KDE Plasma 6.3.6 Shutdown Issue
Hi, We have two Aspire TC-780 PCs and I set them up exactly the same way from the same USB but one does not always shut down using the menu. It is frustrating my spouse. Basically, what happens is when shutdown is chosen via the GUI sometimes the monitor turns black but the PC itself does not shut down, the power button is lit showing it is on. We have to manually press and hold it to turn the PC off.
However, we noticed an odd behaviour, this PC will sometimes shut down as long as there is no update pending. We have noticed that the icon showing when an update is available remains white. The PC will not shut down. However, the next day the update icon will turn red. If we apply the update, whatever it may be, the icon turns white again and the PC will now shut down normally.
I have tried a couple of things, such as changing the settings to always start with a new session, start with a default session, but this does not seem to make a difference.
My PC doesn’t have this issue and it always shuts down. As they are identical PCs I am a bit puzzled. I am not sure what step to take next. If anyone has a suggestion I’d be grateful.
It is KDE Plasma 6.3.6, running X11, Kernel 6.12.48-1.
Many thanks,
Greg
:slight_smile:
  • a watchdog may be preventing shutdown
  • perhaps because the file system has not been fully synced
I’ll try running the sync command when my spouse is done at the end of the day and see what happens at the next shut down.
After a failure to shutdown, requiring a manual power-down, you could always look at the journal entries when you next boot-up, to see if any failure information was logged. I think this shows the log for the previous run:
journalctl -b -1
After thing to consider is whether or not you both run different apps - is there an app often used on the failing PC which is not used on the one never showing the problem? It could be a particular app says it is still busy in the background.
I’ll try the command and see if there is anything in the log. There is an overlap of apps, such as Chromium but I use many more than my spouse. My spouse is mainly using Chromium for social media.
My spouse will close social media in Chromium without logging out of them. I have no idea though if that would contribute to the issue because incomplete shutting down always seems to happen right before the updates. At other times the PC shuts down. I’ll have to observe exactly how that PC is used more closely.
Ok, thanks everyone, I’ll get back to you tomorrow with a progress update. :slight_smile:
Occsionally, there may be a “stop job” in progress which might give the impression of a stalled shutdown. Hitting the Esc key should usually reveal whether or not this is the case.
A “stop job” may be called for a number of reasons, and can sometimes take up to 1.5 minutes to complete. Forcing a hard shutdown or reboot only means that the stop job isn’t allowed to complete, in which case it must run again at the next shutdown.
If this is actually the case, then patience is a distinct virtue.
Information only:
Every hard shutdown/reset can potentially damage your system. Many are unaware that there is a safer method to shut down a frozen system using REISUB/REISUO:
Thank you for the information! :slight_smile: The PC will not shut down after 1.5 minutes. It stays on. I will try ESC and REISUB/REISUO the next time the issue occurs.
Since my previous post my spouse’s PC has been shutting down, defying all expectation, and we have had one update show up. I am waiting for the shutdown issue to recur. I will definitely report back on what happens next.
@seaforthcastle please switch to testing branch and check if the issue still exists: Switching Branches - Manjaro
I had the same problem a year ago after a fresh install and the first update (KDE): black screen and freezing during shutdown…
The solution is In the settings:
→ System → Desktop Session → On Next Session
“Start with empty session”
Maybe this will help.
I do not not know if this is related..
But I know there are a few things that stop my Plasma shutdown, often I know what it is (like an accident such as leaving a root owned process somewhere). But if I initiate the shutdown any other way other than the Plasma way, it would shutdown eventually.
It does take longer in this situation, but it works with systemd/shutdown! It times out after 3 min (I think), then kills all processes. But the Plasma shutdown, you are stuck in limbo, not even able to spawn a terminal. And REISUB is your only option.
This is the useful information you want (if the hang up happened on the previous boot). You just may want to add -r or -reverse, just so it’s starts where it hung up. And --no-pager for copy/pasting/piping.
journalctl --boot=-1 --reverse --no-pager
#journalctl -b -1 -r --no-pager
What were the last dozen or two entries of logs?
KDE 6.3.6 on wayland. Tested kernels : Manjaro 6.6, 6.12, 6.15., 6.16, 6.17, and cachy kernels 6.12, 6.17. No changes.
Hi, thank you for the information!
I’ve been waiting days and finally the shutdown error occurred again today. I’ll read through the log and see if anything jumps out and bites me. Here is the log using the above command you recommended:
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Mounting Kernel Debug File System…
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Mounting POSIX Message Queue File System…
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Mounting Huge Pages File System…
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Listening on User Database Manager Socket.
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Listening on udev Kernel Socket.
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Listening on udev Control Socket.
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Listening on Journal Sockets.
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Listening on Journal Socket (/dev/log).
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Listening on Credential Encryption/Decryption.
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Listening on Process Core Dump Socket.
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Listening on LVM2 poll daemon socket.
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Listening on Device-mapper event daemon FIFOs.
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Reached target Local Verity Protected Volumes.
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Reached target Swaps.
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Reached target Slice Units.
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Reached target Remote File Systems.
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Reached target Local Integrity Protected Volumes.
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Reached target Login Prompts.
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Expecting device /dev/disk/by-uuid/9024-C57B…
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Set up automount Arbitrary Executable File Formats File System Automount Point.
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Started Forward Password Requests to Wall Directory Watch.
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Created slice User and Session Slice.
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Created slice Slice /system/systemd-fsck.
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Created slice Slice /system/modprobe.
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Created slice Slice /system/keyboxd.
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Created slice Slice /system/gpg-agent-ssh.
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Created slice Slice /system/gpg-agent-extra.
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Created slice Slice /system/gpg-agent-browser.
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Created slice Slice /system/gpg-agent.
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Created slice Slice /system/getty.
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Created slice Slice /system/dirmngr.
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Created slice CUPS Slice.
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Queued start job for default target Graphical Interface.
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: bpf-restrict-fs: LSM BPF program attached
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Hostname set to .
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: Detected architecture x86-64.
Dec 01 04:54:08 tracey-aspiretc780 systemd\[1\]: systemd 257.9-1-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +IPE +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF +XKBCOMMON +UTMP -SYSVINIT +LIBARCHIVE)
Dec 01 04:54:08 tracey-aspiretc780 kernel: EXT4-fs (sda5): mounted filesystem a13ec453-9088-41a0-aca1-b168970630a1 r/w with ordered data mode. Quota mode: none.
Dec 01 04:54:08 tracey-aspiretc780 kernel: sd 4:0:0:0: \[sdb\] Attached SCSI removable disk
Dec 01 04:54:08 tracey-aspiretc780 kernel: sd 4:0:0:0: \[sdb\] Media removed, stopped polling
Dec 01 04:54:08 tracey-aspiretc780 kernel: scsi 4:0:0:0: Direct-Access     Generic- SD/MMC/MS PRO    1.00 PQ: 0 ANSI: 4
Dec 01 04:54:08 tracey-aspiretc780 kernel: i915 0000:00:02.0: \[drm\] fb0: i915drmfb frame buffer device
Dec 01 04:54:08 tracey-aspiretc780 kernel: fbcon: Deferring console take-over
Dec 01 04:54:08 tracey-aspiretc780 kernel: fbcon: i915drmfb (fb0) is primary device
Dec 01 04:54:08 tracey-aspiretc780 kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input13
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: video: Video Device \[GFX0\] (multi-head: yes  rom: no  post: no)
Dec 01 04:54:08 tracey-aspiretc780 kernel: \[drm\] Initialized i915 1.6.0 for 0000:00:02.0 on minor 1
Dec 01 04:54:08 tracey-aspiretc780 kernel: i915 0000:00:02.0: \[drm\] \[ENCODER:76:DDI A/PHY A\] failed to retrieve link info, disabling eDP
Dec 01 04:54:08 tracey-aspiretc780 kernel: usbcore: registered new interface driver ums-realtek
Dec 01 04:54:08 tracey-aspiretc780 kernel: scsi host4: usb-storage 1-9:1.0
Dec 01 04:54:08 tracey-aspiretc780 kernel: ums-realtek 1-9:1.0: USB Mass Storage device detected
Dec 01 04:54:08 tracey-aspiretc780 kernel: usbcore: registered new interface driver uas
Dec 01 04:54:08 tracey-aspiretc780 kernel: usbcore: registered new interface driver usb-storage
Dec 01 04:54:08 tracey-aspiretc780 kernel: usb 1-10: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Dec 01 04:54:08 tracey-aspiretc780 kernel: usb 1-10: New USB device found, idVendor=8087, idProduct=0aa7, bcdDevice= 0.01
Dec 01 04:54:08 tracey-aspiretc780 kernel: usb 1-10: new full-speed USB device number 6 using xhci_hcd
Dec 01 04:54:08 tracey-aspiretc780 kernel: usb 1-9: SerialNumber: 20120926571200000
Dec 01 04:54:08 tracey-aspiretc780 kernel: usb 1-9: Manufacturer: Generic
Dec 01 04:54:08 tracey-aspiretc780 kernel: usb 1-9: Product: USB2.0-CRW
Dec 01 04:54:08 tracey-aspiretc780 kernel: usb 1-9: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Dec 01 04:54:08 tracey-aspiretc780 kernel: usb 1-9: New USB device found, idVendor=0bda, idProduct=0153, bcdDevice=57.13
Dec 01 04:54:08 tracey-aspiretc780 kernel: i915 0000:00:02.0: \[drm\] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
Dec 01 04:54:08 tracey-aspiretc780 kernel: i915 0000:00:02.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=io+mem:owns=io+mem
Dec 01 04:54:08 tracey-aspiretc780 kernel: i915 0000:00:02.0: vgaarb: deactivate vga console
Dec 01 04:54:08 tracey-aspiretc780 kernel: i915 0000:00:02.0: \[drm\] Found KABYLAKE (device ID 5912) display version 9.00 stepping C0
Dec 01 04:54:08 tracey-aspiretc780 kernel: usb 1-9: new high-speed USB device number 5 using xhci_hcd
Dec 01 04:54:08 tracey-aspiretc780 kernel: hid-generic 0003:04D9:1702.0004: input,hidraw3: USB HID v1.10 Device \[  USB Keyboard\] on usb-0000:00:14.0-6/input1
Dec 01 04:54:08 tracey-aspiretc780 kernel: input:   USB Keyboard Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.1/0003:04D9:1702.0004/input/input12
Dec 01 04:54:08 tracey-aspiretc780 kernel: input:   USB Keyboard System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.1/0003:04D9:1702.0004/input/input11
Dec 01 04:54:08 tracey-aspiretc780 kernel: hid-generic 0003:04D9:1702.0003: input,hidraw2: USB HID v1.10 Keyboard \[  USB Keyboard\] on usb-0000:00:14.0-6/input0
Dec 01 04:54:08 tracey-aspiretc780 kernel: input:   USB Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0/0003:04D9:1702.0003/input/input10
Dec 01 04:54:08 tracey-aspiretc780 kernel: usb 1-6: Manufacturer:
Dec 01 04:54:08 tracey-aspiretc780 kernel: usb 1-6: Product: USB Keyboard
Dec 01 04:54:08 tracey-aspiretc780 kernel: usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dec 01 04:54:08 tracey-aspiretc780 kernel: usb 1-6: New USB device found, idVendor=04d9, idProduct=1702, bcdDevice= 1.01
Dec 01 04:54:08 tracey-aspiretc780 kernel: clocksource: Switched to clocksource tsc
Dec 01 04:54:08 tracey-aspiretc780 kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2b3e5090ef5, max_idle_ns: 440795222870 ns
Dec 01 04:54:08 tracey-aspiretc780 kernel: tsc: Refined TSC clocksource calibration: 3000.012 MHz
Dec 01 04:54:08 tracey-aspiretc780 kernel: sr 3:0:0:0: Attached scsi CD-ROM sr0
Dec 01 04:54:08 tracey-aspiretc780 kernel: hid-generic 0003:062A:5918.0002: input,hiddev96,hidraw1: USB HID v1.10 Mouse \[MOSART Semi. 2.4G Keyboard Mouse\] on usb-0000:00:14.0-5/input1
Dec 01 04:54:08 tracey-aspiretc780 kernel: input: MOSART Semi. 2.4G Keyboard Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.1/0003:062A:5918.0002/input/input7
Dec 01 04:54:08 tracey-aspiretc780 kernel: input: MOSART Semi. 2.4G Keyboard Mouse System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.1/0003:062A:5918.0002/input/input6
Dec 01 04:54:08 tracey-aspiretc780 kernel: cdrom: Uniform CD-ROM driver Revision: 3.20
Dec 01 04:54:08 tracey-aspiretc780 kernel: sr 3:0:0:0: \[sr0\] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
Dec 01 04:54:08 tracey-aspiretc780 kernel: input: MOSART Semi. 2.4G Keyboard Mouse Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.1/0003:062A:5918.0002/input/input5
Dec 01 04:54:08 tracey-aspiretc780 kernel: input: MOSART Semi. 2.4G Keyboard Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.1/0003:062A:5918.0002/input/input4
Dec 01 04:54:08 tracey-aspiretc780 kernel: hid-generic 0003:062A:5918.0001: input,hidraw0: USB HID v1.10 Keyboard \[MOSART Semi. 2.4G Keyboard Mouse\] on usb-0000:00:14.0-5/input0
Dec 01 04:54:08 tracey-aspiretc780 kernel: usb 1-6: new low-speed USB device number 4 using xhci_hcd
Dec 01 04:54:08 tracey-aspiretc780 kernel: serio: i8042 AUX port at 0x60,0x64 irq 12
Dec 01 04:54:08 tracey-aspiretc780 kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
Dec 01 04:54:08 tracey-aspiretc780 kernel: i8042: PNP: PS/2 Controller \[PNP0303:PS2K,PNP0f03:PS2M\] at 0x60,0x64 irq 1,12
Dec 01 04:54:08 tracey-aspiretc780 kernel: input: MOSART Semi. 2.4G Keyboard Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/0003:062A:5918.0001/input/input3
Dec 01 04:54:08 tracey-aspiretc780 kernel: usbhid: USB HID core driver
Dec 01 04:54:08 tracey-aspiretc780 kernel: usbcore: registered new interface driver usbhid
Dec 01 04:54:08 tracey-aspiretc780 kernel: usb 1-5: Manufacturer: MOSART Semi.
Dec 01 04:54:08 tracey-aspiretc780 kernel: usb 1-5: Product: 2.4G Keyboard Mouse
Dec 01 04:54:08 tracey-aspiretc780 kernel: usb 1-5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dec 01 04:54:08 tracey-aspiretc780 kernel: usb 1-5: New USB device found, idVendor=062a, idProduct=5918, bcdDevice= 1.02
Dec 01 04:54:08 tracey-aspiretc780 kernel:     apm=power_off
Dec 01 04:54:08 tracey-aspiretc780 kernel:     BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64
Dec 01 04:54:08 tracey-aspiretc780 kernel:     TERM=linux
Dec 01 04:54:08 tracey-aspiretc780 kernel:     HOME=/
Dec 01 04:54:08 tracey-aspiretc780 kernel:   with environment:
Dec 01 04:54:08 tracey-aspiretc780 kernel:     splash
Dec 01 04:54:08 tracey-aspiretc780 kernel:     /init
Dec 01 04:54:08 tracey-aspiretc780 kernel:   with arguments:
Dec 01 04:54:08 tracey-aspiretc780 kernel: Run /init as init process
Dec 01 04:54:08 tracey-aspiretc780 kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
Dec 01 04:54:08 tracey-aspiretc780 kernel: usb 1-5: new full-speed USB device number 3 using xhci_hcd
Dec 01 04:54:08 tracey-aspiretc780 kernel: x86/mm: Checking user space page tables
Dec 01 04:54:08 tracey-aspiretc780 kernel: rodata_test: all tests were successful
Dec 01 04:54:08 tracey-aspiretc780 kernel: Freeing unused kernel image (rodata/data gap) memory: 2020K
Dec 01 04:54:08 tracey-aspiretc780 kernel: Write protecting the kernel read-only data: 34816k
Dec 01 04:54:08 tracey-aspiretc780 kernel: Freeing unused kernel image (initmem) memory: 4288K
Dec 01 04:54:08 tracey-aspiretc780 kernel: Freeing unused decrypted memory: 2028K
Dec 01 04:54:08 tracey-aspiretc780 kernel: sd 2:0:0:0: \[sda\] Attached SCSI disk
Dec 01 04:54:08 tracey-aspiretc780 kernel:  sda: sda1 sda2 sda3 sda4 sda5
Dec 01 04:54:08 tracey-aspiretc780 kernel: usb 1-3: Manufacturer: Generic
Dec 01 04:54:08 tracey-aspiretc780 kernel: usb 1-3: Product: USB2.0 PC CAMERA
Dec 01 04:54:08 tracey-aspiretc780 kernel: usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dec 01 04:54:08 tracey-aspiretc780 kernel: usb 1-3: New USB device found, idVendor=1908, idProduct=2311, bcdDevice= 1.00
Dec 01 04:54:08 tracey-aspiretc780 kernel: scsi 3:0:0:0: CD-ROM            Slimtype DVD A  DA8AESH   XA11 PQ: 0 ANSI: 5
Dec 01 04:54:08 tracey-aspiretc780 kernel: ata4.00: configured for UDMA/133
Dec 01 04:54:08 tracey-aspiretc780 kernel: ata4.00: ACPI cmd b1/c1:00:00:00:00:00(DEVICE CONFIGURATION OVERLAY) filtered out
Dec 01 04:54:08 tracey-aspiretc780 kernel: ata4.00: ACPI cmd f5/00:00:00:00:00:00(SECURITY FREEZE LOCK) filtered out
Dec 01 04:54:08 tracey-aspiretc780 kernel: ata4.00: ATAPI: Slimtype DVD A  DA8AESH, XA11, max UDMA/133
Dec 01 04:54:08 tracey-aspiretc780 kernel: sd 2:0:0:0: \[sda\] Preferred minimum I/O size 4096 bytes
Dec 01 04:54:08 tracey-aspiretc780 kernel: sd 2:0:0:0: \[sda\] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
Dec 01 04:54:08 tracey-aspiretc780 kernel: sd 2:0:0:0: \[sda\] Mode Sense: 00 3a 00 00
Dec 01 04:54:08 tracey-aspiretc780 kernel: sd 2:0:0:0: \[sda\] Write Protect is off
Dec 01 04:54:08 tracey-aspiretc780 kernel: sd 2:0:0:0: \[sda\] 4096-byte physical blocks
Dec 01 04:54:08 tracey-aspiretc780 kernel: sd 2:0:0:0: \[sda\] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
Dec 01 04:54:08 tracey-aspiretc780 kernel: scsi 2:0:0:0: Direct-Access     ATA      TOSHIBA DT01ACA1 A8K0 PQ: 0 ANSI: 5
Dec 01 04:54:08 tracey-aspiretc780 kernel: ata3.00: configured for UDMA/133
Dec 01 04:54:08 tracey-aspiretc780 kernel: ata3.00: ACPI cmd b1/c1:00:00:00:00:00(DEVICE CONFIGURATION OVERLAY) filtered out
Dec 01 04:54:08 tracey-aspiretc780 kernel: ata3.00: ACPI cmd f5/00:00:00:00:00:00(SECURITY FREEZE LOCK) filtered out
Dec 01 04:54:08 tracey-aspiretc780 kernel: ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ata3.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
Dec 01 04:54:08 tracey-aspiretc780 kernel: ata3.00: ATA-8: TOSHIBA DT01ACA100, MS2OA8K0, max UDMA/133
Dec 01 04:54:08 tracey-aspiretc780 kernel: ata1: SATA link down (SStatus 4 SControl 300)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ata2: SATA link down (SStatus 4 SControl 300)
Dec 01 04:54:08 tracey-aspiretc780 kernel: usb 1-3: new high-speed USB device number 2 using xhci_hcd
Dec 01 04:54:08 tracey-aspiretc780 kernel: PM: genpd: Disabling unused power domains
Dec 01 04:54:08 tracey-aspiretc780 kernel: clk: Disabling unused clocks
Dec 01 04:54:08 tracey-aspiretc780 kernel: RAS: Correctable Errors collector initialized.
Dec 01 04:54:08 tracey-aspiretc780 kernel: PM:   Magic number: 5:298:876
Dec 01 04:54:08 tracey-aspiretc780 kernel: integrity: Loaded X.509 cert ‘Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53’
Dec 01 04:54:08 tracey-aspiretc780 kernel: integrity: Loading X.509 certificate: UEFI:db
Dec 01 04:54:08 tracey-aspiretc780 kernel: integrity: Loaded X.509 cert ‘Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4’
Dec 01 04:54:08 tracey-aspiretc780 kernel: integrity: Loaded X.509 cert ‘Acer Database: 84f00f5841571abd2cc11a8c26d5c9c8d2b6b0b5’
Dec 01 04:54:08 tracey-aspiretc780 kernel: integrity: Loaded X.509 cert ‘Acer: c4f0474ae6b5e67a509d99132f49a4ec13f7ac68’
Dec 01 04:54:08 tracey-aspiretc780 kernel: Key type fscrypt-provisioning registered
Dec 01 04:54:08 tracey-aspiretc780 kernel: Key type .fscrypt registered
Dec 01 04:54:08 tracey-aspiretc780 kernel: Demotion targets for Node 0: null
Dec 01 04:54:08 tracey-aspiretc780 kernel: Loaded X.509 cert ‘Build time autogenerated kernel key: 14382fbf9b4d278b5c022f1081ca4b0bdb05767e’
Dec 01 04:54:08 tracey-aspiretc780 kernel: Loading compiled-in X.509 certificates
Dec 01 04:54:08 tracey-aspiretc780 kernel: registered taskstats version 1
Dec 01 04:54:08 tracey-aspiretc780 kernel: sched_clock: Marking stable (470001572, 430978)->(474240395, -3807845)
Dec 01 04:54:08 tracey-aspiretc780 kernel: IPI shorthand broadcast: enabled
Dec 01 04:54:08 tracey-aspiretc780 kernel: microcode: Updated early from: 0x00000042
Dec 01 04:54:08 tracey-aspiretc780 kernel: microcode: Current revision: 0x000000f8
Dec 01 04:54:08 tracey-aspiretc780 kernel: ENERGY_PERF_BIAS: Set to ‘normal’, was ‘performance’
Dec 01 04:54:08 tracey-aspiretc780 kernel: NET: Registered PF_PACKET protocol family
Dec 01 04:54:08 tracey-aspiretc780 kernel: In-situ OAM (IOAM) with IPv6
Dec 01 04:54:08 tracey-aspiretc780 kernel: RPL Segment Routing with IPv6
Dec 01 04:54:08 tracey-aspiretc780 kernel: Segment Routing with IPv6
Dec 01 04:54:08 tracey-aspiretc780 kernel: NET: Registered PF_INET6 protocol family
Dec 01 04:54:08 tracey-aspiretc780 kernel: drop_monitor: Initializing network drop monitor service
Dec 01 04:54:08 tracey-aspiretc780 kernel: hid: raw HID events driver (C) Jiri Kosina
Dec 01 04:54:08 tracey-aspiretc780 kernel: simple-framebuffer simple-framebuffer.0: \[drm\] fb0: simpledrmdrmfb frame buffer device
Dec 01 04:54:08 tracey-aspiretc780 kernel: \[drm\] Initialized simpledrm 1.0.0 for simple-framebuffer.0 on minor 0
Dec 01 04:54:08 tracey-aspiretc780 kernel: simple-framebuffer simple-framebuffer.0: \[drm\] Registered 1 planes with drm panic
Dec 01 04:54:08 tracey-aspiretc780 kernel: intel_pstate: HWP enabled
Dec 01 04:54:08 tracey-aspiretc780 kernel: intel_pstate: Disabling energy efficiency optimization
Dec 01 04:54:08 tracey-aspiretc780 kernel: intel_pstate: Intel P-state driver initializing
Dec 01 04:54:08 tracey-aspiretc780 kernel: rtc_cmos 00:05: alarms up to one month, y3k, 242 bytes nvram
Dec 01 04:54:08 tracey-aspiretc780 kernel: rtc_cmos 00:05: setting system clock to 2025-12-01T08:53:57 UTC (1764579237)
Dec 01 04:54:08 tracey-aspiretc780 kernel: rtc_cmos 00:05: registered as rtc0
Dec 01 04:54:08 tracey-aspiretc780 kernel: rtc_cmos 00:05: RTC can wake from S4
Dec 01 04:54:08 tracey-aspiretc780 kernel: usbserial: USB Serial support registered for generic
Dec 01 04:54:08 tracey-aspiretc780 kernel: usbcore: registered new interface driver usbserial_generic
Dec 01 04:54:08 tracey-aspiretc780 kernel: hub 2-0:1.0: 4 ports detected
Dec 01 04:54:08 tracey-aspiretc780 kernel: hub 2-0:1.0: USB hub found
Dec 01 04:54:08 tracey-aspiretc780 kernel: usb usb2: SerialNumber: 0000:00:14.0
Dec 01 04:54:08 tracey-aspiretc780 kernel: usb usb2: Manufacturer: Linux 6.12.48-1-MANJARO xhci-hcd
Dec 01 04:54:08 tracey-aspiretc780 kernel: usb usb2: Product: xHCI Host Controller
Dec 01 04:54:08 tracey-aspiretc780 kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec 01 04:54:08 tracey-aspiretc780 kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.12
Dec 01 04:54:08 tracey-aspiretc780 kernel: hub 1-0:1.0: 10 ports detected
Dec 01 04:54:08 tracey-aspiretc780 kernel: hub 1-0:1.0: USB hub found
Dec 01 04:54:08 tracey-aspiretc780 kernel: usb usb1: SerialNumber: 0000:00:14.0
Dec 01 04:54:08 tracey-aspiretc780 kernel: usb usb1: Manufacturer: Linux 6.12.48-1-MANJARO xhci-hcd
Dec 01 04:54:08 tracey-aspiretc780 kernel: usb usb1: Product: xHCI Host Controller
Dec 01 04:54:08 tracey-aspiretc780 kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec 01 04:54:08 tracey-aspiretc780 kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12
Dec 01 04:54:08 tracey-aspiretc780 kernel: xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
Dec 01 04:54:08 tracey-aspiretc780 kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
Dec 01 04:54:08 tracey-aspiretc780 kernel: xhci_hcd 0000:00:14.0: xHCI Host Controller
Dec 01 04:54:08 tracey-aspiretc780 kernel: xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000001109810
Dec 01 04:54:08 tracey-aspiretc780 kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
Dec 01 04:54:08 tracey-aspiretc780 kernel: ata4: SATA max UDMA/133 abar m2048@0xf722b000 port 0xf722b280 irq 122 lpm-pol 3
Dec 01 04:54:08 tracey-aspiretc780 kernel: ata3: SATA max UDMA/133 abar m2048@0xf722b000 port 0xf722b200 irq 122 lpm-pol 3
Dec 01 04:54:08 tracey-aspiretc780 kernel: ata2: SATA max UDMA/133 abar m2048@0xf722b000 port 0xf722b180 irq 122 lpm-pol 3
Dec 01 04:54:08 tracey-aspiretc780 kernel: ata1: SATA max UDMA/133 abar m2048@0xf722b000 port 0xf722b100 irq 122 lpm-pol 3
Dec 01 04:54:08 tracey-aspiretc780 kernel: scsi host3: ahci
Dec 01 04:54:08 tracey-aspiretc780 kernel: scsi host2: ahci
Dec 01 04:54:08 tracey-aspiretc780 kernel: scsi host1: ahci
Dec 01 04:54:08 tracey-aspiretc780 kernel: scsi host0: ahci
Dec 01 04:54:08 tracey-aspiretc780 kernel: ahci 0000:00:17.0: flags: 64bit ncq sntf led clo only pio slum part ems deso sadm sds apst
Dec 01 04:54:08 tracey-aspiretc780 kernel: ahci 0000:00:17.0: 4/4 ports implemented (port mask 0xf)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ahci 0000:00:17.0: AHCI vers 0001.0301, 32 command slots, 6 Gbps, SATA mode
Dec 01 04:54:08 tracey-aspiretc780 kernel: ahci 0000:00:17.0: version 3.0
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: bus type drm_connector registered
Dec 01 04:54:08 tracey-aspiretc780 kernel: Freeing initrd memory: 30732K
Dec 01 04:54:08 tracey-aspiretc780 kernel: tpm_crb MSFT0101:00: \[Firmware Bug\]: ACPI region does not cover the entire command/response buffer. \[mem 0xfed40000-0xfed4087f flags 0x200\] vs fed40080 f80
Dec 01 04:54:08 tracey-aspiretc780 kernel: Linux agpgart interface v0.103
Dec 01 04:54:08 tracey-aspiretc780 kernel: Non-volatile memory driver v1.3
Dec 01 04:54:08 tracey-aspiretc780 kernel: Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: thermal: Thermal Zone \[TZ01\] (30 C)
Dec 01 04:54:08 tracey-aspiretc780 kernel: thermal LNXTHERM:01: registered as thermal_zone1
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: thermal: Thermal Zone \[TZ00\] (28 C)
Dec 01 04:54:08 tracey-aspiretc780 kernel: thermal LNXTHERM:00: registered as thermal_zone0
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: button: Power Button \[PWRF\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: button: Power Button \[PWRB\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: button: Sleep Button \[SLPB\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
Dec 01 04:54:08 tracey-aspiretc780 kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Dec 01 04:54:08 tracey-aspiretc780 kernel: pcieport 0000:00:1c.5: AER: enabled with IRQ 121
Dec 01 04:54:08 tracey-aspiretc780 kernel: pcieport 0000:00:1c.5: PME: Signaling with IRQ 121
Dec 01 04:54:08 tracey-aspiretc780 kernel: pcieport 0000:00:1c.0: AER: enabled with IRQ 120
Dec 01 04:54:08 tracey-aspiretc780 kernel: pcieport 0000:00:1c.0: PME: Signaling with IRQ 120
Dec 01 04:54:08 tracey-aspiretc780 kernel: ledtrig-cpu: registered to indicate activity on CPUs
Dec 01 04:54:08 tracey-aspiretc780 kernel: io scheduler bfq registered
Dec 01 04:54:08 tracey-aspiretc780 kernel: io scheduler kyber registered
Dec 01 04:54:08 tracey-aspiretc780 kernel: io scheduler mq-deadline registered
Dec 01 04:54:08 tracey-aspiretc780 kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
Dec 01 04:54:08 tracey-aspiretc780 kernel: Asymmetric key parser ‘x509’ registered
Dec 01 04:54:08 tracey-aspiretc780 kernel: Key type asymmetric registered
Dec 01 04:54:08 tracey-aspiretc780 kernel: integrity: Machine keyring initialized
Dec 01 04:54:08 tracey-aspiretc780 kernel: integrity: Platform Keyring initialized
Dec 01 04:54:08 tracey-aspiretc780 kernel: fuse: init (API version 7.41)
Dec 01 04:54:08 tracey-aspiretc780 kernel: workingset: timestamp_bits=36 max_order=22 bucket_order=0
Dec 01 04:54:08 tracey-aspiretc780 kernel: Key type blacklist registered
Dec 01 04:54:08 tracey-aspiretc780 kernel: Initialise system trusted keyrings
Dec 01 04:54:08 tracey-aspiretc780 kernel: Trying to unpack rootfs image as initramfs…
Dec 01 04:54:08 tracey-aspiretc780 kernel: software IO TLB: mapped \[mem 0x0000000092beb000-0x0000000096beb000\] (64MB)
Dec 01 04:54:08 tracey-aspiretc780 kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:1f.1: BAR 0 \[mem 0xfd000000-0xfdffffff 64bit\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:1f.1: \[8086:a120\] type 00 class 0x058000 conventional PCI endpoint
Dec 01 04:54:08 tracey-aspiretc780 kernel: PCI: CLS 64 bytes, default 64
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci_bus 0000:02: resource 1 \[mem 0xf7000000-0xf70fffff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci_bus 0000:01: resource 2 \[mem 0xf0000000-0xf00fffff 64bit pref\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci_bus 0000:01: resource 1 \[mem 0xf7100000-0xf71fffff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci_bus 0000:01: resource 0 \[io  0xe000-0xefff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci_bus 0000:00: resource 8 \[mem 0xfd000000-0xfe7fffff window\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci_bus 0000:00: resource 7 \[mem 0xa8000000-0xf7ffffff window\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci_bus 0000:00: resource 6 \[mem 0x000a0000-0x000effff window\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci_bus 0000:00: resource 5 \[io  0x0d00-0xffff window\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci_bus 0000:00: resource 4 \[io  0x0000-0x0cf7 window\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:1c.5:   bridge window \[mem 0xf7000000-0xf70fffff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:1c.5: PCI bridge to \[bus 02\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:1c.0:   bridge window \[mem 0xf0000000-0xf00fffff 64bit pref\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:1c.0:   bridge window \[mem 0xf7100000-0xf71fffff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:1c.0:   bridge window \[io  0xe000-0xefff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:1c.0: PCI bridge to \[bus 01\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: NET: Registered PF_XDP protocol family
Dec 01 04:54:08 tracey-aspiretc780 kernel: NET: Registered PF_UNIX/PF_LOCAL protocol family
Dec 01 04:54:08 tracey-aspiretc780 kernel: UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
Dec 01 04:54:08 tracey-aspiretc780 kernel: UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
Dec 01 04:54:08 tracey-aspiretc780 kernel: MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
Dec 01 04:54:08 tracey-aspiretc780 kernel: TCP: Hash tables configured (established 131072 bind 65536)
Dec 01 04:54:08 tracey-aspiretc780 kernel: TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
Dec 01 04:54:08 tracey-aspiretc780 kernel: TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
Dec 01 04:54:08 tracey-aspiretc780 kernel: Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
Dec 01 04:54:08 tracey-aspiretc780 kernel: tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
Dec 01 04:54:08 tracey-aspiretc780 kernel: IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
Dec 01 04:54:08 tracey-aspiretc780 kernel: NET: Registered PF_INET protocol family
Dec 01 04:54:08 tracey-aspiretc780 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
Dec 01 04:54:08 tracey-aspiretc780 kernel: pnp: PnP ACPI: found 10 devices
Dec 01 04:54:08 tracey-aspiretc780 kernel: system 00:09: \[mem 0xfdac0000-0xfdacffff\] has been reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: system 00:09: \[mem 0xfdae0000-0xfdaeffff\] has been reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: system 00:09: \[mem 0xfdaf0000-0xfdafffff\] has been reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: system 00:08: \[io  0xff00-0xfffe\] has been reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: system 00:07: \[mem 0xfe410000-0xfe7fffff\] has been reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: system 00:07: \[mem 0xfe03d000-0xfe3fffff\] has been reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: system 00:07: \[mem 0xfe036000-0xfe03bfff\] has been reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: system 00:07: \[mem 0xfe000000-0xfe01ffff\] could not be reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: system 00:07: \[mem 0xfdb00000-0xfdffffff\] has been reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: system 00:07: \[mem 0xfdad0000-0xfdadffff\] has been reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: system 00:07: \[mem 0xfd000000-0xfdabffff\] has been reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: system 00:06: \[mem 0xf7fe0000-0xf7ffffff\] has been reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: system 00:06: \[mem 0xfee00000-0xfeefffff\] could not be reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: system 00:06: \[mem 0xff000000-0xffffffff\] has been reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: system 00:06: \[mem 0xfed45000-0xfed8ffff\] has been reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: system 00:06: \[mem 0xfed90000-0xfed93fff\] could not be reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: system 00:06: \[mem 0xfed20000-0xfed3ffff\] has been reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: system 00:06: \[mem 0xf8000000-0xfbffffff\] has been reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: system 00:06: \[mem 0xfed19000-0xfed19fff\] has been reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: system 00:06: \[mem 0xfed18000-0xfed18fff\] has been reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: system 00:06: \[mem 0xfed10000-0xfed17fff\] has been reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: system 00:04: \[io  0x0800-0x087f\] has been reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: system 00:03: \[io  0x164e-0x164f\] has been reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: system 00:03: \[io  0x1800-0x18fe\] could not be reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: system 00:03: \[io  0xffff\] has been reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: system 00:03: \[io  0x0680-0x069f\] has been reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: system 00:00: \[io  0x0a30-0x0a3f\] has been reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: system 00:00: \[io  0x0a20-0x0a2f\] has been reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: system 00:00: \[io  0x0a00-0x0a1f\] has been reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: pnp: PnP ACPI init
Dec 01 04:54:08 tracey-aspiretc780 kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Dec 01 04:54:08 tracey-aspiretc780 kernel: VFS: Disk quotas dquot_6.6.0
Dec 01 04:54:08 tracey-aspiretc780 kernel: clocksource: Switched to clocksource tsc-early
Dec 01 04:54:08 tracey-aspiretc780 kernel: hpet0: 8 comparators, 64-bit 24.000000 MHz counter
Dec 01 04:54:08 tracey-aspiretc780 kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
Dec 01 04:54:08 tracey-aspiretc780 kernel: vgaarb: loaded
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:02.0: vgaarb: bridge control possible
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:02.0: vgaarb: setting as boot VGA device
Dec 01 04:54:08 tracey-aspiretc780 kernel: e820: reserve RAM buffer \[mem 0x457000000-0x457ffffff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: e820: reserve RAM buffer \[mem 0xa53ff000-0xa7ffffff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: e820: reserve RAM buffer \[mem 0xa3efa000-0xa3ffffff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: e820: reserve RAM buffer \[mem 0xa1156000-0xa3ffffff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: e820: reserve RAM buffer \[mem 0xa0a59000-0xa3ffffff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: e820: reserve RAM buffer \[mem 0x9b6fd000-0x9bffffff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: e820: reserve RAM buffer \[mem 0x96beb018-0x97ffffff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: e820: reserve RAM buffer \[mem 0x0009e000-0x0009ffff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: e820: reserve RAM buffer \[mem 0x00058000-0x0005ffff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: PCI: pci_cache_line_size set to 64 bytes
Dec 01 04:54:08 tracey-aspiretc780 kernel: PCI: Using ACPI for IRQ routing
Dec 01 04:54:08 tracey-aspiretc780 kernel: NET: Registered PF_MCTP protocol family
Dec 01 04:54:08 tracey-aspiretc780 kernel: mctp: management component transport protocol core
Dec 01 04:54:08 tracey-aspiretc780 kernel: NetLabel:  unlabeled traffic allowed by default
Dec 01 04:54:08 tracey-aspiretc780 kernel: NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
Dec 01 04:54:08 tracey-aspiretc780 kernel: NetLabel:  domain hash size = 128
Dec 01 04:54:08 tracey-aspiretc780 kernel: NetLabel: Initializing
Dec 01 04:54:08 tracey-aspiretc780 kernel: efivars: Registered efivars operations
Dec 01 04:54:08 tracey-aspiretc780 kernel: EDAC MC: Ver: 3.0.0
Dec 01 04:54:08 tracey-aspiretc780 kernel: usbcore: registered new device driver usb
Dec 01 04:54:08 tracey-aspiretc780 kernel: usbcore: registered new interface driver hub
Dec 01 04:54:08 tracey-aspiretc780 kernel: usbcore: registered new interface driver usbfs
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: bus type USB registered
Dec 01 04:54:08 tracey-aspiretc780 kernel: libata version 3.00 loaded.
Dec 01 04:54:08 tracey-aspiretc780 kernel: SCSI subsystem initialized
Dec 01 04:54:08 tracey-aspiretc780 kernel: iommu: DMA domain TLB invalidation policy: lazy mode
Dec 01 04:54:08 tracey-aspiretc780 kernel: iommu: Default domain type: Translated
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: PCI: Interrupt link LNKH configured for IRQ 11
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: PCI: Interrupt link LNKG configured for IRQ 11
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: PCI: Interrupt link LNKF configured for IRQ 11
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: PCI: Interrupt link LNKE configured for IRQ 11
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: PCI: Interrupt link LNKD configured for IRQ 11
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: PCI: Interrupt link LNKC configured for IRQ 11
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: PCI: Interrupt link LNKB configured for IRQ 10
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: PCI: Interrupt link LNKA configured for IRQ 11
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:02:00.0: BAR 0 \[mem 0xf7000000-0xf7001fff 64bit\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:02:00.0: \[8086:24fb\] type 00 class 0x028000 PCIe Endpoint
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:01:00.0: supports D1 D2
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:01:00.0: BAR 4 \[mem 0xf0000000-0xf0003fff 64bit pref\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:01:00.0: BAR 2 \[mem 0xf7100000-0xf7100fff 64bit\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:01:00.0: BAR 0 \[io  0xe000-0xe0ff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:01:00.0: \[10ec:8168\] type 00 class 0x020000 PCIe Endpoint
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:1f.4: BAR 4 \[io  0xf040-0xf05f\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:1f.4: BAR 0 \[mem 0xf722a000-0xf722a0ff 64bit\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:1f.4: \[8086:a123\] type 00 class 0x0c0500 conventional PCI endpoint
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:1f.3: PME# supported from D3hot D3cold
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:1f.3: BAR 4 \[mem 0xf7200000-0xf720ffff 64bit\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:1f.3: BAR 0 \[mem 0xf7220000-0xf7223fff 64bit\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:1f.3: \[8086:a170\] type 00 class 0x040300 conventional PCI endpoint
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:1f.2: BAR 0 \[mem 0xf7224000-0xf7227fff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:1f.2: \[8086:a121\] type 00 class 0x058000 conventional PCI endpoint
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:1f.0: \[8086:a143\] type 00 class 0x060100 conventional PCI endpoint
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:1c.5: \[8086:a115\] type 01 class 0x060400 PCIe Root Port
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:1c.0: \[8086:a114\] type 01 class 0x060400 PCIe Root Port
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:17.0: PME# supported from D3hot
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:17.0: BAR 5 \[mem 0xf722b000-0xf722b7ff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:17.0: BAR 4 \[io  0xf060-0xf07f\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:17.0: BAR 3 \[io  0xf080-0xf083\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:17.0: BAR 2 \[io  0xf090-0xf097\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:17.0: BAR 1 \[mem 0xf722c000-0xf722c0ff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:17.0: BAR 0 \[mem 0xf7228000-0xf7229fff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:17.0: \[8086:a102\] type 00 class 0x010601 conventional PCI endpoint
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:16.0: PME# supported from D3hot
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:16.0: BAR 0 \[mem 0xf722d000-0xf722dfff 64bit\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:16.0: \[8086:a13a\] type 00 class 0x078000 conventional PCI endpoint
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:14.2: BAR 0 \[mem 0xf722e000-0xf722efff 64bit\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:14.2: \[8086:a131\] type 00 class 0x118000 conventional PCI endpoint
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:14.0: PME# supported from D3hot D3cold
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:14.0: BAR 0 \[mem 0xf7210000-0xf721ffff 64bit\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:14.0: \[8086:a12f\] type 00 class 0x0c0330 conventional PCI endpoint
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:08.0: BAR 0 \[mem 0xf722f000-0xf722ffff 64bit\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:08.0: \[8086:1911\] type 00 class 0x088000 conventional PCI endpoint
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:02.0: Video device with shadowed ROM at \[mem 0x000c0000-0x000dffff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:02.0: BAR 4 \[io  0xf000-0xf03f\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:02.0: BAR 2 \[mem 0xe0000000-0xefffffff 64bit pref\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:02.0: BAR 0 \[mem 0xf6000000-0xf6ffffff 64bit\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:02.0: \[8086:5912\] type 00 class 0x030000 PCIe Root Complex Integrated Endpoint
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci 0000:00:00.0: \[8086:591f\] type 00 class 0x060000 conventional PCI endpoint
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci_bus 0000:00: root bus resource \[bus 00-3e\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci_bus 0000:00: root bus resource \[mem 0xfd000000-0xfe7fffff window\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci_bus 0000:00: root bus resource \[mem 0xa8000000-0xf7ffffff window\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci_bus 0000:00: root bus resource \[mem 0x000a0000-0x000effff window\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci_bus 0000:00: root bus resource \[io  0x0d00-0xffff window\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: pci_bus 0000:00: root bus resource \[io  0x0000-0x0cf7 window\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: PCI host bridge to bus 0000:00
Dec 01 04:54:08 tracey-aspiretc780 kernel: acpi PNP0A08:00: *OSC: OS now controls \[PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: acpi PNP0A08:00: OSC: OS supports \[ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: PCI Root Bridge \[PCI0\] (domain 0000 \[bus 00-3e\])
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: \_TZ*.FN04: New power resource
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: \_TZ.FN03: New power resource
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: \_TZ\_.FN02: New power resource
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: \_TZ\_.FN01: New power resource
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: \_TZ\_.FN00: New power resource
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: \_SB\_.PCI0.RP16.PXSX.WRST: New power resource
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: \_SB\_.PCI0.RP15.PXSX.WRST: New power resource
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: \_SB\_.PCI0.RP14.PXSX.WRST: New power resource
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: \_SB\_.PCI0.RP20.PXSX.WRST: New power resource
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: \_SB\_.PCI0.RP19.PXSX.WRST: New power resource
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: \_SB\_.PCI0.RP18.PXSX.WRST: New power resource
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: \_SB\_.PCI0.RP17.PXSX.WRST: New power resource
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: \_SB\_.PCI0.RP08.PXSX.WRST: New power resource
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: \_SB\_.PCI0.RP07.PXSX.WRST: New power resource
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: \_SB\_.PCI0.RP06.PXSX.WRST: New power resource
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: \_SB\_.PCI0.RP05.PXSX.WRST: New power resource
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: \_SB\_.PCI0.RP04.PXSX.WRST: New power resource
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: \_SB\_.PCI0.RP03.PXSX.WRST: New power resource
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: \_SB\_.PCI0.RP02.PXSX.WRST: New power resource
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: \_SB\_.PCI0.RP01.PXSX.WRST: New power resource
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: \_SB\_.PCI0.RP13.PXSX.WRST: New power resource
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: \_SB\_.PCI0.RP12.PXSX.WRST: New power resource
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: \_SB\_.PCI0.RP11.PXSX.WRST: New power resource
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: \_SB\_.PCI0.RP10.PXSX.WRST: New power resource
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: \_SB\_.PCI0.RP09.PXSX.WRST: New power resource
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: \_SB\_.PCI0.PEG2.PG02: New power resource
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: \_SB\_.PCI0.PEG1.PG01: New power resource
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: \_SB\_.PCI0.PEG0.PG00: New power resource
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Enabled 6 GPEs in block 00 to 7F
Dec 01 04:54:08 tracey-aspiretc780 kernel: PCI: Using E820 reservations for host bridge windows
Dec 01 04:54:08 tracey-aspiretc780 kernel: PCI: Using host bridge windows from ACPI; if necessary, use “pci=nocrs” and report a bug
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Using IOAPIC for interrupt routing
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: PM: (supports S0 S3 S4 S5)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Interpreter enabled
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: SSDT 0xFFFF88AAC1AA2C00 00018A (v02 PmRef  ApCst    00003000 INTL 20160422)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Dynamic OEM Table Load:
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: SSDT 0xFFFF88AAC1AA2600 000197 (v02 PmRef  ApHwp    00003000 INTL 20160422)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: SSDT 0xFFFF88AAC0F76800 00065C (v02 PmRef  ApIst    00003000 INTL 20160422)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: SSDT 0xFFFF88AAC1AA3400 0001A4 (v02 PmRef  HwpLvt   00003000 INTL 20160422)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: SSDT 0xFFFF88AAC1AA3C00 000115 (v02 PmRef  Cpu0Hwp  00003000 INTL 20160422)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: SSDT 0xFFFF88AAC0F72000 000693 (v02 PmRef  Cpu0Ist  00003000 INTL 20160422)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: SSDT 0xFFFF88AAC1A62C00 0003FF (v02 PmRef  Cpu0Cst  00003001 INTL 20160422)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: \[Firmware Bug\]: BIOS \_OSI(Linux) query ignored
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: 10 ACPI AML tables successfully acquired and loaded
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Added \_OSI(Processor Aggregator Device)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Added \_OSI(Processor Device)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Added \_OSI(Module Device)
Dec 01 04:54:08 tracey-aspiretc780 kernel: HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
Dec 01 04:54:08 tracey-aspiretc780 kernel: HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
Dec 01 04:54:08 tracey-aspiretc780 kernel: HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
Dec 01 04:54:08 tracey-aspiretc780 kernel: HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
Dec 01 04:54:08 tracey-aspiretc780 kernel: kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
Dec 01 04:54:08 tracey-aspiretc780 kernel: PCI: Using configuration type 1 for base access
Dec 01 04:54:08 tracey-aspiretc780 kernel: PCI: ECAM \[mem 0xf8000000-0xfbffffff\] (base 0xf8000000) for domain 0000 \[bus 00-3f\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
Dec 01 04:54:08 tracey-aspiretc780 kernel: cpuidle: using governor menu
Dec 01 04:54:08 tracey-aspiretc780 kernel: cpuidle: using governor ladder
Dec 01 04:54:08 tracey-aspiretc780 kernel: thermal_sys: Registered thermal governor ‘power_allocator’
Dec 01 04:54:08 tracey-aspiretc780 kernel: thermal_sys: Registered thermal governor ‘user_space’
Dec 01 04:54:08 tracey-aspiretc780 kernel: thermal_sys: Registered thermal governor ‘step_wise’
Dec 01 04:54:08 tracey-aspiretc780 kernel: thermal_sys: Registered thermal governor ‘bang_bang’
Dec 01 04:54:08 tracey-aspiretc780 kernel: thermal_sys: Registered thermal governor ‘fair_share’
Dec 01 04:54:08 tracey-aspiretc780 kernel: audit: type=2000 audit(1764579237.063:1): state=initialized audit_enabled=0 res=1
Dec 01 04:54:08 tracey-aspiretc780 kernel: audit: initializing netlink subsys (disabled)
Dec 01 04:54:08 tracey-aspiretc780 kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
Dec 01 04:54:08 tracey-aspiretc780 kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
Dec 01 04:54:08 tracey-aspiretc780 kernel: DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
Dec 01 04:54:08 tracey-aspiretc780 kernel: NET: Registered PF_NETLINK/PF_ROUTE protocol family
Dec 01 04:54:08 tracey-aspiretc780 kernel: PM: RTC time: 08:53:57, date: 2025-12-01
Dec 01 04:54:08 tracey-aspiretc780 kernel: pinctrl core: initialized pinctrl subsystem
Dec 01 04:54:08 tracey-aspiretc780 kernel: futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
Dec 01 04:54:08 tracey-aspiretc780 kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: PM: Registering ACPI NVS region \[mem 0xa4a37000-0xa4e5cfff\] (4349952 bytes)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: PM: Registering ACPI NVS region \[mem 0x9b6fd000-0x9b6fdfff\] (4096 bytes)
Dec 01 04:54:08 tracey-aspiretc780 kernel: x86/mm: Memory block size: 128MB
Dec 01 04:54:08 tracey-aspiretc780 kernel: devtmpfs: initialized
Dec 01 04:54:08 tracey-aspiretc780 kernel: Memory: 16240772K/16693844K available (18432K kernel code, 2681K rwdata, 14364K rodata, 4288K init, 4260K bss, 440324K reserved, 0K cma-reserved)
Dec 01 04:54:08 tracey-aspiretc780 kernel: smpboot: Total of 4 processors activated (24009.00 BogoMIPS)
Dec 01 04:54:08 tracey-aspiretc780 kernel: smp: Brought up 1 node, 4 CPUs
Dec 01 04:54:08 tracey-aspiretc780 kernel: … node  #0, CPUs:      #1 #2 #3
Dec 01 04:54:08 tracey-aspiretc780 kernel: smpboot: x86: Booting SMP configuration:
Dec 01 04:54:08 tracey-aspiretc780 kernel: smp: Bringing up secondary CPUs …
Dec 01 04:54:08 tracey-aspiretc780 kernel: NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
Dec 01 04:54:08 tracey-aspiretc780 kernel: Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
Dec 01 04:54:08 tracey-aspiretc780 kernel: rcu:         Max phase no-delay instances is 1000.
Dec 01 04:54:08 tracey-aspiretc780 kernel: rcu: Hierarchical SRCU implementation.
Dec 01 04:54:08 tracey-aspiretc780 kernel: Estimated ratio of average max frequency by base frequency (times 1024): 1126
Dec 01 04:54:08 tracey-aspiretc780 kernel: signal: max sigframe size: 2032
Dec 01 04:54:08 tracey-aspiretc780 kernel: … event mask:             00000007000000ff
Dec 01 04:54:08 tracey-aspiretc780 kernel: … fixed-purpose events:   3
Dec 01 04:54:08 tracey-aspiretc780 kernel: … max period:             00007fffffffffff
Dec 01 04:54:08 tracey-aspiretc780 kernel: … value mask:             0000ffffffffffff
Dec 01 04:54:08 tracey-aspiretc780 kernel: … generic registers:      8
Dec 01 04:54:08 tracey-aspiretc780 kernel: … bit width:              48
Dec 01 04:54:08 tracey-aspiretc780 kernel: … version:                4
Dec 01 04:54:08 tracey-aspiretc780 kernel: Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
Dec 01 04:54:08 tracey-aspiretc780 kernel: smpboot: CPU0: Intel(R) Core™ i5-7400 CPU @ 3.00GHz (family: 0x6, model: 0x9e, stepping: 0x9)
Dec 01 04:54:08 tracey-aspiretc780 kernel: Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
Dec 01 04:54:08 tracey-aspiretc780 kernel: Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
Dec 01 04:54:08 tracey-aspiretc780 kernel: LSM support for eBPF active
Dec 01 04:54:08 tracey-aspiretc780 kernel: Yama: becoming mindful.
Dec 01 04:54:08 tracey-aspiretc780 kernel: landlock: Up and running.
Dec 01 04:54:08 tracey-aspiretc780 kernel: LSM: initializing lsm=capability,landlock,lockdown,yama,bpf
Dec 01 04:54:08 tracey-aspiretc780 kernel: pid_max: default: 32768 minimum: 301
Dec 01 04:54:08 tracey-aspiretc780 kernel: Freeing SMP alternatives memory: 44K
Dec 01 04:54:08 tracey-aspiretc780 kernel: x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using ‘compacted’ format.
Dec 01 04:54:08 tracey-aspiretc780 kernel: x86/fpu: xstate_offset\[4\]:  896, xstate_sizes\[4\]:   64
Dec 01 04:54:08 tracey-aspiretc780 kernel: x86/fpu: xstate_offset\[3\]:  832, xstate_sizes\[3\]:   64
Dec 01 04:54:08 tracey-aspiretc780 kernel: x86/fpu: xstate_offset\[2\]:  576, xstate_sizes\[2\]:  256
Dec 01 04:54:08 tracey-aspiretc780 kernel: x86/fpu: Supporting XSAVE feature 0x010: ‘MPX CSR’
Dec 01 04:54:08 tracey-aspiretc780 kernel: x86/fpu: Supporting XSAVE feature 0x008: ‘MPX bounds registers’
Dec 01 04:54:08 tracey-aspiretc780 kernel: x86/fpu: Supporting XSAVE feature 0x004: ‘AVX registers’
Dec 01 04:54:08 tracey-aspiretc780 kernel: x86/fpu: Supporting XSAVE feature 0x002: ‘SSE registers’
Dec 01 04:54:08 tracey-aspiretc780 kernel: x86/fpu: Supporting XSAVE feature 0x001: ‘x87 floating point registers’
Dec 01 04:54:08 tracey-aspiretc780 kernel: VMSCAPE: Mitigation: IBPB before exit to userspace
Dec 01 04:54:08 tracey-aspiretc780 kernel: GDS: Mitigation: Microcode
Dec 01 04:54:08 tracey-aspiretc780 kernel: SRBDS: Mitigation: Microcode
Dec 01 04:54:08 tracey-aspiretc780 kernel: MMIO Stale Data: Mitigation: Clear CPU buffers
Dec 01 04:54:08 tracey-aspiretc780 kernel: MDS: Mitigation: Clear CPU buffers
Dec 01 04:54:08 tracey-aspiretc780 kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
Dec 01 04:54:08 tracey-aspiretc780 kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
Dec 01 04:54:08 tracey-aspiretc780 kernel: RETBleed: Mitigation: IBRS
Dec 01 04:54:08 tracey-aspiretc780 kernel: Spectre V2 : Spectre v2 / SpectreRSB: Filling RSB on context switch and VMEXIT
Dec 01 04:54:08 tracey-aspiretc780 kernel: Spectre V2 : Mitigation: IBRS
Dec 01 04:54:08 tracey-aspiretc780 kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and \__user pointer sanitization
Dec 01 04:54:08 tracey-aspiretc780 kernel: process: using mwait in idle threads
Dec 01 04:54:08 tracey-aspiretc780 kernel: Last level dTLB entries: 4KB 64, 2MB 32, 4MB 32, 1GB 4
Dec 01 04:54:08 tracey-aspiretc780 kernel: Last level iTLB entries: 4KB 128, 2MB 8, 4MB 8
Dec 01 04:54:08 tracey-aspiretc780 kernel: CPU0: Thermal monitoring enabled (TM1)
Dec 01 04:54:08 tracey-aspiretc780 kernel: x86/cpu: SGX disabled or unsupported by BIOS.
Dec 01 04:54:08 tracey-aspiretc780 kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 6002.00 BogoMIPS (lpj=10000000)
Dec 01 04:54:08 tracey-aspiretc780 kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2b3e459bf4c, max_idle_ns: 440795289890 ns
Dec 01 04:54:08 tracey-aspiretc780 kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
Dec 01 04:54:08 tracey-aspiretc780 kernel: APIC: Switched APIC routing to: cluster x2apic
Dec 01 04:54:08 tracey-aspiretc780 kernel: x2apic enabled
Dec 01 04:54:08 tracey-aspiretc780 kernel: DMAR-IR: Enabled IRQ remapping in x2apic mode
Dec 01 04:54:08 tracey-aspiretc780 kernel: DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
Dec 01 04:54:08 tracey-aspiretc780 kernel: DMAR-IR: HPET id 0 under DRHD base 0xfed91000
Dec 01 04:54:08 tracey-aspiretc780 kernel: DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
Dec 01 04:54:08 tracey-aspiretc780 kernel: DMAR: RMRR base: 0x000000a5800000 end: 0x000000a7ffffff
Dec 01 04:54:08 tracey-aspiretc780 kernel: DMAR: RMRR base: 0x000000a433a000 end: 0x000000a4359fff
Dec 01 04:54:08 tracey-aspiretc780 kernel: DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
Dec 01 04:54:08 tracey-aspiretc780 kernel: DMAR: DRHD base: 0x000000fed91000 flags: 0x1
Dec 01 04:54:08 tracey-aspiretc780 kernel: DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
Dec 01 04:54:08 tracey-aspiretc780 kernel: DMAR: DRHD base: 0x000000fed90000 flags: 0x0
Dec 01 04:54:08 tracey-aspiretc780 kernel: DMAR: Host address width 39
Dec 01 04:54:08 tracey-aspiretc780 kernel: APIC: Switch to symmetric I/O mode setup
Dec 01 04:54:08 tracey-aspiretc780 kernel: clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Core revision 20240827
Dec 01 04:54:08 tracey-aspiretc780 kernel: printk: legacy console \[tty0\] enabled
Dec 01 04:54:08 tracey-aspiretc780 kernel: Console: colour dummy device 80x25
Dec 01 04:54:08 tracey-aspiretc780 kernel: kfence: initialized - using 2097152 bytes for 255 objects at 0x(***ptrval***)-0x(***ptrval***)
Dec 01 04:54:08 tracey-aspiretc780 kernel: rcu: srcu_init: Setting srcu_struct sizes based on contention.
Dec 01 04:54:08 tracey-aspiretc780 kernel: NR_IRQS: 524544, nr_irqs: 1024, preallocated irqs: 16
Dec 01 04:54:08 tracey-aspiretc780 kernel: RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
Dec 01 04:54:08 tracey-aspiretc780 kernel: RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
Dec 01 04:54:08 tracey-aspiretc780 kernel: RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
Dec 01 04:54:08 tracey-aspiretc780 kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
Dec 01 04:54:08 tracey-aspiretc780 kernel: rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
Dec 01 04:54:08 tracey-aspiretc780 kernel:         Tracing variant of Tasks RCU enabled.
Dec 01 04:54:08 tracey-aspiretc780 kernel:         Rude variant of Tasks RCU enabled.
Dec 01 04:54:08 tracey-aspiretc780 kernel:         Trampoline variant of Tasks RCU enabled.
Dec 01 04:54:08 tracey-aspiretc780 kernel: rcu:         RCU priority boosting: priority 1 delay 500 ms.
Dec 01 04:54:08 tracey-aspiretc780 kernel: rcu:         RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=4.
Dec 01 04:54:08 tracey-aspiretc780 kernel: rcu: Preemptible hierarchical RCU implementation.
Dec 01 04:54:08 tracey-aspiretc780 kernel: Dynamic Preempt: full
Dec 01 04:54:08 tracey-aspiretc780 kernel: ftrace: allocated 202 pages with 4 groups
Dec 01 04:54:08 tracey-aspiretc780 kernel: ftrace: allocating 51466 entries in 202 pages
Dec 01 04:54:08 tracey-aspiretc780 kernel: Kernel/User page tables isolation: enabled
Dec 01 04:54:08 tracey-aspiretc780 kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Dec 01 04:54:08 tracey-aspiretc780 kernel: software IO TLB: area num 4.
Dec 01 04:54:08 tracey-aspiretc780 kernel: mem auto-init: stack:all(zero), heap alloc:on, heap free:off
Dec 01 04:54:08 tracey-aspiretc780 kernel: Policy zone: Normal
Dec 01 04:54:08 tracey-aspiretc780 kernel: Built 1 zonelists, mobility grouping on.  Total pages: 4173461
Dec 01 04:54:08 tracey-aspiretc780 kernel: Fallback order for Node 0: 0
Dec 01 04:54:08 tracey-aspiretc780 kernel: Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
Dec 01 04:54:08 tracey-aspiretc780 kernel: Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
Dec 01 04:54:08 tracey-aspiretc780 kernel: Unknown kernel command line parameters “splash BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64 apm=power_off”, will be passed to user space.
Dec 01 04:54:08 tracey-aspiretc780 kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64 root=UUID=a13ec453-9088-41a0-aca1-b168970630a1 rw quiet splash udev.log_priority=3 acpi=force apm=power_off
Dec 01 04:54:08 tracey-aspiretc780 kernel: pcpu-alloc: \[0\] 0 1 2 3
Dec 01 04:54:08 tracey-aspiretc780 kernel: pcpu-alloc: s237568 r8192 d28672 u524288 alloc=1\*2097152
Dec 01 04:54:08 tracey-aspiretc780 kernel: percpu: Embedded 67 pages/cpu s237568 r8192 d28672 u524288
Dec 01 04:54:08 tracey-aspiretc780 kernel: setup_percpu: NR_CPUS:8192 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node_ids:1
Dec 01 04:54:08 tracey-aspiretc780 kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
Dec 01 04:54:08 tracey-aspiretc780 kernel: Booting paravirtualized kernel on bare hardware
Dec 01 04:54:08 tracey-aspiretc780 kernel: \[mem 0xa8000000-0xfdffffff\] available for PCI devices
Dec 01 04:54:08 tracey-aspiretc780 kernel: PM: hibernation: Registered nosave memory: \[mem 0xa53ff000-0xffffffff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: PM: hibernation: Registered nosave memory: \[mem 0xa3efa000-0xa53fdfff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: PM: hibernation: Registered nosave memory: \[mem 0xa1156000-0xa1156fff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: PM: hibernation: Registered nosave memory: \[mem 0xa0a59000-0xa0b4cfff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: PM: hibernation: Registered nosave memory: \[mem 0x9b6fd000-0x9b6fefff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: PM: hibernation: Registered nosave memory: \[mem 0x0009e000-0x000fffff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: PM: hibernation: Registered nosave memory: \[mem 0x00058000-0x00058fff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: PM: hibernation: Registered nosave memory: \[mem 0x00000000-0x00000fff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: CPU topo: Allowing 4 present CPUs plus 0 hotplug CPUs
Dec 01 04:54:08 tracey-aspiretc780 kernel: CPU topo: Num. threads per package:   4
Dec 01 04:54:08 tracey-aspiretc780 kernel: CPU topo: Num. cores per package:     4
Dec 01 04:54:08 tracey-aspiretc780 kernel: CPU topo: Max. threads per core:   1
Dec 01 04:54:08 tracey-aspiretc780 kernel: CPU topo: Max. dies per package:   1
Dec 01 04:54:08 tracey-aspiretc780 kernel: CPU topo: Max. logical dies:       1
Dec 01 04:54:08 tracey-aspiretc780 kernel: CPU topo: Max. logical packages:   1
Dec 01 04:54:08 tracey-aspiretc780 kernel: TSC deadline timer available
Dec 01 04:54:08 tracey-aspiretc780 kernel: e820: update \[mem 0xa0a59000-0xa0b4cfff\] usable ==> reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: HPET id: 0x8086a201 base: 0xfed00000
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Using ACPI (MADT) for SMP configuration information
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Dec 01 04:54:08 tracey-aspiretc780 kernel: IOAPIC\[0\]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: LAPIC_NMI (acpi_id\[0x04\] high edge lint\[0x1\])
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: LAPIC_NMI (acpi_id\[0x03\] high edge lint\[0x1\])
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: LAPIC_NMI (acpi_id\[0x02\] high edge lint\[0x1\])
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: LAPIC_NMI (acpi_id\[0x01\] high edge lint\[0x1\])
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: PM-Timer IO Port: 0x1808
Dec 01 04:54:08 tracey-aspiretc780 kernel: Reserving Intel graphics memory at \[mem 0xa6000000-0xa7ffffff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: On node 0, zone Normal: 4096 pages in unavailable ranges
Dec 01 04:54:08 tracey-aspiretc780 kernel: On node 0, zone Normal: 11265 pages in unavailable ranges
Dec 01 04:54:08 tracey-aspiretc780 kernel: On node 0, zone DMA32: 5380 pages in unavailable ranges
Dec 01 04:54:08 tracey-aspiretc780 kernel: On node 0, zone DMA32: 2 pages in unavailable ranges
Dec 01 04:54:08 tracey-aspiretc780 kernel: On node 0, zone DMA: 98 pages in unavailable ranges
Dec 01 04:54:08 tracey-aspiretc780 kernel: On node 0, zone DMA: 1 pages in unavailable ranges
Dec 01 04:54:08 tracey-aspiretc780 kernel: Initmem setup node 0 \[mem 0x0000000000001000-0x0000000456ffffff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel:   node   0: \[mem 0x0000000100000000-0x0000000456ffffff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel:   node   0: \[mem 0x00000000a53fe000-0x00000000a53fefff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel:   node   0: \[mem 0x000000009b6ff000-0x00000000a3ef9fff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel:   node   0: \[mem 0x0000000000100000-0x000000009b6fcfff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel:   node   0: \[mem 0x0000000000059000-0x000000000009dfff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel:   node   0: \[mem 0x0000000000001000-0x0000000000057fff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: Early memory node ranges
Dec 01 04:54:08 tracey-aspiretc780 kernel: Movable zone start for each node
Dec 01 04:54:08 tracey-aspiretc780 kernel:   Device   empty
Dec 01 04:54:08 tracey-aspiretc780 kernel:   Normal   \[mem 0x0000000100000000-0x0000000456ffffff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel:   DMA32    \[mem 0x0000000001000000-0x00000000ffffffff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel:   DMA      \[mem 0x0000000000001000-0x0000000000ffffff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: Zone ranges:
Dec 01 04:54:08 tracey-aspiretc780 kernel: NODE_DATA(0) allocated \[mem 0x456fd52c0-0x456ffffff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: Faking a node at \[mem 0x0000000000000000-0x0000000456ffffff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: No NUMA configuration found
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Reserving ASF! table memory at \[mem 0xa4a0b980-0xa4a0ba1f\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Reserving TPM2 table memory at \[mem 0xa4a0b948-0xa4a0b97b\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Reserving DMAR table memory at \[mem 0xa4a0b8a0-0xa4a0b947\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Reserving BGRT table memory at \[mem 0xa4a0b868-0xa4a0b89f\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Reserving DBG2 table memory at \[mem 0xa4a0b810-0xa4a0b863\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Reserving DBGP table memory at \[mem 0xa4a0b7d8-0xa4a0b80b\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Reserving SSDT table memory at \[mem 0xa4a087d0-0xa4a0b7d1\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Reserving SSDT table memory at \[mem 0xa4a08530-0xa4a087ce\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Reserving WSMT table memory at \[mem 0xa4a08508-0xa4a0852f\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Reserving LPIT table memory at \[mem 0xa4a08470-0xa4a08503\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Reserving SSDT table memory at \[mem 0xa4a07590-0xa4a0846d\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Reserving UEFI table memory at \[mem 0xa4a07548-0xa4a07589\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Reserving SSDT table memory at \[mem 0xa4a06c58-0xa4a07547\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Reserving SSDT table memory at \[mem 0xa4a05e70-0xa4a06c54\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Reserving SSDT table memory at \[mem 0xa4a05e48-0xa4a05e6b\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Reserving HPET table memory at \[mem 0xa4a05e10-0xa4a05e47\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Reserving SSDT table memory at \[mem 0xa4a03760-0xa4a05e0d\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Reserving SSDT table memory at \[mem 0xa4a00600-0xa4a03758\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Reserving MSDM table memory at \[mem 0xa4a005a8-0xa4a005fc\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Reserving FIDT table memory at \[mem 0xa4a00508-0xa4a005a3\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Reserving SSDT table memory at \[mem 0xa4a00148-0xa4a00503\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Reserving MCFG table memory at \[mem 0xa4a00108-0xa4a00143\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Reserving FPDT table memory at \[mem 0xa4a000c0-0xa4a00103\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Reserving APIC table memory at \[mem 0xa4a00038-0xa4a000bb\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Reserving FACS table memory at \[mem 0xa4e21c40-0xa4e21c7f\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Reserving DSDT table memory at \[mem 0xa49d5240-0xa49fff1d\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Reserving FACP table memory at \[mem 0xa49fff20-0xa4a00033\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: ASF! 0x00000000A4A0B980 0000A0 (v32 INTEL   HCG     00000001 TFSM 000F4240)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: TPM2 0x00000000A4A0B948 000034 (v03        Tpm2Tabl 00000001 AMI  00000000)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: DMAR 0x00000000A4A0B8A0 0000A8 (v01 INTEL  KBL      00000001 INTL 00000001)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: BGRT 0x00000000A4A0B868 000038 (v01 ACRSYS ACRPRDCT 10000000 AMI  00010013)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: DBG2 0x00000000A4A0B810 000054 (v00 INTEL           00000002 MSFT 0000005F)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: DBGP 0x00000000A4A0B7D8 000034 (v01 INTEL           00000002 MSFT 0000005F)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: SSDT 0x00000000A4A087D0 003002 (v02 INTEL  PtidDevc 00001000 INTL 20160422)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: SSDT 0x00000000A4A08530 00029F (v02 INTEL  sensrhub 00000000 INTL 20160422)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: WSMT 0x00000000A4A08508 000028 (v01 INTEL  KBL      00000000 MSFT 0000005F)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: LPIT 0x00000000A4A08470 000094 (v01 INTEL  KBL      00000000 MSFT 0000005F)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: SSDT 0x00000000A4A07590 000EDE (v02 CpuRef CpuSsdt  00003000 INTL 20160422)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: UEFI 0x00000000A4A07548 000042 (v01 INTEL  EDK2     00000002      01000013)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: SSDT 0x00000000A4A06C58 0008F0 (v02 INTEL  xh_rvp08 00000000 INTL 20160422)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: SSDT 0x00000000A4A05E70 000DE5 (v02 INTEL  Ther_Rvp 00001000 INTL 20160422)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: SSDT 0x00000000A4A05E48 000024 (v02 INTEL  OEM_RTD3 00001000 INTL 20160422)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: HPET 0x00000000A4A05E10 000038 (v01 INTEL  KBL      00000001 MSFT 0000005F)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: SSDT 0x00000000A4A03760 0026AE (v02 PegSsd PegSsdt  00001000 INTL 20160422)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: SSDT 0x00000000A4A00600 003159 (v02 SaSsdt SaSsdt   00003000 INTL 20160422)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: MSDM 0x00000000A4A005A8 000055 (v03 ACRSYS ACRPRDCT 10000000 AMI  00010013)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: FIDT 0x00000000A4A00508 00009C (v01 ACRSYS ACRPRDCT 10000000 AMI  00010013)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: SSDT 0x00000000A4A00148 0003BC (v01 SataRe SataTabl 00001000 INTL 20160422)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: MCFG 0x00000000A4A00108 00003C (v01 ACRSYS ACRPRDCT 10000000 MSFT 00000097)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: FPDT 0x00000000A4A000C0 000044 (v01 ACRSYS ACRPRDCT 10000000 AMI  00010013)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: APIC 0x00000000A4A00038 000084 (v03 ACRSYS ACRPRDCT 10000000 AMI  00010013)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: FACS 0x00000000A4E21C40 000040
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: DSDT 0x00000000A49D5240 02ACDE (v02 ACRSYS ACRPRDCT 10000000 INTL 20160422)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: FACP 0x00000000A49FFF20 000114 (v06 ACRSYS ACRPRDCT 10000000 AMI  00010013)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: XSDT 0x00000000A49D50B8 0000F4 (v01 ACRSYS ACRPRDCT 10000000 AMI  00010013)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: RSDP 0x00000000A49D5000 000024 (v02 ACRSYS)
Dec 01 04:54:08 tracey-aspiretc780 kernel: ACPI: Early table checksum verification disabled
Dec 01 04:54:08 tracey-aspiretc780 kernel: RAMDISK: \[mem 0x96bfc000-0x989fefff\]
Dec 01 04:54:08 tracey-aspiretc780 kernel: Secure boot disabled
Dec 01 04:54:08 tracey-aspiretc780 kernel: Using GB pages for direct mapping
Dec 01 04:54:08 tracey-aspiretc780 kernel: e820: update \[mem 0xa1156000-0xa1156fff\] usable ==> reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: esrt: Reserving ESRT space from 0x00000000a1156c98 to 0x00000000a1156cd0.
Dec 01 04:54:08 tracey-aspiretc780 kernel: last_pfn = 0xa53ff max_arch_pfn = 0x400000000
Dec 01 04:54:08 tracey-aspiretc780 kernel: x86/PAT: Configuration \[0-7\]: WB  WC  UC- UC  WB  WP  UC- WT
Dec 01 04:54:08 tracey-aspiretc780 kernel: MTRR map: 4 entries (3 fixed + 1 variable; max 23), built from 10 variable MTRRs
Dec 01 04:54:08 tracey-aspiretc780 kernel: last_pfn = 0x457000 max_arch_pfn = 0x400000000
Dec 01 04:54:08 tracey-aspiretc780 kernel: e820: remove \[mem 0x000a0000-0x000fffff\] usable
Dec 01 04:54:08 tracey-aspiretc780 kernel: e820: update \[mem 0x00000000-0x00000fff\] usable ==> reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: tsc: Detected 3000.000 MHz processor
Dec 01 04:54:08 tracey-aspiretc780 kernel: DMI: Memory slots populated: 2/2
Dec 01 04:54:08 tracey-aspiretc780 kernel: DMI: Acer Aspire TC-780/Aspire TC-780(KBL), BIOS R02-A0 11/17/2016
Dec 01 04:54:08 tracey-aspiretc780 kernel: SMBIOS 3.0.0 present.
Dec 01 04:54:08 tracey-aspiretc780 kernel: e820: remove \[mem 0xff000000-0xffffffff\] reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: efi: Remove mem40: MMIO range=\[0xff000000-0xffffffff\] (16MB) from e820 map
Dec 01 04:54:08 tracey-aspiretc780 kernel: efi: Not removing mem39: MMIO range=\[0xfee00000-0xfee00fff\] (4KB) from e820 map
Dec 01 04:54:08 tracey-aspiretc780 kernel: efi: Not removing mem38: MMIO range=\[0xfed00000-0xfed00fff\] (4KB) from e820 map
Dec 01 04:54:08 tracey-aspiretc780 kernel: efi: Not removing mem37: MMIO range=\[0xfec00000-0xfec00fff\] (4KB) from e820 map
Dec 01 04:54:08 tracey-aspiretc780 kernel: efi: Not removing mem36: MMIO range=\[0xfe000000-0xfe010fff\] (68KB) from e820 map
Dec 01 04:54:08 tracey-aspiretc780 kernel: e820: remove \[mem 0xf8000000-0xfbffffff\] reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: efi: Remove mem35: MMIO range=\[0xf8000000-0xfbffffff\] (64MB) from e820 map
Dec 01 04:54:08 tracey-aspiretc780 kernel: random: crng init done
Dec 01 04:54:08 tracey-aspiretc780 kernel: efi: TPMFinalLog=0xa4e45000 ACPI 2.0=0xa49d5000 ACPI=0xa49d5000 SMBIOS=0xa52dc000 SMBIOS 3.0=0xa52db000 ESRT=0xa1156c98 INITRD=0x9b7b8b18 RNG=0xa49d4018 TPMEventLog=0xa49cb018
Dec 01 04:54:08 tracey-aspiretc780 kernel: efi: EFI v2.5 by Acer Inc.
Dec 01 04:54:08 tracey-aspiretc780 kernel: reserve setup_data: \[mem 0x0000000100000000-0x0000000456ffffff\] usable
Dec 01 04:54:08 tracey-aspiretc780 kernel: reserve setup_data: \[mem 0x00000000ff000000-0x00000000ffffffff\] reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: reserve setup_data: \[mem 0x00000000fee00000-0x00000000fee00fff\] reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: reserve setup_data: \[mem 0x00000000fed00000-0x00000000fed00fff\] reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: reserve setup_data: \[mem 0x00000000fec00000-0x00000000fec00fff\] reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: reserve setup_data: \[mem 0x00000000fe000000-0x00000000fe010fff\] reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: reserve setup_data: \[mem 0x00000000f8000000-0x00000000fbffffff\] reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: reserve setup_data: \[mem 0x00000000a53ff000-0x00000000a7ffffff\] reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: reserve setup_data: \[mem 0x00000000a53fe000-0x00000000a53fefff\] usable
Dec 01 04:54:08 tracey-aspiretc780 kernel: reserve setup_data: \[mem 0x00000000a4e5d000-0x00000000a53fdfff\] reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: reserve setup_data: \[mem 0x00000000a4a37000-0x00000000a4e5cfff\] ACPI NVS
Dec 01 04:54:08 tracey-aspiretc780 kernel: reserve setup_data: \[mem 0x00000000a49bd000-0x00000000a4a36fff\] ACPI data
Dec 01 04:54:08 tracey-aspiretc780 kernel: reserve setup_data: \[mem 0x00000000a3efa000-0x00000000a49bcfff\] reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: reserve setup_data: \[mem 0x000000009b6ff000-0x00000000a3ef9fff\] usable
Dec 01 04:54:08 tracey-aspiretc780 kernel: reserve setup_data: \[mem 0x000000009b6fe000-0x000000009b6fefff\] reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: reserve setup_data: \[mem 0x000000009b6fd000-0x000000009b6fdfff\] ACPI NVS
Dec 01 04:54:08 tracey-aspiretc780 kernel: reserve setup_data: \[mem 0x0000000096bfb058-0x000000009b6fcfff\] usable
Dec 01 04:54:08 tracey-aspiretc780 kernel: reserve setup_data: \[mem 0x0000000096beb018-0x0000000096bfb057\] usable
Dec 01 04:54:08 tracey-aspiretc780 kernel: reserve setup_data: \[mem 0x0000000000100000-0x0000000096beb017\] usable
Dec 01 04:54:08 tracey-aspiretc780 kernel: reserve setup_data: \[mem 0x000000000009e000-0x00000000000fffff\] reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: reserve setup_data: \[mem 0x0000000000059000-0x000000000009dfff\] usable
Dec 01 04:54:08 tracey-aspiretc780 kernel: reserve setup_data: \[mem 0x0000000000058000-0x0000000000058fff\] reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: reserve setup_data: \[mem 0x0000000000000000-0x0000000000057fff\] usable
Dec 01 04:54:08 tracey-aspiretc780 kernel: extended physical RAM map:
Dec 01 04:54:08 tracey-aspiretc780 kernel: e820: update \[mem 0x96beb018-0x96bfb057\] usable ==> usable
Dec 01 04:54:08 tracey-aspiretc780 kernel: APIC: Static calls initialized
Dec 01 04:54:08 tracey-aspiretc780 kernel: NX (Execute Disable) protection: active
Dec 01 04:54:08 tracey-aspiretc780 kernel: BIOS-e820: \[mem 0x0000000100000000-0x0000000456ffffff\] usable
Dec 01 04:54:08 tracey-aspiretc780 kernel: BIOS-e820: \[mem 0x00000000ff000000-0x00000000ffffffff\] reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: BIOS-e820: \[mem 0x00000000fee00000-0x00000000fee00fff\] reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: BIOS-e820: \[mem 0x00000000fed00000-0x00000000fed00fff\] reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: BIOS-e820: \[mem 0x00000000fec00000-0x00000000fec00fff\] reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: BIOS-e820: \[mem 0x00000000fe000000-0x00000000fe010fff\] reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: BIOS-e820: \[mem 0x00000000f8000000-0x00000000fbffffff\] reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: BIOS-e820: \[mem 0x00000000a53ff000-0x00000000a7ffffff\] reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: BIOS-e820: \[mem 0x00000000a53fe000-0x00000000a53fefff\] usable
Dec 01 04:54:08 tracey-aspiretc780 kernel: BIOS-e820: \[mem 0x00000000a4e5d000-0x00000000a53fdfff\] reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: BIOS-e820: \[mem 0x00000000a4a37000-0x00000000a4e5cfff\] ACPI NVS
Dec 01 04:54:08 tracey-aspiretc780 kernel: BIOS-e820: \[mem 0x00000000a49bd000-0x00000000a4a36fff\] ACPI data
Dec 01 04:54:08 tracey-aspiretc780 kernel: BIOS-e820: \[mem 0x00000000a3efa000-0x00000000a49bcfff\] reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: BIOS-e820: \[mem 0x000000009b6ff000-0x00000000a3ef9fff\] usable
Dec 01 04:54:08 tracey-aspiretc780 kernel: BIOS-e820: \[mem 0x000000009b6fe000-0x000000009b6fefff\] reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: BIOS-e820: \[mem 0x000000009b6fd000-0x000000009b6fdfff\] ACPI NVS
Dec 01 04:54:08 tracey-aspiretc780 kernel: BIOS-e820: \[mem 0x0000000000100000-0x000000009b6fcfff\] usable
Dec 01 04:54:08 tracey-aspiretc780 kernel: BIOS-e820: \[mem 0x000000000009e000-0x00000000000fffff\] reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: BIOS-e820: \[mem 0x0000000000059000-0x000000000009dfff\] usable
Dec 01 04:54:08 tracey-aspiretc780 kernel: BIOS-e820: \[mem 0x0000000000058000-0x0000000000058fff\] reserved
Dec 01 04:54:08 tracey-aspiretc780 kernel: BIOS-e820: \[mem 0x0000000000000000-0x0000000000057fff\] usable
Dec 01 04:54:08 tracey-aspiretc780 kernel: BIOS-provided physical RAM map:
Dec 01 04:54:08 tracey-aspiretc780 kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64 root=UUID=a13ec453-9088-41a0-aca1-b168970630a1 rw quiet splash udev.log_priority=3 acpi=force apm=power_off
Dec 01 04:54:08 tracey-aspiretc780 kernel: Linux version 6.12.48-1-MANJARO (linux612@manjaro) (gcc (GCC) 15.2.1 20250813, GNU ld (GNU Binutils) 2.45.0) #1 SMP PREEMPT_DYNAMIC Fri, 19 Sep 2025 16:11:04 +0000
Moderator edit: I have properly formatted your post. Please see… :backhand_index_pointing_down:
Hi, thank you for your reply. I’ve been waiting days to for the PC to repeat the issue. I did try setting it to start with an empty session, all was good for a few days, and then the problem started again. I’m not sure what the issue is yet. I have a log now so I am going to read through it and see if anything stands out.
Hi, I’ve been waiting days for the issue to repeat. I have a log to look at now. I’ll look into the link you gave me and see what I need to do.
Thank you so much! :smiley:
That command filters only the previous time you booted up the computer. That was meant to be run right after you experience the problem. I do not know what you posted, part of a boot sequence?
-b / --boot will give you your current boot.
You can see the previous boots with:
journalctl --list-boots
(Which may make it more clear.)
You most likely have the logs of when this event occurred. Filtering by boot from above, or by date, and severity level. e.g:
journalctl --until 2025-11-30 --since 2025-1-01 --priority 4
There are many ways to filter. (man journalctl)
Find the event first, then post all logs around the event. It just so happens, for you, it’s going one way from the end of a boot up sequence, which helps you find it easier.
It is always helpful to show the exact command run to save people having to look back to see what was suggested (especially when more than one suggestion has been made). This seems too short to be the complete output for the failed boot.
Hi, The issue occurred this afternoon. Here is severity level 4:
journalctl --until 2025-12-01 --since 2025-11-01 --priority 4                                  ✔
Nov 01 06:03:08 tracey-aspiretc780 kernel: x86/cpu: SGX disabled or unsupported by BIOS.
Nov 01 06:03:08 tracey-aspiretc780 kernel: tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfe>
Nov 01 06:03:08 tracey-aspiretc780 kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Nov 01 06:03:12 tracey-aspiretc780 kernel: resource: resource sanity check: requesting [mem 0x00000000fdffe800-0x00000000fe0007ff], which spans more tha>
Nov 01 06:03:12 tracey-aspiretc780 kernel: caller get_primary_reg_base+0x4d/0xa0 [intel_pmc_core] mapping multiple BARs
Nov 01 06:03:23 tracey-aspiretc780 dbus-broker-launch[484]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedes>
Nov 01 06:03:27 tracey-aspiretc780 dbus-broker-launch[484]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedeskto>
Nov 01 06:03:29 tracey-aspiretc780 dbus-broker-launch[629]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named>
Nov 01 06:03:29 tracey-aspiretc780 dbus-broker-launch[629]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D->
Nov 01 06:03:29 tracey-aspiretc780 dbus-broker-launch[629]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named>
Nov 01 06:03:37 tracey-aspiretc780 kded6[682]: QDBusObjectPath: invalid path "/modules/oom-notifier"
Nov 01 06:03:37 tracey-aspiretc780 kded6[682]: kf.dbusaddons: The kded module name "oom-notifier" is invalid!
Nov 01 06:03:41 tracey-aspiretc780 kded6[682]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
Nov 01 06:03:43 tracey-aspiretc780 org_kde_powerdevil[739]: Failed to create wl_display (No such file or directory)
Nov 01 06:03:43 tracey-aspiretc780 kded6[682]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
Nov 01 06:03:43 tracey-aspiretc780 kded6[682]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
Nov 01 06:03:44 tracey-aspiretc780 org_kde_powerdevil[739]: [   739] busno=0, Feature 0xdd should not exist but ddc_get_nontable_vcp_value() succeeds, r>
Nov 01 06:03:44 tracey-aspiretc780 org_kde_powerdevil[739]: [   739] busno=0, Feature 0x41 should not exist but ddc_get_nontable_vcp_value() succeeds, r>
Nov 01 06:03:44 tracey-aspiretc780 kded6[682]: QDBusObjectPath: invalid path "/modules/wpad-detector"
Nov 01 06:03:44 tracey-aspiretc780 kded6[682]: kf.dbusaddons: The kded module name "wpad-detector" is invalid!
Nov 01 06:03:44 tracey-aspiretc780 org_kde_powerdevil[739]: [   739] busno=0, Feature 0x00 should not exist but ddc_get_nontable_vcp_value() succeeds, r>
Nov 01 06:03:44 tracey-aspiretc780 org_kde_powerdevil[739]: [   739] busno=0, All features that should not exist detected. Monitor does not indicate uns>
Nov 01 06:03:44 tracey-aspiretc780 org_kde_powerdevil[739]: [   739] Watching for DPMS state changes unimplemented
Nov 01 06:03:45 tracey-aspiretc780 backlighthelper[867]: org.kde.powerdevil: no kernel backlight interface found
Nov 01 06:03:45 tracey-aspiretc780 org_kde_powerdevil[739]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thr>
Nov 01 06:03:45 tracey-aspiretc780 org_kde_powerdevil[739]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Nov 01 06:03:49 tracey-aspiretc780 systemd[599]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@0.service: Failed with result 'exit-code'.
Nov 01 06:03:50 tracey-aspiretc780 org_kde_powerdevil[739]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Nov 01 06:03:50 tracey-aspiretc780 org_kde_powerdevil[739]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thr>
Nov 01 06:03:50 tracey-aspiretc780 kconf_update[917]: kf.config.kconf_update: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=>
Nov 01 06:03:51 tracey-aspiretc780 kconf_update[917]: kf.config.kconf_update: /usr/share/kconf_update/filepicker.upd defined Version=5 but Version=6 was>
Nov 01 06:03:52 tracey-aspiretc780 kded6[682]: kf.bluezqt: PendingCall Error: "The name is not activatable"
Nov 01 06:03:52 tracey-aspiretc780 kded6[682]: org.kde.pulseaudio: No object for name "auto_null.monitor"
Nov 01 06:03:52 tracey-aspiretc780 kded6[682]: org.kde.pulseaudio: No object for name "auto_null"
Nov 01 06:03:52 tracey-aspiretc780 kded6[682]: org.kde.pulseaudio: No object for name "@DEFAULT_SINK@"
Nov 01 06:03:52 tracey-aspiretc780 kded6[682]: org.kde.pulseaudio: No object for name "@DEFAULT_SOURCE@"
Nov 01 06:03:52 tracey-aspiretc780 kded6[682]: org.kde.pulseaudio: No object for name "alsa_input.pci-0000_00_1f.3.analog-stereo"
Nov 01 06:03:55 tracey-aspiretc780 plasmashell[706]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:178:25: QML Fold>
                                                     file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:201:9
Nov 01 06:03:59 tracey-aspiretc780 plasmashell[706]: Toolbox not loading, toolbox package is either invalid or disabled.
Nov 01 06:04:02 tracey-aspiretc780 kernel: warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
Nov 01 06:04:03 tracey-aspiretc780 plasmashell[706]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/main.qml:310:13: QML Image: C>
Nov 01 06:04:03 tracey-aspiretc780 plasmashell[706]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" 0x5570a69e8870
Nov 01 06:04:03 tracey-aspiretc780 plasmashell[706]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" 0x5570a69e8870
That is probably just the first page (notice all the dates are Nov 01, despite a much larger range being requested) - there was a suggestion to use --no-pager to get the full output in a way which could be copied.
