KDE does not use my old nvidia GPU
Greetings everyone,
I’ve been trying to make the whole xsession to use my discrete nvidia gpu, but still no results.
Trying prime-run on my xsession does not make a difference.
I’m Using an Asus notebook ROG G53SW. Here are my specs:
OS: Manjaro Linux x86_64
Host: G53SW 1.0
Kernel: 5.10.49-1-MANJARO
Shell: zsh 5.8
Resolution: 1366x768
DE: Plasma 5.22.3
WM: KWin
CPU: Intel i7-2630QM (8) @ 2.900GHz
GPU: NVIDIA GeForce GTX 460M
Memory: 3315MiB / 7930MiB
mhwd -li         ✔
> Installed PCI configs:
    video-nvidia-390xx            2020.11.30               false            PCI
mhwd         ✔
> 0000:01:00.0 (0300:10de:0dd1) Display controller nVidia Corporation:
           video-linux            2018.05.04                true            PCI
> 0000:05:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
         network-r8168            2016.04.20                true            PCI
nvidia-smi         ✔
Tue Jul 20 20:05:40 2021
| NVIDIA-SMI 390.143                Driver Version: 390.143                   |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|   0  GeForce GTX 460M    Off  | 00000000:01:00.0 N/A |                  N/A |
| N/A   69C    P8    N/A /  N/A |    351MiB /  1473MiB |     N/A      Default |
| Processes:                                                       GPU Memory |
|  GPU       PID   Type   Process name                             Usage      |
|    0                    Not Supported                                       |
:+1: Welcome to Manjaro! :+1:
  1. Please read this:
    How to provide good information
    and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies… :grin:
  2. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
  3. Seeing you have an old card, have you tried the 5.4 LTS kernel already?
:+1:
Thanks for replying and directing me to the proper reading <3.
Regarding the information needed:
  Kernel: 5.10.49-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=7dfdefa5-3dbd-4151-9ec9-4ee0b647631c rw quiet apparmor=1
  security=apparmor resume=UUID=2f61b82d-529b-49db-a799-13bece1ac63b
  udev.log_priority=3
  Desktop: KDE Plasma 5.22.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: ASUSTeK product: G53SW v: 1.0 serial: <filter>
  Mobo: ASUSTeK model: G53SW v: 1.0 serial: <filter> BIOS: American Megatrends
  v: G53SW.203 date: 02/15/2011
  ID-1: BAT0 charge: 19.0 Wh (100.0%) condition: 19.0/72.8 Wh (26.0%)
  volts: 16.5 min: 14.4 model: ASUSTek G73--52 type: Li-ion serial: N/A
  status: Full
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
  charge: 55% (should be ignored) rechargeable: yes status: Discharging
  RAM: total: 7.74 GiB used: 3.29 GiB (42.5%)
  Info: Quad Core model: Intel Core i7-2630QM bits: 64 type: MT MCP
  arch: Sandy Bridge family: 6 model-id: 2A (42) stepping: 7 microcode: 2F
  cache: L2: 6 MiB bogomips: 31938
  Speed: 1152 MHz min/max: 800/2900 MHz Core speeds (MHz): 1: 1152 2: 884
  3: 880 4: 1252 5: 1365 6: 1218 7: 1153 8: 1262
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
  constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
  flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce md_clear
  mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
  pebs pge pln pni popcnt pse pse36 pti pts rdtscp rep_good sep ssbd sse sse2
  sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer
  vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
  Type: l1tf
  Device-1: NVIDIA GF106M [GeForce GTX 460M] vendor: ASUSTeK driver: nvidia
  v: 390.143 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:0dd1
  class-ID: 0300
  Display: x11 server: X.org 1.20.11 compositor: kwin_x11 driver:
  loaded: nvidia resolution: <missing: xdpyinfo>
  OpenGL: renderer: GeForce GTX 460M/PCIe/SSE2 v: 4.6.0 NVIDIA 390.143
  direct render: Yes
  vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
  chip-ID: 8086:1c20 class-ID: 0403
  Device-2: NVIDIA GF106 High Definition Audio vendor: ASUSTeK
  driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:0be9
  class-ID: 0403
  Sound Server-1: ALSA v: k5.10.49-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.31 running: yes
  Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter
  vendor: AzureWave AW-NB037H 802.11bgn driver: ath9k v: kernel port: d000
  bus-ID: 03:00.0 chip-ID: 168c:002b class-ID: 0280
  IF: wlp3s0 state: down mac: <filter>
  vendor: ASUSTeK U6V/U31J laptop driver: r8169 v: kernel port: 9000
  bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-1: Qualcomm Atheros AR3011 Bluetooth type: USB driver: btusb v: 0.8
  bus-ID: 1-1.1:9 chip-ID: 0cf3:3005 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
  Permissions: Unable to run lvs. Root privileges required.
  Local Storage: total: 2.03 TiB used: 553.48 GiB (26.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWL110 size: 931.51 GiB
  block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  rotation: 5400 rpm serial: <filter> rev: 0A scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT480BX500SSD1
  size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  rotation: SSD serial: <filter> rev: 041 scheme: MBR
  ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
  model: WD7500BPVT-60HXZT1 size: 698.64 GiB block-size: physical: 4096 B
  logical: 512 B speed: 3.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 1A01
  scheme: MBR
  ID-1: / raw-size: 423.08 GiB size: 415.37 GiB (98.18%)
  used: 137.43 GiB (33.1%) fs: ext4 dev: /dev/sdb3 maj-min: 8:19 label: N/A
  uuid: 7dfdefa5-3dbd-4151-9ec9-4ee0b647631c
  ID-2: /home raw-size: 785.03 GiB size: 771.63 GiB (98.29%)
  used: 416.05 GiB (53.9%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
  uuid: bb8c0c57-d7cd-4108-a02d-2599838d82fb
  ID-1: swap-1 type: partition size: 24 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/sdb2 maj-min: 8:18 label: N/A
  uuid: 2f61b82d-529b-49db-a799-13bece1ac63b
  ID-1: /dev/sda1 maj-min: 8:1 size: 146 GiB fs: <superuser required>
  label: N/A uuid: 2056599556596D12
  ID-2: /dev/sda2 maj-min: 8:2 size: 499 MiB fs: <superuser required>
  label: N/A uuid: FAD897EDD897A703
  ID-3: /dev/sdb1 maj-min: 8:17 size: 50 MiB fs: <superuser required>
  label: System Reserved uuid: 884257B44257A5AA
  ID-4: /dev/sdc1 maj-min: 8:33 size: 698.63 GiB fs: <superuser required>
  label: N/A uuid: 637c816b-e79d-464a-aa03-10a0b47efcb8
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
  Device-1: 1-1.1:9 info: Qualcomm Atheros AR3011 Bluetooth type: Bluetooth
  driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA
  Device-2: 1-1.4:8 info: Realtek RTS5139 Card Reader Controller
  interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0139
  class-ID: ff00 serial: <filter>
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
  Device-1: 2-1.2:3 info: Logitech Unifying Receiver type: Keyboard,Mouse
  driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
  power: 98mA chip-ID: 046d:c534 class-ID: 0301
  Device-2: 2-1.5:4 info: NVIDIA NVIDIA stereo controller
  type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s
  power: 400mA chip-ID: 0955:7002 class-ID: 0000
  Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
  Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 63.0 C mobo: N/A gpu: nvidia temp: 84 C
  Fan Speeds (RPM): cpu: 4200
  Processes: 244 Uptime: 10h 39m wakeups: 17 Init: systemd v: 248
  tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1409
  lib: 364 Shell: Zsh v: 5.8 running-in: yakuake inxi: 3.3.05
and here is my xrandr output
Screen 0: minimum 8 x 8, current 1366 x 768, maximum 16384 x 16384
VGA-0 disconnected (normal left inverted right x axis y axis)
LVDS-0 connected primary 1366x768+0+0 (normal left inverted right x axis y axis) 344mm x 193mm
   1366x768     119.97*+ 109.95   100.02
HDMI-0 disconnected (normal left inverted right x axis y axis)
Here’s my dmseg output
[    0.165568] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[    0.165568]   #5  #6  #7
[    0.173837] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.176177] mtrr: your CPUs had inconsistent variable MTRR settings
[    1.726276] usb 1-1.2: device descriptor read/64, error -32
[    1.906235] usb 1-1.2: device descriptor read/64, error -32
[    2.162912] usb 1-1.2: device descriptor read/64, error -32
[    2.342948] usb 1-1.2: device descriptor read/64, error -32
[    3.020695] vboxdrv: loading out-of-tree module taints kernel.
[    3.047715] VBoxNetAdp: Successfully started.
[    3.050669] VBoxNetFlt: Successfully started.
[    3.282889] nvidia: module license 'NVIDIA' taints kernel.
[    3.282892] Disabling lock debugging due to kernel taint
[    3.323066] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  390.143  Fri Mar 12 07:24:47 UTC 2021 (using threaded interrupts)
[    3.432627] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000044F (\GPIS) (20200925/utaddress-204)
[    3.432636] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20200925/utaddress-204)
[    3.432647] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\GPIO) (20200925/utaddress-204)
[    3.432651] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GP01) (20200925/utaddress-204)
[    3.432661] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\GPIO) (20200925/utaddress-204)
[    3.432667] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GP01) (20200925/utaddress-204)
[    3.432673] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000057F (\GPIO) (20200925/utaddress-204)
[    3.432678] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GP01) (20200925/utaddress-204)
[    3.432684] lpc_ich: Resource conflict(s) found affecting gpio_ich
[    3.459518] usb 1-1.2: device not accepting address 6, error -32
[    3.738489] r8169 0000:05:00.0: can't disable ASPM; OS doesn't have ASPM control
[    3.741548] at24 0-0050: supply vcc not found, using dummy regulator
[    3.742423] at24 0-0051: supply vcc not found, using dummy regulator
[    3.743054] at24 0-0052: supply vcc not found, using dummy regulator
[    3.743673] at24 0-0053: supply vcc not found, using dummy regulator
[    3.946188] usb 1-1.2: device not accepting address 7, error -32
[    3.946366] usb 1-1-port2: unable to enumerate USB device
[    4.832967] resource sanity check: requesting [mem 0x000e0000-0x000fffff], which spans more than PCI Bus 0000:00 [mem 0x000e0000-0x000e3fff window]
[    4.833235] caller _nv027867rm+0x58/0x90 [nvidia] mapping multiple BARs
[    4.843031] ACPI Warning: \_SB.PCI0.PEG0.GFX0._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20200925/nsarguments-61)
[    4.959970] resource sanity check: requesting [mem 0x000c0000-0x000fffff], which spans more than PCI Bus 0000:00 [mem 0x000d0000-0x000d3fff window]
[    4.960154] caller _nv001015rm+0x1bf/0x1f0 [nvidia] mapping multiple BARs
[    5.516396] kauditd_printk_skb: 49 callbacks suppressed
[   12.306734] kauditd_printk_skb: 9 callbacks suppressed
[   21.591888] kauditd_printk_skb: 7 callbacks suppressed
[   35.929860] kauditd_printk_skb: 8 callbacks suppressed
[  905.554754] kauditd_printk_skb: 12 callbacks suppressed
here’s my xorg.0.log
[     4.661] (--) Log file renamed from "/var/log/Xorg.pid-618.log" to "/var/log/Xorg.0.log"
[     4.665]
X.Org X Server 1.20.11
[     4.665] Build Operating System: Linux Manjaro Linux
[     4.665] Current Operating System: Linux gentoo 5.10.49-1-MANJARO #1 SMP PREEMPT Sun Jul 11 12:59:43 UTC 2021 x86_64
[     4.665] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=7dfdefa5-3dbd-4151-9ec9-4ee0b647631c rw quiet apparmor=1 security=apparmor resume=UUID=2f61b82d-529b-49db-a799-13bece1ac63b udev.log_priority=3
[     4.665] Build Date: 13 April 2021  04:11:08PM
[     4.665]
[     4.665] Current version of pixman: 0.40.0
[     4.665]    Before reporting problems, check http://wiki.x.org
[     4.665] Markers: (--) probed, (**) from config file, (==) default setting,
[     4.666] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Jul 24 13:26:49 2021
[     4.672] (==) Using config file: "/etc/X11/xorg.conf"
[     4.672] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     4.672] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     4.674] (==) ServerLayout "Layout0"
[     4.674] (**) |-->Screen "Screen0" (0)
[     4.674] (**) |   |-->Monitor "Monitor0"
[     4.675] (**) |   |-->Device "Device0"
[     4.675] (**) |   |-->GPUDevice "Device0"
[     4.675] (**) |-->Input Device "Keyboard0"
[     4.675] (**) |-->Input Device "Mouse0"
[     4.675] (==) Automatically adding devices
[     4.675] (==) Automatically enabling devices
[     4.675] (==) Automatically adding GPU devices
[     4.675] (==) Automatically binding GPU devices
[     4.675] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     4.676] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[     4.676]    Entry deleted from font path.
[     4.676] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     4.676] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[     4.676] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[     4.676] (==) FontPath set to:
        /usr/share/fonts/misc,
        /usr/share/fonts/TTF
[     4.676] (==) ModulePath set to "/usr/lib/xorg/modules"
[     4.676] (**) Extension "COMPOSITE" is enabled
[     4.676] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[     4.676] (WW) Disabling Keyboard0
[     4.676] (WW) Disabling Mouse0
[     4.676] (II) Module ABI versions:
[     4.676]    X.Org ANSI C Emulation: 0.4
[     4.676]    X.Org Video Driver: 24.1
[     4.676]    X.Org XInput driver : 24.1
[     4.676]    X.Org Server Extension : 10.0
[     4.677] (++) using VT number 1
[     4.677] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     4.677] (II) xfree86: Adding drm device (/dev/dri/card0)
[     4.679] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[     4.679] (**) OutputClass "nvidia" setting /dev/dri/card0 as PrimaryGPU
[     4.681] (--) PCI:*(1@0:0:0) 10de:0dd1:1043:2046 rev 161, Mem @ 0xda000000/33554432, 0xc8000000/134217728, 0xd0000000/67108864, I/O @ 0x0000d000/128, BIOS @ 0x????????/131072
[     4.681] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     4.681] (II) LoadModule: "glx"
[     4.683] (II) Loading /usr/lib/nvidia/xorg/libglx.so
[     4.766] (II) Module glx: vendor="NVIDIA Corporation"
[     4.766]    compiled for 4.0.2, module version = 1.0.0
[     4.766]    Module class: X.Org Server Extension
[     4.768] (II) NVIDIA GLX Module  390.143  Fri Mar 12 07:23:57 UTC 2021
[     4.769] (II) LoadModule: "nvidia"
[     4.770] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[     4.781] (II) Module nvidia: vendor="NVIDIA Corporation"
[     4.781]    compiled for 4.0.2, module version = 1.0.0
[     4.781]    Module class: X.Org Video Driver
[     4.784] (II) NVIDIA dlloader X Driver  390.143  Fri Mar 12 07:27:02 UTC 2021
[     4.784] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[     4.787] (II) Loading sub module "fb"
[     4.787] (II) LoadModule: "fb"
[     4.787] (II) Loading /usr/lib/xorg/modules/libfb.so
[     4.790] (II) Module fb: vendor="X.Org Foundation"
[     4.790]    compiled for 1.20.11, module version = 1.0.0
[     4.790]    ABI class: X.Org ANSI C Emulation, version 0.4
[     4.790] (II) Loading sub module "wfb"
[     4.790] (II) LoadModule: "wfb"
[     4.792] (II) Loading /usr/lib/xorg/modules/libwfb.so
[     4.795] (II) Module wfb: vendor="X.Org Foundation"
[     4.795]    compiled for 1.20.11, module version = 1.0.0
[     4.795]    ABI class: X.Org ANSI C Emulation, version 0.4
[     4.795] (II) Loading sub module "ramdac"
[     4.795] (II) LoadModule: "ramdac"
[     4.795] (II) Module "ramdac" already built-in
[     4.801] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[     4.801] (==) NVIDIA(0): RGB weight 888
[     4.801] (==) NVIDIA(0): Default visual is TrueColor
[     4.801] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[     4.801] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[     4.801] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[     4.801] (**) NVIDIA(0): Enabling 2D acceleration
[     5.495] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[     5.495] (--) NVIDIA(0):     CRT-0
[     5.495] (--) NVIDIA(0):     DFP-0 (boot)
[     5.495] (--) NVIDIA(0):     DFP-1
[     5.497] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 460M (GF106) at PCI:1:0:0 (GPU-0)
[     5.498] (--) NVIDIA(0): Memory: 1572864 kBytes
[     5.498] (--) NVIDIA(0): VideoBIOS: 70.06.26.00.0a
[     5.498] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[     5.499] (--) NVIDIA(GPU-0): CRT-0: disconnected
[     5.499] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[     5.499] (--) NVIDIA(GPU-0): cPATH (DFP-0): connected
[     5.499] (--) NVIDIA(GPU-0): cPATH (DFP-0): Internal LVDS
[     5.499] (--) NVIDIA(GPU-0): cPATH (DFP-0): 330.0 MHz maximum pixel clock
[     5.499] (--) NVIDIA(GPU-0): DFP-1: disconnected
[     5.499] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[     5.499] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[     5.501] (==) NVIDIA(0):
[     5.501] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[     5.501] (==) NVIDIA(0):     will be used as the requested mode.
[     5.501] (II) NVIDIA(0): Validated MetaModes:
[     5.501] (II) NVIDIA(0):     "DFP-0:nvidia-auto-select"
[     5.501] (II) NVIDIA(0): Virtual screen size determined to be 1366 x 768
[     5.503] (--) NVIDIA(0): DPI set to (102, 102); computed from "UseEdidDpi" X config
[     5.503] (--) NVIDIA(0):     option
[     5.504] (II) NVIDIA: Using 6144.00 MB of virtual memory for indirect memory
[     5.504] (II) NVIDIA:     access.
[     5.507] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[     5.507] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[     5.507] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[     5.507] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[     5.507] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[     5.507] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[     5.507] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[     5.507] (II) NVIDIA(0):     Config Options in the README.
[     5.535] (II) NVIDIA(0): Setting mode "DFP-0:nvidia-auto-select"
[     6.859] (==) NVIDIA(0): Disabling shared memory pixmaps
[     6.859] (==) NVIDIA(0): Backing store enabled
[     6.859] (==) NVIDIA(0): Silken mouse disabled
[     6.859] (**) NVIDIA(0): DPMS enabled
[     6.860] (WW) NVIDIA(0): Option "PrimaryGPU" is not used
[     6.860] (WW) NVIDIA(0): Option "NoLogo" is not used
[     6.860] (II) Loading sub module "dri2"
[     6.860] (II) LoadModule: "dri2"
[     6.860] (II) Module "dri2" already built-in
[     6.860] (II) NVIDIA(0): [DRI2] Setup complete
[     6.860] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[     6.862] (II) Initializing extension Generic Event Extension
[     6.862] (II) Initializing extension SHAPE
[     6.862] (II) Initializing extension MIT-SHM
[     6.862] (II) Initializing extension XInputExtension
[     6.862] (II) Initializing extension XTEST
[     6.862] (II) Initializing extension BIG-REQUESTS
[     6.862] (II) Initializing extension SYNC
[     6.863] (II) Initializing extension XKEYBOARD
[     6.863] (II) Initializing extension XC-MISC
[     6.863] (II) Initializing extension SECURITY
[     6.863] (II) Initializing extension XFIXES
[     6.863] (II) Initializing extension RENDER
[     6.863] (II) Initializing extension RANDR
[     6.863] (II) Initializing extension COMPOSITE
[     6.863] (II) Initializing extension DAMAGE
[     6.863] (II) Initializing extension MIT-SCREEN-SAVER
[     6.864] (II) Initializing extension DOUBLE-BUFFER
[     6.864] (II) Initializing extension RECORD
[     6.864] (II) Initializing extension DPMS
[     6.864] (II) Initializing extension Present
[     6.864] (II) Initializing extension DRI3
[     6.864] (II) Initializing extension X-Resource
[     6.864] (II) Initializing extension XVideo
[     6.864] (II) Initializing extension XVideo-MotionCompensation
[     6.864] (II) Initializing extension XFree86-VidModeExtension
[     6.864] (II) Initializing extension XFree86-DGA
[     6.864] (II) Initializing extension XFree86-DRI
[     6.864] (II) Initializing extension DRI2
[     6.865] (II) Initializing extension GLX
[     6.865] (II) Indirect GLX disabled.
[     6.865] (II) Initializing extension NV-GLX
[     6.865] (II) Initializing extension NV-CONTROL
[     6.865] (II) Initializing extension XINERAMA
[     6.956] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[     6.956] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     6.956] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     6.956] (**) Power Button: Applying InputClass "system-keyboard"
[     6.956] (**) Power Button: Applying InputClass "Keyboard Defaults"
[     6.956] (II) LoadModule: "libinput"
[     6.957] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[     6.964] (II) Module libinput: vendor="X.Org Foundation"
[     6.964]    compiled for 1.20.11, module version = 1.1.0
[     6.964]    Module class: X.Org XInput Driver
[     6.964]    ABI class: X.Org XInput driver, version 24.1
[     6.964] (II) Using input driver 'libinput' for 'Power Button'
[     6.964] (**) Power Button: always reports core events
[     6.964] (**) Option "Device" "/dev/input/event2"
[     6.964] (**) Option "_source" "server/udev"
[     6.974] (II) event2  - Power Button: is tagged by udev as: Keyboard
[     6.974] (II) event2  - Power Button: device is a keyboard
[     6.974] (II) event2  - Power Button: device removed
[     7.009] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[     7.009] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[     7.009] (**) Option "xkb_model" "pc105"
[     7.009] (**) Option "xkb_layout" "us"
[     7.009] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     7.043] (II) event2  - Power Button: is tagged by udev as: Keyboard
[     7.043] (II) event2  - Power Button: device is a keyboard
[     7.045] (II) config/udev: Adding input device Video Bus (/dev/input/event6)
[     7.045] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[     7.045] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[     7.045] (**) Video Bus: Applying InputClass "system-keyboard"
[     7.045] (**) Video Bus: Applying InputClass "Keyboard Defaults"
[     7.045] (II) Using input driver 'libinput' for 'Video Bus'
[     7.045] (**) Video Bus: always reports core events
[     7.045] (**) Option "Device" "/dev/input/event6"
[     7.045] (**) Option "_source" "server/udev"
[     7.047] (II) event6  - Video Bus: is tagged by udev as: Keyboard
[     7.047] (II) event6  - Video Bus: device is a keyboard
[     7.047] (II) event6  - Video Bus: device removed
[     7.116] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input27/event6"
[     7.116] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[     7.116] (**) Option "xkb_model" "pc105"
[     7.116] (**) Option "xkb_layout" "us"
[     7.116] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     7.120] (II) event6  - Video Bus: is tagged by udev as: Keyboard
[     7.120] (II) event6  - Video Bus: device is a keyboard
[     7.122] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[     7.122] (II) No input driver specified, ignoring this device.
[     7.122] (II) This device may have been added with another device file.
[     7.123] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[     7.123] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[     7.123] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[     7.123] (**) Sleep Button: Applying InputClass "system-keyboard"
[     7.123] (**) Sleep Button: Applying InputClass "Keyboard Defaults"
[     7.123] (II) Using input driver 'libinput' for 'Sleep Button'
[     7.123] (**) Sleep Button: always reports core events
[     7.123] (**) Option "Device" "/dev/input/event1"
[     7.123] (**) Option "_source" "server/udev"
[     7.125] (II) event1  - Sleep Button: is tagged by udev as: Keyboard
[     7.125] (II) event1  - Sleep Button: device is a keyboard
[     7.126] (II) event1  - Sleep Button: device removed
[     7.156] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
[     7.156] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 8)
[     7.156] (**) Option "xkb_model" "pc105"
[     7.156] (**) Option "xkb_layout" "us"
[     7.156] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     7.159] (II) event1  - Sleep Button: is tagged by udev as: Keyboard
[     7.159] (II) event1  - Sleep Button: device is a keyboard
[     7.161] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event9)
[     7.161] (II) No input driver specified, ignoring this device.
[     7.161] (II) This device may have been added with another device file.
[     7.163] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event10)
[     7.163] (II) No input driver specified, ignoring this device.
[     7.163] (II) This device may have been added with another device file.
[     7.164] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event11)
[     7.164] (II) No input driver specified, ignoring this device.
[     7.164] (II) This device may have been added with another device file.
[     7.165] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event12)
[     7.165] (II) No input driver specified, ignoring this device.
[     7.165] (II) This device may have been added with another device file.
[     7.166] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event13)
[     7.166] (II) No input driver specified, ignoring this device.
[     7.166] (II) This device may have been added with another device file.
[     7.167] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event14)
[     7.167] (II) No input driver specified, ignoring this device.
[     7.167] (II) This device may have been added with another device file.
[     7.170] (II) config/udev: Adding input device Logitech Wireless Keyboard PID:4023 (/dev/input/event4)
[     7.170] (**) Logitech Wireless Keyboard PID:4023: Applying InputClass "evdev keyboard catchall"
[     7.170] (**) Logitech Wireless Keyboard PID:4023: Applying InputClass "libinput keyboard catchall"
[     7.170] (**) Logitech Wireless Keyboard PID:4023: Applying InputClass "system-keyboard"
[     7.170] (**) Logitech Wireless Keyboard PID:4023: Applying InputClass "Keyboard Defaults"
[     7.170] (II) Using input driver 'libinput' for 'Logitech Wireless Keyboard PID:4023'
[     7.170] (**) Logitech Wireless Keyboard PID:4023: always reports core events
[     7.170] (**) Option "Device" "/dev/input/event4"
[     7.170] (**) Option "_source" "server/udev"
[     7.175] (II) event4  - Logitech Wireless Keyboard PID:4023: is tagged by udev as: Keyboard
[     7.175] (II) event4  - Logitech Wireless Keyboard PID:4023: device is a keyboard
[     7.176] (II) event4  - Logitech Wireless Keyboard PID:4023: device removed
[     7.209] (II) libinput: Logitech Wireless Keyboard PID:4023: needs a virtual subdevice
[     7.210] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.1/0003:046D:C534.0002/0003:046D:4023.0003/input/input25/event4"
[     7.210] (II) XINPUT: Adding extended input device "Logitech Wireless Keyboard PID:4023" (type: MOUSE, id 9)
[     7.210] (**) Option "AccelerationScheme" "none"
[     7.210] (**) Logitech Wireless Keyboard PID:4023: (accel) selected scheme none/0
[     7.210] (**) Logitech Wireless Keyboard PID:4023: (accel) acceleration factor: 2.000
[     7.210] (**) Logitech Wireless Keyboard PID:4023: (accel) acceleration threshold: 4
[     7.215] (II) event4  - Logitech Wireless Keyboard PID:4023: is tagged by udev as: Keyboard
[     7.216] (II) event4  - Logitech Wireless Keyboard PID:4023: device is a keyboard
[     7.220] (II) config/udev: Adding input device Logitech Wireless Mouse (/dev/input/event5)
[     7.220] (**) Logitech Wireless Mouse: Applying InputClass "evdev pointer catchall"
[     7.220] (**) Logitech Wireless Mouse: Applying InputClass "libinput pointer catchall"
[     7.220] (II) Using input driver 'libinput' for 'Logitech Wireless Mouse'
[     7.220] (**) Logitech Wireless Mouse: always reports core events
[     7.220] (**) Option "Device" "/dev/input/event5"
[     7.220] (**) Option "_source" "server/udev"
[     7.225] (II) event5  - Logitech Wireless Mouse: is tagged by udev as: Mouse
[     7.226] (II) event5  - Logitech Wireless Mouse: device is a pointer
[     7.227] (II) event5  - Logitech Wireless Mouse: device removed
[     7.303] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.1/0003:046D:C534.0002/0003:046D:4054.0004/input/input26/event5"
[     7.303] (II) XINPUT: Adding extended input device "Logitech Wireless Mouse" (type: MOUSE, id 10)
[     7.303] (**) Option "AccelerationScheme" "none"
[     7.303] (**) Logitech Wireless Mouse: (accel) selected scheme none/0
[     7.303] (**) Logitech Wireless Mouse: (accel) acceleration factor: 2.000
[     7.303] (**) Logitech Wireless Mouse: (accel) acceleration threshold: 4
[     7.306] (II) event5  - Logitech Wireless Mouse: is tagged by udev as: Mouse
[     7.306] (II) event5  - Logitech Wireless Mouse: device is a pointer
[     7.308] (II) config/udev: Adding input device Logitech Wireless Mouse (/dev/input/mouse0)
[     7.308] (II) No input driver specified, ignoring this device.
[     7.308] (II) This device may have been added with another device file.
[     7.309] (II) config/udev: Adding input device Asus WMI hotkeys (/dev/input/event8)
[     7.310] (**) Asus WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[     7.310] (**) Asus WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[     7.310] (**) Asus WMI hotkeys: Applying InputClass "system-keyboard"
[     7.310] (**) Asus WMI hotkeys: Applying InputClass "Keyboard Defaults"
[     7.310] (II) Using input driver 'libinput' for 'Asus WMI hotkeys'
[     7.310] (**) Asus WMI hotkeys: always reports core events
[     7.310] (**) Option "Device" "/dev/input/event8"
[     7.310] (**) Option "_source" "server/udev"
[     7.312] (II) event8  - Asus WMI hotkeys: is tagged by udev as: Keyboard
[     7.312] (II) event8  - Asus WMI hotkeys: device is a keyboard
[     7.313] (II) event8  - Asus WMI hotkeys: device removed
[     7.396] (**) Option "config_info" "udev:/sys/devices/platform/asus-nb-wmi/input/input33/event8"
[     7.396] (II) XINPUT: Adding extended input device "Asus WMI hotkeys" (type: KEYBOARD, id 11)
[     7.396] (**) Option "xkb_model" "pc105"
[     7.396] (**) Option "xkb_layout" "us"
[     7.396] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     7.399] (II) event8  - Asus WMI hotkeys: is tagged by udev as: Keyboard
[     7.399] (II) event8  - Asus WMI hotkeys: device is a keyboard
[     7.401] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[     7.401] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[     7.401] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[     7.401] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[     7.401] (**) AT Translated Set 2 keyboard: Applying InputClass "Keyboard Defaults"
[     7.401] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[     7.401] (**) AT Translated Set 2 keyboard: always reports core events
[     7.401] (**) Option "Device" "/dev/input/event3"
[     7.401] (**) Option "_source" "server/udev"
[     7.404] (II) event3  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[     7.404] (II) event3  - AT Translated Set 2 keyboard: device is a keyboard
[     7.406] (II) event3  - AT Translated Set 2 keyboard: device removed
[     7.436] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
[     7.436] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 12)
[     7.436] (**) Option "xkb_model" "pc105"
[     7.436] (**) Option "xkb_layout" "us"
[     7.436] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     7.439] (II) event3  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[     7.440] (II) event3  - AT Translated Set 2 keyboard: device is a keyboard
[     7.443] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[     7.443] (II) No input driver specified, ignoring this device.
[     7.443] (II) This device may have been added with another device file.
[     7.467] (**) Logitech Wireless Keyboard PID:4023: Applying InputClass "evdev keyboard catchall"
[     7.467] (**) Logitech Wireless Keyboard PID:4023: Applying InputClass "libinput keyboard catchall"
[     7.467] (**) Logitech Wireless Keyboard PID:4023: Applying InputClass "system-keyboard"
[     7.467] (**) Logitech Wireless Keyboard PID:4023: Applying InputClass "Keyboard Defaults"
[     7.467] (II) Using input driver 'libinput' for 'Logitech Wireless Keyboard PID:4023'
[     7.467] (**) Logitech Wireless Keyboard PID:4023: always reports core events
[     7.467] (**) Option "Device" "/dev/input/event4"
[     7.467] (**) Option "_source" "_driver/libinput"
[     7.467] (II) libinput: Logitech Wireless Keyboard PID:4023: is a virtual subdevice
[     7.467] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.1/0003:046D:C534.0002/0003:046D:4023.0003/input/input25/event4"
[     7.467] (II) XINPUT: Adding extended input device "Logitech Wireless Keyboard PID:4023" (type: KEYBOARD, id 13)
[     7.467] (**) Option "xkb_model" "pc105"
[     7.468] (**) Option "xkb_layout" "us"
[     7.468] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     7.470] (II) config/udev: Adding input device Logitech Wireless Mouse (/dev/input/mouse0)
[     7.470] (II) No input driver specified, ignoring this device.
[     7.470] (II) This device may have been added with another device file.
[     7.471] (II) config/udev: removing device Logitech Wireless Mouse
[     7.471] (II) event5  - Logitech Wireless Mouse: device removed
[     7.529] (II) UnloadModule: "libinput"
[     7.531] (II) config/udev: Adding input device Logitech Wireless Mouse (/dev/input/event5)
[     7.531] (**) Logitech Wireless Mouse: Applying InputClass "evdev pointer catchall"
[     7.531] (**) Logitech Wireless Mouse: Applying InputClass "libinput pointer catchall"
[     7.531] (II) Using input driver 'libinput' for 'Logitech Wireless Mouse'
[     7.532] (**) Logitech Wireless Mouse: always reports core events
[     7.532] (**) Option "Device" "/dev/input/event5"
[     7.532] (**) Option "_source" "server/udev"
[     7.537] (II) event5  - Logitech Wireless Mouse: is tagged by udev as: Mouse
[     7.538] (II) event5  - Logitech Wireless Mouse: device is a pointer
[     7.539] (II) event5  - Logitech Wireless Mouse: device removed
[     7.596] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.1/0003:046D:C534.0002/0003:046D:4054.0004/input/input26/event5"
[     7.596] (II) XINPUT: Adding extended input device "Logitech Wireless Mouse" (type: MOUSE, id 10)
[     7.596] (**) Option "AccelerationScheme" "none"
[     7.596] (**) Logitech Wireless Mouse: (accel) selected scheme none/0
[     7.596] (**) Logitech Wireless Mouse: (accel) acceleration factor: 2.000
[     7.596] (**) Logitech Wireless Mouse: (accel) acceleration threshold: 4
[     7.602] (II) event5  - Logitech Wireless Mouse: is tagged by udev as: Mouse
[     7.602] (II) event5  - Logitech Wireless Mouse: device is a pointer
[     7.604] (II) config/udev: removing device Logitech Wireless Keyboard PID:4023
[     7.604] (II) UnloadModule: "libinput"
[     7.604] (II) event4  - Logitech Wireless Keyboard PID:4023: device removed
[     7.636] (II) UnloadModule: "libinput"
[     7.638] (II) config/udev: Adding input device Logitech Wireless Keyboard PID:4023 (/dev/input/event4)
[     7.638] (**) Logitech Wireless Keyboard PID:4023: Applying InputClass "evdev keyboard catchall"
[     7.638] (**) Logitech Wireless Keyboard PID:4023: Applying InputClass "libinput keyboard catchall"
[     7.638] (**) Logitech Wireless Keyboard PID:4023: Applying InputClass "system-keyboard"
[     7.638] (**) Logitech Wireless Keyboard PID:4023: Applying InputClass "Keyboard Defaults"
[     7.638] (II) Using input driver 'libinput' for 'Logitech Wireless Keyboard PID:4023'
[     7.638] (**) Logitech Wireless Keyboard PID:4023: always reports core events
[     7.638] (**) Option "Device" "/dev/input/event4"
[     7.638] (**) Option "_source" "server/udev"
[     7.644] (II) event4  - Logitech Wireless Keyboard PID:4023: is tagged by udev as: Keyboard
[     7.644] (II) event4  - Logitech Wireless Keyboard PID:4023: device is a keyboard
[     7.645] (II) event4  - Logitech Wireless Keyboard PID:4023: device removed
[     7.689] (II) libinput: Logitech Wireless Keyboard PID:4023: needs a virtual subdevice
[     7.689] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.1/0003:046D:C534.0002/0003:046D:4023.0003/input/input25/event4"
[     7.689] (II) XINPUT: Adding extended input device "Logitech Wireless Keyboard PID:4023" (type: MOUSE, id 9)
[     7.689] (**) Option "AccelerationScheme" "none"
[     7.689] (**) Logitech Wireless Keyboard PID:4023: (accel) selected scheme none/0
[     7.689] (**) Logitech Wireless Keyboard PID:4023: (accel) acceleration factor: 2.000
[     7.690] (**) Logitech Wireless Keyboard PID:4023: (accel) acceleration threshold: 4
[     7.695] (II) event4  - Logitech Wireless Keyboard PID:4023: is tagged by udev as: Keyboard
[     7.695] (II) event4  - Logitech Wireless Keyboard PID:4023: device is a keyboard
[     7.697] (**) Logitech Wireless Keyboard PID:4023: Applying InputClass "evdev keyboard catchall"
[     7.697] (**) Logitech Wireless Keyboard PID:4023: Applying InputClass "libinput keyboard catchall"
[     7.697] (**) Logitech Wireless Keyboard PID:4023: Applying InputClass "system-keyboard"
[     7.697] (**) Logitech Wireless Keyboard PID:4023: Applying InputClass "Keyboard Defaults"
[     7.697] (II) Using input driver 'libinput' for 'Logitech Wireless Keyboard PID:4023'
[     7.697] (**) Logitech Wireless Keyboard PID:4023: always reports core events
[     7.697] (**) Option "Device" "/dev/input/event4"
[     7.697] (**) Option "_source" "_driver/libinput"
[     7.697] (II) libinput: Logitech Wireless Keyboard PID:4023: is a virtual subdevice
[     7.697] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.1/0003:046D:C534.0002/0003:046D:4023.0003/input/input25/event4"
[     7.697] (II) XINPUT: Adding extended input device "Logitech Wireless Keyboard PID:4023" (type: KEYBOARD, id 13)
[     7.697] (**) Option "xkb_model" "pc105"
[     7.697] (**) Option "xkb_layout" "us"
[     7.697] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    21.013] (--) NVIDIA(GPU-0): CRT-0: disconnected
[    21.013] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[    21.013] (--) NVIDIA(GPU-0): cPATH (DFP-0): connected
[    21.013] (--) NVIDIA(GPU-0): cPATH (DFP-0): Internal LVDS
[    21.013] (--) NVIDIA(GPU-0): cPATH (DFP-0): 330.0 MHz maximum pixel clock
[    21.014] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    21.014] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    21.014] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    21.894] (--) NVIDIA(GPU-0): CRT-0: disconnected
[    21.894] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[    21.894] (--) NVIDIA(GPU-0): cPATH (DFP-0): connected
[    21.894] (--) NVIDIA(GPU-0): cPATH (DFP-0): Internal LVDS
[    21.894] (--) NVIDIA(GPU-0): cPATH (DFP-0): 330.0 MHz maximum pixel clock
[    21.894] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    21.894] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    21.894] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    82.732] (EE) event5  - Logitech Wireless Mouse: client bug: event processing lagging behind by 15ms, your system is too slow
[   193.397] (EE) event5  - Logitech Wireless Mouse: client bug: event processing lagging behind by 23ms, your system is too slow
[   420.390] (EE) event5  - Logitech Wireless Mouse: client bug: event processing lagging behind by 11ms, your system is too slow
[   422.091] (EE) event5  - Logitech Wireless Mouse: client bug: event processing lagging behind by 12ms, your system is too slow
[   436.088] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-1ms), your system is too slow
[   473.397] (EE) event5  - Logitech Wireless Mouse: client bug: event processing lagging behind by 11ms, your system is too slow
[   473.398] (EE) event5  - Logitech Wireless Mouse: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[   473.896] (II) event5  - Logitech Wireless Mouse: Enabling spurious button debouncing, see https://wayland.freedesktop.org/libinput/doc/1.18.0/button-debouncing.html for details
[  5500.240] (EE) event5  - Logitech Wireless Mouse: client bug: event processing lagging behind by 11ms, your system is too slow
[  5530.009] (EE) event5  - Logitech Wireless Mouse: client bug: event processing lagging behind by 24ms, your system is too slow
[  5530.652] (EE) event5  - Logitech Wireless Mouse: client bug: event processing lagging behind by 23ms, your system is too slow
[  5768.869] (EE) event5  - Logitech Wireless Mouse: client bug: event processing lagging behind by 11ms, your system is too slow
[  5785.371] (EE) event5  - Logitech Wireless Mouse: client bug: event processing lagging behind by 12ms, your system is too slow
[  5785.372] (EE) event5  - Logitech Wireless Mouse: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[  5952.208] (EE) client bug: timer event5 debounce: scheduled expiry is in the past (-13ms), your system is too slow
[  5952.208] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-26ms), your system is too slow
[  5975.065] (EE) event4  - Logitech Wireless Keyboard PID:4023: client bug: event processing lagging behind by 61ms, your system is too slow
[  5995.140] (EE) client bug: timer event5 debounce: scheduled expiry is in the past (-1ms), your system is too slow
[  5995.140] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-14ms), your system is too slow
[  6003.343] (EE) client bug: timer event5 debounce: scheduled expiry is in the past (-0ms), your system is too slow
[  6003.343] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-13ms), your system is too slow
[  6183.003] (EE) client bug: timer event5 debounce: scheduled expiry is in the past (-23ms), your system is too slow
[  6183.003] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-36ms), your system is too slow
[  6191.212] (EE) client bug: timer event5 debounce: scheduled expiry is in the past (-18ms), your system is too slow
[  6205.760] (EE) event4  - Logitech Wireless Keyboard PID:4023: client bug: event processing lagging behind by 58ms, your system is too slow
[  6208.509] (EE) event4  - Logitech Wireless Keyboard PID:4023: client bug: event processing lagging behind by 11ms, your system is too slow
[  6229.557] (EE) event4  - Logitech Wireless Keyboard PID:4023: client bug: event processing lagging behind by 19ms, your system is too slow
[  6239.642] (EE) event4  - Logitech Wireless Keyboard PID:4023: client bug: event processing lagging behind by 32ms, your system is too slow
[  6239.642] (EE) event4  - Logitech Wireless Keyboard PID:4023: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[  6259.664] (EE) client bug: timer event5 debounce: scheduled expiry is in the past (-32ms), your system is too slow
[  6329.147] (EE) client bug: timer event5 debounce: scheduled expiry is in the past (-38ms), your system is too slow
[  6329.147] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-51ms), your system is too slow
[  6501.263] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-0ms), your system is too slow
[ 28978.614] (EE) event5  - Logitech Wireless Mouse: client bug: event processing lagging behind by 14ms, your system is too slow
[ 29518.368] (EE) event5  - Logitech Wireless Mouse: client bug: event processing lagging behind by 15ms, your system is too slow
[ 29587.166] (EE) event5  - Logitech Wireless Mouse: client bug: event processing lagging behind by 14ms, your system is too slow
[ 29587.166] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-2ms), your system is too slow
[ 29857.545] (EE) event5  - Logitech Wireless Mouse: client bug: event processing lagging behind by 21ms, your system is too slow
[ 37082.894] (EE) event5  - Logitech Wireless Mouse: client bug: event processing lagging behind by 11ms, your system is too slow
[ 37246.451] (EE) event5  - Logitech Wireless Mouse: client bug: event processing lagging behind by 11ms, your system is too slow
[ 37246.554] (EE) event5  - Logitech Wireless Mouse: client bug: event processing lagging behind by 14ms, your system is too slow
[ 37278.632] (EE) event5  - Logitech Wireless Mouse: client bug: event processing lagging behind by 13ms, your system is too slow
[ 37410.325] (EE) event5  - Logitech Wireless Mouse: client bug: event processing lagging behind by 13ms, your system is too slow
[ 37410.325] (EE) event5  - Logitech Wireless Mouse: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 37756.255] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-1ms), your system is too slow
[ 37996.455] (EE) event4  - Logitech Wireless Keyboard PID:4023: client bug: event processing lagging behind by 23ms, your system is too slow
[ 38155.459] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-2ms), your system is too slow
[ 38687.002] (--) NVIDIA(GPU-0): CRT-0: disconnected
[ 38687.003] (--) NVIDIA(GPU-0): CRT-0: 400.0 MHz maximum pixel clock
[ 38687.003] (--) NVIDIA(GPU-0): cPATH (DFP-0): connected
[ 38687.003] (--) NVIDIA(GPU-0): cPATH (DFP-0): Internal LVDS
[ 38687.003] (--) NVIDIA(GPU-0): cPATH (DFP-0): 330.0 MHz maximum pixel clock
[ 38687.003] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 38687.003] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[ 38687.003] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[ 38694.316] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-1ms), your system is too slow
Regarding your question, I have tried 5.4 kernel and the problem persisted since then
What do you mean it is not using your video card? I see you have one card, and apparently have no issue using your computer to reply here.
I mean while I have my gpu and its driver installed, my laptop relies solely on my integrated intel gpu that comes with the processor.
What lead me into that is the nvidia-smi output, the gpu ram consumption does not change with load. And the constant lag and unability to watch HD videos without getting my pc to heat up is what made me suspect that in the first place.
I don’t see a second graphic processor here. There is only one device. MHWD output also doesn’t show that.
Sure, but what about the symptoms I mentioned?
I don’t know, but from the information I see you do not have a second GPU, and the Nvidia GPU seems to be properly installed and in use.
Now I see something in nvidia-smi, I need to check but that reminds me about another thread. The video card performance level is at P8. Need to check what it means.
//EDIT:
Detailed Description
The GPU performance state APIs are used to get and set various performance levels on a per-GPU basis. P-States are GPU active/executing performance capability and power consumption states.
P-States range from P0 to P15, with P0 being the highest performance/power state, and P15 being the lowest performance/power state. Each P-State maps to a performance level. Not all P-States are available on a given system. The definition of each P-States are currently as follows:
P0/P1 - Maximum 3D performance
P2/P3 - Balanced 3D performance-power
P8 - Basic HD video playback
P10 - DVD playback
P12 - Minimum idle power consumption
//EDIT2: what happens if you plug the power supply, shutdown the computer, and then boot the computer with the power supply plugged in? Do you see the same bad performance?
My battery does not perform well so I always have the power cable plugged in.
Can we conclude that the gpu is stuck at that P-State ?
Nope we can’t based on the information we have but that reminded me this thread Laptop Nvidia Gpu frequency locked to 33mhz after unplugging from power - #2 by omano which is still not closed (the guy didn’t connect to forum since long time).
I don’t own a laptop I only have one under my eyes from time to time for friends and family, so I’m not sure how to troubleshoot your issue.
First explain in more details the exact issues you have.
“constant lag and unability to watch HD videos” is pretty vague (what is lag for you, where, how to reproduce? what type of HD videos, how do you play it?).
Maybe check Nvidia Settings application to see if you can gather relevant information too.
PS: if your CPU is supposed to have an integrated video chip (which in theory it has?), where is it? Did you disable it in the BIOS?
I agree with @Omano: your system is correctly set up, but your card is showing its age and its performance is comparable to a modern Intel card:
Brand Model Rank Benchmark Samples URL
Intel Iris 540 (Mobile Skylake) 306 7.1 4607 UserBenchmark: Intel Iris 540 (Mobile Skylake)
Nvidia GeForce GTX 460M 309 6.96 3183 UserBenchmark: Nvidia GeForce GTX 460M
However, one thing we haven’t checked is the compositor in KDE:
  • Go to System Settings
  • Type composi
  • Click Compositor
  • Ensure the compositor is enabled at startup
  • You might have to choose OpenGL 2.0 instead of 3.0
After changing these settings, test again
:crossed_fingers:
I think you’re right.
I’ve done the Compositor settings just like you showed me, and I’ve tinkered a little bit with tlpui and set the power settings the way it should be to avoid being bottle-necked by the battery.
I compared some games’ performance among windows and Manjaro. Minecraft for example gives up to 90 fps in both Manjaro and windows.
nvidia-smi gives the desired output:
Fri Aug 13 15:44:22 2021
| NVIDIA-SMI 390.144                Driver Version: 390.144                   |
| N/A   54C    P0    N/A /  N/A |    163MiB /  1473MiB |     N/A      Default |
|    0                    Not Supported                                       |
It’s now in P0 and everything is fine. GPU is not crashing nor slow anymore. But I think It’s just getting old.
Another tip to put in mind is to never buy an Intel/Nvidia laptop anymore.
Thanks again everyone.
My bios does not have the option to disable or enable GPU.
The inability to watch HD videos meant I couldn’t watch Youtube videos for example without lag and slow performance. Now that I set my tlpui and compositor settings right, everything is working like it should be.
