Headphones not detected
Using KDE Manjaro Stable (latest build, updated) on Lenovo Ideapad S540-14IWL
Running latest 5.8 kernel at the time of writing and hybrid nvidia prime drivers 450xx, also optimus-manager-git is installed (I suspect on it to be the cause).
When I plug in the headphones via 3.5mm jack, sound keeps going through the speakers only. Headphones work, as tested on my mobile phone.
I’m relatively new to Linux so I can’t start searching for the problem at all. I hope someone could help me push this through.
Regards,
Alarg
Hello and welcome to Manjaro.
Either you have to select the the output via the means of KDE or you install pavucontrol-qt with which it should be quite easy to select the source.
Hey!
Thanks for the suggestion. I tried it and I can’t see any attached devices, which is strange. I’ve just switched to Windows (dual booted) and the headphones work there.
I’ll keep looking further and let others know if I solved this.
Regards,
Alarg
@Alarg: I may not be able to help specifically but outputs of
inxi --full --admin --verbosity=7 --filter --no-host
and
pacmd list-sinks
may be helpful. Cheers and Welcome!
Thanks! I’m attaching them below:
System:    Kernel: 5.8.3-2-MANJARO x86_64 bits: 64 compiler: N/A
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=982e11fd-ce8c-4ee8-ba1a-2514517a0246 rw quiet
           apparmor=1 security=apparmor resume=UUID=b02c7e05-f919-41c9-abd6-1700a9c0cca3 udev.log_priority=3
           Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Laptop System: LENOVO product: 81ND v: Lenovo IdeaPad S540-14IWL serial: <filter> Chassis: type: 10
           Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <filter> UEFI: LENOVO v: AHCN32WW(V2.09) date: 07/15/2020
Battery:   ID-1: BAT1 charge: 41.3 Wh condition: 41.3/45.0 Wh (92%) volts: 17.3/15.4
           model: 0x53 0x4D 0x50 0x00 0x32 0x30 0x PABAS0241231 type: Li-ion serial: <filter> status: Full cycles: 169
Memory:    RAM: total: 7.62 GiB used: 1.32 GiB (17.3%)
CPU:       Topology: Quad Core model: Intel Core i5-8265U bits: 64 type: MT MCP arch: Kaby Lake family: 6
           model-id: 8E (142) stepping: C (12) microcode: D6 L2 cache: 6144 KiB bogomips: 28808
           Speed: 799 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 801 2: 800 3: 800 4: 800 5: 800 6: 800 7: 799
           8: 800
           Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities arch_perfmon art avx avx2 bmi1
           bmi2 bts clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
           ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify
           ibpb ibrs ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx
           msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts
           rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
           tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves
           xtopology xtpr
           Type: srbds mitigation: TSX disabled
Graphics:  Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:3ea0
           Device-2: NVIDIA GP108M [GeForce MX250] driver: N/A alternate: nouveau, nvidia_drm, nvidia bus ID: 01:00.0
           chip ID: 10de:1d13
           Device-3: Chicony Integrated Camera type: USB driver: uvcvideo bus ID: 1-6:3 chip ID: 04f2:b61e
           serial: <filter>
           Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: modesetting display ID: :0 screens: 1
           Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
           Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 158 size: 309x174mm (12.2x6.9") diag: 355mm (14")
           OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 20.1.6 direct render: Yes
Audio:     Device-1: Intel Cannon Point-LP High Definition Audio vendor: Lenovo driver: snd_hda_intel v: kernel
           alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:9dc8
           Sound Server: ALSA v: k5.8.3-2-MANJARO
Network:   Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel port: 4000 bus ID: 00:14.3
           chip ID: 8086:9df0
           IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Drives:    Local Storage: total: 238.47 GiB used: 40.85 GiB (17.1%)
           ID-1: /dev/nvme0n1 vendor: SK Hynix model: HFS256GD9TNG-L3A0B size: 238.47 GiB block size: physical: 512 B
           logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 80040C10 scheme: GPT
RAID:      Message: No RAID data was found.
Partition: ID-1: / raw size: 50.00 GiB size: 48.97 GiB (97.93%) used: 21.78 GiB (44.5%) fs: ext4 dev: /dev/nvme0n1p6
           label: N/A uuid: 982e11fd-ce8c-4ee8-ba1a-2514517a0246
           ID-2: /boot/efi raw size: 100.0 MiB size: 96.0 MiB (96.00%) used: 25.3 MiB (26.3%) fs: vfat
           dev: /dev/nvme0n1p1 label: N/A uuid: BA9B-6A66
           ID-3: /home raw size: 150.36 GiB size: 147.00 GiB (97.77%) used: 19.05 GiB (13.0%) fs: ext4
           dev: /dev/nvme0n1p7 label: N/A uuid: d647bcdb-0f81-412f-b6c4-a1ecfd198122
Swap:      Kernel: swappiness: 60 (default) cache pressure: 100 (default)
           ID-1: swap-1 type: partition size: 8.00 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3 label: N/A
           uuid: b02c7e05-f919-41c9-abd6-1700a9c0cca3
Unmounted: ID-1: /dev/nvme0n1p2 size: 16.0 MiB fs: <superuser/root required> label: N/A uuid: N/A
           ID-2: /dev/nvme0n1p4 size: 29.50 GiB fs: ntfs label: N/A uuid: EABEB95DBEB922CD
           ID-3: /dev/nvme0n1p5 size: 505.0 MiB fs: ntfs label: N/A uuid: 40AAD50FAAD501F8
USB:       Hub: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
           Device-1: 1-2:2 info: Lenovo Lenovo 300 Wireless Compact Mouse type: Mouse driver: hid-generic,usbhid
           interfaces: 1 rev: 1.1 speed: 12 Mb/s chip ID: 17ef:60ac
           Device-2: 1-6:3 info: Chicony Integrated Camera type: Video driver: uvcvideo interfaces: 2 rev: 2.0
           speed: 480 Mb/s chip ID: 04f2:b61e serial: <filter>
           Device-3: 1-7:4 info: Shenzhen Goodix Fingerprint Reader type: <vendor specific> driver: N/A interfaces: 1
           rev: 2.0 speed: 480 Mb/s chip ID: 27c6:55b4
           Device-4: 1-10:5 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: Bluetooth driver: btusb
           interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 8087:0aaa
           Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Sensors:   System Temperatures: cpu: 38.0 C mobo: N/A
Info:      Processes: 249 Uptime: 5h 31m Init: systemd v: 246 Compilers: gcc: 10.2.0 alt: 9 Packages: 1589 pacman: 1584
           lib: 470 flatpak: 5 Shell: Zsh v: 5.8 running in: konsole inxi: 3.1.05
also:
1 sink(s) available.
  * index: 0
        driver: <module-alsa-card.c>
        flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
        state: SUSPENDED
        suspend cause: IDLE
        priority: 9039
        volume: front-left: 36043 /  55% / -15,58 dB,   front-right: 36043 /  55% / -15,58 dB
                balance 0,00
        base volume: 65536 / 100% / 0,00 dB
        volume steps: 65537
        muted: no
        current latency: 0,00 ms
        max request: 0 KiB
        max rewind: 0 KiB
        monitor source: 0
        sample spec: s16le 2ch 48000Hz
        channel map: front-left,front-right
                     Stereo
        used by: 0
        linked by: 0
        configured latency: 0,00 ms; range is 0,50 .. 2000,00 ms
        card: 0 <alsa_card.pci-0000_00_1f.3>
        module: 6
        properties:
                alsa.resolution_bits = "16"
                device.api = "alsa"
                device.class = "sound"
                alsa.class = "generic"
                alsa.subclass = "generic-mix"
                alsa.name = "CX8070 Analog"
                alsa.id = "CX8070 Analog"
                alsa.subdevice = "0"
                alsa.subdevice_name = "subdevice #0"
                alsa.device = "0"
                alsa.card = "0"
                alsa.long_card_name = "HDA Intel PCH at 0x9431c000 irq 148"
                sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
                device.bus = "pci"
                device.vendor.id = "8086"
                device.product.id = "9dc8"
                device.product.name = "Cannon Point-LP High Definition Audio Controller"
                device.string = "front:0"
                device.buffering.buffer_size = "384000"
                device.buffering.fragment_size = "192000"
                device.access_mode = "mmap+timer"
                device.profile.name = "analog-stereo"
                device.profile.description = "Analog Stereo"
                device.description = "Built-in Audio Analog Stereo"
                alsa.mixer_name = "Conexant CX8070"
                alsa.components = "HDA:14f11f86,17aa3811,00100100 HDA:8086280b,80860101,00100000"
                module-udev-detect.discovered = "1"
                device.icon_name = "audio-card-pci"
        ports:
                analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: unknown)
                        properties:
        active port: <analog-output-speaker>
Also, after plugging in the headphones:
Memory:    RAM: total: 7.62 GiB used: 1.28 GiB (16.8%)
           Speed: 800 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
           8: 800
           xtopology xtpr
           chip ID: 10de:1d13
           serial: <filter>
           chip ID: 8086:9df0
Drives:    Local Storage: total: 238.47 GiB used: 40.86 GiB (17.1%)
Sensors:   System Temperatures: cpu: 39.0 C mobo: N/A
Info:      Processes: 247 Uptime: 5h 35m Init: systemd v: 246 Compilers: gcc: 10.2.0 alt: 9 Packages: 1589 pacman: 1584
again:
  * index: 0
        state: SUSPENDED
        suspend cause: IDLE
        priority: 9039
                balance 0,00
        volume steps: 65537
        muted: no
        max request: 0 KiB
        max rewind: 0 KiB
        monitor source: 0
                     Stereo
        used by: 0
        linked by: 0
        module: 6
        properties:
                device.api = "alsa"
                alsa.device = "0"
                alsa.card = "0"
                device.bus = "pci"
        ports:
                        properties:
After the new stable update pushed out, everything seems to be working fine. Either way, weird. Update your rolling release distro lmao :stuck_out_tongue:
Thanks for your help, everyone!
It’s easy to overlook that, but yes, things do break sometimes only to be fixed with a subsequent update. Really pleased it’s working for you now. :smiley:
The update did not fix things for me.
System:    Kernel: 5.7.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64 root=UUID=b841b317-5f27-4086-9390-595dff39a5c8
           rw quiet apparmor=1 security=apparmor udev.log_priority=3
           Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Desktop Mobo: Micro-Star model: Z390-A PRO (MS-7B98) v: 1.0 serial: <filter>
           UEFI: American Megatrends v: 1.80 date: 12/25/2019
Memory:    RAM: total: 15.58 GiB used: 2.98 GiB (19.1%)
CPU:       Topology: 6-Core model: Intel Core i5-9600K bits: 64 type: MCP arch: Kaby Lake family: 6
           model-id: 9E (158) stepping: C (12) microcode: D6 L2 cache: 9216 KiB bogomips: 44412
           Speed: 800 MHz min/max: 800/4700 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800
           6: 800
           avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de
           ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
           hle ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single
           lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
           pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp
           rep_good rtm sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
           xsaveopt xsaves xtopology xtpr
           Type: spectre_v2
           mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
           Type: tsx_async_abort mitigation: Clear CPU buffers; SMT disabled
Graphics:  Device-1: NVIDIA TU106 [GeForce RTX 2070] driver: nvidia v: 450.66
           alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1f02
           Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: nvidia display ID: :0
           screens: 1
           Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x343mm (23.7x13.5") s-diag: 693mm (27.3")
           Monitor-1: DP-0 res: 1920x1080 hz: 60 dpi: 82 size: 598x336mm (23.5x13.2") diag: 686mm (27")
           OpenGL: renderer: GeForce RTX 2070/PCIe/SSE2 v: 4.6.0 NVIDIA 450.66 direct render: Yes
Audio:     Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
           alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:a348
           Device-2: NVIDIA TU106 High Definition Audio driver: snd_hda_intel v: kernel bus ID: 01:00.1
           chip ID: 10de:10f9
           Device-3: Logitech type: USB driver: snd-usb-audio,uvcvideo bus ID: 1-1.3:4 chip ID: 046d:085b
           serial: <filter>
           Sound Server: ALSA v: k5.7.19-2-MANJARO
Network:   Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e v: 3.2.6-k port: efa0
           bus ID: 00:1f.6 chip ID: 8086:15bc
           IF-ID-1: ovpntun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
           IP v6: <filter> virtual: stable-privacy scope: link
Drives:    Local Storage: total: 912.89 GiB used: 81.73 GiB (9.0%)
           ID-1: /dev/sda vendor: Samsung model: SSD 840 EVO 500GB size: 465.76 GiB block size:
           physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: DB6Q scheme: GPT
           ID-2: /dev/sdb vendor: Kingston model: SA400S37480G size: 447.13 GiB block size:
           physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 0102 scheme: GPT
Partition: ID-1: / raw size: 154.16 GiB size: 150.74 GiB (97.78%) used: 81.69 GiB (54.2%) fs: ext4
           dev: /dev/sdb1 label: N/A uuid: b841b317-5f27-4086-9390-595dff39a5c8
           ID-2: /boot/efi raw size: 100.0 MiB size: 96.0 MiB (96.00%) used: 35.0 MiB (36.5%) fs: vfat
           dev: /dev/sda2 label: N/A uuid: 3E6D-7A34
Swap:      Alert: No Swap data was found.
Unmounted: ID-1: /dev/sda1 size: 499.0 MiB fs: ntfs label: Recupera\xc3\xa7\xc3\xa3o
           uuid: 6C326B69326B36EC
           ID-2: /dev/sda3 size: 16.0 MiB fs: <superuser/root required> label: N/A uuid: N/A
           ID-3: /dev/sda4 size: 379.86 GiB fs: ntfs label: N/A uuid: DE0A70890A706107
           ID-4: /dev/sda5 size: 477.0 MiB fs: ext4 label: N/A uuid: 8058d62b-c13b-4508-b305-df7f16dcc3c1
           ID-5: /dev/sda6 size: 84.83 GiB fs: ext4 label: N/A uuid: 81074b3c-60da-40ea-b821-aaea2cdaaaac
           ID-6: /dev/sdb2 size: 292.97 GiB fs: ntfs label: Novo volume uuid: AC2AA6782AA63EE8
USB:       Hub: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0 speed: 480 Mb/s
           chip ID: 1d6b:0002
           Hub: 1-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s chip ID: 05e3:0610
           Device-1: 1-1.3:4 info: Logitech type: Video,Audio driver: snd-usb-audio,uvcvideo
           interfaces: 4 rev: 2.0 speed: 480 Mb/s chip ID: 046d:085b serial: <filter>
           Device-2: 1-1.4:6 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: Bluetooth
           driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 0a12:0001
           Device-3: 1-9:3 info: Kingston HX-KB4BL1-US [HYPERX Alloy FPS Pro] type: Keyboard,Mouse,HID
           driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s chip ID: 0951:16d2
           Device-4: 1-10:5 info: Kingsis ZOWIE Gaming mouse type: Mouse driver: hid-generic,usbhid
           interfaces: 1 rev: 2.0 speed: 12 Mb/s chip ID: 3057:0001
           Hub: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
           Hub: 2-1:2 info: Genesys Logic hub ports: 4 rev: 3.0 speed: 5 Gb/s chip ID: 05e3:0616
           Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
           Hub: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Sensors:   System Temperatures: cpu: 35.0 C mobo: N/A gpu: nvidia temp: 32 C
           Fan Speeds (RPM): N/A gpu: nvidia fan: 45%
Info:      Processes: 225 Uptime: 44m Init: systemd v: 246 Compilers: gcc: 10.2.0 alt: 8/9 Packages: 1460
           pacman: 1458 lib: 406 flatpak: 0 snap: 2 Shell: Bash v: 5.0.18 running in: konsole
           inxi: 3.1.05
and
pacmd list-sinks
2 sink(s) available.
  • index: 0
    flags: HARDWARE DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
    state: SUSPENDED
    suspend cause: IDLE
    priority: 9030
    volume: front-left: 23806 / 36% / -26,39 dB, front-right: 23806 / 36% / -26,39 dB
    balance 0,00
    volume steps: 65537
    muted: no
    max request: 0 KiB
    max rewind: 0 KiB
    monitor source: 0
    sample spec: s16le 2ch 44100Hz
    Estéreo
    used by: 0
    linked by: 0
    configured latency: 0,00 ms; range is 0,50 … 1999,82 ms
    card: 0 <alsa_card.pci-0000_01_00.1>
    module: 6
    properties:
    alsa.resolution_bits = “16”
    device.api = “alsa”
    device.class = “sound”
    alsa.class = “generic”
    alsa.subclass = “generic-mix”
    alsa.name = “HDMI 1”
    alsa.id = “HDMI 1”
    alsa.subdevice = “0”
    alsa.subdevice_name = “subdevice #0
    alsa.device = “7”
    alsa.card = “1”
    alsa.card_name = “HDA NVidia”
    alsa.long_card_name = “HDA NVidia at 0xa4080000 irq 17”
    alsa.driver_name = “snd_hda_intel”
    device.bus_path = “pci-0000:01:00.1”
    sysfs.path = “/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1”
    device.bus = “pci”
    device.vendor.id = “10de”
    device.vendor.name = “NVIDIA Corporation”
    device.product.id = “10f9”
    device.product.name = “TU106 High Definition Audio Controller”
    device.string = “hdmi:1,1”
    device.buffering.buffer_size = “352768”
    device.buffering.fragment_size = “176384”
    device.access_mode = “mmap+timer”
    device.profile.name = “hdmi-stereo-extra1”
    device.profile.description = “Digital Stereo (HDMI 2)”
    device.description = “TU106 High Definition Audio Controller Digital Stereo (HDMI 2)”
    alsa.mixer_name = “Nvidia GPU 93 HDMI/DP”
    alsa.components = “HDA:10de0093,10de12fe,00100100”
    module-udev-detect.discovered = “1”
    device.icon_name = “audio-card-pci”
    ports:
    hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: yes)
    properties:
    device.icon_name = “video-display”
    device.product.name = "GMX27C144
    active port:
    index: 2
    state: SUSPENDED
    suspend cause: IDLE
    priority: 9039
    volume: front-left: 67734 / 103% / 0,86 dB, front-right: 67734 / 103% / 0,86 dB
    balance 0,00
    volume steps: 65537
    muted: no
    max request: 0 KiB
    max rewind: 0 KiB
    monitor source: 5
    Estéreo
    used by: 0
    linked by: 0
    configured latency: 0,00 ms; range is 0,50 … 2000,00 ms
    card: 2 <alsa_card.pci-0000_00_1f.3>
    module: 8
    properties:
    device.api = “alsa”
    alsa.name = “ALC892 Analog”
    alsa.id = “ALC892 Analog”
    alsa.device = “0”
    alsa.card = “0”
    alsa.card_name = “HDA Intel PCH”
    alsa.long_card_name = “HDA Intel PCH at 0xa4230000 irq 126”
    device.bus_path = “pci-0000:00:1f.3”
    sysfs.path = “/devices/pci0000:00/0000:00:1f.3/sound/card0”
    device.bus = “pci”
    device.vendor.id = “8086”
    device.vendor.name = “Intel Corporation”
    device.product.id = “a348”
    device.product.name = “Cannon Lake PCH cAVS”
    device.form_factor = “internal”
    device.string = “front:0”
    device.buffering.buffer_size = “352800”
    device.buffering.fragment_size = “176400”
    device.profile.name = “analog-stereo”
    device.profile.description = “Estéreo analógico”
    device.description = “Áudio interno Estéreo analógico”
    alsa.mixer_name = “Realtek ALC892”
    alsa.components = “HDA:10ec0892,14629b98,00100302”
    ports:
    analog-output-lineout: Saída de linha (priority 9000, latency offset 0 usec, available: yes)
    properties:
            analog-output-headphones: Fones de ouvido (priority 9900, latency offset 0 usec, available: no)
                    properties:
    active port: <analog-output-lineout>
Hi, your question definitely deserves its own topic, as your issue might be different and your machine certainly is. :wink: Cheers!
