Hi there,
i am using Manjaro with KDE since the start of 2021 without any bigger issues.
But since the last 1 or 2 weeks i have the problem that from time to time the pop up notofication windows is only a black rectangle as well as the context menus. Also the application Launcher, Taskbar etc does not work anymore with forces me to hard reset my Laptop when this happens.
Is this Problem known?
I am using:
KDE Plasma 5.26.3
KDE Framework 5.99.0
Kernel 5.19.17-2-MANJARO
Any Help appriciated
Do you have a custom theme installed? And is everything up-to-date?
Additionally, you should add the output of inxi -Fazy and a the recent journal when the failure happend.
No custom theme installed. And yes, all updates are applied.
Posting any outputs can be a problem because when i crashes there is not much i can do anymore.
But i think that might happened before i needed to hardreset my Laptop:
Nov 22 12:10:36 hinkpadt kernel: audit: type=1131 audit(1669115436.652:496): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 22 12:10:36 hinkpadt audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 22 12:11:30 hinkpadt plasmashell[1645]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55926bf48e90) QQmlContext(0x55926940f5c0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Nov 22 12:11:30 hinkpadt plasmashell[1645]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:221:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Nov 22 12:11:30 hinkpadt plasmashell[1645]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:221:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Nov 22 12:11:31 hinkpadt plasmashell[1645]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:221:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Nov 22 12:11:31 hinkpadt rtkit-daemon[1586]: Supervising 0 threads of 0 processes of 0 users.
Nov 22 12:11:35 hinkpadt kwin_x11[1600]: kwin_core: XCB error: 152 (BadDamage), sequence: 17397, resource id: 17288503, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Nov 22 12:12:24 hinkpadt plasmashell[1645]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x559269748ef0) QQmlContext(0x55926940f5c0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Nov 22 12:12:24 hinkpadt plasmashell[1645]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:221:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Nov 22 12:12:24 hinkpadt plasmashell[1645]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:221:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Nov 22 12:12:24 hinkpadt plasmashell[1645]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:45:27: QML ScrollBar: Binding loop detected for property "visible"
Nov 22 12:12:24 hinkpadt plasmashell[1645]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/SelectableLabel.qml:38:5: QML TextArea: Binding loop detected for property "implicitHeight"
Nov 22 12:12:29 hinkpadt kwin_x11[1600]: kwin_core: XCB error: 152 (BadDamage), sequence: 20861, resource id: 17288779, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Nov 22 12:12:56 hinkpadt plasmashell[1645]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55926b03a1f0) QQmlContext(0x55926940f5c0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Nov 22 12:12:56 hinkpadt plasmashell[1645]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:221:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Nov 22 12:12:56 hinkpadt plasmashell[1645]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:221:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Nov 22 12:12:56 hinkpadt plasmashell[1645]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:45:27: QML ScrollBar: Binding loop detected for property "visible"
Nov 22 12:12:56 hinkpadt plasmashell[1645]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/SelectableLabel.qml:38:5: QML TextArea: Binding loop detected for property "implicitHeight"
Nov 22 12:13:01 hinkpadt kwin_x11[1600]: kwin_core: XCB error: 152 (BadDamage), sequence: 24096, resource id: 17289032, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Nov 22 12:13:18 hinkpadt rtkit-daemon[1586]: Supervising 0 threads of 0 processes of 0 users.
Nov 22 12:14:08 hinkpadt rtkit-daemon[1586]: Supervising 0 threads of 0 processes of 0 users.
Nov 22 12:14:39 hinkpadt rtkit-daemon[1586]: Supervising 0 threads of 0 processes of 0 users.
Nov 22 12:14:46 hinkpadt thunderbird[2233]: console.log: "Passing provided credentials for user <bjoernsengotta@web.de> to nsIHttpChannel."
Nov 22 12:14:47 hinkpadt thunderbird[2233]: console.log: "Passing provided credentials for user <bjoernsengotta@web.de> to nsIHttpChannel."
Nov 22 12:14:59 hinkpadt plasmashell[1645]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55926a9b0520) QQmlContext(0x55926940f5c0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Nov 22 12:14:59 hinkpadt plasmashell[1645]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:221:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Nov 22 12:14:59 hinkpadt plasmashell[1645]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:221:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Nov 22 12:15:04 hinkpadt kwin_x11[1600]: kwin_core: XCB error: 152 (BadDamage), sequence: 28254, resource id: 17289300, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Nov 22 12:15:09 hinkpadt plasmashell[1645]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5592696daed0) QQmlContext(0x55926940f5c0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Nov 22 12:15:09 hinkpadt plasmashell[1645]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:221:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Nov 22 12:15:09 hinkpadt plasmashell[1645]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:221:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Nov 22 12:15:41 hinkpadt pamac-tray-plas[2249]: updates_checker.vala:71: check updates
Nov 22 12:15:41 hinkpadt dbus-daemon[772]: [system] Activating via systemd: service name='org.freedesktop.locale1' unit='dbus-org.freedesktop.locale1.service' requested by ':1.730' (uid=1000 pid=36451 comm="pamac checkupdates -q --refresh-tmp-files-dbs --us")
Nov 22 12:15:41 hinkpadt audit: BPF prog-id=85 op=LOAD
Nov 22 12:15:41 hinkpadt audit: BPF prog-id=86 op=LOAD
Nov 22 12:15:41 hinkpadt audit: BPF prog-id=87 op=LOAD
Nov 22 12:15:41 hinkpadt systemd[1]: Starting Locale Service...
Nov 22 12:15:41 hinkpadt kernel: audit: type=1334 audit(1669115741.984:497): prog-id=85 op=LOAD
Nov 22 12:15:41 hinkpadt kernel: audit: type=1334 audit(1669115741.984:498): prog-id=86 op=LOAD
Nov 22 12:15:41 hinkpadt kernel: audit: type=1334 audit(1669115741.984:499): prog-id=87 op=LOAD
Nov 22 12:15:42 hinkpadt dbus-daemon[772]: [system] Successfully activated service 'org.freedesktop.locale1'
Nov 22 12:15:42 hinkpadt systemd[1]: Started Locale Service.
Nov 22 12:15:42 hinkpadt audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 22 12:15:42 hinkpadt kernel: audit: type=1130 audit(1669115742.044:500): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 22 12:15:44 hinkpadt pamac-tray-plas[2249]: updates_checker.vala:101: 3 updates found
Nov 22 12:16:12 hinkpadt systemd[1]: systemd-localed.service: Deactivated successfully.
Nov 22 12:16:12 hinkpadt audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 22 12:16:12 hinkpadt kernel: audit: type=1131 audit(1669115772.081:501): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 22 12:16:12 hinkpadt audit: BPF prog-id=0 op=UNLOAD
Nov 22 12:16:12 hinkpadt kernel: audit: type=1334 audit(1669115772.231:502): prog-id=0 op=UNLOAD
Nov 22 12:16:12 hinkpadt kernel: audit: type=1334 audit(1669115772.231:503): prog-id=0 op=UNLOAD
Nov 22 12:16:12 hinkpadt kernel: audit: type=1334 audit(1669115772.231:504): prog-id=0 op=UNLOAD
Nov 22 12:16:12 hinkpadt rtkit-daemon[1586]: Supervising 0 threads of 0 processes of 0 users.
Nov 22 12:17:43 hinkpadt wpa_supplicant[1200]: wlp3s0: WPA: Group rekeying completed with 74:42:7f:24:2b:f7 [GTK=CCMP]
Nov 22 12:20:43 hinkpadt rtkit-daemon[1586]: Supervising 0 threads of 0 processes of 0 users.
I don’t know KDE that well. The file that it reports missing belongs to plasma-workspace.
You coudl try reinstall it pamac reinstall plasma-workspace
This problem has been reported before. Please read through the following thread.
