Try creating newuser first.
Jumping the gun here a bit, maybe, but for info, after the latest update to 5.26.3 no hitchesā¦everything seems to be A-OK(stable?) after an equally uneventful reboot.
Hello there ![]()
I realised that if I move windows around with the meta key in order to quick tile them, the windows get frozen and text gets a little bit blurred (happens to all applications and on different screens). If I move a window with meta + left/right to the left or right side of the screen there is actually no issue. The issue occurs if I divide the screen into four or when I split the screen horizontally.
It is possible to ārecoverā the frozen window if I drag it a little bit with the mouse or by meta + left for example. If I drag the window to the preffered size/position manually, I also didnāt faced any issues as well.
I noticed it since 2 releases (not 100% sure) and currently running KDE plasma version 5.26.3. Didnāt found this behaviour described anywhere.
Is there anything to troubleshoot or could you recommend watching any logs? Anything else I can do?
Have a great evening!
Most issues are migration from older Plasma installs. Those scripts to update settings mostly donāt work properly. So create a new user with fresh settings and see if it is still an issue. You can also test a new ISO with 5.26.3 preinstalled: Release 202211150747 Ā· manjaro/release-review Ā· GitHub
Another dissatisfied 5.26.3 customer⦠![]()
ā¦Some seemingly have the luck of the Irishā¦and others not, alasā¦! ![]()
I donāt think it plasma 5.26 is at level of maturity that 5.24 provides. I still have couple of broken 3rd party widgets (donāt know which is to blame here), and get some random plasma crashes while playing video, though the frequency is much less than what was the case with 5.25. I think 5.24 was just a high point in terms of stability with multiple past releases mostly focussing on bug fixes and refining the experience, instead of major rewrites and addition of new features
Iām sure KDEās dev team will iron things out, and, then, weāll pass on toā¦5.27 ![]()
Yes, all will be fixed by 2028⦠![]()
ā¦And, after that - yupee! - thereās Plasma 6.0 inā¦2023ā¦
Could this be the beginning of another serial(killer?)� ![]()
Maybe Iām being unfair - Iāll be positive ! - and there will only be a series of none-connected incidents along the lineā¦or, perhaps, not!..? ![]()
@Aragorn. I think youāre being ridiculous now. 2028?
You know itāll take them longer than six years. Come on. Maybe 2032.
Potential trouble on the way for those of us who chose to stay with 5.24 LTS⦠![]()
This is from todayās announcement thread for the updates to the Testing branch.
5.24 LTS has no problem on my computer running current Testing with KDE framework 5.100, so it should be no issue for anybody I thinkā¦
Cheers ! ![]()
Eddy
Oh man. I so hope you are correct.
I am correct, even my second install with Debian unstable/SID has no problems with the same setup ! ![]()
Cheers,
Eddy
Hi All,
I am also experiencing similar issues with missing system tray icons etc⦠wondering if there is final fix for to this problem please?
Kernel: 5.15.78-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=532ab3a1-b4c8-4fd4-850b-e24e86eac742 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Convertible System: HP product: HP ZBook Studio x360 G5 v: N/A
serial: Chassis: type: 31 serial:
Mobo: HP model: 844F v: KBC Version 16.4E.00 serial:
UEFI: HP v: Q71 Ver. 01.20.00 date: 03/22/2022
ID-1: BAT0 charge: 60.7 Wh (98.4%) condition: 61.7/96.4 Wh (64.0%)
volts: 12.1 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: status: N/A cycles: 383
RAM: total: 31.16 GiB used: 3.5 GiB (11.2%)
Info: model: Intel Xeon E-2186M bits: 64 type: MT MCP arch: Coffee Lake
level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF0
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1205 high: 2200 min/max: 800/4800 scaling:
driver: intel_pstate governor: powersave cores: 1: 1000 2: 1000 3: 1784
4: 2200 5: 1861 6: 1021 7: 900 8: 900 9: 900 10: 900 11: 1000 12: 1000
bogomips: 69629
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel Coffee Lake-S GT2 [UHD Graphics P630] vendor: Hewlett-Packard
ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, HDMI-A-3
bus-ID: 00:02.0 chip-ID: 8086:3e94 class-ID: 0300
Device-2: NVIDIA GP107GLM [Quadro P1000 Mobile] vendor: Hewlett-Packard
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 520.xx+
status: current (as of 2022-10) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1cbb class-ID: 0300
Device-3: Cheng Uei Precision Industry (Foxlink) HP HD Camera type: USB
driver: uvcvideo bus-ID: 1-7:3 chip-ID: 05c8:0808 class-ID: 0e02
serial:
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa dri: iris
gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.88x11.22")
s-diag: 1052mm (41.43")
Monitor-1: HDMI-1-0 pos: right res: 1920x1080 hz: 60 dpi: 82
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
Monitor-2: eDP-1 pos: primary,left res: 1920x1080 hz: 120 dpi: 142
size: 344x194mm (13.54x7.64") diag: 395mm (15.55") modes: N/A
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: Mesa Intel UHD Graphics P630 (CFL
GT2) direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Sound API: ALSA v: k5.15.78-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.59 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
IF: wlp0s20f3 state: down mac:
Device-2: ICS Advent USB 10/100 LAN type: USB driver: cdc_ether
bus-ID: 1-11.2.4:11 chip-ID: 0fe6:9900 class-ID: 0a00 serial:
IF: eth0 state: up speed: 100 Mbps duplex: half mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: noprefixroute scope: link
WAN IP:
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:12 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 480.67 GiB used: 35.67 GiB (7.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB512HAJQ-000H1
lanes: 4 type: SSD serial: rev: EXA73H1Q temp: 40.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB model: General USB Flash Disk
size: 3.73 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: rev: 1100 scheme: MBR
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%) used: 35.67 GiB (7.6%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 532ab3a1-b4c8-4fd4-850b-e24e86eac742
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: E04A-7965
ID-1: /dev/sda1 maj-min: 8:1 size: 3.32 GiB fs: iso9660
ID-2: /dev/sda2 maj-min: 8:2 size: 4 MiB fs: vfat label: MISO_EFI
uuid: C80E-8B3F
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-4:2 info: Silicon Motion - Taiwan (formerly Feiya ) Flash Drive
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 090c:1000 class-ID: 0806 serial:
Device-2: 1-7:3 info: Cheng Uei Precision Industry (Foxlink) HP HD Camera
type: Video driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 05c8:0808 class-ID: 0e02 serial:
Device-3: 1-8:4 info: Validity Sensors type: driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 138a:00ab
class-ID: ff00 serial:
Hub-2: 1-11:5 info: Huasheng USB2.0 HUB ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 214b:7250 class-ID: 0900
Device-1: 1-11.1:7 info: HP Optical Mouse [672662-001] type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 03f0:094a class-ID: 0301
Hub-3: 1-11.2:8 info: Huasheng USB2.0 HUB ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-11.2.3:10 info: Super Top microSD card reader (SY-T18)
power: 100mA chip-ID: 14cd:1212 class-ID: 0806 serial:
Device-2: 1-11.2.4:11 info: ICS Advent USB 10/100 LAN
type: Ethernet Network,CDC-Data driver: cdc_ether interfaces: 2 rev: 2.1
speed: 480 Mb/s power: 100mA chip-ID: 0fe6:9900 class-ID: 0a00
serial:
Device-3: 1-11.3:9 info: Dell KB216 Wired Keyboard type: Keyboard,HID
power: 100mA chip-ID: 413c:2113 class-ID: 0300
Device-4: 1-14:12 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-4: 2-0:1 info: Super-speed hub ports: 10 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 47.0 C pch: 49.0 C mobo: N/A
Processes: 289 Uptime: 8m wakeups: 3 Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
pkgs: 1215 libs: 317 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.23
acpi
acpid
adobe-source-han-sans-cn-fonts
adobe-source-han-sans-jp-fonts
adobe-source-han-sans-kr-fonts
adobe-source-sans-fonts
alsa-firmware
alsa-utils
ark
avahi
b43-fwcutter
bash
bluedevil
breeze-gtk
btrfs-progs
bzip2
coreutils
cpupower
cronie
cryptsetup
device-mapper
dhclient
dhcpcd
diffutils
dmidecode
dmraid
dnsmasq
dolphin
dolphin-plugins
dosfstools
e2fsprogs
ecryptfs-utils
efibootmgr
elisa
exfatprogs
f2fs-tools
ffmpeg
ffmpegthumbs
file
filelight
filesystem
findutils
firefox
fwupd
gawk
gcc-libs
gettext
glibc
glibc-locales
gnome-themes-extra
grep
grub
grub-btrfs
grub-theme-manjaro
gst-libav
gst-plugins-bad
gst-plugins-base
gst-plugins-good
gst-plugins-ugly
gtk3
gwenview
gzip
haveged
htop
inetutils
intel-ucode
inxi
iproute2
iputils
jfsutils
kaccounts-providers
kamera
kate
kcalc
kde-gtk-config
kdeconnect
kdegraphics-thumbnailers
kdenetwork-filesharing
kdeplasma-addons
keditbookmarks
kfind
kgamma5
khelpcenter
khotkeys
kimageformats
kinfocenter
kinit
kio-extras
kmenuedit
konsole
kscreen
kscreenlocker
ksshaskpass
ksysguard
ksystemlog
kwallet-pam
kwalletmanager
kwayland-integration
kwin
kwrited
less
lib32-libcanberra
lib32-libva-intel-driver
lib32-libva-mesa-driver
lib32-libva-vdpau-driver
lib32-mesa-demos
lib32-nvidia-utils
libcanberra
libdvdcss
libpamac-flatpak-plugin
libva-intel-driver
libva-mesa-driver
libva-vdpau-driver
licenses
linux515
linux515-nvidia
logrotate
lvm2
man-db
man-pages
manjaro-alsa
manjaro-application-utility
manjaro-browser-settings
manjaro-documentation-en
manjaro-firmware
manjaro-hello
manjaro-hotfixes
manjaro-kde-settings
manjaro-printer
manjaro-pulse
manjaro-release
manjaro-settings-manager-kcm
manjaro-settings-manager-knotifier
manjaro-system
manjaro-zsh-config
matray
mdadm
memtest86+
mesa-demos
mhwd
mhwd-db
milou
mkinitcpio-openswap
mobile-broadband-provider-info
modemmanager
mtpfs
nano
nano-syntax-highlighting
neofetch
networkmanager
networkmanager-l2tp
networkmanager-openconnect
networkmanager-openvpn
networkmanager-pptp
networkmanager-vpnc
nfs-utils
noto-fonts
noto-fonts-emoji
nss-mdns
ntfs-3g
ntp
numlockx
nvidia-prime
nvidia-utils
okular
onlyoffice-desktopeditors
openresolv
openssh
os-prober
oxygen
oxygen-icons
p7zip
packagekit-qt5
pacman
pamac-cli
pamac-gtk
pamac-tray-icon-plasma
partitionmanager
pciutils
perl
perl-file-mimeinfo
phonon-qt5-gstreamer
plasma-browser-integration
plasma-desktop
plasma-nm
plasma-pa
plasma-simplemenu
plasma-systemmonitor
plasma-workspace
plasma-workspace-wallpapers
poppler-data
powerdevil
powertop
print-manager
procps-ng
psmisc
pulseaudio-bluetooth
pulseaudio-ctl
pulseaudio-zeroconf
python-pillow
python-pip
python-pyqt5
python-pysmbc
python-reportlab
qt5-imageformats
qt5-virtualkeyboard
reiserfsprogs
rsync
ruby
s-nail
samba
sddm
sddm-breath-theme
sddm-kcm
sed
shadow
skanlite
snapd
sof-firmware
spectacle
spectre-meltdown-checker
sshfs
sudo
sysfsutils
system-config-printer
systemd
systemd-fsck-silent
systemd-kcm
systemd-sysvcompat
systemsettings
tar
terminus-font
texinfo
timeshift
timeshift-autosnap-manjaro
ttf-dejavu
ttf-droid
ttf-inconsolata
ttf-indic-otf
ttf-liberation
udiskie
udisks2
unarchiver
usb_modeswitch
usbutils
util-linux
vi
vlc
wget
which
wireless-regdb
wpa_supplicant
xdg-desktop-portal-kde
xdg-user-dirs
xdg-utils
xf86-input-elographics
xf86-input-evdev
xf86-input-libinput
xf86-input-void
xfsprogs
xorg-mkfontscale
xorg-server
xorg-twm
xorg-xinit
xorg-xkill
xz
yakuake
Although my system is still running without a hitch, this might be related:
Yes same here.
I am using:
KDE Plasma 5.26.3
KDE Framework 5.99.0
Kernel 5.19.17-2-MANJARO
Hardware is a Lenovo L14 Gen 1 AMD, so with Radeon Graphics inside, also Multimonitor Setup. Two external Displays, one via USB-C Hub and one via HDMI.
Have the same problems sind appr. 1-2 Weeks. Notofications go to a black rectangle and the whole Desktop seems to crash.
Is there any guide how to downgrade to something less buggy?
Yes, there is, albeit with a couple of caveats, such as that we donāt know how much longer this will work, given that nobodyās willing to maintain the LTS release packages.
But had you read through the whole thread, then you would have already found the workaround. ![]()
Yes i have read this now, but that really doesnt look like a very appealing approach.
At least i have found out that it is possible to restart the plasmashell by posting kquitapp5 plasmashell && plasmashell into the krunner menu, so i dont have to reboot once a day.
Hope that issues get fixed quite fast by the KDE Team.
