Hi all, I have problem with my headphones as they are not detected by KDE. Interestingly enough, microphone has been found and works well. I have Logitech G933, as advised here below are inxi and pacmd outputs.
This issue already lasts since last Mikah update. I had a hope for subsequent release that would fix that but unfortunately that did not happen.
inxi --full --admin --verbosity=7 --filter --no-host
System: Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=56687722-8455-4abb-869d-325f37727313 rw quiet apparmor=1
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: Dell product: XPS 15 9570 v: N/A serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0D0T05 v: A00 serial: <filter> UEFI: Dell v: 1.9.1 date: 04/08/2019
Battery: ID-1: BAT0 charge: 85.2 Wh condition: 85.2/97.0 Wh (88%) volts: 13.0/11.4 model: SMP DELL GPM0365 type: Li-ion
serial: <filter> status: Full
Memory: RAM: total: 15.29 GiB used: 5.35 GiB (35.0%)
CPU: Topology: 6-Core model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Kaby Lake family: 6 model-id: 9E (158)
stepping: A (10) microcode: D6 L2 cache: 9216 KiB bogomips: 52815
Speed: 3600 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 3313 2: 3445 3: 3411 4: 3503 5: 3594 6: 3483 7: 3439
8: 3398 9: 3280 10: 3389 11: 3523 12: 3185
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art avx avx2 bmi1 bmi2 bts clflush
clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel UHD Graphics 630 vendor: Dell driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:3e9b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Dell driver: nvidia v: 430.64
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1c8c
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo bus ID: 1-12:6 chip ID: 0c45:671d
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: modesetting,nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 5360x1440 s-dpi: 96 s-size: 1418x381mm (55.8x15.0") s-diag: 1468mm (57.8")
Monitor-1: eDP-1-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
Monitor-2: DP-1-1 res: 3440x1440 hz: 60 dpi: 109 size: 800x335mm (31.5x13.2") diag: 867mm (34.1")
OpenGL: renderer: GeForce GTX 1050 Ti with Max-Q Design/PCIe/SSE2 v: 4.6.0 NVIDIA 430.64 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:a348
Device-2: Logitech G933 Wireless Headset Dongle type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-5.4:16
chip ID: 046d:0a5b
Sound Server: ALSA v: k5.8.6-1-MANJARO
Network: Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter vendor: Bigfoot Networks driver: ath10k_pci
v: kernel port: 3000 bus ID: 3b:00.0 chip ID: 168c:003e
IF: wlp59s0 state: up mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Device-2: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb bus ID: 1-4:2 chip ID: 0cf3:e300
Device-3: TP-Link type: USB driver: cdc_ether bus ID: 1-5.3:7 chip ID: 2357:0602 serial: <filter>
IF: enp0s20f0u5u3c2 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-1: br-fd4c3444b56f state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: docker_gwbridge state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IP v6: <filter> scope: link
IF-ID-4: veth3c96ba2 state: up speed: 10000 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 476.94 GiB used: 93.87 GiB (19.7%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: PC401 NVMe 512GB size: 476.94 GiB block size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 80007E00 scheme: GPT
RAID: Message: No RAID data was found.
Partition: ID-1: / raw size: 97.66 GiB size: 95.62 GiB (97.92%) used: 30.42 GiB (31.8%) fs: ext4 dev: /dev/nvme0n1p5
label: N/A uuid: 56687722-8455-4abb-869d-325f37727313
ID-2: /boot/efi raw size: 1.84 GiB size: 1.83 GiB (99.80%) used: 280 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p7
label: N/A uuid: 1F65-7A1A
ID-3: /home raw size: 97.65 GiB size: 95.62 GiB (97.92%) used: 63.45 GiB (66.4%) fs: ext4 dev: /dev/dm-0 label: N/A
uuid: 79cc9764-40f6-426c-ac84-b143c6823ee0
Swap: Alert: No Swap data was found.
Unmounted: ID-1: /dev/nvme0n1p1 size: 680.0 MiB fs: vfat label: ESP uuid: 9EBE-017C
ID-2: /dev/nvme0n1p2 size: 128.0 MiB fs: <superuser/root required> label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 size: 261.42 GiB fs: bitlocker label: N/A uuid: N/A
ID-4: /dev/nvme0n1p4 size: 97.66 GiB fs: crypto_luks label: N/A uuid: 6f85c7fb-d7e6-4142-b174-a9bf1f25013a
ID-5: /dev/nvme0n1p6 size: 17.58 GiB fs: ext4 label: N/A uuid: f7471c25-5239-4a0f-a18c-cba227f9fd53
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 1-2:13 info: Logitech G933 Headset Battery Charger type: HID driver: hid-generic,usbhid interfaces: 1
rev: 1.1 speed: 12 Mb/s chip ID: 046d:0a5d
Device-2: 1-4:2 info: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: Bluetooth driver: btusb interfaces: 2 rev: 2.0
speed: 12 Mb/s chip ID: 0cf3:e300
Hub: 1-5:3 info: Texas Instruments ports: 6 rev: 2.1 speed: 480 Mb/s chip ID: 0451:8442
Device-1: 1-5.1:15 info: N/A type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s
chip ID: 258a:0001
Device-2: 1-5.2:10 info: Logitech M-R0017 [G700s Rechargeable Gaming Mouse] type: Mouse,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 046d:c07c serial: <filter>
Device-3: 1-5.3:7 info: TP-Link type: Ethernet Network,CDC-Data driver: cdc_ether interfaces: 2 rev: 2.1
speed: 480 Mb/s chip ID: 2357:0602 serial: <filter>
Device-4: 1-5.4:16 info: Logitech G933 Wireless Headset Dongle type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1 speed: 12 Mb/s chip ID: 046d:0a5b
Device-5: 1-5.5:9 info: Texas Instruments type: HID driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 480 Mb/s chip ID: 0451:82ff serial: <filter>
Device-6: 1-7:4 info: Shenzhen Goodix Fingerprint Reader type: Abstract (modem),CDC-Data driver: cdc_acm
interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 27c6:5395 serial: <filter>
Device-7: 1-12:6 info: Microdia Integrated_Webcam_HD type: Video driver: uvcvideo interfaces: 2 rev: 2.0
speed: 480 Mb/s chip ID: 0c45:671d
Hub: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Sensors: System Temperatures: cpu: 69.0 C mobo: N/A gpu: nvidia temp: 56 C
Fan Speeds (RPM): cpu: 4896 fan-2: 4890
Info: Processes: 327 Uptime: 1h 23m Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1373 pacman: 1369 lib: 387
flatpak: 0 snap: 4 Shell: Bash v: 5.0.18 running in: yakuake inxi: 3.1.05
pacmd list-sinks
1 sink(s) available.
* index: 0
driver: <module-alsa-card.c>
flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 9039
volume: front-left: 50097 / 76% / -7,00 dB, front-right: 50097 / 76% / -7,00 dB
balance 0,00
base volume: 65536 / 100% / 0,00 dB
volume steps: 65537
muted: no
current latency: 0,00 ms
max request: 0 KiB
max rewind: 0 KiB
monitor source: 0
sample spec: s16le 2ch 44100Hz
channel map: front-left,front-right
Stereo
used by: 0
linked by: 0
configured latency: 0,00 ms; range is 0,50 .. 2000,00 ms
card: 0 <alsa_card.pci-0000_00_1f.3>
module: 6
properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "ALC3266 Analog"
alsa.id = "ALC3266 Analog"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0xed618000 irq 150"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "a348"
device.product.name = "Cannon Lake PCH cAVS"
device.string = "front:0"
device.buffering.buffer_size = "352800"
device.buffering.fragment_size = "176400"
device.access_mode = "mmap+timer"
device.profile.name = "analog-stereo"
device.profile.description = "Analog Stereo"
device.description = "Built-in Audio Analog Stereo"
alsa.mixer_name = "Realtek ALC3266"
alsa.components = "HDA:10ec0298,1028087c,00100103 HDA:8086280b,80860101,00100000"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
ports:
analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: unknown)
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: no)
properties:
active port: <analog-output-speaker>
