/home/pranjal/projects/GVH/build> /usr/bin/cmake -DCMAKE_EXPORT_COMPILE_COMMANDS=ON -DCMAKE_BUILD_TYPE=Debug -G ‘Unix Makefiles’ /home/pranjal/projects/GVH
CMake Deprecation Warning at CMakeLists.txt:1 (cmake_minimum_required):
Compatibility with CMake < 3.5 will be removed from a future version of
CMake.
Update the VERSION argument value or use a … suffix to tell
CMake that the project does not need compatibility with older versions.
– The C compiler identification is GNU 13.2.1
– The CXX compiler identification is GNU 13.2.1
– Detecting C compiler ABI info
– Detecting C compiler ABI info - done
– Check for working C compiler: /usr/bin/cc - skipped
– Detecting C compile features
– Detecting C compile features - done
– Detecting CXX compiler ABI info
– Detecting CXX compiler ABI info - done
– Check for working CXX compiler: /usr/bin/c++ - skipped
– Detecting CXX compile features
– Detecting CXX compile features - done
CMake Error at CMakeLists.txt:5 (find_package):
Could not find a package configuration file provided by “ECM” (requested
version 5.68.0) with any of the following names:
ECMConfig.cmake
ecm-config.cmake
Add the installation prefix of “ECM” to CMAKE_PREFIX_PATH or set “ECM_DIR”
to a directory containing one of the above files. If “ECM” provides a
separate development package or SDK, be sure it has been installed.
Tip:
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Please consider installing extra-cmake-modules-git from the AUR.
Source: [SOLVED] I can't build kde frameworks packages from git. / AUR Issues, Discussion & PKGBUILD Requests / Arch Linux Forums
Note: AUR packages need not play well with Manjaro repository afaik. I daily drive Arch and not manjaro, and cannot test the solution for you.
