KDE won’t hibernate after video ending in Vivaldi Browser
That is probably just a symptom of what is wrong.It’ll have to be properly diagnosed. To start, please provide the output of:
systemctl status hibernate.target
This will just provide the status of the hibernation target.
and
journalctl --boot=-1 --unit=hibernate.target --no-pager
This will provide any messages that the target provided when activated for the previous (-1
) boot. feel free to adjust this to a boot where this problem was observed._
Also, what happens when you run
systemctl hibernate
…from the terminal?
Tip:
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C
. For example:
LC_ALL=C bluetoothctl
Probably just a result of a bad implementation of hardware video encoding/decoding in combination with your graphics driver.
The solution is simple: clear out your RAM by cleanly rebooting. Hibernation should work again afterwards.
Also please note that KDE Plasma has nothing to do with hibernation. KDE Plasma is a desktop environment, not an operating system. Thread moved to the generic Support category.
