Suite du sujet [Stable Update] 2023-02-12 - Kernels, OpenSSL, Nvidia, Mesa, LibreOffice 7.5, Pamac, Thunderbird :
can you post more info
inxi -Fza
sudo mhwd-kernel -li
sudo mhwd -li
sudo systemd-analyze blame
inxi -Fza
sudo mhwd -li
Thanks for the help!
Kernel: 6.1.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=7203573d-0ddc-4484-933c-033127cfc0a1 rw amd_iommu=on iommu=pt
video=efifb:off quiet apparmor=1 security=apparmor
resume=UUID=b666983d-8b2e-4246-bada-d2ef3c249d31 udev.log_priority=3
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-E GAMING v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 4021 date: 08/09/2021
Info: model: AMD Ryzen 9 5900X socket: AM4 bits: 64 type: MT MCP
arch: Zen 3+ gen: 4 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 2450 high: 3700 min/max: 2200/4950 boost: enabled
base/boost: 3700/4950 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3700 2: 2200 3: 2200 4: 2200
5: 2200 6: 2200 7: 2200 8: 2200 9: 3700 10: 2200 11: 3700 12: 2200
13: 2200 14: 2200 15: 2200 16: 2200 17: 2200 18: 3700 19: 2200 20: 2200
21: 2200 22: 2200 23: 2200 24: 2200 bogomips: 177654
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] driver: amdgpu
v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1,DP-2
empty: DP-3,HDMI-A-1 bus-ID: 0c:00.0 chip-ID: 1002:73bf class-ID: 0300
Device-2: Logitech C922 Pro Stream Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-3:2 chip-ID: 046d:085c
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.7 compositor: kwin_x11 driver: X:
loaded: amdgpu dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 5120x1440 s-dpi: 96 s-size: 1354x381mm (53.31x15.00")
s-diag: 1407mm (55.38")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,left
model: MSI MAG274QRF-QD serial: <filter> built: 2021 res: 2560x1440 dpi: 109
gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
modes: max: 2560x1440 min: 640x480
Monitor-2: DP-2 mapped: DisplayPort-1 pos: right model: MSI MAG274QRF-QD
serial: <filter> built: 2021 res: 2560x1440 dpi: 109 gamma: 1.2
size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9 modes:
API: OpenGL v: 4.6 Mesa 22.3.5 renderer: AMD Radeon RX 6800 XT (navi21
LLVM 15.0.7 DRM 3.49 6.1.11-1-MANJARO) direct-render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
bus-ID: 1-3:2 chip-ID: 046d:085c gen: 4 class-ID: 0102 speed: 16 GT/s
lanes: 16 serial: <filter> bus-ID: 0c:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech C922 Pro Stream Webcam type: USB
Device-4: Cambridge Silicon Radio Audioengine HD3 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4:3 chip-ID: 0a12:1243
class-ID: 0300 serial: <filter>
Device-5: Corsair VIRTUOSO SE Wireless Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1:4 chip-ID: 1b1c:0a3e
Sound API: ALSA v: k6.1.11-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.65 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp4s0 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 06:00.0
IF: enp6s0 state: down mac: <filter>
IF-ID-1: br-0a335d8d225c state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: virbr0 state: down mac: <filter>
IF-ID-4: virbr1 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-6:5
Local Storage: total: 931.51 GiB used: 538.62 GiB (57.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 type: SSD serial: <filter> rev: 2B2QGXA7 temp: 56.9 C scheme: GPT
SMART: yes health: PASSED on: 52d 17h cycles: 628
read-units: 40,818,242 [20.8 TB] written-units: 39,074,646 [20.0 TB]
ID-1: / raw-size: 862.15 GiB size: 847.54 GiB (98.31%)
used: 538.62 GiB (63.6%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 288 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 69.07 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 50.0 C mobo: 44.0 C gpu: amdgpu temp: 63.0 C
mem: 62.0 C
Fan Speeds (RPM): fan-1: 1038 fan-2: 834 fan-3: 681 fan-4: 0 fan-5: 0
fan-6: 0 gpu: amdgpu fan: 656
Processes: 492 Uptime: 11h 5m wakeups: 0 Memory: 62.71 GiB
used: 13.8 GiB (22.0%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1767
pm: pacman pkgs: 1744 libs: 462 tools: pamac,pikaur pm: flatpak pkgs: 23
Shell: Zsh (sudo) v: 5.9 running-in: konsole inxi: 3.3.25
Currently running: 6.1.11-1-MANJARO (linux61)
* linux510
* linux515
* linux61
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
6.313s NetworkManager-wait-online.service
1.533s docker.service
846ms dev-nvme0n1p2.device
777ms man-db.service
716ms ufw.service
463ms mnt-nas-photos.mount
455ms mnt-nas-container\x2dapps.mount
451ms systemd-udev-trigger.service
449ms mnt-nas-documents.mount
443ms mnt-nas-multimedia.mount
434ms mnt-nas-work.mount
392ms systemd-remount-fs.service
329ms systemd-modules-load.service
276ms modprobe@fuse.service
241ms lvm2-monitor.service
240ms modprobe@drm.service
209ms tlp.service
205ms avahi-daemon.service
204ms polkit.service
203ms lm_sensors.service
195ms systemd-tmpfiles-setup-dev.service
182ms apparmor.service
166ms snapd.service
163ms systemd-logind.service
163ms systemd-machined.service
136ms systemd-tmpfiles-setup.service
133ms systemd-journal-flush.service
129ms systemd-sysctl.service
117ms user@1000.service
106ms systemd-random-seed.service
82ms alsa-restore.service
82ms linux-module-cleanup.service
81ms dbus.service
73ms cups.service
67ms systemd-tmpfiles-clean.service
67ms boot-efi.mount
60ms systemd-rfkill.service
52ms systemd-binfmt.service
48ms systemd-fsck@dev-disk-by\x2duuid-AFF8\x2dF7D7.service
46ms systemd-timesyncd.service
46ms systemd-update-utmp.service
45ms snapd.apparmor.service
41ms modprobe@configfs.service
41ms kmod-static-nodes.service
40ms libvirtd.service
38ms systemd-user-sessions.service
37ms NetworkManager.service
35ms upower.service
34ms systemd-journald.service
30ms user-runtime-dir@1000.service
29ms systemd-udevd.service
28ms ModemManager.service
27ms udisks2.service
26ms accounts-daemon.service
15ms dev-disk-by\x2duuid-b666983d\x2d8b2e\x2d4246\x2dbada\x2dd2ef3c249d31.swap
12ms bluetooth.service
11ms sys-fs-fuse-connections.mount
11ms sys-kernel-config.mount
9ms colord.service
6ms dev-hugepages.mount
5ms dev-mqueue.mount
5ms sys-kernel-debug.mount
5ms sys-kernel-tracing.mount
4ms wpa_supplicant.service
1ms rtkit-daemon.service
1ms docker.socket
892us proc-sys-fs-binfmt_misc.mount
802us tmp.mount
268us snapd.socket
why are you using these option ?
your video card is not a passthrough
you can remove amd_iommu=on ,
activate before cppc in your motherboard for amd pstate
amd_pstate=passive nvme_load=YES processor.max_cstate=5
you may also see for
systemd.unified_cgroup_hierarchy=true scsi_mod.use_blk_mq=1
you can remove tlp service , and stop theses
sudo systemctl mask lvm2-monitor.service
sudo systemctl mask ModemManager.service ( if you not using for your phone )
you may need haveged if entropy is too low for sddm
see also to upgrade your UEFI version
see point for Bios 4403 or 4408
Can you post systemctl
You also using both Pulseaudio and Pipewire.
Are you using docker ?
Do you use baloo ?
I actually have a similar (maybe related) problem: I have a Synology NAS and use the package synology-drive-client. Whenever it starts, the whole system freezes for 10 seconds, then it runs fine. Maybe correlated?
I have those options on because I use single gpu passthrough with my windows 11 vm, for some games that don’t run on linux. That’s why I didn’t upgrade my bios, got single gpu working finally after 123761 years . But I will try to upgrade my bios, because of the random stuttering it can probably fix (although mine is not that random, but still worth it, to rule that out)!
For more information, I used this single gpu tutorial. But I already have this running for a year, so I don’t know if this is the case of the stuttering.
activater before cppc in your motherboard for amd pstate
So for this I need to check my bios and add it to the GRUB_CMDLINE_LINUX
if I’m correct?
sudo systemctl mask lvm2-monitor.service sudo systemctl mask ModemManager.service ( if you not using for your phone )
I will try it out! Thanks for the suggestions!
UNIT LOAD ACTIVE SUB DESCRIPTION
proc-sys-fs-binfmt_misc.automount loaded active running Arbitrary Executable File Formats File System Automount Point
sys-devices-LNXSYSTM:00-LNXSYBUS:00-MSFT0101:00-tpm-tpm0.device loaded active plugged /sys/devices/LNXSYSTM:00/LNXSYBUS:00/MSFT0101:00/tpm/tpm0
sys-devices-LNXSYSTM:00-LNXSYBUS:00-MSFT0101:00-tpmrm-tpmrm0.device loaded active plugged /sys/devices/LNXSYSTM:00/LNXSYBUS:00/MSFT0101:00/tpmrm/tpmrm0
sys-devices-pci0000:00-0000:00:01.1-0000:01:00.0-nvme-nvme0-nvme0n1-nvme0n1p1.device loaded active plugged Samsung SSD 980 PRO 1TB NO_LABEL
sys-devices-pci0000:00-0000:00:01.1-0000:01:00.0-nvme-nvme0-nvme0n1-nvme0n1p2.device loaded active plugged Samsung SSD 980 PRO 1TB 2
sys-devices-pci0000:00-0000:00:01.1-0000:01:00.0-nvme-nvme0-nvme0n1-nvme0n1p3.device loaded active plugged Samsung SSD 980 PRO 1TB 3
sys-devices-pci0000:00-0000:00:01.1-0000:01:00.0-nvme-nvme0-nvme0n1.device loaded active plugged Samsung SSD 980 PRO 1TB
sys-devices-pci0000:00-0000:00:01.2-0000:02:00.0-0000:03:03.0-0000:04:00.0-net-wlp4s0.device loaded active plugged Wi-Fi 6 AX200 (NGW)
sys-devices-pci0000:00-0000:00:01.2-0000:02:00.0-0000:03:04.0-0000:05:00.0-net-enp5s0.device loaded active plugged RTL8125 2.5GbE Controller
sys-devices-pci0000:00-0000:00:01.2-0000:02:00.0-0000:03:05.0-0000:06:00.0-net-enp6s0.device loaded active plugged I211 Gigabit Network Connection
sys-devices-pci0000:00-0000:00:01.2-0000:02:00.0-0000:03:08.0-0000:07:00.1-usb1-1\x2d3-1\x2d3:1.2-sound-card2-controlC2.device loaded active plugged C922_Pro_Stream_Webcam
sys-devices-pci0000:00-0000:00:01.2-0000:02:00.0-0000:03:08.0-0000:07:00.1-usb1-1\x2d4-1\x2d4:1.0-sound-card3-controlC3.device loaded active plugged Audioengine_HD3
sys-devices-pci0000:00-0000:00:01.2-0000:02:00.0-0000:03:08.0-0000:07:00.1-usb1-1\x2d6-1\x2d6:1.0-bluetooth-hci0.device loaded active plugged /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:07:00.1/usb1/1-6/1-6:1.0/bluetooth/hci0
sys-devices-pci0000:00-0000:00:01.2-0000:02:00.0-0000:03:08.0-0000:07:00.3-usb3-3\x2d1-3\x2d1:1.0-sound-card4-controlC4.device loaded active plugged CORSAIR_VIRTUOSO_SE_Wireless_Gaming_Headset
sys-devices-pci0000:00-0000:00:03.1-0000:0a:00.0-0000:0b:00.0-0000:0c:00.1-sound-card0-controlC0.device loaded active plugged /sys/devices/pci0000:00/0000:00:03.1/0000:0a:00.0/0000:0b:00.0/0000:0c:00.1/sound/card0/controlC0
sys-devices-pci0000:00-0000:00:08.1-0000:0e:00.4-sound-card1-controlC1.device loaded active plugged /sys/devices/pci0000:00/0000:00:08.1/0000:0e:00.4/sound/card1/controlC1
sys-devices-platform-serial8250-tty-ttyS0.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS0
sys-devices-platform-serial8250-tty-ttyS1.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS1
sys-devices-platform-serial8250-tty-ttyS10.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS10
sys-devices-platform-serial8250-tty-ttyS11.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS11
sys-devices-platform-serial8250-tty-ttyS12.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS12
sys-devices-platform-serial8250-tty-ttyS13.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS13
sys-devices-platform-serial8250-tty-ttyS14.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS14
sys-devices-platform-serial8250-tty-ttyS15.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS15
sys-devices-platform-serial8250-tty-ttyS16.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS16
sys-devices-platform-serial8250-tty-ttyS17.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS17
sys-devices-platform-serial8250-tty-ttyS18.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS18
sys-devices-platform-serial8250-tty-ttyS19.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS19
sys-devices-platform-serial8250-tty-ttyS2.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS2
sys-devices-platform-serial8250-tty-ttyS20.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS20
sys-devices-platform-serial8250-tty-ttyS21.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS21
sys-devices-platform-serial8250-tty-ttyS22.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS22
sys-devices-platform-serial8250-tty-ttyS23.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS23
sys-devices-platform-serial8250-tty-ttyS24.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS24
sys-devices-platform-serial8250-tty-ttyS25.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS25
sys-devices-platform-serial8250-tty-ttyS26.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS26
sys-devices-platform-serial8250-tty-ttyS27.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS27
sys-devices-platform-serial8250-tty-ttyS28.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS28
sys-devices-platform-serial8250-tty-ttyS29.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS29
sys-devices-platform-serial8250-tty-ttyS3.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS3
sys-devices-platform-serial8250-tty-ttyS30.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS30
sys-devices-platform-serial8250-tty-ttyS31.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS31
sys-devices-platform-serial8250-tty-ttyS4.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS4
sys-devices-platform-serial8250-tty-ttyS5.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS5
sys-devices-platform-serial8250-tty-ttyS6.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS6
sys-devices-platform-serial8250-tty-ttyS7.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS7
sys-devices-platform-serial8250-tty-ttyS8.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS8
sys-devices-platform-serial8250-tty-ttyS9.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS9
sys-devices-virtual-misc-rfkill.device loaded active plugged /sys/devices/virtual/misc/rfkill
sys-devices-virtual-net-br\x2d0a335d8d225c.device loaded active plugged /sys/devices/virtual/net/br-0a335d8d225c
sys-devices-virtual-net-docker0.device loaded active plugged /sys/devices/virtual/net/docker0
sys-devices-virtual-net-virbr0.device loaded active plugged /sys/devices/virtual/net/virbr0
sys-devices-virtual-net-virbr1.device loaded active plugged /sys/devices/virtual/net/virbr1
sys-module-configfs.device loaded active plugged /sys/module/configfs
sys-module-fuse.device loaded active plugged /sys/module/fuse
sys-subsystem-bluetooth-devices-hci0.device loaded active plugged /sys/subsystem/bluetooth/devices/hci0
sys-subsystem-net-devices-br\x2d0a335d8d225c.device loaded active plugged /sys/subsystem/net/devices/br-0a335d8d225c
sys-subsystem-net-devices-docker0.device loaded active plugged /sys/subsystem/net/devices/docker0
sys-subsystem-net-devices-enp5s0.device loaded active plugged RTL8125 2.5GbE Controller
sys-subsystem-net-devices-enp6s0.device loaded active plugged I211 Gigabit Network Connection
sys-subsystem-net-devices-virbr0.device loaded active plugged /sys/subsystem/net/devices/virbr0
sys-subsystem-net-devices-virbr1.device loaded active plugged /sys/subsystem/net/devices/virbr1
sys-subsystem-net-devices-wlp4s0.device loaded active plugged Wi-Fi 6 AX200 (NGW)
-.mount loaded active mounted Root Mount
boot-efi.mount loaded active mounted /boot/efi
dev-hugepages.mount loaded active mounted Huge Pages File System
dev-mqueue.mount loaded active mounted POSIX Message Queue File System
mnt-nas-container\x2dapps.mount loaded active mounted /mnt/nas/container-apps
mnt-nas-documents.mount loaded active mounted /mnt/nas/documents
mnt-nas-multimedia.mount loaded active mounted /mnt/nas/multimedia
mnt-nas-photos.mount loaded active mounted /mnt/nas/photos
mnt-nas-work.mount loaded active mounted /mnt/nas/work
proc-sys-fs-binfmt_misc.mount loaded active mounted Arbitrary Executable File Formats File System
run-credentials-systemd\x2dsysctl.service.mount loaded active mounted /run/credentials/systemd-sysctl.service
run-credentials-systemd\x2dtmpfiles\x2dsetup.service.mount loaded active mounted /run/credentials/systemd-tmpfiles-setup.service
run-credentials-systemd\x2dtmpfiles\x2dsetup\x2ddev.service.mount loaded active mounted /run/credentials/systemd-tmpfiles-setup-dev.service
run-user-1000-doc.mount loaded active mounted /run/user/1000/doc
run-user-1000-gvfs.mount loaded active mounted /run/user/1000/gvfs
run-user-1000.mount loaded active mounted /run/user/1000
sys-fs-fuse-connections.mount loaded active mounted FUSE Control File System
sys-kernel-config.mount loaded active mounted Kernel Configuration File System
sys-kernel-debug.mount loaded active mounted Kernel Debug File System
sys-kernel-tracing.mount loaded active mounted Kernel Trace File System
tmp.mount loaded active mounted Temporary Directory /tmp
cups.path loaded active running CUPS Scheduler
systemd-ask-password-console.path loaded active waiting Dispatch Password Requests to Console Directory Watch
systemd-ask-password-wall.path loaded active waiting Forward Password Requests to Wall Directory Watch
init.scope loaded active running System and Service Manager
session-2.scope loaded active running Session 2 of User brtualis
accounts-daemon.service loaded active running Accounts Service
alsa-restore.service loaded active exited Save/Restore Sound Card State
apparmor.service loaded active exited Load AppArmor profiles
avahi-daemon.service loaded active running Avahi mDNS/DNS-SD Stack
bluetooth.service loaded active running Bluetooth service
colord.service loaded active running Manage, Install and Generate Color Profiles
cronie.service loaded active running Periodic Command Scheduler
cups.service loaded active running CUPS Scheduler
dbus.service loaded active running D-Bus System Message Bus
devolonetsvc.service loaded active running devolo Network Service
docker.service loaded active running Docker Application Container Engine
kmod-static-nodes.service loaded active exited Create List of Static Device Nodes
lm_sensors.service loaded active exited Initialize hardware monitoring sensors
lvm2-monitor.service loaded active exited Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling
ModemManager.service loaded active running Modem Manager
NetworkManager-wait-online.service loaded active exited Network Manager Wait Online
NetworkManager.service loaded active running Network Manager
polkit.service loaded active running Authorization Manager
rtkit-daemon.service loaded active running RealtimeKit Scheduling Policy Service
sddm.service loaded active running Simple Desktop Display Manager
snapd.apparmor.service loaded active exited Load AppArmor profiles managed internally by snapd
sshd.service loaded active running OpenSSH Daemon
systemd-binfmt.service loaded active exited Set Up Additional Binary Formats
systemd-fsck@dev-disk-by\x2duuid-AFF8\x2dF7D7.service loaded active exited File System Check on /dev/disk/by-uuid/AFF8-F7D7
systemd-journal-flush.service loaded active exited Flush Journal to Persistent Storage
systemd-journald.service loaded active running Journal Service
systemd-logind.service loaded active running User Login Management
systemd-machined.service loaded active running Virtual Machine and Container Registration Service
systemd-modules-load.service loaded active exited Load Kernel Modules
systemd-random-seed.service loaded active exited Load/Save Random Seed
systemd-remount-fs.service loaded active exited Remount Root and Kernel File Systems
systemd-sysctl.service loaded active exited Apply Kernel Variables
systemd-timesyncd.service loaded active running Network Time Synchronization
systemd-tmpfiles-setup-dev.service loaded active exited Create Static Device Nodes in /dev
systemd-tmpfiles-setup.service loaded active exited Create Volatile Files and Directories
systemd-udev-trigger.service loaded active exited Coldplug All udev Devices
systemd-udevd.service loaded active running Rule-based Manager for Device Events and Files
systemd-update-utmp.service loaded active exited Record System Boot/Shutdown in UTMP
systemd-user-sessions.service loaded active exited Permit User Sessions
tlp.service loaded active exited TLP system startup/shutdown
udisks2.service loaded active running Disk Manager
ufw.service loaded active exited CLI Netfilter Manager
upower.service loaded active running Daemon for power management
user-runtime-dir@1000.service loaded active exited User Runtime Directory /run/user/1000
user@1000.service loaded active running User Manager for UID 1000
wpa_supplicant.service loaded active running WPA supplicant
-.slice loaded active active Root Slice
machine.slice loaded active active Virtual Machine and Container Slice
system-getty.slice loaded active active Slice /system/getty
system-modprobe.slice loaded active active Slice /system/modprobe
system-systemd\x2dfsck.slice loaded active active Slice /system/systemd-fsck
system.slice loaded active active System Slice
user-1000.slice loaded active active User Slice of UID 1000
user.slice loaded active active User and Session Slice
avahi-daemon.socket loaded active running Avahi mDNS/DNS-SD Stack Activation Socket
cups.socket loaded active running CUPS Scheduler
dbus.socket loaded active running D-Bus System Message Bus Socket
dm-event.socket loaded active listening Device-mapper event daemon FIFOs
docker.socket loaded active running Docker Socket for the API
libvirtd-admin.socket loaded active listening Libvirt admin socket
libvirtd-ro.socket loaded active listening Libvirt local read-only socket
libvirtd.socket loaded active listening Libvirt local socket
lvm2-lvmpolld.socket loaded active listening LVM2 poll daemon socket
snapd.socket loaded active listening Socket activation for snappy daemon
systemd-coredump.socket loaded active listening Process Core Dump Socket
systemd-journald-audit.socket loaded active running Journal Audit Socket
systemd-journald-dev-log.socket loaded active running Journal Socket (/dev/log)
systemd-journald.socket loaded active running Journal Socket
systemd-rfkill.socket loaded active listening Load/Save RF Kill Switch Status /dev/rfkill Watch
systemd-udevd-control.socket loaded active running udev Control Socket
systemd-udevd-kernel.socket loaded active running udev Kernel Socket
virtlockd.socket loaded active listening Virtual machine lock manager socket
virtlogd.socket loaded active listening Virtual machine log manager socket
dev-disk-by\x2duuid-b666983d\x2d8b2e\x2d4246\x2dbada\x2dd2ef3c249d31.swap loaded active active /dev/disk/by-uuid/b666983d-8b2e-4246-bada-d2ef3c249d31
basic.target loaded active active Basic System
bluetooth.target loaded active active Bluetooth Support
cryptsetup.target loaded active active Local Encrypted Volumes
getty.target loaded active active Login Prompts
graphical.target loaded active active Graphical Interface
integritysetup.target loaded active active Local Integrity Protected Volumes
local-fs-pre.target loaded active active Preparation for Local File Systems
local-fs.target loaded active active Local File Systems
multi-user.target loaded active active Multi-User System
network-online.target loaded active active Network is Online
network.target loaded active active Network
nss-user-lookup.target loaded active active User and Group Name Lookups
paths.target loaded active active Path Units
remote-fs.target loaded active active Remote File Systems
slices.target loaded active active Slice Units
snapd.mounts-pre.target loaded active active Mounting snaps
snapd.mounts.target loaded active active Mounted snaps
sockets.target loaded active active Socket Units
sound.target loaded active active Sound Card
swap.target loaded active active Swaps
sysinit.target loaded active active System Initialization
time-set.target loaded active active System Time Set
timers.target loaded active active Timer Units
veritysetup.target loaded active active Local Verity Protected Volumes
archlinux-keyring-wkd-sync.timer loaded active waiting Refresh existing PGP keys of archlinux-keyring regularly
logrotate.timer loaded active waiting Daily rotation of log files
man-db.timer loaded active waiting Daily man-db regeneration
pamac-cleancache.timer loaded active waiting Monthly clean packages cache
pamac-mirrorlist.timer loaded active waiting Generate mirrorlist weekly
pkgfile-update.timer loaded active waiting pkgfile database update timer
shadow.timer loaded active waiting Daily verification of password and group files
systemd-tmpfiles-clean.timer loaded active waiting Daily Cleanup of Temporary Directories
LOAD = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB = The low-level unit activation state, values depend on unit type.
196 loaded units listed. Pass --all to see loaded but inactive units, too.
To show all installed unit files use 'systemctl list-unit-files'.
I have never installed them manually, so I don’t know how they are both installed/enabled…
Yes for development purposes
Didn’t know what it was until I googled for it . But I don’t have it installed on my system.
@Knecker
I can’t reply anymore, because of the forum limitation apparently:
It could be, I use a Qnap nas system and I use auto mount via fstab, but It didn’t freeze until now.
Edit—
I can’t reply anymore, but this is solved:
I have updated my bios to the latest version and all settings are returned to the default, but that didn’t stop the freezing. I have installed the latest update for a few days now and that seems to have solved the freezing for me… [Stable Update] 2023-02-20 - Kernels, GNOME, NetworkManager, KDE Frameworks, Firefox
The problem resolved itself miraculously after the last update. I still have no idea, what caused it.
