That is probably just the first page (notice all the dates are Nov 01, despite a much larger range being requested) - there was a suggestion to use --no-pager to get the full output in a way which could be copied.
Forgive me I’m a noob! Ok, trying again, now we have Nov 1 to 29:
journalctl --until 2025-12-01 --since 2025-11-01 --priority 4 ✔
Nov 01 06:03:08 tracey-aspiretc780 kernel: x86/cpu: SGX disabled or unsupported by BIOS.
Nov 01 06:03:08 tracey-aspiretc780 kernel: tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfe>
Nov 01 06:03:08 tracey-aspiretc780 kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Nov 01 06:03:12 tracey-aspiretc780 kernel: resource: resource sanity check: requesting [mem 0x00000000fdffe800-0x00000000fe0007ff], which spans more tha>
Nov 01 06:03:12 tracey-aspiretc780 kernel: caller get_primary_reg_base+0x4d/0xa0 [intel_pmc_core] mapping multiple BARs
Nov 01 06:03:23 tracey-aspiretc780 dbus-broker-launch[484]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedes>
Nov 01 06:03:27 tracey-aspiretc780 dbus-broker-launch[484]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedeskto>
Nov 01 06:03:29 tracey-aspiretc780 dbus-broker-launch[629]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named>
Nov 01 06:03:29 tracey-aspiretc780 dbus-broker-launch[629]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D->
Nov 01 06:03:29 tracey-aspiretc780 dbus-broker-launch[629]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named>
Nov 01 06:03:37 tracey-aspiretc780 kded6[682]: QDBusObjectPath: invalid path "/modules/oom-notifier"
Nov 01 06:03:37 tracey-aspiretc780 kded6[682]: kf.dbusaddons: The kded module name "oom-notifier" is invalid!
Nov 01 06:03:41 tracey-aspiretc780 kded6[682]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
Nov 01 06:03:43 tracey-aspiretc780 org_kde_powerdevil[739]: Failed to create wl_display (No such file or directory)
Nov 01 06:03:43 tracey-aspiretc780 kded6[682]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
Nov 01 06:03:43 tracey-aspiretc780 kded6[682]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
Nov 01 06:03:44 tracey-aspiretc780 org_kde_powerdevil[739]: [ 739] busno=0, Feature 0xdd should not exist but ddc_get_nontable_vcp_value() succeeds, r>
Nov 01 06:03:44 tracey-aspiretc780 org_kde_powerdevil[739]: [ 739] busno=0, Feature 0x41 should not exist but ddc_get_nontable_vcp_value() succeeds, r>
Nov 01 06:03:44 tracey-aspiretc780 kded6[682]: QDBusObjectPath: invalid path "/modules/wpad-detector"
Nov 01 06:03:44 tracey-aspiretc780 kded6[682]: kf.dbusaddons: The kded module name "wpad-detector" is invalid!
Nov 01 06:03:44 tracey-aspiretc780 org_kde_powerdevil[739]: [ 739] busno=0, Feature 0x00 should not exist but ddc_get_nontable_vcp_value() succeeds, r>
Nov 01 06:03:44 tracey-aspiretc780 org_kde_powerdevil[739]: [ 739] busno=0, All features that should not exist detected. Monitor does not indicate uns>
Nov 01 06:03:44 tracey-aspiretc780 org_kde_powerdevil[739]: [ 739] Watching for DPMS state changes unimplemented
Nov 01 06:03:45 tracey-aspiretc780 backlighthelper[867]: org.kde.powerdevil: no kernel backlight interface found
Nov 01 06:03:45 tracey-aspiretc780 org_kde_powerdevil[739]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thr>
Nov 01 06:03:45 tracey-aspiretc780 org_kde_powerdevil[739]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Nov 01 06:03:49 tracey-aspiretc780 systemd[599]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@0.service: Failed with result 'exit-code'.
Nov 01 06:03:50 tracey-aspiretc780 org_kde_powerdevil[739]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Nov 01 06:03:50 tracey-aspiretc780 org_kde_powerdevil[739]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thr>
Nov 01 06:03:50 tracey-aspiretc780 kconf_update[917]: kf.config.kconf_update: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=>
Nov 01 06:03:51 tracey-aspiretc780 kconf_update[917]: kf.config.kconf_update: /usr/share/kconf_update/filepicker.upd defined Version=5 but Version=6 was>
Nov 01 06:03:52 tracey-aspiretc780 kded6[682]: kf.bluezqt: PendingCall Error: "The name is not activatable"
Nov 01 06:03:52 tracey-aspiretc780 kded6[682]: org.kde.pulseaudio: No object for name "auto_null.monitor"
Nov 01 06:03:52 tracey-aspiretc780 kded6[682]: org.kde.pulseaudio: No object for name "auto_null"
Nov 01 06:03:52 tracey-aspiretc780 kded6[682]: org.kde.pulseaudio: No object for name "@DEFAULT_SINK@"
Nov 01 06:03:52 tracey-aspiretc780 kded6[682]: org.kde.pulseaudio: No object for name "@DEFAULT_SOURCE@"
Nov 01 06:03:52 tracey-aspiretc780 kded6[682]: org.kde.pulseaudio: No object for name "alsa_input.pci-0000_00_1f.3.analog-stereo"
Nov 01 06:03:55 tracey-aspiretc780 plasmashell[706]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:178:25: QML Fold>
file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:201:9
Nov 01 06:03:59 tracey-aspiretc780 plasmashell[706]: Toolbox not loading, toolbox package is either invalid or disabled.
Nov 01 06:04:02 tracey-aspiretc780 kernel: warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
Nov 01 06:04:03 tracey-aspiretc780 plasmashell[706]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/main.qml:310:13: QML Image: C>
Nov 01 06:04:03 tracey-aspiretc780 plasmashell[706]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" 0x5570a69e8870
Nov 01 06:04:03 tracey-aspiretc780 plasmashell[706]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" 0x5570a69e8870
4:27 PM
Tracey
#11 0x000056540c4ae585 n/a (/usr/lib/chromium/chromium + 0x83e5585)
#12 0x00007efd37a969cb n/a (libc.so.6 + 0x969cb)
#13 0x00007efd37b1a834 __clone (libc.so.6 + 0x11a834)
Stack trace of thread 9:
#0 0x00007efd37a9f042 n/a (libc.so.6 + 0x9f042)
#1 0x00007efd37a931ac n/a (libc.so.6 + 0x931ac)
#2 0x00007efd37a9381c n/a (libc.so.6 + 0x9381c)
#3 0x00007efd37a960e8 pthread_cond_timedwait (libc.so.6 + 0x960e8)
#4 0x000056540c4ada84 n/a (/usr/lib/chromium/chromium + 0x83e4a84)
#5 0x000056540c4e62f9 n/a (/usr/lib/chromium/chromium + 0x841d2f9)
#6 0x000056540c4420c8 n/a (/usr/lib/chromium/chromium + 0x83790c8)
#7 0x000056540c48e6f8 n/a (/usr/lib/chromium/chromium + 0x83c56f8)
#8 0x000056540c4ae585 n/a (/usr/lib/chromium/chromium + 0x83e5585)
#9 0x00007efd37a969cb n/a (libc.so.6 + 0x969cb)
#10 0x00007efd37b1a834 __clone (libc.so.6 + 0x11a834)
Stack trace of thread 17:
#3 0x00007efd37a95ede pthread_cond_wait (libc.so.6 + 0x95ede)
#4 0x000056540c4ad844 n/a (/usr/lib/chromium/chromium + 0x83e4844)
#5 0x000056540c4e62df n/a (/usr/lib/chromium/chromium + 0x841d2df)
#7 0x000056540c48be96 n/a (/usr/lib/chromium/chromium + 0x83c2e96)
#8 0x000056540c48cb79 n/a (/usr/lib/chromium/chromium + 0x83c3b79)
#9 0x000056540c48c93a n/a (/usr/lib/chromium/chromium + 0x83c393a)
#10 0x000056540c48c744 n/a (/usr/lib/chromium/chromium + 0x83c3744)
Stack trace of thread 11:
#9 0x000056540c48c8ea n/a (/usr/lib/chromium/chromium + 0x83c38ea)
#10 0x000056540c48c6ef n/a (/usr/lib/chromium/chromium + 0x83c36ef)
Stack trace of thread 20:
#7 0x000056540c3e990a n/a (/usr/lib/chromium/chromium + 0x832090a)
#8 0x000056540c46d73f n/a (/usr/lib/chromium/chromium + 0x83a473f)
#9 0x000056540c42205b n/a (/usr/lib/chromium/chromium + 0x835905b)
#10 0x000056540c4958e7 n/a (/usr/lib/chromium/chromium + 0x83cc8e7)
#11 0x000056540c495c82 n/a (/usr/lib/chromium/chromium + 0x83ccc82)
#12 0x000056540c4ae585 n/a (/usr/lib/chromium/chromium + 0x83e5585)
#13 0x00007efd37a969cb n/a (libc.so.6 + 0x969cb)
#14 0x00007efd37b1a834 __clone (libc.so.6 + 0x11a834)
Stack trace of thread 2:
#2 0x00007efd37a931f4 n/a (libc.so.6 + 0x931f4)
#3 0x00007efd37b1acf5 epoll_wait (libc.so.6 + 0x11acf5)
#4 0x000056540c4e1d48 n/a (/usr/lib/chromium/chromium + 0x8418d48)
#5 0x000056540c4e1ab7 n/a (/usr/lib/chromium/chromium + 0x8418ab7)
#6 0x000056540c46d73f n/a (/usr/lib/chromium/chromium + 0x83a473f)
#7 0x000056540c42205b n/a (/usr/lib/chromium/chromium + 0x835905b)
#8 0x000056540c4958e7 n/a (/usr/lib/chromium/chromium + 0x83cc8e7)
#9 0x000056540c495c82 n/a (/usr/lib/chromium/chromium + 0x83ccc82)
#10 0x000056540c4ae585 n/a (/usr/lib/chromium/chromium + 0x83e5585)
#11 0x00007efd37a969cb n/a (libc.so.6 + 0x969cb)
#12 0x00007efd37b1a834 __clone (libc.so.6 + 0x11a834)
Stack trace of thread 7:
#8 0x0000565409fc8136 n/a (/usr/lib/chromium/chromium + 0x5eff136)
#9 0x000056540c4ae585 n/a (/usr/lib/chromium/chromium + 0x83e5585)
#10 0x00007efd37a969cb n/a (libc.so.6 + 0x969cb)
#11 0x00007efd37b1a834 __clone (libc.so.6 + 0x11a834)
Nov 25 14:29:29 tracey-aspiretc780 plasmashell[709]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
Nov 25 14:29:31 tracey-aspiretc780 plasmashell[709]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
Nov 25 14:29:35 tracey-aspiretc780 plasmashell[709]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:130: TypeError: Cannot read property 'screenGeometry' of null
Nov 25 14:29:36 tracey-aspiretc780 plasmashell[709]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:260: TypeError: Cannot read property 'plasmoid' of undefined
Nov 25 14:29:36 tracey-aspiretc780 sddm-helper[594]: Signal received: SIGTERM
Nov 25 14:29:36 tracey-aspiretc780 sddm[581]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Nov 25 14:29:36 tracey-aspiretc780 sddm[581]: Auth: sddm-helper (--socket /tmp/sddm-auth-1725597e-d921-40de-9904-da11a7f61293 --id 1 --start /usr/bin/startplasma-x11 --user tracey --autologin) crashed (exit code 1)
Nov 25 14:29:36 tracey-aspiretc780 sddm[581]: Auth: sddm-helper exited with 1
Nov 25 14:29:36 tracey-aspiretc780 kwin_x11[678]: kwin_scene_opengl: Could not delete framebuffer because no context is current
Nov 25 14:29:36 tracey-aspiretc780 sddm[581]: Signal received: SIGTERM
Nov 25 14:29:36 tracey-aspiretc780 ksmserver[672]: The X11 connection broke (error 1). Did the X11 server die?
Nov 25 14:29:36 tracey-aspiretc780 systemd[600]: dbus-:1.59-org.a11y.atspi.Registry@0.service: Failed with result 'exit-code'.
Nov 25 14:29:36 tracey-aspiretc780 dbus-broker[486]: A security policy denied :1.5 to send method call /midi/profile:org.bluez.GattProfile1.Release to :1.48.
Nov 25 14:29:36 tracey-aspiretc780 kwin_x11[678]: The X11 connection broke: I/O error (code 1)
Nov 25 14:29:36 tracey-aspiretc780 dbus-broker-launch[485]: Activation request for 'org.bluez' failed.
Nov 25 14:29:37 tracey-aspiretc780 systemd[600]: plasma-kwin_x11.service: Failed with result 'exit-code'.
Nov 25 14:29:37 tracey-aspiretc780 dbus-broker-launch[485]: Activation request for 'org.freedesktop.RealtimeKit1' failed.
Nov 25 14:29:41 tracey-aspiretc780 systemd[600]: plasma-kded6.service: State 'stop-sigterm' timed out. Killing.
Nov 25 14:29:41 tracey-aspiretc780 systemd[600]: plasma-kded6.service: Main process exited, code=killed, status=9/KILL
Nov 25 14:29:41 tracey-aspiretc780 systemd[600]: plasma-kded6.service: Failed with result 'timeout'.
Nov 25 14:29:42 tracey-aspiretc780 dbus-broker-launch[485]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Nov 25 14:29:43 tracey-aspiretc780 kernel: watchdog: watchdog0: watchdog did not stop!
-- Boot 2c236b1ab5084c73aecfba7de8876c08 --
Nov 25 14:30:24 tracey-aspiretc780 kernel: x86/cpu: SGX disabled or unsupported by BIOS.
Nov 25 14:30:24 tracey-aspiretc780 kernel: tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x200] vs fed40080 f80
Nov 25 14:30:24 tracey-aspiretc780 kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Nov 25 14:30:28 tracey-aspiretc780 kernel: resource: resource sanity check: requesting [mem 0x00000000fdffe800-0x00000000fe0007ff], which spans more than pnp 00:07 [mem 0xfdb00000-0xfdffffff]
Nov 25 14:30:28 tracey-aspiretc780 kernel: caller get_primary_reg_base+0x4d/0xa0 [intel_pmc_core] mapping multiple BARs
Nov 25 14:30:39 tracey-aspiretc780 dbus-broker-launch[479]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Nov 25 14:30:44 tracey-aspiretc780 dbus-broker-launch[479]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Nov 25 14:30:46 tracey-aspiretc780 dbus-broker-launch[618]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Nov 25 14:30:46 tracey-aspiretc780 dbus-broker-launch[618]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Nov 25 14:30:46 tracey-aspiretc780 dbus-broker-launch[618]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Nov 25 14:30:53 tracey-aspiretc780 kded6[671]: QDBusObjectPath: invalid path "/modules/oom-notifier"
Nov 25 14:30:53 tracey-aspiretc780 kded6[671]: kf.dbusaddons: The kded module name "oom-notifier" is invalid!
Nov 25 14:30:58 tracey-aspiretc780 kded6[671]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
Nov 25 14:30:59 tracey-aspiretc780 kded6[671]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
Nov 25 14:30:59 tracey-aspiretc780 kded6[671]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
Nov 25 14:30:59 tracey-aspiretc780 org_kde_powerdevil[740]: Failed to create wl_display (No such file or directory)
Nov 25 14:30:59 tracey-aspiretc780 kded6[671]: QDBusObjectPath: invalid path "/modules/wpad-detector"
Nov 25 14:30:59 tracey-aspiretc780 kded6[671]: kf.dbusaddons: The kded module name "wpad-detector" is invalid!
Nov 25 14:30:59 tracey-aspiretc780 org_kde_powerdevil[740]: [ 740] busno=0, Feature 0xdd should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
Nov 25 14:30:59 tracey-aspiretc780 org_kde_powerdevil[740]: [ 740] busno=0, Feature 0x41 should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
Nov 25 14:30:59 tracey-aspiretc780 org_kde_powerdevil[740]: [ 740] busno=0, Feature 0x00 should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
Nov 25 14:30:59 tracey-aspiretc780 org_kde_powerdevil[740]: [ 740] busno=0, All features that should not exist detected. Monitor does not indicate unsupported
Nov 25 14:30:59 tracey-aspiretc780 org_kde_powerdevil[740]: [ 740] Watching for DPMS state changes unimplemented
Nov 25 14:31:00 tracey-aspiretc780 backlighthelper[853]: org.kde.powerdevil: no kernel backlight interface found
Nov 25 14:31:00 tracey-aspiretc780 org_kde_powerdevil[740]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Nov 25 14:31:00 tracey-aspiretc780 org_kde_powerdevil[740]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Nov 25 14:31:05 tracey-aspiretc780 org_kde_powerdevil[740]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Nov 25 14:31:05 tracey-aspiretc780 org_kde_powerdevil[740]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Nov 25 14:31:06 tracey-aspiretc780 kconf_update[958]: kf.config.kconf_update: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
Nov 25 14:31:06 tracey-aspiretc780 kconf_update[958]: kf.config.kconf_update: /usr/share/kconf_update/filepicker.upd defined Version=5 but Version=6 was expected
Nov 25 14:31:07 tracey-aspiretc780 systemd[588]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@0.service: Failed with result 'exit-code'.
Nov 25 14:31:07 tracey-aspiretc780 kded6[671]: kf.bluezqt: PendingCall Error: "The name is not activatable"
Nov 25 14:31:11 tracey-aspiretc780 plasmashell[698]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:178:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth":
Nov 25 14:31:16 tracey-aspiretc780 plasmashell[698]: Toolbox not loading, toolbox package is either invalid or disabled.
Nov 25 14:31:16 tracey-aspiretc780 kernel: warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
Nov 25 14:31:17 tracey-aspiretc780 kdeconnectd[918]: Error sending UDP packet: QAbstractSocket::NetworkError
Nov 25 14:31:19 tracey-aspiretc780 plasmashell[698]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/main.qml:310:13: QML Image: Cannot open: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/start-here-kde-symbolic
Nov 25 14:31:19 tracey-aspiretc780 plasmashell[698]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" 0x558100209570
Nov 25 14:31:19 tracey-aspiretc780 plasmashell[698]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" 0x558100209570
Nov 25 14:31:22 tracey-aspiretc780 plasmashell[698]: org.kde.applets.brightness: D-Bus action "KeyboardBrightnessControl" is not available at service "org.kde.Solid.PowerManagement"
Nov 25 14:31:37 tracey-aspiretc780 systemd[588]: dbus-:1.2-org.kde.kwalletd6@0.service: Failed with result 'exit-code'.
Nov 25 14:31:37 tracey-aspiretc780 systemd[588]: dbus-:1.2-org.kde.kwalletd6@1.service: Failed with result 'exit-code'.
Nov 25 14:31:46 tracey-aspiretc780 systemd[588]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@1.service: Failed with result 'exit-code'.
Nov 25 14:31:46 tracey-aspiretc780 systemd[588]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@2.service: Failed with result 'exit-code'.
Nov 25 14:31:46 tracey-aspiretc780 xdg-desktop-por[641]: Backend call failed: Could not activate remote peer 'org.freedesktop.impl.portal.desktop.kwallet': unit failed
Nov 25 14:31:46 tracey-aspiretc780 systemd[588]: dbus-:1.2-org.kde.kwalletd6@2.service: Failed with result 'exit-code'.
Nov 25 14:32:23 tracey-aspiretc780 systemd[588]: dbus-:1.2-org.kde.KSplash@1.service: Failed with result 'exit-code'.
Nov 25 15:54:05 tracey-aspiretc780 kwin_x11[672]: kwin_core: XCB error: 152 (BadDamage), sequence: 21895, resource id: 20973457, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Nov 25 15:54:05 tracey-aspiretc780 kwin_x11[672]: kwin_core: XCB error: 3 (BadWindow), sequence: 21896, resource id: 4194332, major code: 129 (SHAPE), minor code: 6 (Input)
Nov 25 16:26:06 tracey-aspiretc780 plasmashell[698]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/items/PlasmoidItem.qml:24: TypeError: Cannot read property 'toolTipMainText' of null
Nov 25 16:27:52 tracey-aspiretc780 plasmashell[698]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:130: TypeError: Cannot read property 'screenGeometry' of null
Nov 25 16:27:52 tracey-aspiretc780 plasmashell[698]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:260: TypeError: Cannot read property 'plasmoid' of undefined
Nov 25 16:27:52 tracey-aspiretc780 kwin_x11[672]: kwin_scene_opengl: Could not delete framebuffer because no context is current
Nov 25 16:27:52 tracey-aspiretc780 sddm-helper[583]: Signal received: SIGTERM
Nov 25 16:27:52 tracey-aspiretc780 sddm[569]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Nov 25 16:27:52 tracey-aspiretc780 sddm[569]: Auth: sddm-helper (--socket /tmp/sddm-auth-f9cde891-d2c9-475f-aea2-9b555caba48f --id 1 --start /usr/bin/startplasma-x11 --user tracey --autologin) crashed (exit code 1)
Nov 25 16:27:52 tracey-aspiretc780 sddm[569]: Auth: sddm-helper exited with 1
Nov 25 16:27:53 tracey-aspiretc780 sddm[569]: Signal received: SIGTERM
Nov 25 16:27:53 tracey-aspiretc780 ksmserver[669]: The X11 connection broke (error 1). Did the X11 server die?
Nov 25 16:27:53 tracey-aspiretc780 systemd[588]: dbus-:1.59-org.a11y.atspi.Registry@0.service: Failed with result 'exit-code'.
Nov 25 16:27:53 tracey-aspiretc780 dbus-broker[480]: A security policy denied :1.5 to send method call /midi/profile:org.bluez.GattProfile1.Release to :1.47.
Nov 25 16:27:53 tracey-aspiretc780 systemd[588]: plasma-kwin_x11.service: Failed with result 'exit-code'.
Nov 25 16:27:53 tracey-aspiretc780 kded6[671]: The X11 connection broke: I/O error (code 1)
Nov 25 16:27:53 tracey-aspiretc780 kded6[671]: QThreadStorage: entry 12 destroyed before end of thread 0x558737df7580
Nov 25 16:27:53 tracey-aspiretc780 kded6[671]: QThreadStorage: entry 11 destroyed before end of thread 0x558737df7580
Nov 25 16:27:53 tracey-aspiretc780 kded6[671]: QThreadStorage: entry 10 destroyed before end of thread 0x558737df7580
Nov 25 16:27:53 tracey-aspiretc780 kded6[671]: QThreadStorage: entry 9 destroyed before end of thread 0x558737df7580
Nov 25 16:27:53 tracey-aspiretc780 kded6[671]: QThreadStorage: entry 8 destroyed before end of thread 0x558737df7580
Nov 25 16:27:53 tracey-aspiretc780 kded6[671]: QThreadStorage: entry 2 destroyed before end of thread 0x558737df7580
Nov 25 16:27:53 tracey-aspiretc780 kded6[671]: QThreadStorage: entry 1 destroyed before end of thread 0x558737df7580
Nov 25 16:27:53 tracey-aspiretc780 kded6[671]: QThreadStorage: entry 0 destroyed before end of thread 0x558737df7580
Nov 25 16:27:53 tracey-aspiretc780 systemd[588]: plasma-kded6.service: Failed with result 'exit-code'.
Nov 25 16:27:54 tracey-aspiretc780 dbus-broker-launch[479]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
-- Boot a4275120a88944598f4b164cc5a618ec --
Nov 26 05:36:10 tracey-aspiretc780 kernel: x86/cpu: SGX disabled or unsupported by BIOS.
Nov 26 05:36:10 tracey-aspiretc780 kernel: tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x200] vs fed40080 f80
Nov 26 05:36:10 tracey-aspiretc780 kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Nov 26 05:36:16 tracey-aspiretc780 kernel: resource: resource sanity check: requesting [mem 0x00000000fdffe800-0x00000000fe0007ff], which spans more than pnp 00:07 [mem 0xfdb00000-0xfdffffff]
Nov 26 05:36:16 tracey-aspiretc780 kernel: caller get_primary_reg_base+0x4d/0xa0 [intel_pmc_core] mapping multiple BARs
Nov 26 05:36:27 tracey-aspiretc780 dbus-broker-launch[483]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Nov 26 05:36:29 tracey-aspiretc780 dbus-broker-launch[483]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Nov 26 05:36:31 tracey-aspiretc780 dbus-broker-launch[627]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Nov 26 05:36:32 tracey-aspiretc780 dbus-broker-launch[627]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Nov 26 05:36:32 tracey-aspiretc780 dbus-broker-launch[627]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Nov 26 05:36:40 tracey-aspiretc780 kded6[683]: QDBusObjectPath: invalid path "/modules/oom-notifier"
Nov 26 05:36:40 tracey-aspiretc780 kded6[683]: kf.dbusaddons: The kded module name "oom-notifier" is invalid!
Nov 26 05:36:45 tracey-aspiretc780 kded6[683]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
Nov 26 05:36:45 tracey-aspiretc780 org_kde_powerdevil[737]: Failed to create wl_display (No such file or directory)
Nov 26 05:36:46 tracey-aspiretc780 kded6[683]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
Nov 26 05:36:46 tracey-aspiretc780 kded6[683]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
Nov 26 05:36:46 tracey-aspiretc780 org_kde_powerdevil[737]: [ 737] busno=0, Feature 0xdd should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
Nov 26 05:36:46 tracey-aspiretc780 org_kde_powerdevil[737]: [ 737] busno=0, Feature 0x41 should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
Nov 26 05:36:46 tracey-aspiretc780 org_kde_powerdevil[737]: [ 737] busno=0, Feature 0x00 should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
Nov 26 05:36:46 tracey-aspiretc780 org_kde_powerdevil[737]: [ 737] busno=0, All features that should not exist detected. Monitor does not indicate unsupported
Nov 26 05:36:46 tracey-aspiretc780 org_kde_powerdevil[737]: [ 737] Watching for DPMS state changes unimplemented
Nov 26 05:36:47 tracey-aspiretc780 kded6[683]: QDBusObjectPath: invalid path "/modules/wpad-detector"
Nov 26 05:36:47 tracey-aspiretc780 kded6[683]: kf.dbusaddons: The kded module name "wpad-detector" is invalid!
Nov 26 05:36:47 tracey-aspiretc780 backlighthelper[860]: org.kde.powerdevil: no kernel backlight interface found
Nov 26 05:36:47 tracey-aspiretc780 org_kde_powerdevil[737]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Nov 26 05:36:47 tracey-aspiretc780 org_kde_powerdevil[737]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Nov 26 05:36:52 tracey-aspiretc780 kconf_update[911]: kf.config.kconf_update: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
Nov 26 05:36:52 tracey-aspiretc780 kconf_update[911]: kf.config.kconf_update: /usr/share/kconf_update/filepicker.upd defined Version=5 but Version=6 was expected
Nov 26 05:36:53 tracey-aspiretc780 kded6[683]: kf.bluezqt: PendingCall Error: "The name is not activatable"
Nov 26 05:36:53 tracey-aspiretc780 kded6[683]: kscreen.kded: PowerDevil SuspendSession action not available!
Nov 26 05:36:53 tracey-aspiretc780 systemd[597]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@0.service: Failed with result 'exit-code'.
Nov 26 05:36:54 tracey-aspiretc780 plasmashell[705]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:178:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth":
Nov 26 05:36:54 tracey-aspiretc780 baloo_file[649]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.49'
Nov 26 05:36:55 tracey-aspiretc780 org_kde_powerdevil[737]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Nov 26 05:36:55 tracey-aspiretc780 org_kde_powerdevil[737]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Nov 26 05:36:58 tracey-aspiretc780 plasmashell[705]: Toolbox not loading, toolbox package is either invalid or disabled.
Nov 26 05:37:02 tracey-aspiretc780 plasmashell[705]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/main.qml:310:13: QML Image: Cannot open: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/start-here-kde-symbolic
Nov 26 05:37:02 tracey-aspiretc780 plasmashell[705]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" 0x55e6fe884a70
Nov 26 05:37:02 tracey-aspiretc780 plasmashell[705]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" 0x55e6fe884a70
Nov 26 05:37:03 tracey-aspiretc780 kernel: warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
Nov 26 05:37:03 tracey-aspiretc780 kdeconnectd[944]: Error sending UDP packet: QAbstractSocket::NetworkError
Nov 26 05:37:09 tracey-aspiretc780 plasmashell[705]: org.kde.applets.brightness: D-Bus action "KeyboardBrightnessControl" is not available at service "org.kde.Solid.PowerManagement"
Nov 26 05:37:33 tracey-aspiretc780 systemd[597]: dbus-:1.2-org.kde.kwalletd6@0.service: Failed with result 'exit-code'.
Nov 26 05:37:33 tracey-aspiretc780 systemd[597]: dbus-:1.2-org.kde.kwalletd6@1.service: Failed with result 'exit-code'.
Nov 26 05:37:42 tracey-aspiretc780 systemd[597]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@1.service: Failed with result 'exit-code'.
Nov 26 05:37:43 tracey-aspiretc780 systemd[597]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@2.service: Failed with result 'exit-code'.
Nov 26 05:37:43 tracey-aspiretc780 xdg-desktop-por[650]: Backend call failed: Could not activate remote peer 'org.freedesktop.impl.portal.desktop.kwallet': unit failed
Nov 26 05:37:43 tracey-aspiretc780 systemd[597]: dbus-:1.2-org.kde.kwalletd6@2.service: Failed with result 'exit-code'.
Nov 26 05:38:01 tracey-aspiretc780 pamac-manager[1517]: gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
Nov 26 05:38:10 tracey-aspiretc780 systemd[597]: dbus-:1.2-org.kde.KSplash@1.service: Failed with result 'exit-code'.
Nov 26 05:38:38 tracey-aspiretc780 pamac-tray-plas[969]: Source ID 9 was not found when attempting to remove it
Nov 26 05:38:44 tracey-aspiretc780 pamac-tray-plas[969]: Source ID 10 was not found when attempting to remove it
Nov 26 05:39:49 tracey-aspiretc780 plasmashell[705]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/items/PlasmoidItem.qml:24: TypeError: Cannot read property 'toolTipMainText' of null
Nov 26 15:15:55 tracey-aspiretc780 plasmashell[705]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/items/PlasmoidItem.qml:24: TypeError: Cannot read property 'toolTipMainText' of null
Nov 26 15:16:30 tracey-aspiretc780 plasmashell[705]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:130: TypeError: Cannot read property 'screenGeometry' of null
Nov 26 15:16:30 tracey-aspiretc780 plasmashell[705]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:260: TypeError: Cannot read property 'plasmoid' of undefined
Nov 26 15:16:30 tracey-aspiretc780 kwin_x11[684]: kwin_scene_opengl: Could not delete framebuffer because no context is current
Nov 26 15:16:30 tracey-aspiretc780 sddm-helper[592]: Signal received: SIGTERM
Nov 26 15:16:30 tracey-aspiretc780 sddm[577]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Nov 26 15:16:30 tracey-aspiretc780 sddm[577]: Auth: sddm-helper (--socket /tmp/sddm-auth-c443185b-5f39-4745-9742-67f519f1ff5b --id 1 --start /usr/bin/startplasma-x11 --user tracey --autologin) crashed (exit code 1)
Nov 26 15:16:30 tracey-aspiretc780 sddm[577]: Auth: sddm-helper exited with 1
Nov 26 15:16:30 tracey-aspiretc780 sddm[577]: Signal received: SIGTERM
Nov 26 15:16:30 tracey-aspiretc780 ksmserver[681]: The X11 connection broke (error 1). Did the X11 server die?
Nov 26 15:16:30 tracey-aspiretc780 dbus-broker[484]: A security policy denied :1.5 to send method call /midi/profile:org.bluez.GattProfile1.Release to :1.47.
Nov 26 15:16:30 tracey-aspiretc780 systemd[597]: dbus-:1.60-org.a11y.atspi.Registry@0.service: Failed with result 'exit-code'.
Nov 26 15:16:31 tracey-aspiretc780 systemd[597]: plasma-kwin_x11.service: Failed with result 'exit-code'.
Nov 26 15:16:31 tracey-aspiretc780 dbus-broker-launch[483]: Activation request for 'org.freedesktop.RealtimeKit1' failed.
Nov 26 15:16:31 tracey-aspiretc780 kded6[683]: kf.notifications: Failed to play sound with canberra: Invalid state
Nov 26 15:16:31 tracey-aspiretc780 kded6[683]: The X11 connection broke: I/O error (code 1)
Nov 26 15:16:31 tracey-aspiretc780 kded6[683]: kf.notifications: Had queued notifications on destruction. Was the eventloop running?
Nov 26 15:16:31 tracey-aspiretc780 kded6[683]: QThreadStorage: entry 12 destroyed before end of thread 0x55f046496580
Nov 26 15:16:31 tracey-aspiretc780 kded6[683]: QThreadStorage: entry 11 destroyed before end of thread 0x55f046496580
Nov 26 15:16:31 tracey-aspiretc780 kded6[683]: QThreadStorage: entry 10 destroyed before end of thread 0x55f046496580
Nov 26 15:16:31 tracey-aspiretc780 kded6[683]: QThreadStorage: entry 9 destroyed before end of thread 0x55f046496580
Nov 26 15:16:31 tracey-aspiretc780 kded6[683]: QThreadStorage: entry 8 destroyed before end of thread 0x55f046496580
Nov 26 15:16:31 tracey-aspiretc780 kded6[683]: QThreadStorage: entry 2 destroyed before end of thread 0x55f046496580
Nov 26 15:16:31 tracey-aspiretc780 kded6[683]: QThreadStorage: entry 1 destroyed before end of thread 0x55f046496580
Nov 26 15:16:31 tracey-aspiretc780 kded6[683]: QThreadStorage: entry 0 destroyed before end of thread 0x55f046496580
Nov 26 15:16:31 tracey-aspiretc780 systemd[597]: plasma-kded6.service: Failed with result 'exit-code'.
Nov 26 15:16:31 tracey-aspiretc780 dbus-broker-launch[483]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
-- Boot 1e3e1ca1be294650aff53c4687604cff --
Nov 27 05:00:25 tracey-aspiretc780 kernel: x86/cpu: SGX disabled or unsupported by BIOS.
Nov 27 05:00:25 tracey-aspiretc780 kernel: tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x200] vs fed40080 f80
Nov 27 05:00:25 tracey-aspiretc780 kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Nov 27 05:00:30 tracey-aspiretc780 kernel: resource: resource sanity check: requesting [mem 0x00000000fdffe800-0x00000000fe0007ff], which spans more than pnp 00:07 [mem 0xfdb00000-0xfdffffff]
Nov 27 05:00:30 tracey-aspiretc780 kernel: caller get_primary_reg_base+0x4d/0xa0 [intel_pmc_core] mapping multiple BARs
Nov 27 05:00:42 tracey-aspiretc780 dbus-broker-launch[486]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Nov 27 05:00:46 tracey-aspiretc780 dbus-broker-launch[486]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Nov 27 05:00:48 tracey-aspiretc780 dbus-broker-launch[631]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Nov 27 05:00:48 tracey-aspiretc780 dbus-broker-launch[631]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Nov 27 05:00:48 tracey-aspiretc780 dbus-broker-launch[631]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Nov 27 05:00:56 tracey-aspiretc780 kded6[684]: QDBusObjectPath: invalid path "/modules/oom-notifier"
Nov 27 05:00:56 tracey-aspiretc780 kded6[684]: kf.dbusaddons: The kded module name "oom-notifier" is invalid!
Nov 27 05:01:01 tracey-aspiretc780 kded6[684]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
Nov 27 05:01:03 tracey-aspiretc780 systemd[601]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@0.service: Failed with result 'exit-code'.
Nov 27 05:01:03 tracey-aspiretc780 kded6[684]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
Nov 27 05:01:03 tracey-aspiretc780 kded6[684]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
Nov 27 05:01:03 tracey-aspiretc780 kded6[684]: QDBusObjectPath: invalid path "/modules/wpad-detector"
Nov 27 05:01:03 tracey-aspiretc780 kded6[684]: kf.dbusaddons: The kded module name "wpad-detector" is invalid!
Nov 27 05:01:04 tracey-aspiretc780 org_kde_powerdevil[741]: Failed to create wl_display (No such file or directory)
Nov 27 05:01:04 tracey-aspiretc780 org_kde_powerdevil[741]: [ 741] busno=0, Feature 0xdd should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
Nov 27 05:01:04 tracey-aspiretc780 org_kde_powerdevil[741]: [ 741] busno=0, Feature 0x41 should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
Nov 27 05:01:04 tracey-aspiretc780 org_kde_powerdevil[741]: [ 741] busno=0, Feature 0x00 should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
Nov 27 05:01:04 tracey-aspiretc780 org_kde_powerdevil[741]: [ 741] busno=0, All features that should not exist detected. Monitor does not indicate unsupported
Nov 27 05:01:04 tracey-aspiretc780 org_kde_powerdevil[741]: [ 741] Watching for DPMS state changes unimplemented
Nov 27 05:01:05 tracey-aspiretc780 backlighthelper[898]: org.kde.powerdevil: no kernel backlight interface found
Nov 27 05:01:05 tracey-aspiretc780 org_kde_powerdevil[741]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Nov 27 05:01:05 tracey-aspiretc780 org_kde_powerdevil[741]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Nov 27 05:01:10 tracey-aspiretc780 org_kde_powerdevil[741]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Nov 27 05:01:10 tracey-aspiretc780 org_kde_powerdevil[741]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Nov 27 05:01:11 tracey-aspiretc780 kconf_update[984]: kf.config.kconf_update: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
Nov 27 05:01:11 tracey-aspiretc780 kconf_update[984]: kf.config.kconf_update: /usr/share/kconf_update/filepicker.upd defined Version=5 but Version=6 was expected
Nov 27 05:01:12 tracey-aspiretc780 kded6[684]: kf.bluezqt: PendingCall Error: "The name is not activatable"
Nov 27 05:01:12 tracey-aspiretc780 plasmashell[710]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:178:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth":
Nov 27 05:01:17 tracey-aspiretc780 plasmashell[710]: Toolbox not loading, toolbox package is either invalid or disabled.
Nov 27 05:01:20 tracey-aspiretc780 kernel: warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
Nov 27 05:01:20 tracey-aspiretc780 plasmashell[710]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/main.qml:310:13: QML Image: Cannot open: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/start-here-kde-symbolic
Nov 27 05:01:20 tracey-aspiretc780 kdeconnectd[946]: Error sending UDP packet: QAbstractSocket::NetworkError
Nov 27 05:01:20 tracey-aspiretc780 plasmashell[710]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" 0x55f2d591ac70
Nov 27 05:01:20 tracey-aspiretc780 plasmashell[710]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" 0x55f2d591ac70
Nov 27 05:01:26 tracey-aspiretc780 plasmashell[710]: org.kde.applets.brightness: D-Bus action "KeyboardBrightnessControl" is not available at service "org.kde.Solid.PowerManagement"
Nov 27 05:02:26 tracey-aspiretc780 systemd[601]: dbus-:1.2-org.kde.KSplash@1.service: Failed with result 'exit-code'.
Nov 27 05:24:56 tracey-aspiretc780 systemd[601]: dbus-:1.2-org.kde.kwalletd6@0.service: Failed with result 'exit-code'.
Nov 27 05:24:57 tracey-aspiretc780 systemd[601]: dbus-:1.2-org.kde.kwalletd6@1.service: Failed with result 'exit-code'.
Nov 27 05:25:04 tracey-aspiretc780 systemd[601]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@1.service: Failed with result 'exit-code'.
Nov 27 05:25:04 tracey-aspiretc780 systemd[601]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@2.service: Failed with result 'exit-code'.
Nov 27 05:25:04 tracey-aspiretc780 xdg-desktop-por[654]: Backend call failed: Could not activate remote peer 'org.freedesktop.impl.portal.desktop.kwallet': unit failed
Nov 27 05:25:04 tracey-aspiretc780 systemd[601]: dbus-:1.2-org.kde.kwalletd6@2.service: Failed with result 'exit-code'.
Nov 27 05:27:19 tracey-aspiretc780 plasmashell[710]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/items/PlasmoidItem.qml:24: TypeError: Cannot read property 'toolTipMainText' of null
Nov 27 05:38:20 tracey-aspiretc780 plasmashell[710]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/items/PlasmoidItem.qml:24: TypeError: Cannot read property 'toolTipMainText' of null
Nov 27 10:25:31 tracey-aspiretc780 plasmashell[710]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/items/PlasmoidItem.qml:24: TypeError: Cannot read property 'toolTipMainText' of null
Nov 27 10:25:39 tracey-aspiretc780 plasmashell[710]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/items/PlasmoidItem.qml:24: TypeError: Cannot read property 'toolTipMainText' of null
Nov 27 14:12:57 tracey-aspiretc780 plasmashell[710]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:130: TypeError: Cannot read property 'screenGeometry' of null
Nov 27 14:12:58 tracey-aspiretc780 plasmashell[710]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:260: TypeError: Cannot read property 'plasmoid' of undefined
Nov 27 14:12:58 tracey-aspiretc780 sddm-helper[595]: Signal received: SIGTERM
Nov 27 14:12:58 tracey-aspiretc780 sddm[582]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Nov 27 14:12:58 tracey-aspiretc780 sddm[582]: Auth: sddm-helper (--socket /tmp/sddm-auth-2dbc61b0-2093-4e7d-ab9b-da1ff259a065 --id 1 --start /usr/bin/startplasma-x11 --user tracey --autologin) crashed (exit code 1)
Nov 27 14:12:58 tracey-aspiretc780 sddm[582]: Auth: sddm-helper exited with 1
Nov 27 14:12:58 tracey-aspiretc780 kwin_x11[685]: kwin_scene_opengl: Could not delete render time query because no context is current
Nov 27 14:12:58 tracey-aspiretc780 kwin_x11[685]: kwin_scene_opengl: Could not delete framebuffer because no context is current
Nov 27 14:12:58 tracey-aspiretc780 sddm[582]: Signal received: SIGTERM
Nov 27 14:12:58 tracey-aspiretc780 ksmserver[682]: The X11 connection broke (error 1). Did the X11 server die?
Nov 27 14:12:58 tracey-aspiretc780 systemd[601]: dbus-:1.59-org.a11y.atspi.Registry@0.service: Failed with result 'exit-code'.
Nov 27 14:12:58 tracey-aspiretc780 kwin_x11[685]: The X11 connection broke: I/O error (code 1)
Nov 27 14:12:58 tracey-aspiretc780 dbus-broker[487]: A security policy denied :1.4 to send method call /midi/profile:org.bluez.GattProfile1.Release to :1.48.
Nov 27 14:12:58 tracey-aspiretc780 dbus-broker-launch[486]: Activation request for 'org.bluez' failed.
Nov 27 14:12:59 tracey-aspiretc780 systemd[601]: plasma-kwin_x11.service: Failed with result 'exit-code'.
Nov 27 14:12:59 tracey-aspiretc780 kded6[684]: The X11 connection broke: I/O error (code 1)
Nov 27 14:12:59 tracey-aspiretc780 systemd[601]: plasma-kded6.service: Failed with result 'exit-code'.
Nov 27 14:12:59 tracey-aspiretc780 dbus-broker-launch[486]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
-- Boot 39268ae418c9426d9f359a8020833169 --
Nov 28 05:02:53 tracey-aspiretc780 kernel: x86/cpu: SGX disabled or unsupported by BIOS.
Nov 28 05:02:53 tracey-aspiretc780 kernel: tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x200] vs fed40080 f80
Nov 28 05:02:53 tracey-aspiretc780 kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Nov 28 05:02:58 tracey-aspiretc780 kernel: resource: resource sanity check: requesting [mem 0x00000000fdffe800-0x00000000fe0007ff], which spans more than pnp 00:07 [mem 0xfdb00000-0xfdffffff]
Nov 28 05:02:58 tracey-aspiretc780 kernel: caller get_primary_reg_base+0x4d/0xa0 [intel_pmc_core] mapping multiple BARs
Nov 28 05:03:09 tracey-aspiretc780 dbus-broker-launch[478]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Nov 28 05:03:12 tracey-aspiretc780 dbus-broker-launch[478]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Nov 28 05:03:14 tracey-aspiretc780 dbus-broker-launch[622]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Nov 28 05:03:14 tracey-aspiretc780 dbus-broker-launch[622]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Nov 28 05:03:14 tracey-aspiretc780 dbus-broker-launch[622]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Nov 28 05:03:22 tracey-aspiretc780 kded6[675]: QDBusObjectPath: invalid path "/modules/oom-notifier"
Nov 28 05:03:22 tracey-aspiretc780 kded6[675]: kf.dbusaddons: The kded module name "oom-notifier" is invalid!
Nov 28 05:03:26 tracey-aspiretc780 kded6[675]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
Nov 28 05:03:28 tracey-aspiretc780 org_kde_powerdevil[732]: Failed to create wl_display (No such file or directory)
Nov 28 05:03:28 tracey-aspiretc780 kded6[675]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
Nov 28 05:03:28 tracey-aspiretc780 kded6[675]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
Nov 28 05:03:28 tracey-aspiretc780 org_kde_powerdevil[732]: [ 732] busno=0, Feature 0xdd should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
Nov 28 05:03:28 tracey-aspiretc780 org_kde_powerdevil[732]: [ 732] busno=0, Feature 0x41 should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
Nov 28 05:03:28 tracey-aspiretc780 org_kde_powerdevil[732]: [ 732] busno=0, Feature 0x00 should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
Nov 28 05:03:28 tracey-aspiretc780 org_kde_powerdevil[732]: [ 732] busno=0, All features that should not exist detected. Monitor does not indicate unsupported
Nov 28 05:03:28 tracey-aspiretc780 org_kde_powerdevil[732]: [ 732] Watching for DPMS state changes unimplemented
Nov 28 05:03:28 tracey-aspiretc780 kded6[675]: QDBusObjectPath: invalid path "/modules/wpad-detector"
Nov 28 05:03:28 tracey-aspiretc780 kded6[675]: kf.dbusaddons: The kded module name "wpad-detector" is invalid!
Nov 28 05:03:29 tracey-aspiretc780 backlighthelper[856]: org.kde.powerdevil: no kernel backlight interface found
Nov 28 05:03:29 tracey-aspiretc780 org_kde_powerdevil[732]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Nov 28 05:03:29 tracey-aspiretc780 org_kde_powerdevil[732]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Nov 28 05:03:37 tracey-aspiretc780 baloo_file[646]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.47'
Nov 28 05:03:37 tracey-aspiretc780 systemd[592]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@0.service: Failed with result 'exit-code'.
Nov 28 05:03:37 tracey-aspiretc780 org_kde_powerdevil[732]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Nov 28 05:03:37 tracey-aspiretc780 org_kde_powerdevil[732]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Nov 28 05:03:37 tracey-aspiretc780 kconf_update[918]: kf.config.kconf_update: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
Nov 28 05:03:37 tracey-aspiretc780 kconf_update[918]: kf.config.kconf_update: /usr/share/kconf_update/filepicker.upd defined Version=5 but Version=6 was expected
Nov 28 05:03:38 tracey-aspiretc780 kded6[675]: kf.bluezqt: PendingCall Error: "The name is not activatable"
Nov 28 05:03:38 tracey-aspiretc780 plasmashell[702]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:178:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth":
Nov 28 05:03:42 tracey-aspiretc780 plasmashell[702]: Toolbox not loading, toolbox package is either invalid or disabled.
Nov 28 05:03:45 tracey-aspiretc780 kernel: warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
Nov 28 05:03:45 tracey-aspiretc780 kdeconnectd[935]: Error sending UDP packet: QAbstractSocket::NetworkError
Nov 28 05:03:46 tracey-aspiretc780 plasmashell[702]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/main.qml:310:13: QML Image: Cannot open: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/start-here-kde-symbolic
Nov 28 05:03:46 tracey-aspiretc780 plasmashell[702]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" 0x55f08435bf20
Nov 28 05:03:46 tracey-aspiretc780 plasmashell[702]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" 0x55f08435bf20
Nov 28 05:03:52 tracey-aspiretc780 plasmashell[702]: org.kde.applets.brightness: D-Bus action "KeyboardBrightnessControl" is not available at service "org.kde.Solid.PowerManagement"
Nov 28 05:04:52 tracey-aspiretc780 systemd[592]: dbus-:1.2-org.kde.KSplash@1.service: Failed with result 'exit-code'.
Nov 28 05:38:39 tracey-aspiretc780 systemd[592]: dbus-:1.2-org.kde.kwalletd6@0.service: Failed with result 'exit-code'.
Nov 28 05:38:39 tracey-aspiretc780 systemd[592]: dbus-:1.2-org.kde.kwalletd6@1.service: Failed with result 'exit-code'.
Nov 28 05:38:47 tracey-aspiretc780 systemd[592]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@1.service: Failed with result 'exit-code'.
Nov 28 05:38:47 tracey-aspiretc780 systemd[592]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@2.service: Failed with result 'exit-code'.
Nov 28 05:38:47 tracey-aspiretc780 xdg-desktop-por[648]: Backend call failed: Could not activate remote peer 'org.freedesktop.impl.portal.desktop.kwallet': unit failed
Nov 28 05:38:48 tracey-aspiretc780 systemd[592]: dbus-:1.2-org.kde.kwalletd6@2.service: Failed with result 'exit-code'.
Nov 28 05:38:59 tracey-aspiretc780 kwin_x11[676]: kwin_core: XCB error: 152 (BadDamage), sequence: 16219, resource id: 20972895, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Nov 28 05:38:59 tracey-aspiretc780 kwin_x11[676]: kwin_core: XCB error: 3 (BadWindow), sequence: 16220, resource id: 4194326, major code: 129 (SHAPE), minor code: 6 (Input)
Nov 28 06:01:39 tracey-aspiretc780 kernel: mmap: chromium (1363): VmData 8590422016 exceed data ulimit 8589934592. Update limits or use boot option ignore_rlimit_data.
Nov 28 06:02:44 tracey-aspiretc780 plasmashell[702]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/items/PlasmoidItem.qml:24: TypeError: Cannot read property 'toolTipMainText' of null
Nov 28 06:02:47 tracey-aspiretc780 systemd[592]: dbus-:1.2-org.kde.kwalletd6@3.service: Failed with result 'exit-code'.
Nov 28 06:02:47 tracey-aspiretc780 systemd[592]: dbus-:1.2-org.kde.kwalletd6@4.service: Failed with result 'exit-code'.
Nov 28 06:02:48 tracey-aspiretc780 systemd[592]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@3.service: Failed with result 'exit-code'.
Nov 28 06:02:48 tracey-aspiretc780 systemd[592]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@4.service: Failed with result 'exit-code'.
Nov 28 06:02:48 tracey-aspiretc780 xdg-desktop-por[648]: Backend call failed: Could not activate remote peer 'org.freedesktop.impl.portal.desktop.kwallet': unit failed
Nov 28 06:02:48 tracey-aspiretc780 systemd[592]: dbus-:1.2-org.kde.kwalletd6@5.service: Failed with result 'exit-code'.
Nov 28 06:03:20 tracey-aspiretc780 systemd-coredump[2153]: [🡕] Process 1363 (chromium) of user 1000 dumped core.
Stack trace of thread 1:
#0 0x00005603f03c4c27 n/a (/usr/lib/chromium/chromium + 0x8444c27)
#1 0x00005603f03c4c39 n/a (/usr/lib/chromium/chromium + 0x8444c39)
#2 0x00005603f03c4c49 n/a (/usr/lib/chromium/chromium + 0x8444c49)
#3 0x00005603f03c4dbb n/a (/usr/lib/chromium/chromium + 0x8444dbb)
#4 0x00005603f03c6ce7 n/a (/usr/lib/chromium/chromium + 0x8446ce7)
#5 0x00005603f4e3d5d5 n/a (/usr/lib/chromium/chromium + 0xcebd5d5)
#6 0x00005603f4e3add7 n/a (/usr/lib/chromium/chromium + 0xcebadd7)
#7 0x00005603f4e3f742 n/a (/usr/lib/chromium/chromium + 0xcebf742)
#8 0x00005603f4e41fb2 n/a (/usr/lib/chromium/chromium + 0xcec1fb2)
#9 0x00005603f4232470 n/a (/usr/lib/chromium/chromium + 0xc2b2470)
#10 0x00005603edee49a2 n/a (/usr/lib/chromium/chromium + 0x5f649a2)
#11 0x00005603f02fca15 n/a (/usr/lib/chromium/chromium + 0x837ca15)
#12 0x00005603f0323a3f n/a (/usr/lib/chromium/chromium + 0x83a3a3f)
#13 0x00005603f02a07f8 n/a (/usr/lib/chromium/chromium + 0x83207f8)
#14 0x00005603f032473f n/a (/usr/lib/chromium/chromium + 0x83a473f)
#15 0x00005603f02d905b n/a (/usr/lib/chromium/chromium + 0x835905b)
#16 0x00005603f3c40839 n/a (/usr/lib/chromium/chromium + 0xbcc0839)
#17 0x00005603eecc4fdb n/a (/usr/lib/chromium/chromium + 0x6d44fdb)
#18 0x00005603eecc6a6b n/a (/usr/lib/chromium/chromium + 0x6d46a6b)
#19 0x00005603eecc3a2e n/a (/usr/lib/chromium/chromium + 0x6d43a2e)
#20 0x00005603e99bb2a9 ChromeMain (/usr/lib/chromium/chromium + 0x1a3b2a9)
#21 0x00007f3898627675 n/a (libc.so.6 + 0x27675)
#22 0x00007f3898627729 __libc_start_main (libc.so.6 + 0x27729)
#23 0x00005603e93e4025 _start (/usr/lib/chromium/chromium + 0x1464025)
Stack trace of thread 13:
#0 0x00007f389869f042 n/a (libc.so.6 + 0x9f042)
#1 0x00007f38986931ac n/a (libc.so.6 + 0x931ac)
#2 0x00007f389869381c n/a (libc.so.6 + 0x9381c)
#3 0x00007f38986960e8 pthread_cond_timedwait (libc.so.6 + 0x960e8)
#4 0x00005603f0364a84 n/a (/usr/lib/chromium/chromium + 0x83e4a84)
#5 0x00005603f039d2f9 n/a (/usr/lib/chromium/chromium + 0x841d2f9)
#6 0x00005603f02f90c8 n/a (/usr/lib/chromium/chromium + 0x83790c8)
#7 0x00005603f02a090a n/a (/usr/lib/chromium/chromium + 0x832090a)
#8 0x00005603f032473f n/a (/usr/lib/chromium/chromium + 0x83a473f)
#9 0x00005603f02d905b n/a (/usr/lib/chromium/chromium + 0x835905b)
#10 0x00005603ede7f136 n/a (/usr/lib/chromium/chromium + 0x5eff136)
#11 0x00005603f0365585 n/a (/usr/lib/chromium/chromium + 0x83e5585)
#12 0x00007f38986969cb n/a (libc.so.6 + 0x969cb)
#13 0x00007f389871a834 __clone (libc.so.6 + 0x11a834)
Stack trace of thread 16:
#0 0x00005603f035068b n/a (/usr/lib/chromium/chromium + 0x83d068b)
#1 0x00005603f0323912 n/a (/usr/lib/chromium/chromium + 0x83a3912)
#2 0x00005603f02a07f8 n/a (/usr/lib/chromium/chromium + 0x83207f8)
#3 0x00005603f032473f n/a (/usr/lib/chromium/chromium + 0x83a473f)
#4 0x00005603f02d905b n/a (/usr/lib/chromium/chromium + 0x835905b)
#5 0x00005603f034c8e7 n/a (/usr/lib/chromium/chromium + 0x83cc8e7)
#6 0x00005603f034cc82 n/a (/usr/lib/chromium/chromium + 0x83ccc82)
#7 0x00005603f0365585 n/a (/usr/lib/chromium/chromium + 0x83e5585)
#8 0x00007f38986969cb n/a (libc.so.6 + 0x969cb)
#9 0x00007f389871a834 __clone (libc.so.6 + 0x11a834)
#2 0x00007f38986931f4 n/a (libc.so.6 + 0x931f4)
#3 0x00007f389871acf5 epoll_wait (libc.so.6 + 0x11acf5)
#4 0x00005603f0398d48 n/a (/usr/lib/chromium/chromium + 0x8418d48)
#5 0x00005603f0398ab7 n/a (/usr/lib/chromium/chromium + 0x8418ab7)
#6 0x00005603f032473f n/a (/usr/lib/chromium/chromium + 0x83a473f)
#7 0x00005603f02d905b n/a (/usr/lib/chromium/chromium + 0x835905b)
#8 0x00005603ede7f136 n/a (/usr/lib/chromium/chromium + 0x5eff136)
#9 0x00005603f0365585 n/a (/usr/lib/chromium/chromium + 0x83e5585)
#10 0x00007f38986969cb n/a (libc.so.6 + 0x969cb)
#11 0x00007f389871a834 __clone (libc.so.6 + 0x11a834)
#7 0x00005603f03456f8 n/a (/usr/lib/chromium/chromium + 0x83c56f8)
#8 0x00005603f0365585 n/a (/usr/lib/chromium/chromium + 0x83e5585)
#9 0x00007f38986969cb n/a (libc.so.6 + 0x969cb)
#10 0x00007f389871a834 __clone (libc.so.6 + 0x11a834)
Stack trace of thread 57:
#7 0x00005603f0342e96 n/a (/usr/lib/chromium/chromium + 0x83c2e96)
#8 0x00005603f0343b79 n/a (/usr/lib/chromium/chromium + 0x83c3b79)
#9 0x00005603f03438ea n/a (/usr/lib/chromium/chromium + 0x83c38ea)
#10 0x00005603f03436ef n/a (/usr/lib/chromium/chromium + 0x83c36ef)
Stack trace of thread 10:
#7 0x00005603f0342e54 n/a (/usr/lib/chromium/chromium + 0x83c2e54)
#8 0x00005603f034c8e7 n/a (/usr/lib/chromium/chromium + 0x83cc8e7)
#9 0x00005603f034cc82 n/a (/usr/lib/chromium/chromium + 0x83ccc82)
#10 0x00005603f0365585 n/a (/usr/lib/chromium/chromium + 0x83e5585)
#11 0x00007f38986969cb n/a (libc.so.6 + 0x969cb)
#12 0x00007f389871a834 __clone (libc.so.6 + 0x11a834)
Stack trace of thread 172:
#3 0x00007f389870da6e read (libc.so.6 + 0x10da6e)
#4 0x00005603f037d9ec n/a (/usr/lib/chromium/chromium + 0x83fd9ec)
#5 0x00005603f03831b3 n/a (/usr/lib/chromium/chromium + 0x84031b3)
#6 0x00005603ea4e9607 n/a (/usr/lib/chromium/chromium + 0x2569607)
Stack trace of thread 169:
#3 0x00007f3898695ede pthread_cond_wait (libc.so.6 + 0x95ede)
#4 0x00005603f1806596 n/a (/usr/lib/chromium/chromium + 0x9886596)
#5 0x00007f38986969cb n/a (libc.so.6 + 0x969cb)
#6 0x00007f389871a834 __clone (libc.so.6 + 0x11a834)
Stack trace of thread 5:
#3 0x00007f389871c561 recvmsg (libc.so.6 + 0x11c561)
#4 0x00005603f074cb1b n/a (/usr/lib/chromium/chromium + 0x87ccb1b)
#5 0x00005603e9b43b77 n/a (/usr/lib/chromium/chromium + 0x1bc3b77)
#6 0x00005603f0399495 n/a (/usr/lib/chromium/chromium + 0x8419495)
#7 0x00005603f039896c n/a (/usr/lib/chromium/chromium + 0x841896c)
#10 0x00005603f3b775d9 n/a (/usr/lib/chromium/chromium + 0xbbf75d9)
#11 0x00005603f034cc82 n/a (/usr/lib/chromium/chromium + 0x83ccc82)
#12 0x00005603f0365585 n/a (/usr/lib/chromium/chromium + 0x83e5585)
#13 0x00007f38986969cb n/a (libc.so.6 + 0x969cb)
#14 0x00007f389871a834 __clone (libc.so.6 + 0x11a834)
Stack trace of thread 28:
#4 0x00005603f0364844 n/a (/usr/lib/chromium/chromium + 0x83e4844)
#5 0x00005603f039d2df n/a (/usr/lib/chromium/chromium + 0x841d2df)
#10 0x00005603f034c8e7 n/a (/usr/lib/chromium/chromium + 0x83cc8e7)
Stack trace of thread 6:
Stack trace of thread 23:
Stack trace of thread 3:
#8 0x00005603f0333607 n/a (/usr/lib/chromium/chromium + 0x83b3607)
Stack trace of thread 15:
#0 0x00007f389871876d syscall (libc.so.6 + 0x11876d)
#1 0x00005603f03cf2de n/a (/usr/lib/chromium/chromium + 0x844f2de)
#2 0x00005603f03cf192 n/a (/usr/lib/chromium/chromium + 0x844f192)
#3 0x00005603f4e3d172 n/a (/usr/lib/chromium/chromium + 0xcebd172)
#4 0x00005603f4e3add7 n/a (/usr/lib/chromium/chromium + 0xcebadd7)
#5 0x00005603f4e3f742 n/a (/usr/lib/chromium/chromium + 0xcebf742)
#6 0x00005603f4e41fb2 n/a (/usr/lib/chromium/chromium + 0xcec1fb2)
#7 0x00005603f4232470 n/a (/usr/lib/chromium/chromium + 0xc2b2470)
#8 0x00005603edee49a2 n/a (/usr/lib/chromium/chromium + 0x5f649a2)
#9 0x00005603f02fca15 n/a (/usr/lib/chromium/chromium + 0x837ca15)
#10 0x00005603f0323a3f n/a (/usr/lib/chromium/chromium + 0x83a3a3f)
#11 0x00005603f02a07f8 n/a (/usr/lib/chromium/chromium + 0x83207f8)
#12 0x00005603f032473f n/a (/usr/lib/chromium/chromium + 0x83a473f)
#13 0x00005603f02d905b n/a (/usr/lib/chromium/chromium + 0x835905b)
#14 0x00005603ede7f136 n/a (/usr/lib/chromium/chromium + 0x5eff136)
#15 0x00005603f0365585 n/a (/usr/lib/chromium/chromium + 0x83e5585)
#16 0x00007f38986969cb n/a (libc.so.6 + 0x969cb)
#17 0x00007f389871a834 __clone (libc.so.6 + 0x11a834)
Stack trace of thread 168:
Stack trace of thread 171:
Stack trace of thread 12:
Stack trace of thread 4:
Stack trace of thread 8:
#9 0x00005603f034393a n/a (/usr/lib/chromium/chromium + 0x83c393a)
#10 0x00005603f0343744 n/a (/usr/lib/chromium/chromium + 0x83c3744)
Stack trace of thread 14:
Stack trace of thread 170:
Nov 28 08:18:10 tracey-aspiretc780 plasmashell[702]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
Nov 28 08:40:54 tracey-aspiretc780 plasmashell[702]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
Nov 28 10:05:51 tracey-aspiretc780 plasmashell[702]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
Nov 28 15:57:08 tracey-aspiretc780 plasmashell[702]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:130: TypeError: Cannot read property 'screenGeometry' of null
Nov 28 15:57:08 tracey-aspiretc780 plasmashell[702]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:260: TypeError: Cannot read property 'plasmoid' of undefined
Nov 28 15:57:08 tracey-aspiretc780 sddm-helper[587]: Signal received: SIGTERM
Nov 28 15:57:08 tracey-aspiretc780 sddm[574]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Nov 28 15:57:08 tracey-aspiretc780 sddm[574]: Auth: sddm-helper (--socket /tmp/sddm-auth-b6dd4cff-ab07-4105-8b00-86435b5820ad --id 1 --start /usr/bin/startplasma-x11 --user tracey --autologin) crashed (exit code 1)
Nov 28 15:57:08 tracey-aspiretc780 sddm[574]: Auth: sddm-helper exited with 1
Nov 28 15:57:08 tracey-aspiretc780 kwin_x11[676]: kwin_scene_opengl: Could not delete framebuffer because no context is current
Nov 28 15:57:08 tracey-aspiretc780 sddm[574]: Signal received: SIGTERM
Nov 28 15:57:08 tracey-aspiretc780 ksmserver[673]: The X11 connection broke (error 1). Did the X11 server die?
Nov 28 15:57:08 tracey-aspiretc780 systemd[592]: dbus-:1.59-org.a11y.atspi.Registry@0.service: Failed with result 'exit-code'.
Nov 28 15:57:08 tracey-aspiretc780 kwin_x11[676]: The X11 connection broke: I/O error (code 1)
Nov 28 15:57:08 tracey-aspiretc780 dbus-broker[479]: A security policy denied :1.4 to send method call /midi/profile:org.bluez.GattProfile1.Release to :1.49.
Nov 28 15:57:08 tracey-aspiretc780 systemd[592]: plasma-ksmserver.service: Failed with result 'exit-code'.
Nov 28 15:57:09 tracey-aspiretc780 systemd[592]: plasma-kwin_x11.service: Failed with result 'exit-code'.
Nov 28 15:57:10 tracey-aspiretc780 dbus-broker-launch[478]: Activation request for 'org.freedesktop.RealtimeKit1' failed.
Nov 28 15:57:14 tracey-aspiretc780 systemd[592]: plasma-kded6.service: State 'stop-sigterm' timed out. Killing.
Nov 28 15:57:14 tracey-aspiretc780 systemd[592]: plasma-kded6.service: Main process exited, code=killed, status=9/KILL
Nov 28 15:57:14 tracey-aspiretc780 systemd[592]: plasma-kded6.service: Failed with result 'timeout'.
Nov 28 15:57:14 tracey-aspiretc780 dbus-broker-launch[478]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
-- Boot 668eb7192d9b4c2f9ac6c33a48862da6 --
Nov 29 04:46:02 tracey-aspiretc780 kernel: x86/cpu: SGX disabled or unsupported by BIOS.
Nov 29 04:46:02 tracey-aspiretc780 kernel: tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x200] vs fed40080 f80
Nov 29 04:46:02 tracey-aspiretc780 kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Nov 29 04:46:06 tracey-aspiretc780 kernel: resource: resource sanity check: requesting [mem 0x00000000fdffe800-0x00000000fe0007ff], which spans more than pnp 00:07 [mem 0xfdb00000-0xfdffffff]
Nov 29 04:46:06 tracey-aspiretc780 kernel: caller get_primary_reg_base+0x4d/0xa0 [intel_pmc_core] mapping multiple BARs
Nov 29 04:46:17 tracey-aspiretc780 dbus-broker-launch[478]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Nov 29 04:46:21 tracey-aspiretc780 dbus-broker-launch[478]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Nov 29 04:46:23 tracey-aspiretc780 dbus-broker-launch[623]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Nov 29 04:46:23 tracey-aspiretc780 dbus-broker-launch[623]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Nov 29 04:46:23 tracey-aspiretc780 dbus-broker-launch[623]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Nov 29 04:46:32 tracey-aspiretc780 kded6[666]: QDBusObjectPath: invalid path "/modules/oom-notifier"
Nov 29 04:46:32 tracey-aspiretc780 kded6[666]: kf.dbusaddons: The kded module name "oom-notifier" is invalid!
Nov 29 04:46:34 tracey-aspiretc780 baloo_file[644]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.24'
Nov 29 04:46:34 tracey-aspiretc780 baloo_file[644]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.25'
Nov 29 04:46:37 tracey-aspiretc780 org_kde_powerdevil[746]: Failed to create wl_display (No such file or directory)
Nov 29 04:46:38 tracey-aspiretc780 org_kde_powerdevil[746]: [ 746] busno=0, Feature 0xdd should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
Nov 29 04:46:38 tracey-aspiretc780 kded6[666]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
Nov 29 04:46:38 tracey-aspiretc780 org_kde_powerdevil[746]: [ 746] busno=0, Feature 0x41 should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
Nov 29 04:46:38 tracey-aspiretc780 org_kde_powerdevil[746]: [ 746] busno=0, Feature 0x00 should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
Nov 29 04:46:38 tracey-aspiretc780 org_kde_powerdevil[746]: [ 746] busno=0, All features that should not exist detected. Monitor does not indicate unsupported
Nov 29 04:46:38 tracey-aspiretc780 org_kde_powerdevil[746]: [ 746] Watching for DPMS state changes unimplemented
Nov 29 04:46:38 tracey-aspiretc780 backlighthelper[857]: org.kde.powerdevil: no kernel backlight interface found
Nov 29 04:46:38 tracey-aspiretc780 org_kde_powerdevil[746]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Nov 29 04:46:38 tracey-aspiretc780 org_kde_powerdevil[746]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Nov 29 04:46:39 tracey-aspiretc780 kded6[666]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
Nov 29 04:46:39 tracey-aspiretc780 kded6[666]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
Nov 29 04:46:39 tracey-aspiretc780 org_kde_powerdevil[746]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Nov 29 04:46:39 tracey-aspiretc780 org_kde_powerdevil[746]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Nov 29 04:46:39 tracey-aspiretc780 kded6[666]: QDBusObjectPath: invalid path "/modules/wpad-detector"
Nov 29 04:46:39 tracey-aspiretc780 kded6[666]: kf.dbusaddons: The kded module name "wpad-detector" is invalid!
Nov 29 04:46:43 tracey-aspiretc780 systemd[593]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@0.service: Failed with result 'exit-code'.
Nov 29 04:46:48 tracey-aspiretc780 plasmashell[702]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:178:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth":
file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:201:9
Nov 29 04:46:48 tracey-aspiretc780 kconf_update[1001]: kf.config.kconf_update: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
Nov 29 04:46:48 tracey-aspiretc780 kconf_update[1001]: kf.config.kconf_update: /usr/share/kconf_update/filepicker.upd defined Version=5 but Version=6 was expected
Nov 29 04:46:49 tracey-aspiretc780 kded6[666]: kf.bluezqt: PendingCall Error: "The name is not activatable"
Nov 29 04:46:53 tracey-aspiretc780 plasmashell[702]: Toolbox not loading, toolbox package is either invalid or disabled.
Nov 29 04:46:54 tracey-aspiretc780 kernel: warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
Nov 29 04:46:54 tracey-aspiretc780 kdeconnectd[887]: Error sending UDP packet: QAbstractSocket::NetworkError
Nov 29 04:46:56 tracey-aspiretc780 plasmashell[702]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/main.qml:310:13: QML Image: Cannot open: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/start-here-kde-symbolic
Nov 29 04:46:56 tracey-aspiretc780 plasmashell[702]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" 0x55818ba42830
Nov 29 04:46:56 tracey-aspiretc780 plasmashell[702]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" 0x55818ba42830
Nov 29 04:47:01 tracey-aspiretc780 plasmashell[702]: org.kde.applets.brightness: D-Bus action "KeyboardBrightnessControl" is not available at service "org.kde.Solid.PowerManagement"
Nov 29 04:47:10 tracey-aspiretc780 systemd[593]: dbus-:1.2-org.kde.kwalletd6@0.service: Failed with result 'exit-code'.
Nov 29 04:47:10 tracey-aspiretc780 systemd[593]: dbus-:1.2-org.kde.kwalletd6@1.service: Failed with result 'exit-code'.
Nov 29 04:47:18 tracey-aspiretc780 systemd[593]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@1.service: Failed with result 'exit-code'.
Nov 29 04:47:18 tracey-aspiretc780 systemd[593]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@2.service: Failed with result 'exit-code'.
Nov 29 04:47:18 tracey-aspiretc780 xdg-desktop-por[645]: Backend call failed: Could not activate remote peer 'org.freedesktop.impl.portal.desktop.kwallet': unit failed
Nov 29 04:47:18 tracey-aspiretc780 systemd[593]: dbus-:1.2-org.kde.kwalletd6@2.service: Failed with result 'exit-code'.
Nov 29 04:47:32 tracey-aspiretc780 kwin_x11[669]: kwin_core: XCB error: 152 (BadDamage), sequence: 16066, resource id: 18875718, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Nov 29 04:47:32 tracey-aspiretc780 kwin_x11[669]: kwin_core: XCB error: 3 (BadWindow), sequence: 16067, resource id: 4194336, major code: 129 (SHAPE), minor code: 6 (Input)
Nov 29 04:48:18 tracey-aspiretc780 plasmashell[702]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/items/PlasmoidItem.qml:24: TypeError: Cannot read property 'toolTipMainText' of null
Nov 29 07:31:09 tracey-aspiretc780 plasmashell[702]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/items/PlasmoidItem.qml:24: TypeError: Cannot read property 'toolTipMainText' of null
Nov 29 14:41:30 tracey-aspiretc780 kwin_x11[669]: kwin_core: XCB error: 152 (BadDamage), sequence: 60054, resource id: 20227518, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Nov 29 14:41:30 tracey-aspiretc780 kwin_x11[669]: kwin_core: XCB error: 3 (BadWindow), sequence: 60055, resource id: 4194369, major code: 129 (SHAPE), minor code: 6 (Input)
Nov 29 14:41:36 tracey-aspiretc780 plasmashell[702]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:130: TypeError: Cannot read property 'screenGeometry' of null
Nov 29 14:41:36 tracey-aspiretc780 plasmashell[702]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:260: TypeError: Cannot read property 'plasmoid' of undefined
Nov 29 14:41:37 tracey-aspiretc780 kwin_x11[669]: kwin_scene_opengl: Could not delete framebuffer because no context is current
Nov 29 14:41:37 tracey-aspiretc780 sddm-helper[587]: Signal received: SIGTERM
Nov 29 14:41:37 tracey-aspiretc780 sddm[574]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Nov 29 14:41:37 tracey-aspiretc780 sddm[574]: Auth: sddm-helper (--socket /tmp/sddm-auth-3a75858f-d8c1-4687-bf2b-1f2a57800b91 --id 1 --start /usr/bin/startplasma-x11 --user tracey --autologin) crashed (exit code 1)
Nov 29 14:41:37 tracey-aspiretc780 sddm[574]: Auth: sddm-helper exited with 1
Nov 29 14:41:37 tracey-aspiretc780 sddm[574]: Signal received: SIGTERM
Nov 29 14:41:37 tracey-aspiretc780 ksmserver[662]: The X11 connection broke (error 1). Did the X11 server die?
Nov 29 14:41:37 tracey-aspiretc780 systemd[593]: dbus-:1.58-org.a11y.atspi.Registry@0.service: Failed with result 'exit-code'.
Nov 29 14:41:37 tracey-aspiretc780 dbus-broker[479]: A security policy denied :1.4 to send method call /midi/profile:org.bluez.GattProfile1.Release to :1.49.
Nov 29 14:41:37 tracey-aspiretc780 dbus-broker-launch[478]: Activation request for 'org.bluez' failed.
Nov 29 14:41:37 tracey-aspiretc780 systemd[593]: plasma-kwin_x11.service: Failed with result 'exit-code'.
Nov 29 14:41:37 tracey-aspiretc780 dbus-broker-launch[478]: Activation request for 'org.freedesktop.RealtimeKit1' failed.
Nov 29 14:41:42 tracey-aspiretc780 systemd[593]: plasma-kded6.service: State 'stop-sigterm' timed out. Killing.
Nov 29 14:41:42 tracey-aspiretc780 systemd[593]: plasma-kded6.service: Main process exited, code=killed, status=9/KILL
Nov 29 14:41:42 tracey-aspiretc780 systemd[593]: plasma-kded6.service: Failed with result 'timeout'.
Nov 29 14:41:42 tracey-aspiretc780 dbus-broker-launch[478]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
November 30th.
journalctl --until 2025-12-01 --since 2025-11-30 --priority 4 --no-pager ✔
Nov 30 04:38:26 tracey-aspiretc780 kernel: x86/cpu: SGX disabled or unsupported by BIOS.
Nov 30 04:38:26 tracey-aspiretc780 kernel: tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x200] vs fed40080 f80
Nov 30 04:38:26 tracey-aspiretc780 kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Nov 30 04:38:30 tracey-aspiretc780 kernel: resource: resource sanity check: requesting [mem 0x00000000fdffe800-0x00000000fe0007ff], which spans more than pnp 00:07 [mem 0xfdb00000-0xfdffffff]
Nov 30 04:38:30 tracey-aspiretc780 kernel: caller get_primary_reg_base+0x4d/0xa0 [intel_pmc_core] mapping multiple BARs
Nov 30 04:38:41 tracey-aspiretc780 dbus-broker-launch[478]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Nov 30 04:38:44 tracey-aspiretc780 dbus-broker-launch[478]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Nov 30 04:38:46 tracey-aspiretc780 dbus-broker-launch[622]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Nov 30 04:38:47 tracey-aspiretc780 dbus-broker-launch[622]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Nov 30 04:38:47 tracey-aspiretc780 dbus-broker-launch[622]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Nov 30 04:38:55 tracey-aspiretc780 kded6[677]: QDBusObjectPath: invalid path "/modules/oom-notifier"
Nov 30 04:38:55 tracey-aspiretc780 kded6[677]: kf.dbusaddons: The kded module name "oom-notifier" is invalid!
Nov 30 04:38:58 tracey-aspiretc780 baloo_file[647]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.22'
Nov 30 04:38:58 tracey-aspiretc780 baloo_file[647]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.26'
Nov 30 04:39:01 tracey-aspiretc780 org_kde_powerdevil[746]: Failed to create wl_display (No such file or directory)
Nov 30 04:39:02 tracey-aspiretc780 org_kde_powerdevil[746]: [ 746] busno=0, Feature 0xdd should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
Nov 30 04:39:02 tracey-aspiretc780 org_kde_powerdevil[746]: [ 746] busno=0, Feature 0x41 should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
Nov 30 04:39:02 tracey-aspiretc780 org_kde_powerdevil[746]: [ 746] busno=0, Feature 0x00 should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
Nov 30 04:39:02 tracey-aspiretc780 org_kde_powerdevil[746]: [ 746] busno=0, All features that should not exist detected. Monitor does not indicate unsupported
Nov 30 04:39:02 tracey-aspiretc780 org_kde_powerdevil[746]: [ 746] Watching for DPMS state changes unimplemented
Nov 30 04:39:02 tracey-aspiretc780 kded6[677]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
Nov 30 04:39:02 tracey-aspiretc780 backlighthelper[867]: org.kde.powerdevil: no kernel backlight interface found
Nov 30 04:39:02 tracey-aspiretc780 org_kde_powerdevil[746]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Nov 30 04:39:02 tracey-aspiretc780 org_kde_powerdevil[746]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Nov 30 04:39:03 tracey-aspiretc780 kded6[677]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
Nov 30 04:39:03 tracey-aspiretc780 kded6[677]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
Nov 30 04:39:03 tracey-aspiretc780 systemd[593]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@0.service: Failed with result 'exit-code'.
Nov 30 04:39:03 tracey-aspiretc780 kded6[677]: QDBusObjectPath: invalid path "/modules/wpad-detector"
Nov 30 04:39:03 tracey-aspiretc780 kded6[677]: kf.dbusaddons: The kded module name "wpad-detector" is invalid!
Nov 30 04:39:03 tracey-aspiretc780 org_kde_powerdevil[746]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Nov 30 04:39:03 tracey-aspiretc780 org_kde_powerdevil[746]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Nov 30 04:39:12 tracey-aspiretc780 kconf_update[1006]: kf.config.kconf_update: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
Nov 30 04:39:12 tracey-aspiretc780 kconf_update[1006]: kf.config.kconf_update: /usr/share/kconf_update/filepicker.upd defined Version=5 but Version=6 was expected
Nov 30 04:39:13 tracey-aspiretc780 kded6[677]: kf.bluezqt: PendingCall Error: "The name is not activatable"
Nov 30 04:39:14 tracey-aspiretc780 plasmashell[707]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:178:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth":
Nov 30 04:39:17 tracey-aspiretc780 plasmashell[707]: Toolbox not loading, toolbox package is either invalid or disabled.
Nov 30 04:39:17 tracey-aspiretc780 kernel: warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
Nov 30 04:39:17 tracey-aspiretc780 kdeconnectd[904]: Error sending UDP packet: QAbstractSocket::NetworkError
Nov 30 04:39:20 tracey-aspiretc780 plasmashell[707]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/main.qml:310:13: QML Image: Cannot open: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/start-here-kde-symbolic
Nov 30 04:39:20 tracey-aspiretc780 plasmashell[707]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" 0x55f3dc680300
Nov 30 04:39:20 tracey-aspiretc780 plasmashell[707]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" 0x55f3dc680300
Nov 30 04:39:25 tracey-aspiretc780 plasmashell[707]: org.kde.applets.brightness: D-Bus action "KeyboardBrightnessControl" is not available at service "org.kde.Solid.PowerManagement"
Nov 30 04:40:25 tracey-aspiretc780 systemd[593]: dbus-:1.2-org.kde.KSplash@1.service: Failed with result 'exit-code'.
Nov 30 04:59:42 tracey-aspiretc780 systemd[593]: dbus-:1.2-org.kde.kwalletd6@0.service: Failed with result 'exit-code'.
Nov 30 04:59:42 tracey-aspiretc780 systemd[593]: dbus-:1.2-org.kde.kwalletd6@1.service: Failed with result 'exit-code'.
Nov 30 04:59:50 tracey-aspiretc780 systemd[593]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@1.service: Failed with result 'exit-code'.
Nov 30 04:59:50 tracey-aspiretc780 systemd[593]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@2.service: Failed with result 'exit-code'.
Nov 30 04:59:50 tracey-aspiretc780 xdg-desktop-por[648]: Backend call failed: Could not activate remote peer 'org.freedesktop.impl.portal.desktop.kwallet': unit failed
Nov 30 04:59:50 tracey-aspiretc780 systemd[593]: dbus-:1.2-org.kde.kwalletd6@2.service: Failed with result 'exit-code'.
Nov 30 07:33:13 tracey-aspiretc780 plasmashell[707]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/items/PlasmoidItem.qml:24: TypeError: Cannot read property 'toolTipMainText' of null
Nov 30 15:54:12 tracey-aspiretc780 kwin_x11[678]: kwin_core: XCB error: 152 (BadDamage), sequence: 22422, resource id: 21513994, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Nov 30 15:54:12 tracey-aspiretc780 kwin_x11[678]: kwin_core: XCB error: 3 (BadWindow), sequence: 22423, resource id: 4194353, major code: 129 (SHAPE), minor code: 6 (Input)
Nov 30 15:54:19 tracey-aspiretc780 plasmashell[707]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:130: TypeError: Cannot read property 'screenGeometry' of null
Nov 30 15:54:19 tracey-aspiretc780 plasmashell[707]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:260: TypeError: Cannot read property 'plasmoid' of undefined
Nov 30 15:54:19 tracey-aspiretc780 kwin_x11[678]: kwin_scene_opengl: Could not delete framebuffer because no context is current
Nov 30 15:54:19 tracey-aspiretc780 sddm-helper[587]: Signal received: SIGTERM
Nov 30 15:54:19 tracey-aspiretc780 sddm[574]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Nov 30 15:54:19 tracey-aspiretc780 sddm[574]: Auth: sddm-helper (--socket /tmp/sddm-auth-3313466f-6175-4994-ae82-1a76256a5075 --id 1 --start /usr/bin/startplasma-x11 --user tracey --autologin) crashed (exit code 1)
Nov 30 15:54:19 tracey-aspiretc780 sddm[574]: Auth: sddm-helper exited with 1
Nov 30 15:54:19 tracey-aspiretc780 sddm[574]: Signal received: SIGTERM
Nov 30 15:54:19 tracey-aspiretc780 ksmserver[675]: The X11 connection broke (error 1). Did the X11 server die?
Nov 30 15:54:19 tracey-aspiretc780 systemd[593]: dbus-:1.59-org.a11y.atspi.Registry@0.service: Failed with result 'exit-code'.
Nov 30 15:54:19 tracey-aspiretc780 dbus-broker[479]: A security policy denied :1.5 to send method call /midi/profile:org.bluez.GattProfile1.Release to :1.49.
Nov 30 15:54:20 tracey-aspiretc780 systemd[593]: plasma-kwin_x11.service: Failed with result 'exit-code'.
Nov 30 15:54:20 tracey-aspiretc780 kded6[677]: The X11 connection broke: I/O error (code 1)
Nov 30 15:54:20 tracey-aspiretc780 systemd[593]: plasma-kded6.service: Failed with result 'exit-code'.
Nov 30 15:54:21 tracey-aspiretc780 dbus-broker-launch[478]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
December 01
~ journalctl --until 2025-12-02 --since 2025-12-01 --priority 4 --no-pager ✔
Dec 01 04:54:08 tracey-aspiretc780 kernel: x86/cpu: SGX disabled or unsupported by BIOS.
Dec 01 04:54:08 tracey-aspiretc780 kernel: tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x200] vs fed40080 f80
Dec 01 04:54:08 tracey-aspiretc780 kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Dec 01 04:54:12 tracey-aspiretc780 kernel: resource: resource sanity check: requesting [mem 0x00000000fdffe800-0x00000000fe0007ff], which spans more than pnp 00:07 [mem 0xfdb00000-0xfdffffff]
Dec 01 04:54:12 tracey-aspiretc780 kernel: caller get_primary_reg_base+0x4d/0xa0 [intel_pmc_core] mapping multiple BARs
Dec 01 04:54:23 tracey-aspiretc780 dbus-broker-launch[480]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Dec 01 04:54:28 tracey-aspiretc780 dbus-broker-launch[480]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Dec 01 04:54:30 tracey-aspiretc780 dbus-broker-launch[625]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Dec 01 04:54:30 tracey-aspiretc780 dbus-broker-launch[625]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Dec 01 04:54:30 tracey-aspiretc780 dbus-broker-launch[625]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Dec 01 04:54:38 tracey-aspiretc780 kded6[667]: QDBusObjectPath: invalid path "/modules/oom-notifier"
Dec 01 04:54:38 tracey-aspiretc780 kded6[667]: kf.dbusaddons: The kded module name "oom-notifier" is invalid!
Dec 01 04:54:43 tracey-aspiretc780 baloo_file[649]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.21'
Dec 01 04:54:43 tracey-aspiretc780 baloo_file[649]: qt.dbus.integration: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.26'
Dec 01 04:54:43 tracey-aspiretc780 kded6[667]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
Dec 01 04:54:43 tracey-aspiretc780 org_kde_powerdevil[749]: Failed to create wl_display (No such file or directory)
Dec 01 04:54:44 tracey-aspiretc780 org_kde_powerdevil[749]: [ 749] busno=0, Feature 0xdd should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
Dec 01 04:54:44 tracey-aspiretc780 org_kde_powerdevil[749]: [ 749] busno=0, Feature 0x41 should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
Dec 01 04:54:44 tracey-aspiretc780 org_kde_powerdevil[749]: [ 749] busno=0, Feature 0x00 should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
Dec 01 04:54:44 tracey-aspiretc780 org_kde_powerdevil[749]: [ 749] busno=0, All features that should not exist detected. Monitor does not indicate unsupported
Dec 01 04:54:44 tracey-aspiretc780 org_kde_powerdevil[749]: [ 749] Watching for DPMS state changes unimplemented
Dec 01 04:54:44 tracey-aspiretc780 backlighthelper[850]: org.kde.powerdevil: no kernel backlight interface found
Dec 01 04:54:44 tracey-aspiretc780 org_kde_powerdevil[749]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Dec 01 04:54:44 tracey-aspiretc780 org_kde_powerdevil[749]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Dec 01 04:54:44 tracey-aspiretc780 kded6[667]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
Dec 01 04:54:44 tracey-aspiretc780 kded6[667]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
Dec 01 04:54:45 tracey-aspiretc780 kded6[667]: QDBusObjectPath: invalid path "/modules/wpad-detector"
Dec 01 04:54:45 tracey-aspiretc780 kded6[667]: kf.dbusaddons: The kded module name "wpad-detector" is invalid!
Dec 01 04:54:45 tracey-aspiretc780 org_kde_powerdevil[749]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Dec 01 04:54:45 tracey-aspiretc780 org_kde_powerdevil[749]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Dec 01 04:54:53 tracey-aspiretc780 systemd[595]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@0.service: Failed with result 'exit-code'.
Dec 01 04:54:54 tracey-aspiretc780 kconf_update[1005]: kf.config.kconf_update: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
Dec 01 04:54:54 tracey-aspiretc780 kconf_update[1005]: kf.config.kconf_update: /usr/share/kconf_update/filepicker.upd defined Version=5 but Version=6 was expected
Dec 01 04:54:55 tracey-aspiretc780 kded6[667]: kf.bluezqt: PendingCall Error: "The name is not activatable"
Dec 01 04:54:56 tracey-aspiretc780 plasmashell[706]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:178:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth":
Dec 01 04:54:59 tracey-aspiretc780 plasmashell[706]: Toolbox not loading, toolbox package is either invalid or disabled.
Dec 01 04:54:59 tracey-aspiretc780 kernel: warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
Dec 01 04:55:00 tracey-aspiretc780 kdeconnectd[892]: Error sending UDP packet: QAbstractSocket::NetworkError
Dec 01 04:55:01 tracey-aspiretc780 plasmashell[706]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/main.qml:310:13: QML Image: Cannot open: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/start-here-kde-symbolic
Dec 01 04:55:02 tracey-aspiretc780 plasmashell[706]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" 0x559b4492b440
Dec 01 04:55:02 tracey-aspiretc780 plasmashell[706]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" 0x559b4492b440
Dec 01 04:55:07 tracey-aspiretc780 plasmashell[706]: org.kde.applets.brightness: D-Bus action "KeyboardBrightnessControl" is not available at service "org.kde.Solid.PowerManagement"
Dec 01 04:55:07 tracey-aspiretc780 plasmashell[706]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/delegates/DelegatePopup.qml:147:17: QML Body: Binding loop detected for property "width"
Dec 01 04:55:08 tracey-aspiretc780 plasmashell[706]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/delegates/DelegatePopup.qml:147:17: QML Body: Binding loop detected for property "width"
Dec 01 05:22:53 tracey-aspiretc780 systemd[595]: dbus-:1.2-org.kde.kwalletd6@0.service: Failed with result 'exit-code'.
Dec 01 05:22:54 tracey-aspiretc780 systemd[595]: dbus-:1.2-org.kde.kwalletd6@1.service: Failed with result 'exit-code'.
Dec 01 05:23:02 tracey-aspiretc780 systemd[595]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@1.service: Failed with result 'exit-code'.
Dec 01 05:23:02 tracey-aspiretc780 systemd[595]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@2.service: Failed with result 'exit-code'.
Dec 01 05:23:02 tracey-aspiretc780 xdg-desktop-por[650]: Backend call failed: Could not activate remote peer 'org.freedesktop.impl.portal.desktop.kwallet': unit failed
Dec 01 05:23:02 tracey-aspiretc780 systemd[595]: dbus-:1.2-org.kde.kwalletd6@2.service: Failed with result 'exit-code'.
Dec 01 14:35:42 tracey-aspiretc780 kwin_x11[668]: kwin_core: XCB error: 152 (BadDamage), sequence: 23929, resource id: 21571602, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Dec 01 14:35:42 tracey-aspiretc780 kwin_x11[668]: kwin_core: XCB error: 3 (BadWindow), sequence: 23930, resource id: 4194364, major code: 129 (SHAPE), minor code: 6 (Input)
Dec 01 14:35:48 tracey-aspiretc780 plasmashell[706]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:130: TypeError: Cannot read property 'screenGeometry' of null
Dec 01 14:35:48 tracey-aspiretc780 plasmashell[706]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:260: TypeError: Cannot read property 'plasmoid' of undefined
Dec 01 14:35:48 tracey-aspiretc780 sddm-helper[590]: Signal received: SIGTERM
Dec 01 14:35:48 tracey-aspiretc780 sddm[576]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Dec 01 14:35:48 tracey-aspiretc780 sddm[576]: Auth: sddm-helper (--socket /tmp/sddm-auth-bbc7d438-b764-4a95-8969-c2414712c908 --id 1 --start /usr/bin/startplasma-x11 --user tracey --autologin) crashed (exit code 1)
Dec 01 14:35:48 tracey-aspiretc780 sddm[576]: Auth: sddm-helper exited with 1
Dec 01 14:35:48 tracey-aspiretc780 kwin_x11[668]: kwin_scene_opengl: Could not delete framebuffer because no context is current
Dec 01 14:35:48 tracey-aspiretc780 sddm[576]: Signal received: SIGTERM
Dec 01 14:35:48 tracey-aspiretc780 ksmserver[665]: The X11 connection broke (error 1). Did the X11 server die?
Dec 01 14:35:48 tracey-aspiretc780 kwin_x11[668]: The X11 connection broke: I/O error (code 1)
Dec 01 14:35:48 tracey-aspiretc780 systemd[595]: dbus-:1.58-org.a11y.atspi.Registry@0.service: Failed with result 'exit-code'.
Dec 01 14:35:48 tracey-aspiretc780 dbus-broker[481]: A security policy denied :1.4 to send method call /midi/profile:org.bluez.GattProfile1.Release to :1.49.
Dec 01 14:35:48 tracey-aspiretc780 systemd[595]: plasma-ksmserver.service: Failed with result 'exit-code'.
Dec 01 14:35:49 tracey-aspiretc780 systemd[595]: plasma-kwin_x11.service: Failed with result 'exit-code'.
Dec 01 14:35:49 tracey-aspiretc780 dbus-broker-launch[480]: Activation request for 'org.freedesktop.RealtimeKit1' failed.
Dec 01 14:35:53 tracey-aspiretc780 systemd[595]: plasma-kded6.service: State 'stop-sigterm' timed out. Killing.
Dec 01 14:35:53 tracey-aspiretc780 systemd[595]: plasma-kded6.service: Main process exited, code=killed, status=9/KILL
Dec 01 14:35:53 tracey-aspiretc780 systemd[595]: plasma-kded6.service: Failed with result 'timeout'.
Dec 01 14:35:54 tracey-aspiretc780 dbus-broker-launch[480]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
-- Boot a65d9a81472645248e8d0a2cbe4ab363 --
Dec 01 14:45:28 tracey-aspiretc780 kernel: x86/cpu: SGX disabled or unsupported by BIOS.
Dec 01 14:45:28 tracey-aspiretc780 kernel: tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x200] vs fed40080 f80
Dec 01 14:45:28 tracey-aspiretc780 kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Dec 01 14:45:32 tracey-aspiretc780 kernel: resource: resource sanity check: requesting [mem 0x00000000fdffe800-0x00000000fe0007ff], which spans more than pnp 00:07 [mem 0xfdb00000-0xfdffffff]
Dec 01 14:45:32 tracey-aspiretc780 kernel: caller get_primary_reg_base+0x4d/0xa0 [intel_pmc_core] mapping multiple BARs
Dec 01 14:45:43 tracey-aspiretc780 dbus-broker-launch[477]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Dec 01 14:45:47 tracey-aspiretc780 dbus-broker-launch[477]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Dec 01 14:45:49 tracey-aspiretc780 dbus-broker-launch[617]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Dec 01 14:45:49 tracey-aspiretc780 dbus-broker-launch[617]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Dec 01 14:45:49 tracey-aspiretc780 dbus-broker-launch[617]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Dec 01 14:45:56 tracey-aspiretc780 kded6[670]: QDBusObjectPath: invalid path "/modules/oom-notifier"
Dec 01 14:45:56 tracey-aspiretc780 kded6[670]: kf.dbusaddons: The kded module name "oom-notifier" is invalid!
Dec 01 14:46:01 tracey-aspiretc780 kded6[670]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
Dec 01 14:46:03 tracey-aspiretc780 kded6[670]: QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
Dec 01 14:46:03 tracey-aspiretc780 kded6[670]: kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
Dec 01 14:46:03 tracey-aspiretc780 kded6[670]: QDBusObjectPath: invalid path "/modules/wpad-detector"
Dec 01 14:46:03 tracey-aspiretc780 kded6[670]: kf.dbusaddons: The kded module name "wpad-detector" is invalid!
Dec 01 14:46:03 tracey-aspiretc780 org_kde_powerdevil[730]: Failed to create wl_display (No such file or directory)
Dec 01 14:46:04 tracey-aspiretc780 org_kde_powerdevil[730]: [ 730] busno=0, Feature 0xdd should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
Dec 01 14:46:04 tracey-aspiretc780 org_kde_powerdevil[730]: [ 730] busno=0, Feature 0x41 should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
Dec 01 14:46:04 tracey-aspiretc780 org_kde_powerdevil[730]: [ 730] busno=0, Feature 0x00 should not exist but ddc_get_nontable_vcp_value() succeeds, returning mh=0x00 ml=0x64 sh=0x00 sl=0x64
Dec 01 14:46:04 tracey-aspiretc780 org_kde_powerdevil[730]: [ 730] busno=0, All features that should not exist detected. Monitor does not indicate unsupported
Dec 01 14:46:04 tracey-aspiretc780 org_kde_powerdevil[730]: [ 730] Watching for DPMS state changes unimplemented
Dec 01 14:46:04 tracey-aspiretc780 backlighthelper[855]: org.kde.powerdevil: no kernel backlight interface found
Dec 01 14:46:04 tracey-aspiretc780 org_kde_powerdevil[730]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Dec 01 14:46:04 tracey-aspiretc780 org_kde_powerdevil[730]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Dec 01 14:46:09 tracey-aspiretc780 org_kde_powerdevil[730]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Dec 01 14:46:09 tracey-aspiretc780 org_kde_powerdevil[730]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Dec 01 14:46:10 tracey-aspiretc780 kconf_update[931]: kf.config.kconf_update: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
Dec 01 14:46:10 tracey-aspiretc780 kconf_update[931]: kf.config.kconf_update: /usr/share/kconf_update/filepicker.upd defined Version=5 but Version=6 was expected
Dec 01 14:46:11 tracey-aspiretc780 systemd[587]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@0.service: Failed with result 'exit-code'.
Dec 01 14:46:11 tracey-aspiretc780 kded6[670]: kf.bluezqt: PendingCall Error: "The name is not activatable"
Dec 01 14:46:13 tracey-aspiretc780 plasmashell[697]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:178:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth":
Dec 01 14:46:18 tracey-aspiretc780 plasmashell[697]: Toolbox not loading, toolbox package is either invalid or disabled.
Dec 01 14:46:22 tracey-aspiretc780 kernel: warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
Dec 01 14:46:22 tracey-aspiretc780 plasmashell[697]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/main.qml:310:13: QML Image: Cannot open: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/start-here-kde-symbolic
Dec 01 14:46:22 tracey-aspiretc780 plasmashell[697]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" 0x561d8d326350
Dec 01 14:46:22 tracey-aspiretc780 plasmashell[697]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" 0x561d8d326350
Dec 01 14:46:22 tracey-aspiretc780 kdeconnectd[913]: Error sending UDP packet: QAbstractSocket::NetworkError
Dec 01 14:46:25 tracey-aspiretc780 plasmashell[697]: org.kde.applets.brightness: D-Bus action "KeyboardBrightnessControl" is not available at service "org.kde.Solid.PowerManagement"
Dec 01 14:52:48 tracey-aspiretc780 kwin_x11[671]: kwin_core: XCB error: 152 (BadDamage), sequence: 19513, resource id: 20973543, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Dec 01 14:52:48 tracey-aspiretc780 kwin_x11[671]: kwin_core: XCB error: 3 (BadWindow), sequence: 19514, resource id: 4195540, major code: 129 (SHAPE), minor code: 6 (Input)
Dec 01 14:53:00 tracey-aspiretc780 systemd[587]: dbus-:1.2-org.kde.kwalletd6@0.service: Failed with result 'exit-code'.
Dec 01 14:53:00 tracey-aspiretc780 systemd[587]: dbus-:1.2-org.kde.kwalletd6@1.service: Failed with result 'exit-code'.
Dec 01 14:53:08 tracey-aspiretc780 systemd[587]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@1.service: Failed with result 'exit-code'.
Dec 01 14:53:08 tracey-aspiretc780 systemd[587]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@2.service: Failed with result 'exit-code'.
Dec 01 14:53:08 tracey-aspiretc780 xdg-desktop-por[638]: Backend call failed: Could not activate remote peer 'org.freedesktop.impl.portal.desktop.kwallet': unit failed
Dec 01 14:53:08 tracey-aspiretc780 systemd[587]: dbus-:1.2-org.kde.kwalletd6@2.service: Failed with result 'exit-code'.
Dec 01 15:16:24 tracey-aspiretc780 plasmashell[697]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
Dec 01 16:41:56 tracey-aspiretc780 plasmashell[697]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
Dec 01 16:41:57 tracey-aspiretc780 plasmashell[697]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
Dec 01 16:42:10 tracey-aspiretc780 kwin_x11[671]: kwin_core: XCB error: 152 (BadDamage), sequence: 19063, resource id: 20992647, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Dec 01 16:42:10 tracey-aspiretc780 kwin_x11[671]: kwin_core: XCB error: 3 (BadWindow), sequence: 19064, resource id: 54526004, major code: 129 (SHAPE), minor code: 6 (Input)
Mine were just examples, just to help track it down.
But since you already know, post all the logs right before it hangs. (I suggested it in reverse, probably up until you initiated the shutdown, since this is easier to grab.)
But only you can type the command properly. I was just trying to give you the tools.
Find the boot number in the list from:
Then put that number into this command:
Putting your negative number in place of -1.
Ok I will do that. I was looking at the log for this afternoon and I see the following, this is the last information before the failure to shut down, when the screen was black and the PC power button light was still on, then a hard reset to reboot as I couldn’t bring up a console:
I have to stop for this evening, thank you for your help and I’ll resume tomorrow.
Many thanks!
Greg
It’s a wade through the reeds, but the following Arch Wiki article does give everything needed to learn how to generate useful logs:
This is almost perfect! It’s getting right where we want, but I believe you are looking at priority 4. (Only seeing warning and more severe log messages.) Showing the logs this way, If something hangs, and doesn’t throw a an error, you won’t see it.
But maybe you can see it start (right before it hangs)..
emerg" (0), "alert" (1), "crit" (2), "err" (3), "warning" (4), "notice" (5), "info" (6), "debug" (7)
You can usually just take priority out, which may enough. Or use 7 or debug, but may overload you with useless messages.
I didn’t have a chance to look at this further yesterday. I might not get back to this issue until the weekend when I have more time but I will definitely do that and report back.
Hi, Ok I’m back today, I have a full log for Dec 1st. I hope!
The command I used was:
journalctl --boot=-7 --priority 7 --no-pager
Dec 01 14:45:54 tracey-aspiretc780 systemd[587]: Starting sandboxed app permission store...
Dec 01 14:45:54 tracey-aspiretc780 systemd[587]: Started sandboxed app permission store.
Dec 01 14:45:54 tracey-aspiretc780 systemd[587]: Starting flatpak document portal service...
Dec 01 14:45:54 tracey-aspiretc780 systemd[587]: Started flatpak document portal service.
Dec 01 14:45:54 tracey-aspiretc780 kcminit_startup[635]: Initializing "/usr/lib/qt6/plugins/plasma/kcms/systemsettings/kcm_fonts.so"
Dec 01 14:45:54 tracey-aspiretc780 kcminit_startup[635]: Initializing "/usr/lib/qt6/plugins/plasma/kcms/systemsettings/kcm_mouse.so"
Dec 01 14:45:54 tracey-aspiretc780 systemd[587]: Started KDE Config Module Initialization.
Dec 01 14:45:54 tracey-aspiretc780 systemd[587]: Starting KDE Session Management Server...
Dec 01 14:45:54 tracey-aspiretc780 systemd[587]: Started Unlock kwallet from pam credentials.
Dec 01 14:45:54 tracey-aspiretc780 systemd[587]: Starting KDE Daemon 6...
Dec 01 14:45:54 tracey-aspiretc780 systemd[587]: Starting KDE Window Manager...
Dec 01 14:45:54 tracey-aspiretc780 systemd[1]: Starting RealtimeKit Scheduling Policy Service...
Dec 01 14:45:55 tracey-aspiretc780 systemd[1]: Started RealtimeKit Scheduling Policy Service.
Dec 01 14:45:55 tracey-aspiretc780 rtkit-daemon[676]: Successfully called chroot.
Dec 01 14:45:55 tracey-aspiretc780 rtkit-daemon[676]: Successfully dropped privileges.
Dec 01 14:45:55 tracey-aspiretc780 rtkit-daemon[676]: Successfully limited resources.
Dec 01 14:45:55 tracey-aspiretc780 rtkit-daemon[676]: Canary thread running.
Dec 01 14:45:55 tracey-aspiretc780 rtkit-daemon[676]: Watchdog thread running.
Dec 01 14:45:55 tracey-aspiretc780 rtkit-daemon[676]: Running.
Dec 01 14:45:55 tracey-aspiretc780 rtkit-daemon[676]: Supervising 0 threads of 0 processes of 0 users.
Dec 01 14:45:55 tracey-aspiretc780 systemd[587]: Started KDE Session Management Server.
Dec 01 14:45:55 tracey-aspiretc780 systemd[587]: Starting KDE Plasma Workspace...
Dec 01 14:45:56 tracey-aspiretc780 systemd[587]: Started KDE Daemon 6.
Dec 01 14:45:56 tracey-aspiretc780 systemd[587]: Starting KDE Configuration Module Initialization (Phase 1)...
Dec 01 14:45:56 tracey-aspiretc780 systemd[587]: Starting KActivityManager Activity manager Service...
Dec 01 14:45:56 tracey-aspiretc780 kcminit_startup[635]: Initializing "/usr/lib/qt6/plugins/plasma/kcms/systemsettings_qwidgets/kcm_kgamma.so"
Dec 01 14:45:56 tracey-aspiretc780 kcminit_startup[635]: Initializing "/usr/lib/qt6/plugins/plasma/kcms/systemsettings/kcm_touchpad.so"
Dec 01 14:45:56 tracey-aspiretc780 kcminit_startup[635]: kcm_touchpad: Using X11 backend
Dec 01 14:45:56 tracey-aspiretc780 systemd[587]: Finished KDE Configuration Module Initialization (Phase 1).
Dec 01 14:45:57 tracey-aspiretc780 systemd[587]: Started KActivityManager Activity manager Service.
Dec 01 14:45:58 tracey-aspiretc780 systemd[587]: Started KDE Window Manager.
Dec 01 14:45:58 tracey-aspiretc780 systemd[587]: Started PipeWire Multimedia Service.
Dec 01 14:45:58 tracey-aspiretc780 systemd[587]: Started Multimedia Service Session Manager.
Dec 01 14:45:58 tracey-aspiretc780 systemd[587]: Started PipeWire PulseAudio.
Dec 01 14:45:58 tracey-aspiretc780 systemd[587]: Started KDE Plasma Workspace.
Dec 01 14:45:58 tracey-aspiretc780 systemd[587]: Reached target KDE Plasma Workspace Core.
Dec 01 14:45:58 tracey-aspiretc780 systemd[587]: Started Proxies GTK DBus menus to a Plasma readable format.
Dec 01 14:45:58 tracey-aspiretc780 systemd[587]: Started KAccess.
Dec 01 14:45:58 tracey-aspiretc780 systemd[587]: Starting KDE PolicyKit Authentication Agent...
Dec 01 14:45:58 tracey-aspiretc780 systemd[587]: Starting Powerdevil...
Dec 01 14:45:58 tracey-aspiretc780 systemd[587]: Starting Xdg Desktop Portal For KDE...
Dec 01 14:45:58 tracey-aspiretc780 systemd[587]: Started Handle legacy xembed system tray icons.
Dec 01 14:45:58 tracey-aspiretc780 kaccess[728]: Xlib XKB extension major= 1 minor= 0
Dec 01 14:45:58 tracey-aspiretc780 kaccess[728]: X server XKB extension major= 1 minor= 0
Dec 01 14:45:59 tracey-aspiretc780 systemd[587]: Starting User preferences database...
Dec 01 14:45:59 tracey-aspiretc780 systemd[587]: Started KDE PolicyKit Authentication Agent.
Dec 01 14:45:59 tracey-aspiretc780 polkit-kde-authentication-agent-1[729]: New PolkitAgentListener 0x55c6c80952a0
Dec 01 14:45:59 tracey-aspiretc780 polkit-kde-authentication-agent-1[729]: Adding new listener PolkitQt1::Agent::Listener(0x55c6c8080fc0) for 0x55c6c80952a0
Dec 01 14:45:59 tracey-aspiretc780 polkit-kde-authentication-agent-1[729]: Listener online
Dec 01 14:45:59 tracey-aspiretc780 polkitd[482]: Registered Authentication Agent for unix-session:1 (system bus name :1.24 [/usr/lib/polkit-kde-authentication-agent-1], object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_CA.UTF-8)
Dec 01 14:45:59 tracey-aspiretc780 polkit-kde-authentication-agent-1[729]: Authentication agent result: true
Dec 01 14:45:59 tracey-aspiretc780 systemd[587]: Started User preferences database.
Dec 01 14:45:59 tracey-aspiretc780 systemd[587]: Started Xdg Desktop Portal For KDE.
Dec 01 14:45:59 tracey-aspiretc780 rtkit-daemon[676]: Supervising 0 threads of 0 processes of 0 users.
Dec 01 14:45:59 tracey-aspiretc780 org_kde_powerdevil[730]: Starting libddcutil. library built Not set at Not set. stdout_stderr_redirected=true
Dec 01 14:46:01 tracey-aspiretc780 rtkit-daemon[676]: Successfully made thread 726 of process 726 owned by '1000' high priority at nice level -11.
Dec 01 14:46:01 tracey-aspiretc780 rtkit-daemon[676]: Supervising 1 threads of 1 processes of 1 users.
Dec 01 14:46:01 tracey-aspiretc780 rtkit-daemon[676]: Successfully made thread 724 of process 724 owned by '1000' high priority at nice level -11.
Dec 01 14:46:01 tracey-aspiretc780 rtkit-daemon[676]: Supervising 2 threads of 2 processes of 1 users.
Dec 01 14:46:01 tracey-aspiretc780 rtkit-daemon[676]: Successfully made thread 725 of process 725 owned by '1000' high priority at nice level -11.
Dec 01 14:46:01 tracey-aspiretc780 rtkit-daemon[676]: Supervising 3 threads of 3 processes of 1 users.
Dec 01 14:46:01 tracey-aspiretc780 rtkit-daemon[676]: Successfully made thread 776 of process 724 owned by '1000' RT at priority 20.
Dec 01 14:46:01 tracey-aspiretc780 rtkit-daemon[676]: Supervising 4 threads of 3 processes of 1 users.
Dec 01 14:46:01 tracey-aspiretc780 rtkit-daemon[676]: Successfully made thread 780 of process 726 owned by '1000' RT at priority 20.
Dec 01 14:46:01 tracey-aspiretc780 rtkit-daemon[676]: Supervising 5 threads of 3 processes of 1 users.
Dec 01 14:46:01 tracey-aspiretc780 rtkit-daemon[676]: Successfully made thread 786 of process 725 owned by '1000' RT at priority 20.
Dec 01 14:46:01 tracey-aspiretc780 rtkit-daemon[676]: Supervising 6 threads of 3 processes of 1 users.
Dec 01 14:46:01 tracey-aspiretc780 kded6[670]: kcm_touchpad: Using X11 backend
Dec 01 14:46:01 tracey-aspiretc780 kded6[670]: org.kde.bolt.kded: Couldn't connect to Bolt DBus daemon
Dec 01 14:46:01 tracey-aspiretc780 systemd[1]: Starting Daemon for power management...
Dec 01 14:46:02 tracey-aspiretc780 kded6[670]: org.kde.kameleon: found no RGB LED devices
Dec 01 14:46:03 tracey-aspiretc780 systemd[1]: Started Daemon for power management.
Dec 01 14:46:03 tracey-aspiretc780 org_kde_powerdevil[730]: Initializing libddcutil. ddcutil version: 2.2.1, shared library: /usr/lib/libddcutil.so.5.3.0
Dec 01 14:46:03 tracey-aspiretc780 org_kde_powerdevil[730]: [ 730] Options passed from client:
Dec 01 14:46:03 tracey-aspiretc780 org_kde_powerdevil[730]: [ 730] Applying combined libddcutil options:
Dec 01 14:46:04 tracey-aspiretc780 org_kde_powerdevil[730]: Library initialization complete.
Dec 01 14:46:04 tracey-aspiretc780 org_kde_powerdevil[730]: Watching for DPMS state changes unimplemented
Dec 01 14:46:04 tracey-aspiretc780 org_kde_powerdevil[730]: [ 730] Watching for display connection changes, resolved watch mode = Watch_Mode_Xevent, poll loop interval = 100 millisec
Dec 01 14:46:04 tracey-aspiretc780 org_kde_powerdevil[730]: [ 730] extra_stabilization_millisec: 0, stabilization_poll_millisec: 100
Dec 01 14:46:04 tracey-aspiretc780 org_kde_powerdevil[730]: [ 730] libddcutil recheck thread 0x55a88abdf690 started
Dec 01 14:46:04 tracey-aspiretc780 org_kde_powerdevil[730]: [ 730] libddcutil watch thread 0x55a88abc0680 started
Dec 01 14:46:04 tracey-aspiretc780 org_kde_powerdevil[730]: [ 840] (dw_recheck_displays_func) Recheck interval: Sleeping for 200 milliseconds
Dec 01 14:46:04 tracey-aspiretc780 systemd[1]: Created slice Slice /system/dbus-:1.2-org.kde.powerdevil.discretegpuhelper.
Dec 01 14:46:04 tracey-aspiretc780 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.discretegpuhelper@0.service.
Dec 01 14:46:04 tracey-aspiretc780 systemd[1]: Created slice Slice /system/dbus-:1.2-org.kde.powerdevil.chargethresholdhelper.
Dec 01 14:46:04 tracey-aspiretc780 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.chargethresholdhelper@0.service.
Dec 01 14:46:04 tracey-aspiretc780 systemd[1]: Created slice Slice /system/dbus-:1.2-org.kde.powerdevil.backlighthelper.
Dec 01 14:46:04 tracey-aspiretc780 systemd[1]: Started dbus-:1.2-org.kde.powerdevil.backlighthelper@0.service.
Dec 01 14:46:04 tracey-aspiretc780 systemd[587]: Starting KScreen...
Dec 01 14:46:05 tracey-aspiretc780 systemd[587]: Started KScreen.
Dec 01 14:46:05 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xrandr: Connected output 65 to CRTC 62
Dec 01 14:46:05 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xcb.helper: Detected XRandR 1.6
Dec 01 14:46:05 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xcb.helper: Event Base: 89
Dec 01 14:46:05 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xcb.helper: Event Error: 147
Dec 01 14:46:05 tracey-aspiretc780 systemd-timesyncd[343]: Contacted time server 137.220.55.211:123 (2.manjaro.pool.ntp.org).
Dec 01 14:46:05 tracey-aspiretc780 systemd-timesyncd[343]: Initial clock synchronization to Mon 2025-12-01 14:46:05.967598 AST.
Dec 01 14:46:05 tracey-aspiretc780 systemd[1]: Starting Power Profiles daemon...
Dec 01 14:46:06 tracey-aspiretc780 systemd[1]: Starting Disk Manager...
Dec 01 14:46:06 tracey-aspiretc780 systemd[1]: Started Power Profiles daemon.
Dec 01 14:46:06 tracey-aspiretc780 rtkit-daemon[676]: Supervising 6 threads of 3 processes of 1 users.
Dec 01 14:46:06 tracey-aspiretc780 systemd[587]: Created slice Slice /app/dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet.
Dec 01 14:46:06 tracey-aspiretc780 systemd[587]: Started dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@0.service.
Dec 01 14:46:07 tracey-aspiretc780 udisksd[869]: udisks daemon version 2.10.2 starting
Dec 01 14:46:07 tracey-aspiretc780 systemd[1]: systemd-hostnamed.service: Deactivated successfully.
Dec 01 14:46:09 tracey-aspiretc780 NetworkManager[479]: <info> [1764614769.0072] agent-manager: agent[b5325cf38166a1ff,:1.23/org.kde.plasma.networkmanagement/1000]: agent registered
Dec 01 14:46:09 tracey-aspiretc780 kded6[670]: org.kde.colorcorrectlocationupdater: Geolocator stopped
Dec 01 14:46:09 tracey-aspiretc780 systemd[1]: Started Disk Manager.
Dec 01 14:46:09 tracey-aspiretc780 udisksd[869]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Dec 01 14:46:09 tracey-aspiretc780 systemd[587]: Started Powerdevil.
Dec 01 14:46:09 tracey-aspiretc780 systemd[587]: Reached target KDE Plasma Workspace.
Dec 01 14:46:09 tracey-aspiretc780 systemd[587]: Reached target Current graphical user session.
Dec 01 14:46:09 tracey-aspiretc780 systemd[587]: Reached target plasma-workspace-x11.target.
Dec 01 14:46:09 tracey-aspiretc780 systemd[587]: Starting AT-SPI D-Bus Bus...
Dec 01 14:46:09 tracey-aspiretc780 systemd[587]: Starting MSM Notifier...
Dec 01 14:46:09 tracey-aspiretc780 systemd[587]: Starting KDE Connect...
Dec 01 14:46:09 tracey-aspiretc780 systemd[587]: Starting Plasma Session Restore...
Dec 01 14:46:09 tracey-aspiretc780 systemd[587]: Starting Update Notifier...
Dec 01 14:46:09 tracey-aspiretc780 systemd[587]: Starting Update Notifier Tray Icon...
Dec 01 14:46:09 tracey-aspiretc780 systemd[587]: Starting Print Queue Applet...
Dec 01 14:46:09 tracey-aspiretc780 systemd[587]: Starting xapp-sn-watcher...
Dec 01 14:46:09 tracey-aspiretc780 systemd[587]: Starting KSplash "ready" Stage...
Dec 01 14:46:09 tracey-aspiretc780 systemd[587]: Starting KDE Session Restoration...
Dec 01 14:46:09 tracey-aspiretc780 systemd[587]: Finished KDE Session Restoration.
Dec 01 14:46:09 tracey-aspiretc780 systemd[587]: app-pamac\x2dtray@autostart.service: Skipped due to 'exec-condition'.
Dec 01 14:46:09 tracey-aspiretc780 systemd[587]: Condition check resulted in Update Notifier being skipped.
Dec 01 14:46:09 tracey-aspiretc780 systemd[587]: app-at\x2dspi\x2ddbus\x2dbus@autostart.service: Skipped due to 'exec-condition'.
Dec 01 14:46:09 tracey-aspiretc780 systemd[587]: Condition check resulted in AT-SPI D-Bus Bus being skipped.
Dec 01 14:46:10 tracey-aspiretc780 systemd[587]: app-pamac\x2dtray\x2dbudgie@autostart.service: Skipped due to 'exec-condition'.
Dec 01 14:46:10 tracey-aspiretc780 systemd[587]: Condition check resulted in Update Notifier being skipped.
Dec 01 14:46:10 tracey-aspiretc780 systemd[587]: app-print\x2dapplet@autostart.service: Skipped due to 'exec-condition'.
Dec 01 14:46:10 tracey-aspiretc780 systemd[587]: Condition check resulted in Print Queue Applet being skipped.
Dec 01 14:46:10 tracey-aspiretc780 systemd[587]: Started Plasma Session Restore.
Dec 01 14:46:10 tracey-aspiretc780 systemd[587]: Finished KSplash "ready" Stage.
Dec 01 14:46:10 tracey-aspiretc780 systemd[587]: Started xapp-sn-watcher.
Dec 01 14:46:10 tracey-aspiretc780 systemd[587]: Started KDE Connect.
Dec 01 14:46:10 tracey-aspiretc780 kernel: Bluetooth: RFCOMM TTY layer initialized
Dec 01 14:46:10 tracey-aspiretc780 kernel: Bluetooth: RFCOMM socket layer initialized
Dec 01 14:46:10 tracey-aspiretc780 kernel: Bluetooth: RFCOMM ver 1.11
Dec 01 14:46:10 tracey-aspiretc780 systemd[587]: Started MSM Notifier.
Dec 01 14:46:10 tracey-aspiretc780 systemd[587]: Started Update Notifier Tray Icon.
Dec 01 14:46:10 tracey-aspiretc780 systemd[587]: Reached target Startup of XDG autostart applications.
Dec 01 14:46:10 tracey-aspiretc780 bluetoothd[481]: Endpoint registered: sender=:1.47 path=/MediaEndpoint/A2DPSource/ldac
Dec 01 14:46:10 tracey-aspiretc780 bluetoothd[481]: Endpoint registered: sender=:1.47 path=/MediaEndpoint/A2DPSink/aptx_hd
Dec 01 14:46:10 tracey-aspiretc780 bluetoothd[481]: Endpoint registered: sender=:1.47 path=/MediaEndpoint/A2DPSource/aptx_hd
Dec 01 14:46:10 tracey-aspiretc780 bluetoothd[481]: Endpoint registered: sender=:1.47 path=/MediaEndpoint/A2DPSink/aac
Dec 01 14:46:10 tracey-aspiretc780 bluetoothd[481]: Endpoint registered: sender=:1.47 path=/MediaEndpoint/A2DPSource/aac
Dec 01 14:46:10 tracey-aspiretc780 bluetoothd[481]: Endpoint registered: sender=:1.47 path=/MediaEndpoint/A2DPSink/opus_g
Dec 01 14:46:10 tracey-aspiretc780 bluetoothd[481]: Endpoint registered: sender=:1.47 path=/MediaEndpoint/A2DPSource/opus_g
Dec 01 14:46:10 tracey-aspiretc780 bluetoothd[481]: Endpoint registered: sender=:1.47 path=/MediaEndpoint/A2DPSink/sbc
Dec 01 14:46:10 tracey-aspiretc780 bluetoothd[481]: Endpoint registered: sender=:1.47 path=/MediaEndpoint/A2DPSource/sbc
Dec 01 14:46:10 tracey-aspiretc780 bluetoothd[481]: Endpoint registered: sender=:1.47 path=/MediaEndpoint/A2DPSource/aptx_ll_1
Dec 01 14:46:10 tracey-aspiretc780 bluetoothd[481]: Endpoint registered: sender=:1.47 path=/MediaEndpoint/A2DPSource/aptx_ll_0
Dec 01 14:46:10 tracey-aspiretc780 bluetoothd[481]: Endpoint registered: sender=:1.47 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
Dec 01 14:46:10 tracey-aspiretc780 bluetoothd[481]: Endpoint registered: sender=:1.47 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
Dec 01 14:46:10 tracey-aspiretc780 bluetoothd[481]: Endpoint registered: sender=:1.47 path=/MediaEndpoint/A2DPSource/faststream
Dec 01 14:46:10 tracey-aspiretc780 bluetoothd[481]: Endpoint registered: sender=:1.47 path=/MediaEndpoint/A2DPSource/faststream_duplex
Dec 01 14:46:10 tracey-aspiretc780 bluetoothd[481]: Endpoint registered: sender=:1.47 path=/MediaEndpoint/A2DPSink/opus_05
Dec 01 14:46:10 tracey-aspiretc780 bluetoothd[481]: Endpoint registered: sender=:1.47 path=/MediaEndpoint/A2DPSource/opus_05
Dec 01 14:46:10 tracey-aspiretc780 bluetoothd[481]: Endpoint registered: sender=:1.47 path=/MediaEndpoint/A2DPSink/opus_05_duplex
Dec 01 14:46:10 tracey-aspiretc780 bluetoothd[481]: Endpoint registered: sender=:1.47 path=/MediaEndpoint/A2DPSource/opus_05_duplex
Dec 01 14:46:11 tracey-aspiretc780 systemd[587]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@0.service: Main process exited, code=exited, status=255/EXCEPTION
Dec 01 14:46:11 tracey-aspiretc780 systemd[587]: Started Portal service.
Dec 01 14:46:11 tracey-aspiretc780 wireplumber[725]: wp-device: SPA handle 'api.libcamera.enum.manager' could not be loaded; is it installed?
Dec 01 14:46:11 tracey-aspiretc780 wireplumber[725]: s-monitors-libcamera: PipeWire's libcamera SPA plugin is missing or broken. Some camera types may not be supported.
Dec 01 14:46:11 tracey-aspiretc780 kded6[969]: xsettingsd: Loaded 14 settings from /home/tracey/.config/xsettingsd/xsettingsd.conf
Dec 01 14:46:11 tracey-aspiretc780 kded6[969]: xsettingsd: Created window 0x3000001 on screen 0 with timestamp 53272
Dec 01 14:46:11 tracey-aspiretc780 kded6[969]: xsettingsd: Selection _XSETTINGS_S0 is owned by 0x0
Dec 01 14:46:11 tracey-aspiretc780 kded6[969]: xsettingsd: Took ownership of selection _XSETTINGS_S0
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xrandr: XRandR::setConfig
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xrandr: Requested screen size is QSize(1920, 1080)
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xrandr: Needed CRTCs: 1
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xrandr: Actions to perform:
Priorities: true
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xrandr: Output 65
Old: "0"
New: "1"
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xrandr: Change Screen Size: false
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xrandr: Disable outputs: false
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xrandr: Change outputs: false
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xrandr: Enable outputs: false
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xrandr: RRSetOutputPrimary
New priority: 0
New priority: 1
New priority: 0
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xrandr: XRandR::setConfig done!
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xcb.helper: RRNotify_OutputProperty (ignored)
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xcb.helper: Timestamp: 53366
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xcb.helper: Output: 65
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xcb.helper: Property: "_KDE_SCREEN_INDEX"
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xcb.helper: State (newValue, Deleted): 0
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xcb.helper: RRNotify_OutputChange
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xcb.helper: Timestamp: 24558
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xcb.helper: Output: 64
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xcb.helper: CRTC: 0
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xcb.helper: Mode: 0
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xcb.helper: Rotation: "Rotate_0"
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xcb.helper: Connection: "Disconnected"
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xcb.helper: Subpixel Order: 0
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xcb.helper: CRTC: 62
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xcb.helper: Mode: 68
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xcb.helper: Connection: "Connected"
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xcb.helper: RRScreenChangeNotify
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xcb.helper: Config_timestamp: 24558
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xcb.helper: Window: 41943046
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xcb.helper: Root: 1188
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xcb.helper: Size ID: 0
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xcb.helper: Size: 1920 1080
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xcb.helper: SizeMM: 508 285
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xrandr: XRandROutput 64 update
m_connected: 1
m_crtc QObject(0x0)
CRTC: 0
MODE: 0
Connection: 1
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xrandr: Output 64 : connected = false , enabled = false
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xrandr: XRandROutput 65 update
m_connected: 0
m_crtc XRandRCrtc(0x55fa04ac3e50)
CRTC: 62
MODE: 68
Connection: 0
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xrandr: Output 65 : connected = true , enabled = true
m_connected: 1
m_crtc QObject(0x0)
CRTC: 0
MODE: 0
Connection: 1
m_connected: 0
CRTC: 62
MODE: 68
Connection: 0
Dec 01 14:46:11 tracey-aspiretc780 kscreen_backend_launcher[856]: kscreen.xrandr: Emitting configChanged()
Dec 01 14:46:11 tracey-aspiretc780 kded6[670]: Registering ":1.44/StatusNotifierItem" to system tray
Dec 01 14:46:11 tracey-aspiretc780 pamac-tray-plas[938]: updates_checker.vala:59: check updates
Dec 01 14:46:13 tracey-aspiretc780 plasmashell[697]: kf.plasma.quick: Applet preload policy set to 1
Dec 01 14:46:15 tracey-aspiretc780 systemd[1]: dbus-:1.2-org.kde.powerdevil.discretegpuhelper@0.service: Deactivated successfully.
Dec 01 14:46:15 tracey-aspiretc780 systemd[1]: dbus-:1.2-org.kde.powerdevil.backlighthelper@0.service: Deactivated successfully.
Dec 01 14:46:19 tracey-aspiretc780 systemd[1]: Starting Pamac Daemon...
Dec 01 14:46:20 tracey-aspiretc780 systemd[1]: dbus-:1.2-org.kde.powerdevil.chargethresholdhelper@0.service: Deactivated successfully.
Dec 01 14:46:20 tracey-aspiretc780 systemd[1]: Started Pamac Daemon.
Dec 01 14:46:20 tracey-aspiretc780 kded6[670]: Registering ":1.48/StatusNotifierItem" to system tray
Dec 01 14:46:22 tracey-aspiretc780 systemd[587]: Created slice Slice /app/dbus-:1.2-org.freedesktop.Notifications.
Dec 01 14:46:22 tracey-aspiretc780 systemd[587]: Started dbus-:1.2-org.freedesktop.Notifications@0.service.
Dec 01 14:46:24 tracey-aspiretc780 systemd[1]: pamac-daemon.service: Deactivated successfully.
Dec 01 14:49:23 tracey-aspiretc780 systemd[587]: Started Konsole - Terminal.
Dec 01 14:49:25 tracey-aspiretc780 systemd[587]: Started app-org.kde.konsole-1056.scope.
Dec 01 14:52:29 tracey-aspiretc780 NetworkManager[479]: <info> [1764615149.0658] device (wlp2s0): set-hw-addr: set MAC address to F2:1A:0E:F8:32:5A (scanning)
Dec 01 14:52:29 tracey-aspiretc780 NetworkManager[479]: <info> [1764615149.0689] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 01 14:52:29 tracey-aspiretc780 NetworkManager[479]: <info> [1764615149.0689] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 01 14:52:54 tracey-aspiretc780 systemd[587]: Started Chromium - Web Browser.
Dec 01 14:52:59 tracey-aspiretc780 systemd[587]: Created slice Slice /app/dbus-:1.2-org.kde.kwalletd6.
Dec 01 14:52:59 tracey-aspiretc780 systemd[587]: Started dbus-:1.2-org.kde.kwalletd6@0.service.
Dec 01 14:53:00 tracey-aspiretc780 systemd[587]: dbus-:1.2-org.kde.kwalletd6@0.service: Main process exited, code=exited, status=255/EXCEPTION
Dec 01 14:53:00 tracey-aspiretc780 chromium[1274]: [1274:1274:1201/145300.129699:ERROR:dbus/object_proxy.cc:573] Failed to call method: org.kde.KWallet.isEnabled: object_path= /modules/kwalletd6: org.freedesktop.DBus.Error.NameHasNoOwner: Could not activate remote peer 'org.kde.kwalletd6': unit failed
Dec 01 14:53:00 tracey-aspiretc780 chromium[1274]: [1274:1274:1201/145300.129750:ERROR:components/os_crypt/sync/kwallet_dbus.cc:113] Error contacting kwalletd6 (isEnabled)
Dec 01 14:53:00 tracey-aspiretc780 chromium[1274]: [1274:1274:1201/145300.129884:ERROR:dbus/object_proxy.cc:573] Failed to call method: org.kde.KLauncher.start_service_by_desktop_name: object_path= /KLauncher: org.freedesktop.DBus.Error.ServiceUnknown: The name is not activatable
Dec 01 14:53:00 tracey-aspiretc780 chromium[1274]: [1274:1274:1201/145300.129892:ERROR:components/os_crypt/sync/kwallet_dbus.cc:82] Error contacting klauncher to start kwalletd6
Dec 01 14:53:00 tracey-aspiretc780 systemd[587]: Started dbus-:1.2-org.kde.kwalletd6@1.service.
Dec 01 14:53:00 tracey-aspiretc780 systemd[587]: dbus-:1.2-org.kde.kwalletd6@1.service: Main process exited, code=exited, status=255/EXCEPTION
Dec 01 14:53:00 tracey-aspiretc780 chromium[1274]: [1274:1274:1201/145300.352268:ERROR:dbus/object_proxy.cc:573] Failed to call method: org.kde.KWallet.close: object_path= /modules/kwalletd6: org.freedesktop.DBus.Error.NameHasNoOwner: Could not activate remote peer 'org.kde.kwalletd6': unit failed
Dec 01 14:53:00 tracey-aspiretc780 chromium[1274]: [1274:1274:1201/145300.352284:ERROR:components/os_crypt/sync/kwallet_dbus.cc:408] Error contacting kwalletd6 (close)
Dec 01 14:53:04 tracey-aspiretc780 systemd[587]: Starting Accessibility services bus...
Dec 01 14:53:04 tracey-aspiretc780 systemd[587]: Started Accessibility services bus.
Dec 01 14:53:05 tracey-aspiretc780 dbus-broker-launch[1384]: Ready
Dec 01 14:53:05 tracey-aspiretc780 systemd[587]: Created slice Slice /app/dbus-:1.59-org.a11y.atspi.Registry.
Dec 01 14:53:05 tracey-aspiretc780 systemd[587]: Started dbus-:1.59-org.a11y.atspi.Registry@0.service.
Dec 01 14:53:05 tracey-aspiretc780 at-spi2-registryd[1386]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Dec 01 14:53:07 tracey-aspiretc780 systemd[587]: Started app-org.chromium.Chromium-1274.scope.
Dec 01 14:53:08 tracey-aspiretc780 systemd[587]: Started dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@1.service.
Dec 01 14:53:08 tracey-aspiretc780 systemd[587]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@1.service: Main process exited, code=exited, status=255/EXCEPTION
Dec 01 14:53:08 tracey-aspiretc780 systemd[587]: Started dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@2.service.
Dec 01 14:53:08 tracey-aspiretc780 systemd[587]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@2.service: Main process exited, code=exited, status=255/EXCEPTION
Dec 01 14:53:08 tracey-aspiretc780 chromium[1274]: [1274:1274:1201/145308.707584:ERROR:components/dbus/xdg/request.cc:164] Request ended (non-user cancelled).
Dec 01 14:53:08 tracey-aspiretc780 systemd[587]: Started dbus-:1.2-org.kde.kwalletd6@2.service.
Dec 01 14:53:08 tracey-aspiretc780 systemd[587]: dbus-:1.2-org.kde.kwalletd6@2.service: Main process exited, code=exited, status=255/EXCEPTION
Dec 01 14:53:14 tracey-aspiretc780 chromium[1274]: [1274:1295:1201/145314.100743:ERROR:google_apis/gcm/engine/registration_request.cc:292] Registration response error message: DEPRECATED_ENDPOINT
Dec 01 14:53:34 tracey-aspiretc780 chrome[1274]: [1274:1292:1201/145334.362200:INFO:chrome/browser/extensions/extension_garbage_collector.cc:188] Garbage collection for extensions on file thread is complete.
Dec 01 14:53:39 tracey-aspiretc780 chromium[1274]: [1274:1295:1201/145339.118021:ERROR:google_apis/gcm/engine/registration_request.cc:292] Registration response error message: DEPRECATED_ENDPOINT
Dec 01 14:54:34 tracey-aspiretc780 chromium[1274]: [1274:1295:1201/145434.944442:ERROR:google_apis/gcm/engine/registration_request.cc:292] Registration response error message: DEPRECATED_ENDPOINT
Dec 01 14:56:29 tracey-aspiretc780 chromium[1274]: [1274:1295:1201/145629.026129:ERROR:google_apis/gcm/engine/registration_request.cc:292] Registration response error message: DEPRECATED_ENDPOINT
Dec 01 14:59:20 tracey-aspiretc780 NetworkManager[479]: <info> [1764615560.0598] device (wlp2s0): set-hw-addr: set MAC address to BA:38:8D:8F:B9:67 (scanning)
Dec 01 14:59:20 tracey-aspiretc780 NetworkManager[479]: <info> [1764615560.0848] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 01 14:59:20 tracey-aspiretc780 NetworkManager[479]: <info> [1764615560.0849] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 01 14:59:20 tracey-aspiretc780 NetworkManager[479]: <info> [1764615560.0905] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 01 14:59:20 tracey-aspiretc780 NetworkManager[479]: <info> [1764615560.0906] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 01 15:00:17 tracey-aspiretc780 chromium[1274]: [1274:1295:1201/150017.926638:ERROR:google_apis/gcm/engine/registration_request.cc:292] Registration response error message: DEPRECATED_ENDPOINT
Dec 01 15:00:53 tracey-aspiretc780 systemd[1]: Starting Cleanup of Temporary Directories...
Dec 01 15:00:54 tracey-aspiretc780 systemd[1]: systemd-tmpfiles-clean.service: Deactivated successfully.
Dec 01 15:00:54 tracey-aspiretc780 systemd[1]: Finished Cleanup of Temporary Directories.
Dec 01 15:01:00 tracey-aspiretc780 CROND[1788]: (root) CMD (run-parts /etc/cron.hourly)
Dec 01 15:01:00 tracey-aspiretc780 CROND[1787]: (root) CMDEND (run-parts /etc/cron.hourly)
Dec 01 15:06:13 tracey-aspiretc780 NetworkManager[479]: <info> [1764615973.0597] device (wlp2s0): set-hw-addr: set MAC address to A2:8F:62:C6:26:FB (scanning)
Dec 01 15:06:13 tracey-aspiretc780 NetworkManager[479]: <info> [1764615973.0809] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 01 15:06:13 tracey-aspiretc780 NetworkManager[479]: <info> [1764615973.0809] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 01 15:06:13 tracey-aspiretc780 NetworkManager[479]: <info> [1764615973.0861] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 01 15:06:13 tracey-aspiretc780 NetworkManager[479]: <info> [1764615973.0861] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 01 15:07:34 tracey-aspiretc780 chromium[1274]: [1274:1295:1201/150734.859650:ERROR:google_apis/gcm/engine/registration_request.cc:292] Registration response error message: DEPRECATED_ENDPOINT
Dec 01 15:13:06 tracey-aspiretc780 NetworkManager[479]: <info> [1764616386.0730] device (wlp2s0): set-hw-addr: set MAC address to 76:40:36:D4:68:ED (scanning)
Dec 01 15:13:06 tracey-aspiretc780 NetworkManager[479]: <info> [1764616386.0978] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 01 15:13:06 tracey-aspiretc780 NetworkManager[479]: <info> [1764616386.0979] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 01 15:13:06 tracey-aspiretc780 NetworkManager[479]: <info> [1764616386.1035] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 01 15:13:06 tracey-aspiretc780 NetworkManager[479]: <info> [1764616386.1036] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 01 15:19:57 tracey-aspiretc780 NetworkManager[479]: <info> [1764616797.0630] device (wlp2s0): set-hw-addr: set MAC address to E2:DD:49:FB:69:8F (scanning)
Dec 01 15:19:57 tracey-aspiretc780 NetworkManager[479]: <info> [1764616797.0979] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 01 15:19:57 tracey-aspiretc780 NetworkManager[479]: <info> [1764616797.0980] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 01 15:19:57 tracey-aspiretc780 NetworkManager[479]: <info> [1764616797.1035] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 01 15:19:57 tracey-aspiretc780 NetworkManager[479]: <info> [1764616797.1036] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 01 15:26:48 tracey-aspiretc780 NetworkManager[479]: <info> [1764617208.0695] device (wlp2s0): set-hw-addr: set MAC address to BA:29:03:6E:A5:90 (scanning)
Dec 01 15:26:48 tracey-aspiretc780 NetworkManager[479]: <info> [1764617208.0945] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 01 15:26:48 tracey-aspiretc780 NetworkManager[479]: <info> [1764617208.0946] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 01 15:26:48 tracey-aspiretc780 NetworkManager[479]: <info> [1764617208.1001] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 01 15:26:48 tracey-aspiretc780 NetworkManager[479]: <info> [1764617208.1001] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 01 15:33:15 tracey-aspiretc780 systemd[587]: app-org.kde.konsole@98d6e737b9d94c80a39a6dfe6b646962.service: Consumed 3.095s CPU time, 98.8M memory peak.
Dec 01 15:33:15 tracey-aspiretc780 systemd[587]: app-org.kde.konsole-1056.scope: Consumed 13.333s CPU time, 20.3M memory peak.
Dec 01 15:33:22 tracey-aspiretc780 systemd[587]: Started Konsole - Terminal.
Dec 01 15:33:22 tracey-aspiretc780 systemd[587]: Started app-org.kde.konsole-2162.scope.
Dec 01 15:33:39 tracey-aspiretc780 NetworkManager[479]: <info> [1764617619.0694] device (wlp2s0): set-hw-addr: set MAC address to 36:C3:F0:B3:88:E0 (scanning)
Dec 01 15:33:39 tracey-aspiretc780 NetworkManager[479]: <info> [1764617619.1012] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 01 15:33:39 tracey-aspiretc780 NetworkManager[479]: <info> [1764617619.1012] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 01 15:33:39 tracey-aspiretc780 NetworkManager[479]: <info> [1764617619.1064] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 01 15:33:39 tracey-aspiretc780 NetworkManager[479]: <info> [1764617619.1065] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 01 15:36:49 tracey-aspiretc780 systemd[587]: app-org.kde.konsole@555830cafc7545789685db46dfc8bb5f.service: Consumed 1.683s CPU time, 362.1M memory peak.
Dec 01 15:36:49 tracey-aspiretc780 systemd[587]: app-org.kde.konsole-2162.scope: Consumed 7.204s CPU time, 8.4M memory peak.
Dec 01 15:36:51 tracey-aspiretc780 systemd[587]: Started Konsole - Terminal.
Dec 01 15:36:52 tracey-aspiretc780 systemd[587]: Started app-org.kde.konsole-2284.scope.
Dec 01 15:40:31 tracey-aspiretc780 NetworkManager[479]: <info> [1764618031.0795] device (wlp2s0): set-hw-addr: set MAC address to 16:99:BE:E5:56:C3 (scanning)
Dec 01 15:40:31 tracey-aspiretc780 NetworkManager[479]: <info> [1764618031.1245] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 01 15:40:31 tracey-aspiretc780 NetworkManager[479]: <info> [1764618031.1245] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 01 15:40:31 tracey-aspiretc780 NetworkManager[479]: <info> [1764618031.1299] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 01 15:40:31 tracey-aspiretc780 NetworkManager[479]: <info> [1764618031.1299] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 01 15:45:43 tracey-aspiretc780 NetworkManager[479]: <info> [1764618343.2635] dhcp4 (enp1s0): state changed new lease, address=192.168.0.89
Dec 01 15:45:43 tracey-aspiretc780 systemd[1]: Starting Network Manager Script Dispatcher Service...
Dec 01 15:45:43 tracey-aspiretc780 systemd[1]: Started Network Manager Script Dispatcher Service.
Dec 01 15:45:53 tracey-aspiretc780 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Dec 01 15:46:12 tracey-aspiretc780 pamac-tray-plas[938]: updates_checker.vala:59: check updates
Dec 01 15:46:13 tracey-aspiretc780 systemd[1]: Starting Pamac Daemon...
Dec 01 15:46:13 tracey-aspiretc780 systemd[1]: Started Pamac Daemon.
Dec 01 15:46:15 tracey-aspiretc780 systemd[1]: pamac-daemon.service: Deactivated successfully.
Dec 01 15:47:25 tracey-aspiretc780 NetworkManager[479]: <info> [1764618445.0795] device (wlp2s0): set-hw-addr: set MAC address to 86:FC:03:D6:90:62 (scanning)
Dec 01 15:47:25 tracey-aspiretc780 NetworkManager[479]: <info> [1764618445.1078] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 01 15:47:25 tracey-aspiretc780 NetworkManager[479]: <info> [1764618445.1079] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 01 15:47:25 tracey-aspiretc780 NetworkManager[479]: <info> [1764618445.1135] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 01 15:47:25 tracey-aspiretc780 NetworkManager[479]: <info> [1764618445.1135] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 01 15:54:18 tracey-aspiretc780 NetworkManager[479]: <info> [1764618858.0613] device (wlp2s0): set-hw-addr: set MAC address to 3A:A1:48:B7:9D:D6 (scanning)
Dec 01 15:59:29 tracey-aspiretc780 chromium[1274]: [1274:1274:1201/155929.266228:ERROR:ui/compositor/compositor_animation_observer.cc:65] CompositorAnimationObserver is active for too long (2580.42s) location=Button@ui/views/controls/button/button.cc:668
Dec 01 16:01:00 tracey-aspiretc780 CROND[2781]: (root) CMD (run-parts /etc/cron.hourly)
Dec 01 16:01:00 tracey-aspiretc780 CROND[2780]: (root) CMDEND (run-parts /etc/cron.hourly)
Dec 01 16:01:08 tracey-aspiretc780 NetworkManager[479]: <info> [1764619268.0656] device (wlp2s0): set-hw-addr: set MAC address to 6E:69:FB:00:EA:A8 (scanning)
Dec 01 16:01:08 tracey-aspiretc780 NetworkManager[479]: <info> [1764619268.0874] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 01 16:01:08 tracey-aspiretc780 NetworkManager[479]: <info> [1764619268.0875] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 01 16:01:08 tracey-aspiretc780 NetworkManager[479]: <info> [1764619268.0928] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 01 16:01:08 tracey-aspiretc780 NetworkManager[479]: <info> [1764619268.0929] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 01 16:08:00 tracey-aspiretc780 NetworkManager[479]: <info> [1764619680.0693] device (wlp2s0): set-hw-addr: set MAC address to 3E:EF:8D:93:2C:DA (scanning)
Dec 01 16:08:00 tracey-aspiretc780 NetworkManager[479]: <info> [1764619680.1143] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 01 16:08:00 tracey-aspiretc780 NetworkManager[479]: <info> [1764619680.1144] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 01 16:08:00 tracey-aspiretc780 NetworkManager[479]: <info> [1764619680.1198] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 01 16:08:00 tracey-aspiretc780 NetworkManager[479]: <info> [1764619680.1198] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 01 16:14:52 tracey-aspiretc780 NetworkManager[479]: <info> [1764620092.0658] device (wlp2s0): set-hw-addr: set MAC address to F6:14:76:55:69:2F (scanning)
Dec 01 16:14:52 tracey-aspiretc780 NetworkManager[479]: <info> [1764620092.1110] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 01 16:14:52 tracey-aspiretc780 NetworkManager[479]: <info> [1764620092.1110] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 01 16:14:52 tracey-aspiretc780 NetworkManager[479]: <info> [1764620092.1166] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 01 16:14:52 tracey-aspiretc780 NetworkManager[479]: <info> [1764620092.1166] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 01 16:19:09 tracey-aspiretc780 systemd[587]: app-org.kde.konsole@942f8e6729074d6d9d746ab328649c72.service: Consumed 2.154s CPU time, 193.8M memory peak.
Dec 01 16:19:09 tracey-aspiretc780 systemd[587]: app-org.kde.konsole-2284.scope: Consumed 3.578s CPU time, 21M memory peak.
Dec 01 16:19:11 tracey-aspiretc780 systemd[587]: Started Konsole - Terminal.
Dec 01 16:19:11 tracey-aspiretc780 systemd[587]: Started app-org.kde.konsole-2942.scope.
Dec 01 16:21:19 tracey-aspiretc780 systemd[587]: app-org.kde.konsole-2942.scope: Consumed 16.302s CPU time, 7.9M memory peak.
Dec 01 16:21:22 tracey-aspiretc780 chromium[1274]: [1274:1274:1201/162122.311504:ERROR:ui/compositor/compositor_animation_observer.cc:65] CompositorAnimationObserver is active for too long (150.324s) location=Button@ui/views/controls/button/button.cc:668
Dec 01 16:21:26 tracey-aspiretc780 systemd[587]: Started Konsole - Terminal.
Dec 01 16:21:27 tracey-aspiretc780 systemd[587]: Started app-org.kde.konsole-3035.scope.
Dec 01 16:21:46 tracey-aspiretc780 NetworkManager[479]: <info> [1764620506.0626] device (wlp2s0): set-hw-addr: set MAC address to 42:D1:23:8B:B8:28 (scanning)
Dec 01 16:21:46 tracey-aspiretc780 NetworkManager[479]: <info> [1764620506.1008] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 01 16:21:46 tracey-aspiretc780 NetworkManager[479]: <info> [1764620506.1008] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 01 16:21:46 tracey-aspiretc780 NetworkManager[479]: <info> [1764620506.1062] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 01 16:21:46 tracey-aspiretc780 NetworkManager[479]: <info> [1764620506.1062] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 01 16:27:18 tracey-aspiretc780 chromium[1274]: [1274:1274:1201/162718.646728:ERROR:ui/compositor/compositor_animation_observer.cc:65] CompositorAnimationObserver is active for too long (353.793s) location=Button@ui/views/controls/button/button.cc:668
Dec 01 16:28:38 tracey-aspiretc780 NetworkManager[479]: <info> [1764620918.0689] device (wlp2s0): set-hw-addr: set MAC address to FE:4A:1A:F2:6B:73 (scanning)
Dec 01 16:28:38 tracey-aspiretc780 NetworkManager[479]: <info> [1764620918.1009] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 01 16:28:38 tracey-aspiretc780 NetworkManager[479]: <info> [1764620918.1010] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 01 16:28:38 tracey-aspiretc780 NetworkManager[479]: <info> [1764620918.1065] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 01 16:28:38 tracey-aspiretc780 NetworkManager[479]: <info> [1764620918.1066] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 01 16:35:28 tracey-aspiretc780 NetworkManager[479]: <info> [1764621328.0658] device (wlp2s0): set-hw-addr: set MAC address to D2:E6:58:3E:FB:D5 (scanning)
Dec 01 16:35:28 tracey-aspiretc780 NetworkManager[479]: <info> [1764621328.0906] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 01 16:35:28 tracey-aspiretc780 NetworkManager[479]: <info> [1764621328.0906] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 01 16:35:28 tracey-aspiretc780 NetworkManager[479]: <info> [1764621328.0961] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 01 16:35:28 tracey-aspiretc780 NetworkManager[479]: <info> [1764621328.0962] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 01 16:39:29 tracey-aspiretc780 systemd[587]: app-org.kde.konsole@7d86430509994b3d9584c5c336b5ae23.service: Consumed 3.427s CPU time, 43M memory peak.
Dec 01 16:39:29 tracey-aspiretc780 systemd[587]: app-org.kde.konsole-3035.scope: Consumed 21.904s CPU time, 17.3M memory peak.
Dec 01 16:39:31 tracey-aspiretc780 systemd[587]: Started Konsole - Terminal.
Dec 01 16:39:31 tracey-aspiretc780 systemd[587]: Started app-org.kde.konsole-3360.scope.
Dec 01 16:39:50 tracey-aspiretc780 systemd[587]: Started Konsole - Terminal.
Dec 01 16:39:51 tracey-aspiretc780 systemd[587]: Started app-org.kde.konsole-3420.scope.
Dec 01 16:41:41 tracey-aspiretc780 NetworkManager[479]: <info> [1764621701.2669] dhcp4 (enp1s0): state changed new lease, address=192.168.0.89
Dec 01 16:41:41 tracey-aspiretc780 systemd[1]: Starting Network Manager Script Dispatcher Service...
Dec 01 16:41:41 tracey-aspiretc780 systemd[1]: Started Network Manager Script Dispatcher Service.
Dec 01 16:41:51 tracey-aspiretc780 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Dec 01 16:41:59 tracey-aspiretc780 systemd[587]: Started Dolphin - File Manager.
Dec 01 16:42:04 tracey-aspiretc780 chromium[1274]: [1274:1274:1201/164204.805876:ERROR:ui/compositor/compositor_animation_observer.cc:65] CompositorAnimationObserver is active for too long (224.584s) location=Button@ui/views/controls/button/button.cc:668
Dec 01 16:42:19 tracey-aspiretc780 NetworkManager[479]: <info> [1764621739.0652] device (wlp2s0): set-hw-addr: set MAC address to 8E:75:8D:71:23:47 (scanning)
Dec 01 16:45:26 tracey-aspiretc780 kwin_x11[671]: kwin_core: XCB error: 152 (BadDamage), sequence: 37082, resource id: 20994190, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Dec 01 16:45:26 tracey-aspiretc780 kwin_x11[671]: kwin_core: XCB error: 3 (BadWindow), sequence: 37083, resource id: 4194808, major code: 129 (SHAPE), minor code: 6 (Input)
Dec 01 16:45:27 tracey-aspiretc780 plasmashell[697]: kf.plasma.quick: Exposed with no visual parent. Window positioning broken.
Dec 01 16:45:33 tracey-aspiretc780 chromium[1274]: [1274:1274:1201/164533.285010:ERROR:ui/compositor/compositor_animation_observer.cc:65] CompositorAnimationObserver is active for too long (93.7227s) location=Button@ui/views/controls/button/button.cc:668
Dec 01 16:46:12 tracey-aspiretc780 pamac-tray-plas[938]: updates_checker.vala:59: check updates
Dec 01 16:46:12 tracey-aspiretc780 systemd[1]: Starting Pamac Daemon...
Dec 01 16:46:13 tracey-aspiretc780 systemd[1]: Started Pamac Daemon.
Dec 01 16:46:15 tracey-aspiretc780 systemd[1]: pamac-daemon.service: Deactivated successfully.
Dec 01 16:49:12 tracey-aspiretc780 NetworkManager[479]: <info> [1764622152.0724] device (wlp2s0): set-hw-addr: set MAC address to 8E:EF:D0:79:21:9B (scanning)
Dec 01 16:49:12 tracey-aspiretc780 NetworkManager[479]: <info> [1764622152.1074] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 01 16:49:12 tracey-aspiretc780 NetworkManager[479]: <info> [1764622152.1075] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 01 16:49:12 tracey-aspiretc780 NetworkManager[479]: <info> [1764622152.1128] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 01 16:49:12 tracey-aspiretc780 NetworkManager[479]: <info> [1764622152.1128] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 01 16:56:06 tracey-aspiretc780 NetworkManager[479]: <info> [1764622566.0723] device (wlp2s0): set-hw-addr: set MAC address to 56:9A:32:26:43:CE (scanning)
Dec 01 16:56:06 tracey-aspiretc780 NetworkManager[479]: <info> [1764622566.1073] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 01 16:56:06 tracey-aspiretc780 NetworkManager[479]: <info> [1764622566.1074] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 01 16:56:06 tracey-aspiretc780 NetworkManager[479]: <info> [1764622566.1131] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 01 16:56:06 tracey-aspiretc780 NetworkManager[479]: <info> [1764622566.1131] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 01 17:01:00 tracey-aspiretc780 CROND[3731]: (root) CMD (run-parts /etc/cron.hourly)
Dec 01 17:01:00 tracey-aspiretc780 CROND[3730]: (root) CMDEND (run-parts /etc/cron.hourly)
Dec 01 17:01:17 tracey-aspiretc780 kwin_x11[671]: kwin_core: XCB error: 152 (BadDamage), sequence: 57223, resource id: 20996583, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Dec 01 17:01:17 tracey-aspiretc780 kwin_x11[671]: kwin_core: XCB error: 3 (BadWindow), sequence: 57224, resource id: 54526008, major code: 129 (SHAPE), minor code: 6 (Input)
Dec 01 17:01:18 tracey-aspiretc780 systemd[587]: app-org.chromium.Chromium-1274.scope: Consumed 58.425s CPU time, 281.6M memory peak.
Dec 01 17:01:18 tracey-aspiretc780 systemd[587]: app-chromium@63907810f14046019e2743994776cb34.service: Consumed 7min 9.458s CPU time, 1.3G memory peak.
Dec 01 17:01:19 tracey-aspiretc780 systemd[587]: app-org.kde.konsole@eb0facaeb5b140c492e0a3733368e3c2.service: Consumed 2.421s CPU time, 36M memory peak.
Dec 01 17:01:19 tracey-aspiretc780 systemd[587]: app-org.kde.konsole-3420.scope: Consumed 10.222s CPU time, 5.6M memory peak.
Dec 01 17:01:22 tracey-aspiretc780 systemd[587]: Created slice Slice /app/dbus-:1.2-org.kde.LogoutPrompt.
Dec 01 17:01:22 tracey-aspiretc780 systemd[587]: Started dbus-:1.2-org.kde.LogoutPrompt@0.service.
Dec 01 17:01:24 tracey-aspiretc780 systemd[587]: Created slice Slice /app/dbus-:1.2-org.kde.Shutdown.
Dec 01 17:01:24 tracey-aspiretc780 systemd[587]: Started dbus-:1.2-org.kde.Shutdown@0.service.
Dec 01 17:01:24 tracey-aspiretc780 polkit-kde-authentication-agent-1[729]: Destroying listener
Dec 01 17:01:24 tracey-aspiretc780 polkit-kde-authentication-agent-1[729]: Removing listener PolkitQt1::Agent::Listener(0x55c6c8080fc0)
Dec 01 17:01:24 tracey-aspiretc780 msm_kde_notifier[912]: Shutting down MSM Notifier...
Dec 01 17:01:24 tracey-aspiretc780 polkitd[482]: Unregistered Authentication Agent for unix-session:1 (system bus name :1.24, object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_CA.UTF-8)
Dec 01 17:01:24 tracey-aspiretc780 kded6[670]: Service ":1.48" unregistered
Dec 01 17:01:24 tracey-aspiretc780 kded6[670]: Service ":1.44" unregistered
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: app-pamac\x2dtray\x2dplasma@autostart.service: Consumed 13.951s CPU time, 800.9M memory peak.
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: dbus-:1.2-org.kde.LogoutPrompt@0.service: Consumed 508ms CPU time, 87.6M memory peak.
Dec 01 17:01:25 tracey-aspiretc780 plasmashell[697]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:130: TypeError: Cannot read property 'screenGeometry' of null
Dec 01 17:01:25 tracey-aspiretc780 plasmashell[697]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:260: TypeError: Cannot read property 'plasmoid' of undefined
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: app-msm_kde_notifier@autostart.service: Consumed 2.431s CPU time, 37.1M memory peak.
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: Stopped target plasma-workspace-x11.target.
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: Stopped target KDE Plasma Workspace.
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: Stopped target Current graphical user session.
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: Stopped target Startup of XDG autostart applications.
Dec 01 17:01:25 tracey-aspiretc780 dbus-broker[1385]: Dispatched 1924 messages @ 5(±5)μs / message.
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: Stopping Accessibility services bus...
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: Stopping KAccess...
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: Stopping KActivityManager Activity manager Service...
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: Stopping KDE Global Shortcuts Server...
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: Stopping KScreen...
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: Stopping KDE Window Manager...
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: Stopping Powerdevil...
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: Stopping Xdg Desktop Portal For KDE...
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: Stopping Portal service...
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: Stopping flatpak document portal service...
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: Stopping sandboxed app permission store...
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: Stopping Baloo File Indexer Daemon...
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: Stopped sandboxed app permission store.
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: Stopped Accessibility services bus.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: run-user-1000-doc.mount: Deactivated successfully.
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: Stopped KScreen.
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: Stopped KAccess.
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: Stopped Xdg Desktop Portal For KDE.
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: Stopped Portal service.
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: Stopped KActivityManager Activity manager Service.
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: Stopped KDE Global Shortcuts Server.
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: plasma-kglobalaccel.service: Consumed 1.003s CPU time, 10M memory peak.
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: Stopped flatpak document portal service.
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: Stopped Powerdevil.
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: plasma-powerdevil.service: Consumed 6.755s CPU time, 12.2M memory peak.
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: Stopped target KDE Plasma Workspace Core.
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: Stopping KDE Daemon 6...
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: Stopping KDE Plasma Workspace...
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: Stopped target Session services which should run early before the graphical session is brought up.
Dec 01 17:01:25 tracey-aspiretc780 systemd-logind[483]: The system will power off now!
Dec 01 17:01:25 tracey-aspiretc780 systemd-logind[483]: System is powering down.
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: Stopped Baloo File Indexer Daemon.
Dec 01 17:01:25 tracey-aspiretc780 sddm-helper[582]: Signal received: SIGTERM
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopping Session 1 of User tracey...
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.backlighthelper.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.chargethresholdhelper.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.discretegpuhelper.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Removed slice Slice /system/getty.
Dec 01 17:01:25 tracey-aspiretc780 sddm[568]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Dec 01 17:01:25 tracey-aspiretc780 sddm[568]: Auth: sddm-helper (--socket /tmp/sddm-auth-71e0fedc-64d3-4523-82b3-0050102b5b48 --id 1 --start /usr/bin/startplasma-x11 --user tracey --autologin) crashed (exit code 1)
Dec 01 17:01:25 tracey-aspiretc780 sddm[568]: Auth: sddm-helper exited with 1
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Removed slice Slice /system/modprobe.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopped target Bluetooth Support.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopped target Graphical Interface.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopped target Sound Card.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopped target Timer Units.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: archlinux-keyring-wkd-sync.timer: Deactivated successfully.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopped Refresh existing PGP keys of archlinux-keyring regularly.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: fstrim.timer: Deactivated successfully.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopped Discard unused filesystem blocks once a week.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: logrotate.timer: Deactivated successfully.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopped Daily rotation of log files.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: man-db.timer: Deactivated successfully.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopped Daily man-db regeneration.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: pamac-cleancache.timer: Deactivated successfully.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopped Monthly clean packages cache.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: pamac-mirrorlist.timer: Deactivated successfully.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopped Generate mirrorlist weekly.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: shadow.timer: Deactivated successfully.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopped Daily verification of password and group files.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: systemd-tmpfiles-clean.timer: Deactivated successfully.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopped Daily Cleanup of Temporary Directories.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopped target Trusted Platform Module.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: lvm2-lvmpolld.socket: Deactivated successfully.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Closed LVM2 poll daemon socket.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: systemd-rfkill.socket: Deactivated successfully.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopping Save/Restore Sound Card State...
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopping Bluetooth service...
Dec 01 17:01:25 tracey-aspiretc780 bluetoothd[481]: Terminating
Dec 01 17:01:25 tracey-aspiretc780 kwin_x11[671]: kwin_scene_opengl: Could not delete framebuffer because no context is current
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Starting Generate shutdown-ramfs...
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopping Power Profiles daemon...
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopping RealtimeKit Scheduling Policy Service...
Dec 01 17:01:25 tracey-aspiretc780 sddm[568]: Signal received: SIGTERM
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopping Simple Desktop Display Manager...
Dec 01 17:01:25 tracey-aspiretc780 sddm[568]: Display server stopping...
Dec 01 17:01:25 tracey-aspiretc780 ksmserver[668]: The X11 connection broke (error 1). Did the X11 server die?
Dec 01 17:01:25 tracey-aspiretc780 at-spi2-registryd[1386]: X connection to :0 broken (explicit kill or server shutdown).
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: dbus-:1.59-org.a11y.atspi.Registry@0.service: Main process exited, code=exited, status=1/FAILURE
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: dbus-:1.59-org.a11y.atspi.Registry@0.service: Failed with result 'exit-code'.
Dec 01 17:01:25 tracey-aspiretc780 bluetoothd[481]: Endpoint unregistered: sender=:1.47 path=/MediaEndpoint/A2DPSource/ldac
Dec 01 17:01:25 tracey-aspiretc780 bluetoothd[481]: Endpoint unregistered: sender=:1.47 path=/MediaEndpoint/A2DPSink/aptx_hd
Dec 01 17:01:25 tracey-aspiretc780 bluetoothd[481]: Endpoint unregistered: sender=:1.47 path=/MediaEndpoint/A2DPSource/aptx_hd
Dec 01 17:01:25 tracey-aspiretc780 bluetoothd[481]: Endpoint unregistered: sender=:1.47 path=/MediaEndpoint/A2DPSink/aac
Dec 01 17:01:25 tracey-aspiretc780 bluetoothd[481]: Endpoint unregistered: sender=:1.47 path=/MediaEndpoint/A2DPSource/aac
Dec 01 17:01:25 tracey-aspiretc780 bluetoothd[481]: Endpoint unregistered: sender=:1.47 path=/MediaEndpoint/A2DPSink/opus_g
Dec 01 17:01:25 tracey-aspiretc780 bluetoothd[481]: Endpoint unregistered: sender=:1.47 path=/MediaEndpoint/A2DPSource/opus_g
Dec 01 17:01:25 tracey-aspiretc780 bluetoothd[481]: Endpoint unregistered: sender=:1.47 path=/MediaEndpoint/A2DPSink/sbc
Dec 01 17:01:25 tracey-aspiretc780 bluetoothd[481]: Endpoint unregistered: sender=:1.47 path=/MediaEndpoint/A2DPSource/sbc
Dec 01 17:01:25 tracey-aspiretc780 bluetoothd[481]: Endpoint unregistered: sender=:1.47 path=/MediaEndpoint/A2DPSource/aptx_ll_1
Dec 01 17:01:25 tracey-aspiretc780 bluetoothd[481]: Endpoint unregistered: sender=:1.47 path=/MediaEndpoint/A2DPSource/aptx_ll_0
Dec 01 17:01:25 tracey-aspiretc780 bluetoothd[481]: Endpoint unregistered: sender=:1.47 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
Dec 01 17:01:25 tracey-aspiretc780 bluetoothd[481]: Endpoint unregistered: sender=:1.47 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
Dec 01 17:01:25 tracey-aspiretc780 bluetoothd[481]: Endpoint unregistered: sender=:1.47 path=/MediaEndpoint/A2DPSource/faststream
Dec 01 17:01:25 tracey-aspiretc780 bluetoothd[481]: Endpoint unregistered: sender=:1.47 path=/MediaEndpoint/A2DPSource/faststream_duplex
Dec 01 17:01:25 tracey-aspiretc780 bluetoothd[481]: Endpoint unregistered: sender=:1.47 path=/MediaEndpoint/A2DPSink/opus_05
Dec 01 17:01:25 tracey-aspiretc780 bluetoothd[481]: Endpoint unregistered: sender=:1.47 path=/MediaEndpoint/A2DPSource/opus_05
Dec 01 17:01:25 tracey-aspiretc780 bluetoothd[481]: Endpoint unregistered: sender=:1.47 path=/MediaEndpoint/A2DPSink/opus_05_duplex
Dec 01 17:01:25 tracey-aspiretc780 bluetoothd[481]: Endpoint unregistered: sender=:1.47 path=/MediaEndpoint/A2DPSource/opus_05_duplex
Dec 01 17:01:25 tracey-aspiretc780 dbus-broker[478]: A security policy denied :1.5 to send method call /midi/profile:org.bluez.GattProfile1.Release to :1.48.
Dec 01 17:01:25 tracey-aspiretc780 bluetoothd[481]: Battery Provider Manager destroyed
Dec 01 17:01:25 tracey-aspiretc780 bluetoothd[481]: Stopping SDP server
Dec 01 17:01:25 tracey-aspiretc780 bluetoothd[481]: Exit
Dec 01 17:01:25 tracey-aspiretc780 kwin_x11[671]: The X11 connection broke: I/O error (code 1)
Dec 01 17:01:25 tracey-aspiretc780 kwin_x11[671]: X connection to :0 broken (explicit kill or server shutdown).
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopping Load/Save OS Random Seed...
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: systemd-udev-load-credentials.service: Deactivated successfully.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopped Load udev Rules from Credentials.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopping Disk Manager...
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopping Daemon for power management...
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: plasma-ksmserver.service: Main process exited, code=exited, status=1/FAILURE
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: plasma-ksmserver.service: Failed with result 'exit-code'.
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: Stopped KDE Session Management Server.
Dec 01 17:01:25 tracey-aspiretc780 systemd[587]: plasma-ksmserver.service: Consumed 652ms CPU time, 69.5M memory peak.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: bluetooth.service: Deactivated successfully.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopped Bluetooth service.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: rtkit-daemon.service: Deactivated successfully.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopped RealtimeKit Scheduling Policy Service.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: upower.service: Deactivated successfully.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopped Daemon for power management.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: power-profiles-daemon.service: Deactivated successfully.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopped Power Profiles daemon.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: alsa-restore.service: Deactivated successfully.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopped Save/Restore Sound Card State.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: session-1.scope: Deactivated successfully.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopped Session 1 of User tracey.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: session-1.scope: Consumed 1.987s CPU time, 350.6M memory peak.
Dec 01 17:01:25 tracey-aspiretc780 udisksd[869]: udisks daemon version 2.10.2 exiting
Dec 01 17:01:25 tracey-aspiretc780 systemd-logind[483]: Session 1 logged out. Waiting for processes to exit.
Dec 01 17:01:25 tracey-aspiretc780 dbus-broker-launch[477]: Activation request for 'org.bluez' failed.
Dec 01 17:01:25 tracey-aspiretc780 systemd-logind[483]: Removed session 1.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopped target Multi-User System.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopped target Login Prompts.
Dec 01 17:01:25 tracey-aspiretc780 ModemManager[532]: <msg> caught signal, shutting down...
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopping Modem Manager...
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopping Command Scheduler...
Dec 01 17:01:25 tracey-aspiretc780 crond[559]: (CRON) INFO (Shutting down)
Dec 01 17:01:25 tracey-aspiretc780 ModemManager[532]: <msg> ModemManager is shut down
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopping CUPS Scheduler...
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: plymouth-quit-wait.service: Deactivated successfully.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopped Hold until boot process finishes up.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopping User Manager for UID 1000...
Dec 01 17:01:25 tracey-aspiretc780 NetworkManager[479]: <info> [1764622885.8184] modem-manager: ModemManager no longer available
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: cronie.service: Deactivated successfully.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopped Command Scheduler.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: cups.service: Deactivated successfully.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopped CUPS Scheduler.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Removed slice CUPS Slice.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopped target System Time Set.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: ModemManager.service: Deactivated successfully.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopped Modem Manager.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopping Authorization Manager...
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: polkit.service: Deactivated successfully.
Dec 01 17:01:25 tracey-aspiretc780 systemd[1]: Stopped Authorization Manager.
Dec 01 17:01:26 tracey-aspiretc780 systemd[587]: Activating special unit Exit the Session...
Dec 01 17:01:26 tracey-aspiretc780 systemd[587]: Removed slice Slice /app/dbus-:1.2-org.freedesktop.Notifications.
Dec 01 17:01:26 tracey-aspiretc780 systemd[587]: Removed slice Slice /app/dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet.
Dec 01 17:01:26 tracey-aspiretc780 systemd[587]: Removed slice Slice /app/dbus-:1.2-org.kde.KSplash.
Dec 01 17:01:26 tracey-aspiretc780 systemd[587]: Removed slice Slice /app/dbus-:1.2-org.kde.LogoutPrompt.
Dec 01 17:01:26 tracey-aspiretc780 systemd[587]: app-dbus\x2d:1.2\x2dorg.kde.LogoutPrompt.slice: Consumed 508ms CPU time, 87.6M memory peak.
Dec 01 17:01:26 tracey-aspiretc780 systemd[587]: Removed slice Slice /app/dbus-:1.2-org.kde.kwalletd6.
Dec 01 17:01:26 tracey-aspiretc780 systemd[587]: Removed slice Slice /app/dbus-:1.59-org.a11y.atspi.Registry.
Dec 01 17:01:26 tracey-aspiretc780 systemd[587]: Removed slice User Background Tasks Slice.
Dec 01 17:01:26 tracey-aspiretc780 systemd[587]: background.slice: Consumed 11.044s CPU time, 77.1M memory peak.
Dec 01 17:01:26 tracey-aspiretc780 systemd[587]: Stopped target Main User Target.
Dec 01 17:01:26 tracey-aspiretc780 systemd[587]: Stopping dbus-:1.2-org.kde.Shutdown@0.service...
Dec 01 17:01:26 tracey-aspiretc780 systemd[587]: Stopping User preferences database...
Dec 01 17:01:26 tracey-aspiretc780 systemd[587]: Stopping PipeWire PulseAudio...
Dec 01 17:01:26 tracey-aspiretc780 systemd[587]: Stopped dbus-:1.2-org.kde.Shutdown@0.service.
Dec 01 17:01:26 tracey-aspiretc780 systemd[587]: Stopped PipeWire PulseAudio.
Dec 01 17:01:26 tracey-aspiretc780 systemd[587]: Stopped User preferences database.
Dec 01 17:01:26 tracey-aspiretc780 kernel: fbcon: Taking over console
Dec 01 17:01:26 tracey-aspiretc780 systemd[1]: udisks2.service: Deactivated successfully.
Dec 01 17:01:26 tracey-aspiretc780 systemd[1]: Stopped Disk Manager.
Dec 01 17:01:26 tracey-aspiretc780 systemd[1]: udisks2.service: Consumed 1.756s CPU time, 7.8M memory peak.
Dec 01 17:01:26 tracey-aspiretc780 systemd[587]: Removed slice Slice /app/dbus-:1.2-org.kde.Shutdown.
Dec 01 17:01:26 tracey-aspiretc780 systemd[587]: Stopping Multimedia Service Session Manager...
Dec 01 17:01:26 tracey-aspiretc780 kernel: Console: switching to colour frame buffer device 240x67
Dec 01 17:01:26 tracey-aspiretc780 systemd[587]: Stopped Multimedia Service Session Manager.
Dec 01 17:01:26 tracey-aspiretc780 systemd[587]: Stopping PipeWire Multimedia Service...
Dec 01 17:01:26 tracey-aspiretc780 systemd[587]: Stopped PipeWire Multimedia Service.
Dec 01 17:01:26 tracey-aspiretc780 sddm[568]: Display server stopped.
Dec 01 17:01:26 tracey-aspiretc780 sddm[568]: Running display stop script QList("/usr/share/sddm/scripts/Xstop")
Dec 01 17:01:26 tracey-aspiretc780 systemd[1]: sddm.service: Deactivated successfully.
Dec 01 17:01:26 tracey-aspiretc780 systemd[1]: Stopped Simple Desktop Display Manager.
Dec 01 17:01:26 tracey-aspiretc780 systemd[1]: sddm.service: Consumed 1min 1.198s CPU time, 541.2M memory peak.
Dec 01 17:01:26 tracey-aspiretc780 systemd[1]: Starting Show Plymouth Power Off Screen...
Dec 01 17:01:26 tracey-aspiretc780 systemd[1]: plymouth-quit.service: Deactivated successfully.
Dec 01 17:01:26 tracey-aspiretc780 systemd[1]: Stopped Terminate Plymouth Boot Screen.
Dec 01 17:01:26 tracey-aspiretc780 systemd[1]: Received SIGRTMIN+20 from PID 3886 (plymouthd).
Dec 01 17:01:26 tracey-aspiretc780 systemd[587]: plasma-kwin_x11.service: Main process exited, code=exited, status=1/FAILURE
Dec 01 17:01:26 tracey-aspiretc780 systemd[587]: plasma-kwin_x11.service: Failed with result 'exit-code'.
Dec 01 17:01:26 tracey-aspiretc780 systemd[587]: Stopped KDE Window Manager.
Dec 01 17:01:26 tracey-aspiretc780 systemd[587]: plasma-kwin_x11.service: Consumed 53.354s CPU time, 138.4M memory peak.
Dec 01 17:01:26 tracey-aspiretc780 systemd[1]: systemd-random-seed.service: Deactivated successfully.
Dec 01 17:01:26 tracey-aspiretc780 systemd[1]: Stopped Load/Save OS Random Seed.
Dec 01 17:01:26 tracey-aspiretc780 kded6[670]: The X11 connection broke: I/O error (code 1)
Dec 01 17:01:26 tracey-aspiretc780 kded6[670]: XIO: fatal IO error 9 (Bad file descriptor) on X server ":0"
Dec 01 17:01:26 tracey-aspiretc780 kded6[670]: after 452 requests (452 known processed) with 0 events remaining.
Dec 01 17:01:27 tracey-aspiretc780 kded6[670]: QThreadStorage: entry 12 destroyed before end of thread 0x561eebf29580
Dec 01 17:01:27 tracey-aspiretc780 kded6[670]: QThreadStorage: entry 11 destroyed before end of thread 0x561eebf29580
Dec 01 17:01:27 tracey-aspiretc780 kded6[670]: QThreadStorage: entry 10 destroyed before end of thread 0x561eebf29580
Dec 01 17:01:27 tracey-aspiretc780 kded6[670]: QThreadStorage: entry 9 destroyed before end of thread 0x561eebf29580
Dec 01 17:01:27 tracey-aspiretc780 kded6[670]: QThreadStorage: entry 8 destroyed before end of thread 0x561eebf29580
Dec 01 17:01:27 tracey-aspiretc780 kded6[670]: QThreadStorage: entry 2 destroyed before end of thread 0x561eebf29580
Dec 01 17:01:27 tracey-aspiretc780 kded6[670]: QThreadStorage: entry 1 destroyed before end of thread 0x561eebf29580
Dec 01 17:01:27 tracey-aspiretc780 kded6[670]: QThreadStorage: entry 0 destroyed before end of thread 0x561eebf29580
Dec 01 17:01:27 tracey-aspiretc780 systemd[587]: plasma-kded6.service: Main process exited, code=exited, status=1/FAILURE
Dec 01 17:01:27 tracey-aspiretc780 systemd[587]: plasma-kded6.service: Failed with result 'exit-code'.
Dec 01 17:01:27 tracey-aspiretc780 systemd[587]: Stopped KDE Daemon 6.
Dec 01 17:01:27 tracey-aspiretc780 systemd[587]: plasma-kded6.service: Consumed 2.168s CPU time, 109.8M memory peak.
Dec 01 17:01:27 tracey-aspiretc780 systemd[587]: Stopped KDE Plasma Workspace.
Dec 01 17:01:27 tracey-aspiretc780 systemd[587]: plasma-plasmashell.service: Consumed 13.777s CPU time, 341.1M memory peak.
Dec 01 17:01:27 tracey-aspiretc780 systemd[587]: Stopped target Basic System.
Dec 01 17:01:27 tracey-aspiretc780 systemd[587]: Stopped target Paths.
Dec 01 17:01:27 tracey-aspiretc780 systemd[587]: Stopped target Sockets.
Dec 01 17:01:27 tracey-aspiretc780 systemd[587]: Stopped target Timers.
Dec 01 17:01:27 tracey-aspiretc780 systemd[587]: Closed GnuPG network certificate management daemon.
Dec 01 17:01:27 tracey-aspiretc780 systemd[587]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Dec 01 17:01:27 tracey-aspiretc780 systemd[587]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Dec 01 17:01:27 tracey-aspiretc780 systemd[587]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Dec 01 17:01:27 tracey-aspiretc780 systemd[587]: Closed GnuPG cryptographic agent and passphrase cache.
Dec 01 17:01:27 tracey-aspiretc780 systemd[587]: Closed GnuPG public key management service.
Dec 01 17:01:27 tracey-aspiretc780 systemd[587]: Closed p11-kit server.
Dec 01 17:01:27 tracey-aspiretc780 systemd[587]: Closed PipeWire PulseAudio.
Dec 01 17:01:27 tracey-aspiretc780 systemd[587]: Closed PipeWire Multimedia System Sockets.
Dec 01 17:01:27 tracey-aspiretc780 dbus-broker[618]: Dispatched 18851 messages @ 4(±6)μs / message.
Dec 01 17:01:27 tracey-aspiretc780 systemd[587]: Stopping D-Bus User Message Bus...
Dec 01 17:01:27 tracey-aspiretc780 systemd[587]: Stopped D-Bus User Message Bus.
Dec 01 17:01:27 tracey-aspiretc780 systemd[587]: Removed slice User Core Session Slice.
Dec 01 17:01:27 tracey-aspiretc780 systemd[587]: session.slice: Consumed 1min 13.119s CPU time, 735.3M memory peak.
Dec 01 17:01:27 tracey-aspiretc780 systemd[587]: Closed D-Bus User Message Bus Socket.
Dec 01 17:01:27 tracey-aspiretc780 systemd[587]: Removed slice User Application Slice.
Dec 01 17:01:27 tracey-aspiretc780 systemd[587]: app.slice: Consumed 9min 56.230s CPU time, 2.7G memory peak.
Dec 01 17:01:27 tracey-aspiretc780 systemd[587]: Reached target Shutdown.
Dec 01 17:01:27 tracey-aspiretc780 systemd[587]: Finished Exit the Session.
Dec 01 17:01:27 tracey-aspiretc780 systemd[587]: Reached target Exit the Session.
Dec 01 17:01:27 tracey-aspiretc780 (sd-pam)[589]: pam_unix(systemd-user:session): session closed for user tracey
Dec 01 17:01:27 tracey-aspiretc780 systemd-logind[483]: Removed session 2.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: user@1000.service: Deactivated successfully.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Stopped User Manager for UID 1000.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: user@1000.service: Consumed 11min 22.819s CPU time, 3.4G memory peak.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Stopping Permit User Sessions...
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Stopping User Runtime Directory /run/user/1000...
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Received SIGRTMIN+20 from PID 3886 (plymouthd).
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: run-user-1000.mount: Deactivated successfully.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Unmounted /run/user/1000.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: systemd-user-sessions.service: Deactivated successfully.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Stopped Permit User Sessions.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: user-runtime-dir@1000.service: Deactivated successfully.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Stopped User Runtime Directory /run/user/1000.
Dec 01 17:01:27 tracey-aspiretc780 mkinitcpio[3839]: ==> Starting build: 'none'
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Removed slice User Slice of UID 1000.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: user-1000.slice: Consumed 11min 24.835s CPU time, 3.5G memory peak.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Stopped target Network.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Stopped target Remote File Systems.
Dec 01 17:01:27 tracey-aspiretc780 NetworkManager[479]: <info> [1764622887.3202] caught SIGTERM, shutting down normally.
Dec 01 17:01:27 tracey-aspiretc780 wpa_supplicant[555]: p2p-dev-wlp2s0: CTRL-EVENT-DSCP-POLICY clear_all
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Stopping Network Manager...
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Stopping User Login Management...
Dec 01 17:01:27 tracey-aspiretc780 wpa_supplicant[555]: nl80211: deinit ifname=p2p-dev-wlp2s0 disabled_11b_rates=0
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Stopping WPA supplicant...
Dec 01 17:01:27 tracey-aspiretc780 NetworkManager[479]: <info> [1764622887.3211] dhcp4 (enp1s0): canceled DHCP transaction
Dec 01 17:01:27 tracey-aspiretc780 NetworkManager[479]: <info> [1764622887.3212] dhcp4 (enp1s0): activation: beginning transaction (timeout in 45 seconds)
Dec 01 17:01:27 tracey-aspiretc780 NetworkManager[479]: <info> [1764622887.3212] dhcp4 (enp1s0): state changed no lease
Dec 01 17:01:27 tracey-aspiretc780 NetworkManager[479]: <info> [1764622887.3215] manager: NetworkManager state is now CONNECTED_SITE
Dec 01 17:01:27 tracey-aspiretc780 dbus-broker-launch[477]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Dec 01 17:01:27 tracey-aspiretc780 NetworkManager[479]: <info> [1764622887.3603] device (wlp2s0): state change: disconnected -> unmanaged (reason 'unmanaged-quitting', managed-type: 'full')
Dec 01 17:01:27 tracey-aspiretc780 wpa_supplicant[555]: p2p-dev-wlp2s0: CTRL-EVENT-TERMINATING
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: systemd-logind.service: Deactivated successfully.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Stopped User Login Management.
Dec 01 17:01:27 tracey-aspiretc780 wpa_supplicant[555]: wlp2s0: CTRL-EVENT-DSCP-POLICY clear_all
Dec 01 17:01:27 tracey-aspiretc780 NetworkManager[479]: <info> [1764622887.4108] device (wlp2s0): set-hw-addr: reset MAC address to 30:E3:7A:F3:8A:18 (unmanage)
Dec 01 17:01:27 tracey-aspiretc780 mkinitcpio[3839]: -> Running build hook: [sd-shutdown]
Dec 01 17:01:27 tracey-aspiretc780 wpa_supplicant[555]: nl80211: deinit ifname=wlp2s0 disabled_11b_rates=0
Dec 01 17:01:27 tracey-aspiretc780 wpa_supplicant[555]: wlp2s0: CTRL-EVENT-TERMINATING
Dec 01 17:01:27 tracey-aspiretc780 NetworkManager[479]: <info> [1764622887.4796] device (p2p-dev-wlp2s0): state change: disconnected -> unmanaged (reason 'unmanaged-link-not-init', managed-type: 'removed')
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: wpa_supplicant.service: Deactivated successfully.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Stopped WPA supplicant.
Dec 01 17:01:27 tracey-aspiretc780 NetworkManager[479]: <info> [1764622887.9310] exiting (success)
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: NetworkManager.service: Deactivated successfully.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Stopped Network Manager.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: NetworkManager.service: Consumed 2.119s CPU time, 18.1M memory peak.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Stopped target Basic System.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: systemd-ask-password-plymouth.path: Deactivated successfully.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Stopped Forward Password Requests to Plymouth Directory Watch.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Stopped target Path Units.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: cups.path: Deactivated successfully.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Stopped CUPS Scheduler.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Stopped target Slice Units.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Removed slice User and Session Slice.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: user.slice: Consumed 11min 24.835s CPU time, 3.5G memory peak.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Stopped target Socket Units.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: cups.socket: Deactivated successfully.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Closed CUPS Scheduler.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: dirmngr@etc-pacman.d-gnupg.socket: Deactivated successfully.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Closed GnuPG network certificate management daemon for /etc/pacman.d/gnupg.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Removed slice Slice /system/dirmngr.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: gpg-agent-browser@etc-pacman.d-gnupg.socket: Deactivated successfully.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers) for /etc/pacman.d/gnupg.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Removed slice Slice /system/gpg-agent-browser.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: gpg-agent-extra@etc-pacman.d-gnupg.socket: Deactivated successfully.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Closed GnuPG cryptographic agent and passphrase cache (restricted) for /etc/pacman.d/gnupg.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Removed slice Slice /system/gpg-agent-extra.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: gpg-agent-ssh@etc-pacman.d-gnupg.socket: Deactivated successfully.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Closed GnuPG cryptographic agent (ssh-agent emulation) for /etc/pacman.d/gnupg.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Removed slice Slice /system/gpg-agent-ssh.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: gpg-agent@etc-pacman.d-gnupg.socket: Deactivated successfully.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Closed GnuPG cryptographic agent and passphrase cache for /etc/pacman.d/gnupg.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Removed slice Slice /system/gpg-agent.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: keyboxd@etc-pacman.d-gnupg.socket: Deactivated successfully.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Closed GnuPG public key management service for /etc/pacman.d/gnupg.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Removed slice Slice /system/keyboxd.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: sshd-unix-local.socket: Deactivated successfully.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Closed OpenSSH Server Socket (systemd-ssh-generator, AF_UNIX Local).
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: systemd-hostnamed.socket: Deactivated successfully.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Closed Hostname Service Socket.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: systemd-importd.socket: Deactivated successfully.
Dec 01 17:01:27 tracey-aspiretc780 systemd[1]: Closed Disk Image Download Service Socket.
Dec 01 17:01:28 tracey-aspiretc780 dbus-broker[478]: Dispatched 23996 messages @ 6(±7)μs / message.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Stopping D-Bus System Message Bus...
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: dbus-broker.service: Deactivated successfully.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Stopped D-Bus System Message Bus.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: dbus-broker.service: Consumed 1.078s CPU time, 6.4M memory peak.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Started Show Plymouth Power Off Screen.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: dbus.socket: Deactivated successfully.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Closed D-Bus System Message Bus Socket.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Stopped target System Initialization.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: proc-sys-fs-binfmt_misc.automount: Deactivated successfully.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Unset automount Arbitrary Executable File Formats File System Automount Point.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Stopped target Local Encrypted Volumes.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: systemd-ask-password-wall.path: Deactivated successfully.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Stopped target Local Integrity Protected Volumes.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Stopped target Local Verity Protected Volumes.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: systemd-sysctl.service: Deactivated successfully.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Stopped Apply Kernel Variables.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: systemd-coredump.socket: Deactivated successfully.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Closed Process Core Dump Socket.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: systemd-modules-load.service: Deactivated successfully.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Stopped Load Kernel Modules.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Stopping Network Time Synchronization...
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Stopping Record System Boot/Shutdown in UTMP...
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: systemd-vconsole-setup.service: Deactivated successfully.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Stopped Virtual Console Setup.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Stopping Virtual Console Setup...
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Starting Virtual Console Setup...
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: systemd-timesyncd.service: Deactivated successfully.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Stopped Network Time Synchronization.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: systemd-update-utmp.service: Deactivated successfully.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Stopped Record System Boot/Shutdown in UTMP.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: systemd-tmpfiles-setup.service: Deactivated successfully.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Stopped Create System Files and Directories.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Stopped target Local File Systems.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Unmounting /boot/efi...
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Unmounting Temporary Directory /tmp...
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: boot-efi.mount: Deactivated successfully.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Unmounted /boot/efi.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: tmp.mount: Deactivated successfully.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Unmounted Temporary Directory /tmp.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Stopped target Swaps.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Reached target Unmount All Filesystems.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: systemd-fsck@dev-disk-by\x2duuid-9024\x2dC57B.service: Deactivated successfully.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Stopped File System Check on /dev/disk/by-uuid/9024-C57B.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Removed slice Slice /system/systemd-fsck.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Stopped target Preparation for Local File Systems.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Stopping Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: systemd-remount-fs.service: Deactivated successfully.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Stopped Remount Root and Kernel File Systems.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: systemd-tmpfiles-setup-dev.service: Deactivated successfully.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Stopped Create Static Device Nodes in /dev.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: systemd-tmpfiles-setup-dev-early.service: Deactivated successfully.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Stopped Create Static Device Nodes in /dev gracefully.
Dec 01 17:01:28 tracey-aspiretc780 mkinitcpio[3839]: -> Running build hook: [plymouth-shutdown]
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: lvm2-monitor.service: Deactivated successfully.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Stopped Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Finished Virtual Console Setup.
Dec 01 17:01:28 tracey-aspiretc780 mkinitcpio[3839]: ==> Build complete.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: mkinitcpio-generate-shutdown-ramfs.service: Deactivated successfully.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Finished Generate shutdown-ramfs.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Reached target System Shutdown.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Reached target Late Shutdown Services.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Starting Tell Plymouth To Jump To initramfs...
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: systemd-poweroff.service: Deactivated successfully.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Finished System Power Off.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Reached target System Power Off.
Dec 01 17:01:28 tracey-aspiretc780 systemd[1]: Shutting down.
Dec 01 17:01:29 tracey-aspiretc780 systemd-shutdown[1]: Syncing filesystems and block devices.
Dec 01 17:01:29 tracey-aspiretc780 systemd-shutdown[1]: Sending SIGTERM to remaining processes...
Dec 01 17:01:29 tracey-aspiretc780 systemd-journald[295]: Received SIGTERM from PID 1 (systemd-shutdow).
Dec 01 17:01:29 tracey-aspiretc780 systemd-journald[295]: Journal stopped
Here is the log for the 6th, where it did shut down properly. I noted a few things to look at here as well, I’ll be back!
Dec 06 05:02:09 tracey-aspiretc780 systemd[1]: Starting Pamac Daemon...
Dec 06 05:02:09 tracey-aspiretc780 systemd[1]: Started Pamac Daemon.
Dec 06 05:03:09 tracey-aspiretc780 plasma_waitforname[1075]: org.kde.plasma.waitforname: WaitForName: Service was not registered within timeout
Dec 06 05:03:09 tracey-aspiretc780 systemd[594]: dbus-:1.2-org.kde.KSplash@1.service: Main process exited, code=exited, status=1/FAILURE
Dec 06 05:03:09 tracey-aspiretc780 systemd[594]: dbus-:1.2-org.kde.KSplash@1.service: Failed with result 'exit-code'.
Dec 06 05:08:11 tracey-aspiretc780 NetworkManager[481]: <info> [1765012091.5280] device (wlp2s0): set-hw-addr: set MAC address to 82:B3:0A:9D:62:71 (scanning)
Dec 06 05:08:11 tracey-aspiretc780 NetworkManager[481]: <info> [1765012091.5687] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 05:08:11 tracey-aspiretc780 NetworkManager[481]: <info> [1765012091.5688] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 05:12:02 tracey-aspiretc780 systemd[1]: flatpak-system-helper.service: Deactivated successfully.
Dec 06 05:12:02 tracey-aspiretc780 systemd[1]: flatpak-system-helper.service: Consumed 1.563s CPU time, 57.5M memory peak.
Dec 06 05:14:24 tracey-aspiretc780 systemd[1]: Starting Rotate log files...
Dec 06 05:14:25 tracey-aspiretc780 systemd[1]: logrotate.service: Deactivated successfully.
Dec 06 05:14:25 tracey-aspiretc780 systemd[1]: Finished Rotate log files.
Dec 06 05:15:02 tracey-aspiretc780 NetworkManager[481]: <info> [1765012502.5212] device (wlp2s0): set-hw-addr: set MAC address to 2E:68:47:E7:43:16 (scanning)
Dec 06 05:15:02 tracey-aspiretc780 NetworkManager[481]: <info> [1765012502.5563] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 06 05:15:02 tracey-aspiretc780 NetworkManager[481]: <info> [1765012502.5564] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 06 05:15:02 tracey-aspiretc780 NetworkManager[481]: <info> [1765012502.5620] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 05:15:02 tracey-aspiretc780 NetworkManager[481]: <info> [1765012502.5621] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 05:16:31 tracey-aspiretc780 systemd[1]: Starting Cleanup of Temporary Directories...
Dec 06 05:16:31 tracey-aspiretc780 systemd[1]: systemd-tmpfiles-clean.service: Deactivated successfully.
Dec 06 05:16:31 tracey-aspiretc780 systemd[1]: Finished Cleanup of Temporary Directories.
Dec 06 05:21:54 tracey-aspiretc780 NetworkManager[481]: <info> [1765012914.5412] device (wlp2s0): set-hw-addr: set MAC address to FE:5D:8F:0A:38:DD (scanning)
Dec 06 05:21:54 tracey-aspiretc780 NetworkManager[481]: <info> [1765012914.5662] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 06 05:21:54 tracey-aspiretc780 NetworkManager[481]: <info> [1765012914.5663] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 06 05:21:54 tracey-aspiretc780 NetworkManager[481]: <info> [1765012914.5719] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 05:21:54 tracey-aspiretc780 NetworkManager[481]: <info> [1765012914.5720] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 05:24:26 tracey-aspiretc780 systemd[594]: Started Chromium - Web Browser.
Dec 06 05:24:31 tracey-aspiretc780 systemd[594]: Created slice Slice /app/dbus-:1.2-org.kde.kwalletd6.
Dec 06 05:24:31 tracey-aspiretc780 systemd[594]: Started dbus-:1.2-org.kde.kwalletd6@0.service.
Dec 06 05:24:32 tracey-aspiretc780 systemd[594]: dbus-:1.2-org.kde.kwalletd6@0.service: Main process exited, code=exited, status=255/EXCEPTION
Dec 06 05:24:32 tracey-aspiretc780 systemd[594]: dbus-:1.2-org.kde.kwalletd6@0.service: Failed with result 'exit-code'.
Dec 06 05:24:32 tracey-aspiretc780 chromium[1210]: [1210:1210:1206/052432.329901:ERROR:dbus/object_proxy.cc:573] Failed to call method: org.kde.KWallet.isEnabled: object_path= /modules/kwalletd6: org.freedesktop.DBus.Error.NameHasNoOwner: Could not activate remote peer 'org.kde.kwalletd6': unit failed
Dec 06 05:24:32 tracey-aspiretc780 chromium[1210]: [1210:1210:1206/052432.329964:ERROR:components/os_crypt/sync/kwallet_dbus.cc:113] Error contacting kwalletd6 (isEnabled)
Dec 06 05:24:32 tracey-aspiretc780 chromium[1210]: [1210:1210:1206/052432.330097:ERROR:dbus/object_proxy.cc:573] Failed to call method: org.kde.KLauncher.start_service_by_desktop_name: object_path= /KLauncher: org.freedesktop.DBus.Error.ServiceUnknown: The name is not activatable
Dec 06 05:24:32 tracey-aspiretc780 chromium[1210]: [1210:1210:1206/052432.330104:ERROR:components/os_crypt/sync/kwallet_dbus.cc:82] Error contacting klauncher to start kwalletd6
Dec 06 05:24:32 tracey-aspiretc780 systemd[594]: Started dbus-:1.2-org.kde.kwalletd6@1.service.
Dec 06 05:24:32 tracey-aspiretc780 systemd[594]: dbus-:1.2-org.kde.kwalletd6@1.service: Main process exited, code=exited, status=255/EXCEPTION
Dec 06 05:24:32 tracey-aspiretc780 systemd[594]: dbus-:1.2-org.kde.kwalletd6@1.service: Failed with result 'exit-code'.
Dec 06 05:24:32 tracey-aspiretc780 chromium[1210]: [1210:1210:1206/052432.521916:ERROR:dbus/object_proxy.cc:573] Failed to call method: org.kde.KWallet.close: object_path= /modules/kwalletd6: org.freedesktop.DBus.Error.NameHasNoOwner: Could not activate remote peer 'org.kde.kwalletd6': unit failed
Dec 06 05:24:32 tracey-aspiretc780 chromium[1210]: [1210:1210:1206/052432.521932:ERROR:components/os_crypt/sync/kwallet_dbus.cc:408] Error contacting kwalletd6 (close)
Dec 06 05:24:37 tracey-aspiretc780 systemd[594]: Starting Accessibility services bus...
Dec 06 05:24:37 tracey-aspiretc780 systemd[594]: Started Accessibility services bus.
Dec 06 05:24:37 tracey-aspiretc780 dbus-broker-launch[1318]: Ready
Dec 06 05:24:37 tracey-aspiretc780 systemd[594]: Created slice Slice /app/dbus-:1.59-org.a11y.atspi.Registry.
Dec 06 05:24:37 tracey-aspiretc780 systemd[594]: Started dbus-:1.59-org.a11y.atspi.Registry@0.service.
Dec 06 05:24:37 tracey-aspiretc780 at-spi2-registryd[1320]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Dec 06 05:24:39 tracey-aspiretc780 systemd[594]: Started app-org.chromium.Chromium-1210.scope.
Dec 06 05:24:40 tracey-aspiretc780 systemd[594]: Started dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@1.service.
Dec 06 05:24:40 tracey-aspiretc780 systemd[594]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@1.service: Main process exited, code=exited, status=255/EXCEPTION
Dec 06 05:24:40 tracey-aspiretc780 systemd[594]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@1.service: Failed with result 'exit-code'.
Dec 06 05:24:40 tracey-aspiretc780 systemd[594]: Started dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@2.service.
Dec 06 05:24:41 tracey-aspiretc780 systemd[594]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@2.service: Main process exited, code=exited, status=255/EXCEPTION
Dec 06 05:24:41 tracey-aspiretc780 systemd[594]: dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet@2.service: Failed with result 'exit-code'.
Dec 06 05:24:41 tracey-aspiretc780 xdg-desktop-por[647]: Backend call failed: Could not activate remote peer 'org.freedesktop.impl.portal.desktop.kwallet': unit failed
Dec 06 05:24:41 tracey-aspiretc780 chromium[1210]: [1210:1210:1206/052441.429511:ERROR:components/dbus/xdg/request.cc:164] Request ended (non-user cancelled).
Dec 06 05:24:42 tracey-aspiretc780 systemd[594]: Started dbus-:1.2-org.kde.kwalletd6@2.service.
Dec 06 05:24:42 tracey-aspiretc780 systemd[594]: dbus-:1.2-org.kde.kwalletd6@2.service: Main process exited, code=exited, status=255/EXCEPTION
Dec 06 05:24:42 tracey-aspiretc780 systemd[594]: dbus-:1.2-org.kde.kwalletd6@2.service: Failed with result 'exit-code'.
Dec 06 05:24:46 tracey-aspiretc780 chromium[1210]: [1210:1230:1206/052446.789637:ERROR:google_apis/gcm/engine/registration_request.cc:292] Registration response error message: DEPRECATED_ENDPOINT
Dec 06 05:24:48 tracey-aspiretc780 chromium[1210]: [1210:1210:1206/052448.704056:ERROR:mojo/public/cpp/bindings/lib/interface_endpoint_client.cc:732] Message 0 rejected by interface blink.mojom.WidgetHost
Dec 06 05:24:48 tracey-aspiretc780 chromium[1210]: [1210:1210:1206/052448.704612:ERROR:mojo/public/cpp/bindings/lib/interface_endpoint_client.cc:732] Message 0 rejected by interface blink.mojom.WidgetHost
Dec 06 05:25:06 tracey-aspiretc780 chrome[1210]: [1210:1226:1206/052506.596261:INFO:chrome/browser/extensions/extension_garbage_collector.cc:188] Garbage collection for extensions on file thread is complete.
Dec 06 05:25:14 tracey-aspiretc780 chromium[1210]: [1210:1230:1206/052514.572147:ERROR:google_apis/gcm/engine/registration_request.cc:292] Registration response error message: DEPRECATED_ENDPOINT
Dec 06 05:26:04 tracey-aspiretc780 chromium[1210]: [1210:1230:1206/052604.138485:ERROR:google_apis/gcm/engine/registration_request.cc:292] Registration response error message: DEPRECATED_ENDPOINT
Dec 06 05:27:31 tracey-aspiretc780 chromium[1210]: [1210:1230:1206/052731.302472:ERROR:google_apis/gcm/engine/registration_request.cc:292] Registration response error message: DEPRECATED_ENDPOINT
Dec 06 05:28:47 tracey-aspiretc780 NetworkManager[481]: <info> [1765013327.5178] device (wlp2s0): set-hw-addr: set MAC address to A6:73:F8:1C:F0:97 (scanning)
Dec 06 05:28:47 tracey-aspiretc780 NetworkManager[481]: <info> [1765013327.5527] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 06 05:28:47 tracey-aspiretc780 NetworkManager[481]: <info> [1765013327.5528] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 06 05:28:47 tracey-aspiretc780 NetworkManager[481]: <info> [1765013327.5584] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 05:28:47 tracey-aspiretc780 NetworkManager[481]: <info> [1765013327.5584] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 05:30:17 tracey-aspiretc780 chromium[1210]: [1210:1230:1206/053017.125100:ERROR:google_apis/gcm/engine/registration_request.cc:292] Registration response error message: DEPRECATED_ENDPOINT
Dec 06 05:35:39 tracey-aspiretc780 NetworkManager[481]: <info> [1765013739.5245] device (wlp2s0): set-hw-addr: set MAC address to 3A:53:08:5B:3B:D0 (scanning)
Dec 06 05:37:07 tracey-aspiretc780 chromium[1210]: [1210:1230:1206/053707.490104:ERROR:google_apis/gcm/engine/registration_request.cc:292] Registration response error message: DEPRECATED_ENDPOINT
Dec 06 05:41:58 tracey-aspiretc780 chromium[1210]: [1210:1210:1206/054158.511123:ERROR:mojo/public/cpp/bindings/lib/interface_endpoint_client.cc:732] Message 0 rejected by interface blink.mojom.WidgetHost
Dec 06 05:42:01 tracey-aspiretc780 chromium[1249]: [1249:1254:1206/054201.721617:ERROR:services/network/p2p/socket_manager.cc:137] Failed to resolve address for global.stun.twilio.com., errorcode: -105
Dec 06 05:42:01 tracey-aspiretc780 chromium[1249]: [1249:1254:1206/054201.721789:ERROR:services/network/p2p/socket_manager.cc:137] Failed to resolve address for stun.smartgslb.com., errorcode: -105
Dec 06 05:42:01 tracey-aspiretc780 chromium[1249]: [1249:1254:1206/054201.750843:ERROR:services/network/p2p/socket_manager.cc:137] Failed to resolve address for jp1.stun.twilio.com., errorcode: -105
Dec 06 05:42:01 tracey-aspiretc780 chromium[1249]: [1249:1254:1206/054201.753176:ERROR:services/network/p2p/socket_manager.cc:137] Failed to resolve address for stun.miwifi.com., errorcode: -105
Dec 06 05:42:01 tracey-aspiretc780 chromium[1249]: [1249:1254:1206/054201.815176:ERROR:services/network/p2p/socket_manager.cc:137] Failed to resolve address for hw-v2-web-player-tracker.biliapi.net., errorcode: -105
Dec 06 05:42:29 tracey-aspiretc780 NetworkManager[481]: <info> [1765014149.5311] device (wlp2s0): set-hw-addr: set MAC address to 5E:34:FE:85:28:93 (scanning)
Dec 06 05:42:29 tracey-aspiretc780 NetworkManager[481]: <info> [1765014149.5626] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 06 05:42:29 tracey-aspiretc780 NetworkManager[481]: <info> [1765014149.5627] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 06 05:42:29 tracey-aspiretc780 NetworkManager[481]: <info> [1765014149.5683] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 05:42:29 tracey-aspiretc780 NetworkManager[481]: <info> [1765014149.5684] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 05:49:20 tracey-aspiretc780 NetworkManager[481]: <info> [1765014560.5166] device (wlp2s0): set-hw-addr: set MAC address to D2:50:36:29:60:33 (scanning)
Dec 06 05:49:20 tracey-aspiretc780 NetworkManager[481]: <info> [1765014560.5455] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 06 05:49:20 tracey-aspiretc780 NetworkManager[481]: <info> [1765014560.5456] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 06 05:49:20 tracey-aspiretc780 NetworkManager[481]: <info> [1765014560.5507] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 05:49:20 tracey-aspiretc780 NetworkManager[481]: <info> [1765014560.5507] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 05:56:12 tracey-aspiretc780 NetworkManager[481]: <info> [1765014972.5238] device (wlp2s0): set-hw-addr: set MAC address to 3A:A4:D3:9A:F4:6E (scanning)
Dec 06 06:01:00 tracey-aspiretc780 CROND[2286]: (root) CMD (run-parts /etc/cron.hourly)
Dec 06 06:01:00 tracey-aspiretc780 anacron[2293]: Anacron started on 2025-12-06
Dec 06 06:01:00 tracey-aspiretc780 CROND[2285]: (root) CMDEND (run-parts /etc/cron.hourly)
Dec 06 06:01:00 tracey-aspiretc780 anacron[2293]: Will run job `cron.daily' in 21 min.
Dec 06 06:01:00 tracey-aspiretc780 anacron[2293]: Jobs will be executed sequentially
Dec 06 06:01:26 tracey-aspiretc780 NetworkManager[481]: <info> [1765015286.8605] dhcp4 (enp1s0): state changed new lease, address=192.168.0.89
Dec 06 06:01:26 tracey-aspiretc780 systemd[1]: Starting Network Manager Script Dispatcher Service...
Dec 06 06:01:26 tracey-aspiretc780 systemd[1]: Started Network Manager Script Dispatcher Service.
Dec 06 06:01:36 tracey-aspiretc780 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Dec 06 06:01:55 tracey-aspiretc780 pamac-tray-plas[955]: updates_checker.vala:59: check updates
Dec 06 06:03:05 tracey-aspiretc780 NetworkManager[481]: <info> [1765015385.5173] device (wlp2s0): set-hw-addr: set MAC address to B6:AD:26:81:6A:B2 (scanning)
Dec 06 06:03:05 tracey-aspiretc780 NetworkManager[481]: <info> [1765015385.5237] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 06 06:03:05 tracey-aspiretc780 NetworkManager[481]: <info> [1765015385.5238] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 06 06:03:05 tracey-aspiretc780 NetworkManager[481]: <info> [1765015385.5239] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 06:03:05 tracey-aspiretc780 NetworkManager[481]: <info> [1765015385.5240] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 06:09:58 tracey-aspiretc780 NetworkManager[481]: <info> [1765015798.5139] device (wlp2s0): set-hw-addr: set MAC address to FE:03:04:11:FD:94 (scanning)
Dec 06 06:16:50 tracey-aspiretc780 NetworkManager[481]: <info> [1765016210.5144] device (wlp2s0): set-hw-addr: set MAC address to B6:5C:3C:94:45:DD (scanning)
Dec 06 06:16:50 tracey-aspiretc780 NetworkManager[481]: <info> [1765016210.5365] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 06 06:16:50 tracey-aspiretc780 NetworkManager[481]: <info> [1765016210.5366] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 06 06:16:50 tracey-aspiretc780 NetworkManager[481]: <info> [1765016210.5420] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 06:16:50 tracey-aspiretc780 NetworkManager[481]: <info> [1765016210.5421] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 06:22:00 tracey-aspiretc780 anacron[2293]: Job `cron.daily' started
Dec 06 06:22:00 tracey-aspiretc780 anacron[2293]: Job `cron.daily' terminated
Dec 06 06:22:00 tracey-aspiretc780 anacron[2293]: Normal exit (1 job run)
Dec 06 06:23:41 tracey-aspiretc780 NetworkManager[481]: <info> [1765016621.5174] device (wlp2s0): set-hw-addr: set MAC address to 9A:A4:22:F2:AF:94 (scanning)
Dec 06 06:30:34 tracey-aspiretc780 NetworkManager[481]: <info> [1765017034.5240] device (wlp2s0): set-hw-addr: set MAC address to 7E:9F:F3:23:5F:14 (scanning)
Dec 06 06:37:28 tracey-aspiretc780 NetworkManager[481]: <info> [1765017448.5160] device (wlp2s0): set-hw-addr: set MAC address to 42:45:35:13:D4:E4 (scanning)
Dec 06 06:44:20 tracey-aspiretc780 NetworkManager[481]: <info> [1765017860.5231] device (wlp2s0): set-hw-addr: set MAC address to FE:82:35:20:23:29 (scanning)
Dec 06 06:51:12 tracey-aspiretc780 NetworkManager[481]: <info> [1765018272.5128] device (wlp2s0): set-hw-addr: set MAC address to 0A:6C:DB:10:84:D8 (scanning)
Dec 06 06:56:44 tracey-aspiretc780 NetworkManager[481]: <info> [1765018604.8553] dhcp4 (enp1s0): state changed new lease, address=192.168.0.89
Dec 06 06:56:44 tracey-aspiretc780 systemd[1]: Starting Network Manager Script Dispatcher Service...
Dec 06 06:56:44 tracey-aspiretc780 systemd[1]: Started Network Manager Script Dispatcher Service.
Dec 06 06:56:54 tracey-aspiretc780 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Dec 06 06:57:00 tracey-aspiretc780 kernel: perf: interrupt took too long (2503 > 2500), lowering kernel.perf_event_max_sample_rate to 79800
Dec 06 06:58:03 tracey-aspiretc780 NetworkManager[481]: <info> [1765018683.5301] device (wlp2s0): set-hw-addr: set MAC address to 9E:AC:33:69:67:C4 (scanning)
Dec 06 07:01:00 tracey-aspiretc780 CROND[2681]: (root) CMD (run-parts /etc/cron.hourly)
Dec 06 07:01:00 tracey-aspiretc780 CROND[2680]: (root) CMDEND (run-parts /etc/cron.hourly)
Dec 06 07:01:55 tracey-aspiretc780 pamac-tray-plas[955]: updates_checker.vala:59: check updates
Dec 06 07:04:56 tracey-aspiretc780 NetworkManager[481]: <info> [1765019096.5236] device (wlp2s0): set-hw-addr: set MAC address to 2E:B1:C3:0C:0B:10 (scanning)
Dec 06 07:07:55 tracey-aspiretc780 kernel: usb 1-3: USB disconnect, device number 2
Dec 06 07:07:55 tracey-aspiretc780 kernel: usb 1-3: new high-speed USB device number 7 using xhci_hcd
Dec 06 07:07:55 tracey-aspiretc780 kernel: usb 1-3: New USB device found, idVendor=1908, idProduct=2311, bcdDevice= 1.00
Dec 06 07:07:55 tracey-aspiretc780 kernel: usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dec 06 07:07:55 tracey-aspiretc780 kernel: usb 1-3: Product: USB2.0 PC CAMERA
Dec 06 07:07:55 tracey-aspiretc780 kernel: usb 1-3: Manufacturer: Generic
Dec 06 07:07:55 tracey-aspiretc780 kernel: usb 1-3: Found UVC 1.00 device USB2.0 PC CAMERA (1908:2311)
Dec 06 07:07:55 tracey-aspiretc780 kernel: input: USB2.0 PC CAMERA: USB2.0 PC CAM as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/input/input25
Dec 06 07:07:55 tracey-aspiretc780 mtp-probe[2723]: checking bus 1, device 7: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3"
Dec 06 07:07:55 tracey-aspiretc780 mtp-probe[2723]: bus: 1, device: 7 was not an MTP device
Dec 06 07:07:55 tracey-aspiretc780 mtp-probe[2732]: checking bus 1, device 7: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3"
Dec 06 07:07:55 tracey-aspiretc780 mtp-probe[2732]: bus: 1, device: 7 was not an MTP device
Dec 06 07:07:55 tracey-aspiretc780 plasmashell[703]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/delegates/DelegatePopup.qml:147:17: QML Body: Binding loop detected for property "width"
Dec 06 07:11:49 tracey-aspiretc780 NetworkManager[481]: <info> [1765019509.5236] device (wlp2s0): set-hw-addr: set MAC address to 72:81:48:45:8E:4A (scanning)
Dec 06 07:11:49 tracey-aspiretc780 NetworkManager[481]: <info> [1765019509.5421] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 06 07:11:49 tracey-aspiretc780 NetworkManager[481]: <info> [1765019509.5422] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 06 07:11:49 tracey-aspiretc780 NetworkManager[481]: <info> [1765019509.5477] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 07:11:49 tracey-aspiretc780 NetworkManager[481]: <info> [1765019509.5478] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 07:18:41 tracey-aspiretc780 NetworkManager[481]: <info> [1765019921.5206] device (wlp2s0): set-hw-addr: set MAC address to A6:0D:44:92:06:84 (scanning)
Dec 06 07:18:41 tracey-aspiretc780 NetworkManager[481]: <info> [1765019921.5421] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 06 07:18:41 tracey-aspiretc780 NetworkManager[481]: <info> [1765019921.5422] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 06 07:18:41 tracey-aspiretc780 NetworkManager[481]: <info> [1765019921.5476] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 07:18:41 tracey-aspiretc780 NetworkManager[481]: <info> [1765019921.5476] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 07:24:56 tracey-aspiretc780 kernel: perf: interrupt took too long (3164 > 3128), lowering kernel.perf_event_max_sample_rate to 63000
Dec 06 07:25:32 tracey-aspiretc780 NetworkManager[481]: <info> [1765020332.5202] device (wlp2s0): set-hw-addr: set MAC address to 22:34:B8:94:47:B8 (scanning)
Dec 06 07:32:24 tracey-aspiretc780 NetworkManager[481]: <info> [1765020744.5166] device (wlp2s0): set-hw-addr: set MAC address to BE:08:30:E9:C0:44 (scanning)
Dec 06 07:39:16 tracey-aspiretc780 NetworkManager[481]: <info> [1765021156.5307] device (wlp2s0): set-hw-addr: set MAC address to A2:BC:F8:2F:01:7C (scanning)
Dec 06 07:46:09 tracey-aspiretc780 NetworkManager[481]: <info> [1765021569.5173] device (wlp2s0): set-hw-addr: set MAC address to 02:A0:B5:03:5F:85 (scanning)
Dec 06 07:46:09 tracey-aspiretc780 NetworkManager[481]: <info> [1765021569.5222] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 06 07:46:09 tracey-aspiretc780 NetworkManager[481]: <info> [1765021569.5223] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 06 07:46:09 tracey-aspiretc780 NetworkManager[481]: <info> [1765021569.5228] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 07:46:09 tracey-aspiretc780 NetworkManager[481]: <info> [1765021569.5228] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 07:50:31 tracey-aspiretc780 NetworkManager[481]: <info> [1765021831.8627] dhcp4 (enp1s0): state changed new lease, address=192.168.0.89
Dec 06 07:50:31 tracey-aspiretc780 systemd[1]: Starting Network Manager Script Dispatcher Service...
Dec 06 07:50:31 tracey-aspiretc780 systemd[1]: Started Network Manager Script Dispatcher Service.
Dec 06 07:50:41 tracey-aspiretc780 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Dec 06 07:53:00 tracey-aspiretc780 NetworkManager[481]: <info> [1765021980.5225] device (wlp2s0): set-hw-addr: set MAC address to 72:65:B1:73:83:D9 (scanning)
Dec 06 07:53:00 tracey-aspiretc780 NetworkManager[481]: <info> [1765021980.5415] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 06 07:53:00 tracey-aspiretc780 NetworkManager[481]: <info> [1765021980.5416] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 06 07:53:00 tracey-aspiretc780 NetworkManager[481]: <info> [1765021980.5468] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 07:53:00 tracey-aspiretc780 NetworkManager[481]: <info> [1765021980.5469] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 07:59:51 tracey-aspiretc780 NetworkManager[481]: <info> [1765022391.5210] device (wlp2s0): set-hw-addr: set MAC address to BA:EE:BF:12:E5:DF (scanning)
Dec 06 07:59:51 tracey-aspiretc780 NetworkManager[481]: <info> [1765022391.5254] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 06 07:59:51 tracey-aspiretc780 NetworkManager[481]: <info> [1765022391.5255] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 06 07:59:51 tracey-aspiretc780 NetworkManager[481]: <info> [1765022391.5312] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 07:59:51 tracey-aspiretc780 NetworkManager[481]: <info> [1765022391.5313] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 08:01:00 tracey-aspiretc780 CROND[2978]: (root) CMD (run-parts /etc/cron.hourly)
Dec 06 08:01:00 tracey-aspiretc780 CROND[2977]: (root) CMDEND (run-parts /etc/cron.hourly)
Dec 06 08:01:55 tracey-aspiretc780 pamac-tray-plas[955]: updates_checker.vala:59: check updates
Dec 06 08:06:43 tracey-aspiretc780 NetworkManager[481]: <info> [1765022803.5157] device (wlp2s0): set-hw-addr: set MAC address to D6:A8:BA:96:31:D8 (scanning)
Dec 06 08:09:05 tracey-aspiretc780 kernel: perf: interrupt took too long (3980 > 3955), lowering kernel.perf_event_max_sample_rate to 50100
Dec 06 08:13:35 tracey-aspiretc780 NetworkManager[481]: <info> [1765023215.5198] device (wlp2s0): set-hw-addr: set MAC address to 96:BE:D4:FC:DC:11 (scanning)
Dec 06 08:20:28 tracey-aspiretc780 NetworkManager[481]: <info> [1765023628.5202] device (wlp2s0): set-hw-addr: set MAC address to 26:15:2C:3A:77:02 (scanning)
Dec 06 08:27:20 tracey-aspiretc780 NetworkManager[481]: <info> [1765024040.5373] device (wlp2s0): set-hw-addr: set MAC address to 26:E1:84:BD:16:7F (scanning)
Dec 06 08:34:10 tracey-aspiretc780 NetworkManager[481]: <info> [1765024450.5167] device (wlp2s0): set-hw-addr: set MAC address to 4A:41:60:6D:31:AC (scanning)
Dec 06 08:34:10 tracey-aspiretc780 NetworkManager[481]: <info> [1765024450.5229] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 06 08:34:10 tracey-aspiretc780 NetworkManager[481]: <info> [1765024450.5229] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 06 08:34:10 tracey-aspiretc780 NetworkManager[481]: <info> [1765024450.5232] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 08:34:10 tracey-aspiretc780 NetworkManager[481]: <info> [1765024450.5232] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 08:41:02 tracey-aspiretc780 NetworkManager[481]: <info> [1765024862.5237] device (wlp2s0): set-hw-addr: set MAC address to B2:B1:7B:6C:CD:76 (scanning)
Dec 06 08:45:53 tracey-aspiretc780 NetworkManager[481]: <info> [1765025153.8545] dhcp4 (enp1s0): state changed new lease, address=192.168.0.89
Dec 06 08:45:53 tracey-aspiretc780 systemd[1]: Starting Network Manager Script Dispatcher Service...
Dec 06 08:45:53 tracey-aspiretc780 systemd[1]: Started Network Manager Script Dispatcher Service.
Dec 06 08:46:03 tracey-aspiretc780 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Dec 06 08:47:54 tracey-aspiretc780 NetworkManager[481]: <info> [1765025274.5163] device (wlp2s0): set-hw-addr: set MAC address to 5A:4A:A5:AE:25:4A (scanning)
Dec 06 08:47:54 tracey-aspiretc780 NetworkManager[481]: <info> [1765025274.5382] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 06 08:47:54 tracey-aspiretc780 NetworkManager[481]: <info> [1765025274.5383] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 06 08:47:54 tracey-aspiretc780 NetworkManager[481]: <info> [1765025274.5440] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 08:47:54 tracey-aspiretc780 NetworkManager[481]: <info> [1765025274.5441] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 08:54:48 tracey-aspiretc780 NetworkManager[481]: <info> [1765025688.5191] device (wlp2s0): set-hw-addr: set MAC address to 36:BB:4E:28:71:51 (scanning)
Dec 06 08:54:48 tracey-aspiretc780 NetworkManager[481]: <info> [1765025688.5378] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 06 08:54:48 tracey-aspiretc780 NetworkManager[481]: <info> [1765025688.5379] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 06 08:54:48 tracey-aspiretc780 NetworkManager[481]: <info> [1765025688.5431] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 08:54:48 tracey-aspiretc780 NetworkManager[481]: <info> [1765025688.5431] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 09:01:00 tracey-aspiretc780 CROND[3235]: (root) CMD (run-parts /etc/cron.hourly)
Dec 06 09:01:00 tracey-aspiretc780 CROND[3234]: (root) CMDEND (run-parts /etc/cron.hourly)
Dec 06 09:01:39 tracey-aspiretc780 NetworkManager[481]: <info> [1765026099.5236] device (wlp2s0): set-hw-addr: set MAC address to 76:9B:3D:9C:01:F9 (scanning)
Dec 06 09:01:39 tracey-aspiretc780 NetworkManager[481]: <info> [1765026099.5412] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 06 09:01:39 tracey-aspiretc780 NetworkManager[481]: <info> [1765026099.5413] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 06 09:01:39 tracey-aspiretc780 NetworkManager[481]: <info> [1765026099.5466] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 09:01:39 tracey-aspiretc780 NetworkManager[481]: <info> [1765026099.5466] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 09:01:55 tracey-aspiretc780 pamac-tray-plas[955]: updates_checker.vala:59: check updates
Dec 06 09:08:31 tracey-aspiretc780 NetworkManager[481]: <info> [1765026511.5126] device (wlp2s0): set-hw-addr: set MAC address to 8E:9C:AB:61:4A:52 (scanning)
Dec 06 09:15:23 tracey-aspiretc780 NetworkManager[481]: <info> [1765026923.5225] device (wlp2s0): set-hw-addr: set MAC address to 82:E2:93:8C:11:79 (scanning)
Dec 06 09:15:23 tracey-aspiretc780 NetworkManager[481]: <info> [1765026923.5412] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 06 09:15:23 tracey-aspiretc780 NetworkManager[481]: <info> [1765026923.5413] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 06 09:15:23 tracey-aspiretc780 NetworkManager[481]: <info> [1765026923.5464] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 09:15:23 tracey-aspiretc780 NetworkManager[481]: <info> [1765026923.5464] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 09:22:15 tracey-aspiretc780 NetworkManager[481]: <info> [1765027335.5194] device (wlp2s0): set-hw-addr: set MAC address to 2A:82:79:45:B3:D2 (scanning)
Dec 06 09:22:15 tracey-aspiretc780 NetworkManager[481]: <info> [1765027335.5476] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 06 09:22:15 tracey-aspiretc780 NetworkManager[481]: <info> [1765027335.5477] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 06 09:22:15 tracey-aspiretc780 NetworkManager[481]: <info> [1765027335.5529] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 09:22:15 tracey-aspiretc780 NetworkManager[481]: <info> [1765027335.5529] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 09:29:08 tracey-aspiretc780 NetworkManager[481]: <info> [1765027748.5169] device (wlp2s0): set-hw-addr: set MAC address to E2:07:4C:83:B7:E5 (scanning)
Dec 06 09:29:08 tracey-aspiretc780 NetworkManager[481]: <info> [1765027748.5210] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 06 09:29:08 tracey-aspiretc780 NetworkManager[481]: <info> [1765027748.5211] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 06 09:29:08 tracey-aspiretc780 NetworkManager[481]: <info> [1765027748.5215] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 09:29:08 tracey-aspiretc780 NetworkManager[481]: <info> [1765027748.5216] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 09:35:59 tracey-aspiretc780 NetworkManager[481]: <info> [1765028159.5258] device (wlp2s0): set-hw-addr: set MAC address to 6A:28:62:84:E2:91 (scanning)
Dec 06 09:39:13 tracey-aspiretc780 NetworkManager[481]: <info> [1765028353.8734] dhcp4 (enp1s0): state changed new lease, address=192.168.0.89
Dec 06 09:39:13 tracey-aspiretc780 systemd[1]: Starting Network Manager Script Dispatcher Service...
Dec 06 09:39:13 tracey-aspiretc780 systemd[1]: Started Network Manager Script Dispatcher Service.
Dec 06 09:39:23 tracey-aspiretc780 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Dec 06 09:42:50 tracey-aspiretc780 NetworkManager[481]: <info> [1765028570.5126] device (wlp2s0): set-hw-addr: set MAC address to 9E:E9:B9:80:F0:07 (scanning)
Dec 06 09:43:21 tracey-aspiretc780 kernel: perf: interrupt took too long (4986 > 4975), lowering kernel.perf_event_max_sample_rate to 39900
Dec 06 09:49:41 tracey-aspiretc780 NetworkManager[481]: <info> [1765028981.5263] device (wlp2s0): set-hw-addr: set MAC address to C2:E8:6A:EA:55:22 (scanning)
Dec 06 09:56:34 tracey-aspiretc780 NetworkManager[481]: <info> [1765029394.5261] device (wlp2s0): set-hw-addr: set MAC address to C2:AE:F8:E6:89:4B (scanning)
Dec 06 09:56:34 tracey-aspiretc780 NetworkManager[481]: <info> [1765029394.5447] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 06 09:56:34 tracey-aspiretc780 NetworkManager[481]: <info> [1765029394.5448] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 06 09:56:34 tracey-aspiretc780 NetworkManager[481]: <info> [1765029394.5513] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 09:56:34 tracey-aspiretc780 NetworkManager[481]: <info> [1765029394.5514] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 10:01:00 tracey-aspiretc780 CROND[3502]: (root) CMD (run-parts /etc/cron.hourly)
Dec 06 10:01:01 tracey-aspiretc780 CROND[3501]: (root) CMDEND (run-parts /etc/cron.hourly)
Dec 06 10:01:55 tracey-aspiretc780 pamac-tray-plas[955]: updates_checker.vala:59: check updates
Dec 06 10:03:27 tracey-aspiretc780 NetworkManager[481]: <info> [1765029807.5206] device (wlp2s0): set-hw-addr: set MAC address to 66:E3:FC:9F:FC:A8 (scanning)
Dec 06 10:10:19 tracey-aspiretc780 NetworkManager[481]: <info> [1765030219.5184] device (wlp2s0): set-hw-addr: set MAC address to 36:BF:2C:9C:BD:5F (scanning)
Dec 06 10:15:29 tracey-aspiretc780 kernel: usb 1-3: USB disconnect, device number 7
Dec 06 10:15:29 tracey-aspiretc780 kded6[677]: kf.notifications: Failed to notify "Created too many similar notifications in quick succession"
Dec 06 10:15:29 tracey-aspiretc780 kernel: usb 1-3: new high-speed USB device number 8 using xhci_hcd
Dec 06 10:15:29 tracey-aspiretc780 kernel: usb 1-3: New USB device found, idVendor=1908, idProduct=2311, bcdDevice= 1.00
Dec 06 10:15:29 tracey-aspiretc780 kernel: usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dec 06 10:15:29 tracey-aspiretc780 kernel: usb 1-3: Product: USB2.0 PC CAMERA
Dec 06 10:15:29 tracey-aspiretc780 kernel: usb 1-3: Manufacturer: Generic
Dec 06 10:15:29 tracey-aspiretc780 kernel: usb 1-3: Found UVC 1.00 device USB2.0 PC CAMERA (1908:2311)
Dec 06 10:15:29 tracey-aspiretc780 kernel: input: USB2.0 PC CAMERA: USB2.0 PC CAM as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/input/input26
Dec 06 10:15:29 tracey-aspiretc780 mtp-probe[3590]: checking bus 1, device 8: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3"
Dec 06 10:15:29 tracey-aspiretc780 mtp-probe[3590]: bus: 1, device: 8 was not an MTP device
Dec 06 10:15:29 tracey-aspiretc780 plasmashell[703]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/delegates/DelegatePopup.qml:147:17: QML Body: Binding loop detected for property "width"
Dec 06 10:15:29 tracey-aspiretc780 mtp-probe[3603]: checking bus 1, device 8: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3"
Dec 06 10:15:29 tracey-aspiretc780 mtp-probe[3603]: bus: 1, device: 8 was not an MTP device
Dec 06 10:17:10 tracey-aspiretc780 NetworkManager[481]: <info> [1765030630.5161] device (wlp2s0): set-hw-addr: set MAC address to 12:2E:41:5C:51:16 (scanning)
Dec 06 10:24:02 tracey-aspiretc780 NetworkManager[481]: <info> [1765031042.5302] device (wlp2s0): set-hw-addr: set MAC address to DA:53:C1:C6:42:68 (scanning)
Dec 06 10:27:09 tracey-aspiretc780 kernel: usb 1-3: USB disconnect, device number 8
Dec 06 10:27:10 tracey-aspiretc780 kded6[677]: kf.notifications: Failed to notify "Created too many similar notifications in quick succession"
Dec 06 10:27:10 tracey-aspiretc780 kernel: usb 1-3: new high-speed USB device number 9 using xhci_hcd
Dec 06 10:27:10 tracey-aspiretc780 kernel: usb 1-3: New USB device found, idVendor=1908, idProduct=2311, bcdDevice= 1.00
Dec 06 10:27:10 tracey-aspiretc780 kernel: usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dec 06 10:27:10 tracey-aspiretc780 kernel: usb 1-3: Product: USB2.0 PC CAMERA
Dec 06 10:27:10 tracey-aspiretc780 kernel: usb 1-3: Manufacturer: Generic
Dec 06 10:27:10 tracey-aspiretc780 kernel: usb 1-3: Found UVC 1.00 device USB2.0 PC CAMERA (1908:2311)
Dec 06 10:27:10 tracey-aspiretc780 kernel: input: USB2.0 PC CAMERA: USB2.0 PC CAM as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/input/input27
Dec 06 10:27:10 tracey-aspiretc780 mtp-probe[3687]: checking bus 1, device 9: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3"
Dec 06 10:27:10 tracey-aspiretc780 mtp-probe[3687]: bus: 1, device: 9 was not an MTP device
Dec 06 10:27:10 tracey-aspiretc780 plasmashell[703]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/delegates/DelegatePopup.qml:147:17: QML Body: Binding loop detected for property "width"
Dec 06 10:27:10 tracey-aspiretc780 mtp-probe[3699]: checking bus 1, device 9: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3"
Dec 06 10:27:10 tracey-aspiretc780 mtp-probe[3699]: bus: 1, device: 9 was not an MTP device
Dec 06 10:30:55 tracey-aspiretc780 NetworkManager[481]: <info> [1765031455.5228] device (wlp2s0): set-hw-addr: set MAC address to 12:A5:64:B1:E0:E4 (scanning)
Dec 06 10:30:56 tracey-aspiretc780 kernel: usb 1-3: USB disconnect, device number 9
Dec 06 10:30:56 tracey-aspiretc780 kded6[677]: kf.notifications: Failed to notify "Created too many similar notifications in quick succession"
Dec 06 10:30:56 tracey-aspiretc780 kernel: usb 1-3: new high-speed USB device number 10 using xhci_hcd
Dec 06 10:30:56 tracey-aspiretc780 kernel: usb 1-3: New USB device found, idVendor=1908, idProduct=2311, bcdDevice= 1.00
Dec 06 10:30:56 tracey-aspiretc780 kernel: usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dec 06 10:30:56 tracey-aspiretc780 kernel: usb 1-3: Product: USB2.0 PC CAMERA
Dec 06 10:30:56 tracey-aspiretc780 kernel: usb 1-3: Manufacturer: Generic
Dec 06 10:30:56 tracey-aspiretc780 kernel: usb 1-3: Found UVC 1.00 device USB2.0 PC CAMERA (1908:2311)
Dec 06 10:30:56 tracey-aspiretc780 kernel: input: USB2.0 PC CAMERA: USB2.0 PC CAM as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/input/input28
Dec 06 10:30:56 tracey-aspiretc780 mtp-probe[3733]: checking bus 1, device 10: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3"
Dec 06 10:30:56 tracey-aspiretc780 mtp-probe[3733]: bus: 1, device: 10 was not an MTP device
Dec 06 10:30:56 tracey-aspiretc780 mtp-probe[3741]: checking bus 1, device 10: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3"
Dec 06 10:30:56 tracey-aspiretc780 mtp-probe[3741]: bus: 1, device: 10 was not an MTP device
Dec 06 10:30:56 tracey-aspiretc780 plasmashell[703]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/delegates/DelegatePopup.qml:147:17: QML Body: Binding loop detected for property "width"
Dec 06 10:33:49 tracey-aspiretc780 NetworkManager[481]: <info> [1765031629.8724] dhcp4 (enp1s0): state changed new lease, address=192.168.0.89
Dec 06 10:33:49 tracey-aspiretc780 systemd[1]: Starting Network Manager Script Dispatcher Service...
Dec 06 10:33:49 tracey-aspiretc780 systemd[1]: Started Network Manager Script Dispatcher Service.
Dec 06 10:33:59 tracey-aspiretc780 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Dec 06 10:37:48 tracey-aspiretc780 NetworkManager[481]: <info> [1765031868.5155] device (wlp2s0): set-hw-addr: set MAC address to D6:9C:C5:E1:79:6F (scanning)
Dec 06 10:44:39 tracey-aspiretc780 NetworkManager[481]: <info> [1765032279.5222] device (wlp2s0): set-hw-addr: set MAC address to 02:16:6D:DE:4C:94 (scanning)
Dec 06 10:51:31 tracey-aspiretc780 NetworkManager[481]: <info> [1765032691.5192] device (wlp2s0): set-hw-addr: set MAC address to 76:B1:F7:4E:23:EE (scanning)
Dec 06 10:51:31 tracey-aspiretc780 NetworkManager[481]: <info> [1765032691.5410] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 06 10:51:31 tracey-aspiretc780 NetworkManager[481]: <info> [1765032691.5411] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 06 10:51:31 tracey-aspiretc780 NetworkManager[481]: <info> [1765032691.5465] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 10:51:31 tracey-aspiretc780 NetworkManager[481]: <info> [1765032691.5466] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 10:58:22 tracey-aspiretc780 NetworkManager[481]: <info> [1765033102.5256] device (wlp2s0): set-hw-addr: set MAC address to 8E:52:05:8A:D0:33 (scanning)
Dec 06 10:58:22 tracey-aspiretc780 NetworkManager[481]: <info> [1765033102.5311] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 06 10:58:22 tracey-aspiretc780 NetworkManager[481]: <info> [1765033102.5312] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 06 10:58:22 tracey-aspiretc780 NetworkManager[481]: <info> [1765033102.5323] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 10:58:22 tracey-aspiretc780 NetworkManager[481]: <info> [1765033102.5323] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 11:01:00 tracey-aspiretc780 CROND[3876]: (root) CMD (run-parts /etc/cron.hourly)
Dec 06 11:01:00 tracey-aspiretc780 CROND[3875]: (root) CMDEND (run-parts /etc/cron.hourly)
Dec 06 11:01:55 tracey-aspiretc780 pamac-tray-plas[955]: updates_checker.vala:59: check updates
Dec 06 11:05:15 tracey-aspiretc780 NetworkManager[481]: <info> [1765033515.5154] device (wlp2s0): set-hw-addr: set MAC address to 1A:8B:75:EA:6D:36 (scanning)
Dec 06 11:05:15 tracey-aspiretc780 NetworkManager[481]: <info> [1765033515.5375] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 06 11:05:15 tracey-aspiretc780 NetworkManager[481]: <info> [1765033515.5376] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 06 11:05:15 tracey-aspiretc780 NetworkManager[481]: <info> [1765033515.5429] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 11:05:15 tracey-aspiretc780 NetworkManager[481]: <info> [1765033515.5429] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 11:12:10 tracey-aspiretc780 NetworkManager[481]: <info> [1765033930.5146] device (wlp2s0): set-hw-addr: set MAC address to 8E:AA:7F:DD:1A:8F (scanning)
Dec 06 11:16:53 tracey-aspiretc780 kernel: usb 1-3: USB disconnect, device number 10
Dec 06 11:16:53 tracey-aspiretc780 kded6[677]: kf.notifications: Failed to notify "Created too many similar notifications in quick succession"
Dec 06 11:16:53 tracey-aspiretc780 kernel: usb 1-3: new high-speed USB device number 11 using xhci_hcd
Dec 06 11:16:53 tracey-aspiretc780 kernel: usb 1-3: New USB device found, idVendor=1908, idProduct=2311, bcdDevice= 1.00
Dec 06 11:16:53 tracey-aspiretc780 kernel: usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dec 06 11:16:53 tracey-aspiretc780 kernel: usb 1-3: Product: USB2.0 PC CAMERA
Dec 06 11:16:53 tracey-aspiretc780 kernel: usb 1-3: Manufacturer: Generic
Dec 06 11:16:53 tracey-aspiretc780 kernel: usb 1-3: Found UVC 1.00 device USB2.0 PC CAMERA (1908:2311)
Dec 06 11:16:53 tracey-aspiretc780 kernel: input: USB2.0 PC CAMERA: USB2.0 PC CAM as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/input/input29
Dec 06 11:16:53 tracey-aspiretc780 mtp-probe[3955]: checking bus 1, device 11: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3"
Dec 06 11:16:53 tracey-aspiretc780 mtp-probe[3955]: bus: 1, device: 11 was not an MTP device
Dec 06 11:16:53 tracey-aspiretc780 plasmashell[703]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/delegates/DelegatePopup.qml:147:17: QML Body: Binding loop detected for property "width"
Dec 06 11:16:53 tracey-aspiretc780 mtp-probe[3963]: checking bus 1, device 11: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3"
Dec 06 11:16:53 tracey-aspiretc780 mtp-probe[3963]: bus: 1, device: 11 was not an MTP device
Dec 06 11:19:01 tracey-aspiretc780 NetworkManager[481]: <info> [1765034341.5183] device (wlp2s0): set-hw-addr: set MAC address to 2A:B3:D2:97:AA:13 (scanning)
Dec 06 11:25:51 tracey-aspiretc780 NetworkManager[481]: <info> [1765034751.5196] device (wlp2s0): set-hw-addr: set MAC address to 22:E7:A5:B1:E7:C4 (scanning)
Dec 06 11:25:51 tracey-aspiretc780 NetworkManager[481]: <info> [1765034751.5257] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 06 11:25:51 tracey-aspiretc780 NetworkManager[481]: <info> [1765034751.5257] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 06 11:25:51 tracey-aspiretc780 NetworkManager[481]: <info> [1765034751.5265] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 11:25:51 tracey-aspiretc780 NetworkManager[481]: <info> [1765034751.5265] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 11:29:45 tracey-aspiretc780 NetworkManager[481]: <info> [1765034985.8668] dhcp4 (enp1s0): state changed new lease, address=192.168.0.89
Dec 06 11:29:45 tracey-aspiretc780 systemd[1]: Starting Network Manager Script Dispatcher Service...
Dec 06 11:29:45 tracey-aspiretc780 systemd[1]: Started Network Manager Script Dispatcher Service.
Dec 06 11:29:55 tracey-aspiretc780 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Dec 06 11:32:43 tracey-aspiretc780 NetworkManager[481]: <info> [1765035163.5118] device (wlp2s0): set-hw-addr: set MAC address to 2E:5E:84:2F:89:F1 (scanning)
Dec 06 11:39:35 tracey-aspiretc780 NetworkManager[481]: <info> [1765035575.5195] device (wlp2s0): set-hw-addr: set MAC address to 7A:12:70:22:FA:6C (scanning)
Dec 06 11:46:28 tracey-aspiretc780 NetworkManager[481]: <info> [1765035988.5185] device (wlp2s0): set-hw-addr: set MAC address to 1A:3E:43:9C:41:3D (scanning)
Dec 06 11:46:28 tracey-aspiretc780 NetworkManager[481]: <info> [1765035988.5437] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 06 11:46:28 tracey-aspiretc780 NetworkManager[481]: <info> [1765035988.5438] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 06 11:46:28 tracey-aspiretc780 NetworkManager[481]: <info> [1765035988.5494] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 11:46:28 tracey-aspiretc780 NetworkManager[481]: <info> [1765035988.5495] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 11:53:19 tracey-aspiretc780 NetworkManager[481]: <info> [1765036399.5221] device (wlp2s0): set-hw-addr: set MAC address to DE:56:C7:CD:B1:4B (scanning)
Dec 06 12:00:09 tracey-aspiretc780 NetworkManager[481]: <info> [1765036809.5190] device (wlp2s0): set-hw-addr: set MAC address to 7A:EB:30:6B:05:55 (scanning)
Dec 06 12:00:09 tracey-aspiretc780 NetworkManager[481]: <info> [1765036809.5221] device (wlp2s0): supplicant interface state: inactive -> interface_disabled
Dec 06 12:00:09 tracey-aspiretc780 NetworkManager[481]: <info> [1765036809.5221] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> interface_disabled
Dec 06 12:00:09 tracey-aspiretc780 NetworkManager[481]: <info> [1765036809.5420] device (wlp2s0): supplicant interface state: interface_disabled -> disconnected
Dec 06 12:00:09 tracey-aspiretc780 NetworkManager[481]: <info> [1765036809.5421] device (p2p-dev-wlp2s0): supplicant management interface state: interface_disabled -> disconnected
Dec 06 12:00:12 tracey-aspiretc780 NetworkManager[481]: <info> [1765036812.5452] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 12:00:12 tracey-aspiretc780 NetworkManager[481]: <info> [1765036812.5453] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 12:01:00 tracey-aspiretc780 CROND[4155]: (root) CMD (run-parts /etc/cron.hourly)
Dec 06 12:01:00 tracey-aspiretc780 CROND[4154]: (root) CMDEND (run-parts /etc/cron.hourly)
Dec 06 12:01:55 tracey-aspiretc780 pamac-tray-plas[955]: updates_checker.vala:59: check updates
Dec 06 12:07:01 tracey-aspiretc780 NetworkManager[481]: <info> [1765037221.5278] device (wlp2s0): set-hw-addr: set MAC address to 26:5A:DF:08:38:90 (scanning)
Dec 06 12:13:53 tracey-aspiretc780 NetworkManager[481]: <info> [1765037633.5223] device (wlp2s0): set-hw-addr: set MAC address to 0E:A2:E8:85:95:BB (scanning)
Dec 06 12:20:46 tracey-aspiretc780 NetworkManager[481]: <info> [1765038046.5238] device (wlp2s0): set-hw-addr: set MAC address to 3A:F7:23:12:EB:BC (scanning)
Dec 06 12:20:46 tracey-aspiretc780 NetworkManager[481]: <info> [1765038046.5293] device (wlp2s0): supplicant interface state: inactive -> interface_disabled
Dec 06 12:20:46 tracey-aspiretc780 NetworkManager[481]: <info> [1765038046.5293] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> interface_disabled
Dec 06 12:20:46 tracey-aspiretc780 NetworkManager[481]: <info> [1765038046.5313] device (wlp2s0): supplicant interface state: interface_disabled -> inactive
Dec 06 12:20:46 tracey-aspiretc780 NetworkManager[481]: <info> [1765038046.5313] device (p2p-dev-wlp2s0): supplicant management interface state: interface_disabled -> inactive
Dec 06 12:25:03 tracey-aspiretc780 NetworkManager[481]: <info> [1765038303.8669] dhcp4 (enp1s0): state changed new lease, address=192.168.0.89
Dec 06 12:25:03 tracey-aspiretc780 systemd[1]: Starting Network Manager Script Dispatcher Service...
Dec 06 12:25:03 tracey-aspiretc780 systemd[1]: Started Network Manager Script Dispatcher Service.
Dec 06 12:25:13 tracey-aspiretc780 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Dec 06 12:27:37 tracey-aspiretc780 NetworkManager[481]: <info> [1765038457.5241] device (wlp2s0): set-hw-addr: set MAC address to D6:31:8C:ED:0D:68 (scanning)
Dec 06 12:27:37 tracey-aspiretc780 NetworkManager[481]: <info> [1765038457.5430] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 06 12:27:37 tracey-aspiretc780 NetworkManager[481]: <info> [1765038457.5430] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 06 12:27:37 tracey-aspiretc780 NetworkManager[481]: <info> [1765038457.5485] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 12:27:37 tracey-aspiretc780 NetworkManager[481]: <info> [1765038457.5485] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 12:34:28 tracey-aspiretc780 NetworkManager[481]: <info> [1765038868.5187] device (wlp2s0): set-hw-addr: set MAC address to 22:7D:C2:66:C4:1A (scanning)
Dec 06 12:34:28 tracey-aspiretc780 NetworkManager[481]: <info> [1765038868.5234] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 06 12:34:28 tracey-aspiretc780 NetworkManager[481]: <info> [1765038868.5239] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 06 12:34:28 tracey-aspiretc780 NetworkManager[481]: <info> [1765038868.5241] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 12:34:28 tracey-aspiretc780 NetworkManager[481]: <info> [1765038868.5242] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 12:41:21 tracey-aspiretc780 NetworkManager[481]: <info> [1765039281.5222] device (wlp2s0): set-hw-addr: set MAC address to BE:2E:FF:D1:BC:E1 (scanning)
Dec 06 12:41:21 tracey-aspiretc780 NetworkManager[481]: <info> [1765039281.5264] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 06 12:41:21 tracey-aspiretc780 NetworkManager[481]: <info> [1765039281.5265] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 06 12:41:21 tracey-aspiretc780 NetworkManager[481]: <info> [1765039281.5266] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 12:41:21 tracey-aspiretc780 NetworkManager[481]: <info> [1765039281.5267] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 12:48:13 tracey-aspiretc780 NetworkManager[481]: <info> [1765039693.5249] device (wlp2s0): set-hw-addr: set MAC address to 9E:E6:79:95:B1:56 (scanning)
Dec 06 12:55:06 tracey-aspiretc780 NetworkManager[481]: <info> [1765040106.5214] device (wlp2s0): set-hw-addr: set MAC address to C2:EE:A3:51:7D:AE (scanning)
Dec 06 12:55:06 tracey-aspiretc780 NetworkManager[481]: <info> [1765040106.5254] device (wlp2s0): supplicant interface state: inactive -> interface_disabled
Dec 06 12:55:06 tracey-aspiretc780 NetworkManager[481]: <info> [1765040106.5254] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> interface_disabled
Dec 06 12:55:06 tracey-aspiretc780 NetworkManager[481]: <info> [1765040106.5454] device (wlp2s0): supplicant interface state: interface_disabled -> disconnected
Dec 06 12:55:06 tracey-aspiretc780 NetworkManager[481]: <info> [1765040106.5454] device (p2p-dev-wlp2s0): supplicant management interface state: interface_disabled -> disconnected
Dec 06 12:55:07 tracey-aspiretc780 NetworkManager[481]: <info> [1765040107.5459] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 12:55:07 tracey-aspiretc780 NetworkManager[481]: <info> [1765040107.5459] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 13:01:00 tracey-aspiretc780 CROND[4541]: (root) CMD (run-parts /etc/cron.hourly)
Dec 06 13:01:00 tracey-aspiretc780 CROND[4540]: (root) CMDEND (run-parts /etc/cron.hourly)
Dec 06 13:01:55 tracey-aspiretc780 pamac-tray-plas[955]: updates_checker.vala:59: check updates
Dec 06 13:01:55 tracey-aspiretc780 pamac-checkupda[4582]: flatpak_plugin.vala:393: refreshing flathub appstream data
Dec 06 13:01:57 tracey-aspiretc780 NetworkManager[481]: <info> [1765040517.5170] device (wlp2s0): set-hw-addr: set MAC address to DE:0B:13:B3:E2:C7 (scanning)
Dec 06 13:01:57 tracey-aspiretc780 pamac-checkupdates[4582]: /var/tmp/flatpak-cache-HPY1G3/repo-tSy0vT: Pulled appstream2/x86_64 from flathub
Dec 06 13:01:57 tracey-aspiretc780 systemd[1]: Starting flatpak system helper...
Dec 06 13:01:57 tracey-aspiretc780 systemd[1]: Started flatpak system helper.
Dec 06 13:01:59 tracey-aspiretc780 flatpak-system-helper[4606]: system: Pulled appstream2/x86_64 from /var/tmp/flatpak-cache-HPY1G3/repo-tSy0vT
Dec 06 13:08:49 tracey-aspiretc780 NetworkManager[481]: <info> [1765040929.5248] device (wlp2s0): set-hw-addr: set MAC address to 9A:02:B8:E0:A7:98 (scanning)
Dec 06 13:08:49 tracey-aspiretc780 NetworkManager[481]: <info> [1765040929.5466] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 06 13:08:49 tracey-aspiretc780 NetworkManager[481]: <info> [1765040929.5467] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 06 13:08:49 tracey-aspiretc780 NetworkManager[481]: <info> [1765040929.5519] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 13:08:49 tracey-aspiretc780 NetworkManager[481]: <info> [1765040929.5519] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 13:11:57 tracey-aspiretc780 systemd[1]: flatpak-system-helper.service: Deactivated successfully.
Dec 06 13:11:57 tracey-aspiretc780 systemd[1]: flatpak-system-helper.service: Consumed 1.245s CPU time, 56.2M memory peak.
Dec 06 13:15:40 tracey-aspiretc780 NetworkManager[481]: <info> [1765041340.5216] device (wlp2s0): set-hw-addr: set MAC address to 3E:F6:40:1D:80:5A (scanning)
Dec 06 13:15:40 tracey-aspiretc780 NetworkManager[481]: <info> [1765041340.5468] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 06 13:15:40 tracey-aspiretc780 NetworkManager[481]: <info> [1765041340.5468] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 06 13:15:40 tracey-aspiretc780 NetworkManager[481]: <info> [1765041340.5524] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 13:15:40 tracey-aspiretc780 NetworkManager[481]: <info> [1765041340.5525] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 13:20:17 tracey-aspiretc780 NetworkManager[481]: <info> [1765041617.8574] dhcp4 (enp1s0): state changed new lease, address=192.168.0.89
Dec 06 13:20:17 tracey-aspiretc780 systemd[1]: Starting Network Manager Script Dispatcher Service...
Dec 06 13:20:17 tracey-aspiretc780 systemd[1]: Started Network Manager Script Dispatcher Service.
Dec 06 13:20:27 tracey-aspiretc780 systemd[1]: Starting Daily man-db regeneration...
Dec 06 13:20:27 tracey-aspiretc780 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Dec 06 13:20:31 tracey-aspiretc780 systemd[1]: man-db.service: Deactivated successfully.
Dec 06 13:20:31 tracey-aspiretc780 systemd[1]: Finished Daily man-db regeneration.
Dec 06 13:20:31 tracey-aspiretc780 systemd[1]: man-db.service: Consumed 818ms CPU time, 67.2M memory peak.
Dec 06 13:22:32 tracey-aspiretc780 NetworkManager[481]: <info> [1765041752.5146] device (wlp2s0): set-hw-addr: set MAC address to BE:92:6A:AD:C6:1D (scanning)
Dec 06 13:22:32 tracey-aspiretc780 NetworkManager[481]: <info> [1765041752.5334] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 06 13:22:32 tracey-aspiretc780 NetworkManager[481]: <info> [1765041752.5334] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 06 13:22:32 tracey-aspiretc780 NetworkManager[481]: <info> [1765041752.5386] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 13:22:32 tracey-aspiretc780 NetworkManager[481]: <info> [1765041752.5387] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 13:29:25 tracey-aspiretc780 NetworkManager[481]: <info> [1765042165.5145] device (wlp2s0): set-hw-addr: set MAC address to 2A:0E:46:04:3E:4A (scanning)
Dec 06 13:29:25 tracey-aspiretc780 NetworkManager[481]: <info> [1765042165.5299] device (wlp2s0): supplicant interface state: inactive -> disconnected
Dec 06 13:29:25 tracey-aspiretc780 NetworkManager[481]: <info> [1765042165.5299] device (p2p-dev-wlp2s0): supplicant management interface state: inactive -> disconnected
Dec 06 13:29:25 tracey-aspiretc780 NetworkManager[481]: <info> [1765042165.5352] device (wlp2s0): supplicant interface state: disconnected -> inactive
Dec 06 13:29:25 tracey-aspiretc780 NetworkManager[481]: <info> [1765042165.5352] device (p2p-dev-wlp2s0): supplicant management interface state: disconnected -> inactive
Dec 06 13:33:46 tracey-aspiretc780 kwin_x11[678]: kwin_core: XCB error: 152 (BadDamage), sequence: 60974, resource id: 20464444, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Dec 06 13:33:46 tracey-aspiretc780 kwin_x11[678]: kwin_core: XCB error: 3 (BadWindow), sequence: 60975, resource id: 4194351, major code: 129 (SHAPE), minor code: 6 (Input)
Dec 06 13:33:47 tracey-aspiretc780 systemd[594]: app-org.chromium.Chromium-1210.scope: Consumed 12min 31.046s CPU time, 401.2M memory peak.
Dec 06 13:33:47 tracey-aspiretc780 systemd[594]: app-chromium@6c4d2286a2ad4e75b863c14f0e59dc4e.service: Consumed 7h 35min 53.085s CPU time, 3.7G memory peak.
Dec 06 13:33:50 tracey-aspiretc780 systemd[594]: Created slice Slice /app/dbus-:1.2-org.kde.LogoutPrompt.
Dec 06 13:33:50 tracey-aspiretc780 systemd[594]: Started dbus-:1.2-org.kde.LogoutPrompt@0.service.
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: Created slice Slice /app/dbus-:1.2-org.kde.Shutdown.
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: Started dbus-:1.2-org.kde.Shutdown@0.service.
Dec 06 13:33:52 tracey-aspiretc780 msm_kde_notifier[935]: Shutting down MSM Notifier...
Dec 06 13:33:52 tracey-aspiretc780 kded6[677]: Service ":1.49" unregistered
Dec 06 13:33:52 tracey-aspiretc780 kded6[677]: Service ":1.44" unregistered
Dec 06 13:33:52 tracey-aspiretc780 polkit-kde-authentication-agent-1[733]: Destroying listener
Dec 06 13:33:52 tracey-aspiretc780 polkit-kde-authentication-agent-1[733]: Removing listener PolkitQt1::Agent::Listener(0x560b163f1d90)
Dec 06 13:33:52 tracey-aspiretc780 polkitd[484]: Unregistered Authentication Agent for unix-session:1 (system bus name :1.24, object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_CA.UTF-8)
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: plasma-xembedsniproxy.service: Consumed 1.716s CPU time, 3.3M memory peak.
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: app-pamac\x2dtray\x2dplasma@autostart.service: Consumed 45.913s CPU time, 758.8M memory peak.
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: app-org.kde.kdeconnect.daemon@autostart.service: Consumed 2.806s CPU time, 26.4M memory peak.
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: plasma-polkit-agent.service: Consumed 1.850s CPU time, 16.1M memory peak.
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: dbus-:1.2-org.kde.LogoutPrompt@0.service: Consumed 496ms CPU time, 89M memory peak.
Dec 06 13:33:52 tracey-aspiretc780 plasmashell[703]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:130: TypeError: Cannot read property 'screenGeometry' of null
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: plasma-gmenudbusmenuproxy.service: Consumed 1.760s CPU time, 3.7M memory peak.
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: app-msm_kde_notifier@autostart.service: Consumed 8.384s CPU time, 39.7M memory peak.
Dec 06 13:33:52 tracey-aspiretc780 plasmashell[703]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:260: TypeError: Cannot read property 'plasmoid' of undefined
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: Stopped target plasma-workspace-x11.target.
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: Stopped target KDE Plasma Workspace.
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: Stopped target Current graphical user session.
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: Stopped target Startup of XDG autostart applications.
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: Stopping Accessibility services bus...
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: Stopping KAccess...
Dec 06 13:33:52 tracey-aspiretc780 dbus-broker[1319]: Dispatched 30840 messages @ 4(±2)μs / message.
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: Stopping KActivityManager Activity manager Service...
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: Stopping KDE Global Shortcuts Server...
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: Stopping KScreen...
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: Stopping KDE Window Manager...
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: Stopping Powerdevil...
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: Stopping Xdg Desktop Portal For KDE...
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: Stopping Portal service...
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: Stopping flatpak document portal service...
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: Stopping sandboxed app permission store...
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: Stopping Baloo File Indexer Daemon...
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: run-user-1000-doc.mount: Deactivated successfully.
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: Stopped KDE Global Shortcuts Server.
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: plasma-kglobalaccel.service: Consumed 2.751s CPU time, 10.2M memory peak.
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: Stopped sandboxed app permission store.
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: Stopped KActivityManager Activity manager Service.
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: plasma-kactivitymanagerd.service: Consumed 1.835s CPU time, 10.1M memory peak.
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: Stopped KAccess.
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: plasma-kaccess.service: Consumed 3.739s CPU time, 15.6M memory peak.
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: Stopped Xdg Desktop Portal For KDE.
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: plasma-xdg-desktop-portal-kde.service: Consumed 1.991s CPU time, 16.6M memory peak.
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: Stopped KScreen.
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: plasma-kscreen.service: Consumed 1.810s CPU time, 3.4M memory peak.
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: Stopped Accessibility services bus.
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: at-spi-dbus-bus.service: Consumed 1.565s CPU time, 2.5M memory peak.
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: Stopped Portal service.
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: Stopped Baloo File Indexer Daemon.
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: Stopped Powerdevil.
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: plasma-powerdevil.service: Consumed 21.955s CPU time, 11.9M memory peak.
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: Stopped target KDE Plasma Workspace Core.
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: Stopping KDE Daemon 6...
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: Stopping KDE Plasma Workspace...
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: Stopped target Session services which should run early before the graphical session is brought up.
Dec 06 13:33:52 tracey-aspiretc780 kwin_x11[678]: kwin_scene_opengl: Could not delete framebuffer because no context is current
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: Stopped flatpak document portal service.
Dec 06 13:33:52 tracey-aspiretc780 systemd-logind[486]: The system will power off now!
Dec 06 13:33:52 tracey-aspiretc780 systemd-logind[486]: System is powering down.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopping Session 1 of User tracey...
Dec 06 13:33:52 tracey-aspiretc780 sddm[575]: Authentication error: SDDM::Auth::ERROR_INTERNAL "Process crashed"
Dec 06 13:33:52 tracey-aspiretc780 sddm[575]: Auth: sddm-helper (--socket /tmp/sddm-auth-e7991171-d085-4c75-9613-064ec06e42aa --id 1 --start /usr/bin/startplasma-x11 --user tracey --autologin) crashed (exit code 1)
Dec 06 13:33:52 tracey-aspiretc780 sddm[575]: Auth: sddm-helper exited with 1
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.backlighthelper.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.chargethresholdhelper.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Removed slice Slice /system/dbus-:1.2-org.kde.powerdevil.discretegpuhelper.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Removed slice Slice /system/getty.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Removed slice Slice /system/modprobe.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopped target Bluetooth Support.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopped target Graphical Interface.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopped target Sound Card.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopped target Timer Units.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: archlinux-keyring-wkd-sync.timer: Deactivated successfully.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopped Refresh existing PGP keys of archlinux-keyring regularly.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: fstrim.timer: Deactivated successfully.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopped Discard unused filesystem blocks once a week.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: logrotate.timer: Deactivated successfully.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopped Daily rotation of log files.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: man-db.timer: Deactivated successfully.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopped Daily man-db regeneration.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: pamac-cleancache.timer: Deactivated successfully.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopped Monthly clean packages cache.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: pamac-mirrorlist.timer: Deactivated successfully.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopped Generate mirrorlist weekly.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: shadow.timer: Deactivated successfully.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopped Daily verification of password and group files.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: systemd-tmpfiles-clean.timer: Deactivated successfully.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopped Daily Cleanup of Temporary Directories.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopped target Trusted Platform Module.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: lvm2-lvmpolld.socket: Deactivated successfully.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Closed LVM2 poll daemon socket.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: systemd-rfkill.socket: Deactivated successfully.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopping Save/Restore Sound Card State...
Dec 06 13:33:52 tracey-aspiretc780 bluetoothd[483]: Terminating
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopping Bluetooth service...
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Starting Generate shutdown-ramfs...
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopping Pamac Daemon...
Dec 06 13:33:52 tracey-aspiretc780 at-spi2-registryd[1320]: X connection to :0 broken (explicit kill or server shutdown).
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopping Power Profiles daemon...
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopping RealtimeKit Scheduling Policy Service...
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopping Simple Desktop Display Manager...
Dec 06 13:33:52 tracey-aspiretc780 ksmserver[675]: The X11 connection broke (error 1). Did the X11 server die?
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: dbus-:1.59-org.a11y.atspi.Registry@0.service: Main process exited, code=exited, status=1/FAILURE
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: dbus-:1.59-org.a11y.atspi.Registry@0.service: Failed with result 'exit-code'.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopping Load/Save OS Random Seed...
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: systemd-udev-load-credentials.service: Deactivated successfully.
Dec 06 13:33:52 tracey-aspiretc780 sddm[575]: Signal received: SIGTERM
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopped Load udev Rules from Credentials.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopping Disk Manager...
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopping Daemon for power management...
Dec 06 13:33:52 tracey-aspiretc780 sddm[575]: Display server stopping...
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: rtkit-daemon.service: Deactivated successfully.
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: dbus-:1.59-org.a11y.atspi.Registry@0.service: Consumed 6.188s CPU time, 1.7M memory peak.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopped RealtimeKit Scheduling Policy Service.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: upower.service: Deactivated successfully.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopped Daemon for power management.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: power-profiles-daemon.service: Deactivated successfully.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopped Power Profiles daemon.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: pamac-daemon.service: Deactivated successfully.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopped Pamac Daemon.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: pamac-daemon.service: Consumed 2.282s CPU time, 40M memory peak.
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: Stopped KDE Session Management Server.
Dec 06 13:33:52 tracey-aspiretc780 systemd[594]: plasma-ksmserver.service: Consumed 2.304s CPU time, 16.6M memory peak.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: session-1.scope: Deactivated successfully.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopped Session 1 of User tracey.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: session-1.scope: Consumed 2.311s CPU time, 344.4M memory peak.
Dec 06 13:33:52 tracey-aspiretc780 systemd-logind[486]: Session 1 logged out. Waiting for processes to exit.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopped target Multi-User System.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopped target Login Prompts.
Dec 06 13:33:52 tracey-aspiretc780 ModemManager[540]: <msg> caught signal, shutting down...
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopping Modem Manager...
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopping Command Scheduler...
Dec 06 13:33:52 tracey-aspiretc780 ModemManager[540]: <msg> ModemManager is shut down
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopping CUPS Scheduler...
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: plymouth-quit-wait.service: Deactivated successfully.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopped Hold until boot process finishes up.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopping User Manager for UID 1000...
Dec 06 13:33:52 tracey-aspiretc780 udisksd[872]: udisks daemon version 2.10.2 exiting
Dec 06 13:33:52 tracey-aspiretc780 NetworkManager[481]: <info> [1765042432.9433] modem-manager: ModemManager no longer available
Dec 06 13:33:52 tracey-aspiretc780 systemd-logind[486]: Removed session 1.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: cups.service: Deactivated successfully.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopped CUPS Scheduler.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Removed slice CUPS Slice.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopped target System Time Set.
Dec 06 13:33:52 tracey-aspiretc780 crond[568]: (CRON) INFO (Shutting down)
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: cronie.service: Deactivated successfully.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopped Command Scheduler.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: alsa-restore.service: Deactivated successfully.
Dec 06 13:33:52 tracey-aspiretc780 systemd[1]: Stopped Save/Restore Sound Card State.
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: ModemManager.service: Deactivated successfully.
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: Stopped Modem Manager.
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: Stopping Authorization Manager...
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: polkit.service: Deactivated successfully.
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: Stopped Authorization Manager.
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: polkit.service: Consumed 1.207s CPU time, 7.9M memory peak.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Activating special unit Exit the Session...
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Removed slice Slice /app/dbus-:1.2-org.freedesktop.Notifications.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Removed slice Slice /app/dbus-:1.2-org.freedesktop.impl.portal.desktop.kwallet.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Removed slice Slice /app/dbus-:1.2-org.kde.KSplash.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Removed slice Slice /app/dbus-:1.2-org.kde.LogoutPrompt.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: app-dbus\x2d:1.2\x2dorg.kde.LogoutPrompt.slice: Consumed 496ms CPU time, 89M memory peak.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Removed slice Slice /app/dbus-:1.2-org.kde.kwalletd6.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Removed slice Slice /app/dbus-:1.59-org.a11y.atspi.Registry.
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: udisks2.service: Deactivated successfully.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: app-dbus\x2d:1.59\x2dorg.a11y.atspi.Registry.slice: Consumed 6.188s CPU time, 1.8M memory peak.
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: Stopped Disk Manager.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Removed slice User Background Tasks Slice.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: background.slice: Consumed 37.844s CPU time, 76.6M memory peak.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Stopped target Main User Target.
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: udisks2.service: Consumed 8.343s CPU time, 8M memory peak.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Stopping dbus-:1.2-org.kde.Shutdown@0.service...
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Stopping User preferences database...
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Stopping PipeWire PulseAudio...
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Stopped User preferences database.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Stopped PipeWire PulseAudio.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: pipewire-pulse.service: Consumed 30.158s CPU time, 19.3M memory peak.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Stopped dbus-:1.2-org.kde.Shutdown@0.service.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Removed slice Slice /app/dbus-:1.2-org.kde.Shutdown.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Stopping Multimedia Service Session Manager...
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Stopped Multimedia Service Session Manager.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: wireplumber.service: Consumed 2.936s CPU time, 33.8M memory peak.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Stopping PipeWire Multimedia Service...
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Stopped PipeWire Multimedia Service.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: pipewire.service: Consumed 23.674s CPU time, 10.8M memory peak.
Dec 06 13:33:53 tracey-aspiretc780 kernel: fbcon: Taking over console
Dec 06 13:33:53 tracey-aspiretc780 kernel: Console: switching to colour frame buffer device 240x67
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: plasma-kwin_x11.service: Main process exited, code=exited, status=15/n/a
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: plasma-kwin_x11.service: Failed with result 'exit-code'.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Stopped KDE Window Manager.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: plasma-kwin_x11.service: Consumed 43min 22.840s CPU time, 185.7M memory peak.
Dec 06 13:33:53 tracey-aspiretc780 sddm[575]: Display server stopped.
Dec 06 13:33:53 tracey-aspiretc780 sddm[575]: Running display stop script QList("/usr/share/sddm/scripts/Xstop")
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: sddm.service: Deactivated successfully.
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: Stopped Simple Desktop Display Manager.
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: sddm.service: Consumed 42min 8.796s CPU time, 156.8M memory peak.
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: Starting Show Plymouth Power Off Screen...
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: plymouth-quit.service: Deactivated successfully.
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: Stopped Terminate Plymouth Boot Screen.
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: Received SIGRTMIN+20 from PID 5588 (plymouthd).
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Stopped KDE Plasma Workspace.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: plasma-plasmashell.service: Consumed 25.875s CPU time, 368.5M memory peak.
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: systemd-random-seed.service: Deactivated successfully.
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: Stopped Load/Save OS Random Seed.
Dec 06 13:33:53 tracey-aspiretc780 kded6[677]: The X11 connection broke: I/O error (code 1)
Dec 06 13:33:53 tracey-aspiretc780 kded6[677]: XIO: fatal IO error 9 (Bad file descriptor) on X server ":0"
Dec 06 13:33:53 tracey-aspiretc780 kded6[677]: after 18 requests (18 known processed) with 0 events remaining.
Dec 06 13:33:53 tracey-aspiretc780 bluetoothd[483]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSource/ldac
Dec 06 13:33:53 tracey-aspiretc780 bluetoothd[483]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSink/aptx_hd
Dec 06 13:33:53 tracey-aspiretc780 bluetoothd[483]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSource/aptx_hd
Dec 06 13:33:53 tracey-aspiretc780 bluetoothd[483]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSink/aac
Dec 06 13:33:53 tracey-aspiretc780 bluetoothd[483]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSource/aac
Dec 06 13:33:53 tracey-aspiretc780 bluetoothd[483]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSink/opus_g
Dec 06 13:33:53 tracey-aspiretc780 bluetoothd[483]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSource/opus_g
Dec 06 13:33:53 tracey-aspiretc780 bluetoothd[483]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSink/sbc
Dec 06 13:33:53 tracey-aspiretc780 bluetoothd[483]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSource/sbc
Dec 06 13:33:53 tracey-aspiretc780 bluetoothd[483]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSource/aptx_ll_1
Dec 06 13:33:53 tracey-aspiretc780 bluetoothd[483]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSource/aptx_ll_0
Dec 06 13:33:53 tracey-aspiretc780 bluetoothd[483]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
Dec 06 13:33:53 tracey-aspiretc780 bluetoothd[483]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
Dec 06 13:33:53 tracey-aspiretc780 bluetoothd[483]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSource/faststream
Dec 06 13:33:53 tracey-aspiretc780 bluetoothd[483]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSource/faststream_duplex
Dec 06 13:33:53 tracey-aspiretc780 bluetoothd[483]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSink/opus_05
Dec 06 13:33:53 tracey-aspiretc780 bluetoothd[483]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSource/opus_05
Dec 06 13:33:53 tracey-aspiretc780 bluetoothd[483]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSink/opus_05_duplex
Dec 06 13:33:53 tracey-aspiretc780 bluetoothd[483]: Endpoint unregistered: sender=:1.48 path=/MediaEndpoint/A2DPSource/opus_05_duplex
Dec 06 13:33:53 tracey-aspiretc780 bluetoothd[483]: Battery Provider Manager destroyed
Dec 06 13:33:53 tracey-aspiretc780 bluetoothd[483]: Stopping SDP server
Dec 06 13:33:53 tracey-aspiretc780 bluetoothd[483]: Exit
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: bluetooth.service: Deactivated successfully.
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: Stopped Bluetooth service.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: plasma-kded6.service: Main process exited, code=exited, status=1/FAILURE
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: plasma-kded6.service: Failed with result 'exit-code'.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Stopped KDE Daemon 6.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: plasma-kded6.service: Consumed 7.631s CPU time, 111.4M memory peak.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Stopped target Basic System.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Stopped target Paths.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Stopped target Sockets.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Stopped target Timers.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Closed GnuPG network certificate management daemon.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Closed GnuPG cryptographic agent and passphrase cache.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Closed GnuPG public key management service.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Closed p11-kit server.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Closed PipeWire PulseAudio.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Closed PipeWire Multimedia System Sockets.
Dec 06 13:33:53 tracey-aspiretc780 dbus-broker[625]: Dispatched 50617 messages @ 4(±4)μs / message.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Stopping D-Bus User Message Bus...
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Stopped D-Bus User Message Bus.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: dbus-broker.service: Consumed 1.554s CPU time, 3.3M memory peak.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Removed slice User Core Session Slice.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: session.slice: Consumed 45min 1.563s CPU time, 766.1M memory peak.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Closed D-Bus User Message Bus Socket.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Removed slice User Application Slice.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: app.slice: Consumed 7h 49min 29.557s CPU time, 4.3G memory peak.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Reached target Shutdown.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Finished Exit the Session.
Dec 06 13:33:53 tracey-aspiretc780 systemd[594]: Reached target Exit the Session.
Dec 06 13:33:53 tracey-aspiretc780 (sd-pam)[596]: pam_unix(systemd-user:session): session closed for user tracey
Dec 06 13:33:53 tracey-aspiretc780 systemd-logind[486]: Removed session 2.
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: user@1000.service: Deactivated successfully.
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: Stopped User Manager for UID 1000.
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: user@1000.service: Consumed 8h 35min 15.244s CPU time, 5.1G memory peak.
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: Stopping Permit User Sessions...
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: Stopping User Runtime Directory /run/user/1000...
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: run-user-1000.mount: Deactivated successfully.
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: Unmounted /run/user/1000.
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: systemd-user-sessions.service: Deactivated successfully.
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: Stopped Permit User Sessions.
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: user-runtime-dir@1000.service: Deactivated successfully.
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: Stopped User Runtime Directory /run/user/1000.
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: Removed slice User Slice of UID 1000.
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: user-1000.slice: Consumed 8h 35min 17.587s CPU time, 5.2G memory peak.
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: Stopped target Network.
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: Stopped target Remote File Systems.
Dec 06 13:33:53 tracey-aspiretc780 NetworkManager[481]: <info> [1765042433.8939] caught SIGTERM, shutting down normally.
Dec 06 13:33:53 tracey-aspiretc780 wpa_supplicant[564]: p2p-dev-wlp2s0: CTRL-EVENT-DSCP-POLICY clear_all
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: Stopping Network Manager...
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: Stopping User Login Management...
Dec 06 13:33:53 tracey-aspiretc780 wpa_supplicant[564]: nl80211: deinit ifname=p2p-dev-wlp2s0 disabled_11b_rates=0
Dec 06 13:33:53 tracey-aspiretc780 NetworkManager[481]: <info> [1765042433.8949] dhcp4 (enp1s0): canceled DHCP transaction
Dec 06 13:33:53 tracey-aspiretc780 NetworkManager[481]: <info> [1765042433.8949] dhcp4 (enp1s0): activation: beginning transaction (timeout in 45 seconds)
Dec 06 13:33:53 tracey-aspiretc780 NetworkManager[481]: <info> [1765042433.8950] dhcp4 (enp1s0): state changed no lease
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: Stopping WPA supplicant...
Dec 06 13:33:53 tracey-aspiretc780 NetworkManager[481]: <info> [1765042433.8953] manager: NetworkManager state is now CONNECTED_SITE
Dec 06 13:33:53 tracey-aspiretc780 NetworkManager[481]: <info> [1765042433.8958] device (wlp2s0): state change: disconnected -> unmanaged (reason 'unmanaged-quitting', managed-type: 'full')
Dec 06 13:33:53 tracey-aspiretc780 mkinitcpio[5513]: ==> Starting build: 'none'
Dec 06 13:33:53 tracey-aspiretc780 dbus-broker-launch[479]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Dec 06 13:33:53 tracey-aspiretc780 wpa_supplicant[564]: p2p-dev-wlp2s0: CTRL-EVENT-TERMINATING
Dec 06 13:33:53 tracey-aspiretc780 wpa_supplicant[564]: wlp2s0: CTRL-EVENT-DSCP-POLICY clear_all
Dec 06 13:33:53 tracey-aspiretc780 NetworkManager[481]: <info> [1765042433.9535] device (wlp2s0): set-hw-addr: reset MAC address to 30:E3:7A:F3:8A:18 (unmanage)
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: systemd-logind.service: Deactivated successfully.
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: Stopped User Login Management.
Dec 06 13:33:53 tracey-aspiretc780 systemd[1]: systemd-logind.service: Consumed 1.104s CPU time, 5.4M memory peak.
Dec 06 13:33:54 tracey-aspiretc780 wpa_supplicant[564]: wlp2s0: CTRL-EVENT-DSCP-POLICY clear_all
Dec 06 13:33:54 tracey-aspiretc780 wpa_supplicant[564]: nl80211: deinit ifname=wlp2s0 disabled_11b_rates=0
Dec 06 13:33:54 tracey-aspiretc780 wpa_supplicant[564]: wlp2s0: CTRL-EVENT-TERMINATING
Dec 06 13:33:54 tracey-aspiretc780 NetworkManager[481]: <info> [1765042434.0311] device (p2p-dev-wlp2s0): state change: disconnected -> unmanaged (reason 'unmanaged-link-not-init', managed-type: 'removed')
Dec 06 13:33:54 tracey-aspiretc780 systemd[1]: wpa_supplicant.service: Deactivated successfully.
Dec 06 13:33:54 tracey-aspiretc780 systemd[1]: Stopped WPA supplicant.
Dec 06 13:33:54 tracey-aspiretc780 systemd[1]: wpa_supplicant.service: Consumed 2.321s CPU time, 8M memory peak.
Dec 06 13:33:54 tracey-aspiretc780 dbus-broker-launch[479]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Dec 06 13:33:54 tracey-aspiretc780 systemd[1]: Received SIGRTMIN+20 from PID 5588 (plymouthd).
Dec 06 13:33:54 tracey-aspiretc780 mkinitcpio[5513]: -> Running build hook: [sd-shutdown]
Dec 06 13:33:54 tracey-aspiretc780 NetworkManager[481]: <info> [1765042434.9571] exiting (success)
Dec 06 13:33:54 tracey-aspiretc780 systemd[1]: Started Show Plymouth Power Off Screen.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: NetworkManager.service: Deactivated successfully.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Stopped Network Manager.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: NetworkManager.service: Consumed 6.518s CPU time, 18.1M memory peak.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Stopped target Basic System.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: systemd-ask-password-plymouth.path: Deactivated successfully.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Stopped Forward Password Requests to Plymouth Directory Watch.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Stopped target Path Units.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: cups.path: Deactivated successfully.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Stopped CUPS Scheduler.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Stopped target Slice Units.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Removed slice User and Session Slice.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: user.slice: Consumed 8h 35min 17.587s CPU time, 5.2G memory peak.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Stopped target Socket Units.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: cups.socket: Deactivated successfully.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Closed CUPS Scheduler.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: dirmngr@etc-pacman.d-gnupg.socket: Deactivated successfully.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Closed GnuPG network certificate management daemon for /etc/pacman.d/gnupg.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Removed slice Slice /system/dirmngr.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: gpg-agent-browser@etc-pacman.d-gnupg.socket: Deactivated successfully.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers) for /etc/pacman.d/gnupg.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Removed slice Slice /system/gpg-agent-browser.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: gpg-agent-extra@etc-pacman.d-gnupg.socket: Deactivated successfully.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Closed GnuPG cryptographic agent and passphrase cache (restricted) for /etc/pacman.d/gnupg.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Removed slice Slice /system/gpg-agent-extra.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: gpg-agent-ssh@etc-pacman.d-gnupg.socket: Deactivated successfully.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Closed GnuPG cryptographic agent (ssh-agent emulation) for /etc/pacman.d/gnupg.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Removed slice Slice /system/gpg-agent-ssh.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: gpg-agent@etc-pacman.d-gnupg.socket: Deactivated successfully.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Closed GnuPG cryptographic agent and passphrase cache for /etc/pacman.d/gnupg.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Removed slice Slice /system/gpg-agent.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: keyboxd@etc-pacman.d-gnupg.socket: Deactivated successfully.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Closed GnuPG public key management service for /etc/pacman.d/gnupg.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Removed slice Slice /system/keyboxd.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: sshd-unix-local.socket: Deactivated successfully.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Closed OpenSSH Server Socket (systemd-ssh-generator, AF_UNIX Local).
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: systemd-hostnamed.socket: Deactivated successfully.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Closed Hostname Service Socket.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: systemd-importd.socket: Deactivated successfully.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Closed Disk Image Download Service Socket.
Dec 06 13:33:55 tracey-aspiretc780 dbus-broker[480]: Dispatched 100098 messages @ 6(±6)μs / message.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Stopping D-Bus System Message Bus...
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: dbus-broker.service: Deactivated successfully.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Stopped D-Bus System Message Bus.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: dbus-broker.service: Consumed 4.011s CPU time, 6.3M memory peak.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: dbus.socket: Deactivated successfully.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Closed D-Bus System Message Bus Socket.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Stopped target System Initialization.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: proc-sys-fs-binfmt_misc.automount: Deactivated successfully.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Unset automount Arbitrary Executable File Formats File System Automount Point.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Stopped target Local Encrypted Volumes.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: systemd-ask-password-wall.path: Deactivated successfully.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Stopped target Local Integrity Protected Volumes.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Stopped target Local Verity Protected Volumes.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: systemd-sysctl.service: Deactivated successfully.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Stopped Apply Kernel Variables.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: systemd-coredump.socket: Deactivated successfully.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Closed Process Core Dump Socket.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: systemd-modules-load.service: Deactivated successfully.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Stopped Load Kernel Modules.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Stopping Network Time Synchronization...
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Stopping Record System Boot/Shutdown in UTMP...
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: systemd-vconsole-setup.service: Deactivated successfully.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Stopped Virtual Console Setup.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Stopping Virtual Console Setup...
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Starting Virtual Console Setup...
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: systemd-timesyncd.service: Deactivated successfully.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Stopped Network Time Synchronization.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: systemd-update-utmp.service: Deactivated successfully.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Stopped Record System Boot/Shutdown in UTMP.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: systemd-tmpfiles-setup.service: Deactivated successfully.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Stopped Create System Files and Directories.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Stopped target Local File Systems.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Unmounting /boot/efi...
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Unmounting Temporary Directory /tmp...
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: tmp.mount: Deactivated successfully.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Unmounted Temporary Directory /tmp.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Stopped target Swaps.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: boot-efi.mount: Deactivated successfully.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Unmounted /boot/efi.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Reached target Unmount All Filesystems.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: systemd-fsck@dev-disk-by\x2duuid-9024\x2dC57B.service: Deactivated successfully.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Stopped File System Check on /dev/disk/by-uuid/9024-C57B.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Removed slice Slice /system/systemd-fsck.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Stopped target Preparation for Local File Systems.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Stopping Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: systemd-remount-fs.service: Deactivated successfully.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Stopped Remount Root and Kernel File Systems.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: systemd-tmpfiles-setup-dev.service: Deactivated successfully.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Stopped Create Static Device Nodes in /dev.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: systemd-tmpfiles-setup-dev-early.service: Deactivated successfully.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Stopped Create Static Device Nodes in /dev gracefully.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: lvm2-monitor.service: Deactivated successfully.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Stopped Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Dec 06 13:33:55 tracey-aspiretc780 systemd[1]: Finished Virtual Console Setup.
Dec 06 13:33:55 tracey-aspiretc780 mkinitcpio[5513]: -> Running build hook: [plymouth-shutdown]
Dec 06 13:33:56 tracey-aspiretc780 mkinitcpio[5513]: ==> Build complete.
Dec 06 13:33:56 tracey-aspiretc780 systemd[1]: mkinitcpio-generate-shutdown-ramfs.service: Deactivated successfully.
Dec 06 13:33:56 tracey-aspiretc780 systemd[1]: Finished Generate shutdown-ramfs.
Dec 06 13:33:56 tracey-aspiretc780 systemd[1]: Reached target System Shutdown.
Dec 06 13:33:56 tracey-aspiretc780 systemd[1]: Reached target Late Shutdown Services.
Dec 06 13:33:56 tracey-aspiretc780 systemd[1]: Starting Tell Plymouth To Jump To initramfs...
Dec 06 13:33:56 tracey-aspiretc780 systemd[1]: systemd-poweroff.service: Deactivated successfully.
Dec 06 13:33:56 tracey-aspiretc780 systemd[1]: Finished System Power Off.
Dec 06 13:33:56 tracey-aspiretc780 systemd[1]: Reached target System Power Off.
Dec 06 13:33:56 tracey-aspiretc780 systemd[1]: Shutting down.
Dec 06 13:33:56 tracey-aspiretc780 systemd-shutdown[1]: Syncing filesystems and block devices.
Dec 06 13:33:56 tracey-aspiretc780 systemd-shutdown[1]: Sending SIGTERM to remaining processes...
Dec 06 13:33:56 tracey-aspiretc780 systemd-journald[295]: Received SIGTERM from PID 1 (systemd-shutdow).
Dec 06 13:33:56 tracey-aspiretc780 systemd-journald[295]: Journal stopped
They almost look identical, and both look like they shutdown properly. It’s like its just not actually hitting the power switch for you.
I even went as far as hacking together something so I could somewhat diff your logs..
vim -d \
<(tail -200 broke.log | sed -e 's/^\(\S\+\s\+\)\{4\}//' -e 's/\[[0-9]\+\]/[]/' | tac ) \
<(tail -200 working.log | sed -e 's/^\(\S\+\s\+\)\{4\}//' -e 's/\[[0-9]\+\]/[]/'| tac)
And it looks a little more comparable..
One thing I’m confident in saying, is you can shutdown your computer off just fine. It’s 100% safe! (If you’ve waited the adequate amount of time obviously).
Why it’s not shutting off, I’m not sure. I would try disabling Plymouth just to see.
Thank you so much for looking into this.
I’ll check out that comparison. I find it interesting. We’ve been waiting some time before shutting it down if it won’t power off. We just never know when it won’t power off completely. Its curious behaviour as our two PCs should be identical in every way and I don’t have the same issue. I’ll pull a log from my PC and compare it to see if there are any differences. Might be interesting.
If the problem persists after this massive update, which may be likely, I would look into this..
It has to to do an ACPI call, which shuts off your system, these are tied to your BIOS. Are the BIOS versions identical on each system?
One other test that would be useful, but only if it can be repeated. (So this may not even help.)
Do a halt. Take note, this does not properly shut down your system. So, exit out out everything you can. And make sure to run a sync first. (Flush out writes to mounted file systems.)
To be even more safe you could run sudo systemctl isolate multi-user (like going to the old school run level 2). It will kill many services including SDDM (your desktop). And you can login via tty.
sync
sudo poweroff -f
This should just stop and power off in seconds or less. This should practically never fail when turning it off, it doesn’t wait on services or even killing processes. Just off.
We had the big update, 2gb, on Monday on both of our Acer PCs. I noticed we are now on KDE Plasma 6.5.3 and the graphics platform is Wayland. There were no issues with the upgrade. It powered off properly after the update. I won’t change any settings and see what happens over the next week. So far so good! ![]()
Hi Wollie, thanks for the reply, we have just had the update to 6.5.3. So, we’re just waiting to see if the issue is resolved.
Hi Molski, Thanks for the reply!
I never thought to check and compare the BIOS. I’ll do that. The two Acer TC-780s were purchased at the same time but it is worth looking at. Since we had the update to KDE Plasma 6.5.3, and Wayland, I’m going to see what happens over the next few days in order to see if the update improves the situation. I’ll perform the test you recommend.
I have that same desktop and have not had any issue’s with shutting down.I am also on the unstable branch so maybe that made a difference.I also have in system settings under power management for when power button is pressed to shutdown.I am pretty sure there is also a setting in the bios to set for shutdown as well.Maybe the latest updates you got fixed the issue.
Hi straycat, Manjaro with the KDE Plasma desktop has worked perfectly on every other PC I have installed it on except for this one machine we have. So, we aren’t sure what the problem is. Hopefully the update to Plasma will resolve the issue.
