassis: type: 31 serial: <filter>
Mobo: LENOVO model: 20LJS02W00 serial: <filter> UEFI: LENOVO
v: R0SET50W (1.34 ) date: 07/20/2020
ID-1: BAT0 charge: 46.6 Wh condition: 47.8/51.0 Wh (94%) volts: 16.8/15.3
model: SMP 01AV433 type: Li-poly serial: <filter> status: Unknown
cycles: 215
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K360
status: Discharging
Info: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: E0 L2 cache: 8 MiB
bogomips: 32012
Speed: 625 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 625 2: 634 3: 600
4: 698 5: 629 6: 600 7: 657 8: 666
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:5917
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus ID: 1-8:4
chip ID: 04f2:b614
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display ID: :0
screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1185x381mm (46.7x15.0")
s-diag: 1245mm (49")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 168 size: 290x170mm (11.4x6.7")
diag: 336mm (13.2")
Monitor-2: DP1-1 res: 2560x1440 hz: 60 dpi: 108 size: 600x340mm (23.6x13.4")
diag: 690mm (27.2")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.3.3
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
chip ID: 8086:9d71
Device-2: Lenovo ThinkPad Dock Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 3-1.4.2.3:6
chip ID: 17ef:3063 serial: <filter>
Sound Server: ALSA v: k5.9.16-1-MANJARO
Device-1: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: efa0 bus ID: 00:1f.6 chip ID: 8086:15d8
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: efa0
bus ID: 04:00.0 chip ID: 8086:24fd
IF: wlp4s0 state: up mac: <filter>
Device-3: Lenovo ThinkPad Dock Ethernet [Realtek RTL8153B] type: USB
driver: r8152 bus ID: 4-1.1:4 chip ID: 17ef:3062 serial: <filter>
IF: enp62s0u1u1 state: down mac: <filter>
Local Storage: total: 476.94 GiB used: 259.75 GiB (54.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKKF512G8L
size: 476.94 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: L14P temp: 35.9 C
ID-1: / raw size: 59.3 GiB size: 58.12 GiB (98.01%) used: 45.82 GiB (78.8%)
fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /boot/efi raw size: 99 MiB size: 95 MiB (95.96%)
used: 32.9 MiB (34.6%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw size: 261.12 GiB size: 256.02 GiB (98.05%)
used: 213.89 GiB (83.5%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
ID-1: swap-1 type: partition size: 10.04 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p8 maj-min: 259:8
System Temperatures: cpu: 46.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 279 Uptime: 3m wakeups: 9 Memory: 15.53 GiB
used: 2.84 GiB (18.3%) Init: systemd v: 247 Compilers: gcc: 10.2.0
clang: 11.0.1 Packages: apt: 0 pacman: 1803 lib: 460 flatpak: 0 Shell: Zsh
v: 5.8 default: Bash v: 5.1.0 running in: konsole inxi: 3.2.02
