AUR updates does not show up in Pamac
The icon in the system tray indicates that there are updates.
Starting Pamac says that the system is updated and it doesn’t show any AUR updates, what so ever.
But I am sure that it is AUR updates that the icon in the system tray is trying to tell me about.
This is a new issue. It used to show all AUR updates in Pamac.
What is happening here?
(This is a desktop Dell OptiPlex 790)
/ Hans Gatu
First, double-check by updating your system via terminal window command
pamac upgrade -a
Thank you @Wollie.
It had something to do with that.
Now the system icon indicate that the system doesn’t need to be updated.
/ Hans Gatu
Well, this morning, the system tray icon indicated that updates were available.
I clicked on it and Pamac opened, just as it should.
I could see only two updates, i.e. Firefox 84.0.1 and the Swedish language pack for it.
So, I clicked on the update button to update them, but then I got the message that it also was about to install kibom-git, for the KiCAD.
So, if it wasn’t for the Firefox update, I would not have been able to know that there was an kibom-git update in AUR.
I.e. the problem is still there.
/ Hans Gatu
Use the CLI command (as given in my above post) until it’s fixed.
Reference:
