rve
17 February 2023 20:17
1
Hello. I have updated the system and the kernel, but now the graphical shell is partially working and partially not working.
I recorded a video of what was happening and attached a link (sorry for shooting from the phone, OBS does not work in this system).
disk(.)yandex(.)ru/i/MiZIabHSWE61qQ
I will be grateful for your help)
brahma
17 February 2023 21:08
2
rerun update again, to see if you are up to date…
and it looks like this issue:
The issue seems to be within the file .config/plasma-org.kde.plasma.desktop-appletsrc, specifically within this section:
[ScreenMapping]
itemsOnDisabledScreens=
After deleting the section (best to use vim or something that works on ~20 MB file), and rebooting, everything is back to normal.
if editing the config doestn work, rename the .config folder as instructed in the same link
rve
18 February 2023 07:51
3
Thanks
it turned out not to be necessary to roll back the system. Just after updating and editing through Kate, even without root
.config/plasma-org.kde.plasma.desktop-appletsrc - everything
worked out)
system
Closed
20 February 2023 21:51
4
