keeweb@1.16.7 postinstall /home/estudio/.cache/yay/keeweb/src/keeweb
cd desktop && npm install
added 1 package from 1 contributor and audited 1 package in 0.538s
found 0 vulnerabilities
added 1270 packages from 547 contributors and audited 1471 packages in 26.078s
50 packages are looking for funding
run `npm fund` for details
found 5 low severity vulnerabilities
run `npm audit fix` to fix them, or `npm audit` for details
>> Local Npm module "grunt-appdmg" not found. Is it installed?
Loading "grunt-notarize.js" tasks...ERROR
>> Error: Cannot find module 'electron-notarize'
Loading "grunt-osx-sign.js" tasks...ERROR
>> Error: Cannot find module 'electron-osx-sign'
Running "clean:dist" (clean) task
>> 0 paths cleaned.
Running "clean:desktop" (clean) task
>> 0 paths cleaned.
Running "copy:html" (copy) task
Copied 1 file
Running "copy:icons" (copy) task
Copied 17 files
Running "copy:manifest" (copy) task
Copied 2 files
Running "webpack:app" (webpack) task
Fatal error: iconFontScssSource.matchAll(...) is not a function or its return value is not iterable
Execution Time (2021-01-03 16:51:36 UTC+1)
loading tasks 648ms βββββββββββββββββββββ 25%
copy:icons 63ms βββ 2%
webpack:app 1.9s ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ 72%
Total 2.6s
==> ERROR: A failure occurred in build().
Aborting...
error making: keeweb
How do I go about this now, gents?
It used to be so easy but now that yaourt is no longer recommended, it has become a task in its own right.
