KDE Plasma password dialog does not appear
There are occasions ( it seems to be random and I have not discerned a pattern) when after the screen switches off, on waking the screen does not show a password dialog and I have to reboot to get back into the system.
Can anyone suggest a solution?
Manjaro: 5.15.76-1-MANJARO
KDE Plasma: 5.26.2
KDE Frameworks: 5.99.0
Update system, the current Plasma is 5.26.3
And also provide more information
I’ve upgraded :slight_smile:
I’ll see if I still get the problem and return with more info
You can also switch to another tty and use
$ loginctl unlock-session $session-id
to unlock that session.
https://man.archlinux.org/man/loginctl.1.en
