Hi,
i was trying to boot my system with wayland instead of X11 (plasma-wayland-session is installed), but if I select wayland at login screen, it just gives a black screen followed again by the login screen.
Host: martin-manjaro Kernel: 5.15.12-1-MANJARO x86_64 bits: 64
Desktop: KDE Plasma 5.23.4 Distro: Manjaro Linux
Type: Desktop System: MSI product: MS-7996 v: 1.0
serial: <superuser required>
Mobo: MSI model: H110M PRO-D (MS-7996) v: 1.0
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: 2.E0
date: 08/11/2017
Info: quad core model: Intel Core i5-6500 bits: 64 type: MCP cache:
L2: 1024 KiB
Speed (MHz): avg: 2287 min/max: 800/3600 cores: 1: 1857 2: 2738 3: 1535
4: 3020
Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] driver: nvidia v: 495.44
Device-2: Logitech B525 HD Webcam type: USB
driver: snd-usb-audio,uvcvideo
Display: x11 server: X.Org 1.21.1.2 driver: loaded: nvidia
resolution: 2560x1440~60Hz
Device-1: Intel 100 Series/C230 Series Family HD Audio
driver: snd_hda_intel
Device-2: NVIDIA GP106 High Definition Audio driver: snd_hda_intel
Device-3: Logitech [G533 Wireless Headset Dongle] type: USB
driver: hid-generic,snd-usb-audio,usbhid
Device-4: Logitech B525 HD Webcam type: USB
Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Sound Server-3: PipeWire v: 0.3.42 running: yes
driver: r8169
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: 4c:cc:6a:29:20:9a
driver: btusb
Report: bt-adapter ID: hci0 state: up address: 00:1A:7D:DA:71:0D
Local Storage: total: 5.46 TiB used: 2.77 TiB (50.8%)
ID-1: /dev/sda vendor: SanDisk model: SDSSDH3 1T00 size: 931.51 GiB
ID-2: /dev/sdb vendor: Western Digital model: WD40EZRX-00SPEB0
ID-3: /dev/sdc vendor: Western Digital model: WD10EAVS-32D7B1
ID-1: / size: 52.41 GiB used: 30.17 GiB (57.6%) fs: ext4 dev: /dev/sda2
ID-2: /home size: 813.11 GiB used: 299.65 GiB (36.9%) fs: ext4
dev: /dev/sda4
ID-1: swap-1 type: partition size: 47.52 GiB used: 0 KiB (0.0%)
dev: /dev/sda3
System Temperatures: cpu: 29.8 C pch: 45.5 C mobo: 27.8 C gpu: nvidia
temp: 55 C
Processes: 261 Uptime: 1m Memory: 31.32 GiB used: 2.2 GiB (7.0%)
Shell: Bash inxi: 3.3.11
Any hint what is going on here is welcome.
Thx, Martin
Same to your issue. And also I use nvidia proprietary driver too (although my card is GT 1030).
Log from Journald:
2022/1/19 下午11:26 plasmashell This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
2022/1/19 下午11:26 systemd-coredump Process 965 (plasmashell) of user 1000 dumped core.
Module linux-vdso.so.1 with build-id 7071f5ba88b7adc9e9000c9cb386b05dc3494fb1
Module libuuid.so.1 with build-id 1366ec3008cfdbe45a226330754baeea46a2d7e6
Module libxcb-util.so.1 with build-id 4188ebc629b472b560849c5792a69c1803c3d1a4
Module libxkbcommon-x11.so.0 with build-id 821e1e75e92f3aaa96d19ed31fe98dbbd4d34627
Module libICE.so.6 with build-id af53458a64fe1e62a4d95606f7b03c210b2b098c
Module libSM.so.6 with build-id ac7b055fd3f16b4f29373285ab04ed52eebb632d
Module libxcb-xinput.so.0 with build-id 6403174c48f05f40cf7c168beb86f2886b9f09c1
Module libxcb-xkb.so.1 with build-id fce20d2101f3e5439923e9283c489c2cad4420c3
Module libxcb-xinerama.so.0 with build-id b328103ce7502d94fd3a4e2e8773978a9aa84adc
Module libxcb-xfixes.so.0 with build-id a6b197ace5b9b59f913f5969eb419a88d1194f47
Module libxcb-sync.so.1 with build-id dda14591103b01b1311906053bf1ca9e82ade35c
Module libxcb-render.so.0 with build-id a37bdb37744b508be9dd29fd9ccb9bb0170d43e5
Module libxcb-render-util.so.0 with build-id c64fb28ea20a320a9754273d9ea3af85f6f74b17
Module libxcb-shm.so.0 with build-id fb797f299a446f559a95afcc168227482cc800d1
Module libxcb-image.so.0 with build-id ee7f8577926fe7c1d6972036c2f8e6f727e43b1b
Module libxcb-icccm.so.4 with build-id 73f1e12d76af383aa969a60279ed5ed922045f47
Module libX11-xcb.so.1 with build-id 0db4f94d8ae31b8dc9a83f825a9171656f1e532c
Module libQt5XcbQpa.so.5 with build-id 0d5a74f1ac974f0283de448900e6c1b913c1a294
Module libqxcb.so with build-id 7f5cb7bdf8ee32b69aba35f87336b3d16377a534
Module libbrotlicommon.so.1 with build-id a4ba3f4b4571c8272343b621da812a6e24a202a7
Module libexpat.so.1 with build-id 64e977cfebfe7539f428dec3b388f5d0498b3108
Module libbrotlidec.so.1 with build-id 45defc036e918e0140a72f1fbce6e7692d38241d
Module libgpg-error.so.0 with build-id 3801187d42c4955bd93c605451430cdf1b164e63
Module libgmp.so.10 with build-id e58d34ab389d1b649c24195c2d145e3ff2e58290
Module libhogweed.so.6 with build-id 2d70cff7b1841b4d9ca4e8e7726cd4b944c07fdc
Module libnettle.so.8 with build-id 9a878e513c02007598fcf1e2e286c2203f13536e
Module libunistring.so.2 with build-id 015ac6d6bcb60b7d8bea31a80d1941b06e8636ab
Module libidn2.so.0 with build-id 1ce2b50ad9f9821c2c629b521cf5a3c99593d332
Module libp11-kit.so.0 with build-id f97c44b297b54185bbe3eb6ed6dab5d8967f1532
Module libogg.so.0 with build-id ca0cae30a809f10db1f16e54a23b4e5ff7b2c54c
Module libvorbis.so.0 with build-id ad0a6c1af8f219b4e314090b6e8847223d424cbe
Module libxkbcommon.so.0 with build-id 1f1bc7527e57c886c3df5803068122e1971d4724
Module libfontconfig.so.1 with build-id 1103a641395c7d3b42e49b793d3a9ea927c77bf6
Module libwayland-cursor.so.0 with build-id 79d7e67af210407c2afe92ba8c189c8648a6474c
Module libacl.so.1 with build-id 35319ea4baa70564deddffb113c0961002bc394c
Module libresolv.so.2 with build-id c915c72668282861a813f7ea3c0780f37b681dc0
Module libkeyutils.so.1 with build-id ac405ddd17be10ce538da3211415ee50c8f8df79
Module libkrb5support.so.0 with build-id adf65240a4d2aba772d7a0772b4d015469934113
Module libcom_err.so.2 with build-id be99503e12b86d78d6ede2f0d1ffb66408a37576
Module libk5crypto.so.3 with build-id eb8220b8f36675aac769450be4cb6bb7f97ec38a
Module libkrb5.so.3 with build-id 72d26767c5cb1097db75a5f5bff88860233c902b
Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
Module libicudata.so.70 with build-id e1dcc2a88cfaafed882d09c90c668af0eed4efed
Module libcap.so.2 with build-id f56c6cd6ad4d35053340d7ff2f8f954498796739
Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
Module libgraphite2.so.3 with build-id 47761dc11e553f519cde97ed9ee985be12ccdae2
Module libfreetype.so.6 with build-id 26c5f833068ff72660d1975cbc2074c3eb47fad8
Module libGLX.so.0 with build-id 2a08836c6e6126ce9ff4496b6aacaf29ae9b4e7b
Module libGLdispatch.so.0 with build-id 501765b3a78d668860fa54229b18107473aeda4c
Module libusbmuxd-2.0.so.6 with build-id fd9f05e7f5b0da4e15972f75b61fd9b4b9f06dbe
Module libgcrypt.so.20 with build-id db45f5d5e0f7af1e77324fea1885f974619ad268
Module libtasn1.so.6 with build-id ee3429ca5e94718aea4fe5249fc859e0cd88e4e9
Module libgnutls.so.30 with build-id 8c87466eacaec0041a370df713d0fd200358c94c
Module libblkid.so.1 with build-id 057b6bc8eebd42d1f5cafe4f4ac72646aae1f2c5
Module librt.so.1 with build-id 75484da2d6f1515189eefa076e0a40328834cd16
Module libXi.so.6 with build-id 16603be937a02a7e61b0b0395d064be7efd86f49
Module libXext.so.6 with build-id d70f24beb4fad748d6becffdcc13e51be0a2ebfa
Module libltdl.so.7 with build-id 64bc54a40a0b6e4209a2c712364b4ae653c3f5b2
Module libtdb.so.1 with build-id bec061530310665480ee91395b4eb0a937750a03
Module libvorbisfile.so.3 with build-id 0010b21da05e318b42e718d90738febf58028141
Module libQt5WaylandClient.so.5 with build-id 2cf7fefea430f7560bf5aa8d921f8c4e8f048fb8
Module libKF5AuthCore.so.5 with build-id d6c222c5566f4c7fc50695fdc36143a1b210bac0
Module libKF5Codecs.so.5 with build-id 72a2a63e7416a55d354a4aff199a3b6a0bf03e3c
Module liblzma.so.5 with build-id 8b615460aa230708c5183f16bede67aa0437d95e
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module libKF5Completion.so.5 with build-id 1a0549c505fa36da417ea35e97883267ef76177e
Module libKF5JobWidgets.so.5 with build-id 0690aa6a286cc9e7f6122343c79faab444957bc4
Module libKF5KIOCore.so.5 with build-id 97b93006b6a35dead8be176937e30c1b75640ac9
Module libcrypto.so.1.1 with build-id 4c926b672d97886b123e03a008387aecf0786de4
Module libssl.so.1.1 with build-id 1024424ab33a3767da03f4fdb1fc1b02479f160f
Module libgssapi_krb5.so.2 with build-id e6e098ad51ce7bdd3dbe902d7b0f69a90f8a9e08
Module libffi.so.8 with build-id f90d8b734f6de9b25faedb8cbfab7054dafc0a42
Module ld-linux-x86-64.so.2 with build-id 040cc3dd10461562f177df39e3be2f3704258c3c
Module libglib-2.0.so.0 with build-id 220436a4e27f39372710df014d2517c0387eefa4
Module libzstd.so.1 with build-id 6214183688018e3fba6d66db10c2c8d0b45e0578
Module libpcre2-16.so.0 with build-id 195fbccafbcff538ce13805ba687514fb614c5ed
Module libdl.so.2 with build-id 5abc547e7b0949f89f3c0e21ab0c8331a7440a8a
Module libicuuc.so.70 with build-id 2e245c2bf12f95fd8ab79b3a4be99524677cbd70
Module libicui18n.so.70 with build-id 95af755fca990df26753a7d720b8e3ae24270e42
Module libdouble-conversion.so.3 with build-id d162eb67b00f523a3f146b1077ae00fe04d5fb85
Module libsystemd.so.0 with build-id 69dfd360ef432adc8911dd446411765f1922fb48
Module libmd4c.so.0 with build-id 2151dba72cdc9960097e6e960a58a2f03c8bb96e
Module libharfbuzz.so.0 with build-id 1d9dee49dd99162c3f83eb3259c3c88c6b4cd7fe
Module libz.so.1 with build-id 0c1459c56513efd5d53eb3868290e9afee6a6a26
Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
Module libGL.so.1 with build-id 912ac4f37a9fa2d5abcf7a9088c9983cfe46f12a
Module libdbus-1.so.3 with build-id 74f2ab9c60512f3a93c932c3f627564d42e0b11e
Module libxcb-keysyms.so.1 with build-id 333e5eb4075795f947c924a2085f17e2e2ae7147
Module libgcc_s.so.1 with build-id 7f8508bb914546ada778809b64b99d234337d835
Module libpthread.so.0 with build-id 07c8f95b4f3251d08550217ad8a1f31066229996
Module libm.so.6 with build-id 2b8fd1f869ecab4e0b55e92f2f151897f6818acf
Module libQt5QmlModels.so.5 with build-id 0caff8beb5f70b5cc77a2fd8644ef7476de7cf45
Module libKF5ItemViews.so.5 with build-id e4757fd171ae6c4275382d433ed3bb697638686e
Module libKF5WidgetsAddons.so.5 with build-id 1ecb6c8da7ea562d7aff1acbdd19c74a1f9d393f
Module libQt5PrintSupport.so.5 with build-id 0f0f4b8fb8419929cdfdd238cc87f07ffaa83680
Module libplist-2.0.so.3 with build-id f16bdd42b3d750ba0a150d286248f5dc50cc76cb
Module libimobiledevice-1.0.so.6 with build-id bc258677480403cc2df4f0efcfc97e06af826ddc
Module libmount.so.1 with build-id 39e178b712b6635a8681182f7a9fbb64e6074aee
Module libudev.so.1 with build-id e7bd18780bd5753c14f8561be78e4e78ae0266ee
Module libQt5Xml.so.5 with build-id 6cdf028838bdf9341b52d534475cd2ca774b4f00
Module libdbusmenu-qt5.so.2 with build-id 346cd54093968d3de9e61cc329e9512d248dce18
Module libXtst.so.6 with build-id 96411faea62997274e362f263e65082e601a787b
Module libX11.so.6 with build-id 5ba5798d193c0065014b8c6252a0678671c8d478
Module libQt5TextToSpeech.so.5 with build-id 99b56b543380180d6f5c8c984f01d80487672cff
Module libcanberra.so.0 with build-id 379ed64f9d1408a83806cd5d94dc5bb903765615
Module libKF5GuiAddons.so.5 with build-id 3f8ebbfcec6b33d97aeb5234522e8d0a0b4c6b22
Module libKF5ConfigWidgets.so.5 with build-id 9e7e70e0550a5f02a8b95e0bb86b065a098105d5
Module libKF5Archive.so.5 with build-id 1edf6dc1ca4d38f0ebf6113fb089778b93085676
Module libQt5Svg.so.5 with build-id 8032519f22f34473a8cfdae1d933f60042a40aa1
Module libKF5KIOGui.so.5 with build-id 14950f98ef994c6b071d1444459d0ce69c79b008
Module libKF5KIOWidgets.so.5 with build-id 5ada62a44b5f4d375c9911d0cf27d836f966ee3c
Module libQt5Sql.so.5 with build-id 285217534c277ad967f3df927dce405895e9b57d
Module libXdmcp.so.6 with build-id 8ca0792d23c8b8b4c0864297512349292bea5955
Module libQt5Network.so.5 with build-id 5d5febbf1fc5bc522602a1f1751a9931fc05b78e
Module libXau.so.6 with build-id 1c67764663e07bec24d8951e5fd93f4d165979ff
Module libwayland-client.so.0 with build-id 0a237f2fd096bada4ca381eec5d64474c4078be4
Module libKF5IconThemes.so.5 with build-id a96c9d2a2b3585355c7efbb93eb6b74ffc9813fd
Module libxcb-shape.so.0 with build-id f1b3376c4534fab0469feb1cd19f022ff98df533
Module libc.so.6 with build-id 4b406737057708c0e4c642345a703c47a61c73dc
Module libstdc++.so.6 with build-id 9b5eeeb149bf3c4efe787fb398b44f00507aec87
Module libQt5Core.so.5 with build-id a6903ae93931b07f9214357aac2905372a406c16
Module libQt5Gui.so.5 with build-id b2687a129585978e2ffdb7a91e539c9561e0db3d
Module libQt5X11Extras.so.5 with build-id e41614d2e35852f913bf00633d635cfbf5a90dce
Module libQt5DBus.so.5 with build-id 2e76850f86958307f5d749c780f9f2587e14c9ff
Module libKF5ConfigCore.so.5 with build-id c58e94e4adb85b1097f065447c2af4cc585906ff
Module libKF5CoreAddons.so.5 with build-id 42164ce0f5987f623e5285b1ecd65ceeb0bfce2e
Module libKF5I18n.so.5 with build-id 141662ef754d2d992a1a32082b2f2ddb830676b8
Module libQt5Widgets.so.5 with build-id c5e2b10006d4c02d6421dd36c1a868191dea41fb
Module libKF5WindowSystem.so.5 with build-id 10d0f0de888eb46a1fddcb91ef4ea4dcb3f117f2
Module libKF5ConfigGui.so.5 with build-id 82585efd4a6c6078d45ba753f17a9a7e3f3e45ff
Module libQt5Qml.so.5 with build-id 212307572d9d92b0cb4d236fda1fe3f354b01093
Module libKF5DBusAddons.so.5 with build-id 2d3ca02cc76d878e00280b05ec8728c677dbd6b1
Module libKF5Service.so.5 with build-id d1b849804483cf5e5d045fb60432203206c2ed38
Module libQt5Quick.so.5 with build-id 2dca83de5d1ef02b8ef03fef5f18b531a2457e42
Module libKF5GlobalAccel.so.5 with build-id 76523e2497f0431f013016b5230a674a9bb7aece
Module libKF5XmlGui.so.5 with build-id 3d58ac806211e72b35b32ed884b9b610fad1da41
Module libKF5Crash.so.5 with build-id bb5c5cd905cfdd34bd246bed989f3989ec8bde08
Module libKF5Solid.so.5 with build-id 662e79a4f3becf542fa4cda8ada6723bb78295e1
Module libKF5Package.so.5 with build-id 9492efb4542d5c57531a07c62991a149232b0a21
Module libKF5Declarative.so.5 with build-id 83c0cde7ff07b1c9ec3f5142dd50076069949605
Module libKF5Notifications.so.5 with build-id cf776e57e2e8be19d6ccaec217f91db22751d115
Module libKF5Plasma.so.5 with build-id 7ac5e2f353ba47c4dff42030a193726be02d88da
Module libxcb-randr.so.0 with build-id b6c1c7d4b28863b55ade251813db7f246b7ffe8b
Module libxcb.so.1 with build-id 0d1ef11740a5daad2ee331e812a51aa6574af222
Module libKUserFeedbackCore.so.1 with build-id 495f85a1827b1732a0dfa93532a4101dafc11ac1
Module libkworkspace5.so.5 with build-id a38d7a6135aceba30e6996dfd8da86b79f85d536
Module libKF5WaylandClient.so.5 with build-id 62d9d21d32df6ff25802eeef87b59e7b0895af39
Module libKF5QuickAddons.so.5 with build-id fd00c054198847ab6d9e6c1142e512d53ec4cdbc
Module libKF5Activities.so.5 with build-id b500ac9d9db8af60bf0d5223c830887b1503612c
Module libKF5PlasmaQuick.so.5 with build-id e2abde03dd32c7004808046d0237eed544989787
Module plasmashell with build-id 0e0fdb5040ed557412429645775937c162472550
Stack trace of thread 965:
#0 0x00007f334a989d22 raise (libc.so.6 + 0x3cd22)
#1 0x00007f334a973862 abort (libc.so.6 + 0x26862)
#2 0x00007f334add0ee4 _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5 + 0x9fee4)
#3 0x00007f334b3899f5 _ZN22QGuiApplicationPrivate25createPlatformIntegrationEv (libQt5Gui.so.5 + 0x13a9f5)
#4 0x00007f334b38a019 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt5Gui.so.5 + 0x13b019)
#5 0x00007f334afc249b _ZN23QCoreApplicationPrivate4initEv (libQt5Core.so.5 + 0x29149b)
#6 0x00007f334b38a0d7 _ZN22QGuiApplicationPrivate4initEv (libQt5Gui.so.5 + 0x13b0d7)
#7 0x00007f334bc0437e _ZN19QApplicationPrivate4initEv (libQt5Widgets.so.5 + 0x17637e)
#8 0x00005578a5769338 n/a (plasmashell + 0x1d338)
#9 0x00007f334a974b25 __libc_start_main (libc.so.6 + 0x27b25)
#10 0x00005578a576c8de n/a (plasmashell + 0x208de)
