When i use my computer it freezes sometimes for no reason and i am not able to do nothing but force shut down.
Please help me.
I have attached the logs to this comment
mar 05 16:03:18 sagar-82c7 pamac-tray-plas[855]: updates_checker.vala:71: check updates
mar 05 16:04:12 sagar-82c7 anacron[4053]: Job `cron.weekly' started
mar 05 16:11:14 sagar-82c7 kernel: perf: interrupt took too long (6509 > 6481), lowering kernel.perf_event_max_sample_rate to 30600
mar 05 16:11:14 sagar-82c7 kernel: audit: type=1701 audit(1678028795.223:98): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=227 comm="systemd-journal" exe="/usr/lib/>
mar 05 16:11:14 sagar-82c7 systemd[1]: systemd-journald.service: State 'stop-watchdog' timed out. Killing.
mar 05 16:11:14 sagar-82c7 systemd[1]: systemd-journald.service: Killing process 227 (systemd-journal) with signal SIGKILL.
mar 05 16:11:14 sagar-82c7 systemd[1]: systemd-journald.service: Main process exited, code=killed, status=9/KILL
mar 05 16:11:14 sagar-82c7 systemd[1]: systemd-journald.service: Failed with result 'watchdog'.
mar 05 16:11:14 sagar-82c7 kernel: audit: type=1131 audit(1678028942.594:99): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe>
mar 05 16:11:14 sagar-82c7 kernel: audit: type=1334 audit(1678028942.600:100): prog-id=24 op=UNLOAD
mar 05 16:11:14 sagar-82c7 systemd[1]: systemd-journald.service: Consumed 2.922s CPU time.
mar 05 16:11:14 sagar-82c7 systemd[1]: systemd-journald.service: Scheduled restart job, restart counter is at 1.
mar 05 16:11:14 sagar-82c7 systemd[1]: Stopped Journal Service.
mar 05 16:11:14 sagar-82c7 kernel: audit: type=1130 audit(1678028948.544:101): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" ex>
mar 05 16:11:14 sagar-82c7 kernel: audit: type=1131 audit(1678028949.690:102): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" ex>
mar 05 16:11:14 sagar-82c7 kernel: audit: type=1334 audit(1678028987.840:103): prog-id=42 op=LOAD
mar 05 16:11:14 sagar-82c7 kernel: audit: type=1334 audit(1678028988.170:104): prog-id=43 op=LOAD
mar 05 16:11:14 sagar-82c7 kernel: audit: type=1334 audit(1678028988.174:105): prog-id=44 op=LOAD
mar 05 16:11:14 sagar-82c7 kernel: audit: type=1334 audit(1678028988.174:106): prog-id=25 op=UNLOAD
mar 05 16:11:14 sagar-82c7 kernel: audit: type=1334 audit(1678028988.174:107): prog-id=26 op=UNLOAD
mar 05 16:11:14 sagar-82c7 systemd[1]: Starting Journal Service...
mar 05 16:11:14 sagar-82c7 systemd-coredump[5262]: Failed to get COMM: No such process
mar 05 16:11:14 sagar-82c7 kernel: audit: type=1305 audit(1678029074.014:108): op=set audit_enabled=1 old=1 auid=4294967295 ses=4294967295 res=1
mar 05 16:11:14 sagar-82c7 kernel: audit: type=1300 audit(1678029074.014:108): arch=c000003e syscall=46 success=yes exit=60 a0=3 a1=7ffc3035e5b0 a2=4000 a3=7ffc3035e6>
mar 05 16:11:14 sagar-82c7 kernel: audit: type=1327 audit(1678029074.014:108): proctitle="/usr/lib/systemd/systemd-journald"
mar 05 16:11:14 sagar-82c7 systemd[1]: Starting Network Manager Script Dispatcher Service...
mar 05 16:11:14 sagar-82c7 systemd-journald[5275]: File /var/log/journal/34acd73cdeac4eb8ba1ff62c29d35e9c/system.journal corrupted or uncleanly shut down, renaming an>
mar 05 16:11:14 sagar-82c7 systemd-journald[5275]: Journal started
mar 05 16:11:14 sagar-82c7 systemd-journald[5275]: System Journal (/var/log/journal/34acd73cdeac4eb8ba1ff62c29d35e9c) is 220.4M, max 4.0G, 3.7G free.
mar 05 16:06:35 sagar-82c7 audit[227]: ANOM_ABEND auid=4294967295 uid=0 gid=0 ses=4294967295 pid=227 comm="systemd-journal" exe="/usr/lib/systemd/systemd-journald" si>
mar 05 16:09:02 sagar-82c7 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" >
mar 05 16:09:02 sagar-82c7 audit: BPF prog-id=24 op=UNLOAD
mar 05 16:09:08 sagar-82c7 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd">
mar 05 16:09:09 sagar-82c7 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" >
mar 05 16:09:47 sagar-82c7 audit: BPF prog-id=42 op=LOAD
mar 05 16:09:48 sagar-82c7 audit: BPF prog-id=43 op=LOAD
mar 05 16:09:48 sagar-82c7 audit: BPF prog-id=44 op=LOAD
mar 05 16:09:48 sagar-82c7 audit: BPF prog-id=25 op=UNLOAD
mar 05 16:09:48 sagar-82c7 audit: BPF prog-id=26 op=UNLOAD
mar 05 16:11:14 sagar-82c7 audit: CONFIG_CHANGE op=set audit_enabled=1 old=1 auid=4294967295 ses=4294967295 res=1
mar 05 16:11:14 sagar-82c7 audit[5275]: SYSCALL arch=c000003e syscall=46 success=yes exit=60 a0=3 a1=7ffc3035e5b0 a2=4000 a3=7ffc3035e63c items=0 ppid=1 pid=5275 auid>
mar 05 16:11:14 sagar-82c7 audit: PROCTITLE proctitle="/usr/lib/systemd/systemd-journald"
mar 05 16:06:27 sagar-82c7 systemd[1]: systemd-journald.service: Watchdog timeout (limit 3min)!
mar 05 16:11:14 sagar-82c7 systemd[1]: Started Journal Service.
mar 05 16:11:14 sagar-82c7 kernel: audit: type=1130 audit(1678029074.074:109): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" ex>
mar 05 16:11:14 sagar-82c7 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd">
mar 05 16:05:11 sagar-82c7 wpa_supplicant[448]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-33 noise=9999 txrate=144400
mar 05 16:06:35 sagar-82c7 systemd[1]: systemd-journald.service: Killing process 227 (systemd-journal) with signal SIGABRT.
mar 05 16:05:42 sagar-82c7 wpa_supplicant[448]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-37 noise=9999 txrate=144400
mar 05 16:10:03 sagar-82c7 org_kde_powerdevil[722]: kf.auth: Tried to start an invalid action: "org.kde.powerdevil.backlighthelper.setbrightness"
mar 05 16:11:14 sagar-82c7 systemd-journald[5275]: File /var/log/journal/34acd73cdeac4eb8ba1ff62c29d35e9c/user-1000.journal corrupted or uncleanly shut down, renaming>
mar 05 16:08:01 sagar-82c7 wpa_supplicant[448]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-33 noise=9999 txrate=144400
mar 05 16:10:08 sagar-82c7 org_kde_powerdevil[722]: org.kde.powerdevil: Failed to set screen brightness "Tentato l'avvio di un'azione non valida"
mar 05 16:08:44 sagar-82c7 wpa_supplicant[448]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-31 noise=9999 txrate=144400
mar 05 16:10:42 sagar-82c7 NetworkManager[356]: <info> [1678029042.1989] manager: NetworkManager state is now CONNECTED_SITE
mar 05 16:09:13 sagar-82c7 anacron[4053]: Job `cron.weekly' terminated
mar 05 16:11:14 sagar-82c7 NetworkManager[356]: <info> [1678029074.0427] manager: NetworkManager state is now CONNECTED_GLOBAL
mar 05 16:10:45 sagar-82c7 dbus-daemon[325]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.se>
mar 05 16:11:12 sagar-82c7 dbus-daemon[325]: [system] Failed to activate service 'org.freedesktop.nm_dispatcher': timed out (service_start_timeout=25000ms)
mar 05 16:11:14 sagar-82c7 dbus-daemon[325]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.se>
mar 05 16:11:14 sagar-82c7 dbus-daemon[325]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
mar 05 16:11:14 sagar-82c7 systemd[1]: Started Network Manager Script Dispatcher Service.
mar 05 16:11:14 sagar-82c7 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd>
mar 05 16:11:14 sagar-82c7 kernel: audit: type=1130 audit(1678029074.177:110): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="sy>
mar 05 16:11:14 sagar-82c7 dbus-daemon[325]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.39' (uid=1000 pid=722 comm="/usr/l>
mar 05 16:11:15 sagar-82c7 dbus-daemon[325]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
mar 05 16:11:21 sagar-82c7 kernel: chrome invoked oom-killer: gfp_mask=0x140cca(GFP_HIGHUSER_MOVABLE|__GFP_COMP), order=0, oom_score_adj=300
mar 05 16:11:22 sagar-82c7 kernel: CPU: 1 PID: 1613 Comm: chrome Not tainted 6.1.12-1-MANJARO #1 d419fb51ba9431ae2a4575820ea6b5b95f50a34f
mar 05 16:11:22 sagar-82c7 kernel: Hardware name: LENOVO 82C7/LNVNB161216, BIOS E8CN27WW 01/15/2021
mar 05 16:11:22 sagar-82c7 kernel: oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/user.slice/user-1000.slice/user@>
mar 05 16:11:22 sagar-82c7 kernel: Out of memory: Killed process 1777 (chrome) total-vm:1184817836kB, anon-rss:389020kB, file-rss:0kB, shmem-rss:3668kB, UID:1000 pgta>
mar 05 16:11:22 sagar-82c7 systemd[1]: user@1000.service: A process of this unit has been killed by the OOM killer.
mar 05 16:11:22 sagar-82c7 systemd[553]: app-google\x2dchrome-455de79a527b4749a4cc0170f7eb0a16.scope: A process of this unit has been killed by the OOM killer.
mar 05 16:11:22 sagar-82c7 plasmashell[1174]: [1168:1168:0305/161122.219607:ERROR:zygote_communication_linux.cc(291)] Failed to send GetTerminationStatus message to z>
mar 05 16:11:22 sagar-82c7 plasmashell[1174]: [1168:1196:0305/161122.234677:ERROR:connection_factory_impl.cc(472)] ConnectionHandler failed with net error: -2
mar 05 16:11:22 sagar-82c7 plasmashell[1174]: [1168:5260:0305/161122.462549:ERROR:get_updates_processor.cc(264)] PostClientToServerMessage() failed during GetUpdates >
mar 05 16:11:22 sagar-82c7 plasmashell[1174]: [1168:1168:0305/161122.466136:ERROR:zygote_communication_linux.cc(291)] Failed to send GetTerminationStatus message to z>
mar 05 16:11:22 sagar-82c7 plasmashell[1174]: [1168:1168:0305/161122.470201:ERROR:zygote_communication_linux.cc(291)] Failed to send GetTerminationStatus message to z>
mar 05 16:11:22 sagar-82c7 systemd[553]: app-google\x2dchrome-455de79a527b4749a4cc0170f7eb0a16.scope: Failed with result 'oom-kill'.
mar 05 16:11:22 sagar-82c7 systemd[553]: app-google\x2dchrome-455de79a527b4749a4cc0170f7eb0a16.scope: Consumed 1h 7min 32.417s CPU time.
mar 05 16:11:22 sagar-82c7 systemd[553]: app.slice: A process of this unit has been killed by the OOM killer.
mar 05 16:11:22 sagar-82c7 pamac-tray-plas[855]: updates_checker.vala:101: 1 updates found
mar 05 16:11:24 sagar-82c7 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
mar 05 16:11:24 sagar-82c7 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/>
mar 05 16:11:24 sagar-82c7 kernel: audit: type=1131 audit(1678029084.231:111): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="sy>
mar 05 16:11:33 sagar-82c7 systemd[553]: Started Konsole - Terminale.
mar 05 16:11:34 sagar-82c7 konsole[5319]: kf.xmlgui: Shortcut for action "" "Mostra il gestore SSH" set with QAction::setShortcut()! Use KActionCollection::setDefaul>
mar 05 16:11:34 sagar-82c7 konsole[5319]: kf.xmlgui: Shortcut for action "" "Mostra comandi rapidi" set with QAction::setShortcut()! Use KActionCollection::setDefaul>
mar 05 16:13:21 sagar-82c7 plasmashell[689]: trying to show an empty dialog
mar 05 16:15:22 sagar-82c7 wpa_supplicant[448]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-42 noise=9999 txrate=144400
mar 05 16:15:43 sagar-82c7 wpa_supplicant[448]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-41 noise=9999 txrate=144400
mar 05 16:17:47 sagar-82c7 dbus-daemon[325]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.39' (uid=1000 pid=722 comm="/usr/l>
mar 05 16:17:47 sagar-82c7 dbus-daemon[325]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
mar 05 16:24:01 sagar-82c7 anacron[4053]: Job `cron.monthly' started
mar 05 16:24:01 sagar-82c7 anacron[4053]: Job `cron.monthly' terminated
Hi and welcome to the Forum
Help others to help you better by:
- Providing system info about your hardware by posting program output instead of describing your hardware.
- Use new lines when a sentence ends, so it is better readable and followable by others.
- If english is not your native language please see:
English [HowTo] Become multi-language on internet
Türkçe [Nasıl] İnternette çok dilli olun
Deutsch [Wie man] Werden Sie im Internet mehrsprachig
Français [Comment] Devenir multilingue sur internet
Española [Cómo] Conviértete en multilenguaje en Internet
中文 [如何] 成为互联网上的多语言
Italiana [Come] Diventa multilingua su internet
русский язык [Как] Стать многоязычным в Интернете
Please read and follow all advice in this thread:
Especially:
