Hi everybody
Manjaro with all last updates, kernel 6.7.12-1-MANJARO, KDE Plasma.
Last couple of days noticed that Alt shortcuts stopped working E.g. Alt-F2, Alt-Space, Alt-tab - no reaction.
Logged out and back in - everything works.
After some time - the same ā ā ā ā again.
Strange is that Alt-Ctrl-F3 works.
In Konsole Alt- combinations for MC still are working, even Alt-Tab. which has in MC different meaning.
In Konsole, if I press Alt-Tab, itās just printing āQā in command string (instead of running Krunner).
It seems that all the rest is working.
Restart - everything is working again. Checking logs didnāt gave anything.
Any ideas will be highly appreciated.
Thank you beforehand.
I had some slight issues with shortcuts - some caused by running Easystroke, and others which cleared up (after upgrading to Wayland) by cleaning out my $USER-SH1T ā¢ so it is rather important to mention if youāre in a Wayland or X11 sessionā¦
Itās very likely a $PEBCAK issue.
Iād suggest making a new USER and testing out your theory with a new profile.
If clear, then move your .config to .configBORKED and log out/in again, test againā¦
Also be sure to check logs.
For your āinformationā for a basic start, you can open your menu and type āinfoā and then copy and paste it between some backticks like this:
Code Here
Then you see:
KDE Plasma Version: 6.0.3
KDE Frameworks Version: 6.0.0
Qt Version: 6.6.3
Kernel Version: 6.8.4-1-MANJARO (64-bit)
Graphics Platform: Wayland
Processors: 12 Ć AMD Ryzen 5 5600G with Radeon Graphics
Memory: 15.0 GiB of RAM
Graphics Processor: AMD Radeon Graphics
Product Name: B550M Steel Legend
Then the clever members of the forum wonāt complain so much
KDE Plasma Version: 5.27.11
KDE Frameworks Version: 5.115.0
Qt Version: 5.15.12
Kernel Version: 6.7.12-1-MANJARO (64-bit)
Graphics Platform: X11
Processors: 8 Ć IntelĀ® XeonĀ® CPU E3-1245 v3 @ 3.40GHz
Memory: 30.9 GiB of RAM
Graphics Processor: Mesa IntelĀ® HD Graphics P4600/P4700
Manufacturer: Hewlett-Packard
Product Name: HP Z230 Tower Workstation
And:
I never used Wayland
I have no clue what is Easystroke and probably had never used it
Logs didnāt show anything interesting.
The problem is that it doesnāt happen immediately, but after some time after restart or logout/login.
Actually Iāve restarted comp on Friday before leaving to home, it was working, and now when I came back on monday it did it again
Iām using Anydesk to connect my comp from outside, I was using TeamViewer before but itās not working now, so I switched to Anydesk. And it has some strange behaviour with keys, for example in Midnight Commnader some Alt- combinations are not workingā¦ May it be related?
Most assuredly it might. However, it might not also. The only way to confirm this speculation/theory would be to uninstall as far as Iām aware. I have anydesk here as well, although I use it very rarely and only ever as a client. It worked well every time Iāve tried it.
To remove it:
pamac remove anydesk-bin
I donāt think any user config will be removed.
Tip
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, beforeANDafter the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
Additionally
If your language isnāt English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
