Good evening fellow linux enthusiasts.
I have mucked up my installation quite hard.
3 days ago in a vein attempt to get a gui for my wacom tablet, features have broken.
I will describe in detail what i did .
Before this fiasco I was running manjaro with xfce no issues at all.
The issues after i face installing this package Wacom Tablet KCM
After reboot I got the error message that lightdm failed.
Following that I removed and reinstalled the following things
I reinstalled Xorg I believe
XFCE and light dm
I removed light dm because xfce was not showing up in the bottom right for a selection
I then installed lxdm and attempted to configure it using the wiki
The issue that I face now , is that lxde “loads” and i get the prompt and a selection for XFCE
I then attempt to sign in, the page changes for a split second and then loops back to the LXDE login
Conceptually I am trying to use LXDM with XFCE as I had issues before. any insights are appreaciated
kcm-wacomtablet is a package that depends on plasma-workspace so when you installed that, sddm was installed too from the lost list of dependencies … hence you had two Dysplay Managers, and none can start because of the other. When you uninstalled lightdm probably also removed other packages that make XFCE work, whyle by installing lxdm you had no proper switch to it, but also sddm was still trying to load in the same time with lxdm …
You have to follow the LXDM Configuration - Manjaro
A quick search in the forum about xfce and UI configurator for tablet, would have revealed you at least this
Mixing DEs on the same user is always a bad idea without knowing the implications and how to avoid trouble.
Blockquote Mixing DEs on the same user is always a bad idea without knowing the implications and how to avoid trouble.
Blockquote
I fully understand that now after the aches and pains it caused.
I did follow the wiki’s config instructions for setting up lxdm and commenting the right things in. But I am still unable to get through to the XFCE4 Desktop.
“packages that make XFCE work” when i did the reninstall is it possible that it nuked the configurations needed by manjaro to start up? And if so is there a resource that i can use to find the locations . And compare it to a good installation i have. Repaving this system isnt possible because i have apps that required pv, which i no longer have the numbers to.
Not sure if in your process you did not had to remove the manjaro-xfce-settings and installed the package for kde … Those two can’t reside together. Try to reinstall the default one for xfce, remove sddm, also worth taking another look at the video drivers, in case you need the proprietary nvidia ones. As long as you have access to the TTY and internet connection works, the system should be salvageable. Try to share some logs and the errors you get when trying to load the desktop.
This should help How to provide good information and once you share that information, someone might have a solution.
Funny enough that package was there. When chrooted in I got the error:failed to synchronize all databases (unable to lock databases).This was when i was attempting to reinstall the manjaro-xfce-settings as you stated to check out. . After retrieving the necessary logs on the machine. these are the logs
2System:
12Kernel 5.10.42-1-MANJARO x86_64 12bits 64 12compiler gcc 12v 11.1.0
12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_XFCE_2107 quiet systemd.show_status=1
apparmor=1 security=apparmor driver=nonfree nouveau.modeset=0 i915.modeset=1
radeon.modeset=1
12Desktop Xfce 12info xfce4-panel 12wm xfwm 12dm N/A 12Distro Manjaro Linux
12base Arch Linux
12Machine:
12Type Desktop 12Mobo ASUSTeK 12model ROG STRIX X570-E GAMING 12v Rev X.0x
12serial <filter> 12UEFI American Megatrends 12v 2407 12date 07/01/2020
12Battery:
12Message No system battery data found. Is one present?
12Memory:
12RAM 12total 31.33 GiB 12used 2.28 GiB (7.3%)
12Array-1 12capacity 128 GiB 12slots 4 12EC None 12max-module-size 32 GiB 12note est.
12Device-1 DIMM_A1 12size 16 GiB 12speed 3200 MT/s 12type DDR4
12detail synchronous unbuffered (unregistered) 12bus-width 64 bits 12total 64 bits
12manufacturer Team Group Inc. 12part-no TEAMGROUP-UD4-3200 12serial <filter>
12Device-2 DIMM_A2 12size 16 GiB 12speed 3200 MT/s 12type DDR4
12Device-3 DIMM_B1 12size No Module Installed
12Device-4 DIMM_B2 12size No Module Installed
12CPU:
12Info 16-Core (2-Die) 12model AMD Ryzen 9 3950X 12socket AM4 12bits 64
12type MT MCP MCM 12arch Zen 2 12family 17 (23) 12model-id 71 (113) 12stepping 0
12microcode 8701021 12cache 12L1 1024 KiB 12L2 8 MiB 12L3 64 MiB 12bogomips 243266
12Speed 3795 MHz 12min/max 2200/3800 MHz 12base/boost 3800/4725 12boost enabled
12volts 1.1 V 12ext-clock 100 MHz 12Core speeds (MHz) 121 3795 122 3811 123 3831 124 3815
125 3804 126 3800 127 3815 128 3810 129 3772 1210 3806 1211 3803 1212 3780 1213 3812 1214 3800
1215 3801 1216 3791 1217 3787 1218 3804 1219 3786 1220 3800 1221 3805 1222 3773 1223 3785
1224 3809 1225 3803 1226 3788 1227 3815 1228 3820 1229 3822 1230 3792 1231 3814 1232 3811
12Flags 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1 bmi2
bpext cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov cmp_legacy
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload
vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
xsaveopt xsaves
12Vulnerabilities 12Type itlb_multihit 12status Not affected
12Type l1tf 12status Not affected
12Type mds 12status Not affected
12Type meltdown 12status Not affected
12Type spec_store_bypass
12mitigation Speculative Store Bypass disabled via prctl and seccomp
12Type spectre_v1
12mitigation usercopy/swapgs barriers and __user pointer sanitization
12Type spectre_v2 12mitigation Full AMD retpoline, IBPB: conditional, STIBP:
conditional, RSB filling
12Type srbds 12status Not affected
12Type tsx_async_abort 12status Not affected
12Graphics:
12Device-1 AMD Cape Verde PRO [Radeon HD 7750/8740 / R7 250E] 12vendor VISIONTEK
12driver radeon 12v kernel 12bus-ID 09:00.0 12chip-ID 1002:683f 12class-ID 0300
12Display 12server X.Org 1.20.11 12compositor xfwm4 12driver 12loaded amdgpu,ati
12unloaded modesetting,vesa 12alternate fbdev 12display-ID :0.0 12screens 1
12Screen-1 0 12s-res 9040x1080 12s-dpi 96 12s-size 2391x285mm (94.1x11.2")
12s-diag 2408mm (94.8")
12Monitor-1 DisplayPort-0 12res 1920x1080 12hz 60 12dpi 82
12size 598x336mm (23.5x13.2") 12diag 686mm (27")
12Monitor-2 DisplayPort-1 12res 1920x1080 12hz 60 12dpi 70
12size 700x400mm (27.6x15.7") 12diag 806mm (31.7")
12Monitor-3 DisplayPort-3 12res 1360x768 12hz 60 12dpi 49
12Monitor-4 DisplayPort-4 12res 1920x1080 12hz 60 12dpi 59
12size 820x460mm (32.3x18.1") 12diag 940mm (37")
12Monitor-5 DisplayPort-5 12res 1920x1080 12hz 60 12dpi 52
12size 930x523mm (36.6x20.6") 12diag 1067mm (42")
12OpenGL 12renderer AMD VERDE (DRM 2.50.0 5.10.42-1-MANJARO LLVM 12.0.0)
12v 4.5 Mesa 21.1.4 12direct render Yes
12Audio:
12Device-1 AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
Series]
12vendor VISIONTEK 12driver snd_hda_intel 12v kernel 12bus-ID 09:00.1
12chip-ID 1002:aab0 12class-ID 0403
12Device-2 AMD Starship/Matisse HD Audio 12vendor ASUSTeK 12driver snd_hda_intel
12v kernel 12bus-ID 0b:00.4 12chip-ID 1022:1487 12class-ID 0403
12Device-3 JMTek LLC. USB PnP Audio Device 12type USB
12driver hid-generic,snd-usb-audio,usbhid 12bus-ID 3-3.1.1:7 12chip-ID 0c76:161f
12class-ID 0300
12Sound Server-1 ALSA 12v k5.10.42-1-MANJARO 12running yes
12Sound Server-2 JACK 12v 1.9.18 12running no
12Sound Server-3 PulseAudio 12v 14.2 12running yes
12Sound Server-4 PipeWire 12v 0.3.31 12running no
12Network:
12Device-1 Intel Wi-Fi 6 AX200 12driver iwlwifi 12v kernel 12bus-ID 03:00.0
12chip-ID 8086:2723 12class-ID 0280
12IF wlp3s0 12state down 12mac <filter>
12Device-2 Realtek RTL8125 2.5GbE 12vendor ASUSTeK 12driver r8169 12v kernel
12port e000 12bus-ID 04:00.0 12chip-ID 10ec:8125 12class-ID 0200
12IF enp4s0 12state down 12mac <filter>
12Device-3 Intel I211 Gigabit Network 12vendor ASUSTeK 12driver igb 12v kernel
12port d000 12bus-ID 05:00.0 12chip-ID 8086:1539 12class-ID 0200
12IF enp5s0 12state up 12speed 1000 Mbps 12duplex full 12mac <filter>
12IP v4 <filter> 12type dynamic noprefixroute 12scope global 12broadcast <filter>
12IP v6 <filter> 12type dynamic noprefixroute 12scope global
12IP v6 <filter> 12type noprefixroute 12scope global
12IP v6 <filter> 12type noprefixroute 12scope link
12Device-4 Realtek RTL8153 Gigabit Ethernet Adapter 12type USB 12driver r8152
12bus-ID 3-3.3:6 12chip-ID 0bda:8153 12class-ID 0000 12serial <filter>
12IF enp6s0f3u3u3 12state down 12mac <filter>
12WAN IP <filter>
12Bluetooth:
12Device-1 Intel AX200 Bluetooth 12type USB 12driver btusb 12v 0.8 12bus-ID 1-6:3
12chip-ID 8087:0029 12class-ID e001
12Report rfkill 12ID hci0 12rfk-id 1 12state down 12bt-service N/A 12rfk-block
12hardware no 12software yes 12address see --recommends
12Logical:
12Message No logical block device data found.
12RAID:
12Message No RAID data found.
12Drives:
12Local Storage 12total 1.88 TiB 12used 589.36 GiB (30.7%)
12SMART Message Required tool smartctl not installed. Check --recommends
12ID-1 /dev/sda 12maj-min 8:0 12vendor HP 12model SSD S700 1TB 12size 931.51 GiB
12block-size 12physical 4096 B 12logical 512 B 12speed 6.0 Gb/s 12rotation SSD
12serial <filter> 12rev 2A1
12ID-2 /dev/sdb 12maj-min 8:16 12vendor SanDisk 12model Extreme Portable SSD
12size 931.51 GiB 12block-size 12physical 512 B 12logical 512 B 12speed 6.0 Gb/s
12rotation SSD 12serial <filter> 12rev 30WD
12ID-3 /dev/sdc 12maj-min 8:32 12type USB 12vendor SanDisk 12model Cruzer
12size 58.46 GiB 12block-size 12physical 512 B 12logical 512 B 12serial <filter>
12rev 1.27
12Message No optical or floppy data found.
12Partition:
12ID-1 / 12raw-size 862.44 GiB 12size 847.91 GiB (98.31%) 12used 589.36 GiB (69.5%)
12fs ext4 12block-size 4096 B 12dev /dev/sdb1 12maj-min 8:17 12label N/A
12uuid 45240a36-1368-447f-be10-5e56f2cec0c1
12Swap:
12Alert No swap data was found.
12Unmounted:
12ID-1 /dev/sda1 12maj-min 8:1 12size 931.51 GiB 12fs ext4 12label N/A
12uuid f2dbfe10-c2bc-460b-89a5-ddeb6773211c
12ID-2 /dev/sdb2 12maj-min 8:18 12size 69.07 GiB 12fs swap 12label N/A
12uuid 6d08a224-78c5-48c9-bdec-da2d9d4a9073
12ID-3 /dev/sdc1 12maj-min 8:33 12size 2.42 GiB 12fs N/A 12label MANJARO_XFCE_2107
12uuid 2021-06-14-15-23-05-00
12ID-4 /dev/sdc2 12maj-min 8:34 12size 4 MiB 12fs N/A 12label MISO_EFI 12uuid 0545-B0D1
12USB:
12Hub-1 1-0:1 12info Full speed (or root) Hub 12ports 6 12rev 2.0 12speed 480 Mb/s
12chip-ID 1d6b:0002 12class-ID 0900
12Hub-2 1-5:2 12info Genesys Logic Hub 12ports 4 12rev 2.0 12speed 480 Mb/s
12power 100mA 12chip-ID 05e3:0610 12class-ID 0900
12Device-1 1-6:3 12info Intel AX200 Bluetooth 12type Bluetooth 12driver btusb
12interfaces 2 12rev 2.0 12speed 12 Mb/s 12power 100mA 12chip-ID 8087:0029
12class-ID e001
12Hub-3 2-0:1 12info Full speed (or root) Hub 12ports 4 12rev 3.1 12speed 10 Gb/s
12chip-ID 1d6b:0003 12class-ID 0900
12Hub-4 3-0:1 12info Full speed (or root) Hub 12ports 6 12rev 2.0 12speed 480 Mb/s
12Hub-5 3-3:2 12info VIA Labs USB2.0 Hub 12ports 4 12rev 2.1 12speed 480 Mb/s
12chip-ID 2109:2817 12class-ID 0900
12Hub-6 3-3.1:5 12info Terminus Hub 12ports 4 12rev 2.0 12speed 480 Mb/s 12power 100mA
12chip-ID 1a40:0101 12class-ID 0900
12Device-1 3-3.1.1:7 12info JMTek LLC. USB PnP Audio Device 12type Audio,HID
12driver hid-generic,snd-usb-audio,usbhid 12interfaces 4 12rev 1.1 12speed 12 Mb/s
12power 100mA 12chip-ID 0c76:161f 12class-ID 0300
12Device-2 3-3.1.4:13 12info SiGma Micro XM102K Optical Wheel Mouse 12type Mouse
12driver hid-generic,usbhid 12interfaces 1 12rev 1.1 12speed 1.5 Mb/s 12power 100mA
12chip-ID 1c4f:0034 12class-ID 0301
12Device-3 3-3.3:6 12info Realtek RTL8153 Gigabit Ethernet Adapter 12type Network
12driver r8152 12interfaces 1 12rev 2.1 12speed 480 Mb/s 12power 200mA
12Hub-7 3-3.4:8 12info VIA Labs VL820 Hub 12ports 5 12rev 2.1 12speed 480 Mb/s
12chip-ID 2109:2820 12class-ID 0900
12Device-1 3-3.4.2:10 12info USB usb keyboard 12type Keyboard,HID
12driver hid-generic,usbhid 12interfaces 2 12rev 1.1 12speed 1.5 Mb/s 12power 98mA
12chip-ID c0f4:06e0 12class-ID 0300
12Device-2 3-3.4.3:11 12info SanDisk Cruzer 12type Mass Storage 12driver usb-storage
12interfaces 1 12rev 2.0 12speed 480 Mb/s 12power 200mA 12chip-ID 0781:5530
12class-ID 0806 12serial <filter>
12Device-3 3-4:3 12info ASUSTek AURA LED Controller 12type HID
12driver hid-generic,usbhid 12interfaces 2 12rev 2.0 12speed 12 Mb/s 12power 16mA
12chip-ID 0b05:18f3 12class-ID 0300 12serial <filter>
12Device-4 3-5:4 12info Corsair H100iRGBPROXT 12type Keyboard
12driver hid-generic,usbhid 12interfaces 1 12rev 2.0 12speed 12 Mb/s 12power 100mA
12chip-ID 1b1c:0c20 12class-ID 0300
12Hub-8 4-0:1 12info Full speed (or root) Hub 12ports 4 12rev 3.1 12speed 10 Gb/s
12Hub-9 5-0:1 12info Full speed (or root) Hub 12ports 4 12rev 2.0 12speed 480 Mb/s
12Hub-10 6-0:1 12info Full speed (or root) Hub 12ports 4 12rev 3.1 12speed 10 Gb/s
12Sensors:
12System Temperatures 12cpu 51.5 C 12mobo N/A 12gpu radeon 12temp 50.0 C
12Fan Speeds (RPM) N/A
12Info:
12Processes 657 12Uptime 13m 12wakeups 0 12Init systemd 12v 248 12tool systemctl
12Compilers 12gcc 11.1.0 12clang 12.0.1 12Packages 12pacman 1725 12lib 441
12Client Unknown Client: systemd 12inxi 3.3.05
I also retrieved the xorg logs if needed.
Once out of the chroot, I booted back to the system that is unable to fully login . Got into tty and proceded to remove that manjaro-xfce-settings to renistall it. Ran into the error
Failed to init transaction (unable to lock database)
could not lock database : File exists
Ran into the error
Removed the file suggested in the error and the resolved the issue with pacman not being able to remove packages.
The sddm service does not exist also.
Still unable to get past the lxdm login loop to get into xfce.
